[Mapbender-commits] r1143 - trunk/mapbender/http/javascripts
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri Feb 23 09:22:38 EST 2007
Author: christoph
Date: 2007-02-23 09:22:38 -0500 (Fri, 23 Feb 2007)
New Revision: 1143
Added:
   trunk/mapbender/http/javascripts/geometry.js
geometry library
Added: trunk/mapbender/http/javascripts/geometry.js
--- trunk/mapbender/http/javascripts/geometry.js	                        (rev 0)
+++ trunk/mapbender/http/javascripts/geometry.js	2007-02-23 14:22:38 UTC (rev 1143)
@@ -0,0 +1,790 @@
+* $Id$
+* COPYRIGHT: (C) 2001 by ccgis. This program is free software under the GNU General Public
+* License (>=v2). Read the file gpl.txt that comes with Mapbender for details.
+// http://www.mapbender.org/index.php/GeometryArray.js
+var nameGeometryArray = "GeometryArray";
+var nameMultiGeometry = "MultiGeometry";
+var nameGeometry = "Geometry";
+var geomType = (
+	function () {
+		function ConstructorFunction(){
+			this.polygon = "polygon";
+			this.line = "line";
+			this.point = "point";
+		return new ConstructorFunction();
+// List: a template for geometry data structures
+var List = function() {
+	this.count = function() {
+		return this.list.length;
+	this.del = function(i){
+		i = this.getIndex(i);
+		for(var z = i; z < this.count() - 1; z++){
+			this.list[z] = this.list[z+1];
+		this.list.length -= 1;
+	this.get = function(i) {
+		if (i !== null) {return this.list[i];}
+		return false;
+	this.add = function(item) {
+		this.list.push(item);
+	this.addCopy = function(item) {
+		this.list.push(cloneObject(item));
+	this.union = function(aList) {
+		for (var i=0; i < aList.count(); i++) {this.addCopy(aList.get(i));}
+	this.getIndex = function(i){
+		if ((i >= 0 && i < this.list.length) || (i*(-1)>0 && i*(-1) <= this.list.length)){
+			if (i >= 0) {return i;} else {return this.list.length+i;}
+		else {
+			alert("exception: member index " + i + " is not valid");
+			return null;
+	this.toString = function(){
+		var str = "";
+		for (var i =0 ; i < this.count() ; i++){
+			str += this.get(i).toString();
+		return str;
+	this.list = null;
+// GeometryArray
+function GeometryArray(){
+	this.addMember = function(geomType){
+		this.add(new MultiGeometry(geomType));
+	this.name = nameGeometryArray;
+	this.list = [];
+GeometryArray.prototype = new List();
+GeometryArray.prototype.getGeometry = function(i,j){
+	return this.get(i).get(j);
+GeometryArray.prototype.getPoint = function(i,j,k){
+	return this.get(i).get(j).get(k);
+GeometryArray.prototype.findMultiGeometry = function(geom) {
+	var a = [];
+	for (var i=0; i < this.count(); i++) {
+		if (this.get(i).equals(geom)) {a.push(i);}
+	return a;
+GeometryArray.prototype.delGeometry = function(i,j){
+	if (this.get(i).del(j) === false) {this.del(i);}
+GeometryArray.prototype.delPoint = function (i,j,k){
+	var res = this.get(i).delPoint(j,k);
+	if (res === false) {this.del(i);}
+GeometryArray.prototype.close = function(){
+	if (!this.get(-1).get(-1).close()) {
+		this.delGeometry(-1, -1);
+	else {
+		if (this.get(-1).get(-1).count() === 0) {this.get(-1).del(-1);}
+		if (this.get(-1).count() === 0) {this.del(-1);}
+GeometryArray.prototype.delAllPointsLike = function(point){
+	var finished = false;
+	while (finished === false){
+		finished = true;
+		for (var i = 0 ; finished === true && i < this.count() ; i++){
+			for (var j = 0 ; finished === true && j < this.get(i).count() ; j++){
+				for (var k = 0 ; finished === true && k < this.get(i).get(j).count() ; k++){
+					if (this.getPoint(i,j,k).equals(point)){
+						this.delPoint(i,j,k);
+						finished = false;
+GeometryArray.prototype.updateAllPointsLike = function(oldP, newP){
+	for (var i = 0; i < this.count(); i++){
+		this.get(i).updateAllPointsLike(oldP, newP);
+// MultiGeometry
+function MultiGeometry(geomType){
+	this.addGeometry = function(){
+		this.add(new Geometry(this.geomType));
+		if (i !== null){
+			var tmpLength = this.count() - 1;
+			for (var z = i; z < tmpLength ; z ++){
+				e[z] = e[z+1];
+			if (this.list.length === 0) {return false;}
+		return true;
+	this.list = [];
+	this.e = new Wfs_element();
+	this.geomType = geomType;
+	this.name = nameMultiGeometry;
+MultiGeometry.prototype = new List();
+MultiGeometry.prototype.updateAllPointsLike = function(oldP, newP){
+	for (var i = 0; i < this.count(); i++) {this.get(i).updateAllPointsLike(oldP, newP);}
+MultiGeometry.prototype.getBBox = function(){
+	var q = this.get(0).get(0);
+	var min = cloneObject(q);
+	var max = cloneObject(q);
+	for(var i=0; i<this.count();i++){
+		var pos = this.get(i).getBBox();
+		if (pos[0].x < min.x) {min.x = pos[0].x;}
+		if (pos[1].x > max.x) {max.x = pos[1].x;}
+		if (pos[1].y > max.y) {max.y = pos[1].y;}
+		if (pos[0].y < min.y) {min.y = pos[0].y;}
+	return [min, max];
+MultiGeometry.prototype.getCenter = function(){
+	var tmp = this.getBBox();
+	var x = parseFloat(tmp[0].x) + parseFloat((tmp[1].x - tmp[0].x)/2);
+	var y = parseFloat(tmp[0].y) + parseFloat((tmp[1].y - tmp[0].y)/2);
+	return new Point(x,y);
+MultiGeometry.prototype.getTotalPointCount = function(){
+	var c = 0;
+	for (var i = 0 ; i < this.count(); i++)	{c += this.get(i).count();}
+	return c;
+MultiGeometry.prototype.getPoint = function(j,k){
+	return this.get(j).get(k);
+MultiGeometry.prototype.equals = function(multigeom) {
+	if (this.geomType != multigeom.geomType) {return false;}
+	if (this.count() != multigeom.count()) {return false;}
+	if (this.getTotalPointCount() != multigeom.getTotalPointCount()) {return false;}
+	for (var i=0; i<this.count(); i++) {
+		if (!this.get(i).equals(multigeom.get(i))) {return false;}
+	return true;
+MultiGeometry.prototype.delPoint = function(i,j){ // public
+	var res = this.get(i).del(j);
+	if (res === false) {return this.del(i);}
+	return true;
+// Geometry
+function Geometry(aGeomtype){
+		if (i !== null) {
+			var tmpLength = this.count()-1;
+			if (this.geomType == geomType.polygon){
+				if (i == tmpLength) {this.list[0] = this.list[tmpLength-1];}
+				else if (i === 0) {this.list[tmpLength-1] = this.list[0];}
+				if (this.list.length == 1){return false;}
+			updateDist();
+			if(this.list.length === 0) {return false;}
+			return true;
+		return false;
+	this.addPointByCoordinates = function(x,y){
+		this.add(new Point(x,y));
+		updateDist();
+	this.addPoint = function(aPoint){
+		this.add(new Point(aPoint.x, aPoint.y));
+		updateDist();
+	this.addPointAtIndex = function(p,i){
+		if (i !== null){
+			for(var z = this.count(); z > i; z--){
+				this.list[z] = this.list[z-1];
+			this.list[i] = new Point(p.x, p.y);
+			updateDist();
+	this.updateGeometry = function(p, i){
+		if ((i === 0 || i == this.count()-1) && this.geomType == geomType.polygon){
+			this.list[0] = p;
+			this.list[this.count()-1] = p;
+		else {this.list[i] = p;}
+		updateDist();
+	var updateDist = function(){
+		dist[0] = 0;
+		totaldist[0] = 0;
+		for (var i = 1 ; i < that.count(); i++){
+			dist[i] = that.get(i-1).dist(that.get(i));
+			totaldist[i] = totaldist[i-1] + dist[i];
+	this.getCurrentDist = function(numberOfDigits) {
+		if (typeof(numberOfDigits) == "number") {
+			return roundToDigits(dist[this.count()-1], numberOfDigits);
+		return dist[this.count()-1];
+	this.getTotalDist = function(numberOfDigits) {
+			return roundToDigits(totaldist[this.count()-1], numberOfDigits);
+		return totaldist[this.count()-1];
+	this.close = function(){
+		complete = true;
+			if (this.count() > 2){
+				if (!this.get(0).equals(this.get(-1))) {
+					this.addPoint(this.get(0));
+			else {return false;}
+		if (this.geomType == geomType.line){
+			if (this.count() < 2){return false;}
+		return true;
+	this.isComplete = function() {
+		return complete;
+	this.list = [];
+	var dist = [];
+	var totaldist = [];
+	var complete = false;
+	var that = this;
+	this.geomType = aGeomtype;
+	this.name = nameGeometry;
+Geometry.prototype = new List();
+Geometry.prototype.getBBox = function(){
+	var q = this.get(0);
+	for (var j=0; j<this.count(); j++){
+		var pos = this.get(j);
+		if (pos.x < min.x) {min.x = pos.x;}
+		else if (pos.x > max.x) {max.x = pos.x;}
+		if (pos.y < min.y) {min.y = pos.y;}
+		else if (pos.y > max.y) {max.y = pos.y;}
+Geometry.prototype.updateAllPointsLike = function(oldP, newP){
+	var len = this.count();
+	for (var i = 0; i < len ; i++){
+		if (oldP.equals(this.get(i))){
+			if (i>0 && newP.equals(this.get(i-1))){
+				this.del(i);
+				len--;
+				i--;
+			else {this.updateGeometry(newP, i);}
+Geometry.prototype.equals = function(geom) {
+	if (this.geomType != geom.geomType) {return false;}
+	if (this.count() != geom.count()) {return false;}
+		if (!this.get(i).equals(geom.get(i))) {return false;}
+	return true;
+// Wfs_element (FIXME)
+function Wfs_element(){
+	this.count = function(){return name.length;};
+	this.getName = function(i){
+		if (isValidElementIndex(i)) {return name[i];}
+		return false;
+	this.getValue = function(i){
+		if (isValidElementIndex(i)) {return value[i];}
+		return false;
+	this.setElement = function(aName, aValue){
+		var i = this.getElementIndexByName(aName);
+		if (i === false) {i = this.count();}
+		name[i] = aName;
+		value[i] = aValue;
+		return true;
+	var isValidElementIndex = function(i){
+		if (i>=0 && i<name.length) {return true;}
+		alert("exception: illegal element index");
+		return false;
+	var name  = [];
+	var value = [];
+Wfs_element.prototype.getElementIndexByName = function(elementName){
+	for (var j = 0 ; j < this.count() ; j++){
+		if (this.getName(j) == elementName) {return j;}
+	return false;
+Wfs_element.prototype.getElementValueByName = function(elementName){
+	var i = this.getElementIndexByName(elementName);
+	if (i === false) {return false;}
+	return this.getValue(i);
+// Canvas
+function Canvas(aMapframe, aTagName, aStyle, aLineWidth) {
+	this.drawGeometry = function(t,g,col){
+		var mapObjInd = getMapObjIndexByName(mapframe);
+		width = mb_mapObj[mapObjInd].width;
+		height = mb_mapObj[mapObjInd].height;
+		for(var i=0; i < g.count(); i++){
+			if(t==geomType.point) {
+				var p = realToMap(mapframe,g.get(i).get(0));
+				if (p.x + diameter < mb_mapObj[mapObjInd].width && p.x - diameter > 0 &&
+					p.y + diameter < mb_mapObj[mapObjInd].height && p.y - diameter > 0) {
+					drawCircle(p.x-1, p.y-1, diameter,col);
+			else if(t==geomType.line || t==geomType.polygon) {
+				for (var j=0; j<g.get(i).count()-1; j++) {
+					var pq = calculateVisibleDash(realToMap(mapframe,g.get(i).get(j)), realToMap(mapframe,g.get(i).get(j+1)), width, height);
+					if (pq) {
+						drawLine([pq[0].x-1, pq[1].x-1], [pq[0].y-1, pq[1].y-1], col);
+			else {
+				alert('unknown geomType ' + t);
+	this.isTooSmall = function(g){
+		var tmp = g.getBBox();
+		var min = realToMap(mapframe,tmp[0]);
+		var max = realToMap(mapframe,tmp[1]);
+		if((Math.abs(max.x - min.x) < minWidth) && (Math.abs(max.y - min.y) < minWidth)) {
+			return true;
+		return false;
+	var drawCircle = function(x, y, diameter, color) {
+		canvas.setColor(color);
+		canvas.drawEllipse(x-diameter/2,y-diameter/2,diameter,diameter);
+	var drawLine = function(x_array, y_array, color) {
+		canvas.drawPolyline(x_array, y_array);
+	this.getCanvas = function(){return canvas;};
+	var diameter = 8;
+	var minWidth = 8;
+	var lineWidth = aLineWidth;
+	var mapframe = aMapframe;
+	var style = aStyle;
+	var that = this;
+	this.canvasDivTag = new DivTag(aTagName, mapframe, style);
+	var canvas = new jsGraphics(aTagName, window.frames[mapframe]);
+	canvas.setStroke(lineWidth);
+	mb_registerPanSubElement(aTagName);
+Canvas.prototype.clean = function () {
+	this.canvasDivTag.clean();
+Canvas.prototype.paint = function(gA) {
+	for (var q = 0; q < gA.count(); q++) {
+		var m = gA.get(q);
+		var t = m.geomType;
+		var col = m.color;
+		if (t == geomType.point) {this.drawGeometry(t,m,col);}
+		else {
+			if (this.isTooSmall(m)){
+				var newMember = new MultiGeometry(geomType.point);
+				newMember.addGeometry();
+				newMember.get(-1).addPoint(m.getCenter());
+				this.drawGeometry(geomType.point,newMember,col);
+			else{
+				if(t == geomType.line) {this.drawGeometry(t,m, col);}
+				else if(t == geomType.polygon) {this.drawGeometry(t,m,col);}
+				else {alert("unknown geomType");}
+	this.getCanvas().paint();
+// Highlight
+function Highlight(aTargetArray, aTagName, aStyle, aLineWidth) {
+	this.del = function(m, color) {
+		var a = gA.findMultiGeometry(m);
+		var del = false;
+		for (var i=0; i<a.length && del === false; i++) {
+			if (gA.get(a[i]).color == color) {
+				gA.del(a[i]);
+				del = true;
+		this.paint();
+	this.add = function(m, color) {
+		gA.addCopy(m);
+		if (typeof(color) != 'undefined') {gA.get(-1).color = color;}
+		else {gA.get(-1).color = lineColor;}
+		this.paint();
+	this.clean = function() {
+		if (gA.count() > 0) {
+			gA = new GeometryArray();
+			this.paint();
+	this.paint = function() {
+		for (var i=0; i < canvas.length; i++) {
+			if (typeof(canvas[i]) == "object") {canvas[i].clean();}
+		for (var i=0; i<targets.length; i++){
+			if (typeof(canvas[i]) == 'undefined') {
+				canvas[i] = new Canvas(targets[i], tagname, style, lineWidth);
+			canvas[i].paint(gA);
+	var tagname = 'mod_gaz_draw'+aTagName;
+	var targets = aTargetArray;
+	var canvas = [];
+	var gA = new GeometryArray();
+	var lineColor = "#ff0000";
+// Snapping
+function Snapping(aTarget, aTolerance, aColor, aZIndex){
+	this.draw = function(center,radius){
+		mG = new MultiGeometry(geomType.point);
+		mG.addGeometry();
+		mG.get(-1).addPoint(center);
+		highlight.add(mG);
+	this.getTolerance = function() {return tolerance;};
+	this.getTarget = function() {return target;};
+	this.cleanHighlight = function() {return highlight.clean();};
+	this.addPoint = function(aPoint) {coord.push(aPoint);};
+	this.getPointCount = function() {return coord.length;};
+	this.getPoint = function(i) {return coord[i];};
+	this.resetPoints = function() {coord = [];};
+	this.getNearestNeighbour = function(){
+		if (min_i != -1) {return this.getPoint(min_i);}
+		return false;
+	this.setIndexOfNearestNeighbour = function(i){min_i = i;};
+	this.resetIndexOfNearestNeighbour = function(){min_i = -1;};
+	var tolerance = (typeof(aTolerance) == 'undefined') ? 10 : aTolerance;
+	var coord = [];
+	var min_i = -1;
+	var target = aTarget;
+	var lineWidth = 2;
+	var style = {"position":"absolute", "top":"0px", "left":"0px", "z-index":aZIndex};
+	var highlight = new Highlight([target], "snapping"+Math.round(Math.random()*Math.pow(10,10)), style, lineWidth);
+Snapping.prototype.check = function(currPoint){
+	var minDist = false;
+	for (var i = 0 ; i < this.getPointCount() ; i++) {
+		var currDist = currPoint.dist(realToMap(this.getTarget(), this.getPoint(i)));
+		if (minDist === false || currDist < minDist) {
+			minDist = currDist;
+			if (minDist < this.getTolerance()) {this.setIndexOfNearestNeighbour(i);}
+	if (this.getPointCount() > 0 && minDist > this.getTolerance()) {
+		this.resetIndexOfNearestNeighbour();
+	this.cleanHighlight();
+	if (this.isSnapped()) {
+		this.draw(this.getNearestNeighbour(), this.getTolerance());
+Snapping.prototype.store = function(geom, point){
+	this.resetPoints();
+	for (var i = 0 ; i < geom.count(); i++){
+		if (geom.name == nameGeometryArray || geom.name == nameMultiGeometry){
+			for (var j = 0 ; j < geom.get(i).count() ; j++){
+				if (geom.get(i).name == nameMultiGeometry){
+					for (var k = 0 ; k < geom.get(i).get(j).count() ; k++){
+						if ((geom.get(i).get(j).isComplete() === true && typeof(point) == 'undefined') || (typeof(point) != 'undefined' && !geom.get(i).get(j).get(k).equals(point))){
+							this.add(geom.getPoint(i, j, k));
+				else {
+					if ((geom.get(i).isComplete() === true && typeof(point) == 'undefined') || (typeof(point) != 'undefined' && !geom.get(i).get(j).get(k).equals(point))){
+						this.add(geom.getPoint(i, j));
+		else {
+			if (typeof(point) != 'undefined' && !geom.get(i).get(j).get(k).equals(point)){
+				this.add(geom.get(i));
+Snapping.prototype.isSnapped = function(){
+	if (this.getNearestNeighbour() !== false) {return true;}
+	return false;
+Snapping.prototype.getSnappedPoint = function(geom){
+	return this.getNearestNeighbour();
+Snapping.prototype.add = function(aPoint){
+	this.addPoint(aPoint);
+Snapping.prototype.clean = function(){
+// misc. functions
+function calculateVisibleDash (p0, p1, width, height) {
+	if (p0.x > p1.x) {var p_temp = p0; p0 = p1; p1 = p_temp; p_temp = null;}
+	var p = p0; var q = p1; var m; var ix; var iy;
+	if (p1.x != p0.x) {
+		m = -(p1.y-p0.y)/(p1.x-p0.x);
+		if (p0.x < width && p1.x > 0 && !(p0.y < 0 && p1.y < 0) && !(p0.y > height && p1.y > height) ) {
+			if (p0.x < 0) {
+				iy = p0.y - m*(0-p0.x);
+				if (iy > 0 && iy < height) {p = new Point(0, iy);}
+				else if (iy > height) {
+				    ix = p0.x+((p0.y - height)/m);
+				    if (ix > 0 && ix < width) {p = new Point(ix, height);} else {return false;}
+				else if (iy < 0) {
+				    ix = p0.x+(p0.y/m);
+				    if (ix > 0 && ix < width) {p = new Point(ix, 0);} else {return false;}
+			else if (p0.y >= 0 && p0.y <= height) {p = p0;}
+			else if (p0.y < 0) {
+			else if (p0.y > height && m > 0) {
+			if (p1.x > width) {
+				iy = p1.y - m*(width-p1.x);
+				if (iy > 0 && iy < height) {q = new Point(width, iy);}
+				    if (ix > 0 && ix < width) {q = new Point(ix, 0);} else {return false;}
+				    if (ix > 0 && ix < width) {q = new Point(ix, height);} else {return false;}
+			else if (p1.y >= 0 && p1.y <= height) {q = p1;}
+			else if (p1.y < 0) {
+			    ix = p1.x+(p1.y/m);
+			else if (p1.y > height) {
+			    ix = p1.x+((p1.y- height)/m);
+	else {
+		if (!(p0.y < 0 && p1.y < 0) && !(p0.y > height && p1.y > height)) {
+			if (p0.y < 0) {p = new Point(p0.x, 0);}
+			else if (p0.y > height) {p = new Point(p0.x, height);}
+			else {p = p0;}
+			if (p1.y < 0) {q = new Point(p0.x, 0);}
+			else if (p1.y > height) {q = new Point(p0.x, height);}
+			else {q = p1;}
+	return [new Point(Math.round(q.x), Math.round(q.y)), new Point(Math.round(p.x), Math.round(p.y))];
+function objString (a){
+	var z = "";
+	for (attr in a) {
+		var b = a[attr];
+		if (typeof(b) == "object") {z += objString(b);}
+		else {z += attr + " " + b + "\n";alert(attr + " " + b);}
+	return z;
+function cloneObject(a){
+	var z = [];
+	for (attr in a) {
+		var b = a[attr];
+		if (typeof(b) == "object") {z[attr] = cloneObject(b);}
+		else {z[attr] = b;}
+	return z;
\ No newline at end of file
Property changes on: trunk/mapbender/http/javascripts/geometry.js
___________________________________________________________________
   + HeadURL Id LastChangedBy LastChangedDate LastChangedRevision
More information about the Mapbender_commits mailing list
