[Mapbender-commits] r1648 - trunk/mapbender/resources/db/update
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Aug 9 09:15:11 EDT 2007
Author: astrid_emde
Date: 2007-08-09 09:15:11 -0400 (Thu, 09 Aug 2007)
New Revision: 1648
   trunk/mapbender/resources/db/update/update_mysql_db.sql
database changes for version 2.5, function has to be translated
Modified: trunk/mapbender/resources/db/update/update_mysql_db.sql
--- trunk/mapbender/resources/db/update/update_mysql_db.sql	2007-08-09 13:14:14 UTC (rev 1647)
+++ trunk/mapbender/resources/db/update/update_mysql_db.sql	2007-08-09 13:15:11 UTC (rev 1648)
@@ -1,4 +1,39 @@
 -- no changes in version 2.4.2
+-- notice language plpgsql has to be installed
+-- table wfs_conf_element: change in WFS configuration: access to geometries may now be restricted
+ ALTER TABLE wfs_conf_element ADD COLUMN f_auth_varname VARCHAR(50) NULL;
+-- table gui_element: new column for translation
+ ALTER TABLE gui_element ADD COLUMN e_title VARCHAR(255) NULL;
+-- new table translation: new table for translations
+ CREATE TABLE translations
+   trs_id int(11) NOT NULL auto_increment,
+   locale varchar(8),
+   msgid varchar(512),
+   msgstr varchar(512),
+   PRIMARY KEY (trs_id)
+ CREATE INDEX msgid_idx ON translations(msgid);
+-- new function gettext for easy translations
+-- function has to be translated
More information about the Mapbender_commits mailing list
