[Mapbender-commits] r1492 - trunk/mapbender/http/php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri Jul 13 06:18:50 EDT 2007
Author: christoph
Date: 2007-07-13 06:18:50 -0400 (Fri, 13 Jul 2007)
New Revision: 1492
   trunk/mapbender/http/php/mod_help.php
fixed bug #65
http://trac.osgeo.org/mapbender/ticket/65
Modified: trunk/mapbender/http/php/mod_help.php
--- trunk/mapbender/http/php/mod_help.php	2007-07-13 07:53:31 UTC (rev 1491)
+++ trunk/mapbender/http/php/mod_help.php	2007-07-13 10:18:50 UTC (rev 1492)
@@ -20,7 +20,6 @@
 require_once(dirname(__FILE__)."/../../conf/mapbender.conf");
 $con = db_connect(DBSERVER,OWNER,PW);
 db_select_db(DB,$con);
 <html>
 <head><title></title></head>
@@ -47,7 +46,7 @@
 	$res = db_prep_query($sql, $v, $t);
 	$cnt = 0;
 	while($row = db_fetch_array($res)){
-		echo "str += '<area onclick=\"parent.mod_help_disable();";
+		echo "str += '<area onclick=\"mod_help_disable();";
 		if($row["e_id"] != 'help'){
 			echo "window.open(\'".$row["e_url"]."\');";
More information about the Mapbender_commits mailing list
