[Mapbender-commits] r1317 - trunk/mapbender/http/javascripts
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri May 11 06:12:02 EDT 2007
Author: christoph
Date: 2007-05-11 06:12:02 -0400 (Fri, 11 May 2007)
New Revision: 1317
   trunk/mapbender/http/javascripts/mod_addWMSfromfilteredList.php
fixed IE bug
Modified: trunk/mapbender/http/javascripts/mod_addWMSfromfilteredList.php
--- trunk/mapbender/http/javascripts/mod_addWMSfromfilteredList.php	2007-05-11 08:17:50 UTC (rev 1316)
+++ trunk/mapbender/http/javascripts/mod_addWMSfromfilteredList.php	2007-05-11 10:12:02 UTC (rev 1317)
@@ -1,721 +1,722 @@
-<?php
-# $Id$
-# http://www.mapbender.org/index.php/mod_addWMSfromfilteredList.php
-# Copyright (C) 2002 CCGIS
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2, or (at your option)
-# any later version.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
-# GNU General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-require_once(dirname(__FILE__)."/../../conf/mapbender.conf");
-require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
-import_request_variables("PG");
-<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
-<html>
-<head>
-<?php
-echo '<meta http-equiv="Content-Type" content="text/html; charset='.CHARSET.'">';
-include '../include/dyn_css.php';
-<title>Add WMS from Filtered Catalog</title>
-<link rel="stylesheet" type="text/css" href="../css/administration_alloc.css">
-<STYLE TYPE="text/css">
-body{
-	font-family:Verdana, Geneva, Arial, Helvetica, sans-serif;
-	font-size:10pt
-table{
-	font-size:11;
-.wms_button{
-	color: black;
-	border: solid thin;
-	height:22px;
-	width:60px;
-</STYLE>
-<script type="text/javascript">
-function mod_addWMSfromDB(gui_id, wms_id) {
-	//alert("1/3 mod_addWMSfromDB: GUI ID = " + gui_id + ", WMS ID = " + wms_id);
-	window.opener.mod_addWMSById_load(gui_id, wms_id);
-function mod_addWMSfromfilteredList(pointer_name,version){
-	pointer_name=pointer_name + window.opener.mb_getConjunctionCharacter(pointer_name);
-	if (version == '1.0.0'){
-		var cap = pointer_name + "REQUEST=capabilities&WMTVER=1.0.0";
-		var load = cap;
-	else if (version == '1.1.0'){
-		var cap = pointer_name + "REQUEST=GetCapabilities&SERVICE=WMS&VERSION=1.1.0";
-		var load = cap;
-	else if (version == '1.1.1'){
-		var cap = pointer_name + "REQUEST=GetCapabilities&SERVICE=WMS&VERSION=1.1.1";
-		var load = cap;
-	//alert (load);
-	if(load){
-		if(load.charAt(0) == '/' && load.charAt(1) == 'c'){
-			window.opener.mod_addWMS_load('http://localhost' + load);
-		else{
-			window.opener.mod_addWMS_load(load);
-function mod_show_group_wms(wert){
-	document.form1.show_group_wms.value = wert;
-	document.form1.submit();
-function mod_show_gui_wms(wert2){
-	document.form1.show_gui_wms.value = wert2;
-function mod_show_gui_configured_wms(wert2){
-	document.form1.show_gui_configured_wms.value = wert2;
-function mod_show_wms(wert3){
-	document.form1.wms_show.value = wert3;
-	if (wert3 == 4) {
-		document.form1.wmsSource = "db";
-	else {
-		document.form1.wmsSource = "capabilities";
-function setButtons() {
-	if (typeof(option_all) == "undefined") {
-		option_all = '<?php echo $set_option_all;?>';
-	document.getElementById("set_option_all").value = option_all;
-	if (option_all == '0') {
-		removeChildNodes(document.getElementById("_option_all"));
-	if (typeof(option_group) == "undefined") {
-		option_group = '<?php echo $set_option_group;?>';
-	document.getElementById("set_option_group").value = option_group;
-	if (option_group == '0') {
-		removeChildNodes(document.getElementById("_option_group"));
-	if (typeof(option_gui) == "undefined") {
-		option_gui = '<?php echo $set_option_gui;?>';
-	document.getElementById("set_option_gui").value = option_gui;
-	if (option_gui == '0') {
-		removeChildNodes(document.getElementById("_option_gui"));
-	if (typeof(option_db) == "undefined") {
-		option_db = '<?php echo $set_option_db;?>';
-	document.getElementById("set_option_db").value = option_db;
-	if (option_db == '0') {
-		removeChildNodes(document.getElementById("_option_db"));
-function removeChildNodes(node) {
-	while (node.childNodes.length > 0) {
-		var childNode = node.firstChild;
-		node.removeChild(childNode);
-</script>
-</head>
-<body onLoad="window.focus();setButtons()">
-<?php
-$con = db_connect($DBSERVER,$OWNER,$PW);
-db_select_db(DB,$con);
-require_once(dirname(__FILE__)."/../classes/class_wms.php");
-require_once(dirname(__FILE__)."/../php/mb_getGUIs.php");
-$fieldHeight = 20;
-$cnt_gui = 0;
-$cnt_gui_wms = 0;
-$cnt_wms = 0;
-$cnt_user_group = 0;
-$cnt_group = 0;
-$cnt_gui_mb_group = 0;
-$cnt_group_gui_wms = 0;
-$cnt_fkey_group_gui_wms = 0;
-$cnt_fkey_show_gui_wms = 0;
-$cnt_show_gui_wms = 0;
-$cnt_group_name = 0;
-$cnt_gui_table = 0;
-$exists = false;
-$logged_user_name=$_SESSION["mb_user_name"];
-$logged_user_id=$_SESSION["mb_user_id"];
-$logged_gui_id=$_SESSION["mb_user_gui"];
-######   SQL   #####################################################################################
-/*get infos from gui_element ********************************************************/
-/*get group from logged user  *******************************************************/
-$sql_user_group = "SELECT * FROM mb_user_mb_group WHERE fkey_mb_user_id= $1 ";
-$array_values = array($logged_user_id);
-$array_types = array('s');
-$res_user_group = db_prep_query($sql_user_group, $array_values, $array_types);
-while($row = db_fetch_array($res_user_group)){
-	$user_id[$cnt_user_group] = $row["fkey_mb_user_id"];
-	$group_id[$cnt_user_group] = $row["fkey_mb_group_id"];
-	$cnt_user_group++;
-/*get group from logged user  ************************************************************/
-# Thekla, please recheck
-/*get group name  ********************************************************************************************/
-if(count($group_id) > 0){
-	$v = array();
-	$t = array();
-	$sql_group = "SELECT mb_group_id, mb_group_name, mb_group_description FROM mb_group WHERE mb_group_id IN (";
-	for($i=0; $i < count($group_id); $i++){
-		if($i>0){ $sql_group .= ",";}
-		$sql_group .= "$".strval($i + 1);
-		array_push($v,$group_id[$i]);
-		array_push($t,"i");
-	$sql_group.= ") ORDER BY mb_group_name";
-	$res_group = db_prep_query($sql_group,$v,$t);
-	while($row = db_fetch_array($res_group)){
-		$mb_group_description[$cnt_group] = $row["mb_group_description"];
-		$my_group_name[$cnt_group] = $row["mb_group_name"];
-		$my_group_id[$cnt_group] = $row["mb_group_id"];
-		$cnt_group++;
-/*get allocated gui  ********************************************************************************************/
-$arrayGuis=mb_getGUIs($logged_user_id);
-$sql_gui = "SELECT * FROM gui WHERE gui_id IN (";
-for($i=0; $i<count($arrayGuis); $i++){
-	if($i>0){ $sql_gui .= ",";}
-	$sql_gui .= "'".$arrayGuis[$i]."'";
-$sql_gui.= ") ORDER BY gui_name";
-$res_gui = db_query($sql_gui);
-				while($row = db_fetch_array($res_gui)){
-					$gui_id[$cnt_gui] = $row["gui_id"];
-					$gui_name[$cnt_gui] = $row["gui_name"];
-					$gui_description[$cnt_gui] = $row["gui_description"];
-					#echo"$gui_name[$cnt_gui]";
-					$cnt_gui++;
-/*get allocated wms from allocated gui  ********************************************************************************************/
-$sql_gui_wms = "SELECT DISTINCT fkey_wms_id, fkey_gui_id FROM gui_wms WHERE fkey_gui_id IN (";
-	if($i>0){ $sql_gui_wms .= ",";}
-	$sql_gui_wms .= "'".$arrayGuis[$i]."'";
-$sql_gui_wms.= ") ORDER BY fkey_wms_id";
-$res_gui_wms = db_query($sql_gui_wms);
-while($row = db_fetch_array($res_gui_wms)){
-				$fkey_gui_id[$cnt_gui_wms] = $row["fkey_gui_id"];
-	$fkey_wms_id[$cnt_gui_wms] = $row["fkey_wms_id"];
-	$cnt_gui_wms++;
-/*get allocated wms-Abstract and wms-Capabilities from allocated gui  ********************************************************************************************/
-$sql_wms = "SELECT DISTINCT wms_title, wms_abstract, wms_getcapabilities, wms_version FROM wms WHERE wms_id IN (";
-for($i=0; $i<count($fkey_wms_id); $i++){
-	if($i>0){ $sql_wms .= ",";}
-	$sql_wms .= "'".$fkey_wms_id[$i]."'";
-$sql_wms.= ") ORDER BY wms_title";
-$res_wms = db_query($sql_wms);
-				while($row = db_fetch_array($res_wms)){
-					$wms_title[$cnt_wms] = $row["wms_title"];
-					$wms_abstract[$cnt_wms] = $row["wms_abstract"];
-					$wms_getcapabilities[$cnt_wms] = $row["wms_getcapabilities"];
-					$wms_version[$cnt_wms] = $row["wms_version"];
-					$cnt_wms++;
-/*INSERT HTML*/
-echo "<form name='form1' action='" . $PHP_SELF . "?".SID."' method='post'>";
-# Button
-echo "<table border='0' cellpadding='3'  rules='rows'>";
-echo "<tr>";
-if (isset($wms_show)){
-	echo "<td id='_option_all'><input type='button' class='wms_button' name='wms1' value='all wms' onclick='mod_show_wms(1)'></td>";
-	echo "<td id='_option_group'><input type='button' class='wms_button' name='wms2' value='group' onclick = 'mod_show_wms(2)'></td>";
-	echo "<td id='_option_gui'><input type='button' class='wms_button' name='wms3' value='gui' onclick = 'mod_show_wms(3)'></td>";
-	echo "<td id='_option_db'><input type='button' class='wms_button' name='wms4' value='db' onclick = 'mod_show_wms(4)'></td>";
-	echo "</tr>";
-	echo "</table>";
-######   SHOW GUI WMS OR GROUP WMS   #####################################################################################
-/*show goup wms  ********************************************************************************************/
-#if (isset($show_group_wms))
-if (!empty($show_group_wms)){
-	/*get gui goup   ********************************************************************************************/
-	$sql_gui_mb_group = "SELECT fkey_gui_id, fkey_mb_group_id FROM gui_mb_group WHERE fkey_mb_group_id='".$show_group_wms."'";
-	$res_gui_mb_group = db_query($sql_gui_mb_group);
-				while($row = db_fetch_array($res_gui_mb_group)){
-					$group_gui_id[$cnt_gui_mb_group] = $row["fkey_gui_id"];
-					$fkey_mb_group_id[$cnt_gui_mb_group] = $row["fkey_mb_group_id"];
-					#echo"$group_gui_id[$cnt_gui_mb_group]";
-					$cnt_gui_mb_group++;
-	/*get group gui WMS  ********************************************************************************************/
-	if(count($group_gui_id)>0)	{
-		$sql_fkey_group_gui_wms = "SELECT DISTINCT fkey_wms_id, fkey_gui_id FROM gui_wms WHERE fkey_gui_id IN (";
-		for($i=0; $i<count($group_gui_id); $i++){
-			if($i>0){ $sql_fkey_group_gui_wms .= ",";}
-			$sql_fkey_group_gui_wms .= "'".$group_gui_id[$i]."'";
-		$sql_fkey_group_gui_wms.=  ") ORDER BY fkey_wms_id";
-		$res_fkey_group_gui_wms = db_query($sql_fkey_group_gui_wms);
-		while($row = db_fetch_array($res_fkey_group_gui_wms)){
-			$fkey_group_gui_gui_id[$cnt_fkey_group_gui_wms] = $row["fkey_gui_id"];
-			$fkey_group_gui_wms_id[$cnt_fkey_group_gui_wms] = $row["fkey_wms_id"];
-			#echo"$fkey_group_gui_wms_id[$cnt_fkey_group_gui_wms]";
-			$cnt_fkey_group_gui_wms++;
-		/*group: get allocated wms-Abstract and wms-Capabilities from allocated gui  ********************************************************************************************/
-		if(count($fkey_group_gui_wms_id)>0){
-			$sql_group_gui_wms = "SELECT DISTINCT wms_title, wms_abstract, wms_getcapabilities, wms_version FROM wms WHERE wms_id IN (";
-			for($i=0; $i<count($fkey_group_gui_wms_id); $i++){
-				if($i>0){ $sql_group_gui_wms .= ",";}
-				$sql_group_gui_wms .= "'".$fkey_group_gui_wms_id[$i]."'";
-			$sql_group_gui_wms.= ") ORDER BY wms_title";
-			$res_group_gui_wms = db_query($sql_group_gui_wms);
-			while($row = db_fetch_array($res_group_gui_wms)){
-				$group_wms_title[$cnt_group_gui_wms] = $row["wms_title"];
-				$group_wms_abstract[$cnt_group_gui_wms] = $row["wms_abstract"];
-				$group_wms_getcapabilities[$cnt_group_gui_wms] = $row["wms_getcapabilities"];
-				$group_wms_version[$cnt_group_gui_wms] = $row["wms_version"];
-				#echo"$group_wms_title[$cnt_group_gui_wms]";
-				$cnt_group_gui_wms++;
-	/*table with allocated wms-Abstract and wms-Capabilities from allocated gui  ********************************************************************************************/
-	#if ($show_group_wms > 0)
-	if ($cnt_group_gui_wms > 0){
-		/*get goup name for showing in the table ********************************************************************************************/
-		$sql_group_name = "SELECT mb_group_id, mb_group_name FROM mb_group WHERE mb_group_id ='".$show_group_wms."'";
-		$res_group_name = db_query($sql_group_name);
-		while($row = db_fetch_array($res_group_name)){
-			$group_name_table[$cnt_group_name] = $row["mb_group_name"];
-			$my_group_id_table[$cnt_group_name] = $row["mb_group_id"];
-			$cnt_group_name++;
-	/*get goup name  ********************************************************************************************/
-	echo"<br>";
-	echo"<br>";
-		echo"wms from group: $group_name_table[0]";
-		echo"<br>";
-		echo"<br>";
-	echo "<table border='1' width ='98%' cellpadding='3' rules='rows'>";
-	echo " <thead bgcolor = '#FAEBD7' >";
-	echo "<tr><td width='200' height='10'>WMS-Title</td><td  align = 'left' class='fieldnames_s'>WMS-Abstract</td>";
-	echo " </thead>";
-	echo " <tbody >";
-		for($i=0; $i<$cnt_group_gui_wms; $i++){
-			echo "<tr class='Farbe' onmouseover='this.style.backgroundColor = \"#F08080\"' onmouseout='this.style.backgroundColor = \"#ffffff\"'>";
-			echo "<td><div id ='id_".$group_wms_title[$i]."' class='even' name ='name_".$group_wms_title[$i]."'  style='cursor:pointer' onclick = 'mod_addWMSfromfilteredList(\"".$group_wms_getcapabilities[$i]."\",\"".$group_wms_version[$i]."\")'>".$group_wms_title[$i]."</div></td>";
-			echo "<td><div id ='id_".$group_wms_abstract[$i]."' class='even' name ='name_".$group_wms_abstract[$i]."' style='cursor:pointer' onclick = 'mod_addWMSfromfilteredList(\"".$group_wms_getcapabilities[$i]."\",\"".$group_wms_version[$i]."\")'>".$group_wms_abstract[$i]."</div></td>";
-			echo "</tr>";
-		echo "  </tbody>";
-		echo "</table>";
-		else{
-			echo"<br>";
-			echo"<br>";
-			echo "no wms in this group";
-		}/*End: if ($show_group_wms > 0)   *********/
-	}/*End: if (!empty($show_group_wms))   *********/
-/*show gui wms  ********************************************************************************************/
-if (!empty($show_gui_wms)){
-	$sql_fkey_show_gui_wms = "SELECT DISTINCT fkey_wms_id, fkey_gui_id FROM gui_wms WHERE fkey_gui_id ='".$show_gui_wms."'";
-	#$sql_fkey_show_gui_wms.= ") ORDER BY fkey_wms_id";
-	$res_fkey_show_gui_wms = db_query($sql_fkey_show_gui_wms);
-	while($row = db_fetch_array($res_fkey_show_gui_wms)){
-		$fkey_show_gui_gui_id[$cnt_fkey_show_gui_wms] = $row["fkey_gui_id"];
-		$fkey_show_gui_wms_id[$cnt_fkey_show_gui_wms] = $row["fkey_wms_id"];
-		#echo"$fkey_show_gui_wms_id[$cnt_fkey_show_gui_wms]";
-		$cnt_fkey_show_gui_wms++;
-	/*gui: get allocated wms-Abstract and wms-Capabilities from allocated gui  ********************************************************************************************/
-	if(count($fkey_show_gui_wms_id)>0){
-		$sql_show_gui_wms = "SELECT DISTINCT wms_title, wms_abstract, wms_getcapabilities, wms_id, wms_version FROM wms WHERE wms_id IN (";
-		for($i=0; $i<count($fkey_show_gui_wms_id); $i++){
-			if($i>0){ $sql_show_gui_wms .= ",";}
-			$sql_show_gui_wms .= "'".$fkey_show_gui_wms_id[$i]."'";
-		$sql_show_gui_wms.= ") ORDER BY wms_title";
-		$res_show_gui_wms = db_query($sql_show_gui_wms);
-		while($row = db_fetch_array($res_show_gui_wms)){
-			$gui_wms_id[$cnt_show_gui_wms] = $row["wms_id"];
-			$gui_wms_title[$cnt_show_gui_wms] = $row["wms_title"];
-			$gui_wms_abstract[$cnt_show_gui_wms] = $row["wms_abstract"];
-			$gui_wms_getcapabilities[$cnt_show_gui_wms] = $row["wms_getcapabilities"];
-			$gui_wms_version[$cnt_show_gui_wms] = $row["wms_version"];
-			#echo"$gui_wms_title[$cnt_show_gui_wms]";
-			$cnt_show_gui_wms++;
-		#if (isset($cnt_show_gui_wms > 0))
-	if ($cnt_show_gui_wms > 0){
-	/*get selected gui name for table caption ********************************************************************************************/
-	$sql_gui_table = "SELECT * FROM gui WHERE gui_id ='".$show_gui_wms."'";
-	$res_gui_table = db_query($sql_gui_table);
-		while($row = db_fetch_array($res_gui_table)){
-			$gui_id_table[$cnt_gui_table] = $row["gui_id"];
-			$gui_name_table[$cnt_gui_table] = $row["gui_name"];
-			$cnt_gui_table++;
-			#echo"$gui_id_table[0]";
-		echo"<br>";
-		echo"<br>";
-			echo"wms from gui: $gui_name_table[0]";
-			echo"<br>";
-			echo"<br>";
-		echo " </thead>";
-		echo " <tbody >";
-		for($i=0; $i<$cnt_show_gui_wms; $i++){
-			echo "<td><div id ='id_".$gui_wms_title[$i]."' class='even' name ='name_".$gui_wms_title[$i]."'  style='cursor:pointer' onclick = 'mod_addWMSfromfilteredList(\"".$gui_wms_getcapabilities[$i]."\",\"".$gui_wms_version[$i]."\")'>".$gui_wms_title[$i]."</div></td>";
-			echo "<td><div  id ='id_".$gui_wms_abstract[$i]."' class='even' name ='name_".$gui_wms_abstract[$i]."' style='cursor:pointer' onclick = 'mod_addWMSfromfilteredList(\"".$gui_wms_getcapabilities[$i]."\",\"".$gui_wms_version[$i]."\")'>".$gui_wms_abstract[$i]."</div></td>";
-			echo "</tr>";
-		echo "  </tbody>";
-		echo "</table>";
-	else{
-		echo"<br>";
-		echo"<br>";
-		echo"<br>";
-		echo "no wms in this gui";
-  	}  /*End: if ($cnt_show_gui_wms > 0)  *********/
-} /*End: if(isset($show_gui_wms))   *********/
-if (!empty($show_gui_configured_wms)){
-	$sql_fkey_show_gui_wms = "SELECT DISTINCT fkey_wms_id, fkey_gui_id FROM gui_wms WHERE fkey_gui_id ='".$show_gui_configured_wms."'";
-	$sql_gui_table = "SELECT * FROM gui WHERE gui_id ='".$show_gui_configured_wms."'";
-			$cnt_gui_table++;
-		echo"<br>";
-		echo"<br>";
-			echo"<br>";
-			echo"<br>";
-		echo " </thead>";
-		echo " <tbody >";
-			echo "<td><div id ='id_".$gui_wms_title[$i]."' class='even' name ='name_".$gui_wms_title[$i]."'  style='cursor:pointer' onclick = 'mod_addWMSfromDB(\"".$show_gui_configured_wms."\",\"".$gui_wms_id[$i]."\")'>".$gui_wms_title[$i]."</div></td>";
-			echo "<td><div  id ='id_".$gui_wms_abstract[$i]."' class='even' name ='name_".$gui_wms_abstract[$i]."' style='cursor:pointer' onclick = 'mod_addWMSfromDB(\"".$show_gui_configured_wms."\",\"".$gui_wms_id[$i]."\")'>".$gui_wms_abstract[$i]."</div></td>";
-			echo "</tr>";
-		echo "  </tbody>";
-		echo "</table>";
-	else{
-		echo"<br>";
-		echo"<br>";
-		echo"<br>";
-} /*End: if(isset($show_gui_configured_wms))   *********/
-######   SHOW GUI OR GROUP OR ALL WMS   #####################################################################################
-	if ($wms_show == 4){ #gui
-		echo"<br>";
-		echo"<br>";
-		echo"Please select a gui:";
-		echo"<br>";
-		echo"<br>";
-		echo "<table border='1' width='98%' cellpadding='3' rules='rows'>";
-		echo " <thead bgcolor = 'lightgrey' >";
-		echo "<tr><td width='200' height='10'>gui name</td><td  align = 'left' class='fieldnames_s'>description</td>";
-		echo " </thead>";
-		echo " <tbody >";
-		for($i=0; $i<$cnt_gui; $i++){
-			echo "<td><div id ='id_".$gui_name[$i]."' value='".$gui_id[$i]."' class='even' name ='".$gui_name[$i]."'  style='cursor:pointer'  onclick = 'mod_show_gui_configured_wms(\"".$gui_id[$i]."\")'>".$gui_name[$i]."</div></td>";
-			echo "<td><div id ='id_".$gui_description[$i]."' value='".$gui_id[$i]."' class='even' name ='".$gui_description[$i]."' style='cursor:pointer' onclick = 'mod_show_gui_configured_wms(\"".$gui_id[$i]."\")'>".$gui_description[$i]."</div></td>";
-			echo "</tr>";
-		echo "  </tbody>";
-		echo "</table>";
-	if ($wms_show == 3){ #gui
-		echo"<br>";
-		echo"<br>";
-		echo"<br>";
-		echo"<br>";
-		echo " </thead>";
-		echo " <tbody >";
-			echo "<td><div id ='id_".$gui_name[$i]."' value='".$gui_id[$i]."' class='even' name ='".$gui_name[$i]."'  style='cursor:pointer'  onclick = 'mod_show_gui_wms(\"".$gui_id[$i]."\")'>".$gui_name[$i]."</div></td>";
-			echo "<td><div id ='id_".$gui_description[$i]."' value='".$gui_id[$i]."' class='even' name ='".$gui_description[$i]."' style='cursor:pointer' onclick = 'mod_show_gui_wms(\"".$gui_id[$i]."\")'>".$gui_description[$i]."</div></td>";
-			echo "</tr>";
-		echo "  </tbody>";
-		echo "</table>";
-	elseif  ($wms_show== 2){  # group
-		echo"<br>";
-		echo"<br>";
-		if($cnt_group>0){
-			echo "Please select a group:";
-			echo"<br>";
-			echo"<br>";
-			echo "<tr><td  width='200' height='10'>group name</td><td  align = 'left' class='fieldnames_s'>description</td>";
-			echo " </thead>";
-			echo " <tbody >";
-			for($i=0; $i<$cnt_group; $i++){
-				echo "<td><div id ='id_".$my_group_name[$i]."' value='".$my_group_id[$i]."' class='even' name ='".$my_group_name[$i]."'  style='cursor:pointer'  onclick = 'mod_show_group_wms(\"".$my_group_id[$i]."\")'>".$my_group_name[$i]."</div></td>";
-				echo "<td><div id ='id_".$mb_group_description[$i]."' value='".$my_group_id[$i]."' class='even' name ='".$mb_group_description[$i]."' style='cursor:pointer' onclick = 'mod_show_group_wms(\"".$my_group_id[$i]."\")'>".$mb_group_description[$i]."</div></td>";
-				echo "</tr>";
-			echo "  </tbody>";
-			echo "</table>";
-		else{
-			echo"no group for this user";
-	elseif  ($wms_show== 1){  # all wms
-		echo"<br>";
-		echo"<br>";
-		echo " </thead>";
-		echo " <tbody >";
-		for($i=0; $i<$cnt_wms; $i++){
-			echo "<td><div id ='id_".$wms_title[$i]."' class='even' name ='name_".$wms_title[$i]."'  style='cursor:pointer' onclick = 'mod_addWMSfromfilteredList(\"".$wms_getcapabilities[$i]."\",\"".$wms_version[$i]."\")'>".$wms_title[$i]."</div></td>";
-			echo "<td><div  id ='id_".$wms_abstract[$i]."' class='even' name ='name_".$wms_abstract[$i]."' style='cursor:pointer' onclick = 'mod_addWMSfromfilteredList(\"".$wms_getcapabilities[$i]."\",\"".$wms_version[$i]."\")'>".$wms_abstract[$i]."</div></td>";
-			echo "</tr>";
-		echo "  </tbody>";
-		echo "</table>";
-else{     #if (!isset($wms_show))
-echo "<td id='_option_all'><input type='button' class='wms_button' name='wms1' value='all wms' onclick='mod_show_wms(1)'></td>";
-echo "<td id='_option_group'><input type='button' class='wms_button' name='wms2' value='group' onclick = 'mod_show_wms(2)'></td>";
-echo "<td id='_option_gui'><input type='button' class='wms_button' name='wms3' value='gui' onclick = 'mod_show_wms(3)'></td>";
-echo "<td id='_option_db'><input type='button' class='wms_button' name='wms4' value='db' onclick = 'mod_show_wms(4)'></td>";
-#	echo "<td><input type='button' class='wms_button' name='wms1' value='all wms' onclick='mod_show_wms(1)'></td>";
-#	echo "<td><input type='button' class='wms_button' name='wms2' value='group' onclick = 'mod_show_wms(2)'></td>";
-#	echo "<td><input type='button' class='wms_button' name='wms3' value='gui' onclick = 'mod_show_wms(3)'></td>";
-	echo "</tr>";
-	echo "</tbody>";
-	echo "</table>";
-	echo"<br>";
-	echo"<br>";
-	echo " </thead>";
-	echo " <tbody >";
-		echo "</tr>";
-	echo "  </tbody>";
-	echo "</table>";
-/*show group wms  ********************************************************************************************/
-echo "<input type='hidden' name='show_group_wms'>";
-echo "<input type='hidden' name='show_gui_wms'>";
-echo "<input type='hidden' name='show_gui_configured_wms'>";
-/*show button  ********************************************************************************************/
-echo "<input type='hidden' name='wms_show'>";
-echo "<input id='wmsSource' type='hidden' name='wmsSource'>";
-echo "<input name ='set_option_all' id='set_option_all' type='hidden'>";
-echo "<input name='set_option_group' id='set_option_group' type='hidden'>";
-echo "<input name='set_option_gui' id='set_option_gui' type='hidden'>";
-echo "<input name='set_option_db' id='set_option_db' type='hidden'>";
-echo "</form>";
-</script>
-</body>
+<?php
+# $Id$
+# http://www.mapbender.org/index.php/mod_addWMSfromfilteredList.php
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+require_once(dirname(__FILE__)."/../../conf/mapbender.conf");
+require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
+import_request_variables("PG");
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
+<html>
+<head>
+<?php
+echo '<meta http-equiv="Content-Type" content="text/html; charset='.CHARSET.'">';
+include '../include/dyn_css.php';
+<title>Add WMS from Filtered Catalog</title>
+<link rel="stylesheet" type="text/css" href="../css/administration_alloc.css">
+<STYLE TYPE="text/css">
+body{
+	font-family:Verdana, Geneva, Arial, Helvetica, sans-serif;
+	font-size:10pt
+table{
+	font-size:11;
+.wms_button{
+	color: black;
+	border: solid thin;
+	height:22px;
+	width:60px;
+</STYLE>
+<script type="text/javascript">
+function mod_addWMSfromDB(gui_id, wms_id) {
+	//alert("1/3 mod_addWMSfromDB: GUI ID = " + gui_id + ", WMS ID = " + wms_id);
+	window.opener.mod_addWMSById_load(gui_id, wms_id);
+function mod_addWMSfromfilteredList(pointer_name,version){
+	pointer_name=pointer_name + window.opener.mb_getConjunctionCharacter(pointer_name);
+	if (version == '1.0.0'){
+		var cap = pointer_name + "REQUEST=capabilities&WMTVER=1.0.0";
+		var load = cap;
+	else if (version == '1.1.0'){
+		var cap = pointer_name + "REQUEST=GetCapabilities&SERVICE=WMS&VERSION=1.1.0";
+		var load = cap;
+	else if (version == '1.1.1'){
+		var cap = pointer_name + "REQUEST=GetCapabilities&SERVICE=WMS&VERSION=1.1.1";
+		var load = cap;
+	//alert (load);
+	if(load){
+		if(load.charAt(0) == '/' && load.charAt(1) == 'c'){
+			window.opener.mod_addWMS_load('http://localhost' + load);
+		else{
+			window.opener.mod_addWMS_load(load);
+function mod_show_group_wms(wert){
+	document.form1.show_group_wms.value = wert;
+	document.form1.submit();
+function mod_show_gui_wms(wert2){
+	document.form1.show_gui_wms.value = wert2;
+function mod_show_gui_configured_wms(wert2){
+	document.form1.show_gui_configured_wms.value = wert2;
+function mod_show_wms(wert3){
+	document.form1.wms_show.value = wert3;
+   if (wert3 == 4) {
+		document.form1.wmsSource.nodeValue = "db";
+	else {
+		document.form1.wmsSource.nodeValue = "capabilities";
+function setButtons() {
+	if (typeof(option_all) == "undefined") {
+		option_all = '<?php echo $set_option_all;?>';
+	document.getElementById("set_option_all").value = option_all;
+	if (option_all == '0') {
+		removeChildNodes(document.getElementById("_option_all"));
+	if (typeof(option_group) == "undefined") {
+		option_group = '<?php echo $set_option_group;?>';
+	document.getElementById("set_option_group").value = option_group;
+	if (option_group == '0') {
+		removeChildNodes(document.getElementById("_option_group"));
+	if (typeof(option_gui) == "undefined") {
+		option_gui = '<?php echo $set_option_gui;?>';
+	document.getElementById("set_option_gui").value = option_gui;
+	if (option_gui == '0') {
+		removeChildNodes(document.getElementById("_option_gui"));
+	if (typeof(option_db) == "undefined") {
+		option_db = '<?php echo $set_option_db;?>';
+	document.getElementById("set_option_db").value = option_db;
+	if (option_db == '0') {
+		removeChildNodes(document.getElementById("_option_db"));
+function removeChildNodes(node) {
+	while (node.childNodes.length > 0) {
+		var childNode = node.firstChild;
+		node.removeChild(childNode);
+</script>
+</head>
+<body onLoad="window.focus();setButtons()">
+<?php
+$con = db_connect($DBSERVER,$OWNER,$PW);
+db_select_db(DB,$con);
+require_once(dirname(__FILE__)."/../classes/class_wms.php");
+require_once(dirname(__FILE__)."/../php/mb_getGUIs.php");
+$fieldHeight = 20;
+$cnt_gui = 0;
+$cnt_gui_wms = 0;
+$cnt_wms = 0;
+$cnt_user_group = 0;
+$cnt_group = 0;
+$cnt_gui_mb_group = 0;
+$cnt_group_gui_wms = 0;
+$cnt_fkey_group_gui_wms = 0;
+$cnt_fkey_show_gui_wms = 0;
+$cnt_show_gui_wms = 0;
+$cnt_group_name = 0;
+$cnt_gui_table = 0;
+$exists = false;
+$logged_user_name=$_SESSION["mb_user_name"];
+$logged_user_id=$_SESSION["mb_user_id"];
+$logged_gui_id=$_SESSION["mb_user_gui"];
+######   SQL   #####################################################################################
+/*get infos from gui_element ********************************************************/
+/*get group from logged user  *******************************************************/
+$sql_user_group = "SELECT * FROM mb_user_mb_group WHERE fkey_mb_user_id= $1 ";
+$array_values = array($logged_user_id);
+$array_types = array('s');
+$res_user_group = db_prep_query($sql_user_group, $array_values, $array_types);
+while($row = db_fetch_array($res_user_group)){
+	$user_id[$cnt_user_group] = $row["fkey_mb_user_id"];
+	$group_id[$cnt_user_group] = $row["fkey_mb_group_id"];
+	$cnt_user_group++;
+/*get group from logged user  ************************************************************/
+# Thekla, please recheck
+/*get group name  ********************************************************************************************/
+if(count($group_id) > 0){
+	$v = array();
+	$t = array();
+	$sql_group = "SELECT mb_group_id, mb_group_name, mb_group_description FROM mb_group WHERE mb_group_id IN (";
+	for($i=0; $i < count($group_id); $i++){
+		if($i>0){ $sql_group .= ",";}
+		$sql_group .= "$".strval($i + 1);
+		array_push($v,$group_id[$i]);
+		array_push($t,"i");
+	$sql_group.= ") ORDER BY mb_group_name";
+	$res_group = db_prep_query($sql_group,$v,$t);
+	while($row = db_fetch_array($res_group)){
+		$mb_group_description[$cnt_group] = $row["mb_group_description"];
+		$my_group_name[$cnt_group] = $row["mb_group_name"];
+		$my_group_id[$cnt_group] = $row["mb_group_id"];
+		$cnt_group++;
+/*get allocated gui  ********************************************************************************************/
+$arrayGuis=mb_getGUIs($logged_user_id);
+$sql_gui = "SELECT * FROM gui WHERE gui_id IN (";
+for($i=0; $i<count($arrayGuis); $i++){
+	if($i>0){ $sql_gui .= ",";}
+	$sql_gui .= "'".$arrayGuis[$i]."'";
+$sql_gui.= ") ORDER BY gui_name";
+$res_gui = db_query($sql_gui);
+				while($row = db_fetch_array($res_gui)){
+					$gui_id[$cnt_gui] = $row["gui_id"];
+					$gui_name[$cnt_gui] = $row["gui_name"];
+					$gui_description[$cnt_gui] = $row["gui_description"];
+					#echo"$gui_name[$cnt_gui]";
+					$cnt_gui++;
+/*get allocated wms from allocated gui  ********************************************************************************************/
+$sql_gui_wms = "SELECT DISTINCT fkey_wms_id, fkey_gui_id FROM gui_wms WHERE fkey_gui_id IN (";
+	if($i>0){ $sql_gui_wms .= ",";}
+	$sql_gui_wms .= "'".$arrayGuis[$i]."'";
+$sql_gui_wms.= ") ORDER BY fkey_wms_id";
+$res_gui_wms = db_query($sql_gui_wms);
+while($row = db_fetch_array($res_gui_wms)){
+				$fkey_gui_id[$cnt_gui_wms] = $row["fkey_gui_id"];
+	$fkey_wms_id[$cnt_gui_wms] = $row["fkey_wms_id"];
+	$cnt_gui_wms++;
+/*get allocated wms-Abstract and wms-Capabilities from allocated gui  ********************************************************************************************/
+$sql_wms = "SELECT DISTINCT wms_title, wms_abstract, wms_getcapabilities, wms_version FROM wms WHERE wms_id IN (";
+for($i=0; $i<count($fkey_wms_id); $i++){
+	if($i>0){ $sql_wms .= ",";}
+	$sql_wms .= "'".$fkey_wms_id[$i]."'";
+$sql_wms.= ") ORDER BY wms_title";
+$res_wms = db_query($sql_wms);
+				while($row = db_fetch_array($res_wms)){
+					$wms_title[$cnt_wms] = $row["wms_title"];
+					$wms_abstract[$cnt_wms] = $row["wms_abstract"];
+					$wms_getcapabilities[$cnt_wms] = $row["wms_getcapabilities"];
+					$wms_version[$cnt_wms] = $row["wms_version"];
+					$cnt_wms++;
+/*INSERT HTML*/
+echo "<form name='form1' action='" . $PHP_SELF . "?".SID."' method='post'>";
+# Button
+echo "<table border='0' cellpadding='3'  rules='rows'>";
+echo "<tr>";
+if (isset($wms_show)){
+	echo "<td id='_option_all'><input type='button' class='wms_button' name='wms1' value='all wms' onclick='mod_show_wms(1)'></td>";
+	echo "<td id='_option_group'><input type='button' class='wms_button' name='wms2' value='group' onclick = 'mod_show_wms(2)'></td>";
+	echo "<td id='_option_gui'><input type='button' class='wms_button' name='wms3' value='gui' onclick = 'mod_show_wms(3)'></td>";
+	echo "<td id='_option_db'><input type='button' class='wms_button' name='wms4' value='db' onclick = 'mod_show_wms(4)'></td>";
+	echo "</tr>";
+	echo "</table>";
+######   SHOW GUI WMS OR GROUP WMS   #####################################################################################
+/*show goup wms  ********************************************************************************************/
+#if (isset($show_group_wms))
+if (!empty($show_group_wms)){
+	/*get gui goup   ********************************************************************************************/
+	$sql_gui_mb_group = "SELECT fkey_gui_id, fkey_mb_group_id FROM gui_mb_group WHERE fkey_mb_group_id='".$show_group_wms."'";
+	$res_gui_mb_group = db_query($sql_gui_mb_group);
+				while($row = db_fetch_array($res_gui_mb_group)){
+					$group_gui_id[$cnt_gui_mb_group] = $row["fkey_gui_id"];
+					$fkey_mb_group_id[$cnt_gui_mb_group] = $row["fkey_mb_group_id"];
+					#echo"$group_gui_id[$cnt_gui_mb_group]";
+					$cnt_gui_mb_group++;
+	/*get group gui WMS  ********************************************************************************************/
+	if(count($group_gui_id)>0)	{
+		$sql_fkey_group_gui_wms = "SELECT DISTINCT fkey_wms_id, fkey_gui_id FROM gui_wms WHERE fkey_gui_id IN (";
+		for($i=0; $i<count($group_gui_id); $i++){
+			if($i>0){ $sql_fkey_group_gui_wms .= ",";}
+			$sql_fkey_group_gui_wms .= "'".$group_gui_id[$i]."'";
+		$sql_fkey_group_gui_wms.=  ") ORDER BY fkey_wms_id";
+		$res_fkey_group_gui_wms = db_query($sql_fkey_group_gui_wms);
+		while($row = db_fetch_array($res_fkey_group_gui_wms)){
+			$fkey_group_gui_gui_id[$cnt_fkey_group_gui_wms] = $row["fkey_gui_id"];
+			$fkey_group_gui_wms_id[$cnt_fkey_group_gui_wms] = $row["fkey_wms_id"];
+			#echo"$fkey_group_gui_wms_id[$cnt_fkey_group_gui_wms]";
+			$cnt_fkey_group_gui_wms++;
+		/*group: get allocated wms-Abstract and wms-Capabilities from allocated gui  ********************************************************************************************/
+		if(count($fkey_group_gui_wms_id)>0){
+			$sql_group_gui_wms = "SELECT DISTINCT wms_title, wms_abstract, wms_getcapabilities, wms_version FROM wms WHERE wms_id IN (";
+			for($i=0; $i<count($fkey_group_gui_wms_id); $i++){
+				if($i>0){ $sql_group_gui_wms .= ",";}
+				$sql_group_gui_wms .= "'".$fkey_group_gui_wms_id[$i]."'";
+			$sql_group_gui_wms.= ") ORDER BY wms_title";
+			$res_group_gui_wms = db_query($sql_group_gui_wms);
+			while($row = db_fetch_array($res_group_gui_wms)){
+				$group_wms_title[$cnt_group_gui_wms] = $row["wms_title"];
+				$group_wms_abstract[$cnt_group_gui_wms] = $row["wms_abstract"];
+				$group_wms_getcapabilities[$cnt_group_gui_wms] = $row["wms_getcapabilities"];
+				$group_wms_version[$cnt_group_gui_wms] = $row["wms_version"];
+				#echo"$group_wms_title[$cnt_group_gui_wms]";
+				$cnt_group_gui_wms++;
+	/*table with allocated wms-Abstract and wms-Capabilities from allocated gui  ********************************************************************************************/
+	#if ($show_group_wms > 0)
+	if ($cnt_group_gui_wms > 0){
+		/*get goup name for showing in the table ********************************************************************************************/
+		$sql_group_name = "SELECT mb_group_id, mb_group_name FROM mb_group WHERE mb_group_id ='".$show_group_wms."'";
+		$res_group_name = db_query($sql_group_name);
+		while($row = db_fetch_array($res_group_name)){
+			$group_name_table[$cnt_group_name] = $row["mb_group_name"];
+			$my_group_id_table[$cnt_group_name] = $row["mb_group_id"];
+			$cnt_group_name++;
+	/*get goup name  ********************************************************************************************/
+	echo"<br>";
+	echo"<br>";
+		echo"wms from group: $group_name_table[0]";
+		echo"<br>";
+		echo"<br>";
+	echo "<table border='1' width ='98%' cellpadding='3' rules='rows'>";
+	echo " <thead bgcolor = '#FAEBD7' >";
+	echo "<tr><td width='200' height='10'>WMS-Title</td><td  align = 'left' class='fieldnames_s'>WMS-Abstract</td>";
+	echo " </thead>";
+	echo " <tbody >";
+		for($i=0; $i<$cnt_group_gui_wms; $i++){
+			echo "<tr class='Farbe' onmouseover='this.style.backgroundColor = \"#F08080\"' onmouseout='this.style.backgroundColor = \"#ffffff\"'>";
+			echo "<td><div id ='id_".$group_wms_title[$i]."' class='even' name ='name_".$group_wms_title[$i]."'  style='cursor:pointer' onclick = 'mod_addWMSfromfilteredList(\"".$group_wms_getcapabilities[$i]."\",\"".$group_wms_version[$i]."\")'>".$group_wms_title[$i]."</div></td>";
+			echo "<td><div id ='id_".$group_wms_abstract[$i]."' class='even' name ='name_".$group_wms_abstract[$i]."' style='cursor:pointer' onclick = 'mod_addWMSfromfilteredList(\"".$group_wms_getcapabilities[$i]."\",\"".$group_wms_version[$i]."\")'>".$group_wms_abstract[$i]."</div></td>";
+			echo "</tr>";
+		echo "  </tbody>";
+		echo "</table>";
+		else{
+			echo"<br>";
+			echo"<br>";
+			echo "no wms in this group";
+		}/*End: if ($show_group_wms > 0)   *********/
+	}/*End: if (!empty($show_group_wms))   *********/
+/*show gui wms  ********************************************************************************************/
+if (!empty($show_gui_wms)){
+	$sql_fkey_show_gui_wms = "SELECT DISTINCT fkey_wms_id, fkey_gui_id FROM gui_wms WHERE fkey_gui_id ='".$show_gui_wms."'";
+	#$sql_fkey_show_gui_wms.= ") ORDER BY fkey_wms_id";
+	$res_fkey_show_gui_wms = db_query($sql_fkey_show_gui_wms);
+	while($row = db_fetch_array($res_fkey_show_gui_wms)){
+		$fkey_show_gui_gui_id[$cnt_fkey_show_gui_wms] = $row["fkey_gui_id"];
+		$fkey_show_gui_wms_id[$cnt_fkey_show_gui_wms] = $row["fkey_wms_id"];
+		#echo"$fkey_show_gui_wms_id[$cnt_fkey_show_gui_wms]";
+		$cnt_fkey_show_gui_wms++;
+	/*gui: get allocated wms-Abstract and wms-Capabilities from allocated gui  ********************************************************************************************/
+	if(count($fkey_show_gui_wms_id)>0){
+		$sql_show_gui_wms = "SELECT DISTINCT wms_title, wms_abstract, wms_getcapabilities, wms_id, wms_version FROM wms WHERE wms_id IN (";
+		for($i=0; $i<count($fkey_show_gui_wms_id); $i++){
+			if($i>0){ $sql_show_gui_wms .= ",";}
+			$sql_show_gui_wms .= "'".$fkey_show_gui_wms_id[$i]."'";
+		$sql_show_gui_wms.= ") ORDER BY wms_title";
+		$res_show_gui_wms = db_query($sql_show_gui_wms);
+		while($row = db_fetch_array($res_show_gui_wms)){
+			$gui_wms_id[$cnt_show_gui_wms] = $row["wms_id"];
+			$gui_wms_title[$cnt_show_gui_wms] = $row["wms_title"];
+			$gui_wms_abstract[$cnt_show_gui_wms] = $row["wms_abstract"];
+			$gui_wms_getcapabilities[$cnt_show_gui_wms] = $row["wms_getcapabilities"];
+			$gui_wms_version[$cnt_show_gui_wms] = $row["wms_version"];
+			#echo"$gui_wms_title[$cnt_show_gui_wms]";
+			$cnt_show_gui_wms++;
+		#if (isset($cnt_show_gui_wms > 0))
+	if ($cnt_show_gui_wms > 0){
+	/*get selected gui name for table caption ********************************************************************************************/
+	$sql_gui_table = "SELECT * FROM gui WHERE gui_id ='".$show_gui_wms."'";
+	$res_gui_table = db_query($sql_gui_table);
+		while($row = db_fetch_array($res_gui_table)){
+			$gui_id_table[$cnt_gui_table] = $row["gui_id"];
+			$gui_name_table[$cnt_gui_table] = $row["gui_name"];
+			$cnt_gui_table++;
+			#echo"$gui_id_table[0]";
+		echo"<br>";
+		echo"<br>";
+			echo"wms from gui: $gui_name_table[0]";
+			echo"<br>";
+			echo"<br>";
+		echo " </thead>";
+		echo " <tbody >";
+		for($i=0; $i<$cnt_show_gui_wms; $i++){
+			echo "<td><div id ='id_".$gui_wms_title[$i]."' class='even' name ='name_".$gui_wms_title[$i]."'  style='cursor:pointer' onclick = 'mod_addWMSfromfilteredList(\"".$gui_wms_getcapabilities[$i]."\",\"".$gui_wms_version[$i]."\")'>".$gui_wms_title[$i]."</div></td>";
+			echo "<td><div  id ='id_".$gui_wms_abstract[$i]."' class='even' name ='name_".$gui_wms_abstract[$i]."' style='cursor:pointer' onclick = 'mod_addWMSfromfilteredList(\"".$gui_wms_getcapabilities[$i]."\",\"".$gui_wms_version[$i]."\")'>".$gui_wms_abstract[$i]."</div></td>";
+			echo "</tr>";
+		echo "  </tbody>";
+		echo "</table>";
+	else{
+		echo"<br>";
+		echo"<br>";
+		echo"<br>";
+		echo "no wms in this gui";
+  	}  /*End: if ($cnt_show_gui_wms > 0)  *********/
+} /*End: if(isset($show_gui_wms))   *********/
+if (!empty($show_gui_configured_wms)){
+	$sql_fkey_show_gui_wms = "SELECT DISTINCT fkey_wms_id, fkey_gui_id FROM gui_wms WHERE fkey_gui_id ='".$show_gui_configured_wms."'";
+	$sql_gui_table = "SELECT * FROM gui WHERE gui_id ='".$show_gui_configured_wms."'";
+			$cnt_gui_table++;
+		echo"<br>";
+		echo"<br>";
+			echo"<br>";
+			echo"<br>";
+		echo " </thead>";
+		echo " <tbody >";
+			echo "<td><div id ='id_".$gui_wms_title[$i]."' class='even' name ='name_".$gui_wms_title[$i]."'  style='cursor:pointer' onclick = 'mod_addWMSfromDB(\"".$show_gui_configured_wms."\",\"".$gui_wms_id[$i]."\")'>".$gui_wms_title[$i]."</div></td>";
+			echo "<td><div  id ='id_".$gui_wms_abstract[$i]."' class='even' name ='name_".$gui_wms_abstract[$i]."' style='cursor:pointer' onclick = 'mod_addWMSfromDB(\"".$show_gui_configured_wms."\",\"".$gui_wms_id[$i]."\")'>".$gui_wms_abstract[$i]."</div></td>";
+			echo "</tr>";
+		echo "  </tbody>";
+		echo "</table>";
+	else{
+		echo"<br>";
+		echo"<br>";
+		echo"<br>";
+} /*End: if(isset($show_gui_configured_wms))   *********/
+######   SHOW GUI OR GROUP OR ALL WMS   #####################################################################################
+	if ($wms_show == 4){ #gui
+		echo"<br>";
+		echo"<br>";
+		echo"Please select a gui:";
+		echo"<br>";
+		echo"<br>";
+		echo "<table border='1' width='98%' cellpadding='3' rules='rows'>";
+		echo " <thead bgcolor = 'lightgrey' >";
+		echo "<tr><td width='200' height='10'>gui name</td><td  align = 'left' class='fieldnames_s'>description</td>";
+		echo " </thead>";
+		echo " <tbody >";
+		for($i=0; $i<$cnt_gui; $i++){
+			echo "<td><div id ='id_".$gui_name[$i]."' value='".$gui_id[$i]."' class='even' name ='".$gui_name[$i]."'  style='cursor:pointer'  onclick = 'mod_show_gui_configured_wms(\"".$gui_id[$i]."\")'>".$gui_name[$i]."</div></td>";
+			echo "<td><div id ='id_".$gui_description[$i]."' value='".$gui_id[$i]."' class='even' name ='".$gui_description[$i]."' style='cursor:pointer' onclick = 'mod_show_gui_configured_wms(\"".$gui_id[$i]."\")'>".$gui_description[$i]."</div></td>";
+			echo "</tr>";
+		echo "  </tbody>";
+		echo "</table>";
+	if ($wms_show == 3){ #gui
+		echo"<br>";
+		echo"<br>";
+		echo"<br>";
+		echo"<br>";
+		echo " </thead>";
+		echo " <tbody >";
+			echo "<td><div id ='id_".$gui_name[$i]."' value='".$gui_id[$i]."' class='even' name ='".$gui_name[$i]."'  style='cursor:pointer'  onclick = 'mod_show_gui_wms(\"".$gui_id[$i]."\")'>".$gui_name[$i]."</div></td>";
+			echo "<td><div id ='id_".$gui_description[$i]."' value='".$gui_id[$i]."' class='even' name ='".$gui_description[$i]."' style='cursor:pointer' onclick = 'mod_show_gui_wms(\"".$gui_id[$i]."\")'>".$gui_description[$i]."</div></td>";
+			echo "</tr>";
+		echo "  </tbody>";
+		echo "</table>";
+	elseif  ($wms_show== 2){  # group
+		echo"<br>";
+		echo"<br>";
+		if($cnt_group>0){
+			echo "Please select a group:";
+			echo"<br>";
+			echo"<br>";
+			echo "<tr><td  width='200' height='10'>group name</td><td  align = 'left' class='fieldnames_s'>description</td>";
+			echo " </thead>";
+			echo " <tbody >";
+			for($i=0; $i<$cnt_group; $i++){
+				echo "<td><div id ='id_".$my_group_name[$i]."' value='".$my_group_id[$i]."' class='even' name ='".$my_group_name[$i]."'  style='cursor:pointer'  onclick = 'mod_show_group_wms(\"".$my_group_id[$i]."\")'>".$my_group_name[$i]."</div></td>";
+				echo "<td><div id ='id_".$mb_group_description[$i]."' value='".$my_group_id[$i]."' class='even' name ='".$mb_group_description[$i]."' style='cursor:pointer' onclick = 'mod_show_group_wms(\"".$my_group_id[$i]."\")'>".$mb_group_description[$i]."</div></td>";
+				echo "</tr>";
+			echo "  </tbody>";
+			echo "</table>";
+		else{
+			echo"no group for this user";
+	elseif  ($wms_show== 1){  # all wms
+		echo"<br>";
+		echo"<br>";
+		echo " </thead>";
+		echo " <tbody >";
+		for($i=0; $i<$cnt_wms; $i++){
+			echo "<td><div id ='id_".$wms_title[$i]."' class='even' name ='name_".$wms_title[$i]."'  style='cursor:pointer' onclick = 'mod_addWMSfromfilteredList(\"".$wms_getcapabilities[$i]."\",\"".$wms_version[$i]."\")'>".$wms_title[$i]."</div></td>";
+			echo "<td><div  id ='id_".$wms_abstract[$i]."' class='even' name ='name_".$wms_abstract[$i]."' style='cursor:pointer' onclick = 'mod_addWMSfromfilteredList(\"".$wms_getcapabilities[$i]."\",\"".$wms_version[$i]."\")'>".$wms_abstract[$i]."</div></td>";
+			echo "</tr>";
+		echo "  </tbody>";
+		echo "</table>";
+else{     #if (!isset($wms_show))
+echo "<td id='_option_all'><input type='button' class='wms_button' name='wms1' value='all wms' onclick='mod_show_wms(1)'></td>";
+echo "<td id='_option_group'><input type='button' class='wms_button' name='wms2' value='group' onclick = 'mod_show_wms(2)'></td>";
+echo "<td id='_option_gui'><input type='button' class='wms_button' name='wms3' value='gui' onclick = 'mod_show_wms(3)'></td>";
+echo "<td id='_option_db'><input type='button' class='wms_button' name='wms4' value='db' onclick = 'mod_show_wms(4)'></td>";
+#	echo "<td><input type='button' class='wms_button' name='wms1' value='all wms' onclick='mod_show_wms(1)'></td>";
+#	echo "<td><input type='button' class='wms_button' name='wms2' value='group' onclick = 'mod_show_wms(2)'></td>";
+#	echo "<td><input type='button' class='wms_button' name='wms3' value='gui' onclick = 'mod_show_wms(3)'></td>";
+	echo "</tr>";
+	echo "</tbody>";
+	echo "</table>";
+	echo"<br>";
+	echo"<br>";
+	echo " </thead>";
+	echo " <tbody >";
+		echo "</tr>";
+	echo "  </tbody>";
+	echo "</table>";
+/*show group wms  ********************************************************************************************/
+echo "<input type='hidden' name='show_group_wms'>";
+echo "<input type='hidden' name='show_gui_wms'>";
+echo "<input type='hidden' name='show_gui_configured_wms'>";
+/*show button  ********************************************************************************************/
+echo "<input type='hidden' name='wms_show'>";
+echo "<input id='wmsSource' type='hidden' name='wmsSource'>";
+echo "<input name ='set_option_all' id='set_option_all' type='hidden'>";
+echo "<input name='set_option_group' id='set_option_group' type='hidden'>";
+echo "<input name='set_option_gui' id='set_option_gui' type='hidden'>";
+echo "<input name='set_option_db' id='set_option_db' type='hidden'>";
+echo "</form>";
+</script>
+</body>
 </html>
\ No newline at end of file
More information about the Mapbender_commits mailing list
