[Mapbender-commits] r1512 - trunk/mapbender/http/javascripts
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Wed Jul 18 10:59:55 EDT 2007
Author: christoph
Date: 2007-07-18 10:59:55 -0400 (Wed, 18 Jul 2007)
New Revision: 1512
Added:
   trunk/mapbender/http/javascripts/mod_savewmc.php
Removed:
saving a wmc via ajax
Deleted: trunk/mapbender/http/javascripts/mod_savewmc.php
--- trunk/mapbender/http/javascripts/mod_savewmc.php	2007-07-18 14:59:29 UTC (rev 1511)
+++ trunk/mapbender/http/javascripts/mod_savewmc.php	2007-07-18 14:59:55 UTC (rev 1512)
@@ -1,430 +0,0 @@
-<?php
-# $Id: mod_savewmc.php 264 2006-05-12 11:07:19Z vera_schulze
-# http://www.mapbender.org/index.php/mod_savewmc.php
-# Copyright (C) 2002 CCGIS
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2, or (at your option)
-# any later version.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
-# GNU General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-$gui_id = $_REQUEST["gui_id"];
-require_once("../../conf/mapbender.conf");
-$con = db_connect($DBSERVER,$OWNER,$PW);
-db_select_db(DB,$con);
-$sql = "SELECT e_src, e_target FROM gui_element WHERE e_id = 'savewmc' AND fkey_gui_id = $1";
-$v = array($gui_id);
-$t = array('s');
-$res = db_prep_query($sql, $v, $t);
-$cnt = 0;
-while($row = db_fetch_array($res)){
-	$e_src = $row["e_src"];
-	$e_target = $row["e_target"];
-	$cnt++;
-if($cnt > 1){
-	echo "alert('savewmc: ID not unique!');";
-$e_id_css = "savewmc";
-include("../include/dyn_js.php");
-echo "mod_savewmc_target = '".$e_target."';";
-function setOnUnload() {
-	document.getElementsByTagName('body')[0].setAttribute("onUnload", "mod_savewmc('session');");
-try {if (saveInSession) {}}catch(e) {saveInSession = 0;}
-if (saveInSession == '1') {
-	mb_registerInitFunctions('setOnUnload()');
-var mod_savewmc_img = new Image(); mod_savewmc_img.src = "<?php  echo $e_src;  ?>";
-//var mod_savewmc_img_over = new Image(); mod_savewmc_img_over.src = "<?php  echo preg_replace("/_off/","_over",$e_src);  ?>";
-//0 = Keine Anführungszeichen umwandeln
-//1 = Nur einfache Anführungszeichen umwandeln
-//2 = Nur doppelte Anführungszeichen umwandeln (Standardeinstellung)
-//3 = Beide Arten (einfache und doppelte Anführungszeichen) umwandeln
-function htmlspecialchars(str,typ) {
-	if(typeof str=="undefined") str="";
-	if(typeof typ!="number") typ=2;
-	typ=Math.max(0,Math.min(3,parseInt(typ)));
-	var html=new Array();
-	html[38]="&amp;"; html[60]="&#38;#60;"; html[62]="&#38;#62;";
-	if(typ==1 || typ==3) html[39]="&#38;#39;";
-	if(typ==2 || typ==3) html[34]="&#38;#34;";
-	for(var i in html) {
-		if (typeof(html[i]) != 'function') {
-			var functionString ="str=str.replace('"+String.fromCharCode(i)+"',\""+html[i]+"\");";
-			eval(functionString);
-    return str;
-function mod_savewmc(title){
-	var user = "<?php echo $_SESSION["mb_user_id"]; ?>";
-	var ind = getMapObjIndexByName(mod_savewmc_target);
-	var session = 0;
-	if (title) {
-		var generalTitle = htmlspecialchars(title,0);
-		title_alert = 0;
-		if (title == 'session') {
-			session = 1;
-	else {
-		var generalTitle = htmlspecialchars(prompt("Save WMC as..."),0);
-		title_alert = 1;
-	if (generalTitle != null){
-		var wmc = "";
-		// ViewContext variables
-		var version = "1.0.0";
-		var id = "<?php echo $_SESSION["mb_user_id"] . "_";?>";
-		var jetzt = new Date();
-		id += jetzt.getTime();
-		// General variables
-		var generalWidth = mb_mapObj[ind].width;
-		var generalHeight = mb_mapObj[ind].height;
-		var generalBboxSrs = mb_mapObj[ind].epsg;
-		var arrayBBox = mb_mapObj[ind].extent.split(",");
-		var generalBboxMinx = parseFloat(arrayBBox[0]);
-		var generalBboxMiny = parseFloat(arrayBBox[1]);
-		var generalBboxMaxx = parseFloat(arrayBBox[2]);
-		var generalBboxMaxy = parseFloat(arrayBBox[3]);
-		var generalName = "Mapbender WMC"; // TO do : insert proper data
-		var generalKeywords = new Array('Mapbender', 'WMC'); // TO do : insert proper data
-		var generalAbstract = ""; // TO do : insert proper data
-		var generalLogoUrl = ""; // TO do : insert proper data
-		var generalLogoUrlWidth = ""; // TO do : insert proper data
-		var generalLogoUrlHeight = ""; // TO do : insert proper data
-		var generalLogoUrlFormat = ""; // TO do : insert proper data
-		var generalDescriptionUrl = ""; // TO do : insert proper data
-		var generalContactPerson = "";
-		var generalContactOrganization = "";
-		var generalContactPosition = "";
-		var generalContactAddressType = "";
-		var generalContactAddress = "";
-		var generalContactCity = "";
-		var generalContactStateOrProvince = "";
-		var generalContactPostCode = "";
-		var generalContactCountry = "";
-		var generalContactVoiceTelephone = "";
-		var generalContactFacsimileTelephone = "";
-		var generalContactElectronicMailAddress = "";
-		var extension_namespace = "mapbender";
-		// LayerList variables
-		var layerHidden = "";
-		var layerQueryable = "";
-		var layerAbstract = "";
-		var layerName = "";
-		var layerSrs = "";
-		var layerDataUrl = "";
-		var layerMetadataUrl = "";
-		var layerFormat = "";
-		var layerFormat_current = "";
-		var layerStyle_current = "";
-		var layerStyle_name = "";
-		var layerStyle_title = "";
-		var layerStyle_legendURL = "";
-		var layerStyle_legendURL_width = "";
-		var layerStyle_legendURL_height = "";
-		var layerStyle_legendURL_format = "";
-		// Missing: Extension
-		//ViewContext
-		wmc += "&lt;?xml version=\"1.0\" encoding=\"<?php echo CHARSET; ?>\"?&gt;";
-		// wmc += "&lt;!ENTITY amp    \"&amp;#38;#38;\"&gt;\n";
-		wmc += "&lt;ViewContext version=\"" + version + "\" ";
-		wmc += "id = \"" + id + "\" ";
-		wmc += "xmlns=\"http://www.opengis.net/context\" xmlns:xlink=\"http://www.w3.org/1999/xlink\" xmlns:mapbender=\"http://www.mapbender.org\" xmlns:xsi=\"http://www.w3.org/2001/XMLSchema-instance\" xsi:SchemaLocation=\"http://schemas.opengis.net/context/1.0.0/context.xsd\" ";
-		wmc += "&gt;\n";
-		//General
-		wmc += "\t&lt;General&gt;\n";
-		if (generalWidth && generalHeight){
-			wmc += "\t\t&lt;Window width=\"" + generalWidth + "\" height=\"" + generalHeight + "\" /&gt;\n";
-		wmc += "\t\t&lt;BoundingBox SRS=\"" + generalBboxSrs + "\" minx =\"" + generalBboxMinx + "\" ";
-		wmc += "miny =\"" + generalBboxMiny + "\" maxx =\"" + generalBboxMaxx + "\" maxy =\"" + generalBboxMaxy + "\" /&gt;\n";
-		wmc += "\t\t&lt;Name&gt;" + generalName + "&lt;/Name&gt;\n";
-		wmc += "\t\t&lt;Title&gt;" + generalTitle + "&lt;/Title&gt;\n";
-		if (generalKeywords){
-			wmc += "\t\t&lt;KeywordList&gt;\n";
-			for (var i = 0; i < generalKeywords.length ; i++) {
-				wmc += "\t\t\t&lt;Keyword&gt;" + generalKeywords[i] + "&lt;/Keyword&gt;\n";
-			wmc += "\t\t&lt;/KeywordList&gt;\n";
-		if (generalAbstract){
-			wmc += "\t\t&lt;Abstract&gt;" + generalAbstract + "&lt;/Abstract&gt;\n";
-		if (generalLogoUrlWidth && generalLogoUrlHeight && generalLogoUrlFormat && generalLogoUrl){
-			wmc += "\t\t&lt;LogoURL width = \"" + generalLogoUrlWidth + "\" ";
-			wmc += "height = \"" + generalLogoUrlHeight + "\" ";
-			wmc += "format = \"" + generalLogoUrlFormat + "\"&gt;\n";
-			wmc += "\t\t\t&lt;OnlineResource xmlns:xlink=\"http://www.w3.org/1999/xlink\" xlink:type = \"simple\" xlink:href=\"" + generalLogoUrl + "\" /&gt;\n";
-			wmc += "\t\t&lt;/LogoUrl&gt;\n";
-		if (generalDescriptionUrl){
-			wmc += "\t\t&lt;DescriptionURL&gt;\n";
-			wmc += "\t\t\t&lt;OnlineResource xmlns:xlink=\"http://www.w3.org/1999/xlink\" xlink:type = \"simple\" xlink:href=\"" + generalDescriptionUrl + "\" /&gt;\n";
-			wmc += "\t\t&lt;/DescriptionUrl&gt;\n";
-		if (generalContactElectronicMailAddress || generalContactOrganization ||
-			generalContactPerson || generalContactPosition || generalContactAddressType ||
-			generalContactAddress || generalContactCity || generalContactStateOrProvince ||
-			generalContactPostCode || generalContactCountry || generalContactVoiceTelephone ||
-			generalContactFacsimileTelephone || generalContactElectronicMailAddress){
-			wmc += "\t\t&lt;ContactInformation&gt;\n";
-			if (generalContactPerson || generalContactOrganization){
-				wmc += "\t\t\t&lt;ContactPersonPrimary&gt;\n";
-				if (generalContactPerson){
-					wmc += "\t\t\t\t&lt;ContactPerson&gt;" + generalContactPerson + "&lt;/ContactPerson&gt;\n";
-				if (generalContactOrganization){
-					wmc += "\t\t\t\t&lt;ContactOrganization&gt;" + generalContactOrganization + "&lt;/ContactOrganization&gt;\n";
-				wmc += "\t\t\t&lt;/ContactPersonPrimary&gt;\n";
-			if (generalContactPosition){
-				wmc += "\t\t\t&lt;ContactPosition&gt;" + generalContactPosition + "&lt;/ContactPosition&gt;\n";
-			if (generalContactAddressType || generalContactAddress || generalContactCity || generalContactStateOrProvince ||
-				generalContactPostCode || generalContactCountry){
-				wmc += "\t\t\t&lt;ContactAddress&gt;\n";
-				if (generalContactAddressType){
-					wmc += "\t\t\t\t&lt;AddressType&gt;" + generalContactAddressType + "&lt;/AddressType&gt;\n";
-				if (generalContactAddress){
-					wmc += "\t\t\t\t&lt;Address&gt;" + generalContactAddress + "&lt;/Address&gt;\n";
-				if (generalContactCity){
-					wmc += "\t\t\t\t&lt;City&gt;" + generalContactCity + "&lt;/City&gt;\n";
-				if (generalContactStateOrProvince){
-					wmc += "\t\t\t\t&lt;StateOrProvince&gt;" + generalContactStateOrProvince + "&lt;/StateOrProvince&gt;\n";
-				if (generalContactPostCode){
-					wmc += "\t\t\t\t&lt;PostCode&gt;" + generalContactPostCode + "&lt;/PostCode&gt;\n";
-				if (generalContactCountry){
-					wmc += "\t\t\t\t&lt;Country&gt;" + generalContactCountry + "&lt;/Country&gt;\n";
-				wmc += "\t\t\t&lt;/ContactAddress&gt;\n";
-			wmc += "\t\t\t&lt;ContactVoiceTelephone&gt;" + generalContactVoiceTelephone + "&lt;/ContactVoiceTelephone&gt;\n";
-			wmc += "\t\t\t&lt;ContactFacsimileTelephone&gt;" + generalContactFacsimileTelephone + "&lt;/ContactFacsimileTelephone&gt;\n";
-			wmc += "\t\t\t&lt;ContactElectronicMailAddress&gt;" + generalContactElectronicMailAddress + "&lt;/ContactElectronicMailAddress&gt;\n";
-			wmc += "\t\t&lt;/ContactInformation&gt;\n";
-		wmc += "\t&lt;/General&gt;\n";
-		//layerList
-		wmc += "\t&lt;LayerList&gt;\n";
-		for (var i = 0; i < mb_mapObj[ind].wms.length; i++){
-			wmsId = mb_mapObj[ind].wms[i].wms_id;
-			var wms_epsg = new Array();
-			wms_epsg[0] = mb_mapObj[ind].epsg;
-			if (mb_mapObj[ind].wms[i].gui_wms_epsg != mb_mapObj[ind].epsg){
-				wms_epsg[1] = mb_mapObj[ind].wms[i].gui_wms_epsg;
-			for (q = 0; q < mb_mapObj[ind].wms[i].gui_epsg.length ; q ++){
-				var isInArray = false;
-				for (r = 0 ; r < wms_epsg.length ; r ++){
-					if (wms_epsg[r] == mb_mapObj[ind].wms[i].gui_epsg[q]){
-						isInArray = true;
-				if (isInArray == false){
-					wms_epsg[wms_epsg.length] = mb_mapObj[ind].wms[i].gui_epsg[q];
-			for (var j = 0; j < mb_mapObj[ind].wms[i].objLayer.length; j++){
-				if (mb_mapObj[ind].wms[i].objLayer[j].layer_parent != ''){
-					if (mb_mapObj[ind].wms[i].objLayer[j].gui_layer_visible == '1'){
-						layerHidden = 0;
-					else{
-						layerHidden = 1;
-					layerQueryable = mb_mapObj[ind].wms[i].objLayer[j].layer_queryable;
-					layerQuerylayer = mb_mapObj[ind].wms[i].objLayer[j].gui_layer_querylayer;
-					layerId = mb_mapObj[ind].wms[i].objLayer[j].layer_uid;
-					layerName = htmlspecialchars(mb_mapObj[ind].wms[i].objLayer[j].layer_name,0);
-					layerTitle = htmlspecialchars(mb_mapObj[ind].wms[i].objLayer[j].layer_title, 0);
-					layerAbstract = mb_mapObj[ind].wms[i].wms_abstract; //To Do: insert actual abstract
-					layerDataUrl = mb_mapObj[ind].wms[i].objLayer[j].layer_dataurl_href;
-					layerMetadataUrl = mb_mapObj[ind].wms[i].objLayer[j].layer_metadataurl;
-					layerMinscale = mb_mapObj[ind].wms[i].objLayer[j].layer_minscale;
-					layerMaxscale = mb_mapObj[ind].wms[i].objLayer[j].layer_maxscale;
-					wmsVersion = mb_mapObj[ind].wms[i].wms_version;
-					wmsTitle = htmlspecialchars(mb_mapObj[ind].wms[i].wms_title,0)	;
-					wmsOnlineResource = mb_mapObj[ind].wms[i].wms_getmap;
-					wmc += "\t\t&lt;Layer queryable = \"" + layerQueryable + "\" hidden = \"" + layerHidden + "\"&gt;\n";
-					wmc += "\t\t\t&lt;Server service = \"OGC:WMS\" version = \"" + wmsVersion + "\" title = \"" + wmsTitle + "\"&gt;\n";
-					wmc += "\t\t\t\t&lt;OnlineResource xmlns:xlink=\"http://www.w3.org/1999/xlink\" xlink:type=\"simple\" xlink:href=\"" + wmsOnlineResource + "\" /&gt;\n";
-					wmc += "\t\t\t&lt;/Server&gt;\n";
-					wmc += "\t\t\t&lt;Name&gt;" + layerName + "&lt;/Name&gt;\n";
-					wmc += "\t\t\t&lt;Title&gt;" + layerTitle + "&lt;/Title&gt;\n";
-					if (layerAbstract){
-						wmc += "\t\t\t&lt;Abstract&gt;" + layerAbstract + "&lt;/Abstract&gt;\n";
-					wmc += "\t\t\t&lt;SRS&gt;";
-					for (var k = 0; k < wms_epsg.length ; k ++){
-						wmc +=  wms_epsg[k];
-						if (k < wms_epsg.length-1){
-							wmc += " ";
-					wmc += "&lt;/SRS&gt;\n";
-					if (layerDataUrl){
-						wmc += "\t\t\t&lt;DataURL&gt;\n";
-						wmc += "\t\t\t\t&lt;OnlineResource xmlns:xlink=\"http://www.w3.org/1999/xlink\" xlink:type = \"simple\" xlink:href=\"" + layerDataUrl + "\" /&gt;\n";
-						wmc += "\t\t\t&lt;/DataURL&gt;\n";
-					if (layerMetadataUrl){
-						wmc += "\t\t\t&lt;MetadataURL&gt;\n";
-						wmc += "\t\t\t\t&lt;OnlineResource xmlns:xlink=\"http://www.w3.org/1999/xlink\" xlink:type = \"simple\" xlink:href=\"" + layerMetadataUrl + "\" /&gt;\n";
-						wmc += "\t\t\t&lt;/MetadataURL&gt;\n";
-					wmc += "\t\t\t&lt;Extension&gt;\n";
-					if (layerMinscale && layerMaxscale) {
-						wmc += "\t\t\t\t&lt;"+extension_namespace+":ScaleHint min=\""+layerMinscale+"\" max=\""+layerMaxscale+"\"/&gt;\n";
-					wmc += "\t\t\t\t&lt;"+extension_namespace+":layer_id&gt;"+layerId+"&lt;/"+extension_namespace+":layer_id&gt;\n";
-					wmc += "\t\t\t\t&lt;"+extension_namespace+":wms_id&gt;"+wmsId+"&lt;/"+extension_namespace+":wms_id&gt;\n";
-					wmc += "\t\t\t\t&lt;"+extension_namespace+":querylayer&gt;"+layerQuerylayer+"&lt;/"+extension_namespace+":querylayer&gt;\n";
-					wmc += "\t\t\t&lt;/Extension&gt;\n";
-					//layerFormat
-					wmc += "\t\t\t&lt;FormatList&gt;\n";
-					var data_format_current = false;
-					for (var k = 0; k < wms[i].data_format.length; k++){
-						if (wms[i].data_type[k] == 'map') {
-							layerFormat = mb_mapObj[ind].wms[i].data_format[k];
-							wmc += "\t\t\t\t&lt;Format";
-							if (data_format_current == false && (
-									(mb_mapObj[ind].wms[i].data_format[k] == mb_mapObj[ind].wms[i].gui_wms_mapformat) ||
-									(k == wms[i].data_format.length-1)
-								wmc += " current = \"1\"";
-								data_format_current = true;
-							wmc += "&gt;" + layerFormat + "&lt;/Format&gt;\n";
-					wmc += "\t\t\t&lt;/FormatList&gt;\n";
-					// LayerStyle
-					wmc += "\t\t\t&lt;StyleList&gt;\n";
-					for (var k = 0; k < 1; k++){
-						if (k == 0){
-							layerStyle_current = 1; // To do: insert proper data
-						else{
-							layerStyle_current = 0; // To do: insert proper data
-						wmc += "\t\t\t\t&lt;Style";
-						layerStyleSLD = "";
-						if (layerStyleSLD){
-							layerStyleSLDUrl = ""; // To Do: Insert Proper Data
-							wmc += "\t\t\t\t\t\t&lt;OnlineResource xmlns:xlink=\"http://www.w3.org/1999/xlink\" xlink:type=\"simple\" xlink:href=\"" + layerStyleSLDUrl + "\" /&gt;\n";
-						else{
-							if (mb_mapObj[ind].wms[i].objLayer[j].layer_style[k]){
-								layerStyle_name = mb_mapObj[ind].wms[i].objLayer[j].layer_style[k]['name'];
-								layerStyle_title = mb_mapObj[ind].wms[i].objLayer[j].layer_style[k]['title'];
-								layerStyle_legendUrl = mb_mapObj[ind].wms[i].objLayer[j].layer_style[k]["legendurl"];
-							else{
-								layerStyle_name = "default";
-								layerStyle_title = "default";
-								layerStyle_legendUrl = "";
-							layerStyle_legendUrl_width = ""; // To Do: add proper data
-							layerStyle_legendUrl_height = ""; // To Do: add proper data
-							layerStyle_legendUrl_format = ""; // To Do: add proper data
-							if (layerStyle_current == 1){
-							wmc += "&gt;\n\t\t\t\t\t&lt;Name&gt;" + layerStyle_name + "&lt;/Name&gt;\n";
-							wmc += "\t\t\t\t\t&lt;Title&gt;" + layerStyle_title + "&lt;/Title&gt;\n";
-							wmc += "\t\t\t\t\t&lt;LegendUrl ";
-							wmc += "width = \"" + layerStyle_legendUrl_width + "\" ";
-							wmc += "height = \"" + layerStyle_legendUrl_height + "\" ";
-							wmc += "format = \"" + layerStyle_legendUrl_format + "\"&gt;\n";
-							wmc += "\t\t\t\t\t\t&lt;OnlineResource xmlns:xlink=\"http://www.w3.org/1999/xlink\" xlink:type=\"simple\" xlink:href=\"" + layerStyle_legendUrl + "\" /&gt;\n";
-							wmc += "\t\t\t\t\t&lt;/LegendUrl&gt;\n";
-						wmc += "\t\t\t\t&lt;/Style&gt;\n";
-						// Missing: Describe Style via SLD (see: http://center.ccgis/phprojekt/addons/ewiki/index.php?id=links/SLD)
-					wmc += "\t\t\t&lt;/StyleList&gt;\n";
-					wmc += "\t\t&lt;/Layer&gt;\n";
-		wmc += "\t&lt;/LayerList&gt;\n";
-		wmc += "&lt;/ViewContext&gt;\n";
-		if (session == 1) {
-			var wmc_win = window.open('about:blank', 'wmc_confirm', 'width=200,height=10,left='+Math.round(0.5*screen.width)+',top='+Math.round(0.5*screen.height));
-			document.sendData.target = 'wmc_confirm';
-//			document.sendData.target = '_blank';
-		document.sendData.action = "../javascripts/mod_insertWmcIntoDb.php";
-		document.sendData.data.value = user + "____" + generalTitle + "____" + wmc + "____" + id + "____" + title_alert + "____" + session;
-		document.sendData.submit();
-	return id;
\ No newline at end of file
Added: trunk/mapbender/http/javascripts/mod_savewmc.php
--- trunk/mapbender/http/javascripts/mod_savewmc.php	                        (rev 0)
@@ -0,0 +1,59 @@
+<?php
+# $Id: mod_savewmc.php 264 2006-05-12 11:07:19Z vera_schulze
+# http://www.mapbender.org/index.php/mod_savewmc.php
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+require_once("../../conf/mapbender.conf");
+$gui_id = $_REQUEST["gui_id"];
+include("../include/dyn_js.php");
+echo "mod_savewmc_target = '".$e_target."';";
+function setOnUnload() {
+	document.getElementsByTagName('body')[0].setAttribute("onUnload", "mod_savewmc('session');");
+try {if (saveInSession) {}}catch(e) {saveInSession = 0;}
+if (saveInSession == '1') {
+	mb_registerInitFunctions('setOnUnload()');
+var mod_savewmc_img = new Image(); mod_savewmc_img.src = "<?php  echo $e_src;  ?>";
+//var mod_savewmc_img_over = new Image(); mod_savewmc_img_over.src = "<?php  echo preg_replace("/_off/","_over",$e_src);  ?>";
+function mod_savewmc(title){
+	var ind = getMapObjIndexByName(mod_savewmc_target);
+	var session = 0;
+	var generalTitle = title;
+	if (generalTitle) {
+		if (generalTitle == 'session') {
+			session = 1;
+	else {
+		generalTitle = prompt("Save WMC as...");
+	mb_ajax_post("../php/mod_insertWmcIntoDb.php", {saveInSession:session, generalTitle:generalTitle, mapObject:mb_mapObj[ind].toJSONString()}, function (result, status) {
+		alert(result);
More information about the Mapbender_commits mailing list
