[Mapbender-commits] r1061 - trunk/mapbender
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Jan 25 10:22:09 EST 2007
Author: astrid_emde
Date: 2007-01-25 10:22:09 -0500 (Thu, 25 Jan 2007)
New Revision: 1061
Added:
   trunk/mapbender/Install.txt
renamed mb_installation.txt to Install.txt
Copied: trunk/mapbender/Install.txt (from rev 1045, trunk/mapbender/mb_installation.txt)
--- trunk/mapbender/mb_installation.txt	2007-01-25 13:26:06 UTC (rev 1045)
+++ trunk/mapbender/Install.txt	2007-01-25 15:22:09 UTC (rev 1061)
@@ -0,0 +1,88 @@
+Read the description in the Mapbender Wiki
+http://www.mapbender.org/index.php/Installation
+Every Mapbender User is invited to let the Mapbender Wiki grow.
+If you want an account to edit any of these Wiki pages please write an email to info at mapbender.org and request for an ID and password.
+You need a valid email address to be able to edit this Wiki.
+-- 1. Database:
+-- MySQL --
+-- Create a Database:
+-- select the encoding to run your databse: UTF8 or Latin is possible (choose in the mapbender.conf)
+-- To Show the possible character sets:
+SHOW CHARACTER SET;
+SHOW COLLATION;
+-- database with utf8 encoding
+create database mapbender CHARACTER SET utf8 COLLATE utf8_general_ci ;
+-- database with ISO-8859-1 encoding
+create database mapbender CHARACTER SET latin1 COLLATE latin1_german1_ci ;
+-- select the database mapbender
+use mapbender
+-- special: update the mb_user_password to md5 for an existing Mapbender installation that used password()-encryption
+in the file mapbender/frames/login.php there is a variable $setEncPw.
+Set $setEncPw = true to transform the password to md5 when the user logged in with the right password.
+This helps you to transform the passwords step by step from password() to md5().
+--If you want to run Mapbender with MySQL load the following files:
+1. mysql_schema.sql 	(creates tables, keys, constraints)
+2. mysql_data.sql	(loads data)
+-- run the scripts as follow:
+source mysql_schema.sql
+source mysql_data.sql (make sure, that you use the right sql for the right encoding)
+-- PostgreSQL --
+-- Create a Database with Latin1 or UTF8 encoding
+If you want to run Mapbender with PostgreSQL load the following files:
+1. pgsql_schema.sql (creates tables, keys, constraints)
+2. pgsql_data.sql	(loads data)
+3. pgsql_serial_set_sequences_7x.sql or pgsql_serial_set_sequences.sql
+(depending on wich postgresql version you use, sets the values for the sequences)
+- Zählerstand der Sequenz für Serial-Felder (Autowerte)
+-- How to load the sqls in PostgreSQL:
+psql -f pgsql_schema.sql <dbname>
+psql -f pgsql_data.sql <dbname>
+psql -f pgsql_serial_set_sequences.sql <dbname>
+-- 2. mapbender configuration
+configure the file mapbender.conf
+-- check the database connection
+http://localhost/tools/mapbender_setup.php
+-- 3. print configuration
+to use the pdfprint configure the files:
+mapbender\http\print\printPDF.conf (if you use the print in an iframe)
+mapbender\http\print\printPDF_b.conf (if you use the print with a button - b for button)
Property changes on: trunk/mapbender/Install.txt
___________________________________________________________________
   + HeadURL Id LastChangedBy LastChangedDate LastChangedRevision
More information about the Mapbender_commits mailing list
