[Mapbender-commits] r1451 - trunk/documents/database
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Mon Jun 11 13:33:54 EDT 2007
Author: marko
Date: 2007-06-11 13:33:54 -0400 (Mon, 11 Jun 2007)
New Revision: 1451
Added:
   trunk/documents/database/mapbender_schema.xml
dbdesigner4-xml format schema (not finished yet)
Added: trunk/documents/database/mapbender_schema.xml
--- trunk/documents/database/mapbender_schema.xml	                        (rev 0)
+++ trunk/documents/database/mapbender_schema.xml	2007-06-11 17:33:54 UTC (rev 1451)
@@ -0,0 +1,1636 @@
+<?xml version="1.0" standalone="yes" ?>
+<DBMODEL Version="4.0">
+<SETTINGS>
+<GLOBALSETTINGS ModelName="mapbender" IDModel="0" IDVersion="0" VersionStr="1.0.0.0" Comments="" UseVersionHistroy="1" AutoIncVersion="1" DatabaseType="MySQL" ZoomFac="105.00" XPos="884" YPos="96" DefaultDataType="5" DefaultTablePrefix="0" DefSaveDBConn="" DefSyncDBConn="" DefQueryDBConn="" Printer="" HPageCount="4.0" PageAspectRatio="1.440892512336408" PageOrientation="1" PageFormat="A4 (210x297 mm, 8.26x11.7 inches)" SelectedPages="" UsePositionGrid="0" PositionGridX="20" PositionGridY="20" TableNameInRefs="0" DefaultTableType="1" ActivateRefDefForNewRelations="1" FKPrefix="fkey_" FKPostfix="" CreateFKRefDefIndex="1" DBQuoteCharacter="`" CreateSQLforLinkedObjects="0" DefModelFont="Tahoma" CanvasWidth="4096" CanvasHeight="2842" />
+<DATATYPEGROUPS>
+<DATATYPEGROUP Name="Numeric Types" Icon="1" />
+<DATATYPEGROUP Name="Date and Time Types" Icon="2" />
+<DATATYPEGROUP Name="String Types" Icon="3" />
+<DATATYPEGROUP Name="Blob and Text Types" Icon="4" />
+<DATATYPEGROUP Name="User defined Types" Icon="5" />
+<DATATYPEGROUP Name="Geographic Types" Icon="6" />
+</DATATYPEGROUPS>
+<DATATYPES>
+<DATATYPE ID="1" IDGroup="0" TypeName="TINYINT" Description="A very small integer. The signed range is -128 to 127. The unsigned range is 0 to 255." ParamCount="1" OptionCount="2" ParamRequired="0" EditParamsAsString="0" SynonymGroup="0" PhysicalMapping="0" PhysicalTypeName="" >
+<PARAMS>
+<PARAM Name="length" />
+</PARAMS>
+<OPTIONS>
+<OPTION Name="UNSIGNED" Default="1" />
+<OPTION Name="ZEROFILL" Default="0" />
+</OPTIONS>
+</DATATYPE>
+<DATATYPE ID="2" IDGroup="0" TypeName="SMALLINT" Description="A small integer. The signed range is -32768 to 32767. The unsigned range is 0 to 65535." ParamCount="1" OptionCount="2" ParamRequired="0" EditParamsAsString="0" SynonymGroup="0" PhysicalMapping="0" PhysicalTypeName="" >
+<PARAMS>
+</PARAMS>
+<OPTIONS>
+</OPTIONS>
+</DATATYPE>
+<DATATYPE ID="3" IDGroup="0" TypeName="MEDIUMINT" Description="A medium-size integer. The signed range is -8388608 to 8388607. The unsigned range is 0 to 16777215." ParamCount="1" OptionCount="2" ParamRequired="0" EditParamsAsString="0" SynonymGroup="0" PhysicalMapping="0" PhysicalTypeName="" >
+<PARAMS>
+</PARAMS>
+<OPTIONS>
+</OPTIONS>
+</DATATYPE>
+<DATATYPE ID="4" IDGroup="0" TypeName="INT" Description="A normal-size integer. The signed range is -2147483648 to 2147483647. The unsigned range is 0 to 4294967295." ParamCount="1" OptionCount="2" ParamRequired="0" EditParamsAsString="0" SynonymGroup="1" PhysicalMapping="0" PhysicalTypeName="" >
+<PARAMS>
+</PARAMS>
+<OPTIONS>
+<OPTION Name="UNSIGNED" Default="0" />
+</OPTIONS>
+</DATATYPE>
+<DATATYPE ID="5" IDGroup="0" TypeName="INTEGER" Description="A normal-size integer. The signed range is -2147483648 to 2147483647. The unsigned range is 0 to 4294967295." ParamCount="1" OptionCount="2" ParamRequired="0" EditParamsAsString="0" SynonymGroup="1" PhysicalMapping="0" PhysicalTypeName="" >
+<PARAMS>
+</PARAMS>
+<OPTIONS>
+</OPTIONS>
+</DATATYPE>
+<DATATYPE ID="6" IDGroup="0" TypeName="BIGINT" Description="A large integer. The signed range is -9223372036854775808 to 9223372036854775807. The unsigned range is 0 to 18446744073709551615." ParamCount="1" OptionCount="2" ParamRequired="0" EditParamsAsString="0" SynonymGroup="0" PhysicalMapping="0" PhysicalTypeName="" >
+<PARAMS>
+</PARAMS>
+<OPTIONS>
+</OPTIONS>
+</DATATYPE>
+<DATATYPE ID="7" IDGroup="0" TypeName="FLOAT" Description="A small (single-precision) floating-point number. Cannot be unsigned. Allowable values are -3.402823466E+38 to -1.175494351E-38, 0, and 1.175494351E-38 to 3.402823466E+38." ParamCount="1" OptionCount="1" ParamRequired="1" EditParamsAsString="0" SynonymGroup="0" PhysicalMapping="0" PhysicalTypeName="" >
+<PARAMS>
+<PARAM Name="precision" />
+</PARAMS>
+<OPTIONS>
+</OPTIONS>
+</DATATYPE>
+<DATATYPE ID="8" IDGroup="0" TypeName="FLOAT" Description="A small (single-precision) floating-point number. Cannot be unsigned. Allowable values are -3.402823466E+38 to -1.175494351E-38, 0, and 1.175494351E-38 to 3.402823466E+38." ParamCount="2" OptionCount="1" ParamRequired="0" EditParamsAsString="0" SynonymGroup="0" PhysicalMapping="0" PhysicalTypeName="" >
+<PARAMS>
+<PARAM Name="decimals" />
+</PARAMS>
+<OPTIONS>
+</OPTIONS>
+</DATATYPE>
+<DATATYPE ID="9" IDGroup="0" TypeName="DOUBLE" Description="A normal-size (double-precision) floating-point number. Cannot be unsigned. Allowable values are -1.7976931348623157E+308 to -2.2250738585072014E-308, 0, and 2.2250738585072014E-308 to 1.7976931348623157E+308." ParamCount="2" OptionCount="1" ParamRequired="0" EditParamsAsString="0" SynonymGroup="2" PhysicalMapping="0" PhysicalTypeName="" >
+<PARAMS>
+</PARAMS>
+<OPTIONS>
+</OPTIONS>
+</DATATYPE>
+<DATATYPE ID="10" IDGroup="0" TypeName="DOUBLE PRECISION" Description="This is a synonym for DOUBLE." ParamCount="2" OptionCount="1" ParamRequired="0" EditParamsAsString="0" SynonymGroup="2" PhysicalMapping="0" PhysicalTypeName="" >
+<PARAMS>
+</PARAMS>
+<OPTIONS>
+</OPTIONS>
+</DATATYPE>
+<DATATYPE ID="11" IDGroup="0" TypeName="REAL" Description="This is a synonym for DOUBLE." ParamCount="2" OptionCount="1" ParamRequired="0" EditParamsAsString="0" SynonymGroup="2" PhysicalMapping="0" PhysicalTypeName="" >
+<PARAMS>
+</PARAMS>
+<OPTIONS>
+</OPTIONS>
+</DATATYPE>
+<DATATYPE ID="12" IDGroup="0" TypeName="DECIMAL" Description="An unpacked floating-point number. Cannot be unsigned. Behaves like a CHAR column." ParamCount="2" OptionCount="1" ParamRequired="0" EditParamsAsString="0" SynonymGroup="3" PhysicalMapping="0" PhysicalTypeName="" >
+<PARAMS>
+</PARAMS>
+<OPTIONS>
+</OPTIONS>
+</DATATYPE>
+<DATATYPE ID="13" IDGroup="0" TypeName="NUMERIC" Description="This is a synonym for DECIMAL." ParamCount="2" OptionCount="1" ParamRequired="1" EditParamsAsString="0" SynonymGroup="3" PhysicalMapping="0" PhysicalTypeName="" >
+<PARAMS>
+</PARAMS>
+<OPTIONS>
+</OPTIONS>
+</DATATYPE>
+<DATATYPE ID="14" IDGroup="1" TypeName="DATE" Description="A date. The supported range is \a1000-01-01\a to \a9999-12-31\a." ParamCount="0" OptionCount="0" ParamRequired="0" EditParamsAsString="0" SynonymGroup="0" PhysicalMapping="0" PhysicalTypeName="" >
+</DATATYPE>
+<DATATYPE ID="15" IDGroup="1" TypeName="DATETIME" Description="A date and time combination. The supported range is \a1000-01-01 00:00:00\a to \a9999-12-31 23:59:59\a." ParamCount="0" OptionCount="0" ParamRequired="0" EditParamsAsString="0" SynonymGroup="0" PhysicalMapping="0" PhysicalTypeName="" >
+</DATATYPE>
+<DATATYPE ID="16" IDGroup="1" TypeName="TIMESTAMP" Description="A timestamp. The range is \a1970-01-01 00:00:00\a to sometime in the year 2037. The length can be 14 (or missing), 12, 10, 8, 6, 4, or 2 representing YYYYMMDDHHMMSS, ... , YYYYMMDD, ... , YY formats." ParamCount="1" OptionCount="0" ParamRequired="0" EditParamsAsString="0" SynonymGroup="0" PhysicalMapping="0" PhysicalTypeName="" >
+<PARAMS>
+</PARAMS>
+</DATATYPE>
+<DATATYPE ID="17" IDGroup="1" TypeName="TIME" Description="A time. The range is \a-838:59:59\a to \a838:59:59\a." ParamCount="0" OptionCount="0" ParamRequired="0" EditParamsAsString="0" SynonymGroup="0" PhysicalMapping="0" PhysicalTypeName="" >
+</DATATYPE>
+<DATATYPE ID="18" IDGroup="1" TypeName="YEAR" Description="A year in 2- or 4-digit format (default is 4-digit)." ParamCount="1" OptionCount="0" ParamRequired="0" EditParamsAsString="0" SynonymGroup="0" PhysicalMapping="0" PhysicalTypeName="" >
+<PARAMS>
+</PARAMS>
+</DATATYPE>
+<DATATYPE ID="19" IDGroup="2" TypeName="CHAR" Description="A fixed-length string (1 to 255 characters) that is always right-padded with spaces to the specified length when stored. values are sorted and compared in case-insensitive fashion according to the default character set unless the BINARY keyword is given." ParamCount="1" OptionCount="1" ParamRequired="1" EditParamsAsString="0" SynonymGroup="0" PhysicalMapping="0" PhysicalTypeName="" >
+<PARAMS>
+</PARAMS>
+<OPTIONS>
+<OPTION Name="BINARY" Default="0" />
+</OPTIONS>
+</DATATYPE>
+<DATATYPE ID="20" IDGroup="2" TypeName="VARCHAR" Description="A variable-length string (1 to 255 characters). Values are sorted and compared in case-sensitive fashion unless the BINARY keyword is given." ParamCount="1" OptionCount="1" ParamRequired="1" EditParamsAsString="0" SynonymGroup="0" PhysicalMapping="0" PhysicalTypeName="" >
+<PARAMS>
+</PARAMS>
+<OPTIONS>
+</OPTIONS>
+</DATATYPE>
+<DATATYPE ID="21" IDGroup="2" TypeName="BIT" Description="This is a synonym for CHAR(1)." ParamCount="0" OptionCount="0" ParamRequired="0" EditParamsAsString="0" SynonymGroup="0" PhysicalMapping="0" PhysicalTypeName="" >
+</DATATYPE>
+<DATATYPE ID="22" IDGroup="2" TypeName="BOOL" Description="This is a synonym for CHAR(1)." ParamCount="0" OptionCount="0" ParamRequired="0" EditParamsAsString="0" SynonymGroup="0" PhysicalMapping="0" PhysicalTypeName="" >
+</DATATYPE>
+<DATATYPE ID="23" IDGroup="3" TypeName="TINYBLOB" Description="A column maximum length of 255 (2^8 - 1) characters. Values are sorted and compared in case-sensitive fashion." ParamCount="0" OptionCount="0" ParamRequired="0" EditParamsAsString="0" SynonymGroup="0" PhysicalMapping="0" PhysicalTypeName="" >
+</DATATYPE>
+<DATATYPE ID="24" IDGroup="3" TypeName="BLOB" Description="A column maximum length of 65535 (2^16 - 1) characters. Values are sorted and compared in case-sensitive fashion." ParamCount="0" OptionCount="0" ParamRequired="0" EditParamsAsString="0" SynonymGroup="0" PhysicalMapping="0" PhysicalTypeName="" >
+</DATATYPE>
+<DATATYPE ID="25" IDGroup="3" TypeName="MEDIUMBLOB" Description="A column maximum length of 16777215 (2^24 - 1) characters. Values are sorted and compared in case-sensitive fashion." ParamCount="0" OptionCount="0" ParamRequired="0" EditParamsAsString="0" SynonymGroup="0" PhysicalMapping="0" PhysicalTypeName="" >
+</DATATYPE>
+<DATATYPE ID="26" IDGroup="3" TypeName="LONGBLOB" Description="A column maximum length of 4294967295 (2^32 - 1) characters. Values are sorted and compared in case-sensitive fashion." ParamCount="0" OptionCount="0" ParamRequired="0" EditParamsAsString="0" SynonymGroup="0" PhysicalMapping="0" PhysicalTypeName="" >
+</DATATYPE>
+<DATATYPE ID="27" IDGroup="3" TypeName="TINYTEXT" Description="A column maximum length of 255 (2^8 - 1) characters." ParamCount="0" OptionCount="0" ParamRequired="0" EditParamsAsString="0" SynonymGroup="0" PhysicalMapping="0" PhysicalTypeName="" >
+</DATATYPE>
+<DATATYPE ID="28" IDGroup="3" TypeName="TEXT" Description="A column maximum length of 65535 (2^16 - 1) characters." ParamCount="0" OptionCount="0" ParamRequired="0" EditParamsAsString="0" SynonymGroup="0" PhysicalMapping="0" PhysicalTypeName="" >
+</DATATYPE>
+<DATATYPE ID="29" IDGroup="3" TypeName="MEDIUMTEXT" Description="A column maximum length of 16777215 (2^24 - 1) characters." ParamCount="0" OptionCount="0" ParamRequired="0" EditParamsAsString="0" SynonymGroup="0" PhysicalMapping="0" PhysicalTypeName="" >
+</DATATYPE>
+<DATATYPE ID="30" IDGroup="3" TypeName="LONGTEXT" Description="A column maximum length of 4294967295 (2^32 - 1) characters." ParamCount="0" OptionCount="0" ParamRequired="0" EditParamsAsString="0" SynonymGroup="0" PhysicalMapping="0" PhysicalTypeName="" >
+</DATATYPE>
+<DATATYPE ID="31" IDGroup="3" TypeName="ENUM" Description="An enumeration. A string object that can have only one value, chosen from the list of values." ParamCount="1" OptionCount="0" ParamRequired="1" EditParamsAsString="1" SynonymGroup="0" PhysicalMapping="0" PhysicalTypeName="" >
+<PARAMS>
+<PARAM Name="values" />
+</PARAMS>
+</DATATYPE>
+<DATATYPE ID="32" IDGroup="3" TypeName="SET" Description="A set. A string object that can have zero or more values, each of which must be chosen from the list of values." ParamCount="1" OptionCount="0" ParamRequired="1" EditParamsAsString="1" SynonymGroup="0" PhysicalMapping="0" PhysicalTypeName="" >
+<PARAMS>
+</PARAMS>
+</DATATYPE>
+<DATATYPE ID="33" IDGroup="4" TypeName="Varchar(20)" Description="" ParamCount="0" OptionCount="1" ParamRequired="0" EditParamsAsString="0" SynonymGroup="0" PhysicalMapping="0" PhysicalTypeName="" >
+<OPTIONS>
+</OPTIONS>
+</DATATYPE>
+<DATATYPE ID="34" IDGroup="4" TypeName="Varchar(45)" Description="" ParamCount="0" OptionCount="1" ParamRequired="0" EditParamsAsString="0" SynonymGroup="0" PhysicalMapping="0" PhysicalTypeName="" >
+<OPTIONS>
+</OPTIONS>
+</DATATYPE>
+<DATATYPE ID="35" IDGroup="4" TypeName="Varchar(255)" Description="" ParamCount="0" OptionCount="1" ParamRequired="0" EditParamsAsString="0" SynonymGroup="0" PhysicalMapping="0" PhysicalTypeName="" >
+<OPTIONS>
+</OPTIONS>
+</DATATYPE>
+<DATATYPE ID="36" IDGroup="5" TypeName="GEOMETRY" Description="Geographic Datatype" ParamCount="0" OptionCount="0" ParamRequired="0" EditParamsAsString="0" SynonymGroup="0" PhysicalMapping="0" PhysicalTypeName="" >
+</DATATYPE>
+<DATATYPE ID="38" IDGroup="5" TypeName="LINESTRING" Description="Geographic Datatype" ParamCount="0" OptionCount="0" ParamRequired="0" EditParamsAsString="0" SynonymGroup="0" PhysicalMapping="0" PhysicalTypeName="" >
+</DATATYPE>
+<DATATYPE ID="39" IDGroup="5" TypeName="POLYGON" Description="Geographic Datatype" ParamCount="0" OptionCount="0" ParamRequired="0" EditParamsAsString="0" SynonymGroup="0" PhysicalMapping="0" PhysicalTypeName="" >
+</DATATYPE>
+<DATATYPE ID="40" IDGroup="5" TypeName="MULTIPOINT" Description="Geographic Datatype" ParamCount="0" OptionCount="0" ParamRequired="0" EditParamsAsString="0" SynonymGroup="0" PhysicalMapping="0" PhysicalTypeName="" >
+</DATATYPE>
+<DATATYPE ID="41" IDGroup="5" TypeName="MULTILINESTRING" Description="Geographic Datatype" ParamCount="0" OptionCount="0" ParamRequired="0" EditParamsAsString="0" SynonymGroup="0" PhysicalMapping="0" PhysicalTypeName="" >
+</DATATYPE>
+<DATATYPE ID="42" IDGroup="5" TypeName="MULTIPOLYGON" Description="Geographic Datatype" ParamCount="0" OptionCount="0" ParamRequired="0" EditParamsAsString="0" SynonymGroup="0" PhysicalMapping="0" PhysicalTypeName="" >
+</DATATYPE>
+<DATATYPE ID="43" IDGroup="5" TypeName="GEOMETRYCOLLECTION" Description="Geographic Datatype" ParamCount="0" OptionCount="0" ParamRequired="0" EditParamsAsString="0" SynonymGroup="0" PhysicalMapping="0" PhysicalTypeName="" >
+</DATATYPE>
+</DATATYPES>
+<COMMON_DATATYPES>
+<COMMON_DATATYPE ID="5" />
+<COMMON_DATATYPE ID="8" />
+<COMMON_DATATYPE ID="20" />
+<COMMON_DATATYPE ID="15" />
+<COMMON_DATATYPE ID="22" />
+<COMMON_DATATYPE ID="28" />
+<COMMON_DATATYPE ID="26" />
+<COMMON_DATATYPE ID="33" />
+<COMMON_DATATYPE ID="34" />
+<COMMON_DATATYPE ID="35" />
+</COMMON_DATATYPES>
+<TABLEPREFIXES>
+<TABLEPREFIX Name="Default (no prefix)" />
+</TABLEPREFIXES>
+<REGIONCOLORS>
+<REGIONCOLOR Color="Red=#FFEEEC" />
+<REGIONCOLOR Color="Yellow=#FEFDED" />
+<REGIONCOLOR Color="Green=#EAFFE5" />
+<REGIONCOLOR Color="Cyan=#ECFDFF" />
+<REGIONCOLOR Color="Blue=#F0F1FE" />
+<REGIONCOLOR Color="Magenta=#FFEBFA" />
+</REGIONCOLORS>
+<POSITIONMARKERS>
+<POSITIONMARKER ZoomFac="-1.0" X="0" Y="0" />
+</POSITIONMARKERS>
+</SETTINGS>
+<METADATA>
+<REGIONS>
+</REGIONS>
+<TABLES>
+<TABLE ID="1194" Tablename="gui" PrevTableName="Table_01" XPos="725" YPos="461" TableType="0" TablePrefix="0" nmTable="0" Temporary="0" UseStandardInserts="0" StandardInserts="\n" TableOptions="DelayKeyTblUpdates=0\nPackKeys=0\nRowChecksum=0\nRowFormat=0\nUseRaid=0\nRaidType=0\n" Comments="" Collapsed="0" IsLinkedObject="0" IDLinkedModel="-1" Obj_id_Linked="-1" OrderPos="3" >
+<COLUMNS>
+<COLUMN ID="1196" ColName="gui_id" PrevColName="" Pos="0" idDatatype="20" DatatypeParams="(50)" Width="-1" Prec="-1" PrimaryKey="1" NotNull="1" AutoInc="1" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+<OPTIONSELECT Value="0" />
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1198" ColName="gui_name" PrevColName="" Pos="1" idDatatype="20" DatatypeParams="(50)" Width="-1" Prec="-1" PrimaryKey="0" NotNull="1" AutoInc="0" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1199" ColName="gui_description" PrevColName="" Pos="2" idDatatype="20" DatatypeParams="(255)" Width="-1" Prec="-1" PrimaryKey="0" NotNull="1" AutoInc="0" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1200" ColName="gui_public" PrevColName="" Pos="3" idDatatype="5" DatatypeParams="" Width="-1" Prec="-1" PrimaryKey="0" NotNull="1" AutoInc="0" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+<OPTIONSELECT Value="1" />
+</OPTIONSELECTED>
+</COLUMN>
+</COLUMNS>
+<RELATIONS_START>
+<RELATION_START ID="1207" />
+<RELATION_START ID="1240" />
+<RELATION_START ID="1341" />
+<RELATION_START ID="1353" />
+<RELATION_START ID="1361" />
+<RELATION_START ID="1369" />
+<RELATION_START ID="1468" />
+</RELATIONS_START>
+<INDICES>
+<INDEX ID="1197" IndexName="PRIMARY" IndexKind="0" FKRefDef_Obj_id="-1">
+<INDEXCOLUMNS>
+<INDEXCOLUMN idColumn="1196" LengthParam="0" />
+</INDEXCOLUMNS>
+</INDEX>
+</INDICES>
+</TABLE>
+<TABLE ID="1201" Tablename="gui_element" PrevTableName="Table_02" XPos="1114" YPos="1107" TableType="0" TablePrefix="0" nmTable="0" Temporary="0" UseStandardInserts="0" StandardInserts="\n" TableOptions="DelayKeyTblUpdates=0\nPackKeys=0\nRowChecksum=0\nRowFormat=0\nUseRaid=0\nRaidType=0\n" Comments="" Collapsed="0" IsLinkedObject="0" IDLinkedModel="-1" Obj_id_Linked="-1" OrderPos="4" >
+<COLUMNS>
+<COLUMN ID="1210" ColName="fkey_gui_id" PrevColName="" Pos="1" idDatatype="20" DatatypeParams="(50)" Width="-1" Prec="-1" PrimaryKey="1" NotNull="1" AutoInc="0" IsForeignKey="1" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1203" ColName="e_id" PrevColName="" Pos="0" idDatatype="20" DatatypeParams="(50)" Width="-1" Prec="-1" PrimaryKey="1" NotNull="1" AutoInc="1" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1205" ColName="e_pos" PrevColName="" Pos="1" idDatatype="5" DatatypeParams="" Width="-1" Prec="-1" PrimaryKey="0" NotNull="0" AutoInc="0" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1206" ColName="e_public" PrevColName="" Pos="2" idDatatype="5" DatatypeParams="" Width="-1" Prec="-1" PrimaryKey="0" NotNull="0" AutoInc="0" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1263" ColName="e_comment" PrevColName="" Pos="4" idDatatype="28" DatatypeParams="" Width="-1" Prec="-1" PrimaryKey="0" NotNull="0" AutoInc="0" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1264" ColName="e_element" PrevColName="" Pos="5" idDatatype="20" DatatypeParams="(255)" Width="-1" Prec="-1" PrimaryKey="0" NotNull="1" AutoInc="0" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1269" ColName="e_src" PrevColName="" Pos="6" idDatatype="20" DatatypeParams="(255)" Width="-1" Prec="-1" PrimaryKey="0" NotNull="0" AutoInc="0" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1270" ColName="e_attributes" PrevColName="" Pos="7" idDatatype="28" DatatypeParams="" Width="-1" Prec="-1" PrimaryKey="0" NotNull="0" AutoInc="0" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1271" ColName="e_left" PrevColName="" Pos="8" idDatatype="5" DatatypeParams="" Width="-1" Prec="-1" PrimaryKey="0" NotNull="0" AutoInc="0" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1272" ColName="e_top" PrevColName="" Pos="9" idDatatype="5" DatatypeParams="" Width="-1" Prec="-1" PrimaryKey="0" NotNull="0" AutoInc="0" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1273" ColName="e_width" PrevColName="" Pos="10" idDatatype="5" DatatypeParams="" Width="-1" Prec="-1" PrimaryKey="0" NotNull="0" AutoInc="0" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1274" ColName="e_height" PrevColName="" Pos="11" idDatatype="5" DatatypeParams="" Width="-1" Prec="-1" PrimaryKey="0" NotNull="0" AutoInc="0" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1275" ColName="e_z_index" PrevColName="" Pos="12" idDatatype="5" DatatypeParams="" Width="-1" Prec="-1" PrimaryKey="0" NotNull="0" AutoInc="0" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1276" ColName="e_more_styles" PrevColName="" Pos="13" idDatatype="28" DatatypeParams="" Width="-1" Prec="-1" PrimaryKey="0" NotNull="0" AutoInc="0" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1277" ColName="e_content" PrevColName="" Pos="14" idDatatype="28" DatatypeParams="" Width="-1" Prec="-1" PrimaryKey="0" NotNull="0" AutoInc="0" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1278" ColName="e_closetag" PrevColName="" Pos="15" idDatatype="20" DatatypeParams="(255)" Width="-1" Prec="-1" PrimaryKey="0" NotNull="0" AutoInc="0" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1279" ColName="e_js_file" PrevColName=" " Pos="16" idDatatype="20" DatatypeParams="(50)" Width="-1" Prec="-1" PrimaryKey="0" NotNull="0" AutoInc="0" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1282" ColName="e_mb_mod" PrevColName="" Pos="17" idDatatype="20" DatatypeParams="(50)" Width="-1" Prec="-1" PrimaryKey="0" NotNull="0" AutoInc="0" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1283" ColName="e_target" PrevColName="" Pos="18" idDatatype="20" DatatypeParams="(50)" Width="-1" Prec="-1" PrimaryKey="0" NotNull="0" AutoInc="0" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1284" ColName="e_requires" PrevColName="" Pos="19" idDatatype="20" DatatypeParams="(50)" Width="-1" Prec="-1" PrimaryKey="0" NotNull="0" AutoInc="0" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1286" ColName="e_url" PrevColName="" Pos="20" idDatatype="20" DatatypeParams="(255)" Width="-1" Prec="-1" PrimaryKey="0" NotNull="0" AutoInc="0" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+</COLUMNS>
+<RELATIONS_START>
+<RELATION_START ID="1287" />
+</RELATIONS_START>
+<RELATIONS_END>
+<RELATION_END ID="1207" />
+</RELATIONS_END>
+<INDICES>
+<INDEX ID="1204" IndexName="PRIMARY" IndexKind="0" FKRefDef_Obj_id="-1">
+<INDEXCOLUMNS>
+<INDEXCOLUMN idColumn="1210" LengthParam="0" />
+<INDEXCOLUMN idColumn="1203" LengthParam="0" />
+</INDEXCOLUMNS>
+</INDEX>
+<INDEX ID="1209" IndexName="gui_element_FKIndex1" IndexKind="1" FKRefDef_Obj_id="1207">
+<INDEXCOLUMNS>
+</INDEXCOLUMNS>
+</INDEX>
+</INDICES>
+</TABLE>
+<TABLE ID="1216" Tablename="wfs" PrevTableName="Table_03" XPos="1224" YPos="55" TableType="0" TablePrefix="0" nmTable="0" Temporary="0" UseStandardInserts="0" StandardInserts="\n" TableOptions="DelayKeyTblUpdates=0\nPackKeys=0\nRowChecksum=0\nRowFormat=0\nUseRaid=0\nRaidType=0\n" Comments="" Collapsed="0" IsLinkedObject="0" IDLinkedModel="-1" Obj_id_Linked="-1" OrderPos="6" >
+<COLUMNS>
+<COLUMN ID="1223" ColName="wfs_id" PrevColName="" Pos="0" idDatatype="5" DatatypeParams="" Width="-1" Prec="-1" PrimaryKey="1" NotNull="1" AutoInc="1" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1225" ColName="wfs_version" PrevColName="" Pos="1" idDatatype="5" DatatypeParams="" Width="-1" Prec="-1" PrimaryKey="0" NotNull="0" AutoInc="0" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1226" ColName="wfs_name" PrevColName="" Pos="2" idDatatype="20" DatatypeParams="" Width="-1" Prec="-1" PrimaryKey="0" NotNull="0" AutoInc="0" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+</COLUMNS>
+<RELATIONS_START>
+<RELATION_START ID="1243" />
+</RELATIONS_START>
+<INDICES>
+<INDEX ID="1224" IndexName="PRIMARY" IndexKind="0" FKRefDef_Obj_id="-1">
+<INDEXCOLUMNS>
+<INDEXCOLUMN idColumn="1223" LengthParam="0" />
+</INDEXCOLUMNS>
+</INDEX>
+</INDICES>
+</TABLE>
+<TABLE ID="1229" Tablename="gui_wfs" PrevTableName="Table_04" XPos="722" YPos="63" TableType="1" TablePrefix="0" nmTable="0" Temporary="0" UseStandardInserts="0" StandardInserts="\n" TableOptions="DelayKeyTblUpdates=0\nPackKeys=0\nRowChecksum=0\nRowFormat=0\nUseRaid=0\nRaidType=0\n" Comments="" Collapsed="0" IsLinkedObject="0" IDLinkedModel="-1" Obj_id_Linked="-1" OrderPos="8" >
+<COLUMNS>
+<COLUMN ID="1244" ColName="fkey_wfs_id" PrevColName="" Pos="1" idDatatype="5" DatatypeParams="" Width="-1" Prec="-1" PrimaryKey="0" NotNull="1" AutoInc="0" IsForeignKey="1" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1241" ColName="fkey_gui_id" PrevColName="" Pos="1" idDatatype="20" DatatypeParams="(50)" Width="-1" Prec="-1" PrimaryKey="0" NotNull="1" AutoInc="0" IsForeignKey="1" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+</COLUMNS>
+<RELATIONS_END>
+<RELATION_END ID="1240" />
+<RELATION_END ID="1243" />
+</RELATIONS_END>
+<INDICES>
+<INDEX ID="1242" IndexName="gui_wfs_FKIndex1" IndexKind="1" FKRefDef_Obj_id="1240">
+<INDEXCOLUMNS>
+<INDEXCOLUMN idColumn="1241" LengthParam="0" />
+</INDEXCOLUMNS>
+</INDEX>
+<INDEX ID="1245" IndexName="gui_wfs_FKIndex2" IndexKind="1" FKRefDef_Obj_id="1243">
+<INDEXCOLUMNS>
+<INDEXCOLUMN idColumn="1244" LengthParam="0" />
+</INDEXCOLUMNS>
+</INDEX>
+</INDICES>
+</TABLE>
+<TABLE ID="1247" Tablename="gui_element_vars" PrevTableName="Table_05" XPos="1099" YPos="1705" TableType="1" TablePrefix="0" nmTable="0" Temporary="0" UseStandardInserts="0" StandardInserts="\n" TableOptions="DelayKeyTblUpdates=0\nPackKeys=0\nRowChecksum=0\nRowFormat=0\nUseRaid=0\nRaidType=0\n" Comments="" Collapsed="0" IsLinkedObject="0" IDLinkedModel="-1" Obj_id_Linked="-1" OrderPos="11" >
+<COLUMNS>
+<COLUMN ID="1288" ColName="fkey_e_id" PrevColName="" Pos="1" idDatatype="20" DatatypeParams="(50)" Width="-1" Prec="-1" PrimaryKey="1" NotNull="1" AutoInc="0" IsForeignKey="1" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1249" ColName="var_name" PrevColName="" Pos="0" idDatatype="20" DatatypeParams="(50)" Width="-1" Prec="-1" PrimaryKey="1" NotNull="1" AutoInc="1" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1308" ColName="fkey_fkey_gui_id" PrevColName="" Pos="1" idDatatype="20" DatatypeParams="(50)" Width="-1" Prec="-1" PrimaryKey="0" NotNull="1" AutoInc="0" IsForeignKey="1" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1251" ColName="var_value" PrevColName="" Pos="1" idDatatype="28" DatatypeParams="" Width="-1" Prec="-1" PrimaryKey="0" NotNull="0" AutoInc="0" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1252" ColName="context" PrevColName="var_context" Pos="2" idDatatype="28" DatatypeParams="" Width="-1" Prec="-1" PrimaryKey="0" NotNull="0" AutoInc="0" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1253" ColName="var_type" PrevColName="" Pos="3" idDatatype="20" DatatypeParams="(50)" Width="-1" Prec="-1" PrimaryKey="0" NotNull="0" AutoInc="0" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+</COLUMNS>
+<RELATIONS_END>
+<RELATION_END ID="1287" />
+</RELATIONS_END>
+<INDICES>
+<INDEX ID="1250" IndexName="PRIMARY" IndexKind="0" FKRefDef_Obj_id="-1">
+<INDEXCOLUMNS>
+<INDEXCOLUMN idColumn="1288" LengthParam="0" />
+<INDEXCOLUMN idColumn="1249" LengthParam="0" />
+</INDEXCOLUMNS>
+</INDEX>
+<INDEX ID="1289" IndexName="gui_element_vars_FKIndex1" IndexKind="1" FKRefDef_Obj_id="1287">
+<INDEXCOLUMNS>
+<INDEXCOLUMN idColumn="1308" LengthParam="0" />
+</INDEXCOLUMNS>
+</INDEX>
+</INDICES>
+</TABLE>
+<TABLE ID="1296" Tablename="gui_layer" PrevTableName="Table_06" XPos="1276" YPos="628" TableType="1" TablePrefix="0" nmTable="0" Temporary="0" UseStandardInserts="0" StandardInserts="\n" TableOptions="DelayKeyTblUpdates=0\nPackKeys=0\nRowChecksum=0\nRowFormat=0\nUseRaid=0\nRaidType=0\n" Comments="" Collapsed="0" IsLinkedObject="0" IDLinkedModel="-1" Obj_id_Linked="-1" OrderPos="14" >
+<COLUMNS>
+<COLUMN ID="1491" ColName="fkey_layer_id" PrevColName="" Pos="1" idDatatype="5" DatatypeParams="" Width="-1" Prec="-1" PrimaryKey="1" NotNull="1" AutoInc="0" IsForeignKey="1" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1354" ColName="fkey_gui_id" PrevColName="" Pos="1" idDatatype="20" DatatypeParams="(50)" Width="-1" Prec="-1" PrimaryKey="1" NotNull="1" AutoInc="0" IsForeignKey="1" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1323" ColName="gui_layer_wms_id" PrevColName="" Pos="2" idDatatype="5" DatatypeParams="" Width="-1" Prec="-1" PrimaryKey="0" NotNull="1" AutoInc="0" IsForeignKey="0" DefaultValue="0" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1324" ColName="gui_layer_status" PrevColName="" Pos="3" idDatatype="5" DatatypeParams="" Width="-1" Prec="-1" PrimaryKey="0" NotNull="0" AutoInc="0" IsForeignKey="0" DefaultValue="1" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1325" ColName="gui_layer_selectable" PrevColName="" Pos="4" idDatatype="5" DatatypeParams="" Width="-1" Prec="-1" PrimaryKey="0" NotNull="0" AutoInc="0" IsForeignKey="0" DefaultValue="1" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1326" ColName="gui_layer_visible" PrevColName="" Pos="5" idDatatype="5" DatatypeParams="" Width="-1" Prec="-1" PrimaryKey="0" NotNull="0" AutoInc="0" IsForeignKey="0" DefaultValue="1" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1327" ColName="gui_layer_queryable" PrevColName="" Pos="6" idDatatype="5" DatatypeParams="" Width="-1" Prec="-1" PrimaryKey="0" NotNull="0" AutoInc="0" IsForeignKey="0" DefaultValue="0" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1328" ColName="gui_layer_querylayer" PrevColName="" Pos="7" idDatatype="5" DatatypeParams="" Width="-1" Prec="-1" PrimaryKey="0" NotNull="0" AutoInc="0" IsForeignKey="0" DefaultValue="0" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1329" ColName="gui_layer_minscale" PrevColName="" Pos="8" idDatatype="5" DatatypeParams="" Width="-1" Prec="-1" PrimaryKey="0" NotNull="0" AutoInc="0" IsForeignKey="0" DefaultValue="0" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1330" ColName="gui_layer_maxscale" PrevColName="" Pos="9" idDatatype="5" DatatypeParams="" Width="-1" Prec="-1" PrimaryKey="0" NotNull="0" AutoInc="0" IsForeignKey="0" DefaultValue="0" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1331" ColName="gui_layer_priority" PrevColName="" Pos="10" idDatatype="5" DatatypeParams="" Width="-1" Prec="-1" PrimaryKey="0" NotNull="0" AutoInc="0" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1332" ColName="gui_layer_style" PrevColName="" Pos="11" idDatatype="20" DatatypeParams="(50)" Width="-1" Prec="-1" PrimaryKey="0" NotNull="0" AutoInc="0" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1335" ColName="gui_layer_wfs_featuretype" PrevColName="" Pos="12" idDatatype="20" DatatypeParams="(50)" Width="-1" Prec="-1" PrimaryKey="0" NotNull="0" AutoInc="0" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+</COLUMNS>
+<RELATIONS_END>
+<RELATION_END ID="1353" />
+<RELATION_END ID="1490" />
+</RELATIONS_END>
+<INDICES>
+<INDEX ID="1496" IndexName="PRIMARY" IndexKind="0" FKRefDef_Obj_id="-1">
+<INDEXCOLUMNS>
+<INDEXCOLUMN idColumn="1491" LengthParam="0" />
+<INDEXCOLUMN idColumn="1354" LengthParam="0" />
+</INDEXCOLUMNS>
+</INDEX>
+<INDEX ID="1355" IndexName="gui_layer_FKIndex1" IndexKind="1" FKRefDef_Obj_id="1353">
+<INDEXCOLUMNS>
+</INDEXCOLUMNS>
+</INDEX>
+<INDEX ID="1492" IndexName="gui_layer_FKIndex2" IndexKind="1" FKRefDef_Obj_id="1490">
+<INDEXCOLUMNS>
+</INDEXCOLUMNS>
+</INDEX>
+</INDICES>
+</TABLE>
+<TABLE ID="1337" Tablename="gui_treegde" PrevTableName="Table_07" XPos="301" YPos="65" TableType="1" TablePrefix="0" nmTable="0" Temporary="0" UseStandardInserts="0" StandardInserts="\n" TableOptions="DelayKeyTblUpdates=0\nPackKeys=0\nRowChecksum=0\nRowFormat=0\nUseRaid=0\nRaidType=0\n" Comments="" Collapsed="0" IsLinkedObject="0" IDLinkedModel="-1" Obj_id_Linked="-1" OrderPos="15" >
+<COLUMNS>
+<COLUMN ID="1339" ColName="id" PrevColName="idgui_treegde" Pos="0" idDatatype="5" DatatypeParams="" Width="-1" Prec="-1" PrimaryKey="1" NotNull="1" AutoInc="1" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1342" ColName="fkey_gui_id" PrevColName="" Pos="1" idDatatype="20" DatatypeParams="(50)" Width="-1" Prec="-1" PrimaryKey="0" NotNull="1" AutoInc="0" IsForeignKey="1" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1345" ColName="lft" PrevColName="" Pos="2" idDatatype="5" DatatypeParams="" Width="-1" Prec="-1" PrimaryKey="0" NotNull="1" AutoInc="0" IsForeignKey="0" DefaultValue="0" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1346" ColName="rgt" PrevColName="" Pos="3" idDatatype="5" DatatypeParams="" Width="-1" Prec="-1" PrimaryKey="0" NotNull="1" AutoInc="0" IsForeignKey="0" DefaultValue="0" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1349" ColName="my_layer_title" PrevColName="" Pos="4" idDatatype="20" DatatypeParams="(50)" Width="-1" Prec="-1" PrimaryKey="0" NotNull="0" AutoInc="0" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1350" ColName="layer" PrevColName="" Pos="5" idDatatype="28" DatatypeParams="" Width="-1" Prec="-1" PrimaryKey="0" NotNull="0" AutoInc="0" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1351" ColName="wms_id" PrevColName="" Pos="6" idDatatype="28" DatatypeParams="" Width="-1" Prec="-1" PrimaryKey="0" NotNull="0" AutoInc="0" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+</COLUMNS>
+<RELATIONS_END>
+<RELATION_END ID="1341" />
+</RELATIONS_END>
+<INDICES>
+<INDEX ID="1340" IndexName="PRIMARY" IndexKind="0" FKRefDef_Obj_id="-1">
+<INDEXCOLUMNS>
+<INDEXCOLUMN idColumn="1339" LengthParam="0" />
+</INDEXCOLUMNS>
+</INDEX>
+<INDEX ID="1343" IndexName="gui_treegde_FKIndex1" IndexKind="1" FKRefDef_Obj_id="1341">
+<INDEXCOLUMNS>
+<INDEXCOLUMN idColumn="1342" LengthParam="0" />
+</INDEXCOLUMNS>
+</INDEX>
+</INDICES>
+</TABLE>
+<TABLE ID="1356" Tablename="gui_mb_user" PrevTableName="Table_08" XPos="117" YPos="487" TableType="1" TablePrefix="0" nmTable="0" Temporary="0" UseStandardInserts="0" StandardInserts="\n" TableOptions="DelayKeyTblUpdates=0\nPackKeys=0\nRowChecksum=0\nRowFormat=0\nUseRaid=0\nRaidType=0\n" Comments="" Collapsed="0" IsLinkedObject="0" IDLinkedModel="-1" Obj_id_Linked="-1" OrderPos="15" >
+<COLUMNS>
+<COLUMN ID="1362" ColName="fkey_gui_id" PrevColName="" Pos="1" idDatatype="20" DatatypeParams="(50)" Width="-1" Prec="-1" PrimaryKey="1" NotNull="1" AutoInc="0" IsForeignKey="1" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1398" ColName="fkey_mb_user_id" PrevColName="" Pos="1" idDatatype="5" DatatypeParams="" Width="-1" Prec="-1" PrimaryKey="1" NotNull="1" AutoInc="0" IsForeignKey="1" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1358" ColName="mb_user_type" PrevColName="" Pos="0" idDatatype="20" DatatypeParams="(50)" Width="-1" Prec="-1" PrimaryKey="0" NotNull="1" AutoInc="1" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+</COLUMNS>
+<RELATIONS_END>
+<RELATION_END ID="1361" />
+<RELATION_END ID="1397" />
+</RELATIONS_END>
+<INDICES>
+<INDEX ID="1359" IndexName="PRIMARY" IndexKind="0" FKRefDef_Obj_id="-1">
+<INDEXCOLUMNS>
+<INDEXCOLUMN idColumn="1362" LengthParam="0" />
+<INDEXCOLUMN idColumn="1398" LengthParam="0" />
+</INDEXCOLUMNS>
+</INDEX>
+<INDEX ID="1363" IndexName="gui_mb_user_FKIndex1" IndexKind="1" FKRefDef_Obj_id="1361">
+<INDEXCOLUMNS>
+</INDEXCOLUMNS>
+</INDEX>
+<INDEX ID="1399" IndexName="gui_mb_user_FKIndex2" IndexKind="1" FKRefDef_Obj_id="1397">
+<INDEXCOLUMNS>
+</INDEXCOLUMNS>
+</INDEX>
+</INDICES>
+</TABLE>
+<TABLE ID="1365" Tablename="gui_mb_group" PrevTableName="Table_09" XPos="687" YPos="1043" TableType="1" TablePrefix="0" nmTable="0" Temporary="0" UseStandardInserts="0" StandardInserts="\n" TableOptions="DelayKeyTblUpdates=0\nPackKeys=0\nRowChecksum=0\nRowFormat=0\nUseRaid=0\nRaidType=0\n" Comments="" Collapsed="0" IsLinkedObject="0" IDLinkedModel="-1" Obj_id_Linked="-1" OrderPos="17" >
+<COLUMNS>
+<COLUMN ID="1370" ColName="fkey_gui_id" PrevColName="" Pos="1" idDatatype="20" DatatypeParams="(50)" Width="-1" Prec="-1" PrimaryKey="1" NotNull="1" AutoInc="0" IsForeignKey="1" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1410" ColName="fkey_mb_group_id" PrevColName="" Pos="1" idDatatype="5" DatatypeParams="" Width="-1" Prec="-1" PrimaryKey="1" NotNull="1" AutoInc="0" IsForeignKey="1" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1452" ColName="mb_group_type" PrevColName="" Pos="2" idDatatype="20" DatatypeParams="(50)" Width="-1" Prec="-1" PrimaryKey="0" NotNull="0" AutoInc="0" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+</COLUMNS>
+<RELATIONS_END>
+<RELATION_END ID="1369" />
+<RELATION_END ID="1409" />
+</RELATIONS_END>
+<INDICES>
+<INDEX ID="1368" IndexName="PRIMARY" IndexKind="0" FKRefDef_Obj_id="-1">
+<INDEXCOLUMNS>
+<INDEXCOLUMN idColumn="1370" LengthParam="0" />
+<INDEXCOLUMN idColumn="1410" LengthParam="0" />
+</INDEXCOLUMNS>
+</INDEX>
+<INDEX ID="1371" IndexName="gui_mb_group_FKIndex1" IndexKind="1" FKRefDef_Obj_id="1369">
+<INDEXCOLUMNS>
+</INDEXCOLUMNS>
+</INDEX>
+<INDEX ID="1411" IndexName="gui_mb_group_FKIndex2" IndexKind="1" FKRefDef_Obj_id="1409">
+<INDEXCOLUMNS>
+</INDEXCOLUMNS>
+</INDEX>
+</INDICES>
+</TABLE>
+<TABLE ID="1374" Tablename="mb_user" PrevTableName="Table_10" XPos="82" YPos="713" TableType="1" TablePrefix="0" nmTable="0" Temporary="0" UseStandardInserts="0" StandardInserts="\n" TableOptions="DelayKeyTblUpdates=0\nPackKeys=0\nRowChecksum=0\nRowFormat=0\nUseRaid=0\nRaidType=0\n" Comments="" Collapsed="0" IsLinkedObject="0" IDLinkedModel="-1" Obj_id_Linked="-1" OrderPos="19" >
+<COLUMNS>
+<COLUMN ID="1376" ColName="mb_user_id" PrevColName="" Pos="0" idDatatype="5" DatatypeParams="" Width="-1" Prec="-1" PrimaryKey="1" NotNull="1" AutoInc="1" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1378" ColName="mb_user_name" PrevColName="" Pos="1" idDatatype="20" DatatypeParams="(50)" Width="-1" Prec="-1" PrimaryKey="0" NotNull="0" AutoInc="0" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1379" ColName="mb_user_password" PrevColName="" Pos="2" idDatatype="20" DatatypeParams="(50)" Width="-1" Prec="-1" PrimaryKey="0" NotNull="0" AutoInc="0" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1381" ColName="mb_user_owner" PrevColName="" Pos="3" idDatatype="5" DatatypeParams="" Width="-1" Prec="-1" PrimaryKey="0" NotNull="1" AutoInc="0" IsForeignKey="0" DefaultValue="0" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1382" ColName="mb_user_description" PrevColName="" Pos="4" idDatatype="20" DatatypeParams="(255)" Width="-1" Prec="-1" PrimaryKey="0" NotNull="0" AutoInc="0" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1383" ColName="mb_user_login_count" PrevColName="" Pos="5" idDatatype="5" DatatypeParams="" Width="-1" Prec="-1" PrimaryKey="0" NotNull="1" AutoInc="0" IsForeignKey="0" DefaultValue="0" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1384" ColName="mb_user_email" PrevColName="" Pos="6" idDatatype="20" DatatypeParams="(50)" Width="-1" Prec="-1" PrimaryKey="0" NotNull="0" AutoInc="0" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1385" ColName="mb_user_phone" PrevColName="" Pos="7" idDatatype="20" DatatypeParams="(50)" Width="-1" Prec="-1" PrimaryKey="0" NotNull="0" AutoInc="0" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1386" ColName="mb_user_department" PrevColName="" Pos="8" idDatatype="20" DatatypeParams="(255)" Width="-1" Prec="-1" PrimaryKey="0" NotNull="0" AutoInc="0" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1387" ColName="mb_user_resolution" PrevColName="" Pos="9" idDatatype="5" DatatypeParams="" Width="-1" Prec="-1" PrimaryKey="0" NotNull="1" AutoInc="0" IsForeignKey="0" DefaultValue="72" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1388" ColName="mb_user_organisation_name" PrevColName="" Pos="10" idDatatype="20" DatatypeParams="(255)" Width="-1" Prec="-1" PrimaryKey="0" NotNull="0" AutoInc="0" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1389" ColName="mb_user_position_name" PrevColName="" Pos="11" idDatatype="20" DatatypeParams="(255)" Width="-1" Prec="-1" PrimaryKey="0" NotNull="0" AutoInc="0" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1390" ColName="mb_user_phone1" PrevColName="" Pos="12" idDatatype="20" DatatypeParams="(255)" Width="-1" Prec="-1" PrimaryKey="0" NotNull="0" AutoInc="0" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1391" ColName="mb_user_facsimile" PrevColName="" Pos="13" idDatatype="20" DatatypeParams="(255)" Width="-1" Prec="-1" PrimaryKey="0" NotNull="0" AutoInc="0" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1392" ColName="mb_user_delivery_point" PrevColName="" Pos="14" idDatatype="20" DatatypeParams="(255)" Width="-1" Prec="-1" PrimaryKey="0" NotNull="0" AutoInc="0" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1393" ColName="mb_user_city" PrevColName="" Pos="15" idDatatype="20" DatatypeParams="(255)" Width="-1" Prec="-1" PrimaryKey="0" NotNull="0" AutoInc="0" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1394" ColName="mb_user_postal_code" PrevColName="" Pos="16" idDatatype="5" DatatypeParams="" Width="-1" Prec="-1" PrimaryKey="0" NotNull="0" AutoInc="0" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1395" ColName="mb_user_country" PrevColName="" Pos="17" idDatatype="20" DatatypeParams="(255)" Width="-1" Prec="-1" PrimaryKey="0" NotNull="0" AutoInc="0" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1396" ColName="mb_user_online_resource" PrevColName="" Pos="18" idDatatype="20" DatatypeParams="(255)" Width="-1" Prec="-1" PrimaryKey="0" NotNull="0" AutoInc="0" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+</COLUMNS>
+<RELATIONS_START>
+<RELATION_START ID="1397" />
+<RELATION_START ID="1430" />
+<RELATION_START ID="1442" />
+</RELATIONS_START>
+<INDICES>
+<INDEX ID="1377" IndexName="PRIMARY" IndexKind="0" FKRefDef_Obj_id="-1">
+<INDEXCOLUMNS>
+<INDEXCOLUMN idColumn="1376" LengthParam="0" />
+</INDEXCOLUMNS>
+</INDEX>
+</INDICES>
+</TABLE>
+<TABLE ID="1402" Tablename="mb_group" PrevTableName="Table_11" XPos="672" YPos="1308" TableType="1" TablePrefix="0" nmTable="0" Temporary="0" UseStandardInserts="0" StandardInserts="\n" TableOptions="DelayKeyTblUpdates=0\nPackKeys=0\nRowChecksum=0\nRowFormat=0\nUseRaid=0\nRaidType=0\n" Comments="" Collapsed="0" IsLinkedObject="0" IDLinkedModel="-1" Obj_id_Linked="-1" OrderPos="21" >
+<COLUMNS>
+<COLUMN ID="1404" ColName="mb_group_id" PrevColName="" Pos="0" idDatatype="5" DatatypeParams="" Width="-1" Prec="-1" PrimaryKey="1" NotNull="1" AutoInc="1" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1406" ColName="mb_group_name" PrevColName="" Pos="1" idDatatype="20" DatatypeParams="(50)" Width="-1" Prec="-1" PrimaryKey="0" NotNull="1" AutoInc="0" IsForeignKey="0" DefaultValue="\a\a" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1407" ColName="mb_group_owner" PrevColName="" Pos="2" idDatatype="5" DatatypeParams="" Width="-1" Prec="-1" PrimaryKey="0" NotNull="0" AutoInc="0" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1408" ColName="mb_group_description" PrevColName="" Pos="3" idDatatype="20" DatatypeParams="(255)" Width="-1" Prec="-1" PrimaryKey="0" NotNull="1" AutoInc="0" IsForeignKey="0" DefaultValue="\a\a" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+</COLUMNS>
+<RELATIONS_START>
+<RELATION_START ID="1409" />
+<RELATION_START ID="1427" />
+</RELATIONS_START>
+<INDICES>
+<INDEX ID="1405" IndexName="PRIMARY" IndexKind="0" FKRefDef_Obj_id="-1">
+<INDEXCOLUMNS>
+<INDEXCOLUMN idColumn="1404" LengthParam="0" />
+</INDEXCOLUMNS>
+</INDEX>
+</INDICES>
+</TABLE>
+<TABLE ID="1412" Tablename="mb_user_mb_group" PrevTableName="Table_12" XPos="112" YPos="1322" TableType="1" TablePrefix="0" nmTable="0" Temporary="0" UseStandardInserts="0" StandardInserts="\n" TableOptions="DelayKeyTblUpdates=0\nPackKeys=0\nRowChecksum=0\nRowFormat=0\nUseRaid=0\nRaidType=0\n" Comments="" Collapsed="0" IsLinkedObject="0" IDLinkedModel="-1" Obj_id_Linked="-1" OrderPos="23" >
+<COLUMNS>
+<COLUMN ID="1431" ColName="fkey_mb_user_id" PrevColName="" Pos="1" idDatatype="5" DatatypeParams="" Width="-1" Prec="-1" PrimaryKey="1" NotNull="1" AutoInc="0" IsForeignKey="1" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1428" ColName="fkey_mb_group_id" PrevColName="" Pos="1" idDatatype="5" DatatypeParams="" Width="-1" Prec="-1" PrimaryKey="1" NotNull="1" AutoInc="0" IsForeignKey="1" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+</COLUMNS>
+<RELATIONS_END>
+<RELATION_END ID="1427" />
+<RELATION_END ID="1430" />
+</RELATIONS_END>
+<INDICES>
+<INDEX ID="1500" IndexName="PRIMARY" IndexKind="0" FKRefDef_Obj_id="-1">
+<INDEXCOLUMNS>
+<INDEXCOLUMN idColumn="1431" LengthParam="0" />
+<INDEXCOLUMN idColumn="1428" LengthParam="0" />
+</INDEXCOLUMNS>
+</INDEX>
+<INDEX ID="1429" IndexName="mb_user_mp_group_FKIndex1" IndexKind="1" FKRefDef_Obj_id="1427">
+<INDEXCOLUMNS>
+</INDEXCOLUMNS>
+</INDEX>
+<INDEX ID="1432" IndexName="mb_user_mp_group_FKIndex2" IndexKind="1" FKRefDef_Obj_id="1430">
+<INDEXCOLUMNS>
+</INDEXCOLUMNS>
+</INDEX>
+</INDICES>
+</TABLE>
+<TABLE ID="1438" Tablename="mb_user_wmc" PrevTableName="Table_14" XPos="509" YPos="833" TableType="1" TablePrefix="0" nmTable="0" Temporary="0" UseStandardInserts="0" StandardInserts="\n" TableOptions="DelayKeyTblUpdates=0\nPackKeys=0\nRowChecksum=0\nRowFormat=0\nUseRaid=0\nRaidType=0\n" Comments="" Collapsed="0" IsLinkedObject="0" IDLinkedModel="-1" Obj_id_Linked="-1" OrderPos="26" >
+<COLUMNS>
+<COLUMN ID="1440" ColName="wmc_id" PrevColName="" Pos="0" idDatatype="5" DatatypeParams="" Width="-1" Prec="-1" PrimaryKey="1" NotNull="1" AutoInc="1" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1443" ColName="fkey_mb_user_id" PrevColName="" Pos="1" idDatatype="5" DatatypeParams="" Width="-1" Prec="-1" PrimaryKey="0" NotNull="1" AutoInc="0" IsForeignKey="1" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1446" ColName="wmc" PrevColName="" Pos="2" idDatatype="28" DatatypeParams="" Width="-1" Prec="-1" PrimaryKey="0" NotNull="1" AutoInc="0" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1447" ColName="wmc_title" PrevColName="" Pos="3" idDatatype="20" DatatypeParams="(50)" Width="-1" Prec="-1" PrimaryKey="0" NotNull="0" AutoInc="0" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1448" ColName="wmc_timestamp" PrevColName="" Pos="4" idDatatype="5" DatatypeParams="" Width="-1" Prec="-1" PrimaryKey="0" NotNull="0" AutoInc="0" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+</COLUMNS>
+<RELATIONS_END>
+<RELATION_END ID="1442" />
+</RELATIONS_END>
+<INDICES>
+<INDEX ID="1441" IndexName="PRIMARY" IndexKind="0" FKRefDef_Obj_id="-1">
+<INDEXCOLUMNS>
+<INDEXCOLUMN idColumn="1440" LengthParam="0" />
+</INDEXCOLUMNS>
+</INDEX>
+<INDEX ID="1444" IndexName="mb_user_wmc_FKIndex1" IndexKind="1" FKRefDef_Obj_id="1442">
+<INDEXCOLUMNS>
+<INDEXCOLUMN idColumn="1443" LengthParam="0" />
+</INDEXCOLUMNS>
+</INDEX>
+</INDICES>
+</TABLE>
+<TABLE ID="1453" Tablename="layer" PrevTableName="Table_14" XPos="1725" YPos="638" TableType="1" TablePrefix="0" nmTable="0" Temporary="0" UseStandardInserts="0" StandardInserts="\n" TableOptions="DelayKeyTblUpdates=0\nPackKeys=0\nRowChecksum=0\nRowFormat=0\nUseRaid=0\nRaidType=0\n" Comments="" Collapsed="0" IsLinkedObject="0" IDLinkedModel="-1" Obj_id_Linked="-1" OrderPos="28" >
+<COLUMNS>
+<COLUMN ID="1455" ColName="layer_id" PrevColName="" Pos="0" idDatatype="5" DatatypeParams="" Width="-1" Prec="-1" PrimaryKey="1" NotNull="1" AutoInc="1" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1477" ColName="fkey_wms_id" PrevColName="" Pos="1" idDatatype="5" DatatypeParams="" Width="-1" Prec="-1" PrimaryKey="0" NotNull="1" AutoInc="0" IsForeignKey="1" DefaultValue="0" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1480" ColName="layer_pos" PrevColName="" Pos="2" idDatatype="5" DatatypeParams="" Width="-1" Prec="-1" PrimaryKey="0" NotNull="1" AutoInc="0" IsForeignKey="0" DefaultValue="0" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1481" ColName="layer_parent" PrevColName="" Pos="3" idDatatype="20" DatatypeParams="(50)" Width="-1" Prec="-1" PrimaryKey="0" NotNull="1" AutoInc="0" IsForeignKey="0" DefaultValue="\a\a" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1482" ColName="layer_name" PrevColName="" Pos="4" idDatatype="20" DatatypeParams="(255)" Width="-1" Prec="-1" PrimaryKey="0" NotNull="1" AutoInc="0" IsForeignKey="0" DefaultValue="\a\a" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1483" ColName="layer_title" PrevColName="" Pos="5" idDatatype="20" DatatypeParams="(255)" Width="-1" Prec="-1" PrimaryKey="0" NotNull="1" AutoInc="0" IsForeignKey="0" DefaultValue="\a\a" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1484" ColName="layer_queryable" PrevColName="" Pos="6" idDatatype="5" DatatypeParams="" Width="-1" Prec="-1" PrimaryKey="0" NotNull="1" AutoInc="0" IsForeignKey="0" DefaultValue="0" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1485" ColName="layer_minscale" PrevColName="" Pos="7" idDatatype="5" DatatypeParams="" Width="-1" Prec="-1" PrimaryKey="0" NotNull="0" AutoInc="0" IsForeignKey="0" DefaultValue="0" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1486" ColName="layer_maxscale" PrevColName="" Pos="8" idDatatype="5" DatatypeParams="" Width="-1" Prec="-1" PrimaryKey="0" NotNull="0" AutoInc="0" IsForeignKey="0" DefaultValue="0" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1487" ColName="layer_dataurl" PrevColName="" Pos="9" idDatatype="20" DatatypeParams="(255)" Width="-1" Prec="-1" PrimaryKey="0" NotNull="0" AutoInc="0" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1488" ColName="layer_metadataurl" PrevColName="" Pos="10" idDatatype="20" DatatypeParams="(255)" Width="-1" Prec="-1" PrimaryKey="0" NotNull="0" AutoInc="0" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1489" ColName="layer_abstract" PrevColName="" Pos="11" idDatatype="28" DatatypeParams="" Width="-1" Prec="-1" PrimaryKey="0" NotNull="0" AutoInc="0" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+</COLUMNS>
+<RELATIONS_START>
+<RELATION_START ID="1490" />
+<RELATION_START ID="1594" />
+<RELATION_START ID="1605" />
+<RELATION_START ID="1616" />
+</RELATIONS_START>
+<RELATIONS_END>
+<RELATION_END ID="1476" />
+</RELATIONS_END>
+<INDICES>
+<INDEX ID="1456" IndexName="PRIMARY" IndexKind="0" FKRefDef_Obj_id="-1">
+<INDEXCOLUMNS>
+<INDEXCOLUMN idColumn="1455" LengthParam="0" />
+</INDEXCOLUMNS>
+</INDEX>
+<INDEX ID="1478" IndexName="layer_FKIndex1" IndexKind="1" FKRefDef_Obj_id="1476">
+<INDEXCOLUMNS>
+<INDEXCOLUMN idColumn="1477" LengthParam="0" />
+</INDEXCOLUMNS>
+</INDEX>
+</INDICES>
+</TABLE>
+<TABLE ID="1458" Tablename="gui_wms" PrevTableName="Table_15" XPos="1274" YPos="463" TableType="1" TablePrefix="0" nmTable="0" Temporary="0" UseStandardInserts="0" StandardInserts="\n" TableOptions="DelayKeyTblUpdates=0\nPackKeys=0\nRowChecksum=0\nRowFormat=0\nUseRaid=0\nRaidType=0\n" Comments="" Collapsed="0" IsLinkedObject="0" IDLinkedModel="-1" Obj_id_Linked="-1" OrderPos="29" >
+<COLUMNS>
+<COLUMN ID="1472" ColName="fkey_wms_id" PrevColName="" Pos="1" idDatatype="5" DatatypeParams="" Width="-1" Prec="-1" PrimaryKey="1" NotNull="1" AutoInc="0" IsForeignKey="1" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1469" ColName="fkey_gui_id" PrevColName="" Pos="1" idDatatype="20" DatatypeParams="(50)" Width="-1" Prec="-1" PrimaryKey="1" NotNull="1" AutoInc="0" IsForeignKey="1" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+</COLUMNS>
+<RELATIONS_END>
+<RELATION_END ID="1468" />
+<RELATION_END ID="1471" />
+</RELATIONS_END>
+<INDICES>
+<INDEX ID="1461" IndexName="PRIMARY" IndexKind="0" FKRefDef_Obj_id="-1">
+<INDEXCOLUMNS>
+<INDEXCOLUMN idColumn="1472" LengthParam="0" />
+<INDEXCOLUMN idColumn="1469" LengthParam="0" />
+</INDEXCOLUMNS>
+</INDEX>
+<INDEX ID="1470" IndexName="gui_wms_FKIndex1" IndexKind="1" FKRefDef_Obj_id="1468">
+<INDEXCOLUMNS>
+</INDEXCOLUMNS>
+</INDEX>
+<INDEX ID="1473" IndexName="gui_wms_FKIndex2" IndexKind="1" FKRefDef_Obj_id="1471">
+<INDEXCOLUMNS>
+</INDEXCOLUMNS>
+</INDEX>
+</INDICES>
+</TABLE>
+<TABLE ID="1462" Tablename="wms" PrevTableName="Table_16" XPos="2172" YPos="327" TableType="1" TablePrefix="0" nmTable="0" Temporary="0" UseStandardInserts="0" StandardInserts="\n" TableOptions="DelayKeyTblUpdates=0\nPackKeys=0\nRowChecksum=0\nRowFormat=0\nUseRaid=0\nRaidType=0\n" Comments="" Collapsed="0" IsLinkedObject="0" IDLinkedModel="-1" Obj_id_Linked="-1" OrderPos="30" >
+<COLUMNS>
+<COLUMN ID="1464" ColName="wms_id" PrevColName="" Pos="0" idDatatype="5" DatatypeParams="" Width="-1" Prec="-1" PrimaryKey="1" NotNull="1" AutoInc="1" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1466" ColName="wms_version" PrevColName="" Pos="1" idDatatype="20" DatatypeParams="(50)" Width="-1" Prec="-1" PrimaryKey="0" NotNull="0" AutoInc="0" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1503" ColName="wms_title" PrevColName="" Pos="2" idDatatype="20" DatatypeParams="(255)" Width="-1" Prec="-1" PrimaryKey="0" NotNull="0" AutoInc="0" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1504" ColName="wms_abstract" PrevColName="" Pos="3" idDatatype="28" DatatypeParams="" Width="-1" Prec="-1" PrimaryKey="0" NotNull="0" AutoInc="0" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1505" ColName="wms_getcapabilities" PrevColName="" Pos="4" idDatatype="20" DatatypeParams="(255)" Width="-1" Prec="-1" PrimaryKey="0" NotNull="0" AutoInc="0" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1506" ColName="wms_getmap" PrevColName="" Pos="5" idDatatype="20" DatatypeParams="(255)" Width="-1" Prec="-1" PrimaryKey="0" NotNull="0" AutoInc="0" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1507" ColName="wms_getfeatureinfo" PrevColName="" Pos="6" idDatatype="20" DatatypeParams="(255)" Width="-1" Prec="-1" PrimaryKey="0" NotNull="0" AutoInc="0" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1508" ColName="wms_getlegendurl" PrevColName="" Pos="7" idDatatype="20" DatatypeParams="(255)" Width="-1" Prec="-1" PrimaryKey="0" NotNull="0" AutoInc="0" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1509" ColName="wms_filter" PrevColName="" Pos="8" idDatatype="20" DatatypeParams="(255)" Width="-1" Prec="-1" PrimaryKey="0" NotNull="0" AutoInc="0" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1510" ColName="wms_getcapabilities_doc" PrevColName="" Pos="9" idDatatype="28" DatatypeParams="" Width="-1" Prec="-1" PrimaryKey="0" NotNull="0" AutoInc="0" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1511" ColName="wms_owsproxy" PrevColName="" Pos="10" idDatatype="20" DatatypeParams="(50)" Width="-1" Prec="-1" PrimaryKey="0" NotNull="0" AutoInc="0" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1512" ColName="wms_upload_url" PrevColName="" Pos="11" idDatatype="20" DatatypeParams="(255)" Width="-1" Prec="-1" PrimaryKey="0" NotNull="0" AutoInc="0" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1513" ColName="fees" PrevColName="" Pos="12" idDatatype="20" DatatypeParams="(255)" Width="-1" Prec="-1" PrimaryKey="0" NotNull="0" AutoInc="0" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1514" ColName="accessconstraints" PrevColName="" Pos="13" idDatatype="28" DatatypeParams="" Width="-1" Prec="-1" PrimaryKey="0" NotNull="0" AutoInc="0" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1515" ColName="contactperson" PrevColName="" Pos="14" idDatatype="20" DatatypeParams="(255)" Width="-1" Prec="-1" PrimaryKey="0" NotNull="0" AutoInc="0" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1516" ColName="contactposition" PrevColName="" Pos="15" idDatatype="20" DatatypeParams="(255)" Width="-1" Prec="-1" PrimaryKey="0" NotNull="0" AutoInc="0" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1517" ColName="contactorganization" PrevColName="" Pos="16" idDatatype="20" DatatypeParams="(255)" Width="-1" Prec="-1" PrimaryKey="0" NotNull="0" AutoInc="0" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1518" ColName="address" PrevColName="" Pos="17" idDatatype="20" DatatypeParams="(255)" Width="-1" Prec="-1" PrimaryKey="0" NotNull="0" AutoInc="0" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1519" ColName="city" PrevColName="" Pos="18" idDatatype="20" DatatypeParams="(255)" Width="-1" Prec="-1" PrimaryKey="0" NotNull="0" AutoInc="0" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1520" ColName="stateorprovince" PrevColName="" Pos="19" idDatatype="20" DatatypeParams="(255)" Width="-1" Prec="-1" PrimaryKey="0" NotNull="0" AutoInc="0" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1521" ColName="postcode" PrevColName="" Pos="20" idDatatype="20" DatatypeParams="(255)" Width="-1" Prec="-1" PrimaryKey="0" NotNull="0" AutoInc="0" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1522" ColName="country" PrevColName="" Pos="21" idDatatype="20" DatatypeParams="(255)" Width="-1" Prec="-1" PrimaryKey="0" NotNull="0" AutoInc="0" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1523" ColName="contactvoicetelephone" PrevColName="" Pos="22" idDatatype="20" DatatypeParams="(255)" Width="-1" Prec="-1" PrimaryKey="0" NotNull="0" AutoInc="0" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1524" ColName="contactfacsimiletelephone" PrevColName="" Pos="23" idDatatype="20" DatatypeParams="(255)" Width="-1" Prec="-1" PrimaryKey="0" NotNull="0" AutoInc="0" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1525" ColName="contactelectronicmailaddress" PrevColName="" Pos="24" idDatatype="20" DatatypeParams="(255)" Width="-1" Prec="-1" PrimaryKey="0" NotNull="0" AutoInc="0" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1526" ColName="wms_mb_getcapabilies_doc" PrevColName="" Pos="25" idDatatype="28" DatatypeParams="" Width="-1" Prec="-1" PrimaryKey="0" NotNull="0" AutoInc="0" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1527" ColName="wms_owner" PrevColName="" Pos="26" idDatatype="5" DatatypeParams="" Width="-1" Prec="-1" PrimaryKey="0" NotNull="0" AutoInc="0" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1528" ColName="wms_timestamp" PrevColName="" Pos="27" idDatatype="5" DatatypeParams="" Width="-1" Prec="-1" PrimaryKey="0" NotNull="0" AutoInc="0" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+</COLUMNS>
+<RELATIONS_START>
+<RELATION_START ID="1471" />
+<RELATION_START ID="1476" />
+<RELATION_START ID="1533" />
+<RELATION_START ID="1544" />
+</RELATIONS_START>
+<INDICES>
+<INDEX ID="1465" IndexName="PRIMARY" IndexKind="0" FKRefDef_Obj_id="-1">
+<INDEXCOLUMNS>
+<INDEXCOLUMN idColumn="1464" LengthParam="0" />
+</INDEXCOLUMNS>
+</INDEX>
+</INDICES>
+</TABLE>
+<TABLE ID="1529" Tablename="wms_srs" PrevTableName="Table_17" XPos="2721" YPos="467" TableType="1" TablePrefix="0" nmTable="0" Temporary="0" UseStandardInserts="0" StandardInserts="\n" TableOptions="DelayKeyTblUpdates=0\nPackKeys=0\nRowChecksum=0\nRowFormat=0\nUseRaid=0\nRaidType=0\n" Comments="" Collapsed="0" IsLinkedObject="0" IDLinkedModel="-1" Obj_id_Linked="-1" OrderPos="35" >
+<COLUMNS>
+<COLUMN ID="1534" ColName="fkey_wms_id" PrevColName="" Pos="1" idDatatype="5" DatatypeParams="" Width="-1" Prec="-1" PrimaryKey="1" NotNull="1" AutoInc="0" IsForeignKey="1" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1531" ColName="wms_srs" PrevColName="" Pos="0" idDatatype="20" DatatypeParams="(50)" Width="-1" Prec="-1" PrimaryKey="1" NotNull="1" AutoInc="1" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+</COLUMNS>
+<RELATIONS_END>
+<RELATION_END ID="1533" />
+</RELATIONS_END>
+<INDICES>
+<INDEX ID="1532" IndexName="PRIMARY" IndexKind="0" FKRefDef_Obj_id="-1">
+<INDEXCOLUMNS>
+<INDEXCOLUMN idColumn="1534" LengthParam="0" />
+<INDEXCOLUMN idColumn="1531" LengthParam="0" />
+</INDEXCOLUMNS>
+</INDEX>
+<INDEX ID="1535" IndexName="wms_srs_FKIndex1" IndexKind="1" FKRefDef_Obj_id="1533">
+<INDEXCOLUMNS>
+</INDEXCOLUMNS>
+</INDEX>
+</INDICES>
+</TABLE>
+<TABLE ID="1539" Tablename="wms_format" PrevTableName="Table_18" XPos="2730" YPos="624" TableType="1" TablePrefix="0" nmTable="0" Temporary="0" UseStandardInserts="0" StandardInserts="\n" TableOptions="DelayKeyTblUpdates=0\nPackKeys=0\nRowChecksum=0\nRowFormat=0\nUseRaid=0\nRaidType=0\n" Comments="" Collapsed="0" IsLinkedObject="0" IDLinkedModel="-1" Obj_id_Linked="-1" OrderPos="37" >
+<COLUMNS>
+<COLUMN ID="1545" ColName="fkey_wms_id" PrevColName="" Pos="1" idDatatype="5" DatatypeParams="" Width="-1" Prec="-1" PrimaryKey="1" NotNull="1" AutoInc="0" IsForeignKey="1" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1541" ColName="data_type" PrevColName="" Pos="0" idDatatype="20" DatatypeParams="(50)" Width="-1" Prec="-1" PrimaryKey="1" NotNull="1" AutoInc="1" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1543" ColName="data_format" PrevColName="" Pos="1" idDatatype="20" DatatypeParams="(50)" Width="-1" Prec="-1" PrimaryKey="1" NotNull="1" AutoInc="0" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+</COLUMNS>
+<RELATIONS_END>
+<RELATION_END ID="1544" />
+</RELATIONS_END>
+<INDICES>
+<INDEX ID="1542" IndexName="PRIMARY" IndexKind="0" FKRefDef_Obj_id="-1">
+<INDEXCOLUMNS>
+<INDEXCOLUMN idColumn="1545" LengthParam="0" />
+<INDEXCOLUMN idColumn="1541" LengthParam="0" />
+<INDEXCOLUMN idColumn="1543" LengthParam="0" />
+</INDEXCOLUMNS>
+</INDEX>
+<INDEX ID="1546" IndexName="wms_format_FKIndex1" IndexKind="1" FKRefDef_Obj_id="1544">
+<INDEXCOLUMNS>
+</INDEXCOLUMNS>
+</INDEX>
+</INDICES>
+</TABLE>
+<TABLE ID="1550" Tablename="wms_md_topic_category" PrevTableName="Table_19" XPos="2508" YPos="331" TableType="1" TablePrefix="0" nmTable="0" Temporary="0" UseStandardInserts="0" StandardInserts="\n" TableOptions="DelayKeyTblUpdates=0\nPackKeys=0\nRowChecksum=0\nRowFormat=0\nUseRaid=0\nRaidType=0\n" Comments="" Collapsed="0" IsLinkedObject="0" IDLinkedModel="-1" Obj_id_Linked="-1" OrderPos="39" >
+<COLUMNS>
+<COLUMN ID="1578" ColName="md_topic_category_id" PrevColName="" Pos="0" idDatatype="5" DatatypeParams="" Width="-1" Prec="-1" PrimaryKey="1" NotNull="1" AutoInc="1" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1580" ColName="md_topic_category_code_en" PrevColName="" Pos="1" idDatatype="20" DatatypeParams="(255)" Width="-1" Prec="-1" PrimaryKey="0" NotNull="0" AutoInc="0" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1581" ColName="md_topic_category_code_de" PrevColName="" Pos="2" idDatatype="20" DatatypeParams="(255)" Width="-1" Prec="-1" PrimaryKey="0" NotNull="0" AutoInc="0" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+</COLUMNS>
+<INDICES>
+<INDEX ID="1579" IndexName="PRIMARY" IndexKind="0" FKRefDef_Obj_id="-1">
+<INDEXCOLUMNS>
+<INDEXCOLUMN idColumn="1578" LengthParam="0" />
+</INDEXCOLUMNS>
+</INDEX>
+</INDICES>
+</TABLE>
+<TABLE ID="1554" Tablename="mb_log" PrevTableName="Table_20" XPos="382" YPos="1521" TableType="1" TablePrefix="0" nmTable="0" Temporary="0" UseStandardInserts="0" StandardInserts="\n" TableOptions="DelayKeyTblUpdates=0\nPackKeys=0\nRowChecksum=0\nRowFormat=0\nUseRaid=0\nRaidType=0\n" Comments="" Collapsed="0" IsLinkedObject="0" IDLinkedModel="-1" Obj_id_Linked="-1" OrderPos="40" >
+<COLUMNS>
+</COLUMNS>
+</TABLE>
+<TABLE ID="1556" Tablename="mb_monitor" PrevTableName="Table_21" XPos="2208" YPos="187" TableType="1" TablePrefix="0" nmTable="0" Temporary="0" UseStandardInserts="0" StandardInserts="\n" TableOptions="DelayKeyTblUpdates=0\nPackKeys=0\nRowChecksum=0\nRowFormat=0\nUseRaid=0\nRaidType=0\n" Comments="" Collapsed="0" IsLinkedObject="0" IDLinkedModel="-1" Obj_id_Linked="-1" OrderPos="41" >
+<COLUMNS>
+</COLUMNS>
+</TABLE>
+<TABLE ID="1558" Tablename="keyword" PrevTableName="Table_22" XPos="2126" YPos="1190" TableType="1" TablePrefix="0" nmTable="0" Temporary="0" UseStandardInserts="0" StandardInserts="\n" TableOptions="DelayKeyTblUpdates=0\nPackKeys=0\nRowChecksum=0\nRowFormat=0\nUseRaid=0\nRaidType=0\n" Comments="" Collapsed="0" IsLinkedObject="0" IDLinkedModel="-1" Obj_id_Linked="-1" OrderPos="42" >
+<COLUMNS>
+<COLUMN ID="1583" ColName="keyword_id" PrevColName="" Pos="0" idDatatype="5" DatatypeParams="" Width="-1" Prec="-1" PrimaryKey="1" NotNull="1" AutoInc="1" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1585" ColName="keyword" PrevColName="" Pos="1" idDatatype="20" DatatypeParams="(255)" Width="-1" Prec="-1" PrimaryKey="0" NotNull="0" AutoInc="0" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+</COLUMNS>
+<RELATIONS_START>
+<RELATION_START ID="1591" />
+</RELATIONS_START>
+<INDICES>
+<INDEX ID="1584" IndexName="PRIMARY" IndexKind="0" FKRefDef_Obj_id="-1">
+<INDEXCOLUMNS>
+<INDEXCOLUMN idColumn="1583" LengthParam="0" />
+</INDEXCOLUMNS>
+</INDEX>
+</INDICES>
+</TABLE>
+<TABLE ID="1560" Tablename="layer_epsg" PrevTableName="Table_23" XPos="1533" YPos="1010" TableType="1" TablePrefix="0" nmTable="0" Temporary="0" UseStandardInserts="0" StandardInserts="\n" TableOptions="DelayKeyTblUpdates=0\nPackKeys=0\nRowChecksum=0\nRowFormat=0\nUseRaid=0\nRaidType=0\n" Comments="" Collapsed="0" IsLinkedObject="0" IDLinkedModel="-1" Obj_id_Linked="-1" OrderPos="43" >
+<COLUMNS>
+<COLUMN ID="1617" ColName="fkey_layer_id" PrevColName="" Pos="1" idDatatype="5" DatatypeParams="" Width="-1" Prec="-1" PrimaryKey="1" NotNull="1" AutoInc="0" IsForeignKey="1" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1610" ColName="epsg" PrevColName="" Pos="0" idDatatype="20" DatatypeParams="(50)" Width="-1" Prec="-1" PrimaryKey="1" NotNull="1" AutoInc="1" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1612" ColName="minx" PrevColName="" Pos="1" idDatatype="9" DatatypeParams="" Width="-1" Prec="-1" PrimaryKey="0" NotNull="0" AutoInc="0" IsForeignKey="0" DefaultValue="0" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1613" ColName="miny" PrevColName="" Pos="2" idDatatype="9" DatatypeParams="" Width="-1" Prec="-1" PrimaryKey="0" NotNull="0" AutoInc="0" IsForeignKey="0" DefaultValue="0" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1614" ColName="maxx" PrevColName="" Pos="3" idDatatype="9" DatatypeParams="" Width="-1" Prec="-1" PrimaryKey="0" NotNull="0" AutoInc="0" IsForeignKey="0" DefaultValue="0" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1615" ColName="maxy" PrevColName="" Pos="4" idDatatype="9" DatatypeParams="" Width="-1" Prec="-1" PrimaryKey="0" NotNull="0" AutoInc="0" IsForeignKey="0" DefaultValue="0" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+</COLUMNS>
+<RELATIONS_END>
+<RELATION_END ID="1616" />
+</RELATIONS_END>
+<INDICES>
+<INDEX ID="1611" IndexName="PRIMARY" IndexKind="0" FKRefDef_Obj_id="-1">
+<INDEXCOLUMNS>
+<INDEXCOLUMN idColumn="1617" LengthParam="0" />
+<INDEXCOLUMN idColumn="1610" LengthParam="0" />
+</INDEXCOLUMNS>
+</INDEX>
+<INDEX ID="1618" IndexName="layer_epsg_FKIndex1" IndexKind="1" FKRefDef_Obj_id="1616">
+<INDEXCOLUMNS>
+</INDEXCOLUMNS>
+</INDEX>
+</INDICES>
+</TABLE>
+<TABLE ID="1562" Tablename="layer_keyword" PrevTableName="Table_24" XPos="2108" YPos="977" TableType="1" TablePrefix="0" nmTable="0" Temporary="0" UseStandardInserts="0" StandardInserts="\n" TableOptions="DelayKeyTblUpdates=0\nPackKeys=0\nRowChecksum=0\nRowFormat=0\nUseRaid=0\nRaidType=0\n" Comments="" Collapsed="0" IsLinkedObject="0" IDLinkedModel="-1" Obj_id_Linked="-1" OrderPos="44" >
+<COLUMNS>
+<COLUMN ID="1595" ColName="fkey_layer_id" PrevColName="" Pos="1" idDatatype="5" DatatypeParams="" Width="-1" Prec="-1" PrimaryKey="1" NotNull="1" AutoInc="0" IsForeignKey="1" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1592" ColName="fkey_keyword_id" PrevColName="" Pos="1" idDatatype="5" DatatypeParams="" Width="-1" Prec="-1" PrimaryKey="1" NotNull="1" AutoInc="0" IsForeignKey="1" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1588" ColName="idlayer_keyword" PrevColName="" Pos="0" idDatatype="5" DatatypeParams="" Width="-1" Prec="-1" PrimaryKey="0" NotNull="1" AutoInc="1" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+</COLUMNS>
+<RELATIONS_END>
+<RELATION_END ID="1591" />
+<RELATION_END ID="1594" />
+</RELATIONS_END>
+<INDICES>
+<INDEX ID="1589" IndexName="PRIMARY" IndexKind="0" FKRefDef_Obj_id="-1">
+<INDEXCOLUMNS>
+<INDEXCOLUMN idColumn="1595" LengthParam="0" />
+<INDEXCOLUMN idColumn="1592" LengthParam="0" />
+</INDEXCOLUMNS>
+</INDEX>
+<INDEX ID="1593" IndexName="layer_keyword_FKIndex1" IndexKind="1" FKRefDef_Obj_id="1591">
+<INDEXCOLUMNS>
+</INDEXCOLUMNS>
+</INDEX>
+<INDEX ID="1596" IndexName="layer_keyword_FKIndex2" IndexKind="1" FKRefDef_Obj_id="1594">
+<INDEXCOLUMNS>
+</INDEXCOLUMNS>
+</INDEX>
+</INDICES>
+</TABLE>
+<TABLE ID="1564" Tablename="layer_style" PrevTableName="Table_25" XPos="1771" YPos="1008" TableType="1" TablePrefix="0" nmTable="0" Temporary="0" UseStandardInserts="0" StandardInserts="\n" TableOptions="DelayKeyTblUpdates=0\nPackKeys=0\nRowChecksum=0\nRowFormat=0\nUseRaid=0\nRaidType=0\n" Comments="" Collapsed="0" IsLinkedObject="0" IDLinkedModel="-1" Obj_id_Linked="-1" OrderPos="45" >
+<COLUMNS>
+<COLUMN ID="1606" ColName="fkey_layer_id" PrevColName="" Pos="1" idDatatype="5" DatatypeParams="" Width="-1" Prec="-1" PrimaryKey="1" NotNull="1" AutoInc="0" IsForeignKey="1" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1598" ColName="name" PrevColName="" Pos="0" idDatatype="20" DatatypeParams="(50)" Width="-1" Prec="-1" PrimaryKey="1" NotNull="1" AutoInc="1" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1602" ColName="title" PrevColName="" Pos="1" idDatatype="20" DatatypeParams="(100)" Width="-1" Prec="-1" PrimaryKey="0" NotNull="0" AutoInc="0" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1603" ColName="legendurl" PrevColName="" Pos="2" idDatatype="20" DatatypeParams="(255)" Width="-1" Prec="-1" PrimaryKey="0" NotNull="0" AutoInc="0" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+</OPTIONSELECTED>
+</COLUMN>
+<COLUMN ID="1604" ColName="legendurlformat" PrevColName="" Pos="3" idDatatype="20" DatatypeParams="(50)" Width="-1" Prec="-1" PrimaryKey="0" NotNull="0" AutoInc="0" IsForeignKey="0" DefaultValue="" Comments="">
+<OPTIONSELECTED>
+<OPTIONSELECT Value="0" />
+</OPTIONSELECTED>
+</COLUMN>
+</COLUMNS>
+<RELATIONS_END>
+<RELATION_END ID="1605" />
+</RELATIONS_END>
+<INDICES>
+<INDEX ID="1599" IndexName="PRIMARY" IndexKind="0" FKRefDef_Obj_id="-1">
+<INDEXCOLUMNS>
+<INDEXCOLUMN idColumn="1606" LengthParam="0" />
+<INDEXCOLUMN idColumn="1598" LengthParam="0" />
+</INDEXCOLUMNS>
+</INDEX>
+<INDEX ID="1607" IndexName="layer_style_FKIndex1" IndexKind="1" FKRefDef_Obj_id="1605">
+<INDEXCOLUMNS>
+</INDEXCOLUMNS>
+</INDEX>
+</INDICES>
+</TABLE>
+<TABLE ID="1566" Tablename="wfs_conf" PrevTableName="Table_26" XPos="1192" YPos="181" TableType="1" TablePrefix="0" nmTable="0" Temporary="0" UseStandardInserts="0" StandardInserts="\n" TableOptions="DelayKeyTblUpdates=0\nPackKeys=0\nRowChecksum=0\nRowFormat=0\nUseRaid=0\nRaidType=0\n" Comments="" Collapsed="0" IsLinkedObject="0" IDLinkedModel="-1" Obj_id_Linked="-1" OrderPos="46" >
+<COLUMNS>
+</COLUMNS>
+</TABLE>
+<TABLE ID="1568" Tablename="wfs_conf_element" PrevTableName="Table_27" XPos="1306" YPos="183" TableType="1" TablePrefix="0" nmTable="0" Temporary="0" UseStandardInserts="0" StandardInserts="\n" TableOptions="DelayKeyTblUpdates=0\nPackKeys=0\nRowChecksum=0\nRowFormat=0\nUseRaid=0\nRaidType=0\n" Comments="" Collapsed="0" IsLinkedObject="0" IDLinkedModel="-1" Obj_id_Linked="-1" OrderPos="47" >
+<COLUMNS>
+</COLUMNS>
+</TABLE>
+<TABLE ID="1570" Tablename="wfs_element" PrevTableName="Table_28" XPos="1456" YPos="187" TableType="1" TablePrefix="0" nmTable="0" Temporary="0" UseStandardInserts="0" StandardInserts="\n" TableOptions="DelayKeyTblUpdates=0\nPackKeys=0\nRowChecksum=0\nRowFormat=0\nUseRaid=0\nRaidType=0\n" Comments="" Collapsed="0" IsLinkedObject="0" IDLinkedModel="-1" Obj_id_Linked="-1" OrderPos="48" >
+<COLUMNS>
+</COLUMNS>
+</TABLE>
+<TABLE ID="1572" Tablename="wfs_featuretype" PrevTableName="Table_29" XPos="1575" YPos="190" TableType="1" TablePrefix="0" nmTable="0" Temporary="0" UseStandardInserts="0" StandardInserts="\n" TableOptions="DelayKeyTblUpdates=0\nPackKeys=0\nRowChecksum=0\nRowFormat=0\nUseRaid=0\nRaidType=0\n" Comments="" Collapsed="0" IsLinkedObject="0" IDLinkedModel="-1" Obj_id_Linked="-1" OrderPos="49" >
+<COLUMNS>
+</COLUMNS>
+</TABLE>
+<TABLE ID="1574" Tablename="wfs_featuretype_namespace" PrevTableName="Table_30" XPos="1713" YPos="187" TableType="1" TablePrefix="0" nmTable="0" Temporary="0" UseStandardInserts="0" StandardInserts="\n" TableOptions="DelayKeyTblUpdates=0\nPackKeys=0\nRowChecksum=0\nRowFormat=0\nUseRaid=0\nRaidType=0\n" Comments="" Collapsed="0" IsLinkedObject="0" IDLinkedModel="-1" Obj_id_Linked="-1" OrderPos="50" >
+<COLUMNS>
+</COLUMNS>
+</TABLE>
+</TABLES>
+<RELATIONS>
+<RELATION ID="1207" RelationName="Rel_01" Kind="2" SrcTable="1194" DestTable="1201" FKFields="gui_id=fkey_gui_id\n" FKFieldsComments="\n" relDirection="3" MidOffset="0" OptionalStart="0" OptionalEnd="0" CaptionOffsetX="0" CaptionOffsetY="0" StartIntervalOffsetX="0" StartIntervalOffsetY="0" EndIntervalOffsetX="0" EndIntervalOffsetY="0" CreateRefDef="1" Invisible="0" RefDef="Matching=0\nOnDelete=3\nOnUpdate=3\n" Comments="" FKRefDefIndex_Obj_id="1209" Splitted="0" IsLinkedObject="0" IDLinkedModel="-1" Obj_id_Linked="-1" OrderPos="5" />
+<RELATION ID="1240" RelationName="Rel_02" Kind="2" SrcTable="1194" DestTable="1229" FKFields="gui_id=fkey_gui_id\n" FKFieldsComments="\n" relDirection="1" MidOffset="23" OptionalStart="0" OptionalEnd="0" CaptionOffsetX="0" CaptionOffsetY="0" StartIntervalOffsetX="0" StartIntervalOffsetY="0" EndIntervalOffsetX="0" EndIntervalOffsetY="0" CreateRefDef="1" Invisible="0" RefDef="Matching=0\nOnDelete=3\nOnUpdate=3\n" Comments="" FKRefDefIndex_Obj_id="1242" Splitted="0" IsLinkedObject="0" IDLinkedModel="-1" Obj_id_Linked="-1" OrderPos="9" />
+<RELATION ID="1243" RelationName="Rel_03" Kind="2" SrcTable="1216" DestTable="1229" FKFields="wfs_id=fkey_wfs_id\n" FKFieldsComments="\n" relDirection="4" MidOffset="0" OptionalStart="0" OptionalEnd="0" CaptionOffsetX="0" CaptionOffsetY="0" StartIntervalOffsetX="0" StartIntervalOffsetY="0" EndIntervalOffsetX="0" EndIntervalOffsetY="0" CreateRefDef="1" Invisible="0" RefDef="Matching=0\nOnDelete=3\nOnUpdate=3\n" Comments="" FKRefDefIndex_Obj_id="1245" Splitted="0" IsLinkedObject="0" IDLinkedModel="-1" Obj_id_Linked="-1" OrderPos="10" />
+<RELATION ID="1287" RelationName="Rel_05" Kind="2" SrcTable="1201" DestTable="1247" FKFields="e_id=fkey_e_id\nfkey_gui_id=fkey_fkey_gui_id\n" FKFieldsComments="\n\n" relDirection="3" MidOffset="0" OptionalStart="0" OptionalEnd="0" CaptionOffsetX="0" CaptionOffsetY="0" StartIntervalOffsetX="0" StartIntervalOffsetY="0" EndIntervalOffsetX="0" EndIntervalOffsetY="0" CreateRefDef="1" Invisible="0" RefDef="Matching=0\nOnDelete=3\nOnUpdate=3\n" Comments="" FKRefDefIndex_Obj_id="1289" Splitted="0" IsLinkedObject="0" IDLinkedModel="-1" Obj_id_Linked="-1" OrderPos="12" />
+<RELATION ID="1341" RelationName="Rel_08" Kind="2" SrcTable="1194" DestTable="1337" FKFields="gui_id=fkey_gui_id\n" FKFieldsComments="\n" relDirection="4" MidOffset="0" OptionalStart="0" OptionalEnd="0" CaptionOffsetX="0" CaptionOffsetY="0" StartIntervalOffsetX="0" StartIntervalOffsetY="0" EndIntervalOffsetX="0" EndIntervalOffsetY="0" CreateRefDef="1" Invisible="0" RefDef="Matching=0\nOnDelete=3\nOnUpdate=3\n" Comments="" FKRefDefIndex_Obj_id="1343" Splitted="0" IsLinkedObject="0" IDLinkedModel="-1" Obj_id_Linked="-1" OrderPos="16" />
+<RELATION ID="1353" RelationName="Rel_09" Kind="2" SrcTable="1194" DestTable="1296" FKFields="gui_id=fkey_gui_id\n" FKFieldsComments="\n" relDirection="2" MidOffset="0" OptionalStart="0" OptionalEnd="0" CaptionOffsetX="0" CaptionOffsetY="0" StartIntervalOffsetX="0" StartIntervalOffsetY="0" EndIntervalOffsetX="0" EndIntervalOffsetY="0" CreateRefDef="1" Invisible="0" RefDef="Matching=0\nOnDelete=3\nOnUpdate=3\n" Comments="" FKRefDefIndex_Obj_id="1355" Splitted="0" IsLinkedObject="0" IDLinkedModel="-1" Obj_id_Linked="-1" OrderPos="15" />
+<RELATION ID="1361" RelationName="Rel_10" Kind="2" SrcTable="1194" DestTable="1356" FKFields="gui_id=fkey_gui_id\n" FKFieldsComments="\n" relDirection="4" MidOffset="0" OptionalStart="0" OptionalEnd="0" CaptionOffsetX="0" CaptionOffsetY="0" StartIntervalOffsetX="0" StartIntervalOffsetY="0" EndIntervalOffsetX="0" EndIntervalOffsetY="0" CreateRefDef="1" Invisible="0" RefDef="Matching=0\nOnDelete=3\nOnUpdate=3\n" Comments="" FKRefDefIndex_Obj_id="1363" Splitted="0" IsLinkedObject="0" IDLinkedModel="-1" Obj_id_Linked="-1" OrderPos="16" />
+<RELATION ID="1369" RelationName="Rel_11" Kind="2" SrcTable="1194" DestTable="1365" FKFields="gui_id=fkey_gui_id\n" FKFieldsComments="\n" relDirection="3" MidOffset="0" OptionalStart="0" OptionalEnd="0" CaptionOffsetX="0" CaptionOffsetY="0" StartIntervalOffsetX="0" StartIntervalOffsetY="0" EndIntervalOffsetX="0" EndIntervalOffsetY="0" CreateRefDef="1" Invisible="0" RefDef="Matching=0\nOnDelete=3\nOnUpdate=3\n" Comments="" FKRefDefIndex_Obj_id="1371" Splitted="0" IsLinkedObject="0" IDLinkedModel="-1" Obj_id_Linked="-1" OrderPos="18" />
+<RELATION ID="1397" RelationName="Rel_12" Kind="2" SrcTable="1374" DestTable="1356" FKFields="mb_user_id=fkey_mb_user_id\n" FKFieldsComments="\n" relDirection="1" MidOffset="0" OptionalStart="0" OptionalEnd="0" CaptionOffsetX="0" CaptionOffsetY="0" StartIntervalOffsetX="0" StartIntervalOffsetY="0" EndIntervalOffsetX="0" EndIntervalOffsetY="0" CreateRefDef="1" Invisible="0" RefDef="Matching=0\nOnDelete=3\nOnUpdate=3\n" Comments="" FKRefDefIndex_Obj_id="1399" Splitted="0" IsLinkedObject="0" IDLinkedModel="-1" Obj_id_Linked="-1" OrderPos="20" />
+<RELATION ID="1409" RelationName="Rel_13" Kind="2" SrcTable="1402" DestTable="1365" FKFields="mb_group_id=fkey_mb_group_id\n" FKFieldsComments="\n" relDirection="1" MidOffset="0" OptionalStart="0" OptionalEnd="0" CaptionOffsetX="0" CaptionOffsetY="0" StartIntervalOffsetX="0" StartIntervalOffsetY="0" EndIntervalOffsetX="0" EndIntervalOffsetY="0" CreateRefDef="1" Invisible="0" RefDef="Matching=0\nOnDelete=3\nOnUpdate=3\n" Comments="" FKRefDefIndex_Obj_id="1411" Splitted="0" IsLinkedObject="0" IDLinkedModel="-1" Obj_id_Linked="-1" OrderPos="22" />
+<RELATION ID="1427" RelationName="Rel_16" Kind="2" SrcTable="1402" DestTable="1412" FKFields="mb_group_id=fkey_mb_group_id\n" FKFieldsComments="\n" relDirection="4" MidOffset="0" OptionalStart="0" OptionalEnd="0" CaptionOffsetX="0" CaptionOffsetY="0" StartIntervalOffsetX="0" StartIntervalOffsetY="0" EndIntervalOffsetX="0" EndIntervalOffsetY="0" CreateRefDef="1" Invisible="0" RefDef="Matching=0\nOnDelete=3\nOnUpdate=3\n" Comments="" FKRefDefIndex_Obj_id="1429" Splitted="0" IsLinkedObject="0" IDLinkedModel="-1" Obj_id_Linked="-1" OrderPos="24" />
+<RELATION ID="1430" RelationName="Rel_17" Kind="2" SrcTable="1374" DestTable="1412" FKFields="mb_user_id=fkey_mb_user_id\n" FKFieldsComments="\n" relDirection="3" MidOffset="0" OptionalStart="0" OptionalEnd="0" CaptionOffsetX="0" CaptionOffsetY="0" StartIntervalOffsetX="0" StartIntervalOffsetY="0" EndIntervalOffsetX="0" EndIntervalOffsetY="0" CreateRefDef="1" Invisible="0" RefDef="Matching=0\nOnDelete=3\nOnUpdate=3\n" Comments="" FKRefDefIndex_Obj_id="1432" Splitted="0" IsLinkedObject="0" IDLinkedModel="-1" Obj_id_Linked="-1" OrderPos="25" />
+<RELATION ID="1442" RelationName="Rel_14" Kind="2" SrcTable="1374" DestTable="1438" FKFields="mb_user_id=fkey_mb_user_id\n" FKFieldsComments="\n" relDirection="2" MidOffset="0" OptionalStart="0" OptionalEnd="0" CaptionOffsetX="0" CaptionOffsetY="0" StartIntervalOffsetX="0" StartIntervalOffsetY="0" EndIntervalOffsetX="0" EndIntervalOffsetY="0" CreateRefDef="1" Invisible="0" RefDef="Matching=0\nOnDelete=3\nOnUpdate=3\n" Comments="" FKRefDefIndex_Obj_id="1444" Splitted="0" IsLinkedObject="0" IDLinkedModel="-1" Obj_id_Linked="-1" OrderPos="27" />
+<RELATION ID="1468" RelationName="Rel_14" Kind="2" SrcTable="1194" DestTable="1458" FKFields="gui_id=fkey_gui_id\n" FKFieldsComments="\n" relDirection="2" MidOffset="0" OptionalStart="0" OptionalEnd="0" CaptionOffsetX="0" CaptionOffsetY="0" StartIntervalOffsetX="0" StartIntervalOffsetY="0" EndIntervalOffsetX="0" EndIntervalOffsetY="0" CreateRefDef="1" Invisible="0" RefDef="Matching=0\nOnDelete=3\nOnUpdate=3\n" Comments="" FKRefDefIndex_Obj_id="1470" Splitted="0" IsLinkedObject="0" IDLinkedModel="-1" Obj_id_Linked="-1" OrderPos="31" />
+<RELATION ID="1471" RelationName="Rel_15" Kind="2" SrcTable="1462" DestTable="1458" FKFields="wms_id=fkey_wms_id\n" FKFieldsComments="\n" relDirection="4" MidOffset="0" OptionalStart="0" OptionalEnd="0" CaptionOffsetX="0" CaptionOffsetY="0" StartIntervalOffsetX="0" StartIntervalOffsetY="0" EndIntervalOffsetX="0" EndIntervalOffsetY="0" CreateRefDef="1" Invisible="0" RefDef="Matching=0\nOnDelete=3\nOnUpdate=3\n" Comments="" FKRefDefIndex_Obj_id="1473" Splitted="0" IsLinkedObject="0" IDLinkedModel="-1" Obj_id_Linked="-1" OrderPos="32" />
+<RELATION ID="1476" RelationName="Rel_16" Kind="2" SrcTable="1462" DestTable="1453" FKFields="wms_id=fkey_wms_id\n" FKFieldsComments="\n" relDirection="4" MidOffset="0" OptionalStart="0" OptionalEnd="0" CaptionOffsetX="0" CaptionOffsetY="0" StartIntervalOffsetX="0" StartIntervalOffsetY="0" EndIntervalOffsetX="0" EndIntervalOffsetY="0" CreateRefDef="1" Invisible="0" RefDef="Matching=0\nOnDelete=3\nOnUpdate=3\n" Comments="" FKRefDefIndex_Obj_id="1478" Splitted="0" IsLinkedObject="0" IDLinkedModel="-1" Obj_id_Linked="-1" OrderPos="33" />
+<RELATION ID="1490" RelationName="Rel_17" Kind="2" SrcTable="1453" DestTable="1296" FKFields="layer_id=fkey_layer_id\n" FKFieldsComments="\n" relDirection="4" MidOffset="0" OptionalStart="0" OptionalEnd="0" CaptionOffsetX="0" CaptionOffsetY="0" StartIntervalOffsetX="0" StartIntervalOffsetY="0" EndIntervalOffsetX="0" EndIntervalOffsetY="0" CreateRefDef="1" Invisible="0" RefDef="Matching=0\nOnDelete=3\nOnUpdate=3\n" Comments="" FKRefDefIndex_Obj_id="1492" Splitted="0" IsLinkedObject="0" IDLinkedModel="-1" Obj_id_Linked="-1" OrderPos="34" />
+<RELATION ID="1533" RelationName="Rel_18" Kind="2" SrcTable="1462" DestTable="1529" FKFields="wms_id=fkey_wms_id\n" FKFieldsComments="\n" relDirection="2" MidOffset="0" OptionalStart="0" OptionalEnd="0" CaptionOffsetX="0" CaptionOffsetY="0" StartIntervalOffsetX="0" StartIntervalOffsetY="0" EndIntervalOffsetX="0" EndIntervalOffsetY="0" CreateRefDef="1" Invisible="0" RefDef="Matching=0\nOnDelete=3\nOnUpdate=3\n" Comments="" FKRefDefIndex_Obj_id="1535" Splitted="0" IsLinkedObject="0" IDLinkedModel="-1" Obj_id_Linked="-1" OrderPos="36" />
+<RELATION ID="1544" RelationName="Rel_19" Kind="2" SrcTable="1462" DestTable="1539" FKFields="wms_id=fkey_wms_id\n" FKFieldsComments="\n" relDirection="2" MidOffset="0" OptionalStart="0" OptionalEnd="0" CaptionOffsetX="0" CaptionOffsetY="0" StartIntervalOffsetX="0" StartIntervalOffsetY="0" EndIntervalOffsetX="0" EndIntervalOffsetY="0" CreateRefDef="1" Invisible="0" RefDef="Matching=0\nOnDelete=3\nOnUpdate=3\n" Comments="" FKRefDefIndex_Obj_id="1546" Splitted="0" IsLinkedObject="0" IDLinkedModel="-1" Obj_id_Linked="-1" OrderPos="38" />
+<RELATION ID="1591" RelationName="Rel_20" Kind="2" SrcTable="1558" DestTable="1562" FKFields="keyword_id=fkey_keyword_id\n" FKFieldsComments="\n" relDirection="1" MidOffset="0" OptionalStart="0" OptionalEnd="0" CaptionOffsetX="0" CaptionOffsetY="0" StartIntervalOffsetX="0" StartIntervalOffsetY="0" EndIntervalOffsetX="0" EndIntervalOffsetY="0" CreateRefDef="1" Invisible="0" RefDef="Matching=0\nOnDelete=3\nOnUpdate=3\n" Comments="" FKRefDefIndex_Obj_id="1593" Splitted="0" IsLinkedObject="0" IDLinkedModel="-1" Obj_id_Linked="-1" OrderPos="51" />
+<RELATION ID="1594" RelationName="Rel_21" Kind="2" SrcTable="1453" DestTable="1562" FKFields="layer_id=fkey_layer_id\n" FKFieldsComments="\n" relDirection="2" MidOffset="0" OptionalStart="0" OptionalEnd="0" CaptionOffsetX="0" CaptionOffsetY="0" StartIntervalOffsetX="0" StartIntervalOffsetY="0" EndIntervalOffsetX="0" EndIntervalOffsetY="0" CreateRefDef="1" Invisible="0" RefDef="Matching=0\nOnDelete=3\nOnUpdate=3\n" Comments="" FKRefDefIndex_Obj_id="1596" Splitted="0" IsLinkedObject="0" IDLinkedModel="-1" Obj_id_Linked="-1" OrderPos="52" />
+<RELATION ID="1605" RelationName="Rel_22" Kind="2" SrcTable="1453" DestTable="1564" FKFields="layer_id=fkey_layer_id\n" FKFieldsComments="\n" relDirection="3" MidOffset="0" OptionalStart="0" OptionalEnd="0" CaptionOffsetX="0" CaptionOffsetY="0" StartIntervalOffsetX="0" StartIntervalOffsetY="0" EndIntervalOffsetX="0" EndIntervalOffsetY="0" CreateRefDef="1" Invisible="0" RefDef="Matching=0\nOnDelete=3\nOnUpdate=3\n" Comments="" FKRefDefIndex_Obj_id="1607" Splitted="0" IsLinkedObject="0" IDLinkedModel="-1" Obj_id_Linked="-1" OrderPos="53" />
+<RELATION ID="1616" RelationName="Rel_23" Kind="2" SrcTable="1453" DestTable="1560" FKFields="layer_id=fkey_layer_id\n" FKFieldsComments="\n" relDirection="3" MidOffset="0" OptionalStart="0" OptionalEnd="0" CaptionOffsetX="0" CaptionOffsetY="0" StartIntervalOffsetX="0" StartIntervalOffsetY="0" EndIntervalOffsetX="0" EndIntervalOffsetY="0" CreateRefDef="1" Invisible="0" RefDef="Matching=0\nOnDelete=3\nOnUpdate=3\n" Comments="" FKRefDefIndex_Obj_id="1618" Splitted="0" IsLinkedObject="0" IDLinkedModel="-1" Obj_id_Linked="-1" OrderPos="54" />
+</RELATIONS>
+<NOTES>
+</NOTES>
+<IMAGES>
+</IMAGES>
+</METADATA>
+<PLUGINDATA>
+<PLUGINDATARECORDS>
+</PLUGINDATARECORDS>
+</PLUGINDATA>
+<QUERYDATA>
+<QUERYRECORDS>
+</QUERYRECORDS>
+</QUERYDATA>
+<LINKEDMODELS>
+</LINKEDMODELS>
+</DBMODEL>
More information about the Mapbender_commits mailing list
