[Mapbender-commits] r1131 - trunk/mapbender/http/javascripts
svn_mapbender at osgeo.org
Thu Feb 22 11:54:09 EST 2007
Author: christoph
Date: 2007-02-22 11:54:09 -0500 (Thu, 22 Feb 2007)
New Revision: 1131
trunk/mapbender/http/javascripts/map.php
moved code from geometry.js
Modified: trunk/mapbender/http/javascripts/map.php
--- trunk/mapbender/http/javascripts/map.php 2007-02-22 16:52:34 UTC (rev 1130)
+++ trunk/mapbender/http/javascripts/map.php 2007-02-22 16:54:09 UTC (rev 1131)
@@ -180,9 +180,7 @@
function mb_mapObj_const(frameName, elementName, width, height, wms_index){
this.width = width;
this.height = height;
this.frameName = frameName;
@@ -1264,6 +1262,97 @@
return false;
+// DivTag
+function DivTag (aTagName, aFrameName, aStyle) {
+ this.exists = function () {
+ return (rootNode.getElementById(tagName))?true:false;
+ var determineRootNode = function () {
+ node = document;
+ if (frameName !== "") {
+ if (checkFrame()) {node = window.frames[frameName].document;}
+ else {alert("frame "+frameName+" doesn't exist.");}
+ return node;
+ var reformatJavaStyle = function(aString) {
+ var newString = "";
+ for (var i = 0; i < aString.length; i++) {
+ if (aString.substr(i,1) != "-") {
+ newString += aString.substr(i,1);
+ else {
+ i++;
+ newString += aString.substr(i,1).toUpperCase();
+ return newString;
+ var setStyle = function () {
+ if (that.exists()) {
+ var node = rootNode.getElementById(tagName);
+ node.setAttribute("style", "");
+ for (var attr in tagStyle) {
+ if (typeof(tagStyle[attr] != "function") && typeof(tagStyle[attr] != "object")) {
+ var evalString = "node.style."+reformatJavaStyle(attr)+" = \"" + tagStyle[attr] + "\";";
+ eval(evalString);
+ var create = function () {
+ if (!that.exists()) {
+ var divTag = rootNode.createElement("div");
+ var divTagAppended = rootNode.getElementsByTagName("body")[0].appendChild(divTag);
+ divTagAppended.id = tagName;
+ else {
+ that.clean();
+ setStyle();
+ var checkFrame = function () {
+ return (typeof(window.frames[frameName]) != 'undefined');
+ return true;
+ this.getTag = function() {
+ return rootNode.getElementById(tagName);
+ var that = this;
+ var tagName = aTagName;
+ var frameName = aFrameName;
+ var rootNode = determineRootNode();
+ var tagStyle = aStyle;
+ create();
+DivTag.prototype.write = function (someText) {
+ if (this.exists()) {
+ this.getTag().innerHTML = someText;
+DivTag.prototype.clean = function () {
+ this.write("");
function mb_checkTag(frameName, tagName, elementId, appendAtTagName, attributes){
var oldElement;
var newElement;
More information about the Mapbender_commits
