[Mapbender-commits] r1375 - trunk/mapbender/http/print
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Tue May 29 10:33:18 EDT 2007
Author: sven
Date: 2007-05-29 10:33:18 -0400 (Tue, 29 May 2007)
New Revision: 1375
Added:
   trunk/mapbender/http/print/print_functions.php
   trunk/mapbender/http/print/mod_printPDF.php
   trunk/mapbender/http/print/mod_printPDF_pdf.php
add temporary elements
Modified: trunk/mapbender/http/print/mod_printPDF.php
--- trunk/mapbender/http/print/mod_printPDF.php	2007-05-29 12:22:37 UTC (rev 1374)
+++ trunk/mapbender/http/print/mod_printPDF.php	2007-05-29 14:33:18 UTC (rev 1375)
@@ -18,6 +18,7 @@
 # Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
 session_start();
 require_once(dirname(__FILE__)."/../../conf/mapbender.conf");
 <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
@@ -282,6 +283,24 @@
 			document.form1.mylegend.value = 'true';
+		// write the measured coordinates
+		var tmp_x = '';
+		var tmp_y = '';
+		var tmp_dist = '';
+		for(i = 0; i<pt.mod_measure_RX.length; i++) {
+			if(tmp_x != '') {
+				tmp_x += ','
+			tmp_x += pt.mod_measure_RX[i];
+		for(i = 0; i<pt.mod_measure_RY.length; i++) {
+			if(tmp_y != '') {
+				tmp_y += ','
+			tmp_y += pt.mod_measure_RY[i];
+		document.forms['form1'].elements['measured_x_values'].value = tmp_x;
+		document.forms['form1'].elements['measured_y_values'].value = tmp_y;
 		document.form1.submit();
 	else{
@@ -371,6 +390,8 @@
 <input type='hidden' name='comment1' value=''>
 <input type='hidden' name='comment2' value=''>
 <input type='hidden' name='mylegend' value='true'>
+<input type='hidden' name='measured_x_values' value=''>
+<input type='hidden' name='measured_y_values' value=''>
 </form>
 </body>
Modified: trunk/mapbender/http/print/mod_printPDF_pdf.php
--- trunk/mapbender/http/print/mod_printPDF_pdf.php	2007-05-29 12:22:37 UTC (rev 1374)
+++ trunk/mapbender/http/print/mod_printPDF_pdf.php	2007-05-29 14:33:18 UTC (rev 1375)
@@ -29,6 +29,8 @@
 include (dirname(__FILE__)."/../classes/class_weldOverview2PNG.php");
 include (dirname(__FILE__)."/../print/".$_REQUEST["conf"]);
 include (dirname(__FILE__)."/../classes/class_SaveLegend.php");
+include (dirname(__FILE__)."/../print/print_functions.php");
 if($log == true){
 	include (dirname(__FILE__)."/../classes/class_log.php");
@@ -435,6 +437,38 @@
 $pdf->addText($mapOffset_left  + $map_width - ($pdf->getTextWidth($mySize, $myMaxx)), $mapOffset_bottom + $map_height  + 3, $mySize, $myMaxx);
 $pdf->addText($mapOffset_left + $map_width + 3, $mapOffset_bottom + $map_height, $mySize, $myMaxy, 90);
+* user drawn elements
+$theMeasureConfigArray = array(
+   "do_fill" => FALSE,
+     "fill_color" => array(
+     "r" => "0.95",
+     "g" => "0.95",
+     "b" => "0.95"
+   "do_stroke" => TRUE,
+     "stroke_color" => array(
+     "r" => 254 / 255,
+     "g" => 1 / 255,
+     "b" => 1 / 255
+   "line_style" => array(
+       "width" => 2,
+       "cap" => 'butt',
+       "join" => 'miter',
+       "dash" => array(10, 6)
+$use_r = 180 / 255;
+$use_g = 206 / 255;
+$use_b = 140 / 255;
+addMeasuredItem(&$pdf, $_POST['measured_x_values'], $_POST['measured_y_values'], $theMeasureConfigArray);
+hideElementsOutsideMapframe(&$pdf);
 if ($overview==true){
 	// analyse request, draw rectancle
 	$filename = str_replace("map_","overview_",$filename);
Added: trunk/mapbender/http/print/print_functions.php
--- trunk/mapbender/http/print/print_functions.php	                        (rev 0)
+++ trunk/mapbender/http/print/print_functions.php	2007-05-29 14:33:18 UTC (rev 1375)
@@ -0,0 +1,375 @@
+<?php
+ * converts the coordinates created via the JavaScript
+ * functions in 'mod_measure.php' into an array which
+ * then holds both X- ans Y-values for each point in
+ * the formats 'realworld coordinate' and 'pdf_coordinate'
+ * @param string commaseperated X-values of the points (realworld coordinate)
+ * @param string commaseperated Y-values of the points (realworld coordinate)
+ * @return array Array looking like 0 => array(
+ *                                         'real_x' => 1234567,
+ *                                         'real_y' => 7654321,
+ *                                         'pdf_x'  => 451.12,
+ *                                         'pdf_y'  => 254.7
+ * @see transformForPDF
+ * @author M. Jansen <jansen at terrestris.de>, 2006-05-26
+function makeCoordPairs($x_values, $y_values) {
+  $arr_x = explode(",", $x_values);
+	$arr_y = explode(",", $y_values);
+	$x_elems = count($arr_x);
+	$y_elems = count($arr_y);
+	$the_return_arr = array();
+	if ($x_elems == $y_elems) {
+	  for ($i = 0; $i < $x_elems; $i ++) {
+		  $the_return_arr[$i] = array(
+			                        "real_x" => $arr_x[$i],
+															"real_y" => $arr_y[$i],
+															"pdf_x"  => transformForPDF($arr_x[$i], "x"),
+															"pdf_y"  => transformForPDF($arr_y[$i], "y")
+	return $the_return_arr;
+} // end of function makeCoordPairs
+ * Transforms given realworld-coordinate according to its type (X or Y)
+ * into a pdf-coordinate. Needs the variables $mapOffset_left, $mapOffset_bottom,
+ * $map_height, $map_width, $coord to be defined in a global scope.
+ * @param float the realworld coordinate
+ * @param string type of coordinate either 'X' or 'Y'
+ * @see makeCoordPairs [needs this function]
+ * @return float the pdf-coordinate
+function transformForPDF ($theRealCoord, $theType) {
+  global $mapOffset_left, $mapOffset_bottom, $map_height, $map_width, $coord;
+	$thePDFvalue = "";
+	switch (strtolower($theType)) {
+	  case 'x':
+		  // calculate pdf x-pos:
+			$real_shown_width = $coord[2] - $coord[0];
+			$ratio_to_display = $map_width / $real_shown_width;
+			$target_width     = $theRealCoord - $coord[0];
+			$thePDFvalue      = $mapOffset_left + ($target_width * $ratio_to_display);
+			break;
+		case 'y':
+		  // calculate pdf y-pos:
+			$real_shown_height = $coord[3] - $coord[1];
+			$ratio_to_display  = $map_height / $real_shown_height;
+			$target_height     = $theRealCoord - $coord[1];
+			$thePDFvalue       = $mapOffset_bottom + ($target_height * $ratio_to_display);
+		  break;
+		default:
+		  // a non valid parameter was given
+		  $thePDFvalue = $theRealCoord;
+      break;
+	return $thePDFvalue;
+} // end of function transformForPDF
+ * extracts PDF-relevant information from a full coordinates array
+ * and returns a transformed array
+ * @param array the Array containing all infos about single coordinates
+ *              created via makeCoordPairs()
+ * @return array the array containing PDF-Values for a polygon
+function makePolyFromCoord($theFullCoordinatesArray) {
+  $theRetArr = array();
+	foreach($theFullCoordinatesArray as $singlePoint) {
+	  $theRetArr[] = $singlePoint['pdf_x'];
+		$theRetArr[] = $singlePoint['pdf_y'];
+	return $theRetArr;
+} // end of function makePolyFromCoord
+ * converts an array of coordinates (created e.g. by makeCoordPairs()) into
+ * an array thats needed to draw lines via line(x0, y0, x1, y1)
+ * @return array the array containing PDF-Values for single lines
+function makeStrokePointPairs($thePointArray) {
+  $cnt = count($thePointArray);
+	$theRetArray = array();
+  for($i = 0; $i < $cnt; $i++) {
+	  if($i != $cnt - 1) {
+		  $theRetArray[] = array(
+		    $thePointArray[$i]['pdf_x'],
+				$thePointArray[$i]['pdf_y'],
+				$thePointArray[$i+1]['pdf_x'],
+				$thePointArray[$i+1]['pdf_y'],
+		} else {
+				$thePointArray[0]['pdf_x'],
+				$thePointArray[0]['pdf_y'],
+	return $theRetArray;
+} // end of function makeStrokePointPairs
+ * test whether the coordinates in an array form a closed polygon
+ * meaning that first an last point of polygon are equal
+ * @return bool is it closed (TRUE || FALSE)
+function isClosedPolygon($coord_arr) {
+  $nr_of = count($coord_arr);
+	if ($coord_arr[0]['pdf_x'] == $coord_arr[$nr_of-1]['pdf_x']
+	    && $coord_arr[0]['pdf_y'] == $coord_arr[$nr_of-1]['pdf_y']
+			&& $nr_of != 1) {
+	  return TRUE;
+	} else {
+	  return FALSE;
+}  // end of function isClosedPolygon
+ * Adds the measured item to the PDF output.
+ * @param object reference (!) to the current ezPDF-Object
+ * @param string commaseperated X-Values of polygon / line
+ * @param string commaseperated Y-Values of polygon / line
+ * @param array configuration settings.
+ * @return void nothing
+ * @see isClosedPolygon
+ * @see makeStrokePointPairs
+ * @see makePolyFromCoord
+function addMeasuredItem($thePDF, $x_value_str, $y_value_str, $theConfArray = array()) {
+  // get global variable:
+  global $legendFilenameUserPolygon;
+	// create legend image:
+	$legend_width = 17;
+	$leg_img = imagecreate($legend_width, $legend_width);
+	// save previous state:
+	$thePDF->saveState();
+	// save colors for legend:
+	if(!defined("MAP_HAS_USER_POLYGON")) {
+	  define("MAP_HAS_USER_POLYGON", "test");
+	// get the arrays
+	$theFullArr = makeCoordPairs($x_value_str, $y_value_str);
+  $thePolyArr = makePolyFromCoord($theFullArr);
+	if (isClosedPolygon($theFullArr)) {
+	  $nr_of_points = count($theFullArr);
+		$isClosed = TRUE;
+	} else {
+	  $nr_of_points = count($theFullArr) - 1;
+		$isClosed = FALSE;
+	// is fill option set?
+	// wenn der erste und letzte punkt nicht übereinstimmen,
+	// so muss in jedem Falle dofill auf 0 gesetzt werden
+	if($theConfArray['do_fill'] != '' && $isClosed) {
+	  $doFill = 1;
+	  // which color to use for filling?
+	  if (is_array($theConfArray['fill_color'])
+	      && $theConfArray['fill_color']['r'] != ''
+			  && $theConfArray['fill_color']['g'] != ''
+			  && $theConfArray['fill_color']['b'] != '') {
+	    $thePDF->setColor($theConfArray['fill_color']['r'], $theConfArray['fill_color']['g'], $theConfArray['fill_color']['b']);
+			$legend_image_fill = $theConfArray['fill_color']['r'] . "," . $theConfArray['fill_color']['g'] . "," . $theConfArray['fill_color']['b'];
+			// color to legend file
+			$bg_color = imagecolorallocate($leg_img, round($theConfArray['fill_color']['r'] * 255), round($theConfArray['fill_color']['g'] * 255), round($theConfArray['fill_color']['b'] * 255));
+	  } else {
+	    $thePDF->setColor(0, 0, 0);
+			$bg_color = imagecolorallocate($leg_img, 0, 0, 0);
+	} else {
+	  $doFill = 0;
+	  $bg_color = imagecolorallocate($leg_img, -1, -1, -1);
+	// Do we need to stroke (outline)?
+	if($theConfArray['do_stroke'] != '') {
+	  if (is_array($theConfArray['stroke_color'])
+	      && $theConfArray['stroke_color']['r'] != ''
+			  && $theConfArray['stroke_color']['g'] != ''
+			  && $theConfArray['stroke_color']['b'] != '') {
+	    $thePDF->setStrokeColor($theConfArray['stroke_color']['r'], $theConfArray['stroke_color']['g'], $theConfArray['stroke_color']['b']);
+			$thePDF->setLineStyle($theConfArray['line_style']['width'], $theConfArray['line_style']['cap'], $theConfArray['line_style']['join'], $theConfArray['line_style']['dash']);
+			$theStrokePointPairs = makeStrokePointPairs($theFullArr);
+			for($i = 0; $i < count($theStrokePointPairs); $i++) {
+			  $line = $theStrokePointPairs[$i];
+				if ($i != count($theStrokePointPairs) - 1
+				    || $isClosed) {
+			    $thePDF->line($line[0], $line[1], $line[2], $line[3]);
+					$stroke_color_legend_image = imagecolorallocate($leg_img, round($theConfArray['stroke_color']['r'] * 255), round($theConfArray['stroke_color']['g'] * 255), round($theConfArray['stroke_color']['b'] * 255));
+					if (is_array($theConfArray['line_style']['dash'])
+					    && $theConfArray['line_style']['dash'][1] != ""
+							&& $theConfArray['line_style']['dash'][1] != 0) {
+						imagedashedline($leg_img, 0, 0, $legend_width-1, 0, $stroke_color_legend_image);
+						imagedashedline($leg_img, $legend_width-1, 0, $legend_width-1, $legend_width-1, $stroke_color_legend_image);
+						imagedashedline($leg_img, $legend_width-1, $legend_width-1, 0, $legend_width-1, $stroke_color_legend_image);
+						imagedashedline($leg_img, 0, $legend_width-1, 0, 0, $stroke_color_legend_image);
+					} else {
+					  imageline($leg_img, 0, 0, $legend_width-1, 0, $stroke_color_legend_image);
+						imageline($leg_img, $legend_width-1, 0, $legend_width-1, $legend_width-1, $stroke_color_legend_image);
+						imageline($leg_img, $legend_width-1, $legend_width-1, 0, $legend_width-1, $stroke_color_legend_image);
+						imageline($leg_img, 0, $legend_width-1, 0, 0, $stroke_color_legend_image);
+  $thePDF->polygon($thePolyArr, $nr_of_points, $doFill);
+  // eventually create the file:
+	imagepng($leg_img, $legendFilenameUserPolygon);
+	$thePDF->restoreState();
+} // end of function addMeasuredItem
+ * Konvertiert einen Text in ein array aus einzelnen Zeilen. Parameter wie Zeichen pro
+ * zeile etc. können in der Funktion geändert werden.
+function convert2lines($the_text) {
+    $words = explode(' ', $the_text);
+	$maxlines                 = 6;
+	$available_chars_per_line = 35;
+	$total_number_of_lines    = 0;
+	$chars_current_line       = 0;
+	$the_return_array         = array();
+    foreach($words as $word) {
+    	// trimme wort auf maximal erlaubte zeichenzahl
+        $word_fit = substr($word, 0, $available_chars_per_line);
+	    $chars = preg_split('//', $word_fit, -1, PREG_SPLIT_NO_EMPTY);
+	    if(count($chars) + $chars_current_line + 1 < $available_chars_per_line && $total_number_of_lines < $maxlines) {
+		    $chars_current_line += count($chars) + 1;
+			$the_return_array[$total_number_of_lines]  .= " " . $word_fit;
+		} elseif($total_number_of_lines < $maxlines) {
+	      $chars_current_line = count($chars) + 1;
+		  $the_return_array[$total_number_of_lines + 1] = " " . $word_fit;
+		  $total_number_of_lines++;
+  return $the_return_array;
+} // end of function convert2lines
+ * Adds two white polygons to hide any user elements outside the mapframe:
+ * First all A-Areas are filled, then all B-Areas. This is a rather grumpy
+ * way out of having user edited stuff flying outside the mapframe.
+ * @example <pre>
+ * BBBBBBBBBBBBBBBBBBBBBBBBBBBBAAA
+ * BBB                                                  AAA
+ * BBB                                                  AAA
+ * BBB       Mapframe                              AAA
+ * BBB                                                  AAA
+ * BBB                                                  AAA
+ * BBB                                                  AAA
+ * AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+ * </pre>
+ * @param reference (!, pass over with '&') to the pdf-file
+function hideElementsOutsideMapframe($pdf) {
+  // get globals
+  global $mapOffset_left, $map_width, $mapOffset_bottom, $map_height;
+  $pdf->saveState();
+  $pdf->setColor(1, 1, 1);
+	// The AAA-Part
+  $allOutside = array(
+    0                              , 0,                       // 1st coord-pair
+    $pdf->ez['pageWidth']          , 0,                       // 2nd coord-pair
+    $pdf->ez['pageWidth']          , $pdf->ez['pageHeight'],  // ...
+    $mapOffset_left + $map_width   , $pdf->ez['pageHeight'],
+    $mapOffset_left + $map_width   , $mapOffset_bottom,
+    0                              , $mapOffset_bottom,
+    0                              , 0
+	// draw polygon
+  $pdf->polygon($allOutside, 7, 1);
+  // The BBB-part
+    0                              , $mapOffset_bottom,       // 1st coord-pair
+    $mapOffset_left                , $mapOffset_bottom,       // 2nd coord-pair
+    $mapOffset_left                , $mapOffset_bottom + $map_height, // ...
+    $mapOffset_left + $map_width   , $mapOffset_bottom + $map_height,
+    0                              , $pdf->ez['pageHeight'],
+	// draw polygon
+  $pdf->restoreState();
\ No newline at end of file
More information about the Mapbender_commits mailing list
