[Mapbender-commits] r1059 - trunk/mapbender/http/php
svn_mapbender at osgeo.org
Thu Jan 25 10:15:01 EST 2007
Author: christoph
Date: 2007-01-25 10:15:01 -0500 (Thu, 25 Jan 2007)
New Revision: 1059
trunk/mapbender/http/php/mod_editWMS_Metadata.php
fixed minor bug
Modified: trunk/mapbender/http/php/mod_editWMS_Metadata.php
--- trunk/mapbender/http/php/mod_editWMS_Metadata.php 2007-01-25 15:12:47 UTC (rev 1058)
+++ trunk/mapbender/http/php/mod_editWMS_Metadata.php 2007-01-25 15:15:01 UTC (rev 1059)
@@ -310,7 +310,7 @@
editWMSByWMSID ($_REQUEST['wmsList']);
-$wms_id;
+//$wms_id;
function editWMSByWMSID($param_wms_id)
global $wms_id;
@@ -437,17 +437,26 @@
<td><input type='text' size='42' name='L_<?php echo $layer_row['layer_id']?>___layer_keywords'
value='<?php echo $keywordList?>'>
</td>
- <td><input type="button" value='preview' onclick="window.open('../frames/index.php?&gui_id=layer_preview&layer_preview=1&portal_services=<?php echo $layer_row['layer_id'];?>', 'mini_mapbender', 'height=370, width=370, dependent=yes');"></td>
<td>
+ <input type="button" value='preview' onclick="window.open('../frames/index.php?&gui_id=layer_preview&layer_preview=1&portal_services=<?php echo $layer_row['layer_id'];?>', 'mini_mapbender', 'height=370, width=370, dependent=yes');">
+ </td>
+ <td>
<?php
$preview_sql = "SELECT * FROM layer_preview " .
"WHERE fkey_layer_id = ".$layer_row['layer_id']."";
$res_preview_sql = db_query($preview_sql);
if(db_numrows($res_preview_sql)>0){?>
<input id="<?php echo $layer_row['layer_id'];?>_dp" type="button" value='delete preview' onclick="deletepreview('<?php echo $layer_row['layer_id'];?>');">
<?php }else{?>
<input id="<?php echo $layer_row['layer_id'];?>_dp" type="button" value='delete preview' style="display:none;" onclick="deletepreview('<?php echo $layer_row['layer_id'];?>');">
-<?php }?>
+<?php }*/?>
</td>
</tr>
@@ -462,7 +471,9 @@
</table>
<input type='hidden' name='update_content' value=''/>
<input type='hidden' name='wms_id' value='<?php echo $wms_id ?>'/>
<input type="hidden" value='' name='delete_preview'>
<input type="hidden" value='' name='layer_id'>
</form>
</body>
More information about the Mapbender_commits
