[Mapbender-commits] r1642 - trunk/mapbender/http/php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Aug 9 04:52:57 EDT 2007
Author: christoph
Date: 2007-08-09 04:52:57 -0400 (Thu, 09 Aug 2007)
New Revision: 1642
Added:
   trunk/mapbender/http/php/mod_button_tooltips.php
i18n of buttons
Added: trunk/mapbender/http/php/mod_button_tooltips.php
--- trunk/mapbender/http/php/mod_button_tooltips.php	                        (rev 0)
+++ trunk/mapbender/http/php/mod_button_tooltips.php	2007-08-09 08:52:57 UTC (rev 1642)
@@ -0,0 +1,43 @@
+<?php
+#$Id: mod_insertWmcIntoDb.php 507 2006-11-20 10:55:57Z christoph $
+#$Header: /cvsroot/mapbender/mapbender/http/javascripts/mod_insertWmcIntoDb.php,v 1.19 2006/03/09 14:02:42 uli_rothstein Exp $
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+require_once(dirname(__FILE__)."/../../conf/mapbender.conf");
+require_once(dirname(__FILE__)."/../extensions/JSON.php");
+require_once(dirname(__FILE__)."/../classes/class_mb_exception.php");
+session_start();
+$con = db_connect(DBSERVER,OWNER,PW);
+db_select_db(DB,$con);
+$buttonObj = array();
+$sql = "SELECT e_id, gettext($1, e_title) AS e_title FROM gui_element WHERE fkey_gui_id = $2 AND e_element = 'img'";
+$v = array($_SESSION["mb_lang"], $_SESSION["mb_user_gui"]);
+$t = array("s", "s");
+$res = db_prep_query($sql, $v, $t);
+while ($row = db_fetch_array($res)) {
+	array_push($buttonObj, array("id" => $row["e_id"], "title" => $row["e_title"]));
+$json = new Services_JSON();
+$output = $json->encode($buttonObj);
+header("Content-type:text/plain; Charset='UTF-8'");
+echo $output;
\ No newline at end of file
More information about the Mapbender_commits mailing list
