[Mapbender-commits] r1097 - trunk/mapbender/http/php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Feb 8 10:06:59 EST 2007
Author: christoph
Date: 2007-02-08 10:06:54 -0500 (Thu, 08 Feb 2007)
New Revision: 1097
Removed:
   trunk/mapbender/http/php/mod_digitize.php
deprecated
Deleted: trunk/mapbender/http/php/mod_digitize.php
--- trunk/mapbender/http/php/mod_digitize.php	2007-02-08 14:51:19 UTC (rev 1096)
+++ trunk/mapbender/http/php/mod_digitize.php	2007-02-08 15:06:54 UTC (rev 1097)
@@ -1,427 +0,0 @@
-<?php
-# $Id$
-# http://www.mapbender.org/index.php/mod_digitize.php
-# Copyright (C) 2002 CCGIS
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2, or (at your option)
-# any later version.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
-# GNU General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-require_once(dirname(__FILE__)."/../../conf/mapbender.conf");
-	<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
-	<html>
-	<head>
-	<meta http-equiv="cache-control" content="no-cache">
-	<meta http-equiv="pragma" content="no-cache">
-	<meta http-equiv="expires" content="0">
-	<?php
-	echo '<meta http-equiv="Content-Type" content="text/html; charset='.CHARSET.'">';
-	<title>Digitize</title>
-	<?php
-	   include '../include/dyn_css.php';
-	<style type="text/css">
-		body{
-			font-family: Arial, Helvetica, sans-serif;
-			font-size : 12px;
-			color: #ffffff;
-			background-color: lightgray;
-			margin-top: 0px;
-			margin-left: 0px;
-		.button{
-			height: 18px;
-			width: 32px;
-	</style>
-	<script language='JavaScript'>
-	<?php
-	echo "var mod_digitize_target = '".$_REQUEST["target"]."';";
-	//public
-	var mod_digitize_color1 = "white";
-	var mod_digitize_color2 = "black";
-	var mod_digitize_font = "Arial, Helvetica, sans-serif";
-	var mod_digitize_fontsize = "9px";
-	var mod_digitize_basepoint = "#8a2be2";
-	var mod_digitize_linepoint = "#ff00ff";
-	var mod_digitize_bg = "";
-	var mod_digitize_elName = "digitize_frame"
-	var mod_digitize_frameName = "";
-	// constructor - object:
-	var D = new Array();
-	function register_D(type){
-		var id = D.length;
-		if(id > 0){
-			var check = val_D(id);
-			if(check == false){
-				id -= 1;
-		D[id] = new const_D(id, type);
-	function const_D(id,type){
-		this.id = id;
-		this.type = type;
-		this.x = new Array();
-		this.y = new Array();
-		this.label = "";
-		var ind = parent.getMapObjIndexByName(mod_digitize_target);
-		this.epsg = parent.mb_mapObj[ind].epsg;
-		this.units = "";
-		this.dist = new Array();
-		this.totaldist = new Array();
-		this.complete = false;
-	function val_D(id){
-		if(D[(id - 1)].x.length == 0){
-			return false;
-		else{
-			return true;
-	var isOn = true;
-	var mod_digitize_width;
-	var mod_digitize_height;
-	var mod_digitize_Dist = new Array();
-	var mod_digitize_TotalDist = new Array();
-	var mod_digitizeSubFunctions = new Array();
-	var mod_digitizeEvent = false;
-	var bp_active  = false;
-	var bp_obj = false;
-	var bp_geom = false;
-	var bp_p = false;
-	var start_x = false;
-	var start_y = false;
-	var end_x = false;
-	var end_y = false;
-	function mod_digitize_go(){
-		parent.mb_registerGML(mod_digitize_target,D);
-		parent.document.getElementById(mod_digitize_elName).style.visibility = 'visible';
-		var el = parent.frames[mod_digitize_target].document;
-		el.onmousedown = mod_digitize_start;
-		//el.onmousemove = mod_digitize_run;
-		mod_digitize_width = parent.mb_mapObj[ind].width;
-		mod_digitize_height = parent.mb_mapObj[ind].height;
-		//mod_digitize_epsg = parent.mb_mapObj[ind].epsg;
-	function mod_digitize_disable(){
-		isOn = false;
-		parent.document.getElementById(mod_digitize_elName).style.visibility = 'hidden';
-		el.onmousedown = null;
-		el.onmouseup = null;
-		el.onmousemove = null;
-		drawDashedLine();
-	function mod_digitize_timeout(){
-	var el = parent.window.frames[mod_digitize_target].document;
-	el.ondblclick = null;
-	function mod_digitize_start(e){
-		isOn = true;
-		if(D[D.length -1].complete == true || (D.length == 0)){
-			alert("Geometrie muss ausgewählt sein!");
-			return true;
-		parent.mb_getMousePos(e,mod_digitize_target);
-		var realWorldPos = parent.makeClickPos2RealWorldPos(mod_digitize_target,parent.clickX,parent.clickY);
-		D[D.length-1].x[D[D.length-1].x.length] = Math.round(realWorldPos[0] * 100)/100;
-		D[D.length-1].y[D[D.length-1].y.length] = Math.round(realWorldPos[1] * 100)/100;
-		if(D[D.length-1].type == 'text'){
-			var l = prompt("Beschriftung: ","");
-			if(l != null){
-				D[D.length-1].label = l;
-				D[D.length-1].complete = true;
-		drawDashedLine();
-		return true;
-	function drawDashedLine(){
-		var smP = "";
-		smP += "<div class='t_img'>";
-		smP += "<img src='"+parent.mb_trans.src+"' width='"+mod_digitize_width+"' height='0'></div>";
-		smP += "<img   src='"+parent.mb_trans.src+"' width='0' height='"+mod_digitize_height+"'></div>";
-		for(var j=0; j<D.length; j++){
-			for(var i=0; i<D[j].x.length; i++){
-				var pos = parent.makeRealWorld2mapPos(mod_digitize_target,D[j].x[i],D[j].y[i]);
-				if(D[j].type != 'text' || (D[j].type == 'point' && D[j].label =="")){
-					smP += "<div class='bp' style='top:"+(pos[1]-2)+"px;left:"+(pos[0]-2)+"px;'";
-					if(i==0 && D[j].type == 'polygon' && D[j].complete == false){
-						smP += " title='close polygon' ";
-					if(isOn){
-						smP += " onmouseover='parent.window.frames[\""+mod_digitize_elName+"\"].mobp(this,"+j+","+i+")' ;"
-						smP += " onmouseout='parent.window.frames[\""+mod_digitize_elName+"\"].mod_digitize_go()' ";
-					smP += "></div>";
-				//label:
-				if(i == 0 && D[j].label != ""){
-					smP += "<div class='label' style='top:"+(pos[1]-6)+"px;left:"+(pos[0])+"px'>"+D[j].label+"</div>";
-			if(D[j].x.length>1){
-				for(var k=1; k<D[j].x.length; k++){
-					var pos0 = parent.makeRealWorld2mapPos(mod_digitize_target,D[j].x[k], D[j].y[k]);
-					var pos1 = parent.makeRealWorld2mapPos(mod_digitize_target,D[j].x[k-1], D[j].y[k-1]);
-					smP += evaluateDashes(pos1[0],pos1[1],pos0[0],pos0[1],k,j,k);
-		parent.writeTag(mod_digitize_target,"digitize",smP);
-	function evaluateDashes(x1,y1,x2,y2,count,geom,p){
-		var str_dashedLine = "";
-		var s = 10;
-		var d = Math.sqrt(Math.pow((y1-y2),2) + Math.pow((x1-x2),2)) ;
-		var n = Math.round(d/s);
-		var s_x =  (x2 - x1)/n;
-		var s_y =  (y2 - y1)/n;
-		for(var i=1; i<n; i++){
-			var x = Math.round(x1 + i * s_x)-2;
-			var y = Math.round(y1 + i * s_y)-2;
-			if(x >= 0 && x <= mod_digitize_width && y >= 0 && y <= mod_digitize_height){
-				str_dashedLine += "<div class='lp' style='top:"+y+"px;left:"+x+"px;z-index:50;' ";
-				if(isOn){
-					str_dashedLine += "onmouseover='parent.window.frames[\""+mod_digitize_elName+"\"].lp2bp(this,"+geom+","+p+")'>";
-				str_dashedLine += "</div>";
-		return str_dashedLine;
-	function mobp(Obj,geom,p){
-		if(!isOn){ return false; };
-		bp_obj = Obj;
-		bp_geom = geom;
-		bp_p = p;
-		if(mod_digitizeEvent == "dragBasePoint"){
-			mod_digitize_timeout();
-			Obj.style.cursor = 'move';
-			Obj.onmousedown = parent.window.frames[mod_digitize_elName].bp_down;
-		if(mod_digitizeEvent == false && D[geom].type == 'polygon' && D[geom].complete == false){
-			Obj.onmousedown = parent.window.frames[mod_digitize_elName].close_Pol;
-		if(mod_digitizeEvent == "delBasePoint"){
-			Obj.style.cursor = 'crosshair';
-			Obj.onmousedown = parent.window.frames[mod_digitize_elName].delete_bp;
-	function delete_bp(e){
-		for(var i= bp_p; i<D[bp_geom].x.length; i++){
-			D[bp_geom].x[i] = D[bp_geom].x[i+1];
-			D[bp_geom].y[i] = D[bp_geom].y[i+1];
-		D[bp_geom].x.length = D[bp_geom].x.length -1;
-		D[bp_geom].y.length = D[bp_geom].y.length -1;
-		drawDashedLine();
-	function close_Pol(e){
-		if(!isOn){ return; };
-		D[bp_geom].complete = true;
-		D[bp_geom].x[D[bp_geom].x.length] = D[bp_geom].x[0];
-		D[bp_geom].y[D[bp_geom].y.length] = D[bp_geom].y[0];
-		close_D();
-		drawDashedLine();
-	function lp2bp(obj,geom,p){
-		if(mod_digitizeEvent == "setBasePoint"){
-			obj.style.cursor = 'crosshair';
-			obj.onclick = set_bp;
-			bp_obj = obj;
-			bp_geom = geom;
-			bp_p = p;
-	function set_bp(e){
-		parent.mb_getMousePos(e);
-		var pos = parent.makeClickPos2RealWorldPos(mod_digitize_target,parent.clickX, parent.clickY);
-		for(var i=D[bp_geom].x.length; i>bp_p; i--){
-			D[bp_geom].x[i] = D[bp_geom].x[i-1];
-			D[bp_geom].y[i] = D[bp_geom].y[i-1];
-		D[bp_geom].x[bp_p] = pos[0];
-		D[bp_geom].y[bp_p] = pos[1];
-		drawDashedLine();
-	function set_D(obj){
-		register_D(obj.value);
-	function close_D(){
-		if(D.length > 0){
-			D[D.length -1].complete = true;
-		for(var i=0; i<D.length; i++){
-			if(D[i].complete == true && D[i].type == 'polygon' && D[i].x[0] != D[i].x[D[i].x.length-1]){
-				D[i].x[D[i].x.length] = D[i].x[0];
-				D[i].y[D[i].y.length] = D[i].y[0];
-				drawDashedLine();
-		for(var i=0; i<document.dig.geomType.length; i++){
-			document.dig.geomType[i].checked = false;
-		parent.mb_obj2gml("mapframe1");
-	function del_D(){
-		D = new Array();
-		drawDashedLine();
-	function bp_down(e){
-	if(bp_active == false && mod_digitizeEvent == "dragBasePoint"){
-	bp_obj.onmouseup = bp_up;
-	bp_obj.onmousemove = bp_drag;
-	start_x = parent.clickX;
-	start_y = parent.clickY;
-	end_x = parent.clickX;
-	end_y = parent.clickY;
-	bp_active = true;
-	return false;
-	function bp_up(e){
-		//document.onmouseup = null;
-		//document.onmousemove = null;
-		bp_active = false;
-		var pos =  parent.makeClickPos2RealWorldPos(mod_digitize_target,end_x, end_y);
-		if ( (bp_p == D[bp_geom].x.length - 1 || bp_p == 0) && D[bp_geom].complete == true && D[bp_geom].type == 'polygon') {
-			D[bp_geom].x[0] = pos[0];
-			D[bp_geom].y[0] = pos[1];
-		drawDashedLine();
-	function bp_drag(e){
-	if(bp_active){
-	bp_obj.style.backgroundColor = 'transparent';
-	bp_obj.style.width = 30;
-	bp_obj.style.height = 30;
-	bp_obj.style.left = start_x + (end_x - start_x) - (parseInt(bp_obj.style.width)/2);
-	bp_obj.style.top = start_y + (end_y - start_y) - (parseInt(bp_obj.style.height)/2);
-	function setEvent(obj){
-		mod_digitizeEvent = obj.value;
-	function delEvent(){
-		mod_digitizeEvent = false;
-			document.modify.mod[i].checked = false;
-		mod_digitize_go();
-	</script>
-	</head>
-	<body>
-	<form name='dig'>
-	<table cellpadding='0' cellspacing='0'>
-	<tr>
-		<td><input type='radio' name='geomType' value='text' onclick='set_D(this)'></td>
-		<td><img src="../img/button_digitize/14_text.png" width='18' height='18'></td>
-		<td><input class='button' type='button' value='ok' onclick='close_D()'></td>
-	</tr>
-	<tr>
-		<td><input type='radio' name='geomType' value='line' onclick='set_D(this)'></td>
-		<td><img src="../img/button_digitize/line.png" width='18' height='18'></td>
-		<td><input class='button' type='button' value='del' onclick='del_D()'></td>
-	</tr>
-	<tr>
-		<td><input type='radio' name='geomType' value='polygon' onclick='set_D(this)'></td>
-		<td><img src="../img/button_digitize/14_polyline.png" width='18' height='18'></td>
-		<td></td>
-	</tr>
-	</table>
-	</form>
-	<form name='modify'>
-	<tr>
-		<td><input name='mod'  value='dragBasePoint' type='radio'  onclick='setEvent(this)'></td>
-		<td><img src='../img/button_digitize/move.png'></td>
-		<td><input class='button' type='button' value='del' onclick='delEvent()'></td>
-	</tr>
-	<tr>
-		<td><input name='mod' value='setBasePoint' type='radio'  onclick='setEvent(this)'></td>
-		<td><img src='../img/button_digitize/newNode.png'></td>
-		<td></td>
-	</tr>
-	<tr>
-		<td><input name='mod' value='delBasePoint' type='radio'  onclick='setEvent(this)'></td>
-		<td><img src='../img/button_digitize/14_layer_deletelayer.png'></td>
-		<td></td>
-	</tr>
-	</table>
-	</form>
-	</body>
-	</html>
\ No newline at end of file
More information about the Mapbender_commits mailing list
