[Mapbender-commits] r1552 - trunk/mapbender
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Mon Jul 30 06:01:45 EDT 2007
Author: astrid_emde
Date: 2007-07-30 06:01:45 -0400 (Mon, 30 Jul 2007)
New Revision: 1552
   trunk/mapbender/Install.txt
CREATE DATABASE  added
Modified: trunk/mapbender/Install.txt
--- trunk/mapbender/Install.txt	2007-07-30 09:54:34 UTC (rev 1551)
+++ trunk/mapbender/Install.txt	2007-07-30 10:01:45 UTC (rev 1552)
@@ -25,11 +25,11 @@
 -- database with utf8 encoding
-create database mapbender CHARACTER SET utf8 COLLATE utf8_general_ci ;
+CREATE DATABASE mapbender CHARACTER SET utf8 COLLATE utf8_general_ci ;
 -- database with ISO-8859-1 encoding
-create database mapbender CHARACTER SET latin1 COLLATE latin1_german1_ci ;
+CREATE DATABASE mapbender CHARACTER SET latin1 COLLATE latin1_german1_ci ;
 -- select the database mapbender
@@ -56,7 +56,13 @@
 -- Create a Database with Latin1 or UTF8 encoding
+CREATE DATABASE mapbender ENCODING = 'UTF8';
+or
+CREATE DATABASE mapbender ENCODING = 'LATIN1';
 If you want to run Mapbender with PostgreSQL load the following files:
 1. pgsql_schema.sql (creates tables, keys, constraints)
 2. pgsql_data.sql	(loads data)
More information about the Mapbender_commits mailing list
