[Mapbender-commits] r1412 - trunk/mapbender
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu May 31 10:57:08 EDT 2007
Author: christoph
Date: 2007-05-31 10:57:08 -0400 (Thu, 31 May 2007)
New Revision: 1412
   trunk/mapbender/Changes.txt
added info from version history
Modified: trunk/mapbender/Changes.txt
--- trunk/mapbender/Changes.txt	2007-05-31 14:36:18 UTC (rev 1411)
+++ trunk/mapbender/Changes.txt	2007-05-31 14:57:08 UTC (rev 1412)
@@ -4,8 +4,49 @@
- Changelog 2.4.1
+Changelog 2.4.2
+  english
+    bug fixes: see http://trac.osgeo.org/mapbender/report/9
+    new features
+    * set WMS opacity in treeGDE2
+    * Bulgarian translation of the introduction to Mapbender
+    * improved module Add WMS from filtered list: loading a configured WMS from a GUI is now possible
+    * updated Meetingpoint / Treffpunkt: new image, some bugfixes
+    * improved exception handling / log levels (see mapbender.conf#Mapbender_error_logging)
+    * poi (not included in a GUI yet)
+    * JavaScript compression; Mapbender will load faster
+    * dynamic overview - integration in the rc1 an testing gui2
+    * treeGDE2 replaces treeGDE
+    * different configurations of treeGDE2
+    * first draft of an API documentation for JavaScript classes
+    * print temporary objects (lines and polygons) which where drawn with the measure element
+  deutsch
+    behobene Fehler: siehe http://trac.osgeo.org/mapbender/report/9
+    neue Features
+    * Einstellen der Deckkraft (Opacity) einzelner WMSe in der TreeGDE2
+    * Bulgarische Übersetzung der Mapbender-Einführung
+    * Verbesserung des Moduls Add WMS from filtered list: es ist nun möglich, konfigurierte WMSe aus GUIs zu laden
+    * Update des Moduls Meetingpoint / Treffpunkt: neue Bilddatei, diverse Fehler behoben
+    * Verbessertes Logging, auch von JavaScript Fehlern (siehe mapbender.conf#Mapbender_error_logging)
+    * poi (noch in keiner GUI enthalten)
+    * JavaScript Kompression; Mapbender lädt schneller
+    * Dynamisches Overview
+    * TreeGDE2 ersetzt die alte Baumstruktur
+    * verschiedene Konfigurationen der TreeGDE2 in den Standard-GUIs
+    * vorläufige API Dokumentation für JavaScript Klassen
+    * Druck von temporären Objekten (Linien und Polygone), die mit dem "measure" Element erstellt wurden
+Changelog 2.4.1
 english
More information about the Mapbender_commits mailing list
