[Mapbender-commits] r1134 - trunk/mapbender/resources/db/mysql
svn_mapbender at osgeo.org
Fri Feb 23 05:43:26 EST 2007
Author: astrid_emde
Date: 2007-02-23 05:43:26 -0500 (Fri, 23 Feb 2007)
New Revision: 1134
trunk/mapbender/resources/db/mysql/mysql_schema.sql
added new columns in table wfs_conf_element
Modified: trunk/mapbender/resources/db/mysql/mysql_schema.sql
--- trunk/mapbender/resources/db/mysql/mysql_schema.sql 2007-02-22 16:57:20 UTC (rev 1133)
+++ trunk/mapbender/resources/db/mysql/mysql_schema.sql 2007-02-23 10:43:26 UTC (rev 1134)
@@ -394,6 +394,9 @@
f_label_id varchar(50) default NULL,
f_show tinyint(3) unsigned default NULL,
f_respos int(11) default NULL,
+ f_form_element_html TEXT NULL,
+ f_edit int4,
+ f_mandatory int4,
PRIMARY KEY (wfs_conf_element_id),
KEY fkey_wfs_conf_id (fkey_wfs_conf_id)
) TYPE=InnoDB;
@@ -721,17 +724,6 @@
-- wms_owner has to be set
-- Update wms set wms_owner =1;
--- new columns in table wfs_conf_element
--- Selectbox (Text) for predefined values
-ALTER TABLE wfs_conf_element ADD f_box TEXT NULL ;
--- editable
-ALTER TABLE wfs_conf_element ADD COLUMN f_edit int4;
--- Pflichtfeld / mandatory
-ALTER TABLE wfs_conf_element ADD COLUMN f_mandatory int4;
-- add missing primary keys
More information about the Mapbender_commits
