[Mapbender-commits] r1816 - branches/mapbender_sld/http/sld/classes
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Nov 15 11:11:08 EST 2007
Author: mschulz
Date: 2007-11-15 11:11:08 -0500 (Thu, 15 Nov 2007)
New Revision: 1816
Added:
   branches/mapbender_sld/http/sld/classes/ParameterValue.php
Initial checkin, new ParameterValueType
Added: branches/mapbender_sld/http/sld/classes/ParameterValue.php
--- branches/mapbender_sld/http/sld/classes/ParameterValue.php	                        (rev 0)
+++ branches/mapbender_sld/http/sld/classes/ParameterValue.php	2007-11-15 16:11:08 UTC (rev 1816)
@@ -0,0 +1,57 @@
+<?php
+ * Implementation of the ParameterValueType type of elements
+ * @package sld_classes
+ * @author Michael Schulz
+class ParameterValue
+	 * The value attribute from the xml-scheme.
+	 * @var string
+	var $value = "";
+	 * Index identifying the object in the $_SESSION("sld_objects") array.
+	 * @var int
+	var $id = "";
+	 * Index identifying the object's parent object in the $_SESSION("sld_objects") array.
+	 * @var int
+	var $parent = "";
+	 * creates the xml for this object and its child objects
+	 * @param string $offset string used for formatting the output
+	 * @return string containing the xml-fragment
+	function generateXml()
+		$temp = "<PropertyName>".$this->value."</PropertyName>";
+		return $temp;
+	 * creates the html-form-fragment for this object
+	 * @param $id string containing a prefix that should be used to identify this
+	 * object's html fields. This must be done, so that the generateObjectFromPost(...)
+	 * function can address the fields belonging to this object in the http-post.
+	 * @return string containing the html-form-fragment
+	function generateHtmlForm($id, $offset = "")
+		$temp = $this->value;
+		return $temp;
\ No newline at end of file
More information about the Mapbender_commits mailing list
