[Mapbender-commits] r1045 - trunk/mapbender/conf
svn_mapbender at osgeo.org
Thu Jan 25 08:26:06 EST 2007
Author: christoph
Date: 2007-01-25 08:26:06 -0500 (Thu, 25 Jan 2007)
New Revision: 1045
Removed:
trunk/mapbender/conf/digitize.conf
deleted: now digitize_default.conf
Deleted: trunk/mapbender/conf/digitize.conf
--- trunk/mapbender/conf/digitize.conf 2007-01-25 13:24:27 UTC (rev 1044)
+++ trunk/mapbender/conf/digitize.conf 2007-01-25 13:26:06 UTC (rev 1045)
@@ -1,24 +0,0 @@
-var buttonDig_imgdir = "../img/button_digitize/";
-var buttonDig_id = new Array("Point","Line","Polygon","dragBasePoint","setBasePoint","delBasePoint");
-var buttonDig_on = new Array(1,1,1,1,1,1);
-var buttonDig_src = new Array("point_off.png","line_off.png","polygon_off.png","move_node_off.png","new_node_off.png","delete_node_off.png");
-var buttonDig_title_off = new Array("add point","add line","add polygon","move basepoint","insert basepoint","delete basepoint");
-var buttonDig_title_on = new Array("finish editing","finish editing","close polygon","move basepoint","insert basepoint","delete basepoint");
-var buttonDig_x = new Array(0,27,54,84,112,139);
-var buttonDig_y = new Array(0,0,0,0,0,0);
-var buttonDig_wfs_src = "geomInfo.png";
-var buttonDig_wfs_title = "save / update / delete";
-var buttonDig_remove_src = "geomRemove.png";
-var buttonDig_remove_title = "remove from workspace";
-var closePolygon_title = "click the first basepoint to close the polygon";
-var dotDistance = 7;
-var geomList_x = 20;
-var geomList_y = 50;
-var linepointColor = "#ffff00";
-var mod_digitize_elName = "digitize";
-var snappingColor = "#ff0000";
-var snappingTolerance = 12;
\ No newline at end of file
More information about the Mapbender_commits
