[Mapbender-commits] r1367 - branches/redesign/http/javascripts
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri May 25 10:44:55 EDT 2007
Author: uli
Date: 2007-05-25 10:44:55 -0400 (Fri, 25 May 2007)
New Revision: 1367
   branches/redesign/http/javascripts/map.php
   branches/redesign/http/javascripts/map_obj.js
   branches/redesign/http/javascripts/mod_featureInfo_collect.php
Modified: branches/redesign/http/javascripts/map.php
--- branches/redesign/http/javascripts/map.php	2007-05-25 14:26:37 UTC (rev 1366)
+++ branches/redesign/http/javascripts/map.php	2007-05-25 14:44:55 UTC (rev 1367)
@@ -221,7 +221,10 @@
 		var allRequests = [];
 		//loop through all wms to get the FeatureInfoRequests
 		for(var i=0; i<this.wms.length; i++){
-			allRequests.push(this.wms[i].getFeatureInfoRequest(this, clickPoint));
+			var currentRequest = this.wms[i].getFeatureInfoRequest(this, clickPoint);
+			if(currentRequest){
+				allRequests.push(currentRequest);
 		if(allRequests.length > 0){
 			return allRequests;
Modified: branches/redesign/http/javascripts/map_obj.js
--- branches/redesign/http/javascripts/map_obj.js	2007-05-25 14:26:37 UTC (rev 1366)
+++ branches/redesign/http/javascripts/map_obj.js	2007-05-25 14:44:55 UTC (rev 1367)
@@ -131,7 +131,7 @@
 	rq += "&EXCEPTIONS=application/vnd.ogc.se_xml";
 	rq += "&X=" + clickPoint.x;
 	rq += "&Y=" + clickPoint.y;
+	return rq;
 //TODO: handle FEATURE_COUNT AS ELEMENT_VAR IN EACH MODULE
 //	if(mb_feature_count > 0){
 //		rq += "FEATURE_COUNT="+mb_feature_count+"&";
Modified: branches/redesign/http/javascripts/mod_featureInfo_collect.php
--- branches/redesign/http/javascripts/mod_featureInfo_collect.php	2007-05-25 14:26:37 UTC (rev 1366)
+++ branches/redesign/http/javascripts/mod_featureInfo_collect.php	2007-05-25 14:44:55 UTC (rev 1367)
@@ -16,8 +16,15 @@
 # You should have received a copy of the GNU General Public License
 # along with this program; if not, write to the Free Software
 # Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-include '../include/dyn_css.php';
-echo "mod_featureInfoResult = '".$featureInfoResult."';"
+ * element_var: mod_featureInfoResult: Type (one window, each request in a separate window etc.)
+// further element_vars: feature_count, window.width, window.height
+$gui_id = $_REQUEST["gui_id"];
+include '../include/dyn_js.php';
 var mod_featureInfo_elName = "featureInfo_collect";
 var mod_featureInfo_frameName = "";
@@ -44,6 +51,7 @@
 function mod_featureInfo_disable(){
 	window.frames[mod_featureInfo_target].document.onclick = null;
+mod_featureInfoResWin = false;
 function mod_featureInfo_event(e){
 	if(ie){
 		clickX = window.frames[mod_featureInfo_target].event.clientX;
@@ -56,21 +64,30 @@
 	var clickPoint = new Point(clickX,clickY);
 	var myObj = getMapObjByName(mod_featureInfo_target);
 	var myRequests = myObj.getFeatureInfoRequests(clickPoint);
-	// TODO: CONSIDER NULL REQUESTS
+	if(myRequests.length == 0){
+		return false;
 	if(mod_featureInfoResult == 'window'){
-		mod_featureInfoResWin = window.open("../html/mod_blank.html", "mod_featureInfoResWin" , "width=300,height=400,scrollbars=yes,resizable=yes");
+		if(!mod_featureInfoResWin || mod_featureInfoResWin.closed == true){
+			mod_featureInfoResWin = window.open("../html/mod_blank.html", "mod_featureInfoResWin" , "width=300,height=400,scrollbars=yes,resizable=yes,dependent=yes");
+		else{
+			mod_featureInfoResWin.document.getElementsByTagName("body")[0].innerHTML = "";
+			mod_featureInfoResWin.focus();
+			console.log("focus");
 		var doc = mod_featureInfoResWin.document;
 		for(i=0; i<myRequests.length;i++){
-			var resDiv = doc.createElement("div");
-			var resId = doc.createAttribute("id");
-			resId.nodeValue = "res"+i;
-			resDiv.setAttributeNode(resId);
-			doc.getElementsByTagName("body")[0].appendChild(resDiv);
-		for(i=0; i<myRequests.length;i++){
 			mb_ajax_post("../extensions/ext_featureInfoTunnel.php", {url:myRequests[i]}, function(result, status) {
+				var doc = mod_featureInfoResWin.document;
+				var resDiv = doc.createElement("div");
+				var resId = doc.createAttribute("id");
+				resId.nodeValue = "res"+i;
+				resDiv.setAttributeNode(resId);
+				resDiv.innerHTML = 'hallo';
+				doc.getElementsByTagName("body")[0].appendChild(resDiv);
 				doc.getElementById("res"+i).innerHTML = result;
\ No newline at end of file
More information about the Mapbender_commits mailing list
