[Mapbender-commits] r1431 - branches/mapbender_sld/http/javascripts
svn_mapbender at osgeo.org
Tue Jun 5 03:36:10 EDT 2007
Author: uli
Date: 2007-06-05 03:36:09 -0400 (Tue, 05 Jun 2007)
New Revision: 1431
branches/mapbender_sld/http/javascripts/map.js
merged with js part from map.php
Modified: branches/mapbender_sld/http/javascripts/map.js
--- branches/mapbender_sld/http/javascripts/map.js 2007-06-05 07:07:19 UTC (rev 1430)
+++ branches/mapbender_sld/http/javascripts/map.js 2007-06-05 07:36:09 UTC (rev 1431)
@@ -30,9 +30,6 @@
function mb_registerVendorSpecific(stringFunction){
mb_vendorSpecific[mb_vendorSpecific.length] = stringFunction;
-var mb_security_proxy = "http://wms1.ccgis.de/mapbender/tools/security_proxy.php?mb_ows_security_proxy=";
var mb_trans = new Image;
mb_trans.src = "../img/transparent.gif";
/*END OF GLOBALS*/
@@ -130,12 +127,117 @@
this.epsg = wms[0].gui_wms_epsg;
this.extent = setExtent(this.width,this.height,this.epsg);
this.mapURL = [];
+ * get the width of the mapObj
+ * @member mb_mapObj_const
+ * @return width of the mapObj
+ * @type integer
+ this.getWidth = function(){
+ return this.width;
+ * get the height of the mapObj
+ * @type integer
+ this.getHeight = function(){
+ return this.height;
+ * get the extent of the mapObj
+ * @return extent of the mapObj as commaseparated minx,minx,maxx,maxy
+ * @type string
+ this.getExtent = function(){
+ return this.extent;
+ * get the srs of the mapObj
+ * @return srs as epsg:number
+ * @type string
+ this.getSRS = function(){
+ return this.epsg;
+ * get all mapRequests
+ * @return array of mapRequests of this map object
+ * @type string[]
+ this.getMapRequests = function(){
+ var allRequests = [];
+ //loop through all wms to get the mapRequests
+ for(var i=0; i<this.wms.length; i++){
+ var currentRequest = this.wms[i].getMapRequest(this);
+ if(currentRequest){
+ allRequests.push(currentRequest);
+ if(allRequests.length > 0){
+ return allRequests;
+ return false;
+ * get all featureInfoRequests
+ * @param float x the x-value of the click position in pixel
+ * @param float y the y-value of the click position in pixel
+ * @return array of all featureInfoRequests of this map object
+ * @type string[]
+ this.getFeatureInfoRequests = function(clickPoint){
+ //loop through all wms to get the FeatureInfoRequests
+ var currentRequest = this.wms[i].getFeatureInfoRequest(this, clickPoint);
+ return false;
+ * calculation of the mapscale
+ * @return scale
+ * @type integer
+ this.getScale = function(){
+ var bbox = this.extent.split(",");
+ var xtenty = parseFloat(bbox[3]) - parseFloat(bbox[1]);
+ var scale = (xtenty / this.height) * (mb_resolution * 100);
+ return Math.round(scale);
for(var i=0; i<mb_MapObjectSubFunctions.length; i++){
eval(mb_MapObjectSubFunctions[i]);
function mb_getConjunctionCharacter(onlineresource){
if(onlineresource.indexOf("?") > -1){
if(onlineresource.charAt(onlineresource.length-1) == "?"){
@@ -386,6 +488,12 @@
var temp = "&SLD=" + tmp+ "&";
newMapURL += temp;
+ // add sld
+ if(mb_mapObj[i].wms[ii].gui_wms_sldurl != ""){
+ //alert(mb_mapObj[i].wms[ii].gui_wms_sldurl);
+ var temp = "&SLD=" + mb_mapObj[i].wms[ii].gui_wms_sldurl + "&";
+ newMapURL += temp;
if(mb_log){
var tmp = eval(mb_log + "('" + newMapURL + "','" + ts + "')");
@@ -469,6 +577,12 @@
newMapURL += temp;
+ // add sld
//prompt("",newMapURL);
if(mb_mapObj[i].layers[ii] != "" && str_LayerStyles[0] != ""){
newMapRequest += newMapURL;
@@ -553,6 +667,10 @@
str_parent += mb_mapObj[mObj].wms[wmsObj].objLayer[i].layer_parent;
if(mb_mapObj[mObj].wms[wmsObj].objLayer[i].layer_style.length>0){
str_legendurls += mb_mapObj[mObj].wms[wmsObj].objLayer[i].layer_style[0]["legendurl"] ;
+ // add SLD-Url to Legend-Url
+ if (mb_mapObj[mObj].wms[wmsObj].gui_wms_sldurl != "") {
+ str_legendurls += "&SLD="+mb_mapObj[mObj].wms[wmsObj].gui_wms_sldurl;
cnt_layer++;
@@ -568,7 +686,6 @@
return str_layerstyles;
function setFeatureInfoRequest(fName,x,y, path) {
- var functionName = 'setFeatureInfoRequest';
var ts = mb_timestamp();
for(var i=0; i<mb_FeatureInfoPreFunctions.length; i++){
eval(mb_FeatureInfoPreFunctions[i]);
@@ -891,6 +1008,14 @@
+function getMapObjByName(frameName){
+ for(var i=0; i<mb_mapObj.length; i++){
+ if(mb_mapObj[i].frameName == frameName){
+ return mb_mapObj[i];
+ return false;
function mb_getLayerTitleByName(map_index, wms_index, myLayer_name){
for(var i=0; i<mb_mapObj[map_index].wms[wms_index].objLayer.length; i++){
if(mb_mapObj[map_index].wms[wms_index].objLayer[i].layer_name == myLayer_name){
@@ -1281,13 +1406,13 @@
* @extends {@link Mb_log}
* @param message the message that is being logged
function Mb_warning(message) {
var level = "warning";
this.throwException(message, level);
Mb_warning.prototype = new Mb_log();
* class for notice logging
More information about the Mapbender_commits
