[Mapbender-commits] r1808 - branches/mapbender_sld/http/sld
svn_mapbender at osgeo.org
Thu Nov 15 10:52:00 EST 2007
Author: mschulz
Date: 2007-11-15 10:52:00 -0500 (Thu, 15 Nov 2007)
New Revision: 1808
branches/mapbender_sld/http/sld/sld_edit_filter.php
branches/mapbender_sld/http/sld/sld_filter_parse.php
branches/mapbender_sld/http/sld/sld_parse.php
Added copyright and license
Modified: branches/mapbender_sld/http/sld/sld_edit_filter.php
--- branches/mapbender_sld/http/sld/sld_edit_filter.php 2007-11-15 15:51:05 UTC (rev 1807)
+++ branches/mapbender_sld/http/sld/sld_edit_filter.php 2007-11-15 15:52:00 UTC (rev 1808)
@@ -1,4 +1,22 @@
<?php
+# $Id$
+# http://www.mapbender.org/index.php/SLD/
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
* This file contains the source of the filter-expression-editor-module.
* This was separated from the sld-editor's parsing and functionhandling
Property changes on: branches/mapbender_sld/http/sld/sld_edit_filter.php
___________________________________________________________________
+ Id
Modified: branches/mapbender_sld/http/sld/sld_filter_parse.php
--- branches/mapbender_sld/http/sld/sld_filter_parse.php 2007-11-15 15:51:05 UTC (rev 1807)
+++ branches/mapbender_sld/http/sld/sld_filter_parse.php 2007-11-15 15:52:00 UTC (rev 1808)
@@ -1,4 +1,22 @@
<?php
+# $Id$
* This file parses the filter expressions and creates the corresponding objects.
Property changes on: branches/mapbender_sld/http/sld/sld_filter_parse.php
+ Id
Modified: branches/mapbender_sld/http/sld/sld_parse.php
--- branches/mapbender_sld/http/sld/sld_parse.php 2007-11-15 15:51:05 UTC (rev 1807)
+++ branches/mapbender_sld/http/sld/sld_parse.php 2007-11-15 15:52:00 UTC (rev 1808)
@@ -1,4 +1,22 @@
<?php
+# $Id$
+# http://www.mapbender.org/index.php/SLD/sld_config.php
* Parses the sld-documents and creates the object structure.
* This file does the parsing of the sld-data.
@@ -15,13 +33,32 @@
* @author Markus Krzyzanowski
session_start();
+ * Creates a empty SLD object up to the rule object
+ * @return StyledLayerDescriptor
+function createEmptySLD() {
+ $styledlayerdescriptor = new StyledLayerDescriptor();
+ $layer = new NamedLayer();
+ $style = new UserStyle();
+ $fts = new FeatureTypeStyle();
+ $rule = new Rule();
+ $fts->rules[] = $rule;
+ $style->featuretypestyles[] = $fts;
+ $layer->styles[] = $style;
+ $layer->name = $_SESSION["sld_layer_name"];
+ $styledlayerdescriptor->layers[] = $layer;
+ $styledlayerdescriptor->version = "1.0.0";
+ $styledlayerdescriptor->id = 0;
+ $styledlayerdescriptor->parent = false;
+ return $styledlayerdescriptor;
* Opens the file at the specified URL and returns the content.
@@ -58,7 +95,6 @@
xml_parse_into_struct($xml_parser, $data, $vals, $index);
xml_parser_free($xml_parser);
$parent = array();
$objects = array();
@@ -77,9 +113,12 @@
$parent[] = false;
$parentactual = 0;
//Experimental:
+ $styledlayerdescriptor = createEmptySLD();
//END Experimental
@@ -715,14 +754,41 @@
$objects[$parentactual]->colormapentries[count($objects[$parentactual]->colormapentries)-1]->label = $element["attributes"]["label"];
break;
- //TODO: Kl�ren mit sld:parameterValueType
- //bei den folgenden XML Elementen
case "LABEL":
if ($element["type"] == "complete")
//Kl�ren, ob Label nur so vorkommen kann - TODO
- $objects[$parentactual]->label = $element["value"];
+ //$objects[$parentactual]->label = $element["value"];
+ //use the new ParameterValue class to store the mixed content value
+ //simple case no extra markup ...
+ //the label is instanciated by TextSymbolizer
+ $parent[] = $parentactual;
+ $objects[count($parent)-1] = new ParameterValue();
+ //Experimental:
+ $objects[count($parent)-1]->id = count($parent)-1;
+ $objects[count($parent)-1]->parent = $parentactual;
+ $objects[count($parent)-1]->value = $element["value"];
+ //END Experimental
+ $objects[$parentactual]->label = &$objects[count($parent)-1];
+ $parentactual = count($parent)-1;
+ $parentactual = $parent[$parentactual];
+ elseif ($element["type"] == "open")
+ //Experimental:
+ elseif ($element["type"] == "close")
break;
case "RADIUS":
@@ -776,6 +842,20 @@
$objects[$parentactual]->displacementy = $element["value"];
break;
+ //TODO: Kl�ren mit sld:parameterValueType
+ //bei den folgenden XML Elementen
+ case "PROPERTYNAME":
+ if ($element["type"] == "complete")
+ if ($temp == "") {
+ $objects[$parentactual]->value = $element["value"];
+ else {
+ die($temp);
+ break;
//END TODO
//von den vorhergegangenen XML Elementen
@@ -809,6 +889,7 @@
if (strtoupper(get_class($objects[$parentactual])) == "RULE")
$objects[$parentactual]->filter .= $temp;
+ $temp = "";
Property changes on: branches/mapbender_sld/http/sld/sld_parse.php
+ Id
More information about the Mapbender_commits
