[Mapbender-commits] r1022 - in trunk/mapbender/http: html javascripts
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Wed Jan 24 05:28:58 EST 2007
Author: nimix
Date: 2007-01-24 05:28:58 -0500 (Wed, 24 Jan 2007)
New Revision: 1022
   trunk/mapbender/http/html/mod_treefolder2.php
   trunk/mapbender/http/javascripts/jsTree.js
adapt code conventions to coding style
Modified: trunk/mapbender/http/html/mod_treefolder2.php
--- trunk/mapbender/http/html/mod_treefolder2.php	2007-01-24 09:01:34 UTC (rev 1021)
+++ trunk/mapbender/http/html/mod_treefolder2.php	2007-01-24 10:28:58 UTC (rev 1022)
@@ -1,6 +1,24 @@
 <?php
+# $Id:
+# http://www.mapbender.org/index.php/Mod_treefolder2.php
+# Copyright (C) 2007 Melchior Moos
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
 session_start();
-require_once("../../conf/mapbender.conf");
+require_once(dirname(__FILE__)."/../../conf/mapbender.conf");
 $con = db_connect(DBSERVER,OWNER,PW);
 db_select_db(DB,$con);
 $gui_id = $_SESSION["mb_user_gui"];
@@ -16,14 +34,13 @@
  include '../include/dyn_css.php';
 <script language='JavaScript'>
-/* Treefolder2, written 2006 by Melchior Moos*/
 function openwindow(Adresse) {
 Fenster1 = window.open(Adresse, "Informationen", "width=500,height=500,left=100,top=100,scrollbars=yes,resizable=no");
 Fenster1.focus();
 </script>
-<script src="../javascripts/jsTreeID.js" type="text/javascript" language="JavaScript"></script>
+<script src="../javascripts/jsTree.js" type="text/javascript" language="JavaScript"></script>
 <?php
 echo "<script language='JavaScript'>";
    $sql = "SELECT e_target FROM gui_element WHERE e_id = $1 AND fkey_gui_id = $2";
@@ -77,12 +94,10 @@
 //var menu_layer_switch = ['menu_zoom', ['Zjjj&nbsp;', 'javascript:var sd = "{@strData}";eval(eval(sd.substr(0, sd.length-6))[1][1]);openwindow("../php/mod_layerMetadata.php?id="+parent.mb_mapObj[selectedMap].wms[selectedWMS].objLayer[selectedLayer].layer_uid);',,'info.png']];
 //var menu_info_switch = ['menu_zoom', ['Zmn&nbsp;', 'javascript:var sd = "{@strData}";eval(eval(sd.substr(0, sd.length-6))[1][1]);openwindow("../php/mod_layerMetadata.php?id="+parent.mb_mapObj[selectedMap].wms[selectedWMS].objLayer[selectedLayer].layer_uid);',,'info.png']];
-function select(i,ii,iii)
+function select(i,ii,iii){
 	//ignore if selected
 	if(selectedMap==i && selectedWMS==ii && selectedLayer==iii)return;
-	if(selectedMap==-1 && selectedWMS==-1 && selectedLayer==-1)
+	if(selectedMap==-1 && selectedWMS==-1 && selectedLayer==-1){
 		selectedMap=i;
 		selectedWMS=ii;
 		selectedLayer=iii;
@@ -114,8 +129,7 @@
 	selectedLayer=iii;
-function updateScale()
+function updateScale(){
 	if(!init)return;
 	for(var i=0; i<parent.mb_mapObj.length; i++){
 		var scale = parseInt(parent.mb_getScale(mod_treeGDE_map));
@@ -146,17 +160,14 @@
-function operaLoad()
+function operaLoad(){
 	initArray();
 	renderTree();
 	setTimeout('initWmsCheckboxen();updateScale();',100);
-function loadTree()
-	if(window.opera)
+function loadTree(){
+	if(window.opera){
 		setTimeout('operaLoad()',200);
 		return;
@@ -166,8 +177,7 @@
 	updateScale();
-function reloadTree()
+function reloadTree(){
 	if(!init) return;
 	selectedMap=-1;
 	selectedWMS=-1;
@@ -180,8 +190,7 @@
 	renderTree();
 	if(window.opera)
-	else
+	else{
 		updateScale();
@@ -189,24 +198,20 @@
 parent.mb_registerloadWmsSubFunctions("window.frames['treeGDE'].reloadTree();");
 parent.mb_registerInitFunctions("window.frames['treeGDE'].loadTree();");
-if(showstatus=='true'||alerterror=='true')
+if(showstatus=='true'||alerterror=='true'){
 	parent.mb_registerSubFunctions("window.frames['treeGDE'].init_mapcheck();");
 	init_mapcheck();
 parent.mb_registerSubFunctions("window.frames['treeGDE'].updateScale();");
-function imgerror()
+function imgerror(){
 	var map=parent.getMapObjIndexByName(mod_treeGDE_map);
 	var wms=Number(this.id.substr(4));
 	this.onerror=null;
 	this.onabort=null;
-	if(state[wms]!=-1 && alerterror=='true')
+	if(state[wms]!=-1 && alerterror=='true'){
 		state[wms]=-1;
-		if(confirm('Failed to Load WMS "'+parent.mb_mapObj[map].wms[wms].objLayer[0].layer_title+'" from Server "'+parent.mb_mapObj[map].wms[wms].wms_getmap.substr(0,parent.mb_mapObj[map].wms[wms].wms_getmap.length-1)+'"\nDo you want to try to load it in a new window?'))
+		if(confirm('Failed to Load WMS "'+parent.mb_mapObj[map].wms[wms].objLayer[0].layer_title+'" from Server "'+parent.mb_mapObj[map].wms[wms].wms_getmap.substr(0,parent.mb_mapObj[map].wms[wms].wms_getmap.length-1)+'"\nDo you want to try to load it in a new window?')){
 			window.open(this.src,"");
@@ -216,17 +221,12 @@
 		setNodeImage(arrNodes[0][0]+"|"+parent.mb_mapObj[map].wms[wms].wms_id, "error_folder.png");
-function checkComplete(wms, map, img, first)
-	if(parent.frames[mod_treeGDE_map].document.getElementById(map).complete)
-		if(state[wms]!=-1)
+function checkComplete(wms, map, img, first){
+	if(parent.frames[mod_treeGDE_map].document.getElementById(map).complete){
+		if(state[wms]!=-1){
 			var ind=parent.getMapObjIndexByName(mod_treeGDE_map);
-			for(var i=1;i<parent.mb_mapObj[ind].wms[wms].objLayer.length;i++)
-				if(parent.mb_mapObj[ind].wms[wms].objLayer[i].gui_layer_visible==1)
+			for(var i=1;i<parent.mb_mapObj[ind].wms[wms].objLayer.length;i++){
+				if(parent.mb_mapObj[ind].wms[wms].objLayer[i].gui_layer_visible==1){
 					state[wms]=1;
 					if(showstatus=='true')
 						setNodeImage(img);
@@ -235,10 +235,8 @@
-	else
-		if(first)
+	else{
+		if(first){
 			state[wms]=0;
 			parent.frames[mod_treeGDE_map].document.getElementById(map).onerror=imgerror;
 			parent.frames[mod_treeGDE_map].document.getElementById(map).onabort=imgerror;
@@ -256,23 +254,19 @@
 	if(!init)return;
 	errors = 0;
 	var ind = parent.getMapObjIndexByName(mod_treeGDE_map);
-	if(!parent.mb_mapObj[ind]||!init)
+	if(!parent.mb_mapObj[ind]||!init){
 		setTimeout("init_mapcheck();",100);
 		return;
-	for(var wms=0;wms<parent.mb_mapObj[ind].wms.length;wms++)
+	for(var wms=0;wms<parent.mb_mapObj[ind].wms.length;wms++){
 		var wmsimgid="map_"+wms;
-		if(parent.frames[mod_treeGDE_map].document.getElementById(wmsimgid))
+		if(parent.frames[mod_treeGDE_map].document.getElementById(wmsimgid)){
 			checkComplete(wms, wmsimgid, arrNodes[0][0]+'|'+parent.mb_mapObj[ind].wms[wms].wms_id, true);
-function handleSelectedLayer(mapObj,wms_id,layername,type,status)
+function handleSelectedLayer(mapObj,wms_id,layername,type,status){
 	var mywms = new Array();
 	mywms[0] = wms_id;
 	var mylayername = new Array();
@@ -280,19 +274,15 @@
 	parent.handleSelectedLayer_array(mapObj, mywms, mylayername, type, status);
-function zoomToLayer(j,k,l)
-	if(!j&&!k&&!l)
+function zoomToLayer(j,k,l){
+	if(!j&&!k&&!l){
 		j=selectedMap;
 		k=selectedWMS;
 		l=selectedLayer;
 	var my=parent.mb_mapObj[j].wms[k].objLayer[l].layer_epsg;
-	for(var i=0;i<my.length-1;i++)
-		if(my[i]["epsg"]==parent.mb_mapObj[j].epsg)
+	for(var i=0;i<my.length-1;i++){
+		if(my[i]["epsg"]==parent.mb_mapObj[j].epsg){
 			parent.mb_calculateExtent(mod_treeGDE_map,my[i]["minx"],my[i]["miny"],my[i]["maxx"],my[i]["maxy"]);
 			var arrayExt = parent.mb_mapObj[j].extent.split(",");
 			parent.mb_repaint(mod_treeGDE_map,arrayExt[0],arrayExt[1],arrayExt[2],arrayExt[3]);
@@ -301,23 +291,18 @@
-function move_up(j,k,l)
-	if(!j&&!k&&!l)
+function move_up(j,k,l){
+	if(!j&&!k&&!l){
 		j=selectedMap;
 		k=selectedWMS;
 		l=selectedLayer;
-	if(j==-1||k==-1||l==-1)
+	if(j==-1||k==-1||l==-1){
 		alert("You have to select the WMS you want to move up!")
 		return;
-	if(l!=0)
-		if(l==1)
+	if(l!=0){
+		if(l==1){
 			alert("The Layer you selected is already on top of the WMS");
 			return;
@@ -334,18 +319,15 @@
 	var previousWMS=-1;
 	for(var i=k-1;i>=0;i--)
-		if(parent.mb_mapObj[j].wms[i].gui_wms_visible=='1'||parent.mb_mapObj[j].wms[i].gui_wms_visible==1)
+		if(parent.mb_mapObj[j].wms[i].gui_wms_visible=='1'||parent.mb_mapObj[j].wms[i].gui_wms_visible==1){
 			previousWMS=i;
 			break;
-	if(previousWMS==-1)
+	if(previousWMS==-1){
 		alert("The selected WMS is already on top!")
 		return;
-	if (parent.mb_swapWmsByIndex(j, previousWMS, k) == true)
+	if (parent.mb_swapWmsByIndex(j, previousWMS, k) == true){
 		parent.zoom(parent.mb_mapObj[j].frameName, true, 1.0);
 		parent.mb_execloadWmsSubFunctions();
 		select(j, previousWMS, 0);
@@ -353,24 +335,19 @@
-function move_down(j,k,l)
-	if(!j&&!k&&!l)
+function move_down(j,k,l){
+	if(!j&&!k&&!l){
 		j=selectedMap;
 		k=selectedWMS;
 		l=selectedLayer;
 		alert("You have to select the WMS you want to move down!")
 		return;
-	if(l!=0)
+	if(l!=0){
 		var my = parent.mb_mapObj[j];
-		if(selectedLayer==my.wms[k].objLayer.length-1)
+		if(selectedLayer==my.wms[k].objLayer.length-1){
 			alert("The Layer you selected is already on bottom of the WMS");
 			return;
@@ -385,21 +362,17 @@
 		return;
 	var nextWMS=-1;
-	for(var i=k+1;i<parent.mb_mapObj[j].wms.length;i++)
+	for(var i=k+1;i<parent.mb_mapObj[j].wms.length;i++){
 			nextWMS=i;
 			break;
-	if(nextWMS==-1)
+	if(nextWMS==-1){
 		alert("The selected WMS is already on bottom!")
 		return;
-	if (parent.mb_swapWmsByIndex(j, k, nextWMS) == true)
+	if (parent.mb_swapWmsByIndex(j, k, nextWMS) == true){
 		select(j, nextWMS, 0);
@@ -407,21 +380,17 @@
-function remove_wms(j,k,l)
-	if(!j&&!k&&!l)
+function remove_wms(j,k,l){
+	if(!j&&!k&&!l){
 		j=selectedMap;
 		k=selectedWMS;
 		l=selectedLayer;
 		alert("You have to select the WMS you want to delete!")
 		return;
-	if(l!=0)
+	if(l!=0){
 		alert("It is not possible to delete a single layer, please select a WMS!")
 		return;
@@ -429,28 +398,24 @@
 	for(var i=0;i<parent.mb_mapObj[j].wms.length;i++)
 			visibleWMS++;
-	if(visibleWMS<=1)
+	if(visibleWMS<=1){
 		alert ("Last WMS can't be removed.\n(Der letzte WMS kann nicht entfernt werden.)");
 		return;
-	if(confirm('Are you sure you want to remove "'+parent.mb_mapObj[j].wms[k].objLayer[l].layer_title+'"?'))
+	if(confirm('Are you sure you want to remove "'+parent.mb_mapObj[j].wms[k].objLayer[l].layer_title+'"?')){
   		parent.mb_mapObjremoveWMS(j,k);
-function updateParent(path)
+function updateParent(path){
 	if(lock)return;
 	lock=true;
 	var state=getChildrenCheckState(path, 0);
 	//enableCheckbox(path, (state!=-1)); //3rd state
 	checkNode(path, 0, (state==1));
-	if(state==0 && showstatus=='true')
+	if(state==0 && showstatus=='true'){
 /*		var arrPath = path.split(jst_delimiter[0])
@@ -464,8 +429,7 @@
 	lock=false;
-function handleSelectedWMS(path)
+function handleSelectedWMS(path){
 	if(lock)return;
 	lock=true;
 	var bChk = IsChecked(path, 0);
@@ -477,8 +441,7 @@
 	lock=false;
-function initArray()
+function initArray(){
 	var parentObj = "";
 	var controls="";
 	if(parent.mb_mapObj.length > 0){
@@ -533,8 +496,7 @@
 	init=true;
-function initWmsCheckboxen()
+function initWmsCheckboxen(){
 	var hidden=0;
@@ -564,8 +526,7 @@
 <BODY VLINK="#000000" ALINK="#000000" LINK="#000000" BGCOLOR="#ffffff" TEXT="#000000"
  MARGINHEIGHT="0" MARGINWIDTH="0" LEFTMARGIN="0" TOPMARGIN="0">
 <SCRIPT language="JavaScript" type="text/javascript">
-if(wmsbuttons=='true')
+if(wmsbuttons=='true'){
 	document.writeln("<div>");
 	document.writeln('<a href="javascript:move_up()"><img src="'+imagedir+'/move_up.png" alt="move up" style="position:relative;top:0px;left:0px;"/></a>');
 	document.writeln('<a href="javascript:move_down()"><img src="'+imagedir+'/move_down.png" alt="move down" style="position:relative;top:0px;left:-3px"/></a>');
Property changes on: trunk/mapbender/http/html/mod_treefolder2.php
___________________________________________________________________
   + Id
Modified: trunk/mapbender/http/javascripts/jsTree.js
--- trunk/mapbender/http/javascripts/jsTree.js	2007-01-24 09:01:34 UTC (rev 1021)
+++ trunk/mapbender/http/javascripts/jsTree.js	2007-01-24 10:28:58 UTC (rev 1022)
@@ -1,5 +1,5 @@
-*  $Id: jsTree.js 855 2006-11-20 14:06:28Z christoph $
+# $Id:
 *  http://www.mapbender.org/index.php/Mod_treefolder2.php
 *  Copyright notice
Property changes on: trunk/mapbender/http/javascripts/jsTree.js
   + Id
More information about the Mapbender_commits mailing list
