[Mapbender-commits] r1360 - branches/mapbender_sld/http/javascripts
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri May 25 04:59:17 EDT 2007
Author: astrid_emde
Date: 2007-05-25 04:59:17 -0400 (Fri, 25 May 2007)
New Revision: 1360
Added:
   branches/mapbender_sld/http/javascripts/mod_add_SLD.php
only to have a look
Added: branches/mapbender_sld/http/javascripts/mod_add_SLD.php
--- branches/mapbender_sld/http/javascripts/mod_add_SLD.php	                        (rev 0)
+++ branches/mapbender_sld/http/javascripts/mod_add_SLD.php	2007-05-25 08:59:17 UTC (rev 1360)
@@ -0,0 +1,64 @@
+<?php
+# $Id$
+# add SLD-Parameter parameters to MapRequest
+# http://www.mapbender.org/index.php/mod_add_vendorspecific.php
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+var sldURL = "";
+var mod_remove_layer_and_styles = "";
+var removeLayerAndStylesAffectedWMSTitle = "deegree wms";
+//var addSldAffectedWMSTitle = "deegree wms";
+//var sldLocationUrl = "http://wms1.ccgis.de/mapbender_dev/tmp/";
+var addSldAffectedWMSTitle = "Bonn Ergebnisse";
+var sldLocationUrl = "http://localhost/bonn_orlando_svn/http/tmp/";
+mod_remove_layer_and_styles += "if (sldURL != '' && (functionName == 'setMapRequest' || functionName == 'setSingleMapRequest') && mb_mapObj[i].wms[ii].wms_title == removeLayerAndStylesAffectedWMSTitle){";
+mod_remove_layer_and_styles += "newMapURL = newMapURL.replace(/LAYERS=[^&]*&/, '');";
+mod_remove_layer_and_styles += "newMapURL = newMapURL.replace(/STYLES=[^&]*&/, '');";
+mod_remove_layer_and_styles += "}";
+function mod_sld_init(wmsTitle, functionName) {
+		//alert(sldURL + ' ' + functionName );
+	if (sldURL != ''){
+		if (functionName == 'setMapRequest' || functionName == 'setSingleMapRequest') {
+			//Stadt Bonn: if (wmsTitle == 'deegree wms'){
+			if (wmsTitle == addSldAffectedWMSTitle){
+				return 'SLD=' + sldURL;
+	return "";
+mb_registerVendorSpecific(mod_remove_layer_and_styles);
+mb_registerVendorSpecific("mod_sld_init(mb_mapObj[i].wms[ii].wms_title, functionName);");
+function mod_set_sld(sldString){
+	//console.debug("%s",sldString);
+	mb_ajax_post("../orlando/saveSLD.php", {'sld':sldString}, function (json, status) {
+	var result = eval('('+json+')');
+	sldURL = sldLocationUrl + result.filename;
+	zoom("mapframe1", true,0.9999);
Property changes on: branches/mapbender_sld/http/javascripts/mod_add_SLD.php
___________________________________________________________________
   + HeadURL Id LastChangedBy LastChangedDate LastChangedRevision
More information about the Mapbender_commits mailing list
