[Mapbender-commits] r1296 - trunk/mapbender/http/classes
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Sat May 5 07:39:52 EDT 2007
Author: marcjansen
Date: 2007-05-05 07:39:52 -0400 (Sat, 05 May 2007)
New Revision: 1296
   trunk/mapbender/http/classes/class_administration.php
PHPdoc comments added
Modified: trunk/mapbender/http/classes/class_administration.php
--- trunk/mapbender/http/classes/class_administration.php	2007-05-05 11:04:24 UTC (rev 1295)
+++ trunk/mapbender/http/classes/class_administration.php	2007-05-05 11:39:52 UTC (rev 1296)
@@ -20,77 +20,106 @@
 $con = db_connect(DBSERVER,OWNER,PW);
 db_select_db(DB,$con);
-require("phpmailer-1.72/class.phpmailer.php");
+require("phpmailer-1.72/class.phpmailer.php");
+ * class to wrap administration methods
+ * @uses phpmailer
 class administration{
+     * checks whether the passed email-address is valid / following a pattern
+     * @todo is this an exact representation of the RFC 2822?
+     * @todo this should be checked: what about umlaut-domains and tld like '.museum'?
+     * @see http://tools.ietf.org/html/rfc2822
+     * @param <string> a all lowercase email adress to test
+     * @return <boolean> answer to "is the passed over email valid?""
 	function isValidEmail($email) {
-		if(eregi("^[_a-z0-9-]+(\.[_a-z0-9-]+)*@[a-z0-9-]+(\.[a-z0-9-]+)*(\.[a-z]{2,3})$", $email)) {
+        if(eregi("^[_a-z0-9-]+(\.[_a-z0-9-]+)*@[a-z0-9-]+(\.[a-z0-9-]+)*(\.[a-z]{2,3})$", $email)) {
             return true;
 		return false;
+     * sends an email via php mailer
+     * @param <string> an email address for the "From"-field
+     * @param <string> the displayed name for the "From"-field
+     * @param <string> an email address for the "To"-field
+     * @param <string> the text to be set as "Subject"
+     * @param <string> the text of the emails body
+     * @param <string> a reference to an error string
 	function sendEmail($fromAddr, $fromName, $toAddr, $toName, $subject, $body, &$error_msg ){
 		global $mailHost, $mailUsername, $mailPassword;
 		if($fromAddr == ''){
 			$fromAddr = MAILADMIN;
 		if($fromName == ''){
 			$fromName = MAILADMINNAME;
 		if ($this->isValidEmail($fromAddr) && $this->isValidEmail($toAddr)) {
 			$mail = new PHPMailer();
 			if ($fromName != "" ) {
 				$mail->FromName = $fromName;
 			$mail->IsSMTP();                  // set mailer to use SMTP
 			$mail->Host = $mailHost;          // specify main and backup server
 			$mail->SMTPAuth = true;           // turn on SMTP authentication
 			$mail->Username = $mailUsername;  // SMTP username
 			$mail->Password = $mailPassword;  // SMTP password
 			$mail->From = $fromAddr;
 			$mail->AddAddress($toAddr, $toName);
 			#$mail->AddReplyTo("info at ccgis.de", "Information");
 			$mail->WordWrap = 50;                                 // set word wrap to 50 characters
 			#$mail->AddAttachment("/var/tmp/file.tar.gz");         // add attachments
 			#$mail->AddAttachment("/tmp/image.jpg", "new.jpg");    // optional name
 			$mail->IsHTML(false);                                  // set email format to HTML
 			$mail->Subject = "[".$fromName."] ".$subject;
 			$mail->Body    = $body;
 			#$mail->AltBody = "This is the body in plain text for non-HTML mail clients";
 			$error_msg='';
 			if(!$mail->Send())
 			   $error_msg .= "Mailer Error: " . $mail->ErrorInfo;
 			   return false;
 			return true;
 		else {
 			return false;
+     * returns a random password with numbers and chars both lowercase and uppercase (0-9a-zA-Z)
+     * @return <string> the new password
  	function getRandomPassword() {
 		// password length
-		$max = 16;
+		$max = 16;
 		//new password
 		$newpass = "";
 		for ($i=0;$i <= $max;$i++) {
 			//die ASCII-Zeichen 48 - 57 sind die zahlen 0-9
 			//die ASCII-Zeichen 65 - 90 sind die buchstaben A-Z (Groß)
@@ -103,9 +132,9 @@
 		return $newpass;
  	function getOwnerByGui($gui_id){
 		$sql = "(SELECT mb_user.mb_user_name";
 		$sql .= "FROM mb_user ";
 		$sql .= "JOIN gui_mb_user ON mb_user.mb_user_id = gui_mb_user.fkey_mb_user_id ";
@@ -121,7 +150,7 @@
 		$sql .= "WHERE gui_mb_group.mb_group_type = 'owner' ";
 		$sql .= "AND gui_mb_group.fkey_gui_id = $2 ";
-		$sql .= "GROUP BY mb_user.mb_user_name)";
+		$sql .= "GROUP BY mb_user.mb_user_name)";
 		$owner = array();
 		$v = array($gui_id,$gui_id);
 		$t = array('s','s');
@@ -130,49 +159,49 @@
 		while($row = db_fetch_array($res)){
 			$owner[$cnt] = $row["mb_user_name"];
 			$cnt++;
 		return $owner;
 	function getEmailByUserId($userid){
-		$sql = "SELECT mb_user_email FROM mb_user ";
+		$sql = "SELECT mb_user_email FROM mb_user ";
 		$sql .= "WHERE mb_user_id = $1 GROUP by mb_user_email";
 		$v = array($userid);
-		$t = array('i');
+		$t = array('i');
 		$res = db_prep_query($sql,$v,$t);
 		$count_g = 0;
 		$array = array();
-		$row = db_fetch_array($res);
+		$row = db_fetch_array($res);
 		if ($row) {
 			return $row["mb_user_email"];
 		else {
 			return false;
 	function getUserNameByUserId($userid){
-		$sql = "SELECT mb_user_name FROM mb_user ";
+		$sql = "SELECT mb_user_name FROM mb_user ";
 		$sql .= "WHERE mb_user_id = $1 GROUP BY mb_user_name";
-		$t = array("i");
+		$t = array("i");
 		$count_g = 0;
 		$array = array();
 		if ($row) {
 			return $row["mb_user_name"];
 		else {
 			return false;
  	function getUserIdByEmail($email){
-		$sql = "SELECT  mb_user_id FROM mb_user ";
+		$sql = "SELECT  mb_user_id FROM mb_user ";
 		$sql .= "WHERE mb_user_email = $1 GROUP BY mb_user_id";
 		$v = array($email);
-		$t = array('s');
+		$t = array('s');
   		$count_g = 0;
   		$array = array();
@@ -185,8 +214,8 @@
 		else {
 			return false;
 	function getOwnerByWms($wms_id){
 		$sql = "SELECT fkey_gui_id FROM gui_wms WHERE fkey_wms_id = $1 GROUP BY fkey_gui_id";
@@ -245,7 +274,7 @@
 		else return false;
 	function guiExists($id){
 		$sql = "SELECT * FROM gui WHERE gui_id = $1 ";
 		$v = array($id);
@@ -257,17 +286,17 @@
 		else {
 			return false;
  	function deleteWmc($wmc_id, $user_id){
-		$sql = "DELETE FROM mb_user_wmc ";
+		$sql = "DELETE FROM mb_user_wmc ";
 		$sql .= "WHERE fkey_user_id = $1 AND wmc_id = $2";
 		$v = array($user_id,$wmc_id);
-		$t = array('i','s');
+		$t = array('i','s');
 		if ($res) {
-			return true;
+			return true;
 		else {
 			return false;
@@ -282,10 +311,10 @@
 			if ($res) {
 				return true;
 		return false;
 	function delAllUsersOfGui($guiId) {
 		$sql = "DELETE FROM gui_mb_user WHERE fkey_gui_id = $1 ";
@@ -297,14 +326,14 @@
 		else {
 			return true;
 	function getWmsByOwner($user_id){
 		$gui_list = $this->getGuisByOwner($user_id,true);
 		return $this->getWmsByOwnGuis($gui_list);
 	function getWmsByWmsOwner($user_id){
 		$sql = "SELECT wms_id FROM wms WHERE wms_owner = $1";
 		$v = array($user_id);
@@ -316,7 +345,7 @@
 		return $r;
 	function getUserByWms($wms_id){
 		$v = array($wms_id);
@@ -343,7 +372,7 @@
 			$sql .= ") GROUP BY mb_user.mb_user_name) UNION";
 			$sql .= "(SELECT mb_user.mb_user_name FROM gui_mb_group JOIN mb_user_mb_group ON   mb_user_mb_group.fkey_mb_group_id = gui_mb_group.fkey_mb_group_id     JOIN mb_user ";
-			$sql .= "ON mb_user.mb_user_id = mb_user_mb_group.fkey_mb_user_id ";
+			$sql .= "ON mb_user.mb_user_id = mb_user_mb_group.fkey_mb_user_id ";
 			$sql .= " WHERE gui_mb_group.fkey_gui_id IN (";
 			for($i=0; $i<count($gui); $i++){
 				if($i>0){ $sql .= ",";}
@@ -360,10 +389,10 @@
 				$user[$cnt] = $row["mb_user_name"];
 				$cnt++;
 		return $user;
 	function getWmsTitleByWmsId($id){
 		$sql = "SELECT wms_title from wms WHERE wms_id = $1 GROUP BY wms_title";
 		$v = array($id);
@@ -372,7 +401,7 @@
 		if ($row) return $row["wms_title"]; else return false;
 	function getLayerTitleByLayerId($id){
 		$sql = "SELECT layer_title from layer WHERE layer_id = $1 GROUP BY layer_title";
 		$v = array($id);
@@ -381,7 +410,7 @@
 		if ($row) return $row["layer_title"]; else return false;
 	function getWmcById($id){
 		$sql = "SELECT wmc FROM mb_user_wmc WHERE wmc_id = $1 ";
 		$v = array($id);
@@ -393,14 +422,14 @@
 		else {
 			return false;
 	function resetLoginCount($userId) {
 		$sql = "UPDATE mb_user SET mb_user_login_count = '0' ";
 		$sql .= "WHERE mb_user_id = $1 ";
 		$v = array($userId);
-		$t = array('i');
+		$t = array('i');
 		if (!$res) {
@@ -408,24 +437,24 @@
 		else {
 			return true;
 	function getUserIdByUserName($username){
 		$sql .= "WHERE mb_user_name = $1 GROUP BY mb_user_id";
 		$v = array($username);
 		$t = array('s');
 		if ($row) return $row["mb_user_id"]; else return false;
 	function setUserAsGuiOwner($guiId, $userId) {
 		$sql = "UPDATE gui_mb_user SET mb_user_type = 'owner' ";
 		$sql .= "WHERE fkey_gui_id = $1 AND fkey_mb_user_id = $2 ";
 		$v = array($guiId,$userId);
-		$t = array('s','i');
+		$t = array('s','i');
 		if (!$res) {
@@ -433,14 +462,14 @@
 		else {
 			return true;
 	function getGuiIdByGuiName($guiTitle){
-		$sql = "SELECT gui_id FROM gui ";
+		$sql = "SELECT gui_id FROM gui ";
 		$sql .= "WHERE gui_name = $1 GROUP BY gui_id";
 		$v = array($guiTitle);
-		$t = array('s');
+		$t = array('s');
   		$count_g = 0;
   		$array = array();
@@ -453,12 +482,12 @@
 		else {
 			return false;
 	function getGuisByOwner($user_id,$ignore_public)
-		$sql_guis = "SELECT gui.gui_id FROM gui,gui_mb_user ";
+		$sql_guis = "SELECT gui.gui_id FROM gui,gui_mb_user ";
 		$sql_guis .= "WHERE (gui.gui_id = gui_mb_user.fkey_gui_id AND gui_mb_user.fkey_mb_user_id = $1) ";
 		if (!isset($ignore_public) OR $ignore_public == false){
 			$sql_guis .= " AND gui.gui_public = 1 ";
@@ -466,7 +495,7 @@
 		$sql_guis .= " AND gui_mb_user.mb_user_type = 'owner' GROUP BY gui.gui_id";
 		$sql_guis .= " ORDER by gui.gui_id";
-		$t = array('i');
+		$t = array('i');
 		$res_guis = db_prep_query($sql_guis,$v,$t);
   		$count_g = 0;
   		$arrayGuis = array();
@@ -474,11 +503,11 @@
 			$arrayGuis[$count_g] = $row["gui_id"];
 			$count_g++;
-		return $arrayGuis;
+		return $arrayGuis;
  	function getWmcByOwner($user_id){
-		$sql_wmc = "SELECT wmc_id FROM mb_user_wmc ";
+		$sql_wmc = "SELECT wmc_id FROM mb_user_wmc ";
 		$sql_wmc .= "WHERE fkey_user_id = $1 GROUP BY wmc_id";
 		$t = array('i');
@@ -489,16 +518,16 @@
 			$arrayWmc[$count_g] = $row["wmc_id"];
 			$count_g++;
-		return $arrayWmc;
+		return $arrayWmc;
 	function getGuisByPermission($mb_user_id,$ignore_public){
-		$mb_user_groups = array();
+		$mb_user_groups = array();
 		$sql_groups = "SELECT fkey_mb_group_id FROM mb_user_mb_group WHERE fkey_mb_user_id = $1 ";
 		$v = array($mb_user_id);
 		$t = array("i");
-		$res_groups = db_prep_query($sql_groups,$v,$t);
+		$res_groups = db_prep_query($sql_groups,$v,$t);
 		$cnt_groups = 0;
 		while($row = db_fetch_array($res_groups)){
 			$mb_user_groups[$cnt_groups] = $row["fkey_mb_group_id"];
@@ -507,8 +536,8 @@
 		if($cnt_groups > 0){
 			$v = array();
 			$t = array();
-			$sql_g = "SELECT gui.gui_id FROM gui JOIN gui_mb_group ";
-			$sql_g .= " ON gui.gui_id = gui_mb_group.fkey_gui_id WHERE gui_mb_group.fkey_mb_group_id IN (";
+			$sql_g = "SELECT gui.gui_id FROM gui JOIN gui_mb_group ";
+			$sql_g .= " ON gui.gui_id = gui_mb_group.fkey_gui_id WHERE gui_mb_group.fkey_mb_group_id IN (";
 			for($i=0; $i<count($mb_user_groups);$i++){
 				if($i > 0){$sql_g .= ",";}
 				$sql_g .= "$".strval($i+1);
@@ -519,14 +548,14 @@
 			$res_g = db_prep_query($sql_g,$v,$t);
 			while($row = db_fetch_array($res_g)){
 				array_push($arrayGuis,$row["gui_id"]);
-		$sql_guis = "SELECT gui.gui_id FROM gui JOIN gui_mb_user ON gui.gui_id = gui_mb_user.fkey_gui_id";
+		$sql_guis = "SELECT gui.gui_id FROM gui JOIN gui_mb_user ON gui.gui_id = gui_mb_user.fkey_gui_id";
 		$sql_guis .= " WHERE (gui_mb_user.fkey_mb_user_id = $1) ";
 		if (!isset($ignore_public) OR $ignore_public== false){
-		$sql_guis .= " GROUP BY gui.gui_id";
+		$sql_guis .= " GROUP BY gui.gui_id";
 		$t = array("i");
@@ -534,12 +563,12 @@
 		while($row = db_fetch_array($res_guis)){
 			if(!in_array($row['gui_id'],$arrayGuis)){
 		return $arrayGuis;
-	function getWmsByOwnGuis($array_gui_ids){
+	function getWmsByOwnGuis($array_gui_ids){
 		if(count($array_gui_ids)>0){
 			$v = array();
 			$t = array();
@@ -556,13 +585,13 @@
 			$i=0;
 				$ownguis[$i] = $row['fkey_wms_id'];
-				$i++;
+				$i++;
 		return $ownguis;
-	function getLayerByWms($wms_id){
+	function getLayerByWms($wms_id){
 		$sql = "SELECT layer_id from layer WHERE fkey_wms_id = $1 AND layer_pos NOT IN ('0') GROUP BY layer_id, layer_title ORDER BY layer_title";
 		$t = array('i');
@@ -570,11 +599,11 @@
 		$layer_id_array = array();
 			$layer_id_array[count($layer_id_array)] = $row['layer_id'];
 		return $layer_id_array;
-	function getWmsOwner($wms_id){
+	function getWmsOwner($wms_id){
 		$t = array('i');
@@ -608,7 +637,7 @@
 		return $wmsowner;
 	function insertUserAsGuiOwner($guiId, $userId){
 		$sql = "INSERT INTO gui_mb_user VALUES ($1, $2, 'owner')";
@@ -619,9 +648,9 @@
 		else {
 			return true;
    	function checkModulePermission($arrayGuis, $modulePath, $column){
    		$check = true;
    		if($check == true){
@@ -636,20 +665,20 @@
 		   			array_push($v,$arrayGuis[$i]);
 		   			array_push($t,'s');
-		   		$sql .= ")";
+		   		$sql .= ")";
 				$cnt = 0;
 					if(strpos(stripslashes($row[$column]),$modulePath) !== false){
 						$perm = true;
-					$cnt++;
+					$cnt++;
 			return $perm;
    		else{
-   			return true;
+   			return true;
@@ -662,7 +691,7 @@
    			return $row["wms_owsproxy"];
    		else{
-   			return false;
+   			return false;
@@ -674,7 +703,7 @@
 			$v = array($time,$wms_id);
    		else{
-   			$v = array("",$wms_id);
+   			$v = array("",$wms_id);
@@ -689,7 +718,7 @@
 			return $url."?";
 		else{
-			return $url;
+			return $url;
 	function getModulPermission($userID,$guiID,$elementID){
@@ -707,8 +736,8 @@
 		else{
-			return false;
+			return false;
 	function getLayerPermission($wms_id, $layer_name, $user_id){
 		$layer_id = $this->getLayerIdByLayerName($wms_id,$layer_name);
@@ -722,7 +751,7 @@
 			$sql .= "$".$c;
 			$c++;
 			array_push($v, $array_guis[$i]);
-			array_push($t, 's');
+			array_push($t, 's');
 		$sql .= ") AND fkey_layer_id = $".$c." AND gui_layer_status = 1";
 		array_push($v,$layer_id);
@@ -746,7 +775,7 @@
 			$sql .= "$".$c;
 			$c++;
 		$sql .= ") AND fkey_wms_id = $".$c;
 		array_push($v,$wms_id);
@@ -769,7 +798,7 @@
 			return $row['layer_id'];
 		else{
-			return false;
+			return false;
 	function getWmsIdByWmsGetmap($getmap) {
@@ -782,7 +811,7 @@
 			return $row['wms_id'];
 		else{
-			return false;
+			return false;
More information about the Mapbender_commits mailing list
