[Mapbender-commits] r1010 - trunk/mapbender/http/php
svn_mapbender at osgeo.org
Tue Jan 16 06:53:16 EST 2007
Author: christoph
Date: 2007-01-16 06:53:16 -0500 (Tue, 16 Jan 2007)
New Revision: 1010
trunk/mapbender/http/php/mod_wfs_conf.php
trunk/mapbender/http/php/mod_wfs_edit.php
f_box und f_edit
Modified: trunk/mapbender/http/php/mod_wfs_conf.php
--- trunk/mapbender/http/php/mod_wfs_conf.php 2007-01-16 11:27:50 UTC (rev 1009)
+++ trunk/mapbender/http/php/mod_wfs_conf.php 2007-01-16 11:53:16 UTC (rev 1010)
@@ -99,7 +99,7 @@
$res = db_query($sql);
$wfsID = db_insert_id($con,'wfs_conf','wfs_conf_id');
for($i=0; $i<$_REQUEST["num"]; $i++){
- $sql = "INSERT INTO wfs_conf_element (fkey_wfs_conf_id,f_id,f_search,f_pos,f_style_id,f_toupper,f_label,f_label_id,f_show,f_respos) VALUES(";
+ $sql = "INSERT INTO wfs_conf_element (fkey_wfs_conf_id,f_id,f_search,f_pos,f_style_id,f_toupper,f_label,f_label_id,f_show,f_respos,f_edit,f_box) VALUES(";
$sql .= "'".$wfsID."',";
$sql .= "'".$_REQUEST["f_id".$i]."',";
if(!empty($_REQUEST["f_search".$i])){
@@ -115,7 +115,11 @@
if(!empty($_REQUEST["f_show".$i])){
$sql .= "'1',";
}else{$sql .= "'0',";}
- $sql .= "'".$_REQUEST["f_respos".$i]."'";
+ $sql .= "'".$_REQUEST["f_respos".$i]."',";
+ if(!empty($_REQUEST["f_edit".$i])){
+ $sql .= "'1',";
+ }else{$sql .= "'0',";}
+ $sql .= "'".$_REQUEST["f_box".$i]."'";
$sql .= "); ";
@@ -237,6 +241,8 @@
echo "<td>label_id</td>";
echo "<td>show</td>";
echo "<td>position</td>";
+ echo "<td>edit</td>";
+ echo "<td>box</td>";
echo "</tr>";
for($i=0; $i<count($aWFS->elements->element_id); $i++){
@@ -254,6 +260,8 @@
echo "<td><input name='f_label_id".$i."' type='text' size='2' value='0'></td>";
echo "<td><input name='f_show".$i."' type='checkbox'></td>";
echo "<td><input name='f_respos".$i."' type='text' size='4' value='0'></td>";
+ echo "<td><input name='f_edit".$i."' type='checkbox'></td>";
+ echo "<td><textarea name='f_box".$cnt."' cols='15' rows='1' ></textarea></td>";
echo "</tr>";
echo "</table>";
Modified: trunk/mapbender/http/php/mod_wfs_edit.php
--- trunk/mapbender/http/php/mod_wfs_edit.php 2007-01-16 11:27:50 UTC (rev 1009)
+++ trunk/mapbender/http/php/mod_wfs_edit.php 2007-01-16 11:53:16 UTC (rev 1010)
@@ -117,7 +117,13 @@
$sql .= '1';
}else{$sql .= '0';}
$sql .= "',";
- $sql .= "f_respos = '".$_REQUEST["f_respos".$i]."'";
+ $sql .= "f_respos = '".$_REQUEST["f_respos".$i]."', ";
+ $sql .= "f_edit = '";
+ $sql .= '1';
+ }else{$sql .= '0';}
+ $sql .= "',";
+ $sql .= "f_box = '".addslashes($_REQUEST["f_box".$i])."' ";
$sql .= " WHERE fkey_wfs_conf_id = ".$_REQUEST["gaz"]." AND f_id = ".$_REQUEST["f_id".$i].";";
@@ -190,6 +196,8 @@
echo "</tr>";
$cnt = 0;
while($row = db_fetch_array($res)){
@@ -217,6 +225,10 @@
if($row["f_show"] == 1){ echo " checked"; }
echo "></td>";
echo "<td><input name='f_respos".$cnt."' type='text' size='4' value='".$row["f_respos"]."'></td>";
+ echo "<td><input name='f_edit".$cnt."' type='checkbox'";
+ if($row["f_edit"] == 1){ echo " checked"; }
+ echo "></td>";
+ echo "<td><textarea name='f_box".$cnt."' cols='15' rows='1' >".$row["f_box"]."</textarea></td>";
echo "</tr>";
$cnt++;
More information about the Mapbender_commits
