[Mapbender-commits] r1141 - trunk/mapbender/http/php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri Feb 23 07:06:00 EST 2007
Author: christoph
Date: 2007-02-23 07:06:00 -0500 (Fri, 23 Feb 2007)
New Revision: 1141
   trunk/mapbender/http/php/mod_wfs_result.php
removed obsolete function
Modified: trunk/mapbender/http/php/mod_wfs_result.php
--- trunk/mapbender/http/php/mod_wfs_result.php	2007-02-23 11:58:17 UTC (rev 1140)
+++ trunk/mapbender/http/php/mod_wfs_result.php	2007-02-23 12:06:00 UTC (rev 1141)
@@ -34,53 +34,6 @@
-function addParameterToFilter($filter) {
-	$doc = new DOMDocument('1.0');
-	$doc->encoding = CHARSET;
-	$doc->preserveWhiteSpace = false;
-	$doc->loadXML($filter);
-	return $doc->saveXML();
-	$andNode = $doc->createElement('And');
-	// get all 'within' nodes
-	$nodeListWithin = $doc->getElementsByTagName('Within');
-	for ($i=0 ; $i < $nodeListWithin->length ; $i++) {
-		$currentNode = $doc->removeChild($nodeListWithin->item($i));
-		$andNode->appendChild($currentNode);
-	// get all 'ogc:BBOX' nodes
-	$nodeListBox = $doc->getElementsByTagNameNS('http://ogc.org', 'BBOX');
-	for ($i=0 ; $i < $nodeListBox->length ; $i++) {
-		$currentNode = $doc->removeChild($nodeListBox->item($i));
-	// generate 'propertyIsLike' Node
-	$propertyIsLikeNode = $doc->createElementNS('http://ogc.org', 'PropertyIsLike');
-	$propertyIsLikeNode->setAttribute('wildCard', '*');
-	$propertyIsLikeNode->setAttribute('singleChar', '.');
-	$propertyIsLikeNode->setAttribute('escape', '!');
-	$propertyNameNode = $doc->createElementNS('http://ogc.org', 'PropertyName', 'ud_id');
-	$propertyIsLikeNode->appendChild($propertyNameNode);
-	$literalNode = $doc->createElementNS('http://ogc.org', 'Literal', '*'.$_SESSION['AstUdNr']);
-	$propertyIsLikeNode->appendChild($literalNode);
-	$andNode->appendChild($propertyIsLikeNode);
-	// add 'And' node to XML
-	$nodeListFilter = $doc->getElementsByTagNameNS('http://ogc.org', 'Filter');
-	for ($i=0 ; $i < $nodeListFilter->length ; $i++) {
-		$currentNode = $nodeListFilter->item($i);
-		$currentNode->appendChild($andNode);
-//echo addParameterToFilter($filter);die();
 $wfsRequest = $url . urlencode($filter);
 $connection = new connector($wfsRequest);
 $data = $connection->file;
@@ -151,6 +104,7 @@
 		else {
 			$geom_str .= "alert('unknown geomtype ".sepNameSpace($element[tag])."');";
+		// TO DO: the following is added twice! Once suffices.
 		$element_str .= "geom.get(" . $member . ").e.setElement('fid', '".$fid."');\n";
 		$element_str .= "geom.get(" . $member . ").wfs_conf = ".$_REQUEST['wfs_conf_id'].";\n";
More information about the Mapbender_commits mailing list
