[Mapbender-commits] r1654 - trunk/mapbender/http/php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri Aug 10 05:10:51 EDT 2007
Author: christoph
Date: 2007-08-10 05:10:50 -0400 (Fri, 10 Aug 2007)
New Revision: 1654
   trunk/mapbender/http/php/mod_editWMS_Metadata.php
   trunk/mapbender/http/php/mod_exportElement.php
   trunk/mapbender/http/php/mod_exportGUI.php
   trunk/mapbender/http/php/mod_getStyles.php
   trunk/mapbender/http/php/mod_layerMetadata.php
new column e_title in gui_element
fixed faulty preg_replace call
Modified: trunk/mapbender/http/php/mod_editWMS_Metadata.php
--- trunk/mapbender/http/php/mod_editWMS_Metadata.php	2007-08-10 09:09:40 UTC (rev 1653)
+++ trunk/mapbender/http/php/mod_editWMS_Metadata.php	2007-08-10 09:10:50 UTC (rev 1654)
@@ -132,7 +132,7 @@
         if(preg_match("/___/", $key))
             $myKey = explode("___", $key);
-            $layer_id = preg_replace("L_","",$myKey[0]);
+            $layer_id = preg_replace("/L_/","",$myKey[0]);
             if($myKey[1]=="layer_abstract")
                 $layer_sql = "UPDATE layer SET layer_abstract = '$val' " .
Modified: trunk/mapbender/http/php/mod_exportElement.php
--- trunk/mapbender/http/php/mod_exportElement.php	2007-08-10 09:09:40 UTC (rev 1653)
+++ trunk/mapbender/http/php/mod_exportElement.php	2007-08-10 09:10:50 UTC (rev 1654)
@@ -50,6 +50,7 @@
       $insert .=  "e_pos, ";
       $insert .=  "e_public, ";
       $insert .=  "e_comment, ";
+      $insert .=  "e_title, ";
       $insert .=  "e_element, ";
       $insert .=  "e_src, ";
       $insert .=  "e_attributes, ";
@@ -72,6 +73,7 @@
       $insert .=  "".$row["e_pos"]. ",";
       $insert .=  "".$row["e_public"]. ",";
       $insert .=  "'".db_escape_string($row["e_comment"])."',";
+      $insert .=  "'".db_escape_string($row["e_title"])."',";
       $insert .=  "'".$row["e_element"]."',";
       $insert .=  "'".$row["e_src"]."',";
       $insert .=  "'".db_escape_string($row["e_attributes"])."',";
@@ -89,7 +91,7 @@
       $insert .=  "'".$row["e_requires"]."',";
       $insert .=  "'".$row["e_url"]."'";
    $insert .=  ");\n";
-   $insert = preg_replace(",,", ",NULL ,", $insert);
+   $insert = preg_replace("/,,/", ",NULL ,", $insert);
 	# export element vars
@@ -114,13 +116,13 @@
       $insert .=  "'".db_escape_string($row["context"])."' ,";
       $insert .=  "'".db_escape_string($row["var_type"])."'";
    	$insert .=  ");\n";
    	$cnt_res++;
    echo "<textarea rows=30 cols=100>";
-    echo preg_replace(", ,", ",NULL ,", $insert);
+    echo preg_replace("/, ,/", ",NULL ,", $insert);
    echo "</textarea>";
Modified: trunk/mapbender/http/php/mod_exportGUI.php
--- trunk/mapbender/http/php/mod_exportGUI.php	2007-08-10 09:09:40 UTC (rev 1653)
+++ trunk/mapbender/http/php/mod_exportGUI.php	2007-08-10 09:10:50 UTC (rev 1654)
@@ -88,7 +88,7 @@
 	$cnt_gel = 0;
 	while ($row = db_fetch_array($res_gel)){
-		$insert.="INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element,";
+		$insert.="INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,";
 		$insert.="e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles,";
 		$insert.=" e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES (";
@@ -97,6 +97,7 @@
 		$insert.="".$row["e_pos"].",";
 		$insert.="".$row["e_public"].",";
 		$insert.="'".db_escape_string($row["e_comment"])."',";
+		$insert.="'".db_escape_string($row["e_title"])."',";
 		$insert.="'".$row["e_element"]."',";
 		$insert.="'".$row["e_src"]."',";
 		$insert.="'".db_escape_string($row["e_attributes"])."',";
@@ -114,7 +115,7 @@
 		$insert.="'".$row["e_requires"]."',";
 		$insert.="'".$row["e_url"]."'";
 		$insert.= ");\n";
@@ -142,8 +143,8 @@
 				$insert.=", ";
 			$temp = db_escape_string($row[$i]);
-			$temp = preg_replace(">","&gt;",$temp);
-			$temp = preg_replace("<","&lt;",$temp);
+			$temp = preg_replace("/>/","&gt;",$temp);
+			$temp = preg_replace("/</","&lt;",$temp);
 			$insert.="'" . $temp . "'";
 			$i++;
@@ -153,8 +154,8 @@
-	$insert = preg_replace(",,",",NULL,",$insert);
-	$insert = preg_replace(", ,", ",NULL,",$insert);
+	$insert = preg_replace("/,,/",",NULL,",$insert);
+	$insert = preg_replace("/, ,/", ",NULL,",$insert);
 	echo "<textarea rows=40 cols=80>";
 	echo $insert;
Modified: trunk/mapbender/http/php/mod_getStyles.php
--- trunk/mapbender/http/php/mod_getStyles.php	2007-08-10 09:09:40 UTC (rev 1653)
+++ trunk/mapbender/http/php/mod_getStyles.php	2007-08-10 09:10:50 UTC (rev 1654)
@@ -168,8 +168,8 @@
 if($style_filename){
 	$style_file = fopen($style_filename,"r");
 	while(!feof($style_file)){
-		$content = preg_replace("<","&lt;",fgets($style_file));
-		echo preg_replace(">","&gt;",$content)."<br>";
+		$content = preg_replace("/</","&lt;",fgets($style_file));
+		echo preg_replace("/>/","&gt;",$content)."<br>";
 	fclose($style_file);
Modified: trunk/mapbender/http/php/mod_layerMetadata.php
--- trunk/mapbender/http/php/mod_layerMetadata.php	2007-08-10 09:09:40 UTC (rev 1653)
+++ trunk/mapbender/http/php/mod_layerMetadata.php	2007-08-10 09:10:50 UTC (rev 1654)
@@ -106,7 +106,7 @@
 		$layer['Minscale'] = $row['layer_minscale'];
 		$layer['Maxscale'] = $row['layer_maxscale'];
-	$layer['Koordinatensysteme'] = preg_replace(" ", ", ", getEpsgByLayerId($row['layer_id']));
+	$layer['Koordinatensysteme'] = preg_replace("/ /", ", ", getEpsgByLayerId($row['layer_id']));
 //	$layer['Capabilities-Dokument'] = "<a href = '../x_geoportal/getCapabilities_document.php?wms_request=".$row['wms_id']."&layer_request=".$row['layer_pos']."' target=_blank>Capabilities-Dokument</a>";
 	if ($row['wms_timestamp']) {
 		$layer['Datum der Registrierung'] = date("d.m.Y",$row['wms_timestamp']);
More information about the Mapbender_commits mailing list
