[Mapbender-commits] r1389 - trunk/mapbender/http/javascripts
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Wed May 30 08:09:56 EDT 2007
Author: christoph
Date: 2007-05-30 08:09:56 -0400 (Wed, 30 May 2007)
New Revision: 1389
   trunk/mapbender/http/javascripts/point.js
more JSDoc
Modified: trunk/mapbender/http/javascripts/point.js
--- trunk/mapbender/http/javascripts/point.js	2007-05-30 12:09:34 UTC (rev 1388)
+++ trunk/mapbender/http/javascripts/point.js	2007-05-30 12:09:56 UTC (rev 1389)
@@ -9,17 +9,28 @@
  * @class A class representing a two-dimensional point.
  * @constructor
+ * @param {Float} x x value of the {@link Point}
+ * @param {Float} y y value of the {@link Point}
  function Point(x, y){
+ 	 * x value of the {@link Point}
+	 * @type Float
 	this.x = parseFloat(x);
+ 	 * y value of the {@link Point}
+	 * @type Float
 	this.y = parseFloat(y);
  * computes the distance between a {@link Point} p and this {@link Point}
- * @member Point
- * @param {Point} p
- * @return {Float} the distance between the two points
+ * @param {Point} p the distance between this {@link Point} and the {@link Point} p is computed.
+ * @return {Float} the distance between the two {@link Point} objects.
 Point.prototype.dist = function(p){
 	return Math.sqrt(Math.pow(this.y-p.y,2) + Math.pow(this.x-p.x,2)) ;
@@ -27,7 +38,6 @@
  * checks if the coordinates of this {@link Point} match the coordinates of a {@link Point} p
- * @member Point
  * @param {Point} p
  * @return {Boolean} true if the two points are equal; elso false
@@ -38,9 +48,8 @@
  * subtracts a {@link Point} p from this {@link Point}
- * @member Point
  * @param {Point} p
- * @return a new {Point} with the difference of the two points
+ * @return a new {@link Point} with the difference of the two points
 Point.prototype.minus = function(p){
 	return new Point(this.x-p.x, this.y-p.y);
@@ -48,9 +57,8 @@
  * adds this {@link Point} to a {@link Point} p
- * @member Point
  * @param {Point} p
- * @return a new {Point} with the sum of the two points
+ * @return a new {@link Point} with the sum of the two points
 Point.prototype.plus = function(p){
 	return new Point(this.x+p.x, this.y+p.y);
@@ -58,9 +66,8 @@
  * divides this {@link Point} by a scalar c
- * @member Point
  * @param {Float} c divisor
- * @return a new {Point} divided by c
+ * @return a new {@link Point} divided by c
 Point.prototype.dividedBy = function(c){
 	if (c != 0) {
@@ -72,9 +79,8 @@
  * multiplies this {@link Point} by a scalar c
- * @member Point
  * @param {Float} c factor
- * @return a new {Point} multiplied by c
+ * @return a new {@link Point} multiplied by c
 Point.prototype.times = function(c){
 	return new Point(this.x*c, this.y*c);
@@ -82,15 +88,14 @@
  * rounds the coordinates to numOfDigits digits
- * @member Point
- * @return a new {Point} rounded to numOfDigits
+ * @param numOfDigits the coordinate will be rounded to numOfDigits digits
+ * @return a new {@link Point} rounded to numOfDigits digits
  * @type Point
 Point.prototype.round = function(numOfDigits){
 	return new Point(roundToDigits(this.x, numOfDigits), roundToDigits(this.y, numOfDigits));
- * @member Point
  * @returns a {String} representation of this Point
  * @type String
@@ -101,7 +106,9 @@
 // possible improvement: point has flag: map OR real. additional functions: toReal, toMap
+ * @ignore
 function mapToReal(frameName, aPoint) {
 	var v;
 	if (typeof(mb_mapObj) == 'object') v = makeClickPos2RealWorldPos(frameName, aPoint.x, aPoint.y);
@@ -109,6 +116,9 @@
 	else alert('where am i?');
 	return new Point(v[0], v[1]);
+ * @ignore
 function realToMap(frameName, aPoint) {
 	var v;
 	if (typeof(mb_mapObj) == 'object') {
@@ -122,6 +132,9 @@
+ * @ignore
 function mb_calcExtent(frameName, min, max) {
 	var ind;
@@ -153,6 +166,9 @@
 	mb_mapObj[ind].extent = new_min.x +","+ new_min.y +","+ new_max.x  +","+ new_max.y;
+ * @ignore
 function roundToDigits(aFloat, numberOfDigits) {
 	return Math.round(aFloat*Math.pow(10, parseInt(numberOfDigits)))/Math.pow(10, parseInt(numberOfDigits));
More information about the Mapbender_commits mailing list
