[Mapbender-commits] r1075 - trunk/mapbender
svn_mapbender at osgeo.org
Fri Jan 26 12:47:34 EST 2007
Author: astrid_emde
Date: 2007-01-26 12:47:33 -0500 (Fri, 26 Jan 2007)
New Revision: 1075
trunk/mapbender/Install.txt
Modified: trunk/mapbender/Install.txt
--- trunk/mapbender/Install.txt 2007-01-26 17:43:43 UTC (rev 1074)
+++ trunk/mapbender/Install.txt 2007-01-26 17:47:33 UTC (rev 1075)
@@ -20,6 +20,7 @@
-- To Show the possible character sets:
SHOW CHARACTER SET;
SHOW COLLATION;
+SHOW databases;
-- database with utf8 encoding
@@ -29,6 +30,7 @@
-- database with ISO-8859-1 encoding
create database mapbender CHARACTER SET latin1 COLLATE latin1_german1_ci ;
-- select the database mapbender
use mapbender
@@ -42,6 +44,7 @@
--If you want to run Mapbender with MySQL load the following files:
1. mysql_schema.sql (creates tables, keys, constraints)
2. mysql_data.sql (loads data)
-- run the scripts as follow:
source mysql_schema.sql
source mysql_data.sql (make sure, that you use the right sql for the right encoding)
More information about the Mapbender_commits
