[Mapbender-commits] r1636 - trunk/mapbender/http/classes
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Wed Aug 8 11:32:31 EDT 2007
Author: christoph
Date: 2007-08-08 11:32:31 -0400 (Wed, 08 Aug 2007)
New Revision: 1636
   trunk/mapbender/http/classes/class_bbox.php
php5 oo approach
Modified: trunk/mapbender/http/classes/class_bbox.php
--- trunk/mapbender/http/classes/class_bbox.php	2007-08-08 14:26:34 UTC (rev 1635)
+++ trunk/mapbender/http/classes/class_bbox.php	2007-08-08 15:32:31 UTC (rev 1636)
@@ -1,6 +1,6 @@
 <?php
 # $Id$
-# http://www.mapbender.org/index.php/Mod_treefolder2.php
+# http://www.mapbender.org/index.php/
 # Copyright (C) 2002 CCGIS
 # This program is free software; you can redistribute it and/or modify
@@ -45,21 +45,21 @@
 	 * computes a new point with the minimal coordinates of this point and $point
-	function min ($point) {
-		if ($this->epsg == $point->epsg) {
-			if ($this->isWestOf($point)) {
-				$minx = $this->x;
+	static function min ($point1, $point2) {
+		if ($point1->epsg == $point2->epsg) {
+			if ($point1->isWestOf($point2)) {
+				$minx = $point1->x;
 			else {
-				$minx = $point->x;
+				$minx = $point2->x;
-			if ($this->isSouthOf($point)) {
-				$miny = $this->y;
+			if ($point1->isSouthOf($point2)) {
+				$miny = $point1->y;
 			else {
-				$miny = $point->y;
+				$miny = $point2->y;
-			return new Mapbender_point($minx, $miny, $this->epsg);
+			return new Mapbender_point($minx, $miny, $point1->epsg);
 		else {
 			$e = new mb_exception("Mapbender_point: cannot process min with different EPSG codes");
@@ -69,21 +69,21 @@
 	 * computes a new point with the maximal coordinates of this point and $point
-	function max ($point) {
-				$maxx = $point->x;
+	static function max ($point1, $point2) {
+				$maxx = $point2->x;
 			else {
-				$maxx = $this->x;
+				$maxx = $point1->x;
-				$maxy = $point->y;
+				$maxy = $point2->y;
 			else {
-				$maxy = $this->y;
+				$maxy = $point1->y;
-			return new Mapbender_point($maxx, $maxy, $this->epsg);
+			return new Mapbender_point($maxx, $maxy, $point1->epsg);
 		else {
@@ -122,8 +122,8 @@
-	function toString() {
-		return "(" . $this->x . "," . $this->y . "," . $this->epsg . ")";
+	function __toString() {
+		return (string) "(" . $this->x . "," . $this->y . "," . $this->epsg . ")";
@@ -155,26 +155,40 @@
-	 * Computes a new bounding box, this bbox UNION $bbox
+	 * Computes a new bounding box, bbox1 UNION bbox2
-	function union ($bbox) {
-		if ($this->isValid()) {
-			if ($bbox != null && $bbox->isValid()) {
-				if ($this->epsg == $bbox->epsg) {
-					return new Mapbender_bbox($this->min->min($bbox->min), $this->max->max($bbox->max), $this->epsg);
+	static function union ($bboxArray) {
+		if (count($bboxArray) == 1) {
+			return array_pop($bboxArray);
+		elseif (count($bboxArray) >= 2) {
+			$bbox1 = array_pop($bboxArray);
+			$bbox2 = Mapbender_bbox::union($bboxArray);
+			if (!($bbox1 != null && $bbox1->isValid()) && !($bbox2 != null && $bbox2->isValid())) {
+				$e = new mb_notice("Mapbender_bbox: union: both parameters invalid!");
+				return null;
+			elseif (!($bbox1 != null && $bbox1->isValid()) && ($bbox2 != null && $bbox2->isValid())) {
+				$e = new mb_notice("Mapbender_bbox: union: first parameter invalid!");
+				return $bbox2;
+			elseif (($bbox1 != null && $bbox1->isValid()) && !($bbox2 != null && $bbox2->isValid())) {
+				$e = new mb_notice("Mapbender_bbox: union: second parameter invalid!");
+				return $bbox1;
+			else {
+				if ($bbox1->epsg == $bbox2->epsg) {
+					return new Mapbender_bbox(Mapbender_point::min($bbox1->min, $bbox2->min), Mapbender_point::max($bbox1->max, $bbox2->max), $bbox1->epsg);
 				else {
-					$e = new mb_exception("mapbender_bbox: cannot process union with different EPSG codes");
+					$e = new mb_exception("Mapbender_bbox: cannot process union with different EPSG codes");
-			else {
-				$e = new mb_notice("mapbender_bbox: union: second parameter not a bbox, returning first bbox");
-				return new Mapbender_bbox($this->min, $this->max, $this->epsg);
-			$e = new mb_notice("mapbender_bbox: union: first parameter not a bbox, returning second bbox");
-			return $bbox;
+		else {
+			$e = new mb_exception("Mapbender_bbox: Invalid parameter (Not an array)!");
 		return null;
@@ -203,8 +217,8 @@
 		return false;
-		return "[" . $this->min->toString() . $this->max->toString() . " " . $this->epsg . "]";
+		return (string) "[" . $this->min . $this->max . " " . $this->epsg . "]";
\ No newline at end of file
More information about the Mapbender_commits mailing list
