[Mapbender-commits] r1063 - trunk/mapbender/conf
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Jan 25 10:51:48 EST 2007
Author: christoph
Date: 2007-01-25 10:51:41 -0500 (Thu, 25 Jan 2007)
New Revision: 1063
   trunk/mapbender/conf/digitize_default.conf
added clear button
Modified: trunk/mapbender/conf/digitize_default.conf
--- trunk/mapbender/conf/digitize_default.conf	2007-01-25 15:26:56 UTC (rev 1062)
+++ trunk/mapbender/conf/digitize_default.conf	2007-01-25 15:51:41 UTC (rev 1063)
@@ -23,11 +23,14 @@
 addButtonDig("dragBasePoint", 1, "move_node_off.png", "move basepoint", "move basepoint", 75, 0);
 addButtonDig("setBasePoint", 1, "new_node_off.png", "insert basepoint", "insert basepoint", 100, 0);
 addButtonDig("delBasePoint", 1, "delete_node_off.png", "delete basepoint", "delete basepoint", 125, 0);
+addButtonDig("clear", 1, "del_off.png", "clear", "clear", 150, 0);
 var buttonDig_wfs_src = "geomInfo.png";
 var buttonDig_wfs_title = "save / update / delete";
 var buttonDig_remove_src = "geomRemove.png";
 var buttonDig_remove_title = "remove from workspace";
+var buttonDig_removeDb_src = "geomRemoveDb.png";
+var buttonDig_removeDb_title = "remove from database";
 var closePolygon_title = "click the first basepoint to close the polygon";
More information about the Mapbender_commits mailing list
