[Mapbender-commits] r1082 - trunk/mapbender/http/php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Mon Jan 29 07:52:37 EST 2007
Author: christoph
Date: 2007-01-29 07:52:37 -0500 (Mon, 29 Jan 2007)
New Revision: 1082
   trunk/mapbender/http/php/mod_wfs_conf.php
   trunk/mapbender/http/php/mod_wfs_edit.php
new columns f_form_element, f_edit and f_mandatory
Modified: trunk/mapbender/http/php/mod_wfs_conf.php
--- trunk/mapbender/http/php/mod_wfs_conf.php	2007-01-29 12:48:25 UTC (rev 1081)
+++ trunk/mapbender/http/php/mod_wfs_conf.php	2007-01-29 12:52:37 UTC (rev 1082)
@@ -116,14 +116,14 @@
                 	$sql .= "'1',";
                 }else{$sql .= "'0',";}
                 $sql .= "'".$_REQUEST["f_respos".$i]."'";
-//				$sql .= ",";
-//                if(!empty($_REQUEST["f_edit".$i])){
-//                	$sql .= "'1',";
-//                }else{$sql .= "'0',";}
-//                $sql .= "'".$_REQUEST["f_form_element_html".$i]."',";
-//                if(!empty($_REQUEST["f_mandatory".$i])){
-//                	$sql .= "'1'";
-//                }else{$sql .= "'0'";}
+				$sql .= ",";
+                if(!empty($_REQUEST["f_edit".$i])){
+                	$sql .= "'1',";
+                }else{$sql .= "'0',";}
+                $sql .= "'".$_REQUEST["f_form_element_html".$i]."',";
+                if(!empty($_REQUEST["f_mandatory".$i])){
+                	$sql .= "'1'";
+                }else{$sql .= "'0'";}
                 $sql .= "); ";
                 $res = db_query($sql);
@@ -245,9 +245,9 @@
                 echo "<td>label_id</td>";
                 echo "<td>show</td>";
                 echo "<td>position</td>";
-//                echo "<td>mandatory</td>";
-//                echo "<td>edit</td>";
-//                echo "<td>html</td>";
+                echo "<td>mandatory</td>";
+                echo "<td>edit</td>";
+                echo "<td>html</td>";
         echo "</tr>";
         for($i=0; $i<count($aWFS->elements->element_id); $i++){
@@ -265,9 +265,9 @@
                 echo "<td><input name='f_label_id".$i."' type='text' size='2'  value='0'></td>";
                 echo "<td><input name='f_show".$i."' type='checkbox'></td>";
                 echo "<td><input name='f_respos".$i."' type='text' size='4' value='0'></td>";
-//                echo "<td><input name='f_mandatory".$i."' type='checkbox'></td>";
-//                echo "<td><input name='f_edit".$i."' type='checkbox'></td>";
-//                echo "<td><textarea name='f_form_element_html".$cnt."' cols='15' rows='1' ></textarea></td>";
+                echo "<td><input name='f_mandatory".$i."' type='checkbox'></td>";
+                echo "<td><input name='f_edit".$i."' type='checkbox'></td>";
+                echo "<td><textarea name='f_form_element_html".$cnt."' cols='15' rows='1' ></textarea></td>";
                 echo "</tr>";
         echo "</table>";
Modified: trunk/mapbender/http/php/mod_wfs_edit.php
--- trunk/mapbender/http/php/mod_wfs_edit.php	2007-01-29 12:48:25 UTC (rev 1081)
+++ trunk/mapbender/http/php/mod_wfs_edit.php	2007-01-29 12:52:37 UTC (rev 1082)
@@ -118,19 +118,19 @@
                 }else{$sql .= '0';}
 				$sql .= "',";
                 $sql .= "f_respos = '".$_REQUEST["f_respos".$i]."' ";
-//				$sql .= ",";
-//                $sql .= "f_edit = '";
-//                	$sql .= '1';
-//                }else{$sql .= '0';}
-//				$sql .= "',";
-//                $sql .= "f_form_element_html = '".addslashes($_REQUEST["f_form_element_html".$i]);
-//				$sql .= "',";
-//                $sql .= "f_mandatory = '";
-//                	$sql .= '1';
-//                $sql .= "' ";
+				$sql .= ",";
+                $sql .= "f_edit = '";
+                	$sql .= '1';
+                }else{$sql .= '0';}
+				$sql .= "',";
+                $sql .= "f_form_element_html = '".addslashes($_REQUEST["f_form_element_html".$i]);
+				$sql .= "',";
+                $sql .= "f_mandatory = '";
+                	$sql .= '1';
+                $sql .= "' ";
                 $sql .= " WHERE fkey_wfs_conf_id = ".$_REQUEST["gaz"]." AND f_id = ".$_REQUEST["f_id".$i].";";
@@ -203,9 +203,9 @@
         echo "</tr>";
         $cnt = 0;
         while($row = db_fetch_array($res)){
@@ -233,14 +233,14 @@
                 if($row["f_show"] == 1){ echo " checked"; }
                 echo "></td>";
                 echo "<td><input name='f_respos".$cnt."' type='text' size='4' value='".$row["f_respos"]."'></td>";
-//                echo "<td><input name='f_mandatory".$cnt."' type='checkbox'";
-//                if($row["f_mandatory"] == 1){ echo " checked"; }
-//                echo "></td>";
-//                echo "<td><input name='f_edit".$cnt."' type='checkbox'";
-//                if($row["f_edit"] == 1){ echo " checked"; }
-//                echo "></td>";
-//                echo "<td><textarea name='f_form_element_html".$cnt."' cols='15' rows='1' >".$row["f_form_element_html"]."</textarea></td>";
-//                echo "</tr>";
+                echo "<td><input name='f_mandatory".$cnt."' type='checkbox'";
+                if($row["f_mandatory"] == 1){ echo " checked"; }
+                echo "></td>";
+                echo "<td><input name='f_edit".$cnt."' type='checkbox'";
+                if($row["f_edit"] == 1){ echo " checked"; }
+                echo "></td>";
+                echo "<td><textarea name='f_form_element_html".$cnt."' cols='15' rows='1' >".$row["f_form_element_html"]."</textarea></td>";
+                echo "</tr>";
                 $cnt++;
         echo "</table>";
More information about the Mapbender_commits mailing list
