[Mapbender-commits] r1459 - branches/mapbender_sld/http/javascripts
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri Jun 22 14:24:19 EDT 2007
Author: uli
Date: 2007-06-22 14:24:19 -0400 (Fri, 22 Jun 2007)
New Revision: 1459
   branches/mapbender_sld/http/javascripts/map.js
some new methods for the wms-obj
Modified: branches/mapbender_sld/http/javascripts/map.js
--- branches/mapbender_sld/http/javascripts/map.js	2007-06-15 13:13:19 UTC (rev 1458)
+++ branches/mapbender_sld/http/javascripts/map.js	2007-06-22 18:24:19 UTC (rev 1459)
@@ -136,10 +136,19 @@
 	 * @type integer
 	this.getWidth = function(){
-		return this.width;
+		return parseInt(this.width);
+	 * set the width of the mapObj
+	 * @param {integer} widht the width of the mapObj
+	this.setWidth = function(width){
+		this.width = parseInt(width);
 	 * get the height of the mapObj
 	 * @member mb_mapObj_const
@@ -147,10 +156,19 @@
 	 * @type integer
 	this.getHeight = function(){
-		return this.height;
+		return parseInt(this.height);
+	 * set the height of the mapObj
+	 * @param {integer} height the height of the mapObj
+	this.setHeight = function(height){
+		this.height = parseInt(height);
 	 * get the extent of the mapObj
@@ -164,20 +182,35 @@
 	 * get the extent as minx, maxx, miny, maxy
-	 * @return extent of the mapObj as  minx,minx,maxx,maxy
+	 * @return extent and additional informations of the mapObj
 	 * @type Object
-	this.getExtentAsObj = function(){
-		var coordslist = this.getExtent().split(",");
-		var coords = new Object();
-		coords.minx = parseFloat(coordslist[0]);
-		coords.miny = parseFloat(coordslist[1]);
-		coords.maxx = parseFloat(coordslist[2]);
-		coords.maxy = parseFloat(coordslist[3]);
-		return coords;
+	this.getExtentInfos = function(){
+		var ext = new Extent(this.getExtent());
+		return ext;
+	 * converts the extent of the mapobject so that the maximum	extent will be displayed
+	this.calculateExtent = function(ext){
+		var relation_px_x = this.getWidth() / this.getHeight();
+		var relation_px_y = this.getHeight() / this.getWidth();
+		var relation_bbox_x = ext.extentx / ext.extenty;
+		if(relation_bbox_x <= relation_px_x){
+			ext.minx = ext.centerx - relation_px_x * ext.extenty / 2;
+			ext.maxx = ext.centerx + relation_px_x * ext.extenty / 2;
+		if(relation_bbox_x > relation_px_x){
+			ext.miny = ext.centery - relation_px_y * ext.extentx / 2;
+			ext.maxy = ext.centery + relation_px_y * ext.extentx / 2;
+		this.setExtent(ext.minx,ext.miny,ext.maxx,ext.maxy);
 	 * zoom the map with a zoomfactor and optional to x,y coords
 	 * @param {boolean} in_ in = true, out = false
@@ -191,7 +224,7 @@
 			factor = 1 / factor;
-		var extent = this.getExtentAsObj();
+		var extent = this.getExtentInfos();
 		var distx = extent.maxx - extent.minx;
 		var disty =  extent.maxy - extent.miny;
@@ -261,9 +294,9 @@
 	 * @return array of all mapRequests of this map-object
 	 * @type string[]
-	this.getMapRequests = function(clickPoint){
+	this.getMapRequests = function(){
 		var allRequests = [];
-		//loop through all wms to get the FeatureInfoRequests
+		//loop through all wms to get the MapRequests
 		for(var i=0; i<this.wms.length; i++){
 			var currentRequest = this.wms[i].getMapRequest(this);
 			if(currentRequest){
@@ -1171,27 +1204,37 @@
    mb_mapObj[ind].extent = minx + "," + miny + "," + maxx + "," + maxy;
    setMapRequest(frameName);
+ * converts the extent of the mapobject so that the maximum	extent will be displayed {@link mb_mapObj_const#calculateExtent}
+ * use: mb_mapObj.calculateExtent
+ * @deprecated
 function mb_calculateExtent(frameName,minx,miny,maxx,maxy){
-  var ind = getMapObjIndexByName(frameName);
-  var extenty = parseFloat(maxy) - parseFloat(miny);
-  var extentx = parseFloat(maxx) - parseFloat(minx);
-  var relation_px_x = mb_mapObj[ind].width / mb_mapObj[ind].height;
-  var relation_px_y = mb_mapObj[ind].height / mb_mapObj[ind].width;
-  var relation_bbox_x = extentx / extenty;
-  var centerx = parseFloat(minx) + (extentx/2);
-  var centery = parseFloat(miny) + (extenty/2);
-  if(relation_bbox_x <= relation_px_x){
-    minx = centerx - relation_px_x * extenty / 2;
-    maxx = centerx + relation_px_x * extenty / 2;
-  if(relation_bbox_x > relation_px_x){
-    miny = centery - relation_px_y * extentx / 2;
-    maxy = centery + relation_px_y * extentx / 2;
-  mb_mapObj[ind].extent = minx  +","+ miny +","+ maxx  +","+ maxy;
+  var map = getMapObjByName(frameName);
+  var extent = new Extent(minx,miny,maxx,maxy);
+  map.calculateExtent(extent);
+ * @class extent
+ * @param {float} minx
+ * @param {float} miny
+ * @param {float} maxx
+ * @param {float} maxy
+ * @return the extent as object
+ * @type Object
+function Extent(minx,miny,maxx,maxy){
+	this.minx = parseFloat(minx);
+	this.miny = parseFloat(miny);
+	this.maxx = parseFloat(maxx);
+	this.maxy = parseFloat(maxy);
+	this.extentx = this.maxx - this.minx;
+	this.extenty = this.maxy - this.miny;
+	this.centerx = this.minx + this.extentx/2;
+	this.centery = this.miny + this.extenty/2;
+	return this;
 function mb_showHighlight(frameName,x,y){
    var pos = makeRealWorld2mapPos(frameName,x, y);
@@ -1452,7 +1495,7 @@
 		var isAppropriate = (typeof(levelIndex)=='number' && levelIndex < indexOfLevel(log_level));
 		return (isNotOff && isAppropriate);
-	var throwException = function (message, level) {
+	this.throwException = function (message, level) {
 		if (isValidLevel(level)) {
 			if (log_js == "on") {
 				try {
@@ -1479,7 +1522,7 @@
  * @param message the message that is being logged
 function Mb_exception(message) {
-	 var level = "error";
+	var level = "error";
 	this.throwException(message, level);
 Mb_exception.prototype = new Mb_log();
More information about the Mapbender_commits mailing list
