[Mapbender-commits] r1792 - trunk/mapbender/http/classes
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri Nov 9 09:34:28 EST 2007
Author: christoph
Date: 2007-11-09 09:34:28 -0500 (Fri, 09 Nov 2007)
New Revision: 1792
   trunk/mapbender/http/classes/class_wfs_conf.php
moved get all wfs to class_wfs
Modified: trunk/mapbender/http/classes/class_wfs_conf.php
--- trunk/mapbender/http/classes/class_wfs_conf.php	2007-11-09 14:30:22 UTC (rev 1791)
+++ trunk/mapbender/http/classes/class_wfs_conf.php	2007-11-09 14:34:28 UTC (rev 1792)
@@ -18,6 +18,7 @@
 # Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
 require_once(dirname(__FILE__)."/class_mb_exception.php");
+require_once(dirname(__FILE__)."/class_administration.php");
 require_once(dirname(__FILE__)."/../extensions/JSON.php");
 class WfsConf {
@@ -26,8 +27,11 @@
 	 * Gets the configuration from the database
-	function __construct ($idOrIdArray) {
+	function __construct () {
+	public function load ($idOrIdArray) {
 		 * Check parameter and set idArray
@@ -35,7 +39,7 @@
 			// parameter is a number
 			if (!is_array($idOrIdArray) && is_numeric($idOrIdArray)) {
-				$this->getWfsConfFromDB(array(intval($idOrIdArray)));
+				$this->getWfsConfFromDB(array(intval($idOrIdArray)), $_SESSION["mb_user_id"]);
 			// parameter is an array of numbers
 			else if (is_array($idOrIdArray)) {
@@ -47,7 +51,7 @@
 					array_push($idArray, intval($idOrIdArray[$i]));
-				$this->getWfsConfFromDB($idArray);
+				$this->getWfsConfFromDB($idArray, $_SESSION["mb_user_id"]);
 			// parameter is invalid
 			else {
@@ -63,81 +67,103 @@
 	 * get WFS conf data from database
-	private function getWfsConfFromDB ($idArray) {
-		$sql = "SELECT * FROM wfs_conf ";
-		$sql .= "JOIN wfs ON wfs_conf.fkey_wfs_id = wfs.wfs_id ";
-		$sql .= "WHERE wfs_conf.wfs_conf_id IN (";
-		$v = array();
-		$t = array();
-		for ($i = 0; $i < count($idArray); $i++) {
-			if ($i > 0) {$sql .= ", ";}
-			$sql .= "$" . ($i+1);
-			array_push($v, $idArray[$i]);
-			array_push($t, 'i');
+	private function getWfsConfFromDB ($idArray, $userId) {
+		 * If a user ID is given, remove the ones the user has no access to
+		if ($userId) {
+			$idArray = array_intersect($idArray, WfsConf::getWfsConfByPermission($userId));
-		$sql .= ")";
-		$res = db_prep_query($sql, $v, $t);
-		$checkedIdArray = array();
-		while ($row = db_fetch_array($res)) {
-			$id = $row["wfs_conf_id"];
-			$sql_conf_element = "SELECT * FROM wfs_conf_element ";
-			$sql_conf_element .= "JOIN wfs_element ON wfs_conf_element.f_id = wfs_element.element_id ";
-			$sql_conf_element .= "WHERE wfs_conf_element.fkey_wfs_conf_id = $1 ";
-			$sql_conf_element .= "AND wfs_conf_element.f_search = 1 ORDER BY wfs_conf_element.f_pos";
-			$v_conf_element = array($id);
-			$t_conf_element = array('i');
-			$res_conf_element = db_prep_query($sql_conf_element, $v_conf_element, $t_conf_element);
-			$elementArray = array();
-			while ($row_conf_element = db_fetch_array($res_conf_element)) {
-				$currentElement = array("f_search" => $row_conf_element["f_search"],
-										"f_style_id" => $row_conf_element["f_style_id"],
-										"f_toupper" => $row_conf_element["f_toupper"],
-										"f_label" => $row_conf_element["f_label"],
-										"f_label_id" => $row_conf_element["f_label_id"],
-										"element_name" => $row_conf_element["element_name"],
-										"element_type" => $row_conf_element["element_type"]
-				array_push($elementArray, $currentElement);
+		if (count($idArray) > 0) {
+			 * Get WFS configurations
+			$sql = "SELECT * FROM wfs_conf ";
+			$sql .= "JOIN wfs ON wfs_conf.fkey_wfs_id = wfs.wfs_id ";
+			$sql .= "WHERE wfs_conf.wfs_conf_id IN (";
+			$v = array();
+			$t = array();
+			for ($i = 0; $i < count($idArray); $i++) {
+				if ($i > 0) {$sql .= ", ";}
+				$sql .= "$" . ($i+1);
+				array_push($v, $idArray[$i]);
+				array_push($t, 'i');
+			$sql .= ")";
-			$sql_feature_type = "SELECT * FROM wfs_featuretype WHERE fkey_wfs_id = $1 AND featuretype_id = $2";
-			$v_feature_type = array($row["fkey_wfs_id"], $row["fkey_featuretype_id"]);
-			$t_feature_type = array("i", "i");
-			$res_feature_type = db_prep_query($sql_feature_type, $v_feature_type, $t_feature_type);
-			if($row_feature_type = db_fetch_array($res_feature_type)){
-				$featuretype_name  = $row_feature_type["featuretype_name"];
-				$featuretype_srs  = $row_feature_type["featuretype_srs"];
+			$res = db_prep_query($sql, $v, $t);
+			while ($row = db_fetch_array($res)) {
+				 * Get WFS conf elements
+				$id = $row["wfs_conf_id"];
+				$sql_conf_element = "SELECT * FROM wfs_conf_element ";
+				$sql_conf_element .= "JOIN wfs_element ON wfs_conf_element.f_id = wfs_element.element_id ";
+				$sql_conf_element .= "WHERE wfs_conf_element.fkey_wfs_conf_id = $1 ";
+#filtered on client side
+#				$sql_conf_element .= "AND wfs_conf_element.f_search = 1 ";
+				$sql_conf_element .= "ORDER BY wfs_conf_element.f_pos";
+				$v_conf_element = array($id);
+				$t_conf_element = array('i');
+				$res_conf_element = db_prep_query($sql_conf_element, $v_conf_element, $t_conf_element);
+				$elementArray = array();
+				while ($row_conf_element = db_fetch_array($res_conf_element)) {
+					$currentElement = array("f_search" => $row_conf_element["f_search"],
+											"f_style_id" => $row_conf_element["f_style_id"],
+											"f_toupper" => $row_conf_element["f_toupper"],
+											"f_label" => $row_conf_element["f_label"],
+											"f_label_id" => $row_conf_element["f_label_id"],
+											"f_geom" => $row_conf_element["f_geom"],
+											"element_name" => $row_conf_element["element_name"],
+											"element_type" => $row_conf_element["element_type"]
+					array_push($elementArray, $currentElement);
+				 * Get WFS featuretype
+				$sql_feature_type = "SELECT * FROM wfs_featuretype WHERE fkey_wfs_id = $1 AND featuretype_id = $2";
+				$v_feature_type = array($row["fkey_wfs_id"], $row["fkey_featuretype_id"]);
+				$t_feature_type = array("i", "i");
+				$res_feature_type = db_prep_query($sql_feature_type, $v_feature_type, $t_feature_type);
+				if($row_feature_type = db_fetch_array($res_feature_type)){
+					$featuretype_name  = $row_feature_type["featuretype_name"];
+					$featuretype_srs  = $row_feature_type["featuretype_srs"];
+				$currentRow = array("g_label" => $row["g_label"],
+			                        "g_label_id" => $row["g_label_id"],
+									"g_style" => $row["g_style"],
+									"g_button" => $row["g_button"],
+									"g_button_id" => $row["g_button_id"],
+									"g_buffer" => $row["g_buffer"],
+									"g_res_style" => $row["g_res_style"],
+									"g_use_wzgraphics" => $row["g_use_wzgraphics"],
+									"wfs_id" => $row["fkey_wfs_id"],
+									"featuretype_id" => $row["fkey_featuretype_id"],
+									"featuretype_name" => $featuretype_name,
+									"featuretype_id" => $featuretype_srs,
+									"wfs_getfeature" => $row["wfs_getfeature"],
+									"element" => $elementArray
+				$this->confArray[$id] = $currentRow;
-			$currentRow = array("g_label" => $row["g_label"],
-		                        "g_label_id" => $row["g_label_id"],
-								"g_style" => $row["g_style"],
-								"g_button" => $row["g_button"],
-								"g_button_id" => $row["g_button_id"],
-								"g_buffer" => $row["g_buffer"],
-								"g_res_style" => $row["g_res_style"],
-								"g_use_wzgraphics" => $row["g_use_wzgraphics"],
-								"wfs_id" => $row["fkey_wfs_id"],
-								"featuretype_id" => $row["fkey_featuretype_id"],
-								"featuretype_name" => $featuretype_name,
-								"featuretype_id" => $featuretype_srs,
-								"wfs_getfeature" => $row["wfs_getfeature"],
-								"element" => $elementArray
-			$this->confArray[$id] = $currentRow;
+		else {
+			$e = new mb_warning("class_wfs_conf.php: getWfsConfFromDB: You don't have access to any WFS confs. Check EDIT WFS.");
 	/** identifies the Conf-FeatureServices where the current user is owner
@@ -148,8 +174,8 @@
 	public static function getWfsConfByPermission($userid){
 	 	$guisByPer = array();
 //	 	1.
-	 	$guisByPer = $this->getGuisByPermission($userid, true);
+		$adm = new administration();
+	 	$guisByPer = $adm->getGuisByPermission($userid, true);
 //	 	2.
 		if(count($guisByPer)>0){
 			$v = array();
@@ -194,39 +220,7 @@
 	var $elements;
 	var $namespaces;
-	function getallwfs($userid){
-		$this->wfs_id = array();
-		$this->wfs_name = array();
-		$this->wfs_title = array();
-		$this->wfs_abstract = array();
-		global $DBSERVER,$DB,$OWNER,$PW;
-		$con = db_connect($DBSERVER,$OWNER,$PW);
-		db_select_db($DB,$con);
-		if($userid){
-		 	$sql = "SELECT * FROM wfs WHERE wfs_owner = $1";
-			$v = array($userid);
-			$t = array('i');
-			$res = db_prep_query($sql,$v,$t);
-		else{
-		 	$sql = "SELECT * FROM wfs";
-			$res = db_query($sql);
-		$cnt = 0;
-		while ($row = db_fetch_array($res)){
-			$this->wfs_version[$cnt] = $row["wfs_version"];
-			$this->wfs_id[$cnt] = $row["wfs_id"];
-			$this->wfs_name[$cnt] = $row["wfs_name"];
-			$this->wfs_title[$cnt] = $row["wfs_title"];
-			$this->wfs_abstract[$cnt] = $row["wfs_abstract"];
-			$this->wfs_getcapabilities[$cnt] = $row["wfs_getcapabilities"];
-			$this->wfs_describefeaturetype[$cnt] = $row["wfs_describefeaturetype"];
-			$this->wfs_getfeature[$cnt] = $row["wfs_getfeature"];
-			$cnt++;
 	function getfeatures($wfsid){
 		$this->features = new features($wfsid);
More information about the Mapbender_commits mailing list
