[Mapbender-commits] r1532 - trunk/mapbender
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Wed Jul 25 04:56:56 EDT 2007
Author: astrid_emde
Date: 2007-07-25 04:56:56 -0400 (Wed, 25 Jul 2007)
New Revision: 1532
   trunk/mapbender/Install.txt
little syntax changes
Modified: trunk/mapbender/Install.txt
--- trunk/mapbender/Install.txt	2007-07-25 07:53:31 UTC (rev 1531)
+++ trunk/mapbender/Install.txt	2007-07-25 08:56:56 UTC (rev 1532)
@@ -62,7 +62,7 @@
 2. pgsql_data.sql	(loads data)
 3. pgsql_serial_set_sequences_7x.sql or pgsql_serial_set_sequences.sql
 (depending on wich postgresql version you use, sets the values for the sequences)
-- Z�hlerstand der Sequenz f�r Serial-Felder (Autowerte)
+- Zaehlerstand der Sequenz fuer Serial-Felder (Autowerte)
 -- How to load the sqls in PostgreSQL:
More information about the Mapbender_commits mailing list
