[Mapbender-commits] r1101 - trunk/mapbender/http/javascripts
    svn_mapbender at osgeo.org
    Thu Feb  8 10:21:37 EST 2007
Author: christoph
Date: 2007-02-08 10:21:27 -0500 (Thu, 08 Feb 2007)
New Revision: 1101
Removed:
   trunk/mapbender/http/javascripts/ajax_jquery.js
moved to extensions folder
Deleted: trunk/mapbender/http/javascripts/ajax_jquery.js
--- trunk/mapbender/http/javascripts/ajax_jquery.js	2007-02-08 15:20:56 UTC (rev 1100)
+++ trunk/mapbender/http/javascripts/ajax_jquery.js	2007-02-08 15:21:27 UTC (rev 1101)
@@ -1,1827 +0,0 @@
- * jQuery - New Wave Javascript
- * Copyright (c) 2006 John Resig (jquery.com)
- * Dual licensed under the MIT (MIT-LICENSE.txt)
- * and GPL (GPL-LICENSE.txt) licenses.
- * $Date: 2006-08-31 13:26:31 -0400 (Thu, 31 Aug 2006) $
- * $Rev: 249 $
-// Global undefined variable
-window.undefined = window.undefined;
-function jQuery(a,c) {
-	// Shortcut for document ready (because $(document).each() is silly)
-	if ( a && a.constructor == Function && jQuery.fn.ready )
-		return jQuery(document).ready(a);
-	// Make sure that a selection was provided
-	a = a || jQuery.context || document;
-	// Watch for when a jQuery object is passed as the selector
-	if ( a.jquery )
-		return $( jQuery.merge( a, [] ) );
-	// Watch for when a jQuery object is passed at the context
-	if ( c && c.jquery )
-		return $( c ).find(a);
-	// If the context is global, return a new object
-	if ( window == this )
-		return new jQuery(a,c);
-	// Handle HTML strings
-	var m = /^[^<]*(<.+>)[^>]*$/.exec(a);
-	if ( m ) a = jQuery.clean( [ m[1] ] );
-	// Watch for when an array is passed in
-	this.get( a.constructor == Array || a.length && !a.nodeType && a[0] != undefined && a[0].nodeType ?
-		// Assume that it is an array of DOM Elements
-		jQuery.merge( a, [] ) :
-		// Find the matching elements and save them for later
-		jQuery.find( a, c ) );
-  // See if an extra function was provided
-	var fn = arguments[ arguments.length - 1 ];
-	// If so, execute it in context
-	if ( fn && fn.constructor == Function )
-		this.each(fn);
-// Map over the $ in case of overwrite
-if ( typeof $ != "undefined" )
-	jQuery._$ = $;
-// Map the jQuery namespace to the '$' one
-var $ = jQuery;
-jQuery.fn = jQuery.prototype = {
-	jquery: "$Rev: 249 $",
-	size: function() {
-		return this.length;
-	get: function( num ) {
-		// Watch for when an array (of elements) is passed in
-		if ( num && num.constructor == Array ) {
-			// Use a tricky hack to make the jQuery object
-			// look and feel like an array
-			this.length = 0;
-			[].push.apply( this, num );
-			return this;
-		} else
-			return num == undefined ?
-				// Return a 'clean' array
-				jQuery.map( this, function(a){ return a } ) :
-				// Return just the object
-				this[num];
-	each: function( fn, args ) {
-		return jQuery.each( this, fn, args );
-	index: function( obj ) {
-		var pos = -1;
-		this.each(function(i){
-			if ( this == obj ) pos = i;
-		return pos;
-	attr: function( key, value, type ) {
-		// Check to see if we're setting style values
-		return key.constructor != String || value != undefined ?
-			this.each(function(){
-				// See if we're setting a hash of styles
-				if ( value == undefined )
-					// Set all the styles
-					for ( var prop in key )
-						jQuery.attr(
-							type ? this.style : this,
-							prop, key[prop]
-				// See if we're setting a single key/value style
-				else
-					jQuery.attr(
-						key, value
-			// Look for the case where we're accessing a style value
-			jQuery[ type || "attr" ]( this[0], key );
-	css: function( key, value ) {
-		return this.attr( key, value, "curCSS" );
-	text: function(e) {
-		e = e || this;
-		var t = "";
-		for ( var j = 0; j < e.length; j++ ) {
-			var r = e[j].childNodes;
-			for ( var i = 0; i < r.length; i++ )
-				if ( r[i].nodeType != 8 )
-					t += r[i].nodeType != 1 ?
-						r[i].nodeValue : jQuery.fn.text([ r[i] ]);
-		return t;
-	wrap: function() {
-		// The elements to wrap the target around
-		var a = jQuery.clean(arguments);
-		// Wrap each of the matched elements individually
-		return this.each(function(){
-			// Clone the structure that we're using to wrap
-			var b = a[0].cloneNode(true);
-			// Insert it before the element to be wrapped
-			this.parentNode.insertBefore( b, this );
-			// Find he deepest point in the wrap structure
-			while ( b.firstChild )
-				b = b.firstChild;
-			// Move the matched element to within the wrap structure
-			b.appendChild( this );
-	append: function() {
-		return this.domManip(arguments, true, 1, function(a){
-			this.appendChild( a );
-	prepend: function() {
-		return this.domManip(arguments, true, -1, function(a){
-			this.insertBefore( a, this.firstChild );
-	before: function() {
-		return this.domManip(arguments, false, 1, function(a){
-			this.parentNode.insertBefore( a, this );
-	after: function() {
-		return this.domManip(arguments, false, -1, function(a){
-			this.parentNode.insertBefore( a, this.nextSibling );
-	end: function() {
-		return this.get( this.stack.pop() );
-	find: function(t) {
-		return this.pushStack( jQuery.map( this, function(a){
-			return jQuery.find(t,a);
-		}), arguments );
-	clone: function(deep) {
-			return a.cloneNode( deep != undefined ? deep : true );
-		}), arguments );
-	filter: function(t) {
-			t.constructor == Array &&
-			jQuery.map(this,function(a){
-				for ( var i = 0; i < t.length; i++ )
-					if ( jQuery.filter(t[i],[a]).r.length )
-						return a;
-			t.constructor == Boolean &&
-			( t ? this.get() : [] ) ||
-			t.constructor == Function &&
-			jQuery.grep( this, t ) ||
-			jQuery.filter(t,this).r, arguments );
-	not: function(t) {
-		return this.pushStack( t.constructor == String ?
-			jQuery.filter(t,this,false).r :
-			jQuery.grep(this,function(a){ return a != t; }), arguments );
-	add: function(t) {
-		return this.pushStack( jQuery.merge( this, t.constructor == String ?
-			jQuery.find(t) : t.constructor == Array ? t : [t] ), arguments );
-	is: function(expr) {
-		return expr ? jQuery.filter(expr,this).r.length > 0 : this.length > 0;
-	domManip: function(args, table, dir, fn){
-		var clone = this.size() > 1;
-		var a = jQuery.clean(args);
-			var obj = this;
-			if ( table && this.nodeName == "TABLE" && a[0].nodeName != "THEAD" ) {
-				var tbody = this.getElementsByTagName("tbody");
-				if ( !tbody.length ) {
-					obj = document.createElement("tbody");
-					this.appendChild( obj );
-				} else
-					obj = tbody[0];
-			for ( var i = ( dir < 0 ? a.length - 1 : 0 );
-				i != ( dir < 0 ? dir : a.length ); i += dir ) {
-					fn.apply( obj, [ clone ? a[i].cloneNode(true) : a[i] ] );
-	pushStack: function(a,args) {
-		var fn = args && args[args.length-1];
-		if ( !fn || fn.constructor != Function ) {
-			if ( !this.stack ) this.stack = [];
-			this.stack.push( this.get() );
-			this.get( a );
-		} else {
-			var old = this.get();
-			this.get( a );
-			if ( fn.constructor == Function )
-				return this.each( fn );
-			this.get( old );
-		return this;
-jQuery.extend = jQuery.fn.extend = function(obj,prop) {
-	if ( !prop ) { prop = obj; obj = this; }
-	for ( var i in prop ) obj[i] = prop[i];
-	return obj;
-jQuery.extend({
-	init: function(){
-		jQuery.initDone = true;
-		jQuery.each( jQuery.macros.axis, function(i,n){
-			jQuery.fn[ i ] = function(a) {
-				var ret = jQuery.map(this,n);
-				if ( a && a.constructor == String )
-					ret = jQuery.filter(a,ret).r;
-				return this.pushStack( ret, arguments );
-		jQuery.each( jQuery.macros.to, function(i,n){
-			jQuery.fn[ i ] = function(){
-				var a = arguments;
-					for ( var j = 0; j < a.length; j++ )
-						$(a[j])[n]( this );
-		jQuery.each( jQuery.macros.each, function(i,n){
-			jQuery.fn[ i ] = function() {
-				return this.each( n, arguments );
-		jQuery.each( jQuery.macros.filter, function(i,n){
-			jQuery.fn[ n ] = function(num,fn) {
-				return this.filter( ":" + n + "(" + num + ")", fn );
-		jQuery.each( jQuery.macros.attr, function(i,n){
-			n = n || i;
-			jQuery.fn[ i ] = function(h) {
-				return h == undefined ?
-					this.length ? this[0][n] : null :
-					this.attr( n, h );
-		jQuery.each( jQuery.macros.css, function(i,n){
-			jQuery.fn[ n ] = function(h) {
-					( this.length ? jQuery.css( this[0], n ) : null ) :
-					this.css( n, h );
-	each: function( obj, fn, args ) {
-		if ( obj.length == undefined )
-			for ( var i in obj )
-				fn.apply( obj[i], args || [i, obj[i]] );
-		else
-			for ( var i = 0; i < obj.length; i++ )
-		return obj;
-	className: {
-		add: function(o,c){
-			if (jQuery.className.has(o,c)) return;
-			o.className += ( o.className ? " " : "" ) + c;
-		remove: function(o,c){
-			o.className = !c ? "" :
-				o.className.replace(
-					new RegExp("(^|\\s*\\b[^-])"+c+"($|\\b(?=[^-]))", "g"), "");
-		has: function(e,a) {
-			if ( e.className != undefined )
-				e = e.className;
-			return new RegExp("(^|\\s)" + a + "(\\s|$)").test(e);
-	swap: function(e,o,f) {
-		for ( var i in o ) {
-			e.style["old"+i] = e.style[i];
-			e.style[i] = o[i];
-		f.apply( e, [] );
-			e.style[i] = e.style["old"+i];
-	css: function(e,p) {
-		if ( p == "height" || p == "width" ) {
-			var old = {}, oHeight, oWidth, d = ["Top","Bottom","Right","Left"];
-			for ( var i in d ) {
-				old["padding" + d[i]] = 0;
-				old["border" + d[i] + "Width"] = 0;
-			jQuery.swap( e, old, function() {
-				if (jQuery.css(e,"display") != "none") {
-					oHeight = e.offsetHeight;
-					oWidth = e.offsetWidth;
-				} else {
-					e = $(e.cloneNode(true)).css({
-						visibility: "hidden", position: "absolute", display: "block"
-					}).prependTo("body")[0];
-					oHeight = e.clientHeight;
-					oWidth = e.clientWidth;
-					e.parentNode.removeChild(e);
-			return p == "height" ? oHeight : oWidth;
-		} else if ( p == "opacity" && jQuery.browser.msie )
-			return parseFloat( jQuery.curCSS(e,"filter").replace(/[^0-9.]/,"") ) || 1;
-		return jQuery.curCSS( e, p );
-	curCSS: function(elem, prop, force) {
-		var ret;
-		if (!force && elem.style[prop]) {
-			ret = elem.style[prop];
-		} else if (elem.currentStyle) {
-			var newProp = prop.replace(/\-(\w)/g,function(m,c){return c.toUpperCase()});
-			ret = elem.currentStyle[prop] || elem.currentStyle[newProp];
-		} else if (document.defaultView && document.defaultView.getComputedStyle) {
-			prop = prop.replace(/([A-Z])/g,"-$1").toLowerCase();
-			var cur = document.defaultView.getComputedStyle(elem, null);
-			if ( cur )
-				ret = cur.getPropertyValue(prop);
-			else if ( prop == 'display' )
-				ret = 'none';
-			else
-				jQuery.swap(elem, { display: 'block' }, function() {
-					ret = document.defaultView.getComputedStyle(this,null).getPropertyValue(prop);
-		return ret;
-	clean: function(a) {
-		var r = [];
-		for ( var i = 0; i < a.length; i++ ) {
-			if ( a[i].constructor == String ) {
-				var table = "";
-				if ( !a[i].indexOf("<thead") || !a[i].indexOf("<tbody") ) {
-					table = "thead";
-					a[i] = "<table>" + a[i] + "</table>";
-				} else if ( !a[i].indexOf("<tr") ) {
-					table = "tr";
-				} else if ( !a[i].indexOf("<td") || !a[i].indexOf("<th") ) {
-					table = "td";
-					a[i] = "<table><tbody><tr>" + a[i] + "</tr></tbody></table>";
-				var div = document.createElement("div");
-				div.innerHTML = a[i];
-				if ( table ) {
-					div = div.firstChild;
-					if ( table != "thead" ) div = div.firstChild;
-					if ( table == "td" ) div = div.firstChild;
-				for ( var j = 0; j < div.childNodes.length; j++ )
-					r.push( div.childNodes[j] );
-				} else if ( a[i].jquery || a[i].length && !a[i].nodeType )
-					for ( var k = 0; k < a[i].length; k++ )
-						r.push( a[i][k] );
-				else if ( a[i] !== null )
-					r.push(	a[i].nodeType ? a[i] : document.createTextNode(a[i].toString()) );
-		return r;
-	expr: {
-		"": "m[2]== '*'||a.nodeName.toUpperCase()==m[2].toUpperCase()",
-		"#": "a.getAttribute('id')&&a.getAttribute('id')==m[2]",
-			// Position Checks
-			lt: "i<m[3]-0",
-			gt: "i>m[3]-0",
-			nth: "m[3]-0==i",
-			eq: "m[3]-0==i",
-			first: "i==0",
-			last: "i==r.length-1",
-			even: "i%2==0",
-			odd: "i%2",
-			// Child Checks
-			"nth-child": "jQuery.sibling(a,m[3]).cur",
-			"first-child": "jQuery.sibling(a,0).cur",
-			"last-child": "jQuery.sibling(a,0).last",
-			"only-child": "jQuery.sibling(a).length==1",
-			// Parent Checks
-			parent: "a.childNodes.length",
-			empty: "!a.childNodes.length",
-			// Text Check
-			contains: "(a.innerText||a.innerHTML).indexOf(m[3])>=0",
-			// Visibility
-			visible: "a.type!='hidden'&&jQuery.css(a,'display')!='none'&&jQuery.css(a,'visibility')!='hidden'",
-			hidden: "a.type=='hidden'||jQuery.css(a,'display')=='none'||jQuery.css(a,'visibility')=='hidden'",
-			// Form elements
-			enabled: "!a.disabled",
-			disabled: "a.disabled",
-			checked: "a.checked",
-			selected: "a.selected"
-		".": "jQuery.className.has(a,m[2])",
-			"=": "z==m[4]",
-			"!=": "z!=m[4]",
-			"^=": "!z.indexOf(m[4])",
-			"$=": "z.substr(z.length - m[4].length,m[4].length)==m[4]",
-			"*=": "z.indexOf(m[4])>=0",
-			"": "z"
-		"[": "jQuery.find(m[2],a).length"
-	token: [
-		"\\.\\.|/\\.\\.", "a.parentNode",
-		">|/", "jQuery.sibling(a.firstChild)",
-		"\\+", "jQuery.sibling(a).next",
-		"~", function(a){
-			var r = [];
-			var s = jQuery.sibling(a);
-			if ( s.n > 0 )
-				for ( var i = s.n; i < s.length; i++ )
-					r.push( s[i] );
-			return r;
-	find: function( t, context ) {
-		// Make sure that the context is a DOM Element
-		if ( context && context.nodeType == undefined )
-			context = null;
-		// Set the correct context (if none is provided)
-		context = context || jQuery.context || document;
-		if ( t.constructor != String ) return [t];
-		if ( !t.indexOf("//") ) {
-			context = context.documentElement;
-			t = t.substr(2,t.length);
-		} else if ( !t.indexOf("/") ) {
-			t = t.substr(1,t.length);
-			// FIX Assume the root element is right :(
-			if ( t.indexOf("/") >= 1 )
-				t = t.substr(t.indexOf("/"),t.length);
-		var ret = [context];
-		var done = [];
-		var last = null;
-		while ( t.length > 0 && last != t ) {
-			var r = [];
-			last = t;
-			t = jQuery.trim(t).replace( /^\/\//i, "" );
-			var foundToken = false;
-			for ( var i = 0; i < jQuery.token.length; i += 2 ) {
-				if ( foundToken ) continue;
-				var re = new RegExp("^(" + jQuery.token[i] + ")");
-				var m = re.exec(t);
-				if ( m ) {
-					r = ret = jQuery.map( ret, jQuery.token[i+1] );
-					t = jQuery.trim( t.replace( re, "" ) );
-					foundToken = true;
-			if ( !foundToken ) {
-				if ( !t.indexOf(",") || !t.indexOf("|") ) {
-					if ( ret[0] == context ) ret.shift();
-					done = jQuery.merge( done, ret );
-					r = ret = [context];
-					t = " " + t.substr(1,t.length);
-				} else {
-					var re2 = /^([#.]?)([a-z0-9\\*_-]*)/i;
-					var m = re2.exec(t);
-					if ( m[1] == "#" ) {
-						// Ummm, should make this work in all XML docs
-						var oid = document.getElementById(m[2]);
-						r = ret = oid ? [oid] : [];
-						t = t.replace( re2, "" );
-					} else {
-						if ( !m[2] || m[1] == "." ) m[2] = "*";
-						for ( var i = 0; i < ret.length; i++ )
-							r = jQuery.merge( r,
-								m[2] == "*" ?
-									jQuery.getAll(ret[i]) :
-									ret[i].getElementsByTagName(m[2])
-			if ( t ) {
-				var val = jQuery.filter(t,r);
-				ret = r = val.r;
-				t = jQuery.trim(val.t);
-		if ( ret && ret[0] == context ) ret.shift();
-		return done;
-	getAll: function(o,r) {
-		r = r || [];
-		var s = o.childNodes;
-		for ( var i = 0; i < s.length; i++ )
-			if ( s[i].nodeType == 1 ) {
-				r.push( s[i] );
-				jQuery.getAll( s[i], r );
-		return r;
-	attr: function(elem, name, value){
-		var fix = {
-			"for": "htmlFor",
-			"class": "className",
-			"float": "cssFloat",
-			innerHTML: "innerHTML",
-			className: "className",
-			value: "value",
-			disabled: "disabled"
-		if ( fix[name] ) {
-			if ( value != undefined ) elem[fix[name]] = value;
-			return elem[fix[name]];
-		} else if ( elem.getAttribute ) {
-			if ( value != undefined ) elem.setAttribute( name, value );
-			return elem.getAttribute( name, 2 );
-		} else {
-			name = name.replace(/-([a-z])/ig,function(z,b){return b.toUpperCase();});
-			if ( value != undefined ) elem[name] = value;
-			return elem[name];
-	// The regular expressions that power the parsing engine
-	parse: [
-		// Match: [@value='test'], [@foo]
-		[ "\\[ *(@)S *([!*$^=]*) *Q\\]", 1 ],
-		// Match: [div], [div p]
-		[ "(\\[)Q\\]", 0 ],
-		// Match: :contains('foo')
-		[ "(:)S\\(Q\\)", 0 ],
-		// Match: :even, :last-chlid
-		[ "([:.#]*)S", 0 ]
-	filter: function(t,r,not) {
-		// Figure out if we're doing regular, or inverse, filtering
-		var g = not !== false ? jQuery.grep :
-			function(a,f) {return jQuery.grep(a,f,true);};
-		while ( t && /^[a-z[({<*:.#]/i.test(t) ) {
-			var p = jQuery.parse;
-			for ( var i = 0; i < p.length; i++ ) {
-				var re = new RegExp( "^" + p[i][0]
-					// Look for a string-like sequence
-					.replace( 'S', "([a-z*_-][a-z0-9_-]*)" )
-					// Look for something (optionally) enclosed with quotes
-					.replace( 'Q', " *'?\"?([^'\"]*?)'?\"? *" ), "i" );
-				var m = re.exec( t );
-				if ( m ) {
-					// Re-organize the match
-					if ( p[i][1] )
-						m = ["", m[1], m[3], m[2], m[4]];
-					// Remove what we just matched
-					t = t.replace( re, "" );
-					break;
-			// :not() is a special case that can be optomized by
-			// keeping it out of the expression list
-			if ( m[1] == ":" && m[2] == "not" )
-				r = jQuery.filter(m[3],r,false).r;
-			// Otherwise, find the expression to execute
-			else {
-				var f = jQuery.expr[m[1]];
-				if ( f.constructor != String )
-					f = jQuery.expr[m[1]][m[2]];
-				// Build a custom macro to enclose it
-				eval("f = function(a,i){" +
-					( m[1] == "@" ? "z=jQuery.attr(a,m[3]);" : "" ) +
-					"return " + f + "}");
-				// Execute it against the current filter
-				r = g( r, f );
-		// Return an array of filtered elements (r)
-		// and the modified expression string (t)
-		return { r: r, t: t };
-	trim: function(t){
-		return t.replace(/^\s+|\s+$/g, "");
-	parents: function( elem ){
-		var matched = [];
-		var cur = elem.parentNode;
-		while ( cur && cur != document ) {
-			matched.push( cur );
-			cur = cur.parentNode;
-		return matched;
-	sibling: function(elem, pos, not) {
-		var elems = [];
-		var siblings = elem.parentNode.childNodes;
-		for ( var i = 0; i < siblings.length; i++ ) {
-			if ( not === true && siblings[i] == elem ) continue;
-			if ( siblings[i].nodeType == 1 )
-				elems.push( siblings[i] );
-			if ( siblings[i] == elem )
-				elems.n = elems.length - 1;
-		return jQuery.extend( elems, {
-			last: elems.n == elems.length - 1,
-			cur: pos == "even" && elems.n % 2 == 0 || pos == "odd" && elems.n % 2 || elems[pos] == elem,
-			prev: elems[elems.n - 1],
-			next: elems[elems.n + 1]
-	merge: function(first, second) {
-		var result = [];
-		// Move b over to the new array (this helps to avoid
-		// StaticNodeList instances)
-		for ( var k = 0; k < first.length; k++ )
-			result[k] = first[k];
-		// Now check for duplicates between a and b and only
-		// add the unique items
-		for ( var i = 0; i < second.length; i++ ) {
-			var noCollision = true;
-			// The collision-checking process
-			for ( var j = 0; j < first.length; j++ )
-				if ( second[i] == first[j] )
-					noCollision = false;
-			// If the item is unique, add it
-			if ( noCollision )
-				result.push( second[i] );
-		return result;
-	grep: function(elems, fn, inv) {
-		// If a string is passed in for the function, make a function
-		// for it (a handy shortcut)
-		if ( fn.constructor == String )
-			fn = new Function("a","i","return " + fn);
-		var result = [];
-		// Go through the array, only saving the items
-		// that pass the validator function
-		for ( var i = 0; i < elems.length; i++ )
-			if ( !inv && fn(elems[i],i) || inv && !fn(elems[i],i) )
-				result.push( elems[i] );
-		return result;
-	map: function(elems, fn) {
-			fn = new Function("a","return " + fn);
-		var result = [];
-		// Go through the array, translating each of the items to their
-		// new value (or values).
-		for ( var i = 0; i < elems.length; i++ ) {
-			var val = fn(elems[i],i);
-			if ( val !== null && val != undefined ) {
-				if ( val.constructor != Array ) val = [val];
-				result = jQuery.merge( result, val );
-		return result;
-	 * A number of helper functions used for managing events.
-	 * Many of the ideas behind this code orignated from Dean Edwards' addEvent library.
-	event: {
-		// Bind an event to an element
-		// Original by Dean Edwards
-		add: function(element, type, handler) {
-			// For whatever reason, IE has trouble passing the window object
-			// around, causing it to be cloned in the process
-			if ( jQuery.browser.msie && element.setInterval != undefined )
-				element = window;
-			// Make sure that the function being executed has a unique ID
-			if ( !handler.guid )
-				handler.guid = this.guid++;
-			// Init the element's event structure
-			if (!element.events)
-				element.events = {};
-			// Get the current list of functions bound to this event
-			var handlers = element.events[type];
-			// If it hasn't been initialized yet
-			if (!handlers) {
-				// Init the event handler queue
-				handlers = element.events[type] = {};
-				// Remember an existing handler, if it's already there
-				if (element["on" + type])
-					handlers[0] = element["on" + type];
-			// Add the function to the element's handler list
-			handlers[handler.guid] = handler;
-			// And bind the global event handler to the element
-			element["on" + type] = this.handle;
-			// Remember the function in a global list (for triggering)
-			if (!this.global[type])
-				this.global[type] = [];
-			this.global[type].push( element );
-		guid: 1,
-		global: {},
-		// Detach an event or set of events from an element
-		remove: function(element, type, handler) {
-			if (element.events)
-				if (type && element.events[type])
-					if ( handler )
-						delete element.events[type][handler.guid];
-					else
-						for ( var i in element.events[type] )
-							delete element.events[type][i];
-				else
-					for ( var j in element.events )
-						this.remove( element, j );
-		trigger: function(type,data,element) {
-			// Touch up the incoming data
-			data = data || [];
-			// Handle a global trigger
-			if ( !element ) {
-				var g = this.global[type];
-				if ( g )
-					for ( var i = 0; i < g.length; i++ )
-						this.trigger( type, data, g[i] );
-			// Handle triggering a single element
-			} else if ( element["on" + type] ) {
-				// Pass along a fake event
-				data.unshift( this.fix({ type: type, target: element }) );
-				// Trigger the event
-				element["on" + type].apply( element, data );
-		handle: function(event) {
-			if ( typeof jQuery == "undefined" ) return;
-			event = event || jQuery.event.fix( window.event );
-			// If no correct event was found, fail
-			if ( !event ) return;
-			var returnValue = true;
-			var c = this.events[event.type];
-			for ( var j in c ) {
-				if ( c[j].apply( this, [event] ) === false ) {
-					event.preventDefault();
-					event.stopPropagation();
-					returnValue = false;
-			return returnValue;
-		fix: function(event) {
-			if ( event ) {
-				event.preventDefault = function() {
-					this.returnValue = false;
-				event.stopPropagation = function() {
-					this.cancelBubble = true;
-			return event;
-new function() {
-	var b = navigator.userAgent.toLowerCase();
-	// Figure out what browser is being used
-	jQuery.browser = {
-		safari: /webkit/.test(b),
-		opera: /opera/.test(b),
-		msie: /msie/.test(b) && !/opera/.test(b),
-		mozilla: /mozilla/.test(b) && !/compatible/.test(b)
-	// Check to see if the W3C box model is being used
-	jQuery.boxModel = !jQuery.browser.msie || document.compatMode == "CSS1Compat";
-jQuery.macros = {
-	to: {
-		appendTo: "append",
-		prependTo: "prepend",
-		insertBefore: "before",
-		insertAfter: "after"
-	css: "width,height,top,left,position,float,overflow,color,background".split(","),
-	filter: [ "eq", "lt", "gt", "contains" ],
-	attr: {
-		val: "value",
-		html: "innerHTML",
-		id: null,
-		title: null,
-		name: null,
-		href: null,
-		src: null,
-		rel: null
-	axis: {
-		parent: "a.parentNode",
-		ancestors: jQuery.parents,
-		parents: jQuery.parents,
-		next: "jQuery.sibling(a).next",
-		prev: "jQuery.sibling(a).prev",
-		siblings: jQuery.sibling,
-		children: "jQuery.sibling(a.firstChild)"
-	each: {
-		removeAttr: function( key ) {
-			this.removeAttribute( key );
-		show: function(){
-			this.style.display = this.oldblock ? this.oldblock : "";
-			if ( jQuery.css(this,"display") == "none" )
-				this.style.display = "block";
-		hide: function(){
-			this.oldblock = this.oldblock || jQuery.css(this,"display");
-			if ( this.oldblock == "none" )
-				this.oldblock = "block";
-			this.style.display = "none";
-		toggle: function(){
-			$(this)[ $(this).is(":hidden") ? "show" : "hide" ].apply( $(this), arguments );
-		addClass: function(c){
-			jQuery.className.add(this,c);
-		removeClass: function(c){
-			jQuery.className.remove(this,c);
-		toggleClass: function( c ){
-			jQuery.className[ jQuery.className.has(this,c) ? "remove" : "add" ](this,c);
-		remove: function(a){
-			if ( !a || jQuery.filter( a, [this] ).r )
-				this.parentNode.removeChild( this );
-		empty: function(){
-			while ( this.firstChild )
-				this.removeChild( this.firstChild );
-		bind: function( type, fn ) {
-				fn = new Function("e", ( !fn.indexOf(".") ? "$(this)" : "return " ) + fn);
-			jQuery.event.add( this, type, fn );
-		unbind: function( type, fn ) {
-			jQuery.event.remove( this, type, fn );
-		trigger: function( type, data ) {
-			jQuery.event.trigger( type, data, this );
-jQuery.init();
-jQuery.fn.extend({
-	// We're overriding the old toggle function, so
-	// remember it for later
-	_toggle: jQuery.fn.toggle,
-	toggle: function(a,b) {
-		// If two functions are passed in, we're
-		// toggling on a click
-		return a && b && a.constructor == Function && b.constructor == Function ? this.click(function(e){
-			// Figure out which function to execute
-			this.last = this.last == a ? b : a;
-			// Make sure that clicks stop
-			e.preventDefault();
-			// and execute the function
-			return this.last.apply( this, [e] ) || false;
-		// Otherwise, execute the old toggle function
-		this._toggle.apply( this, arguments );
-	hover: function(f,g) {
-		// A private function for haandling mouse 'hovering'
-		function handleHover(e) {
-			// Check if mouse(over|out) are still within the same parent element
-			var p = (e.type == "mouseover" ? e.fromElement : e.toElement) || e.relatedTarget;
-			// Traverse up the tree
-			while ( p && p != this ) p = p.parentNode;
-			// If we actually just moused on to a sub-element, ignore it
-			if ( p == this ) return false;
-			// Execute the right function
-			return (e.type == "mouseover" ? f : g).apply(this, [e]);
-		// Bind the function to the two event listeners
-		return this.mouseover(handleHover).mouseout(handleHover);
-	ready: function(f) {
-		// If the DOM is already ready
-		if ( jQuery.isReady )
-			// Execute the function immediately
-			f.apply( document );
-		// Otherwise, remember the function for later
-		else {
-			// Add the function to the wait list
-			jQuery.readyList.push( f );
-		return this;
-jQuery.extend({
-	 * All the code that makes DOM Ready work nicely.
-	isReady: false,
-	readyList: [],
-	// Handle when the DOM is ready
-	ready: function() {
-		// Make sure that the DOM is not already loaded
-		if ( !jQuery.isReady ) {
-			// Remember that the DOM is ready
-			jQuery.isReady = true;
-			// If there are functions bound, to execute
-			if ( jQuery.readyList ) {
-				// Execute all of them
-				for ( var i = 0; i < jQuery.readyList.length; i++ )
-					jQuery.readyList[i].apply( document );
-				// Reset the list of functions
-				jQuery.readyList = null;
-new function(){
-	var e = ("blur,focus,load,resize,scroll,unload,click,dblclick," +
-		"mousedown,mouseup,mousemove,mouseover,mouseout,change,reset,select," +
-		"submit,keydown,keypress,keyup,error").split(",");
-	// Go through all the event names, but make sure that
-	// it is enclosed properly
-	for ( var i = 0; i < e.length; i++ ) new function(){
-		var o = e[i];
-		// Handle event binding
-		jQuery.fn[o] = function(f){
-			return f ? this.bind(o, f) : this.trigger(o);
-		// Handle event unbinding
-		jQuery.fn["un"+o] = function(f){ return this.unbind(o, f); };
-		// Finally, handle events that only fire once
-		jQuery.fn["one"+o] = function(f){
-			// Attach the event listener
-				var count = 0;
-				// Add the event
-				jQuery.event.add( this, o, function(e){
-					// If this function has already been executed, stop
-					if ( count++ ) return;
-					// And execute the bound function
-					return f.apply(this, [e]);
-	// If Mozilla is used
-	if ( jQuery.browser.mozilla || jQuery.browser.opera ) {
-		// Use the handy event callback
-		document.addEventListener( "DOMContentLoaded", jQuery.ready, false );
-	// If IE is used, use the excellent hack by Matthias Miller
-	// http://www.outofhanwell.com/blog/index.php?title=the_window_onload_problem_revisited
-	} else if ( jQuery.browser.msie ) {
-		// Only works if you document.write() it
-		document.write("<scr" + "ipt id=__ie_init defer=true " +
-			"src=//:><\/script>");
-		// Use the defer script hack
-		var script = document.getElementById("__ie_init");
-		script.onreadystatechange = function() {
-			if ( this.readyState != "complete" ) return;
-			jQuery.ready();
-		// Clear from memory
-		script = null;
-	// If Safari  is used
-	} else if ( jQuery.browser.safari ) {
-		// Continually check to see if the document.readyState is valid
-		jQuery.safariTimer = setInterval(function(){
-			// loaded and complete are both valid states
-			if ( document.readyState == "loaded" ||
-				document.readyState == "complete" ) {
-				// If either one are found, remove the timer
-				clearInterval( jQuery.safariTimer );
-				jQuery.safariTimer = null;
-				// and execute any waiting functions
-				jQuery.ready();
-		}, 10);
-	// A fallback to window.onload, that will always work
-	jQuery.event.add( window, "load", jQuery.ready );
-jQuery.fn.extend({
-	// overwrite the old show method
-	_show: jQuery.fn.show,
-	show: function(speed,callback){
-		return speed ? this.animate({
-			height: "show", width: "show", opacity: "show"
-		}, speed, callback) : this._show();
-	// Overwrite the old hide method
-	_hide: jQuery.fn.hide,
-	hide: function(speed,callback){
-			height: "hide", width: "hide", opacity: "hide"
-		}, speed, callback) : this._hide();
-	slideDown: function(speed,callback){
-		return this.animate({height: "show"}, speed, callback);
-	slideUp: function(speed,callback){
-		return this.animate({height: "hide"}, speed, callback);
-	slideToggle: function(speed,callback){
-			var state = $(this).is(":hidden") ? "show" : "hide";
-			$(this).animate({height: state}, speed, callback);
-	fadeIn: function(speed,callback){
-		return this.animate({opacity: "show"}, speed, callback);
-	fadeOut: function(speed,callback){
-		return this.animate({opacity: "hide"}, speed, callback);
-	fadeTo: function(speed,to,callback){
-		return this.animate({opacity: to}, speed, callback);
-	animate: function(prop,speed,callback) {
-		return this.queue(function(){
-			this.curAnim = prop;
-			for ( var p in prop ) {
-				var e = new jQuery.fx( this, jQuery.speed(speed,callback), p );
-				if ( prop[p].constructor == Number )
-					e.custom( e.cur(), prop[p] );
-				else
-					e[ prop[p] ]( prop );
-	queue: function(type,fn){
-		if ( !fn ) {
-			fn = type;
-			type = "fx";
-			if ( !this.queue )
-				this.queue = {};
-			if ( !this.queue[type] )
-				this.queue[type] = [];
-			this.queue[type].push( fn );
-			if ( this.queue[type].length == 1 )
-				fn.apply(this);
-jQuery.extend({
-	setAuto: function(e,p) {
-		if ( e.notAuto ) return;
-		if ( p == "height" && e.scrollHeight != parseInt(jQuery.curCSS(e,p)) ) return;
-		if ( p == "width" && e.scrollWidth != parseInt(jQuery.curCSS(e,p)) ) return;
-		// Remember the original height
-		var a = e.style[p];
-		// Figure out the size of the height right now
-		var o = jQuery.curCSS(e,p,1);
-		if ( p == "height" && e.scrollHeight != o ||
-			p == "width" && e.scrollWidth != o ) return;
-		// Set the height to auto
-		e.style[p] = e.currentStyle ? "" : "auto";
-		// See what the size of "auto" is
-		var n = jQuery.curCSS(e,p,1);
-		// Revert back to the original size
-		if ( o != n && n != "auto" ) {
-			e.style[p] = a;
-			e.notAuto = true;
-	speed: function(s,o) {
-		o = o || {};
-		if ( o.constructor == Function )
-			o = { complete: o };
-		var ss = { slow: 600, fast: 200 };
-		o.duration = (s && s.constructor == Number ? s : ss[s]) || 400;
-		// Queueing
-		o.oldComplete = o.complete;
-		o.complete = function(){
-			jQuery.dequeue(this, "fx");
-			if ( o.oldComplete && o.oldComplete.constructor == Function )
-				o.oldComplete.apply( this );
-		return o;
-	queue: {},
-	dequeue: function(elem,type){
-		type = type || "fx";
-		if ( elem.queue && elem.queue[type] ) {
-			// Remove self
-			elem.queue[type].shift();
-			// Get next function
-			var f = elem.queue[type][0];
-			if ( f ) f.apply( elem );
-	 * I originally wrote fx() as a clone of moo.fx and in the process
-	 * of making it small in size the code became illegible to sane
-	 * people. You've been warned.
-	fx: function( elem, options, prop ){
-		var z = this;
-		// The users options
-		z.o = {
-			duration: options.duration || 400,
-			complete: options.complete,
-			step: options.step
-		// The element
-		z.el = elem;
-		// The styles
-		var y = z.el.style;
-		// Simple function for setting a style value
-		z.a = function(){
-			if ( options.step )
-				options.step.apply( elem, [ z.now ] );
-			if ( prop == "opacity" ) {
-				if (jQuery.browser.mozilla && z.now == 1) z.now = 0.9999;
-				if (window.ActiveXObject)
-					y.filter = "alpha(opacity=" + z.now*100 + ")";
-				else
-					y.opacity = z.now;
-			// My hate for IE will never die
-			} else if ( parseInt(z.now) )
-				y[prop] = parseInt(z.now) + "px";
-			y.display = "block";
-		// Figure out the maximum number to run to
-		z.max = function(){
-			return parseFloat( jQuery.css(z.el,prop) );
-		// Get the current size
-		z.cur = function(){
-			var r = parseFloat( jQuery.curCSS(z.el, prop) );
-			return r && r > -10000 ? r : z.max();
-		// Start an animation from one number to another
-		z.custom = function(from,to){
-			z.startTime = (new Date()).getTime();
-			z.now = from;
-			z.a();
-			z.timer = setInterval(function(){
-				z.step(from, to);
-			}, 13);
-		// Simple 'show' function
-		z.show = function( p ){
-			if ( !z.el.orig ) z.el.orig = {};
-			// Remember where we started, so that we can go back to it later
-			z.el.orig[prop] = this.cur();
-			z.custom( 0, z.el.orig[prop] );
-			// Stupid IE, look what you made me do
-			if ( prop != "opacity" )
-				y[prop] = "1px";
-		// Simple 'hide' function
-		z.hide = function(){
-			z.o.hide = true;
-			// Begin the animation
-			z.custom(z.el.orig[prop], 0);
-		// IE has trouble with opacity if it does not have layout
-		if ( jQuery.browser.msie && !z.el.currentStyle.hasLayout )
-			y.zoom = "1";
-		// Remember  the overflow of the element
-		if ( !z.el.oldOverlay )
-			z.el.oldOverflow = jQuery.css( z.el, "overflow" );
-		// Make sure that nothing sneaks out
-		y.overflow = "hidden";
-		// Each step of an animation
-		z.step = function(firstNum, lastNum){
-			var t = (new Date()).getTime();
-			if (t > z.o.duration + z.startTime) {
-				// Stop the timer
-				clearInterval(z.timer);
-				z.timer = null;
-				z.now = lastNum;
-				z.a();
-				z.el.curAnim[ prop ] = true;
-				var done = true;
-				for ( var i in z.el.curAnim )
-					if ( z.el.curAnim[i] !== true )
-						done = false;
-				if ( done ) {
-					// Reset the overflow
-					y.overflow = z.el.oldOverflow;
-					// Hide the element if the "hide" operation was done
-					if ( z.o.hide )
-						y.display = 'none';
-					// Reset the property, if the item has been hidden
-					if ( z.o.hide ) {
-						for ( var p in z.el.curAnim ) {
-							y[ p ] = z.el.orig[p] + ( p == "opacity" ? "" : "px" );
-							// set its height and/or width to auto
-							if ( p == 'height' || p == 'width' )
-								jQuery.setAuto( z.el, p );
-				// If a callback was provided, execute it
-				if( done && z.o.complete && z.o.complete.constructor == Function )
-					// Execute the complete function
-					z.o.complete.apply( z.el );
-			} else {
-				// Figure out where in the animation we are and set the number
-				var p = (t - this.startTime) / z.o.duration;
-				z.now = ((-Math.cos(p*Math.PI)/2) + 0.5) * (lastNum-firstNum) + firstNum;
-				// Perform the next step of the animation
-				z.a();
-// AJAX Plugin
-// Docs Here:
-// http://jquery.com/docs/ajax/
-jQuery.fn.loadIfModified = function( url, params, callback ) {
-	this.load( url, params, callback, 1 );
-jQuery.fn.load = function( url, params, callback, ifModified ) {
-	if ( url.constructor == Function )
-		return this.bind("load", url);
-	callback = callback || function(){};
-	// Default to a GET request
-	var type = "GET";
-	// If the second parameter was provided
-	if ( params ) {
-		// If it's a function
-		if ( params.constructor == Function ) {
-			// We assume that it's the callback
-			callback = params;
-			params = null;
-		// Otherwise, build a param string
-		} else {
-			params = jQuery.param( params );
-			type = "POST";
-	var self = this;
-	// Request the remote document
-	jQuery.ajax( type, url, params,function(res, status){
-		if ( status == "success" || !ifModified && status == "notmodified" ) {
-			// Inject the HTML into all the matched elements
-			self.html(res.responseText).each( callback, [res.responseText, status] );
-			// Execute all the scripts inside of the newly-injected HTML
-			$("script", self).each(function(){
-				if ( this.src )
-					$.getScript( this.src );
-				else
-					eval.call( window, this.text || this.textContent || this.innerHTML || "" );
-		} else
-			callback.apply( self, [res.responseText, status] );
-	}, ifModified);
-	return this;
-// If IE is used, create a wrapper for the XMLHttpRequest object
-if ( jQuery.browser.msie && typeof XMLHttpRequest == "undefined" )
-	XMLHttpRequest = function(){
-		return new ActiveXObject(
-			navigator.userAgent.indexOf("MSIE 5") >= 0 ?
-			"Microsoft.XMLHTTP" : "Msxml2.XMLHTTP"
-// Attach a bunch of functions for handling common AJAX events
-new function(){
-	var e = "ajaxStart,ajaxStop,ajaxComplete,ajaxError,ajaxSuccess".split(',');
-		var o = e[i];
-			return this.bind(o, f);
-jQuery.extend({
-	get: function( url, data, callback, type, ifModified ) {
-		if ( data.constructor == Function ) {
-			type = callback;
-			callback = data;
-			data = null;
-		if ( data ) url += "?" + jQuery.param(data);
-		// Build and start the HTTP Request
-		jQuery.ajax( "GET", url, null, function(r, status) {
-			if ( callback ) callback( jQuery.httpData(r,type), status );
-		}, ifModified);
-	getIfModified: function( url, data, callback, type ) {
-		jQuery.get(url, data, callback, type, 1);
-	getScript: function( url, data, callback ) {
-		jQuery.get(url, data, callback, "script");
-	post: function( url, data, callback, type ) {
-		jQuery.ajax( "POST", url, jQuery.param(data), function(r, status) {
-	// timeout (ms)
-	timeout: 0,
-	ajaxTimeout: function(timeout) {
-		jQuery.timeout = timeout;
-	// Last-Modified header cache for next request
-	lastModified: {},
-	ajax: function( type, url, data, ret, ifModified ) {
-		// If only a single argument was passed in,
-		// assume that it is a object of key/value pairs
-		if ( !url ) {
-			ret = type.complete;
-			var success = type.success;
-			var error = type.error;
-			data = type.data;
-			url = type.url;
-			type = type.type;
-		// Watch for a new set of requests
-		if ( ! jQuery.active++ )
-			jQuery.event.trigger( "ajaxStart" );
-		var requestDone = false;
-		// Create the request object
-		var xml = new XMLHttpRequest();
-		// Open the socket
-		xml.open(type || "GET", url, true);
-		// Set the correct header, if data is being sent
-		if ( data )
-			xml.setRequestHeader("Content-Type", "application/x-www-form-urlencoded");
-		// Set the If-Modified-Since header, if ifModified mode.
-		if ( ifModified )
-			xml.setRequestHeader("If-Modified-Since",
-				jQuery.lastModified[url] || "Thu, 01 Jan 1970 00:00:00 GMT" );
-		// Set header so calling script knows that it's an XMLHttpRequest
-		xml.setRequestHeader("X-Requested-With", "XMLHttpRequest");
-		// Make sure the browser sends the right content length
-		if ( xml.overrideMimeType )
-			xml.setRequestHeader("Connection", "close");
-		// Wait for a response to come back
-		var onreadystatechange = function(istimeout){
-			// The transfer is complete and the data is available, or the request timed out
-			if ( xml && (xml.readyState == 4 || istimeout == "timeout") ) {
-				requestDone = true;
-				var status = jQuery.httpSuccess( xml ) && istimeout != "timeout" ?
-					ifModified && jQuery.httpNotModified( xml, url ) ? "notmodified" : "success" : "error";
-				// Make sure that the request was successful or notmodified
-				if ( status != "error" ) {
-					// Cache Last-Modified header, if ifModified mode.
-					var modRes = xml.getResponseHeader("Last-Modified");
-					if ( ifModified && modRes ) jQuery.lastModified[url] = modRes;
-					// If a local callback was specified, fire it
-					if ( success ) success( xml, status );
-					// Fire the global callback
-					jQuery.event.trigger( "ajaxSuccess" );
-				// Otherwise, the request was not successful
-				} else {
-					if ( error ) error( xml, status );
-					jQuery.event.trigger( "ajaxError" );
-				// The request was completed
-				jQuery.event.trigger( "ajaxComplete" );
-				// Handle the global AJAX counter
-				if ( ! --jQuery.active )
-					jQuery.event.trigger( "ajaxStop" );
-				// Process result
-				if ( ret ) ret(xml, status);
-				// Stop memory leaks
-				xml.onreadystatechange = function(){};
-				xml = null;
-		xml.onreadystatechange = onreadystatechange;
-		// Timeout checker
-		if(jQuery.timeout > 0)
-			setTimeout(function(){
-				// Check to see if the request is still happening
-				if (xml) {
-					// Cancel the request
-					xml.abort();
-					if ( !requestDone ) onreadystatechange( "timeout" );
-					xml = null;
-			}, jQuery.timeout);
-		// Send the data
-		xml.send(data);
-	// Counter for holding the number of active queries
-	active: 0,
-	// Determines if an XMLHttpRequest was successful or not
-	httpSuccess: function(r) {
-		try {
-			return !r.status && location.protocol == "file:" ||
-				( r.status >= 200 && r.status < 300 ) || r.status == 304 ||
-				jQuery.browser.safari && r.status == undefined;
-		} catch(e){}
-		return false;
-	// Determines if an XMLHttpRequest returns NotModified
-	httpNotModified: function(xml, url) {
-		try {
-			var xmlRes = xml.getResponseHeader("Last-Modified");
-			// Firefox always returns 200. check Last-Modified date
-			return xml.status == 304 || xmlRes == jQuery.lastModified[url] ||
-				jQuery.browser.safari && xml.status == undefined;
-		} catch(e){}
-		return false;
-	// Get the data out of an XMLHttpRequest.
-	// Return parsed XML if content-type header is "xml" and type is "xml" or omitted,
-	// otherwise return plain text.
-	httpData: function(r,type) {
-		var ct = r.getResponseHeader("content-type");
-		var data = !type && ct && ct.indexOf("xml") >= 0;
-		data = type == "xml" || data ? r.responseXML : r.responseText;
-		// If the type is "script", eval it
-		if ( type == "script" ) eval.call( window, data );
-		// Get the JavaScript object, if JSON is used.
-		if ( type == "json" ) eval( "data = " + data );
-		return data;
-	// Serialize an array of form elements or a set of
-	// key/values into a query string
-	param: function(a) {
-		var s = [];
-		// If an array was passed in, assume that it is an array
-		// of form elements
-		if ( a.constructor == Array ) {
-			// Serialize the form elements
-				s.push( a[i].name + "=" + encodeURIComponent( a[i].value ) );
-		// Otherwise, assume that it's an object of key/value pairs
-		} else {
-			// Serialize the key/values
-			for ( var j in a )
-				s.push( j + "=" + encodeURIComponent( a[j] ) );
-		// Return the resulting serialization
-		return s.join("&");
\ No newline at end of file
More information about the Mapbender_commits
