[Mapbender-commits] r1820 - branches/mapbender_sld/http/sld/classes
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Nov 15 11:15:33 EST 2007
Author: mschulz
Date: 2007-11-15 11:15:33 -0500 (Thu, 15 Nov 2007)
New Revision: 1820
   branches/mapbender_sld/http/sld/classes/TextSymbolizer.php
Label uses new parameterValueType and featureTypes attributes
Modified: branches/mapbender_sld/http/sld/classes/TextSymbolizer.php
--- branches/mapbender_sld/http/sld/classes/TextSymbolizer.php	2007-11-15 16:13:49 UTC (rev 1819)
+++ branches/mapbender_sld/http/sld/classes/TextSymbolizer.php	2007-11-15 16:15:33 UTC (rev 1820)
@@ -10,8 +10,10 @@
 	 * The Label element from the xml-scheme.
 	 * This element is not implemented as an object.
+	 * Although it is an object, we'll use a workaround ...
+	 * <Label>Townname: <ogc:PropertyValue>NAME</ogc:PropertyValue></Label> should be possible
-	 * @var string
+	 * @var object
 	var $label = "";
@@ -32,7 +34,8 @@
 	var $labelplacement = "";
 	//Halo is not supported by Mapserver
-	//var $halo = "";
+	var $halo = "";
 	//Fill is not supported by Mapserver - only solid color
 	var $fill = "";
@@ -50,7 +53,7 @@
 	function TextSymbolizer()
-		//$this->font = new Font();
+		//$this->label = new ParameterValue();
 		//$this->labelplacement = new LabelPlacement();
 		//$this->fill = new Fill();
@@ -64,10 +67,11 @@
 	function generateXml($offset = "")
 		$temp = $offset."<TextSymbolizer>\n";
-		if ($this->label != "") $temp .= $offset." <Label>".htmlspecialchars($this->label)."</Label>\n";
+		#if ($this->label != "") $temp .= $offset." <Label>".htmlspecialchars($this->label)."</Label>\n";
+		if ($this->label != "") $temp .= $offset." <Label>".$this->label->generateXml()."</Label>\n";
 		if ($this->font != "") $temp .= $this->font->generateXml($offset." ");
 		if ($this->labelplacement != "") $temp .= $this->labelplacement->generateXml($offset." ");
-		//if ($this->halo != "") $temp .= $this->halo->generateXml($offset." ");
+		if ($this->halo != "") $temp .= $this->halo->generateXml($offset." ");
 		if ($this->fill != "") $temp .= $this->fill->generateXml($offset." ");
 		$temp .= $offset."</TextSymbolizer>\n";
 		return $temp;
@@ -86,7 +90,8 @@
 	function generateHtmlForm($id, $offset= "")
 		$temp = "";
-		$temp .= $offset."<table bgcolor=\"#FFFFFF\" border='1' cellspacing='2' cellpadding='0' style=\"border: 1px solid black; width:100%;\">\n";
+		$label_value = "";
+		$temp .= $offset."<table bgcolor=\"#FFFFFF\" cellspacing='2' cellpadding='0' style=\"border: 1px solid black; width:100%;\">\n";
 		$temp .= $offset." <tr valign=\"top\">\n";
 		$temp .= $offset."   <td class='text' style=\"width: 130px;\">\n";
 		$temp .= $offset."    TextSymbolizer<br>\n";
@@ -106,7 +111,14 @@
 		$temp .= $offset."      Label:\n";
 		$temp .= $offset."     </td>\n";
 		$temp .= $offset."     <td>\n";
-		$temp .= $offset."      <input name=\"".$id."_label\" value=\"".$this->label."\">\n";
+		$temp .= $offset."      <input name=\"".$id."_label\" id=\"".$id."_label\" value=\"";
+			$label_value = $this->label->generateHtmlForm($id."_label","");
+			$temp .= $label_value;
+		$temp .= "\">\n";
+		//experimental
+		$temp_elements = $_SESSION["sld_objects"][3]->generateElementsHtml($id."_label",$label_value);
+		$temp .= $offset.$temp_elements;
 		$temp .= $offset."    </tr>\n";
 		$temp .= $offset."   </table>\n";
@@ -128,6 +140,15 @@
 			$temp .= $offset."<a class='edit' href=\"sld_function_handler.php?function=addlabelplacement&id=".$this->id."\">Labelplacement hinzuf&uuml;gen</a><br>\n";
 		//Halo is not supported - removed from source
+			$temp .= $this->halo->generateHtmlForm($id."_halo", $offset."   ");
+		else
+			$temp .= $offset."   <a class='edit' href=\"sld_function_handler.php?function=addhalo&id=".$this->id."\">Halo hinzuf&uuml;gen</a><br>\n";
 			$temp .= $this->fill->generateHtmlForm($id."_fill", $offset."   ");
@@ -157,7 +178,8 @@
 		if (isset($_REQUEST[$id."_label"]))
-			$this->label = $_REQUEST[$id."_label"];
+			$this->label = new ParameterValue();
+			$this->label->value = $_REQUEST[$id."_label"];
 		if (isset($_REQUEST[$id."_font"]))
@@ -169,11 +191,11 @@
 			$this->labelplacement->generateObjectFromPost($id."_labelplacement");
-//		if (isset($_REQUEST[$id."_halo"]))
-//			$this->halo = new Halo();
-//			$this->halo->generateObjectFromPost($id."_halo");
+		if (isset($_REQUEST[$id."_halo"]))
+			$this->halo = new Halo();
+			$this->halo->generateObjectFromPost($id."_halo");
 		if (isset($_REQUEST[$id."_fill"]))
@@ -181,4 +203,4 @@
\ No newline at end of file
More information about the Mapbender_commits mailing list
