[Mapbender-commits] r1503 - trunk/mapbender/http/php
svn_mapbender at osgeo.org
Wed Jul 18 09:25:31 EDT 2007
Author: christoph
Date: 2007-07-18 09:25:31 -0400 (Wed, 18 Jul 2007)
New Revision: 1503
Removed:
trunk/mapbender/http/php/mod_monitorCapabilities.php
replaced by mod_monitorCapabilities_main
Deleted: trunk/mapbender/http/php/mod_monitorCapabilities.php
--- trunk/mapbender/http/php/mod_monitorCapabilities.php 2007-07-17 09:39:12 UTC (rev 1502)
+++ trunk/mapbender/http/php/mod_monitorCapabilities.php 2007-07-18 13:25:31 UTC (rev 1503)
@@ -1,132 +0,0 @@
-<?php
-# $Id$
-# http://www.mapbender.org/index.php/Monitor_Capabilities
-# Copyright (C) 2002 CCGIS
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2, or (at your option)
-# any later version.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
-# GNU General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
-require_once(dirname(__FILE__)."/../../conf/mapbender.conf");
-session_start();
-import_request_variables("PG");
-<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
-<html>
-<head>
-<?php
-echo '<meta http-equiv="Content-Type" content="text/html; charset='.CHARSET.'">';
-<title>Monitor WMS Capabilities</title>
-<link rel="stylesheet" type="text/css" href="../css/administration_alloc.css">
-</head>
-<body>
-<?php
-require_once(dirname(__FILE__)."/../classes/class_wms.php");
-require_once(dirname(__FILE__)."/../classes/class_administration.php");
-$con = db_connect($DBSERVER,$OWNER,$PW);
-db_select_db(DB,$con);
-$admin = new administration();
-$ownguis = $admin->getGuisByOwner($_SESSION["mb_user_id"],true);
-$permguis = $admin->getGuisByPermission($_SESSION["mb_user_id"],true);
-$wms_id_own = $admin->getWmsByOwnGuis($ownguis);
-set_time_limit(0);
-echo "Starting monitoring cycle...<br><br>";
-echo "WMS services are requested for availabiltiy. ";
-echo "Capabilities documents are requested and all changes synchronized with the database cache.<br><br>";
-echo "<table cellspacing=10 cellpadding = 8 border = 1>";
-for ($k=0; $k<count($wms_id_own); $k++) {
- $wmsId = $wms_id_own[$k];
- echo "<tr><td><b>Processing WMS</b> (ID = " . $wmsId . ")<br>";
- // get the wms version, capabilities, capabilities_doc
- $sql = "SELECT wms_title, wms_version, wms_getcapabilities, wms_getcapabilities_doc ";
- $sql .= "FROM wms WHERE wms_id = $1";
- $v = array($wmsId);
- $t = array('i');
- $res = db_prep_query($sql,$v,$t);
- $someArray = db_fetch_row($res);
- $wms_title = $someArray[0];
- $version = $someArray[1];
- $capabilities = $someArray[2];
- $capabilities_doc = $someArray[3];
- echo "WMS Title: <b><i>" . $wms_title . "</i></b><br>";
- // construct capabilities URL
- if ($version == "1.1.1" || $version == "1.1.0") {
- $myURL = $capabilities . "REQUEST=GetCapabilities&SERVICE=wms&VERSION=" . $version;
- elseif ($version == "1.0.0" ) {
- $myURL = $capabilities . "REQUEST=capabilities&WMTVER=1.0.0";
- else {
- echo "Version '" . $version . "' cannot be handled! Update process terminated.</td><td><img src ='../img/trafficlights/stop.bmp'></td></tr>";
- if (($version == "1.1.1" || $version == "1.1.0" ||$version == "1.0.0") && $myURL) {
- // compare the capabilities XML documents
- $localXml = $capabilities_doc;
- set_time_limit(300);
- echo "<a href='" . $myURL . "'>Get Capabilities Link</a><br>";
- $x = new connector($myURL);
- $z = new wms();
- $remoteXml = $z->char_encode($x->file);
-// $remoteXml = implode("", file($myURL));
-// $localXmlArray = explode("\n", $localXml);
-// $remoteXmlArray = explode("\n", $remoteXml);
-// for ($i=0; $i<count($localXmlArray); $i++) {
-// $localXmlArray[$i] = trim(htmlentities($localXmlArray[$i]));
-// for ($i=0; $i<count($remoteXmlArray); $i++) {
-// $remoteXmlArray[$i] = trim(htmlentities($remoteXmlArray[$i]));
-// print_r($localXmlArray);
-// print_r($remoteXmlArray);
- if (!$remoteXml) {
- $result = -1;
- echo "Connection failed.</td><td><img src ='../img/trafficlights/stop.bmp'></td></tr>";
- elseif (!$localXml) {
- $result = 0;
- else {
- if ($localXml == $remoteXml) {
- $result = 1;
- echo "WMS is stable.</td><td><img src ='../img/trafficlights/go.bmp'></td></tr>";
- else {
- $result = 0;
- if ($result == 0) {
- $mywms = new wms();
- $result = $mywms->createObjFromXML($myURL);
- if ($result == true) {
- $mywms->updateObjInDB($wmsId);
- echo "Updating WMS " . $wmsId . "...</td><td><img src ='../img/trafficlights/wait.bmp'></td></tr>";
- else {
- $result = -1;
- echo "Invalid getCapabilities request.</td><td><img src ='../img/trafficlights/stop.bmp'></td></tr>";
-echo "</table>";
-echo "<br>Monitoring Cycle completed.";
-</body>
-</html>
\ No newline at end of file
More information about the Mapbender_commits
