[Mapbender-commits] r1827 - in trunk/mapbender/http: classes tools
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri Nov 23 06:31:16 EST 2007
Author: christoph
Date: 2007-11-23 06:31:03 -0500 (Fri, 23 Nov 2007)
New Revision: 1827
   trunk/mapbender/http/classes/class_mb_exception.php
   trunk/mapbender/http/tools/mapbender_setup.php
check if error logging works by logging a test message
Modified: trunk/mapbender/http/classes/class_mb_exception.php
--- trunk/mapbender/http/classes/class_mb_exception.php	2007-11-23 10:40:54 UTC (rev 1826)
+++ trunk/mapbender/http/classes/class_mb_exception.php	2007-11-23 11:31:03 UTC (rev 1827)
@@ -29,6 +29,8 @@
 	var $mb_log_level = LOG_LEVEL;
 	var $dir = "../../log/";
 	var $filename_prefix = "mb_error_";
+	var $result = false;
+	var $message = "";
 	function indexOf($level, $levelArray) {
 		$index = false;
@@ -57,12 +59,32 @@
 				if($h = fopen($logfile,"a")){
 					$content = date("Y.m.d, H:i:s") . "," . $n .chr(13).chr(10);
 					if(!fwrite($h,$content)){
-						#exit;
+						$this->result = false;
+						$this->message = "Unable to write " . $logfile;
+						return false;
 					fclose($h);
+					$this->result = true;
+					$this->message = "Successful.";
+					return true;
+				else {
+					$this->message = "Unable to open or generate " . $logfile;
+					return false;
+			else {
+				$this->message = "Directory " . $this->dir . " is not valid.";
+				return false;
+		else {
+			$this->message = "Log level '" . $level . "' is not valid or logging is disabled in mapbender.conf.";
+			return false;
@@ -70,7 +92,7 @@
 	var $level = "notice";
 	function mb_notice($message) {
-		$this->mb_log("Notice: " . $message, $this->level);
+		return $this->mb_log("Notice: " . $message, $this->level);
@@ -78,7 +100,7 @@
 	var $level = "warning";
 	function mb_warning($message) {
-		$this->mb_log("Warning: " . $message, $this->level);
+		return $this->mb_log("Warning: " . $message, $this->level);
@@ -86,7 +108,7 @@
 	var $level = "error";
 	function mb_exception($message) {
-		$this->mb_log("ERROR: " . $message, $this->level);
+		return $this->mb_log("ERROR: " . $message, $this->level);
\ No newline at end of file
Modified: trunk/mapbender/http/tools/mapbender_setup.php
--- trunk/mapbender/http/tools/mapbender_setup.php	2007-11-23 10:40:54 UTC (rev 1826)
+++ trunk/mapbender/http/tools/mapbender_setup.php	2007-11-23 11:31:03 UTC (rev 1827)
@@ -21,7 +21,8 @@
  # along with this program; if not, write to the Free Software
  # Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
- include_once(dirname(__FILE__)."/../../conf/mapbender.conf");
+include_once(dirname(__FILE__)."/../../conf/mapbender.conf");
+include_once(dirname(__FILE__)."/../classes/class_mb_exception.php");
  <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN"
@@ -251,6 +252,14 @@
 		else $check .="<tr><td>AUTO_UPDATE</td><td></td><td><font color=#FF0000>set to " . AUTO_UPDATE . ": this configuration value is not supported(as yet!)</td></tr>";
 	else $check .="<tr><td>AUTO_UPDATE</td><td></td><td><font color=#FF0000>AUTO_UPDATE not defined </font><font color=#0000FF>(for the wms monitoring 	functionality you have to define this constant)</font></td></tr>";
+# ERROR LOGGING
+	$testLog = new mb_notice("This is a test run by the Mapbender setup script.");
+	if ($testLog->result) {
+		$check .="<tr><td>ERROR LOGGING</td><td>X</td><td><font color=#00D000>" . $testLog->message . "</font></td></tr>";
+	else {
+		$check .="<tr><td>ERROR LOGGING</td><td></td><td><font color=#FF0000>" . $testLog->message . "</font></td></tr>";
 #LOG_LEVEL (off,error,warning,all)
 	if (LOG_LEVEL !="" && defined('LOG_LEVEL')){
 		if (LOG_LEVEL =='off') $check .="<tr><td>LOG_LEVEL</td><td>X</td><td>switched off: <font color=#FF0000>-no Mapbender-errors logging</font><td></tr>";
More information about the Mapbender_commits mailing list
