[Mapbender-commits] r1461 - trunk/mapbender/http/print
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Mon Jun 25 08:28:08 EDT 2007
Author: astrid_emde
Date: 2007-06-25 08:28:08 -0400 (Mon, 25 Jun 2007)
New Revision: 1461
   trunk/mapbender/http/print/mod_printPDF_pdf.php
mapbender print with A1 and A0
Modified: trunk/mapbender/http/print/mod_printPDF_pdf.php
--- trunk/mapbender/http/print/mod_printPDF_pdf.php	2007-06-22 18:25:09 UTC (rev 1460)
+++ trunk/mapbender/http/print/mod_printPDF_pdf.php	2007-06-25 12:28:08 UTC (rev 1461)
@@ -1,805 +1,853 @@
-<?php
-# $Id:
-# http://www.mapbender.org/index.php/mod_printPDF_pdf.php
-# Copyright (C) 2002 CCGIS
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2, or (at your option)
-# any later version.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
-# GNU General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-#require_once("../php/mb_validateSession.php");
-ob_start();
-session_start();
-ini_set('error_reporting', 'E_ALL & ~ E_NOTICE');
-require_once(dirname(__FILE__)."/../../conf/mapbender.conf");
-include (dirname(__FILE__)."/../classes/class.ezpdf.php");
-include (dirname(__FILE__)."/../classes/class_stripRequest.php");
-include (dirname(__FILE__)."/../classes/class_weldMaps2PNG.php");
-include (dirname(__FILE__)."/../classes/class_weldOverview2PNG.php");
-include (dirname(__FILE__)."/../print/".$_REQUEST["conf"]);
-include (dirname(__FILE__)."/../classes/class_SaveLegend.php");
-include (dirname(__FILE__)."/../print/print_functions.php");
-if($log == true){
-	include (dirname(__FILE__)."/../classes/class_log.php");
-#Globals
-$factor = intval($_REQUEST["quality"]);
-#$date = date("d.m.Y",strtotime("now"));
-$linewidth_dashed = 0.5;
-$linewidth = 0.5;
-// DURATION TIME:
-function microtime_float(){
-   list($usec, $sec) = explode(" ", microtime());
-   return ((float)$usec + (float)$sec);
-$time_start = microtime_float();
-// END DURATION TIME
-$time_end = microtime_float();
-$time = $time_end - $time_start;
-$size = $_REQUEST["size"];
-$format = $_REQUEST["format"];
-$map_scale = $_REQUEST["map_scale"];
-$overview_url = $_REQUEST["overview_url"];
-$epsg = $_REQUEST["epsg"];
-function setscalebar($scale){
-    	$mb_resolution = 28.35;
-		if($scale < 16){
-	      $value = "10";
-	      $unit = "cm";
-	      $scalefactor = 10/$scale;
-	      $img_width = round($scalefactor * $mb_resolution);
-	   if($scale >= 16 && $scale < 151){
-	      $value = "1";
-	      $unit = "Meter";
-	      $scalefactor = 100/$scale;
-	   if($scale >= 151 && $scale < 1550 ){
-	      $value = "10";
-	      $unit = "Meter";
-	      $scalefactor = 1000/$scale;
-	   if($scale >= 1550 && $scale < 15050){
-	      $value = "100";
-	      $unit = "Meter";
-	      $scalefactor = 10000/$scale;
-	   if($scale < 150050 && $scale >= 15050){
-	      $value = "1";
-	      $unit = "Kilometer";
-	      $scalefactor = 100000/$scale;
-	   if($scale < 1500050 && $scale >= 150050){
-	      $value = "10";
-	      $scalefactor = 1000000/$scale;
-	   if($scale < 15000050 && $scale >= 1500050){
-	      $value = "100";
-	      $scalefactor = 10000000/$scale;
-	   if($scale < 150000001 && $scale >= 15000001){
-	      $value = "1000";
-	      $scalefactor = 100000000/$scale;
-	   if($scale >= 150000001){
-	      $value = "1000";
-	   $array_scale[0] = $unit;
-	   $array_scale[1] = $img_width;
-		$array_scale[2] = $value;
-	   return  $array_scale;
-$border = 0.8 * $DPC;
-if($matching == true){
-   $urls = str_replace($pattern,$replacement,$_REQUEST["map_url"]);
-else{
-   $urls = $_REQUEST["map_url"];
-$array_urls = explode("___", $urls);
-$myURL = new stripRequest($array_urls[0]);
-$map_width = round($myURL->get("width"));
-$map_height = round($myURL->get("height"));
-$map_extent = $myURL->get("BBOX");
-if($factor>1){
-	for($i=0; $i<count($array_urls); $i++){
-		$m = new stripRequest($array_urls[$i]);
-		$m->set('width',(intval($m->get('width'))*4));
-		$m->set('height',(intval($m->get('height'))*4));
-		if(in_array($m->get('map'),$highqualitymapfiles)){
-			$m->set('map',str_replace(".map","_4.map",$m->get('map')));
-		$array_urls[$i] = $m->url;
-$coord = split(",",$map_extent);
-// analyse overview url and draw rectangle with position
-$o_url = new stripRequest($overview_url);
-$overview_width = round($o_url->get("width"));
-$overview_height = round($o_url->get("height"));
-if($factor>1){
-	$o_url->set('width',(intval($o_url->get('width'))*4));
-	$o_url->set('height',(intval($o_url->get('height'))*4));
-	if(in_array($o_url->get('map'),$highqualitymapfiles)){
-			$o_url->set('map',str_replace(".map","_4.map",$o_url->get('map')));
-			$overview_url = $o_url->url;
-	$overview_url = str_replace($pattern,$replacement,$overview_url);
-if ($size == "A4" && $format == "portrait"){
-	$overview_left = $a4p_overviewOffset_left;
-	$overview_bottom =$a4p_overviewOffset_bottom;
-}elseif ($size == "A4" && $format == "landscape"){
-	$overview_left = $a4l_overviewOffset_left;
-	$overview_bottom =$a4l_overviewOffset_bottom;
-}elseif ($size == "A3" && $format == "portrait"){
-	$overview_left = $a3p_overviewOffset_left;
-	$overview_bottom =$a3p_overviewOffset_bottom;
-}elseif ($size == "A3" && $format == "landscape"){
-	$overview_left = $a3l_overviewOffset_left;
-	$overview_bottom = $a3l_overviewOffset_bottom;
-}elseif ($size == "A2" && $format == "portrait"){
-	$overview_left = $a2p_overviewOffset_left;
-	$overview_bottom =$a2p_overviewOffset_bottom;
-}elseif ($size == "A2" && $format == "landscape"){
-	$overview_left = $a2l_overviewOffset_left;
-	$overview_bottom = $a2l_overviewOffset_bottom;
-$o_extent = $o_url->get("BBOX");
-$array_overview_url[0] = $overview_url;
-if($log == true){
-	$l = new log("printPDF_overview",$array_overview_url);
-$o_new = new stripRequest($overview_url);
-$o_new->set('width',50);
-$o_new->set('height',50);
-//$o->set('BBOX',$overview_extent);
-$o_url_new =$o_new->url;
-$array_overview[0] = $overview_url;
-$array_overview[1] = $o_url;
- * north arrow
-if($size == "A4" && $format == "portrait"){
-	$northarrow_left = $a4p_northarrow_left;
-	$northarrow_bottom = $a4p_northarrow_bottom;
-	$northarrow_left = $a4l_northarrow_left;
-	$northarrow_bottom = $a4l_northarrow_bottom;
-	$northarrow_left = $a3p_northarrow_left;
-	$northarrow_bottom = $a3p_northarrow_bottom;
-	$northarrow_left = $a3l_northarrow_left;
-	$northarrow_bottom = $a3l_northarrow_bottom;
-	$northarrow_left = $a2p_northarrow_left;
-	$northarrow_bottom = $a2p_northarrow_bottom;
-	$northarrow_left = $a2l_northarrow_left;
-	$northarrow_bottom = $a2l_northarrow_bottom;
- * special image
-	$specialImage_left = $a4p_special_left;
-	$specialImage_bottom = $a4p_special_bottom;
-	$specialImage_left = $a4l_special_left;
-	$specialImage_bottom = $a4l_special_bottom;
-	$specialImage_left = $a3p_special_left;
-	$specialImage_bottom = $a3p_special_bottom;
-	$specialImage_left = $a3l_special_left;
-	$specialImage_bottom = $a3l_special_bottom;
-	$specialImage_left = $a2p_special_left;
-	$specialImage_bottom = $a2p_special_bottom;
-	$specialImage_left = $a2l_special_left;
-	$specialImage_bottom = $a2l_special_bottom;
-if($log == true){
-	$l = new log("printPDF",$array_urls);
-$pdf = new Cezpdf();
-$pdf->Cezpdf(strtolower($size),$format);
-$diff=array(196=>'Adieresis',228=>'adieresis',
-   214=>'Odieresis',246=>'odieresis',
-   220=>'Udieresis',252=>'udieresis',
-   223=>'germandbls');
-$pdf->selectFont('../classes/fonts/Helvetica.afm', array('encoding'=>'WinAnsiEncoding','differences'=>$diff));
-	$mapOffset_left = $a4p_mapOffset_left;
-	$mapOffset_bottom = $a4p_mapOffset_bottom;
-	$header_height = $a4p_header_height;
-	$footer_height = $a4p_footer_height;
-else{
-	$mapOffset_left = $a4l_mapOffset_left;
-	$mapOffset_bottom = $a4l_mapOffset_bottom;
-	$header_height = $a4l_header_height;
-	$header_width = $a4l_header_width;
-session_write_close();
-$i = new weldMaps2PNG(implode("___",$array_urls),$filename);
-$pdf->addPngFromFile($filename, $mapOffset_left, $mapOffset_bottom, $map_width, $map_height);
-if($unlink == true){
-	unlink($filename);
-* user drawn elements
-$theMeasureConfigArray = array(
-   "do_fill" => FALSE,
-     "fill_color" => array(
-     "r" => 128 / 255,
-     "g" => 128 / 255,
-     "b" => 128 / 255
-   "do_stroke" => TRUE,
-     "stroke_color" => array(
-     "r" => 254 / 255,
-     "g" => 1 / 255,
-     "b" => 1 / 255
-   "line_style" => array(
-       "width" => 2,
-       "cap" => 'butt',
-       "join" => 'miter',
-       "dash" => array(10, 6)
-if ($_POST['measured_x_values']!=''){
-	addMeasuredItem(&$pdf, $_POST['measured_x_values'], $_POST['measured_y_values'], $theMeasureConfigArray);
-	hideElementsOutsideMapframe(&$pdf);
-# dashed line
-$pdf->setLineStyle($linewidth_dashed, '','', array(2,2));
-$pdf->line($mapOffset_left - $linewidth_dashed, $mapOffset_bottom - $linewidth_dashed, $mapOffset_left - $linewidth_dashed, $mapOffset_bottom  + $map_height + $linewidth_dashed);
-$pdf->line($mapOffset_left - $linewidth_dashed, $mapOffset_bottom  + $map_height + $linewidth_dashed, $mapOffset_left + $map_width + $linewidth_dashed, $mapOffset_bottom + $map_height + $linewidth_dashed);
-$pdf->line($mapOffset_left + $map_width + $linewidth_dashed, $mapOffset_bottom + $map_height + $linewidth_dashed, $mapOffset_left + $map_width + $linewidth_dashed, $mapOffset_bottom -$linewidth_dashed);
-$pdf->line($mapOffset_left + $map_width + $linewidth_dashed, $mapOffset_bottom -$linewidth_dashed, $mapOffset_left - $linewidth_dashed, $mapOffset_bottom - $linewidth_dashed);
-#line
-$pdf->setLineStyle($linewidth, '', '', array());
-$pdf->line($mapOffset_left - $border, $mapOffset_bottom - $border, $mapOffset_left - $border, $mapOffset_bottom  + $map_height + $border);
-$pdf->line($mapOffset_left - $border, $mapOffset_bottom  + $map_height + $border, $mapOffset_left + $map_width + $border, $mapOffset_bottom + $map_height + $border);
-$pdf->line($mapOffset_left + $map_width + $border, $mapOffset_bottom + $map_height + $border, $mapOffset_left + $map_width + $border, $mapOffset_bottom -$border);
-$pdf->line($mapOffset_left + $map_width + $border, $mapOffset_bottom -$border, $mapOffset_left - $border, $mapOffset_bottom - $border);
-if($epsg == "EPSG:4326"){
-	$text4 = "";
-   #header:
-   $pdf->line($mapOffset_left - $border, $mapOffset_bottom  + $map_height + $border, $mapOffset_left - $border, $mapOffset_bottom  + $map_height + $border + $header_height);
-   $pdf->line($mapOffset_left - $border, $mapOffset_bottom  + $map_height + $border + $header_height, $mapOffset_left + $map_width + $border, $mapOffset_bottom  + $map_height + $border + $header_height);
-   $pdf->line($mapOffset_left + $map_width + $border, $mapOffset_bottom  + $map_height + $border + $header_height, $mapOffset_left + $map_width + $border, $mapOffset_bottom  + $map_height + $border);
-   $pdf->line( $mapOffset_left + $map_width/2, $mapOffset_bottom  + $map_height + $border, $mapOffset_left + $map_width/2, $mapOffset_bottom  + $map_height + $border + $header_height);
-   #header-text
-   $mySize = 9;
-   $length = $pdf->getTextWidth($mySize, $text1);
-   $pdf->addText($mapOffset_left - ($border/2) + ($map_width/4) - ($length/2),$mapOffset_bottom + $map_height + $border + 60,$mySize,$text1);
-   $mySize = 8;
-   $length = $pdf->getTextWidth($mySize, $text2);
-   $pdf->addText($mapOffset_left - ($border/2) + ($map_width/4) - ($length/2),$mapOffset_bottom + $map_height + $border + 45,$mySize,$text2);
-   $length = $pdf->getTextWidth($mySize, $text3);
-   $pdf->addText($mapOffset_left - ($border/2) + ($map_width/4) - ($length/2),$mapOffset_bottom + $map_height + $border + 35,$mySize,$text3);
-   $mySize = 9;
-   $length = $pdf->getTextWidth($mySize, $text4);
-   $pdf->addText($mapOffset_left - ($border/2) + ($map_width/4) - ($length/2),$mapOffset_bottom + $map_height + $border + 20,$mySize,$text4);
-   $mySize = 8;
-   $length = $pdf->getTextWidth($mySize, $text5);
-   $pdf->addText($mapOffset_left - ($border/2) + ($map_width/4) - ($length/2),$mapOffset_bottom + $map_height + $border + 10,$mySize,$text5);
-   $mySize = 9;
-   $length = $pdf->getTextWidth($mySize, $text6);
-   $pdf->addText($mapOffset_left + ($border/2) + ($map_width/4*3) - ($length/2),$mapOffset_bottom + $map_height + $border + 60,$mySize,$text6);
-   $length = $pdf->getTextWidth($mySize, $text7);
-   $pdf->addText($mapOffset_left + ($border/2) + ($map_width/4*3) - ($length/2),$mapOffset_bottom + $map_height + $border + 50,$mySize,$text7);
-   $length = $pdf->getTextWidth($mySize, $text8);
-   $pdf->addText($mapOffset_left + ($border/2) + ($map_width/4*3) - ($length/2),$mapOffset_bottom + $map_height + $border + 30,$mySize,$text8);
-   $length = $pdf->getTextWidth($mySize, $text9);
-   $pdf->addText($mapOffset_left + ($border/2) + ($map_width/4*3) - ($length/2),$mapOffset_bottom + $map_height + $border + 20,$mySize,$text9);
-   $length = $pdf->getTextWidth($mySize, $text10);
-   $pdf->addText($mapOffset_left + ($border/2) + ($map_width/4*3) - ($length/2),$mapOffset_bottom + $map_height + $border + 10,$mySize,$text10);
-   //special image on the map-page
-   if ($special == true){
-   	$pdf->addPngFromFile($specialImage, $specialImage_left, $specialImage_bottom , $specialImage_width, $specialImage_height);
-   #footer
-   $pdf->line($mapOffset_left - $border, $mapOffset_bottom - $border, $mapOffset_left - $border, $mapOffset_bottom - $border - $footer_height);
-   $pdf->line($mapOffset_left - $border, $mapOffset_bottom - $border - $footer_height, $mapOffset_left + $map_width + $border, $mapOffset_bottom - $border - $footer_height);
-   $pdf->line($mapOffset_left + $map_width + $border, $mapOffset_bottom - $border - $footer_height, $mapOffset_left + $map_width + $border, $mapOffset_bottom - $border);
-   $mySize = 8;
-   $length = $pdf->getTextWidth($mySize, $text11);
-   $pdf->addText( $mapOffset_left + $map_width/2 - ($length/2),$mapOffset_bottom - $border - 10,$mySize,$text11);
-   $mySize = 6;
-   $length = $pdf->getTextWidth($mySize, $text12);
-   $pdf->addText( $mapOffset_left + $map_width/2 - ($length/2),$mapOffset_bottom - $border - 18,$mySize,$text12);
-   $length = $pdf->getTextWidth($mySize, $text13);
-   $pdf->addText( $mapOffset_left + $map_width/2 - ($length/2),$mapOffset_bottom - $border - 25,$mySize,$text13);
-else{
-   $pdf->setColor(1,1,1);
-   $ll = array($mapOffset_left + $map_width - $header_width + $border - $linewidth, $mapOffset_bottom - $border + 1);
-   $pdf->filledRectangle($ll[0], $ll[1], $header_width,$header_height);
-   $pdf->line($ll[0], $ll[1], $ll[0], $ll[1] + $header_height);
-   $pdf->line($ll[0], $ll[1] + $header_height, $ll[0] + $header_width, $ll[1] + $header_height);
-   $pdf->line($ll[0] + 2, $ll[1] + 2, $ll[0] + 2,  $ll[1] + $header_height - 2);
-   $pdf->line($ll[0] + 2,  $ll[1] + $header_height - 2, $ll[0] - 2 + $header_width, $ll[1] + $header_height - 2);
-   $pdf->line($ll[0] - 2 + $header_width, $ll[1] + $header_height - 2, $ll[0] - 2 + $header_width, $ll[1] + 2);
-   $pdf->line($ll[0] - 2 + $header_width, $ll[1] + 2, $ll[0] + 2, $ll[1] + 2);
-   $pdf->line($ll[0] + 2, $ll[1] + 110 , $ll[0] - 2 + $header_width, $ll[1] + 110);
-   $pdf->line($ll[0] + 2, $ll[1] + 40 , $ll[0] - 2 + $header_width, $ll[1] + 40);
-    if($epsg == "EPSG:4326"){
-	$text4 = "";
-   $pdf->setColor(0,0,0);
-   $mySize = 9;
-   $pdf->addText($ll[0] + $header_width/2 - $length/2,185,$mySize,$text1);
-   $mySize = 8;
-   $pdf->addText($ll[0] + $header_width/2 - $length/2,175,$mySize,$text2);
-   $pdf->addText($ll[0] + $header_width/2 - $length/2,165,$mySize,$text3);
-   $mySize = 9;
-   $pdf->addText($ll[0] + $header_width/2 - $length/2,155,$mySize,$text4);
-   $mySize = 8;
-   $pdf->addText($ll[0] + $header_width/2 - $length/2,145,$mySize,$text5);
-   $mySize = 9;
-   $pdf->addText($ll[0] + $header_width/2 - $length/2,125,$mySize,$text6);
-   $pdf->addText($ll[0] + $header_width/2 - $length/2,115,$mySize,$text7);
-   $pdf->addText($ll[0] + $header_width/2 - $length/2,95,$mySize,$text8);
-   $pdf->addText($ll[0] + $header_width/2 - $length/2,85,$mySize,$text9);
-   $pdf->addText($ll[0] + $header_width/2 - $length/2,75,$mySize,$text10);
-   $mySize = 8;
-   $pdf->addText($ll[0] + $header_width/2 - $length/2,60,$mySize,$text11);
-   $mySize = 6;
-   $length = $pdf->getTextWidth($mySize, $text14);
-   $pdf->addText($ll[0] + $header_width/2 - $length/2,53,$mySize,$text14);
-   $length = $pdf->getTextWidth($mySize, $text15);
-   $pdf->addText($ll[0] + $header_width/2 - $length/2,47,$mySize,$text15);
-   $length = $pdf->getTextWidth($mySize, $text16);
-   $pdf->addText($ll[0] + $header_width/2 - $length/2,41,$mySize,$text16);
-   $length = $pdf->getTextWidth($mySize, $text17);
-   $pdf->addText($ll[0] + $header_width/2 - $length/2,35,$mySize,$text17);
-#Coordinates
-$myMinx = "R ".substr(round($coord[0]), 0, 4)." ".substr(round($coord[0]), 4, 3)."";
-$myMiny = "H ".substr(round($coord[1]), 0, 4)." ".substr(round($coord[1]), 4, 3)."";
-$myMaxx = "R ".substr(round($coord[2]), 0, 4)." ".substr(round($coord[2]), 4, 3)."";
-$myMaxy = "H ".substr(round($coord[3]), 0, 4)." ".substr(round($coord[3]), 4, 3)."";
-$mySize = 9;
-$pdf->addText($mapOffset_left - 3, $mapOffset_bottom, $mySize, $myMinx, -90);
-$pdf->addText($mapOffset_left, $mapOffset_bottom  - ($pdf->getFontHeight($mySize)), $mySize, $myMiny);
-$pdf->addText($mapOffset_left  + $map_width - ($pdf->getTextWidth($mySize, $myMaxx)), $mapOffset_bottom + $map_height  + 3, $mySize, $myMaxx);
-$pdf->addText($mapOffset_left + $map_width + 3, $mapOffset_bottom + $map_height, $mySize, $myMaxy, 90);
-if ($overview==true){
-	// analyse request, draw rectancle
-	$filename = str_replace("map_","overview_",$filename);
-	if($size == "A4" && $format == "portrait"){
-		$i = new weldOverview2PNG($overview_url,$array_urls[0] ,$filename);
-		$pdf->addPngFromFile($filename, $overview_left,$overview_bottom, $overview_width, $overview_height);
-		if($unlink == true){
-	else{
-		$i = new weldOverview2PNG($overview_url,$array_urls[0],$filename);
-		//$pdf->addPngFromFile($filename, $mapOffset_left,$mapOffset_bottom, $overview_width, $overview_height);
-if ($northarrow==true){
-	$pdf->addPngFromFile($northarrowImage, $northarrow_left, $northarrow_bottom , $northarrowImage_width, $northarrowImage_height);
-	$scalebar = false;
-else{
-	$scalebar = true;
-if($scalebar == true){
-	if ($size == "A4" && $format == "portrait"){
-		$scalebar_left = $a4p_scalebar_left;
-		$scalebar_bottom = $a4p_scalebar_bottom;
-	}elseif ($size == "A4" && $format == "landscape"){
-		$scalebar_left = $a4l_scalebar_left;
-		$scalebar_bottom = $a4l_scalebar_bottom;
-	}elseif ($size == "A3" && $format == "portrait"){
-		$scalebar_left = $a3p_scalebar_left;
-		$scalebar_bottom = $a3p_scalebar_bottom;
-	}elseif ($size == "A3" && $format == "landscape"){
-		$scalebar_left = $a3l_scalebar_left;
-		$scalebar_bottom = $a3l_scalebar_bottom;
-	}elseif ($size == "A2" && $format == "portrait"){
-		$scalebar_left = $a2p_scalebar_left;
-		$scalebar_bottom = $a2p_scalebar_bottom;
-	}elseif ($size == "A2" && $format == "landscape"){
-		$scalebar_left = $a2l_scalebar_left;
-		$scalebar_bottom = $a2l_scalebar_bottom;
-	$array_scalebar = setscalebar($map_scale);
-	$scalebar_left = $scalebar_left + $header_width/2 - $array_scalebar[1]/2;
-	$pdf->setLineStyle($scalebar_height, '','', array());
-	#$pdf->line($scalebar_left, $scalebar_bottom , $scalebar_left - 200 + $array_scalebar[1], $scalebar_bottom);
-	$pdf->filledRectangle($scalebar_left, $scalebar_bottom, $array_scalebar[1],$scalebar_height);
-	$pdf->filledRectangle($scalebar_left + $array_scalebar[1]/4 + 1 , $scalebar_bottom + 1, $array_scalebar[1]/4 - 1 ,$scalebar_height-2);
-	$pdf->filledRectangle($scalebar_left + 3*($array_scalebar[1]/4) + 1 , $scalebar_bottom + 1, $array_scalebar[1]/4 - 2 ,$scalebar_height-2);
-	#$pdf->setColor(1,0,1);
-	#$pdf->filledRectangle($scalebar_left  , $scalebar_bottom - 20, 1 * $DPC ,$scalebar_height-2);
-	# value - Einheiten
-   $mySize = 8;
-   $scalebar_height_half = 0.5 * $scalebar_height;
-	$myText = 0;
-   $length = $pdf->getTextWidth($mySize, $myText);
-   $pdf->addText($scalebar_left - $length/2 ,$scalebar_bottom + 9 ,$mySize,$myText);
-	$myText = $array_scalebar[2]/2;
-   $pdf->addText($scalebar_left + $array_scalebar[1]/2 - $length/2 ,$scalebar_bottom + 9 ,$mySize,$myText);
-	$myText = $array_scalebar[2];
-   $pdf->addText($scalebar_left + $array_scalebar[1] - $length/2 - $length/4 ,$scalebar_bottom + 9 ,$mySize,$myText);
-   $mySize = 8;
-   $myText = $array_scalebar[0];
-   #$pdf->addText($scalebar_left + $scalebar_width + 5,$scalebar_bottom - $scalebar_height_half ,$mySize,$myText);
-	#units
-   $pdf->addText($scalebar_left + $array_scalebar[1]/2 - $length/2 ,$scalebar_bottom - 12 ,$mySize,$myText);
-    new page for legend
-if ($legend == true && $_REQUEST["mylegend"]=='true'){
-	$pdf->ezNewPage();
-	//Pageborder (top, bottom, left, right)
-	  $pdf->ezSetMargins(50,50,80,30);
-	} else {
-	  $pdf->ezSetMargins(60,35,60,60);
-	//Requests
-	if(CHARSET=="UTF-8"){
-		$new_wms_title=utf8_decode($_REQUEST["wms_title"]);
-	}else{
-		$new_wms_title=$_REQUEST["wms_title"];
-		$new_layers=utf8_decode($_REQUEST["layers"]);
-	}else{
-		$new_layers=$_REQUEST["layers"];
-	$my_wms_id = explode("___",$_REQUEST["wms_id"]);
-	$my_wms_title = explode("___",$new_wms_title);
-	$my_layers = explode("___",$new_layers);
-	if($matching == true){
-        $my_legend = str_replace($pattern,$replacement,$_REQUEST["legendurl"]);
-    else{
-        $my_legend = $_REQUEST["legendurl"];
-    $my_legend = explode("___",$my_legend);
-	//columns
-	  $pdf->ezColumnsStart(array ('num'=>2, 'gap'=>10));
-	} else {
-	  $pdf->ezColumnsStart(array ('num'=>3, 'gap'=>10));
-	//header from printPDF.conf
-	//$pdf->ezText("<b>".$titel."</b>", 13);
-	$pdf->ezText("<b><u>".$legendText."</u></b>", 13);
-	//Seitenraender (top, bottom, left, right)
-	  $pdf->ezSetMargins(70,35,80,30);
-	} else {
-	  $pdf->ezSetMargins(100,35,60,60);
-	//generate the legend---------------------------------------------
-	// Gesamthoehe Legende / height of the legend
-	$sum_legend_height = 0;
-	for($i=0; $i<count($my_wms_id); $i++){
-		if ($my_wms_id[$i] != '0'){  //wms_id not 0
-			$layer = explode(",",$my_layers[$i]);
-			$my_legendurls = explode(",",$my_legend[$i]);
-			$wms_y_position = $pdf->ezText("<b>".$my_wms_title[$i]."</b>", 12, array('spacing'=>1.2));
-			$wms_zeilenhoehe   =  $pdf->getFontHeight(12);
-			// add this to the height of the legend /addiere dies zur Gesamthoehe Legende
-			$sum_legend_height += $wms_zeilenhoehe;
-			//Layer
-			$l = 0;		#l temporary parameter to count the layer /Hilfvariable zum durchz�hlen der angezeigten Layer
-			for($j=0; $j<count($my_legendurls); $j++){
-				// url with grouped layers------------------
-				$temp_url = explode('*',$my_legendurls[$j]);
-				$temp_layers = explode('*',$layer[$j]);
-				for ($q=0; $q <count($temp_url);$q++){
-					if($temp_url[$q] == '1' ){			// Layertitle for the parent of grouped layers
-						// add this to the height of the legend /addiere dies zur Gesamth�he Legende
-						$layer_y_position = $pdf->ezText($temp_layers[$q], 11, array('spacing'=>1.2));
-						$layer_zeilenhoehe   =  $pdf->getFontHeight(12);
-						$sum_legend_height += $layer_zeilenhoehe;
-					}elseif($temp_url[$q] != '0' ){
-						$funktionsaufruf = new SaveLegend($temp_url[$q],$legendFilename);
-						$imgsize = getimagesize($legendFilename);
-						// add this to the height of the legend /addiere dies zur Gesamthoehe der Legende
-						$sum_legend_height += $imgsize[1];
-						//calculate text + picture / Berechnung Groesse Schrift + Bild
-						if($l == 0){
-						       $y_position = $wms_y_position;
-						       $wms_y_position = '';
-						}else{
-							 $y_position = $pdf->ezText("", 1, array('spacing'=>1.2));
-						$layer_zeilenhoehe = $pdf->getFontHeight(11);
-						$next_position = $y_position - $layer_zeilenhoehe - $imgsize[1];
-						// add this to the height of the legend / addiere dies zur Gesamth�he Legende
-						$l = $l+1;
-		     			// if text + picture are smaler then the lower margin + textsize, then set a space
-						//wenn Schrift + Bild kleiner der unteren Margin + Zeilenhoehe, dann Abstand setzen
-						 if($size == "A4" && $format == "portrait" && $next_position <= 35 +$layer_zeilenhoehe){ //90 $layer_zeilenhoehe
-							$space = $layer_zeilenhoehe + $imgsize[1];
-						  $pdf->ezSetDy(-$space);
-						if($size == "A4" && $format == "landscape" && $next_position <= 35+$layer_zeilenhoehe){//50
-						//write the header layername / Ueberschrift schreiben
-						$legend = $temp_layers[$q]."\n";  //$layer[$j]."\n";
-						$pdf->ezText($legend, 11, array('spacing'=>1.2));
-						//$pdf->ezText($url, 9, array('spacing'=>1.2));
-						//print the picture / Bild schreiben
-						$pdf->ezImage($legendFilename, 0, 'width', 'none', 'left');
-							unlink($legendFilename);
-					} //if legendurl
-				}// for legendurl
-			  	//frames (x1, y1, x2, y2)
-					#line
-					$pdf->setLineStyle($linewidth, '', '', array());
-					//left
-					$pdf->line($mapOffset_left - $border, $mapOffset_bottom - $border - $footer_height, $mapOffset_left - $border, $mapOffset_bottom  + $map_height + $border + $header_height);
-					//right
-					//top
-					$pdf->line($mapOffset_left + $map_width + $border, $mapOffset_bottom + $map_height + $border + $header_height, $mapOffset_left + $map_width + $border, $mapOffset_bottom - $border - $footer_height);
-					//bottom
-					$pdf->line($mapOffset_left + $map_width + $border, $mapOffset_bottom -$border - $footer_height, $mapOffset_left - $border, $mapOffset_bottom - $border - $footer_height);
-					if ($legendImage!=''){
-						//image on top of page
-						$pdf->addPngFromFile($legendImage, $mapOffset_left + $map_width + $border - $legendImage_width -6, $mapOffset_bottom + $map_height + $border + $header_height - $legendImage_height - 4 , $legendImage_width, $legendImage_height);
-				} else {
-				  //left
-				  $pdf->line($mapOffset_left - $border, $mapOffset_bottom - $border, $mapOffset_left - $border, $mapOffset_bottom  + $map_height + $border);
-				  //right
-				  $pdf->line($mapOffset_left - $border, $mapOffset_bottom  + $map_height + $border , $mapOffset_left + $map_width + $border, $mapOffset_bottom + $map_height + $border);
-				  //top
-				  $pdf->line($mapOffset_left + $map_width + $border, $mapOffset_bottom + $map_height + $border , $mapOffset_left + $map_width + $border, $mapOffset_bottom - $border);
-				   //bottom
-				   $pdf->line($mapOffset_left + $map_width + $border, $mapOffset_bottom -$border , $mapOffset_left - $border, $mapOffset_bottom - $border);
-						$pdf->addPngFromFile($legendImage, $mapOffset_left + $map_width + $border - $legendImage_width -6, $mapOffset_bottom + $map_height + $border - $legendImage_height -4 , $legendImage_width, $legendImage_height);
-						//line under legend (only landscape)
-						//$pdf->line($mapOffset_left - $border, $mapOffset_bottom + $map_height + $border  - $legendImage_height - 4 , $mapOffset_left + $map_width + $border, $mapOffset_bottom + $map_height + $border - $legendImage_height - 6);
-			}// for layers
-		} //if wms_id not 0
-	}// for wms
-    * USER POLYGON:
-   if($_POST['measured_x_values'] != ""
-      && $_POST['measured_y_values'] != ""
-        && is_file($legendFilenameUserPolygon)) {
-     // load image
-       $myY = $pdf->ezText("<b>temporary Object</b>", 11);
-       $pdf->ezSetDy(-15);
-       $pdf->ezImage($legendFilenameUserPolygon, 5, 17, 'none', 'left');
-       		unlink($legendFilenameUserPolygon);
-       $pdf->ezSetY($myY - 7);
-        $pdf->ezText("Element", 11, array("left" => 25));
-             // deletes image
-$pdf->ezText($legendFooter, 11);
-}//legend true
-    end of legend
-ob_clean();
-if($download == false){
-	$pdf->ezStream();
-else{
-	$content = $pdf->ezOutput();
-	$fp = fopen($downloadFile,'w');
-	fwrite($fp,$content);
-	fclose($fp);
-	echo "<html><head></head><body><a href='".$downloadFile."'>".$downloadText."</a></body></html>";
+<?php
+# $Id:
+# http://www.mapbender.org/index.php/mod_printPDF_pdf.php
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+#require_once("../php/mb_validateSession.php");
+ob_start();
+session_start();
+ini_set('error_reporting', 'E_ALL & ~ E_NOTICE');
+require_once(dirname(__FILE__)."/../../conf/mapbender.conf");
+include (dirname(__FILE__)."/../classes/class.ezpdf.php");
+include (dirname(__FILE__)."/../classes/class_stripRequest.php");
+include (dirname(__FILE__)."/../classes/class_weldMaps2PNG.php");
+include (dirname(__FILE__)."/../classes/class_weldOverview2PNG.php");
+include (dirname(__FILE__)."/../print/".$_REQUEST["conf"]);
+include (dirname(__FILE__)."/../classes/class_SaveLegend.php");
+include (dirname(__FILE__)."/../print/print_functions.php");
+if($log == true){
+	include (dirname(__FILE__)."/../classes/class_log.php");
+#Globals
+$factor = intval($_REQUEST["quality"]);
+#$date = date("d.m.Y",strtotime("now"));
+$linewidth_dashed = 0.5;
+$linewidth = 0.5;
+// DURATION TIME:
+function microtime_float(){
+   list($usec, $sec) = explode(" ", microtime());
+   return ((float)$usec + (float)$sec);
+$time_start = microtime_float();
+// END DURATION TIME
+$time_end = microtime_float();
+$time = $time_end - $time_start;
+$size = $_REQUEST["size"];
+$format = $_REQUEST["format"];
+$map_scale = $_REQUEST["map_scale"];
+$overview_url = $_REQUEST["overview_url"];
+$epsg = $_REQUEST["epsg"];
+function setscalebar($scale){
+    	$mb_resolution = 28.35;
+		if($scale < 16){
+	      $value = "10";
+	      $unit = "cm";
+	      $scalefactor = 10/$scale;
+	      $img_width = round($scalefactor * $mb_resolution);
+	   if($scale >= 16 && $scale < 151){
+	      $value = "1";
+	      $unit = "Meter";
+	      $scalefactor = 100/$scale;
+	   if($scale >= 151 && $scale < 1550 ){
+	      $value = "10";
+	      $unit = "Meter";
+	      $scalefactor = 1000/$scale;
+	   if($scale >= 1550 && $scale < 15050){
+	      $value = "100";
+	      $unit = "Meter";
+	      $scalefactor = 10000/$scale;
+	   if($scale < 150050 && $scale >= 15050){
+	      $value = "1";
+	      $unit = "Kilometer";
+	      $scalefactor = 100000/$scale;
+	   if($scale < 1500050 && $scale >= 150050){
+	      $value = "10";
+	      $scalefactor = 1000000/$scale;
+	   if($scale < 15000050 && $scale >= 1500050){
+	      $value = "100";
+	      $scalefactor = 10000000/$scale;
+	   if($scale < 150000001 && $scale >= 15000001){
+	      $value = "1000";
+	      $scalefactor = 100000000/$scale;
+	   if($scale >= 150000001){
+	      $value = "1000";
+	   $array_scale[0] = $unit;
+	   $array_scale[1] = $img_width;
+		$array_scale[2] = $value;
+	   return  $array_scale;
+$border = 0.8 * $DPC;
+if($matching == true){
+   $urls = str_replace($pattern,$replacement,$_REQUEST["map_url"]);
+else{
+   $urls = $_REQUEST["map_url"];
+$array_urls = explode("___", $urls);
+$myURL = new stripRequest($array_urls[0]);
+$map_width = round($myURL->get("width"));
+$map_height = round($myURL->get("height"));
+$map_extent = $myURL->get("BBOX");
+if($factor>1){
+	for($i=0; $i<count($array_urls); $i++){
+		$m = new stripRequest($array_urls[$i]);
+		$m->set('width',(intval($m->get('width'))*4));
+		$m->set('height',(intval($m->get('height'))*4));
+		if(in_array($m->get('map'),$highqualitymapfiles)){
+			$m->set('map',str_replace(".map","_4.map",$m->get('map')));
+		$array_urls[$i] = $m->url;
+$coord = split(",",$map_extent);
+// analyse overview url and draw rectangle with position
+$o_url = new stripRequest($overview_url);
+$overview_width = round($o_url->get("width"));
+$overview_height = round($o_url->get("height"));
+if($factor>1){
+	$o_url->set('width',(intval($o_url->get('width'))*4));
+	$o_url->set('height',(intval($o_url->get('height'))*4));
+	if(in_array($o_url->get('map'),$highqualitymapfiles)){
+			$o_url->set('map',str_replace(".map","_4.map",$o_url->get('map')));
+			$overview_url = $o_url->url;
+	$overview_url = str_replace($pattern,$replacement,$overview_url);
+if ($size == "A4" && $format == "portrait"){
+	$overview_left = $a4p_overviewOffset_left;
+	$overview_bottom =$a4p_overviewOffset_bottom;
+}elseif ($size == "A4" && $format == "landscape"){
+	$overview_left = $a4l_overviewOffset_left;
+	$overview_bottom =$a4l_overviewOffset_bottom;
+}elseif ($size == "A3" && $format == "portrait"){
+	$overview_left = $a3p_overviewOffset_left;
+	$overview_bottom =$a3p_overviewOffset_bottom;
+}elseif ($size == "A3" && $format == "landscape"){
+	$overview_left = $a3l_overviewOffset_left;
+	$overview_bottom = $a3l_overviewOffset_bottom;
+}elseif ($size == "A2" && $format == "portrait"){
+	$overview_left = $a2p_overviewOffset_left;
+	$overview_bottom =$a2p_overviewOffset_bottom;
+}elseif ($size == "A2" && $format == "landscape"){
+	$overview_left = $a2l_overviewOffset_left;
+	$overview_bottom = $a2l_overviewOffset_bottom;
+}elseif ($size == "A1" && $format == "portrait"){
+	$overview_left = $a1p_overviewOffset_left;
+	$overview_bottom =$a1p_overviewOffset_bottom;
+}elseif ($size == "A1" && $format == "landscape"){
+	$overview_left = $a1l_overviewOffset_left;
+	$overview_bottom = $a1l_overviewOffset_bottom;
+}elseif ($size == "A0" && $format == "portrait"){
+	$overview_left = $a0p_overviewOffset_left;
+	$overview_bottom =$a0p_overviewOffset_bottom;
+}elseif ($size == "A0" && $format == "landscape"){
+	$overview_left = $a0l_overviewOffset_left;
+	$overview_bottom = $a0l_overviewOffset_bottom;
+$o_extent = $o_url->get("BBOX");
+$array_overview_url[0] = $overview_url;
+if($log == true){
+	$l = new log("printPDF_overview",$array_overview_url);
+$o_new = new stripRequest($overview_url);
+$o_new->set('width',50);
+$o_new->set('height',50);
+//$o->set('BBOX',$overview_extent);
+$o_url_new =$o_new->url;
+$array_overview[0] = $overview_url;
+$array_overview[1] = $o_url;
+ * north arrow
+if($size == "A4" && $format == "portrait"){
+	$northarrow_left = $a4p_northarrow_left;
+	$northarrow_bottom = $a4p_northarrow_bottom;
+	$northarrow_left = $a4l_northarrow_left;
+	$northarrow_bottom = $a4l_northarrow_bottom;
+	$northarrow_left = $a3p_northarrow_left;
+	$northarrow_bottom = $a3p_northarrow_bottom;
+	$northarrow_left = $a3l_northarrow_left;
+	$northarrow_bottom = $a3l_northarrow_bottom;
+	$northarrow_left = $a2p_northarrow_left;
+	$northarrow_bottom = $a2p_northarrow_bottom;
+	$northarrow_left = $a2l_northarrow_left;
+	$northarrow_bottom = $a2l_northarrow_bottom;
+	$northarrow_left = $a1p_northarrow_left;
+	$northarrow_bottom = $a1p_northarrow_bottom;
+	$northarrow_left = $a1l_northarrow_left;
+	$northarrow_bottom = $a1l_northarrow_bottom;
+	$northarrow_left = $a0p_northarrow_left;
+	$northarrow_bottom = $a0p_northarrow_bottom;
+	$northarrow_left = $a0l_northarrow_left;
+	$northarrow_bottom = $a0l_northarrow_bottom;
+ * special image
+	$specialImage_left = $a4p_special_left;
+	$specialImage_bottom = $a4p_special_bottom;
+	$specialImage_left = $a4l_special_left;
+	$specialImage_bottom = $a4l_special_bottom;
+	$specialImage_left = $a3p_special_left;
+	$specialImage_bottom = $a3p_special_bottom;
+	$specialImage_left = $a3l_special_left;
+	$specialImage_bottom = $a3l_special_bottom;
+	$specialImage_left = $a2p_special_left;
+	$specialImage_bottom = $a2p_special_bottom;
+	$specialImage_left = $a2l_special_left;
+	$specialImage_bottom = $a2l_special_bottom;
+	$specialImage_left = $a1p_special_left;
+	$specialImage_bottom = $a1p_special_bottom;
+	$specialImage_left = $a1l_special_left;
+	$specialImage_bottom = $a1l_special_bottom;
+	$specialImage_left = $a0p_special_left;
+	$specialImage_bottom = $a0p_special_bottom;
+	$specialImage_left = $a0l_special_left;
+	$specialImage_bottom = $a0l_special_bottom;
+if($log == true){
+	$l = new log("printPDF",$array_urls);
+$pdf = new Cezpdf();
+$pdf->Cezpdf(strtolower($size),$format);
+$diff=array(196=>'Adieresis',228=>'adieresis',
+   214=>'Odieresis',246=>'odieresis',
+   220=>'Udieresis',252=>'udieresis',
+   223=>'germandbls');
+$pdf->selectFont('../classes/fonts/Helvetica.afm', array('encoding'=>'WinAnsiEncoding','differences'=>$diff));
+	$mapOffset_left = $a4p_mapOffset_left;
+	$mapOffset_bottom = $a4p_mapOffset_bottom;
+	$header_height = $a4p_header_height;
+	$footer_height = $a4p_footer_height;
+else{
+	$mapOffset_left = $a4l_mapOffset_left;
+	$mapOffset_bottom = $a4l_mapOffset_bottom;
+	$header_height = $a4l_header_height;
+	$header_width = $a4l_header_width;
+session_write_close();
+$i = new weldMaps2PNG(implode("___",$array_urls),$filename);
+$pdf->addPngFromFile($filename, $mapOffset_left, $mapOffset_bottom, $map_width, $map_height);
+if($unlink == true){
+	unlink($filename);
+* user drawn elements
+$theMeasureConfigArray = array(
+   "do_fill" => FALSE,
+     "fill_color" => array(
+     "r" => 128 / 255,
+     "g" => 128 / 255,
+     "b" => 128 / 255
+   "do_stroke" => TRUE,
+     "stroke_color" => array(
+     "r" => 254 / 255,
+     "g" => 1 / 255,
+     "b" => 1 / 255
+   "line_style" => array(
+       "width" => 2,
+       "cap" => 'butt',
+       "join" => 'miter',
+       "dash" => array(10, 6)
+//if ($_POST['measured_x_values']!=''){
+//	addMeasuredItem(&$pdf, $_POST['measured_x_values'], $_POST['measured_y_values'], $theMeasureConfigArray);
+//	hideElementsOutsideMapframe(&$pdf);
+# dashed line
+$pdf->setLineStyle($linewidth_dashed, '','', array(2,2));
+$pdf->line($mapOffset_left - $linewidth_dashed, $mapOffset_bottom - $linewidth_dashed, $mapOffset_left - $linewidth_dashed, $mapOffset_bottom  + $map_height + $linewidth_dashed);
+$pdf->line($mapOffset_left - $linewidth_dashed, $mapOffset_bottom  + $map_height + $linewidth_dashed, $mapOffset_left + $map_width + $linewidth_dashed, $mapOffset_bottom + $map_height + $linewidth_dashed);
+$pdf->line($mapOffset_left + $map_width + $linewidth_dashed, $mapOffset_bottom + $map_height + $linewidth_dashed, $mapOffset_left + $map_width + $linewidth_dashed, $mapOffset_bottom -$linewidth_dashed);
+$pdf->line($mapOffset_left + $map_width + $linewidth_dashed, $mapOffset_bottom -$linewidth_dashed, $mapOffset_left - $linewidth_dashed, $mapOffset_bottom - $linewidth_dashed);
+#line
+$pdf->setLineStyle($linewidth, '', '', array());
+$pdf->line($mapOffset_left - $border, $mapOffset_bottom - $border, $mapOffset_left - $border, $mapOffset_bottom  + $map_height + $border);
+$pdf->line($mapOffset_left - $border, $mapOffset_bottom  + $map_height + $border, $mapOffset_left + $map_width + $border, $mapOffset_bottom + $map_height + $border);
+$pdf->line($mapOffset_left + $map_width + $border, $mapOffset_bottom + $map_height + $border, $mapOffset_left + $map_width + $border, $mapOffset_bottom -$border);
+$pdf->line($mapOffset_left + $map_width + $border, $mapOffset_bottom -$border, $mapOffset_left - $border, $mapOffset_bottom - $border);
+if($epsg == "EPSG:4326"){
+	$text4 = "";
+   #header:
+   $pdf->line($mapOffset_left - $border, $mapOffset_bottom  + $map_height + $border, $mapOffset_left - $border, $mapOffset_bottom  + $map_height + $border + $header_height);
+   $pdf->line($mapOffset_left - $border, $mapOffset_bottom  + $map_height + $border + $header_height, $mapOffset_left + $map_width + $border, $mapOffset_bottom  + $map_height + $border + $header_height);
+   $pdf->line($mapOffset_left + $map_width + $border, $mapOffset_bottom  + $map_height + $border + $header_height, $mapOffset_left + $map_width + $border, $mapOffset_bottom  + $map_height + $border);
+   $pdf->line( $mapOffset_left + $map_width/2, $mapOffset_bottom  + $map_height + $border, $mapOffset_left + $map_width/2, $mapOffset_bottom  + $map_height + $border + $header_height);
+   #header-text
+   $mySize = 9;
+   $length = $pdf->getTextWidth($mySize, $text1);
+   $pdf->addText($mapOffset_left - ($border/2) + ($map_width/4) - ($length/2),$mapOffset_bottom + $map_height + $border + 60,$mySize,$text1);
+   $mySize = 8;
+   $length = $pdf->getTextWidth($mySize, $text2);
+   $pdf->addText($mapOffset_left - ($border/2) + ($map_width/4) - ($length/2),$mapOffset_bottom + $map_height + $border + 45,$mySize,$text2);
+   $length = $pdf->getTextWidth($mySize, $text3);
+   $pdf->addText($mapOffset_left - ($border/2) + ($map_width/4) - ($length/2),$mapOffset_bottom + $map_height + $border + 35,$mySize,$text3);
+   $mySize = 9;
+   $length = $pdf->getTextWidth($mySize, $text4);
+   $pdf->addText($mapOffset_left - ($border/2) + ($map_width/4) - ($length/2),$mapOffset_bottom + $map_height + $border + 20,$mySize,$text4);
+   $mySize = 8;
+   $length = $pdf->getTextWidth($mySize, $text5);
+   $pdf->addText($mapOffset_left - ($border/2) + ($map_width/4) - ($length/2),$mapOffset_bottom + $map_height + $border + 10,$mySize,$text5);
+   $mySize = 9;
+   $length = $pdf->getTextWidth($mySize, $text6);
+   $pdf->addText($mapOffset_left + ($border/2) + ($map_width/4*3) - ($length/2),$mapOffset_bottom + $map_height + $border + 60,$mySize,$text6);
+   $length = $pdf->getTextWidth($mySize, $text7);
+   $pdf->addText($mapOffset_left + ($border/2) + ($map_width/4*3) - ($length/2),$mapOffset_bottom + $map_height + $border + 50,$mySize,$text7);
+   $length = $pdf->getTextWidth($mySize, $text8);
+   $pdf->addText($mapOffset_left + ($border/2) + ($map_width/4*3) - ($length/2),$mapOffset_bottom + $map_height + $border + 30,$mySize,$text8);
+   $length = $pdf->getTextWidth($mySize, $text9);
+   $pdf->addText($mapOffset_left + ($border/2) + ($map_width/4*3) - ($length/2),$mapOffset_bottom + $map_height + $border + 20,$mySize,$text9);
+   $length = $pdf->getTextWidth($mySize, $text10);
+   $pdf->addText($mapOffset_left + ($border/2) + ($map_width/4*3) - ($length/2),$mapOffset_bottom + $map_height + $border + 10,$mySize,$text10);
+   //special image on the map-page
+   if ($special == true){
+   	$pdf->addPngFromFile($specialImage, $specialImage_left, $specialImage_bottom , $specialImage_width, $specialImage_height);
+   #footer
+   $pdf->line($mapOffset_left - $border, $mapOffset_bottom - $border, $mapOffset_left - $border, $mapOffset_bottom - $border - $footer_height);
+   $pdf->line($mapOffset_left - $border, $mapOffset_bottom - $border - $footer_height, $mapOffset_left + $map_width + $border, $mapOffset_bottom - $border - $footer_height);
+   $pdf->line($mapOffset_left + $map_width + $border, $mapOffset_bottom - $border - $footer_height, $mapOffset_left + $map_width + $border, $mapOffset_bottom - $border);
+   $mySize = 8;
+   $length = $pdf->getTextWidth($mySize, $text11);
+   $pdf->addText( $mapOffset_left + $map_width/2 - ($length/2),$mapOffset_bottom - $border - 10,$mySize,$text11);
+   $mySize = 6;
+   $length = $pdf->getTextWidth($mySize, $text12);
+   $pdf->addText( $mapOffset_left + $map_width/2 - ($length/2),$mapOffset_bottom - $border - 18,$mySize,$text12);
+   $length = $pdf->getTextWidth($mySize, $text13);
+   $pdf->addText( $mapOffset_left + $map_width/2 - ($length/2),$mapOffset_bottom - $border - 25,$mySize,$text13);
+else{
+   $pdf->setColor(1,1,1);
+   $ll = array($mapOffset_left + $map_width - $header_width + $border - $linewidth, $mapOffset_bottom - $border + 1);
+   $pdf->filledRectangle($ll[0], $ll[1], $header_width,$header_height);
+   $pdf->line($ll[0], $ll[1], $ll[0], $ll[1] + $header_height);
+   $pdf->line($ll[0], $ll[1] + $header_height, $ll[0] + $header_width, $ll[1] + $header_height);
+   $pdf->line($ll[0] + 2, $ll[1] + 2, $ll[0] + 2,  $ll[1] + $header_height - 2);
+   $pdf->line($ll[0] + 2,  $ll[1] + $header_height - 2, $ll[0] - 2 + $header_width, $ll[1] + $header_height - 2);
+   $pdf->line($ll[0] - 2 + $header_width, $ll[1] + $header_height - 2, $ll[0] - 2 + $header_width, $ll[1] + 2);
+   $pdf->line($ll[0] - 2 + $header_width, $ll[1] + 2, $ll[0] + 2, $ll[1] + 2);
+   $pdf->line($ll[0] + 2, $ll[1] + 110 , $ll[0] - 2 + $header_width, $ll[1] + 110);
+   $pdf->line($ll[0] + 2, $ll[1] + 40 , $ll[0] - 2 + $header_width, $ll[1] + 40);
+    if($epsg == "EPSG:4326"){
+	$text4 = "";
+   $pdf->setColor(0,0,0);
+   $mySize = 9;
+   $pdf->addText($ll[0] + $header_width/2 - $length/2,185,$mySize,$text1);
+   $mySize = 8;
+   $pdf->addText($ll[0] + $header_width/2 - $length/2,175,$mySize,$text2);
+   $pdf->addText($ll[0] + $header_width/2 - $length/2,165,$mySize,$text3);
+   $mySize = 9;
+   $pdf->addText($ll[0] + $header_width/2 - $length/2,155,$mySize,$text4);
+   $mySize = 8;
+   $pdf->addText($ll[0] + $header_width/2 - $length/2,145,$mySize,$text5);
+   $mySize = 9;
+   $pdf->addText($ll[0] + $header_width/2 - $length/2,125,$mySize,$text6);
+   $pdf->addText($ll[0] + $header_width/2 - $length/2,115,$mySize,$text7);
+   $pdf->addText($ll[0] + $header_width/2 - $length/2,95,$mySize,$text8);
+   $pdf->addText($ll[0] + $header_width/2 - $length/2,85,$mySize,$text9);
+   $pdf->addText($ll[0] + $header_width/2 - $length/2,75,$mySize,$text10);
+   $mySize = 8;
+   $pdf->addText($ll[0] + $header_width/2 - $length/2,60,$mySize,$text11);
+   $mySize = 6;
+   $length = $pdf->getTextWidth($mySize, $text14);
+   $pdf->addText($ll[0] + $header_width/2 - $length/2,53,$mySize,$text14);
+   $length = $pdf->getTextWidth($mySize, $text15);
+   $pdf->addText($ll[0] + $header_width/2 - $length/2,47,$mySize,$text15);
+   $length = $pdf->getTextWidth($mySize, $text16);
+   $pdf->addText($ll[0] + $header_width/2 - $length/2,41,$mySize,$text16);
+   $length = $pdf->getTextWidth($mySize, $text17);
+   $pdf->addText($ll[0] + $header_width/2 - $length/2,35,$mySize,$text17);
+#Coordinates
+$myMinx = "R ".substr(round($coord[0]), 0, 4)." ".substr(round($coord[0]), 4, 3)."";
+$myMiny = "H ".substr(round($coord[1]), 0, 4)." ".substr(round($coord[1]), 4, 3)."";
+$myMaxx = "R ".substr(round($coord[2]), 0, 4)." ".substr(round($coord[2]), 4, 3)."";
+$myMaxy = "H ".substr(round($coord[3]), 0, 4)." ".substr(round($coord[3]), 4, 3)."";
+$mySize = 9;
+$pdf->addText($mapOffset_left - 3, $mapOffset_bottom, $mySize, $myMinx, -90);
+$pdf->addText($mapOffset_left, $mapOffset_bottom  - ($pdf->getFontHeight($mySize)), $mySize, $myMiny);
+$pdf->addText($mapOffset_left  + $map_width - ($pdf->getTextWidth($mySize, $myMaxx)), $mapOffset_bottom + $map_height  + 3, $mySize, $myMaxx);
+$pdf->addText($mapOffset_left + $map_width + 3, $mapOffset_bottom + $map_height, $mySize, $myMaxy, 90);
+if ($overview==true){
+	// analyse request, draw rectancle
+	$filename = str_replace("map_","overview_",$filename);
+	if($size == "A4" && $format == "portrait"){
+		$i = new weldOverview2PNG($overview_url,$array_urls[0] ,$filename);
+		$pdf->addPngFromFile($filename, $overview_left,$overview_bottom, $overview_width, $overview_height);
+		if($unlink == true){
+	else{
+		$i = new weldOverview2PNG($overview_url,$array_urls[0],$filename);
+		//$pdf->addPngFromFile($filename, $mapOffset_left,$mapOffset_bottom, $overview_width, $overview_height);
+if ($northarrow==true){
+	$pdf->addPngFromFile($northarrowImage, $northarrow_left, $northarrow_bottom , $northarrowImage_width, $northarrowImage_height);
+	$scalebar = false;
+else{
+	$scalebar = true;
+if($scalebar == true){
+	if ($size == "A4" && $format == "portrait"){
+		$scalebar_left = $a4p_scalebar_left;
+		$scalebar_bottom = $a4p_scalebar_bottom;
+	}elseif ($size == "A4" && $format == "landscape"){
+		$scalebar_left = $a4l_scalebar_left;
+		$scalebar_bottom = $a4l_scalebar_bottom;
+	}elseif ($size == "A3" && $format == "portrait"){
+		$scalebar_left = $a3p_scalebar_left;
+		$scalebar_bottom = $a3p_scalebar_bottom;
+	}elseif ($size == "A3" && $format == "landscape"){
+		$scalebar_left = $a3l_scalebar_left;
+		$scalebar_bottom = $a3l_scalebar_bottom;
+	}elseif ($size == "A2" && $format == "portrait"){
+		$scalebar_left = $a2p_scalebar_left;
+		$scalebar_bottom = $a2p_scalebar_bottom;
+	}elseif ($size == "A2" && $format == "landscape"){
+		$scalebar_left = $a2l_scalebar_left;
+		$scalebar_bottom = $a2l_scalebar_bottom;
+	}elseif ($size == "A1" && $format == "portrait"){
+		$scalebar_left = $a1p_scalebar_left;
+		$scalebar_bottom = $a1p_scalebar_bottom;
+	}elseif ($size == "A1" && $format == "landscape"){
+		$scalebar_left = $a1l_scalebar_left;
+		$scalebar_bottom = $a1l_scalebar_bottom;
+	}elseif ($size == "A0" && $format == "portrait"){
+		$scalebar_left = $a0p_scalebar_left;
+		$scalebar_bottom = $a0p_scalebar_bottom;
+	}elseif ($size == "A0" && $format == "landscape"){
+		$scalebar_left = $a0l_scalebar_left;
+		$scalebar_bottom = $a0l_scalebar_bottom;
+	$array_scalebar = setscalebar($map_scale);
+	$scalebar_left = $scalebar_left + $header_width/2 - $array_scalebar[1]/2;
+	$pdf->setLineStyle($scalebar_height, '','', array());
+	#$pdf->line($scalebar_left, $scalebar_bottom , $scalebar_left - 200 + $array_scalebar[1], $scalebar_bottom);
+	$pdf->filledRectangle($scalebar_left, $scalebar_bottom, $array_scalebar[1],$scalebar_height);
+	$pdf->filledRectangle($scalebar_left + $array_scalebar[1]/4 + 1 , $scalebar_bottom + 1, $array_scalebar[1]/4 - 1 ,$scalebar_height-2);
+	$pdf->filledRectangle($scalebar_left + 3*($array_scalebar[1]/4) + 1 , $scalebar_bottom + 1, $array_scalebar[1]/4 - 2 ,$scalebar_height-2);
+	#$pdf->setColor(1,0,1);
+	#$pdf->filledRectangle($scalebar_left  , $scalebar_bottom - 20, 1 * $DPC ,$scalebar_height-2);
+	# value - Einheiten
+   $mySize = 8;
+   $scalebar_height_half = 0.5 * $scalebar_height;
+	$myText = 0;
+   $length = $pdf->getTextWidth($mySize, $myText);
+   $pdf->addText($scalebar_left - $length/2 ,$scalebar_bottom + 9 ,$mySize,$myText);
+	$myText = $array_scalebar[2]/2;
+   $pdf->addText($scalebar_left + $array_scalebar[1]/2 - $length/2 ,$scalebar_bottom + 9 ,$mySize,$myText);
+	$myText = $array_scalebar[2];
+   $pdf->addText($scalebar_left + $array_scalebar[1] - $length/2 - $length/4 ,$scalebar_bottom + 9 ,$mySize,$myText);
+   $mySize = 8;
+   $myText = $array_scalebar[0];
+   #$pdf->addText($scalebar_left + $scalebar_width + 5,$scalebar_bottom - $scalebar_height_half ,$mySize,$myText);
+	#units
+   $pdf->addText($scalebar_left + $array_scalebar[1]/2 - $length/2 ,$scalebar_bottom - 12 ,$mySize,$myText);
+    new page for legend
+if ($legend == true && $_REQUEST["mylegend"]=='true'){
+	$pdf->ezNewPage();
+	//Pageborder (top, bottom, left, right)
+	  $pdf->ezSetMargins(50,50,80,30);
+	} else {
+	  $pdf->ezSetMargins(60,35,60,60);
+	//Requests
+	if(CHARSET=="UTF-8"){
+		$new_wms_title=utf8_decode($_REQUEST["wms_title"]);
+	}else{
+		$new_wms_title=$_REQUEST["wms_title"];
+		$new_layers=utf8_decode($_REQUEST["layers"]);
+	}else{
+		$new_layers=$_REQUEST["layers"];
+	$my_wms_id = explode("___",$_REQUEST["wms_id"]);
+	$my_wms_title = explode("___",$new_wms_title);
+	$my_layers = explode("___",$new_layers);
+	if($matching == true){
+        $my_legend = str_replace($pattern,$replacement,$_REQUEST["legendurl"]);
+    else{
+        $my_legend = $_REQUEST["legendurl"];
+    $my_legend = explode("___",$my_legend);
+	//columns
+	  $pdf->ezColumnsStart(array ('num'=>2, 'gap'=>10));
+	} else {
+	  $pdf->ezColumnsStart(array ('num'=>3, 'gap'=>10));
+	//header from printPDF.conf
+	//$pdf->ezText("<b>".$titel."</b>", 13);
+	$pdf->ezText("<b><u>".$legendText."</u></b>", 13);
+	//Seitenraender (top, bottom, left, right)
+	  $pdf->ezSetMargins(70,35,80,30);
+	} else {
+	  $pdf->ezSetMargins(100,35,60,60);
+	//generate the legend---------------------------------------------
+	// Gesamthoehe Legende / height of the legend
+	$sum_legend_height = 0;
+	for($i=0; $i<count($my_wms_id); $i++){
+		if ($my_wms_id[$i] != '0'){  //wms_id not 0
+			$layer = explode(",",$my_layers[$i]);
+			$my_legendurls = explode(",",$my_legend[$i]);
+			$wms_y_position = $pdf->ezText("<b>".$my_wms_title[$i]."</b>", 12, array('spacing'=>1.2));
+			$wms_zeilenhoehe   =  $pdf->getFontHeight(12);
+			// add this to the height of the legend /addiere dies zur Gesamthoehe Legende
+			$sum_legend_height += $wms_zeilenhoehe;
+			//Layer
+			$l = 0;		#l temporary parameter to count the layer /Hilfvariable zum durchz�hlen der angezeigten Layer
+			for($j=0; $j<count($my_legendurls); $j++){
+				// url with grouped layers------------------
+				$temp_url = explode('*',$my_legendurls[$j]);
+				$temp_layers = explode('*',$layer[$j]);
+				for ($q=0; $q <count($temp_url);$q++){
+					if($temp_url[$q] == '1' ){			// Layertitle for the parent of grouped layers
+						// add this to the height of the legend /addiere dies zur Gesamth�he Legende
+						$layer_y_position = $pdf->ezText($temp_layers[$q], 11, array('spacing'=>1.2));
+						$layer_zeilenhoehe   =  $pdf->getFontHeight(12);
+						$sum_legend_height += $layer_zeilenhoehe;
+					}elseif($temp_url[$q] != '0' ){
+						$funktionsaufruf = new SaveLegend($temp_url[$q],$legendFilename);
+						$imgsize = getimagesize($legendFilename);
+						// add this to the height of the legend /addiere dies zur Gesamthoehe der Legende
+						$sum_legend_height += $imgsize[1];
+						//calculate text + picture / Berechnung Groesse Schrift + Bild
+						if($l == 0){
+						       $y_position = $wms_y_position;
+						       $wms_y_position = '';
+						}else{
+							 $y_position = $pdf->ezText("", 1, array('spacing'=>1.2));
+						$layer_zeilenhoehe = $pdf->getFontHeight(11);
+						$next_position = $y_position - $layer_zeilenhoehe - $imgsize[1];
+						// add this to the height of the legend / addiere dies zur Gesamth�he Legende
+						$l = $l+1;
+		     			// if text + picture are smaler then the lower margin + textsize, then set a space
+						//wenn Schrift + Bild kleiner der unteren Margin + Zeilenhoehe, dann Abstand setzen
+						 if($size == "A4" && $format == "portrait" && $next_position <= 35 +$layer_zeilenhoehe){ //90 $layer_zeilenhoehe
+							$space = $layer_zeilenhoehe + $imgsize[1];
+						  $pdf->ezSetDy(-$space);
+						if($size == "A4" && $format == "landscape" && $next_position <= 35+$layer_zeilenhoehe){//50
+						//write the header layername / Ueberschrift schreiben
+						$legend = $temp_layers[$q]."\n";  //$layer[$j]."\n";
+						$pdf->ezText($legend, 11, array('spacing'=>1.2));
+						//$pdf->ezText($url, 9, array('spacing'=>1.2));
+						//print the picture / Bild schreiben
+						$pdf->ezImage($legendFilename, 0, 'width', 'none', 'left');
+							unlink($legendFilename);
+					} //if legendurl
+				}// for legendurl
+			  	//frames (x1, y1, x2, y2)
+					#line
+					$pdf->setLineStyle($linewidth, '', '', array());
+					//left
+					$pdf->line($mapOffset_left - $border, $mapOffset_bottom - $border - $footer_height, $mapOffset_left - $border, $mapOffset_bottom  + $map_height + $border + $header_height);
+					//right
+					//top
+					$pdf->line($mapOffset_left + $map_width + $border, $mapOffset_bottom + $map_height + $border + $header_height, $mapOffset_left + $map_width + $border, $mapOffset_bottom - $border - $footer_height);
+					//bottom
+					$pdf->line($mapOffset_left + $map_width + $border, $mapOffset_bottom -$border - $footer_height, $mapOffset_left - $border, $mapOffset_bottom - $border - $footer_height);
+					if ($legendImage!=''){
+						//image on top of page
+						$pdf->addPngFromFile($legendImage, $mapOffset_left + $map_width + $border - $legendImage_width -6, $mapOffset_bottom + $map_height + $border + $header_height - $legendImage_height - 4 , $legendImage_width, $legendImage_height);
+				} else {
+				  //left
+				  $pdf->line($mapOffset_left - $border, $mapOffset_bottom - $border, $mapOffset_left - $border, $mapOffset_bottom  + $map_height + $border);
+				  //right
+				  $pdf->line($mapOffset_left - $border, $mapOffset_bottom  + $map_height + $border , $mapOffset_left + $map_width + $border, $mapOffset_bottom + $map_height + $border);
+				  //top
+				  $pdf->line($mapOffset_left + $map_width + $border, $mapOffset_bottom + $map_height + $border , $mapOffset_left + $map_width + $border, $mapOffset_bottom - $border);
+				   //bottom
+				   $pdf->line($mapOffset_left + $map_width + $border, $mapOffset_bottom -$border , $mapOffset_left - $border, $mapOffset_bottom - $border);
+						$pdf->addPngFromFile($legendImage, $mapOffset_left + $map_width + $border - $legendImage_width -6, $mapOffset_bottom + $map_height + $border - $legendImage_height -4 , $legendImage_width, $legendImage_height);
+						//line under legend (only landscape)
+						//$pdf->line($mapOffset_left - $border, $mapOffset_bottom + $map_height + $border  - $legendImage_height - 4 , $mapOffset_left + $map_width + $border, $mapOffset_bottom + $map_height + $border - $legendImage_height - 6);
+			}// for layers
+		} //if wms_id not 0
+	}// for wms
+    * USER POLYGON:
+   if($_POST['measured_x_values'] != ""
+      && $_POST['measured_y_values'] != ""
+        && is_file($legendFilenameUserPolygon)) {
+     // load image
+       $myY = $pdf->ezText("<b>temporary Object</b>", 11);
+       $pdf->ezSetDy(-15);
+       $pdf->ezImage($legendFilenameUserPolygon, 5, 17, 'none', 'left');
+       		unlink($legendFilenameUserPolygon);
+       $pdf->ezSetY($myY - 7);
+        $pdf->ezText("Element", 11, array("left" => 25));
+             // deletes image
+$pdf->ezText($legendFooter, 11);
+}//legend true
+    end of legend
+ob_clean();
+if($download == false){
+	$pdf->ezStream();
+else{
+	$content = $pdf->ezOutput();
+	$fp = fopen($downloadFile,'w');
+	fwrite($fp,$content);
+	fclose($fp);
+	echo "<html><head></head><body><a href='".$downloadFile."'>".$downloadText."</a></body></html>";
More information about the Mapbender_commits mailing list
