[Mapbender-commits] r1312 - trunk/mapbender/http/javascripts
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Wed May 9 09:03:19 EDT 2007
Author: christoph
Date: 2007-05-09 09:03:19 -0400 (Wed, 09 May 2007)
New Revision: 1312
   trunk/mapbender/http/javascripts/geometry.js
removed duplicate function cloneObject
Modified: trunk/mapbender/http/javascripts/geometry.js
--- trunk/mapbender/http/javascripts/geometry.js	2007-05-09 13:01:04 UTC (rev 1311)
+++ trunk/mapbender/http/javascripts/geometry.js	2007-05-09 13:03:19 UTC (rev 1312)
@@ -1040,19 +1040,37 @@
 		mG.get(-1).addPoint(center);
 		highlight.add(mG);
-	this.getTolerance = function() {return tolerance;};
-	this.getTarget = function() {return target;};
-	this.cleanHighlight = function() {return highlight.clean();};
-	this.addPoint = function(aPoint) {coord.push(aPoint);};
-	this.getPointCount = function() {return coord.length;};
-	this.getPoint = function(i) {return coord[i];};
-	this.resetPoints = function() {coord = [];};
+	this.getTolerance = function() {
+		return tolerance;
+	this.getTarget = function() {
+		return target;
+	this.cleanHighlight = function() {
+		return highlight.clean();
+	this.addPoint = function(aPoint) {
+		coord.push(aPoint);
+	this.getPointCount = function() {
+		return coord.length;
+	this.getPoint = function(i) {
+		return coord[i];
+	this.resetPoints = function() {
+		coord = [];
 	this.getNearestNeighbour = function(){
 		if (min_i != -1) {return this.getPoint(min_i);}
 		return false;
-	this.setIndexOfNearestNeighbour = function(i){min_i = i;};
-	this.resetIndexOfNearestNeighbour = function(){min_i = -1;};
+	this.setIndexOfNearestNeighbour = function(i){
+		min_i = i;
+	this.resetIndexOfNearestNeighbour = function(){
+		min_i = -1;
 	var tolerance = (typeof(aTolerance) == 'undefined') ? 10 : aTolerance;
 	var zIndex = (typeof(aZIndex) == 'undefined') ? 50 : aZIndex;
@@ -1214,14 +1232,3 @@
 	return z;
-function cloneObject(a){
-	var z = [];
-	for (attr in a) {
-		var b = a[attr];
-		if (typeof(b) == "object") {z[attr] = cloneObject(b);}
-		else {z[attr] = b;}
-	return z;
\ No newline at end of file
More information about the Mapbender_commits mailing list
