[Mapbender-commits] r1343 - branches/redesign/http/javascripts
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu May 24 02:54:03 EDT 2007
Author: uli
Date: 2007-05-24 02:54:03 -0400 (Thu, 24 May 2007)
New Revision: 1343
   branches/redesign/http/javascripts/map.php
some new methods for the mb_mapObj and a new function getMapObjByName
Modified: branches/redesign/http/javascripts/map.php
--- branches/redesign/http/javascripts/map.php	2007-05-23 15:33:16 UTC (rev 1342)
+++ branches/redesign/http/javascripts/map.php	2007-05-24 06:54:03 UTC (rev 1343)
@@ -163,12 +163,75 @@
    this.epsg = wms[0].gui_wms_epsg;
    this.extent = setExtent(this.width,this.height,this.epsg);
    this.mapURL = new Array();
+	 * get the width of the mapObj
+	 * @member mb_mapObj_const
+	 * @return width of the mapObj
+	 * @type integer
+	this.getWidth = function(){
+		return this.width;
+	 * get the height of the mapObj
+	 * @type integer
+		return this.height;
+	 * get the extent of the mapObj
+	 * @return extent of the mapObj as commaseparated minx,minx,maxx,maxy
+	 * @type string
+	this.getExtent = function(){
+		return this.extent;
+	 * get the srs of the mapObj
+	 * @return srs as epsg:number
+	 * @type string
+	this.getSRS = function(){
+		return this.epsg;
+	 * get all featureInfoRequests
+	 * @param float x the x-value of the click position in pixel
+	 * @param float y the y-value of the click position in pixel
+	 * @return array of all featureInfoRequests of this map object
+	 * @type string[]
+	this.getFeatureInfoRequests = function(clickPoint){
+		var allRequests = [];
+		//loop through all wms to get the FeatureInfoRequests
+		for(var i=0; i<this.wms.length; i++){
+			allRequests.push(this.wms[i].getFeatureInfoRequest(this, clickPoint));
    for(var i=0; i<mb_MapObjectSubFunctions.length; i++){
       eval(mb_MapObjectSubFunctions[i]);
 function mb_getConjunctionCharacter(onlineresource){
 	if(onlineresource.indexOf("?") > -1){
 		if(onlineresource.charAt(onlineresource.length-1) == "?"){
@@ -352,7 +415,7 @@
 function setMapRequest(frameName){
-	var functionName = 'setMapRequest';
 	var ts = mb_timestamp();
 	for(var i=0; i<mb_MapRequestPreFunctions.length; i++){
@@ -446,7 +509,7 @@
 function setSingleMapRequest(frameName,wms_id){
-	var functionName = 'setSingleMapRequest';
@@ -601,7 +664,6 @@
 	return str_layerstyles;
 function setFeatureInfoRequest(fName,x,y, path) {
-	var functionName = 'setFeatureInfoRequest';
 	for(var i=0; i<mb_FeatureInfoPreFunctions.length; i++){
 		eval(mb_FeatureInfoPreFunctions[i]);
@@ -924,6 +986,14 @@
+function getMapObjByName(frameName){
+	for(var i=0; i<mb_mapObj.length; i++){
+		if(mb_mapObj[i].frameName == frameName){
+			return mb_mapObj[i];
+	return false;
 function mb_getLayerTitleByName(map_index, wms_index, myLayer_name){
 	for(var i=0; i<mb_mapObj[map_index].wms[wms_index].objLayer.length; i++){
 		if(mb_mapObj[map_index].wms[wms_index].objLayer[i].layer_name == myLayer_name){
More information about the Mapbender_commits mailing list
