[Mapbender-commits] r1831 - branches/mapbender_sld/http/classes
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri Nov 23 08:22:46 EST 2007
Author: christoph
Date: 2007-11-23 08:22:46 -0500 (Fri, 23 Nov 2007)
New Revision: 1831
Added:
   branches/mapbender_sld/http/classes/class_bbox.php
   branches/mapbender_sld/http/classes/class_keyword.php
   branches/mapbender_sld/http/classes/class_layer_monitor.php
   branches/mapbender_sld/http/classes/class_locale.php
   branches/mapbender_sld/http/classes/class_metadata.php
   branches/mapbender_sld/http/classes/class_monitor.php
   branches/mapbender_sld/http/classes/class_administration.php
   branches/mapbender_sld/http/classes/class_checkInput.php
   branches/mapbender_sld/http/classes/class_gml2.php
   branches/mapbender_sld/http/classes/class_gui.php
   branches/mapbender_sld/http/classes/class_kml.php
   branches/mapbender_sld/http/classes/class_mb_exception.php
   branches/mapbender_sld/http/classes/class_stripRequest.php
   branches/mapbender_sld/http/classes/class_weldLegend2PNG.php
   branches/mapbender_sld/http/classes/class_weldOverview2PNG.php
   branches/mapbender_sld/http/classes/class_wfs.php
   branches/mapbender_sld/http/classes/class_wfs_conf.php
   branches/mapbender_sld/http/classes/class_wmc.php
new and updated classes
Modified: branches/mapbender_sld/http/classes/class_administration.php
--- branches/mapbender_sld/http/classes/class_administration.php	2007-11-23 13:20:10 UTC (rev 1830)
+++ branches/mapbender_sld/http/classes/class_administration.php	2007-11-23 13:22:46 UTC (rev 1831)
@@ -17,6 +17,7 @@
 # Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
 require_once(dirname(__FILE__)."/../../conf/mapbender.conf");
+require_once(dirname(__FILE__)."/class_mb_exception.php");
 $con = db_connect(DBSERVER,OWNER,PW);
 db_select_db(DB,$con);
@@ -38,7 +39,7 @@
      * @return <boolean> answer to "is the passed over email valid?""
 	function isValidEmail($email) {
-        if(eregi("^[_a-z0-9-]+(\.[_a-z0-9-]+)*@[a-z0-9-]+(\.[a-z0-9-]+)*(\.[a-z]{2,3})$", $email)) {
+        if(mb_eregi("^[_a-z0-9-]+(\.[_a-z0-9-]+)*@[a-z0-9-]+(\.[a-z0-9-]+)*(\.[a-z]{2,3})$", $email)) {
             return true;
 		return false;
@@ -122,7 +123,7 @@
 		for ($i=0;$i <= $max;$i++) {
 			//die ASCII-Zeichen 48 - 57 sind die zahlen 0-9
-			//die ASCII-Zeichen 65 - 90 sind die buchstaben A-Z (Groß)
+			//die ASCII-Zeichen 65 - 90 sind die buchstaben A-Z (Gro�)
 			//die ASCII-Zeichen 97 - 122 sind die buchstaben a-z (Klein)
 			$ascii = 0;
 			do {
@@ -132,10 +133,10 @@
 		return $newpass;
      * returns the name of a mapbender user which owns the GUI identified by the passed over gui_id.
      * @param <string> the gui_id
      * @return <string> the name of the owner
@@ -167,10 +168,10 @@
 		return $owner;
      * returns the content of the field mb_user_email for the given userid.
      * @param <integer> the userid
      * @return <mixed> the email if one row is found or false if none is foundd
@@ -181,7 +182,7 @@
 		$v = array($userid);
 		$t = array('i');
 		$res = db_prep_query($sql,$v,$t);
-		// TODO shall the next two lines be removed?
+		// TODO shall the next two lines be removed?
         $count_g = 0;
 		$array = array();
 		$row = db_fetch_array($res);
@@ -192,10 +193,10 @@
 			return false;
      * returns the name of the user for the given userid.
      * @return  the name if one row is found or false if none is foundd
@@ -221,7 +222,7 @@
      * returns one or more userids from the given email or false,
      * if there is no record in the database matching the given email
      * @param <string> the email
      * @return <mixed> returns an array of userids or false when no records matches
@@ -249,9 +250,9 @@
      * returns one or more owners for the given wm_id. First all guis deploying
      * this wms are selected. Afterwards for each of the guis the owners are
      * selected and stored within an array.
      * @param <integer> the wms_id
-     * @return <mixed> an array of usernames which use thw wms in their guis (both for persona or group ownership)
+     * @return <mixed> an array of usernames which use thw wms in their guis (both for persona or group ownership)
 	function getOwnerByWms($wms_id){
 		// first get guis which deploy this wms.
@@ -318,7 +319,7 @@
      * tests whether a gui with the passed gui_id exits and returns true or false.
      * @param <string> the gui_id to test
      * @return <boolean> Does a Gui with the passed over gui_id exist?
@@ -335,10 +336,10 @@
 			return false;
      * deletes a WMC entry specified by wmc_id and user_id
      * @param <integer> the user_id
      * @param <string> the wmc_id
      * @return <boolean> Did the query run succesfull? This does not necessarily mean that an entry was deleted.
@@ -356,10 +357,10 @@
 			return false;
      * inserts a gui with the specified gui_id, after checking the uniqueness of teh gui id.
      * @uses guiExists
      * @param <string> the name and id of the gui to insert.
      * @return <boolean> could the gui be inserted?
@@ -376,10 +377,10 @@
 		return false;
      * deletes links between user and guis in gui_mb_user for a certain gui.
      * @param <string> the gui name
      * @return <boolean> could the sql be executed without errors. This does not necessarily mean, that entries were deleted
@@ -395,16 +396,23 @@
 			return true;
+     * returns an array of WMS for a given user id
      * @uses getGuisByOwner
+     * @param <integer> the user id
+     * @return <array> wms ids for the user
 	function getWmsByOwner($user_id){
 		$gui_list = $this->getGuisByOwner($user_id,true);
 		return $this->getWmsByOwnGuis($gui_list);
+     * returns an array of WMS where the owner is the user with the passed user_id
 	function getWmsByWmsOwner($user_id){
 		$sql = "SELECT wms_id FROM wms WHERE wms_owner = $1";
 		$v = array($user_id);
@@ -417,6 +425,12 @@
 		return $r;
+     * returns an array of user which are associated with a wms
+     * @param <integer> the wms id
+     * @return <array> user_ids for the wms
 	function getUserByWms($wms_id){
 		$sql = "SELECT fkey_gui_id FROM gui_wms WHERE fkey_wms_id = $1 GROUP BY fkey_gui_id";
 		$v = array($wms_id);
@@ -464,8 +478,14 @@
 		return $user;
+     * selects the WMS-title for a given wms id.
+     * @return <string|boolean> either the title of the wms as string or false when none exists
 	function getWmsTitleByWmsId($id){
-		$sql = "SELECT wms_title from wms WHERE wms_id = $1 GROUP BY wms_title";
+		$sql = "SELECT wms_title FROM wms WHERE wms_id = $1 GROUP BY wms_title";
 		$v = array($id);
 		$t = array('i');
@@ -473,8 +493,14 @@
 		if ($row) return $row["wms_title"]; else return false;
+     * selects the Layer-title for a given layer id.
 	function getLayerTitleByLayerId($id){
-		$sql = "SELECT layer_title from layer WHERE layer_id = $1 GROUP BY layer_title";
+		$sql = "SELECT layer_title FROM layer WHERE layer_id = $1 GROUP BY layer_title";
 		$v = array($id);
 		$t = array('i');
@@ -482,6 +508,12 @@
 		if ($row) return $row["layer_title"]; else return false;
+     * selects the WMC for a given wmc_id.
+     * @return <string|boolean> either the wmc as string or false when none exists
 	function getWmcById($id){
 		$sql = "SELECT wmc FROM mb_user_wmc WHERE wmc_id = $1 ";
 		$v = array($id);
@@ -496,13 +528,18 @@
+     * resets the login count of a given user to 0
+     * @return <boolean> could the login count be reseted?
 	function resetLoginCount($userId) {
-		$sql = "UPDATE mb_user SET mb_user_login_count = '0' ";
+		// TODO: isn't mb_user_login_count a integer?
+        $sql = "UPDATE mb_user SET mb_user_login_count = '0' ";
 		$sql .= "WHERE mb_user_id = $1 ";
 		$v = array($userId);
 		$t = array('i');
 		if (!$res) {
 			return false;
@@ -511,6 +548,12 @@
+     * returns the user id for a given username
+     * @param <string> the username of which the id shall be returned
+     * @return <string|boolean> the userid or false if the operation fails
 	function getUserIdByUserName($username){
 		$sql = "SELECT mb_user_id FROM mb_user ";
 		$sql .= "WHERE mb_user_name = $1 GROUP BY mb_user_id";
@@ -518,9 +561,21 @@
 		$t = array('s');
-		if ($row) return $row["mb_user_id"]; else return false;
+		if ($row) {
+			return $row["mb_user_id"];
+        else {
+        	return false;
+     * sets the given user_id as owner for the passed gui_id
+     * @param <string> the gui_id to change ownership of
+     * @param <integer> the user_id of the intended new owner
+     * @return <boolean> Could the owner be updated?
 	function setUserAsGuiOwner($guiId, $userId) {
 		$sql = "UPDATE gui_mb_user SET mb_user_type = 'owner' ";
 		$sql .= "WHERE fkey_gui_id = $1 AND fkey_mb_user_id = $2 ";
@@ -536,8 +591,16 @@
+     * gets and returns gui_ids identified by the passed over gui_name
+     * @param <string> name of the gui
+     * @return <array|boolean> an array of gui_ids or false when something went wrong
 	function getGuiIdByGuiName($guiTitle){
-		$sql = "SELECT gui_id FROM gui ";
+		//TODO: check whether the passed variable should be renamed, guiTitle is misleading
+        //TODO: check whether the function should be renamed to "getGuiIdsByGuiName" since it usually returns an array
+        $sql = "SELECT gui_id FROM gui ";
 		$sql .= "WHERE gui_name = $1 GROUP BY gui_id";
 		$v = array($guiTitle);
 		$t = array('s');
@@ -556,15 +619,23 @@
-	function getGuisByOwner($user_id,$ignore_public)
-		$sql_guis = "SELECT gui.gui_id FROM gui,gui_mb_user ";
+     * returns gui_ids owned by the user with the passed user_id
+     * @param <integer> user_id of the owner
+     * @param <boolean> shall only public guis be returned? sort of optional... see todo
+     * @return <array> array of gui_ids owned by the user
+	function getGuisByOwner($user_id,$ignore_public) {
+		//TODO: isn't the name of the second parameter misleading?
+        $sql_guis = "SELECT gui.gui_id FROM gui,gui_mb_user ";
 		$sql_guis .= "WHERE (gui.gui_id = gui_mb_user.fkey_gui_id AND gui_mb_user.fkey_mb_user_id = $1) ";
-		if (!isset($ignore_public) OR $ignore_public == false){
+		//TODO: when using !isset() below should IMO be replaced with a true otional second parameter via a default value
+        if (!isset($ignore_public) OR $ignore_public == false){
 			$sql_guis .= " AND gui.gui_public = 1 ";
 		$sql_guis .= " AND gui_mb_user.mb_user_type = 'owner' GROUP BY gui.gui_id";
-		$sql_guis .= " ORDER by gui.gui_id";
+		$sql_guis .= " ORDER BY gui.gui_id";
 		$t = array('i');
 		$res_guis = db_prep_query($sql_guis,$v,$t);
@@ -574,9 +645,16 @@
 			$arrayGuis[$count_g] = $row["gui_id"];
 			$count_g++;
+        //TODO: check: why do we always return an array, when most other comparable functions would return false? This is IMO at least inconsistent.
 		return $arrayGuis;
+     * returns wmc_ids owned by the user with the passed user_id
+     * @return <array> array of wmc_ids owned by the user
  	function getWmcByOwner($user_id){
 		$sql_wmc = "SELECT wmc_id FROM mb_user_wmc ";
 		$sql_wmc .= "WHERE fkey_user_id = $1 GROUP BY wmc_id";
@@ -589,6 +667,7 @@
 			$arrayWmc[$count_g] = $row["wmc_id"];
 			$count_g++;
 		return $arrayWmc;
@@ -643,7 +722,7 @@
 		if(count($array_gui_ids)>0){
 			$v = array();
 			$t = array();
-			$sql = "SELECT fkey_wms_id from gui_wms WHERE gui_wms.fkey_gui_id IN(";
+			$sql = "SELECT fkey_wms_id FROM gui_wms WHERE gui_wms.fkey_gui_id IN(";
 			for($i=0; $i<count($array_gui_ids); $i++){
 				if($i>0){ $sql .= ",";}
 				$sql .= "$".strval($i+1);
@@ -740,7 +819,7 @@
 				$cnt = 0;
 				while($row = db_fetch_array($res)){
-					if(strpos(stripslashes($row[$column]),$modulePath) !== false){
+					if(mb_strpos(stripslashes($row[$column]),$modulePath) !== false){
 						$perm = true;
 					$cnt++;
@@ -778,10 +857,55 @@
+	 * get the owsproxy-string of the current wfs
+	 * @param integer the wfs-id of the current wfs
+	 * @return mixed the owsproxy-string or false
+   	function getWfsOwsproxyString($wfs_id){
+   		$sql = "SELECT wfs_owsproxy FROM wfs WHERE wfs_id = $1 ";
+   		$v = array($wfs_id);
+   		$t = array("i");
+   		$res = db_prep_query($sql,$v,$t);
+   		if($row = db_fetch_array($res)){
+   			return $row["wfs_owsproxy"];
+   		else{
+   			return false;
+	 * sets or removes the owsproxy string of the current wfs
+	 * @param boolean set (true) or remove (false) the owsproxy-string
+   	function setWfsOwsproxyString($wfs_id, $status){
+   		$sql = "UPDATE wfs SET wfs_owsproxy = $1 WHERE wfs_id = $2 ";
+   		$t = array("s","i");
+   		if($status == true){
+   			$time = md5(microtime(1));
+			$v = array($time,$wfs_id);
+   		else{
+   			$n = new mb_notice("removed owsproxy for wfs:".$wfs_id);
+   			$v = array("",$wfs_id);
+   		$newOwsString = $this->getWfsOwsproxyString($wfs_id);
+   		$n = new mb_notice("Class administration - setOWSString for wfs (".$wfs_id.") to: ". $this->getWfsOwsproxyString($wfs_id));
+   		return $newOwsString;
    	function checkURL($url){
 		$pos_qm = strpos($url,"?");
-		if($pos_qm > 0 && $pos_qm < (strlen($url)-1) && substr($url,(strlen($url)-1)) != "&"){
+		if($pos_qm > 0 && $pos_qm < (mb_strlen($url)-1) && mb_substr($url,(mb_strlen($url)-1)) != "&"){
 			$url = $url."&";
 			return $url;
@@ -802,6 +926,7 @@
 				return true;
+            //TODO: next three lines should be removable...
 			else{
 				return false;
@@ -885,5 +1010,113 @@
 			return false;
+	function is_utf8_string($string) {
+		return preg_match('%(?:
+		[\xC2-\xDF][\x80-\xBF]        # non-overlong 2-byte
+		|\xE0[\xA0-\xBF][\x80-\xBF]               # excluding overlongs
+		|[\xE1-\xEC\xEE\xEF][\x80-\xBF]{2}      # straight 3-byte
+		|\xED[\x80-\x9F][\x80-\xBF]               # excluding surrogates
+		|\xF0[\x90-\xBF][\x80-\xBF]{2}    # planes 1-3
+		|[\xF1-\xF3][\x80-\xBF]{3}                  # planes 4-15
+		|\xF4[\x80-\x8F][\x80-\xBF]{2}    # plane 16
+		)+%xs', $string);
+	function is_utf8_xml($xml) {
+		return preg_match('/<\?xml[^>]+encoding="utf-8"[^>]*\?>/is', $xml);
+	function is_utf8 ($data) {
+		return ($this->is_utf8_xml($data) || $this->is_utf8_string($data));
+	function char_encode($data) {
+		if (CHARSET == "UTF-8") {
+			if (!$this->is_utf8($data)) {
+				$e = new mb_notice("Conversion: ISO-8859-1 to UTF-8");
+				return utf8_encode($data);
+		else {
+			if ($this->is_utf8($data)) {
+				$e = new mb_notice("Conversion: UTF-8 to ISO-8859-1");
+				return utf8_decode($data);
+		$e = new mb_notice("No conversion: is " . CHARSET);
+		return $data;
+	function char_decode($data) {
+		$e = new mb_notice("no conversion: is " . CHARSET);
+		return $data;
+	 * identifies the Featureservices where the current user is owner
+	 * @param integer userid the user-ID of the current user
+	 * @return array an array of the IDs as integers of the featureservices
+	function getWfsByOwner($userid){
+		$sql = "SELECT wfs_id FROM wfs WHERE wfs_owner = $1";
+		$v = array($userid);
+		$t = array('i');
+		$r = array();
+		while($row = db_fetch_array($res)){
+			array_push($r,$row["wfs_id"]);
+		return $r;
+	 /* identifies the Conf-FeatureServices where the current user is owner
+	 * @returen integer[] the IDs of the wfs_conf-table
+	 function getWfsConfByPermission($userid){
+	 	$guisByPer = array();
+//	 	1.
+	 	$guisByPer = $this->getGuisByPermission($userid, true);
+//	 	2.
+		if(count($guisByPer)>0){
+			$v = array();
+			$t = array();
+			$sql = "SELECT wfs_conf.wfs_conf_id  FROM gui_wfs_conf, wfs_conf " .
+					"where wfs_conf.wfs_conf_id = gui_wfs_conf.fkey_wfs_conf_id " .
+					"and gui_wfs_conf.fkey_gui_id IN(";
+			for($i=0; $i<count($guisByPer); $i++){
+				if($i>0){ $sql .= ",";}
+				$sql .= "$".strval($i+1);
+				array_push($v, $guisByPer[$i]);
+				array_push($t, "s");
+			$sql .= ") GROUP BY wfs_conf.wfs_conf_id ORDER BY wfs_conf.wfs_conf_id";
+			$ownWFSconfs = array();
+			$i=0;
+				$ownWFSconfs[$i] = $row['wfs_conf_id'];
+				$i++;
+		return $ownWFSconfs;
\ No newline at end of file
Added: branches/mapbender_sld/http/classes/class_bbox.php
--- branches/mapbender_sld/http/classes/class_bbox.php	                        (rev 0)
+++ branches/mapbender_sld/http/classes/class_bbox.php	2007-11-23 13:22:46 UTC (rev 1831)
@@ -0,0 +1,285 @@
+<?php
+# $Id: class_bbox.php 1740 2007-10-26 10:12:53Z christoph $
+# http://www.mapbender.org/index.php/
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+require_once(dirname(__FILE__)."/../../conf/mapbender.conf");
+require_once(dirname(__FILE__)."/../classes/class_mb_exception.php");
+$con = db_connect(DBSERVER,OWNER,PW);
+db_select_db(DB,$con);
+ * A Mapbender_point is a 2-dimensional point with an EPSG.
+class Mapbender_point {
+	var $x;
+	var $y;
+	var $epsg;
+	 * @constructor
+	function __construct($x, $y, $epsg) {
+		if (!$x || !$y || !$epsg) {
+			$e = new mb_exception("Mapbender_point: constructor: some parameters are not set (set (x: ".$x.", y: ".$y.", epsg:".$epsg.")!");
+		$this->x = $x;
+		$this->y = $y;
+		$this->epsg = $epsg;
+	 * computes a new point with the minimal coordinates of this point and $point
+	static function min ($point1, $point2) {
+		if ($point1->epsg == $point2->epsg) {
+			if ($point1->isWestOf($point2)) {
+				$minx = $point1->x;
+			else {
+				$minx = $point2->x;
+			if ($point1->isSouthOf($point2)) {
+				$miny = $point1->y;
+			else {
+				$miny = $point2->y;
+			return new Mapbender_point($minx, $miny, $point1->epsg);
+		else {
+			$e = new mb_exception("Mapbender_point: cannot process min with different EPSG codes");
+	 * computes a new point with the maximal coordinates of this point and $point
+	static function max ($point1, $point2) {
+				$maxx = $point2->x;
+			else {
+				$maxx = $point1->x;
+				$maxy = $point2->y;
+			else {
+				$maxy = $point1->y;
+			return new Mapbender_point($maxx, $maxy, $point1->epsg);
+		else {
+	function isWestOf($point) {
+		if ($this->x < $point->x) {
+			return true;
+	function isSouthOf($point) {
+		if ($this->y < $point->y) {
+			return true;
+	 * Addition
+	 * @param anotherPoint another Mapbender_point
+	function plus ($anotherPoint) {
+		return new Mapbender_point($this->x + $anotherPoint->x, $this->y + $anotherPoint->y, $this->epsg);
+	 * Subtraction
+	function minus ($anotherPoint) {
+		return $this->plus($anotherPoint->times(-1));
+	 * Scalar multiplication
+	 * @param aFloat a floating point number
+	function times ($aFloat) {
+		return new Mapbender_point($this->x * $aFloat, $this->y * $aFloat, $this->epsg);
+	 * transforms this point to another EPSG
+	function transform($toEpsg) {
+		if(SYS_DBTYPE=='pgsql'){
+			$currentEpsg = preg_replace("/EPSG:/", "", $this->epsg);
+			$targetEpsg = preg_replace("/EPSG:/", "", $toEpsg);
+			$sql = "SELECT X(transform(GeometryFromText('POINT(".$this->x." ".$this->y.")',".$currentEpsg."),".$targetEpsg.")) as x, ";
+			$sql .= "Y(transform(GeometryFromText('POINT(".$this->x." ".$this->y.")',".$currentEpsg."),".$targetEpsg.")) as y";
+			$res = db_query($sql);
+			$point = new Mapbender_point(db_result($res,0,"x"), db_result($res,0,"y"), $toEpsg);
+			$this->x = $point->x;
+			$this->y = $point->y;
+			$this->epsg = $point->epsg;
+		else {
+			$e = new mb_exception("transformCoordinates needs PostgreSQL");
+	function __toString() {
+		return (string) "(" . $this->x . "," . $this->y . "," . $this->epsg . ")";
+ * A bounding box consisting of an lower left and an upper right point, and an EPSG.
+class Mapbender_bbox {
+	var $min;
+	var $max;
+	var $epsg;
+	 * @constructor
+	function __construct($param0, $param1, $param2, $param3, $param4) {
+		// params are point, point, epsg
+		if (is_a($param0, "Mapbender_point") && is_a($param1, "Mapbender_point") && !$param3 && !$param4) {
+			$e = new mb_notice("Mapbender_bbox: constructor: point1, point2, epsg");
+			$min = $param0; // is a Mapbender_point
+			$max = $param1; // is a Mapbender_point
+			$epsg = $param2; // is an EPSG code like "EPSG:4326"
+			if ($min->isWestOf($max) && $min->isSouthOf($max)) {
+				if ($min->epsg == $max->epsg && $min->epsg == $epsg) {
+					$this->min = $min;
+					$this->max = $max;
+				else {
+					$e = new mb_exception("Mapbender_bbox: constructor: EPSG mismatch!");
+			else {
+				$e = new mb_exception("Mapbender_bbox: constructor: min (".$this->min.") is not southwest of max (".$this->max.")!");
+		// params are x1, y1, x2, xy, epsg
+		else {
+			$e = new mb_notice("Mapbender_bbox: constructor: x1, y1, x2, y2, epsg");
+			$min = new Mapbender_point($param0, $param1, $param4);
+			$max = new Mapbender_point($param2, $param3, $param4);
+			$epsg = $param4; // is an EPSG code like "EPSG:4326"
+				else {
+			else {
+	 * Computes a new bounding box, bbox1 UNION bbox2
+	static function union ($bboxArray) {
+		if (count($bboxArray) == 1) {
+			return array_pop($bboxArray);
+		elseif (count($bboxArray) >= 2) {
+			$bbox1 = array_pop($bboxArray);
+			$bbox2 = Mapbender_bbox::union($bboxArray);
+			if (!($bbox1 != null && $bbox1->isValid()) && !($bbox2 != null && $bbox2->isValid())) {
+				$e = new mb_exception("Mapbender_bbox: union: both parameters invalid!");
+				return null;
+			elseif (!($bbox1 != null && $bbox1->isValid()) && ($bbox2 != null && $bbox2->isValid())) {
+				$e = new mb_exception("Mapbender_bbox: union: first parameter invalid!");
+				return $bbox2;
+			elseif (($bbox1 != null && $bbox1->isValid()) && !($bbox2 != null && $bbox2->isValid())) {
+				$e = new mb_exception("Mapbender_bbox: union: second parameter invalid!");
+				return $bbox1;
+			else {
+				if ($bbox1->epsg == $bbox2->epsg) {
+					$e = new mb_notice("Mapbender_bbox: union: bbox1 is: " . $bbox1);
+					$e = new mb_notice("Mapbender_bbox: union: bbox2 is: " . $bbox2);
+					$e = new mb_notice("Mapbender_bbox: union: merging bbox1 and bbox2...");
+					return new Mapbender_bbox(Mapbender_point::min($bbox1->min, $bbox2->min), Mapbender_point::max($bbox1->max, $bbox2->max), $bbox1->epsg);
+				else {
+					$e = new mb_exception("Mapbender_bbox: cannot process union with different EPSG codes");
+		else {
+			$e = new mb_exception("Mapbender_bbox: Invalid parameter (Not an array)!");
+		return null;
+	 * transforms this bbox in another EPSG
+	 * @param toEpsg transform the bbox to this EPSG code, example: "EPSG:4326"
+		if ($this->isValid()) {
+			$this->epsg = $toEpsg;
+			$this->min->transform($toEpsg);
+			$this->max->transform($toEpsg);
+			return true;
+		return false;
+	 * checks if lower left and upper right coordinate are set, as well as EPSG
+	function isValid() {
+		if ($this->min != null && $this->max != null && $this->epsg != null) {
+			return true;
+		$e = new mb_exception("Mapbender_bbox: this is not a valid bbox!");
+		return false;
+		return (string) "[" . $this->min . $this->max . " " . $this->epsg . "]";
Modified: branches/mapbender_sld/http/classes/class_checkInput.php
--- branches/mapbender_sld/http/classes/class_checkInput.php	2007-11-23 13:20:10 UTC (rev 1830)
+++ branches/mapbender_sld/http/classes/class_checkInput.php	2007-11-23 13:22:46 UTC (rev 1831)
@@ -29,7 +29,7 @@
 		if(count($v) != count($t)){
 			$e = new mb_exception("array params and array types have a different count  in ".$_SERVER['SCRIPT_FILENAME'].": Sql: ".$q);
-		if(PREPAREDSTATEMENTS == true){
+		if(PREPAREDSTATEMENTS == true && SYS_DBTYPE == "pgsql"){
 			$this->v = $v;
 		else{
Modified: branches/mapbender_sld/http/classes/class_gml2.php
--- branches/mapbender_sld/http/classes/class_gml2.php	2007-11-23 13:20:10 UTC (rev 1830)
+++ branches/mapbender_sld/http/classes/class_gml2.php	2007-11-23 13:22:46 UTC (rev 1831)
@@ -1,237 +1,234 @@
-<?php
-# $Id$
-# http://www.mapbender.org/index.php/class_gml2.php
-# Copyright (C) 2002 CCGIS
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2, or (at your option)
-# any later version.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
-# GNU General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-require_once("class_mb_exception.php");
-require_once("class_connector.php");
-require_once("../../conf/mapbender.conf");
-class gml2{
-	var $geomtype_point = 'Point';
-	var $geomtype_polygon = 'Polygon';
-	var $geomtype_line = 'LineString';
-	var $geomtype_multipolygon = 'MultiPolygon';
-	var $geomtype_multiline = 'MultiLine';
-	var $geometries = array();
-	var $member = -1;
-	var $geomtype = array();
-	var $keys = array();
-	var $values = array();
-	var $geometry = array();
-	var $bbox = array();
-	function gml2(){
-		$this->geometries = array($this->geomtype_point, $this->geomtype_polygon, $this->geomtype_line, $this->geomtype_multipolygon, $this->geomtype_multiline);
-	function getGml($req){
-		$x = new connector($req);
-		return $x->file;
-	function parsegml($req){
-		#$data = implode("",file($req));
-		$data = $this->char_encode($x->file);
-		$this->parse_xml($data);
-	function parsestring($data){
-	function parse_xml($data){
-		$section = false;
-		$geom = false;
-		$boundedBy = false;
-		$coordinates = false;
-		$el = -1;
-		$parser = xml_parser_create(CHARSET);
-		xml_parser_set_option($parser,XML_OPTION_CASE_FOLDING,0);
-		xml_parser_set_option($parser,XML_OPTION_SKIP_WHITE,1);
-		xml_parser_set_option($parser,XML_OPTION_TARGET_ENCODING,CHARSET);
-		xml_parse_into_struct($parser,$data,$values,$tags);
-		$code = xml_get_error_code ($parser);
-		if ($code) {
-			$line = xml_get_current_line_number($parser);
-			$mb_exception = new mb_exception(xml_error_string($code) .  " in line " . $line);
-		xml_parser_free($parser);
-		foreach ($values as $element) {
-			if(strtoupper($this->sepNameSpace($element[tag])) == strtoupper("boundedBy") && $element[type] == "open"){
-				$boundedBy = true;
-			if ($boundedBy) {
-				if(strtoupper($this->sepNameSpace($element[tag])) == strtoupper("coordinates")){
-					$this->bbox = explode(",", str_replace(",,","",str_replace(" ",",",trim($element[value]))));
-					$boundedBy=false;
-			if(strtoupper($this->sepNameSpace($element[tag])) == strtoupper("featureMember") && $element[type] == "open"){
-				$this->member++;
-				$this->keys[$this->member] = array();
-				$this->value[$this->member] = array();
-				$this->geometry[$this->member] = array();
-				$section = true;
-				$cnt_geom = 0;
-			if($section == true){
-				if( in_array($this->sepNameSpace($element[tag]),$this->geometries) && $element[type] == "open"){
-					$geom = true;
-					$this->geomtype[$this->member] = $this->sepNameSpace($element[tag]);
-				else if(in_array($this->sepNameSpace($element[tag]),$this->geometries) && $element[type] == "close"){
-					$cnt_geom++;
-					$geom = false;
-				if($geom == true){
-					if (strtoupper($this->sepNameSpace($element[tag])) == strtoupper("coordinates")) {
-						$this->geometry[$this->member][$cnt_geom] =  str_replace(",,","",str_replace(" ",",",trim($element[value])));
-						$coordinates = true;
-					else if (!$coordinates && trim($element[value])) {
-						$coords = str_replace(",,","",str_replace(" ",",",trim($element[value])));
-						$tmp_array = explode(",", $coords);
-						if (count($tmp_array > 1)) {
-							$this->geometry[$this->member][$cnt_geom] =  $coords;
-				else if(strtoupper($this->sepNameSpace($element[tag])) == strtoupper("featureMember") && $element[type] == "close"){
-					$section = false;
-					$el = -1;
-				else{
-					$el++;
-					$this->values[$this->member][$el] = $element[value];
-					$this->keys[$this->member][$el] = $element[tag];
-	function sepNameSpace($s){
-		$c = strpos($s,":");
-		if($c>0){
-			return substr($s,$c+1);
-		else{
-			return $s;
-	function getMemberCount(){
-		return ($this->member+1);
-	function getValueBySeparatedKey($memberCount,$keyName){
-		for($i=0; $i<count($this->keys[$memberCount]); $i++){
-			if($this->sepNameSpace($this->keys[$memberCount][$i]) == $keyName){
-				return $this->values[$memberCount][$i];
-	function getValueByKey($memberCount,$keyName){
-			if($this->keys[$memberCount][$i] == $keyName){
-	function getXfromMemberAsString($memberCount,$geomCount){
-		$t = explode(",",$this->geometry[$memberCount][$geomCount]);
-		$x = array();
-		for($i=0; $i<(count($t)-1); $i=$i+2){
-			array_push($x,$t[$i]);
-		return implode(",",$x);
-	function getYfromMemberAsString($memberCount,$geomCount){
-		$y = array();
-		for($i=1; $i<=(count($t)-1); $i=$i+2){
-			array_push($y,$t[$i]);
-		return implode(",",$y);
-	function getGeometriesFromMember($memberCount){
-		return $this->geometry[$memberCount];
-	function getGeometryTypeFromMember($memberCount){
-		return 	$this->geomtype[$memberCount];
-	function char_encode($s){
-		if(CHARSET == 'UTF-8'){
-			$s = utf8_encode($s);
-		return $s;
-	function exportGeometriesToJS ($isInFrame) {
-		$prefix = "";
-		if ($isInFrame == true) {
-			$prefix = "parent.";
-		$js = "";
-		$js .= "var geom = new ".$prefix."GeometryArray();\n";
-		for ($i=0; $i<count($this->geometry); $i++) {
-			$js .= $this->exportMemberToJS($i, $isInFrame);
-			$js .= "geom.addCopy(q);\n";
-		return $js;
-	function exportMemberToJS ($i, $isInFrame) {
-		$prefix = "";
-		$js = "";
-		if ($this->getGeometryTypeFromMember($i) == $this->geomtype_point) {
-			$js .= "var current_geomtype = ".$prefix."geomType.point;\n";
-		elseif ($this->getGeometryTypeFromMember($i) == $this->geomtype_line || $this->getGeometryTypeFromMember($i) == $this->geomtype_multiline) {
-			$js .= "var current_geomtype = ".$prefix."geomType.line;\n";
-		elseif ($this->getGeometryTypeFromMember($i) == $this->geomtype_polygon || $this->getGeometryTypeFromMember($i) == $this->geomtype_multipolygon) {
-			$js .= "var current_geomtype = ".$prefix."geomType.polygon;\n";
-		else die("unknown geometry type: '".$this->getGeometryTypeFromMember($i)."'");
-		$js .= "var q = new ".$prefix."MultiGeometry(current_geomtype);\n";
-		for ($j=0; $j<count($this->geometry[$i]); $j++) {
-			$js .= "q.addGeometry(current_geomtype);\n";
-			$x_array = explode(",", $this->getXfromMemberAsString($i, $j));
-			$y_array = explode(",", $this->getYfromMemberAsString($i, $j));
-			for ($k=0; $k<count($x_array); $k++) {
-				$js .= "q.get(-1).addPointByCoordinates(parseFloat(".$x_array[$k]."), parseFloat(".$y_array[$k]."));\n";
-				//$js .= "alert(parseFloat(".$x_array[$k]."), parseFloat(".$y_array[$k]."));";
-			$js .= "q.get(-1).close();\n";
-//		$js .= "alert(q);\n";
-		return $js;
+<?php
+# $Id$
+# http://www.mapbender.org/index.php/class_gml2.php
+require_once("class_mb_exception.php");
+require_once("class_connector.php");
+require_once("../../conf/mapbender.conf");
+class gml2{
+	var $geomtype_point = 'Point';
+	var $geomtype_polygon = 'Polygon';
+	var $geomtype_line = 'LineString';
+	var $geomtype_multipolygon = 'MultiPolygon';
+	var $geomtype_multiline = 'MultiLine';
+	var $geometries = array();
+	var $member = -1;
+	var $geomtype = array();
+	var $keys = array();
+	var $values = array();
+	var $geometry = array();
+	var $bbox = array();
+	function gml2(){
+		$this->geometries = array($this->geomtype_point, $this->geomtype_polygon, $this->geomtype_line, $this->geomtype_multipolygon, $this->geomtype_multiline);
+	function getGml($req){
+		$x = new connector($req);
+		return $x->file;
+	function parsegml($req){
+		#$data = implode("",file($req));
+		$data = $x->file;
+		$this->parse_xml($data);
+	function parse_xml($data){
+		$section = false;
+		$geom = false;
+		$boundedBy = false;
+		$coordinates = false;
+		$values = null;
+		$tags = null;
+		$el = -1;
+		$parser = xml_parser_create(CHARSET);
+		xml_parser_set_option($parser,XML_OPTION_CASE_FOLDING,0);
+		xml_parser_set_option($parser,XML_OPTION_SKIP_WHITE,1);
+		xml_parser_set_option($parser,XML_OPTION_TARGET_ENCODING,CHARSET);
+		xml_parse_into_struct($parser,$data,$values,$tags);
+		$code = xml_get_error_code ($parser);
+		if ($code) {
+			$line = xml_get_current_line_number($parser);
+			$mb_exception = new mb_exception(xml_error_string($code) .  " in line " . $line);
+		xml_parser_free($parser);
+		foreach ($values as $element) {
+			if(mb_strtoupper($this->sepNameSpace($element[tag])) == mb_strtoupper("boundedBy") && $element[type] == "open"){
+				$boundedBy = true;
+			if ($boundedBy) {
+				if(mb_strtoupper($this->sepNameSpace($element[tag])) == mb_strtoupper("coordinates")){
+					$this->bbox = explode(",", preg_replace("/,,/","",preg_replace("/ /",",",trim($element[value]))));
+					$boundedBy=false;
+			if(mb_strtoupper($this->sepNameSpace($element[tag])) == mb_strtoupper("featureMember") && $element[type] == "open"){
+				$this->member++;
+				$this->keys[$this->member] = array();
+				$this->value[$this->member] = array();
+				$this->geometry[$this->member] = array();
+				$section = true;
+				$cnt_geom = 0;
+			if($section == true){
+				if( in_array($this->sepNameSpace($element[tag]),$this->geometries) && $element[type] == "open"){
+					$geom = true;
+					$this->geomtype[$this->member] = $this->sepNameSpace($element[tag]);
+				else if(in_array($this->sepNameSpace($element[tag]),$this->geometries) && $element[type] == "close"){
+					$cnt_geom++;
+					$geom = false;
+				if($geom == true){
+					if (mb_strtoupper($this->sepNameSpace($element[tag])) == mb_strtoupper("coordinates")) {
+						$this->geometry[$this->member][$cnt_geom] =  preg_replace("/,,/","",preg_replace("/ /",",",trim($element[value])));
+						$coordinates = true;
+						// XXX: Increment counter to get all geometries of a feature member,
+						// comment it out to only show first geometry of featuremember
+						$cnt_geom++;
+					else if (!$coordinates && trim($element[value])) {
+						$coords = preg_replace("/,,/","",preg_replace("/ /",",",trim($element[value])));
+						$tmp_array = explode(",", $coords);
+						if (count($tmp_array > 1)) {
+							$this->geometry[$this->member][$cnt_geom] =  $coords;
+							$cnt_geom++;
+				else if(mb_strtoupper($this->sepNameSpace($element[tag])) == mb_strtoupper("featureMember") && $element[type] == "close"){
+					$section = false;
+					$el = -1;
+				else{
+					$el++;
+					$this->values[$this->member][$el] = $element[value];
+					$this->keys[$this->member][$el] = $element[tag];
+	function sepNameSpace($s){
+		$c = mb_strpos($s,":");
+		if($c>0){
+			return mb_substr($s,$c+1);
+		else{
+			return $s;
+	function getMemberCount(){
+		return ($this->member+1);
+	function getValueBySeparatedKey($memberCount,$keyName){
+		for($i=0; $i<count($this->keys[$memberCount]); $i++){
+			if($this->sepNameSpace($this->keys[$memberCount][$i]) == $keyName){
+				return $this->values[$memberCount][$i];
+	function getValueByKey($memberCount,$keyName){
+			if($this->keys[$memberCount][$i] == $keyName){
+	function getXfromMemberAsString($memberCount,$geomCount){
+		$t = explode(",",$this->geometry[$memberCount][$geomCount]);
+		$x = array();
+		for($i=0; $i<(count($t)-1); $i=$i+2){
+			array_push($x,$t[$i]);
+		return implode(",",$x);
+	function getYfromMemberAsString($memberCount,$geomCount){
+		$y = array();
+		for($i=1; $i<=(count($t)-1); $i=$i+2){
+			array_push($y,$t[$i]);
+		return implode(",",$y);
+	function getGeometriesFromMember($memberCount){
+		return $this->geometry[$memberCount];
+	function getGeometryTypeFromMember($memberCount){
+		return 	$this->geomtype[$memberCount];
+	function exportGeometriesToJS ($isInFrame) {
+		$prefix = "";
+		if ($isInFrame == true) {
+			$prefix = "parent.";
+		$js = "";
+		$js .= "var geom = new ".$prefix."GeometryArray();\n";
+		for ($i=0; $i<count($this->geometry); $i++) {
+			$js .= $this->exportMemberToJS($i, $isInFrame);
+			$js .= "geom.addCopy(q);\n";
+		return $js;
+	function exportMemberToJS ($i, $isInFrame) {
+		$prefix = "";
+		$js = "";
+		if ($this->getGeometryTypeFromMember($i) == $this->geomtype_point) {
+			$js .= "var current_geomtype = ".$prefix."geomType.point;\n";
+		elseif ($this->getGeometryTypeFromMember($i) == $this->geomtype_line || $this->getGeometryTypeFromMember($i) == $this->geomtype_multiline) {
+			$js .= "var current_geomtype = ".$prefix."geomType.line;\n";
+		elseif ($this->getGeometryTypeFromMember($i) == $this->geomtype_polygon || $this->getGeometryTypeFromMember($i) == $this->geomtype_multipolygon) {
+			$js .= "var current_geomtype = ".$prefix."geomType.polygon;\n";
+		else die("unknown geometry type: '".$this->getGeometryTypeFromMember($i)."'");
+		$js .= "var q = new ".$prefix."MultiGeometry(current_geomtype);\n";
+		for ($j=0; $j<count($this->geometry[$i]); $j++) {
+			$js .= "q.addGeometry(current_geomtype);\n";
+			$x_array = explode(",", $this->getXfromMemberAsString($i, $j));
+			$y_array = explode(",", $this->getYfromMemberAsString($i, $j));
+			for ($k=0; $k<count($x_array); $k++) {
+				$js .= "q.get(-1).addPointByCoordinates(parseFloat(".$x_array[$k]."), parseFloat(".$y_array[$k]."));\n";
+				//$js .= "alert(parseFloat(".$x_array[$k]."), parseFloat(".$y_array[$k]."));";
+			$js .= "q.get(-1).close();\n";
+//		$js .= "alert(q);\n";
+		return $js;
Modified: branches/mapbender_sld/http/classes/class_gui.php
--- branches/mapbender_sld/http/classes/class_gui.php	2007-11-23 13:20:10 UTC (rev 1830)
+++ branches/mapbender_sld/http/classes/class_gui.php	2007-11-23 13:22:46 UTC (rev 1831)
@@ -183,7 +183,7 @@
 				$error = true;
-			$sql = "INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) SELECT '" . $newGuiName . "', e_id, e_pos, e_public, e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url FROM gui_element WHERE fkey_gui_id = '" . $guiList . "';";
+			$sql = "INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) SELECT '" . $newGuiName . "', e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url FROM gui_element WHERE fkey_gui_id = '" . $guiList . "';";
 			if (!$res) {
 				$report .= "<br><br>" . $sql . "<br><br>" . db_error() . "<br>";
@@ -204,14 +204,15 @@
 				$error = true;
-			$sql = "INSERT INTO gui_mb_group (fkey_gui_id, fkey_mb_group_id, mb_group_type) SELECT '" . $newGuiName . "', fkey_mb_group_id, mb_group_type FROM gui_mb_group WHERE fkey_gui_id = '" . $guiList . "';";
-			$res = db_query($sql);
-			if (!$res) {
-				$report .= "<br><br>" . $sql . "<br><br>" . db_error() . "<br>";
-				$error = true;
+			if ($withUsers == true) {
+				/* group of original gui is copied as well */
+				$sql = "INSERT INTO gui_mb_group (fkey_gui_id, fkey_mb_group_id, mb_group_type) SELECT '" . $newGuiName . "', fkey_mb_group_id, mb_group_type FROM gui_mb_group WHERE fkey_gui_id = '" . $guiList . "';";
+				if (!$res) {
+					$report .= "<br><br>" . $sql . "<br><br>" . db_error() . "<br>";
+					$error = true;
-			if ($withUsers == true) {
 				/* users of original gui are copied as well */
 				$sql = "INSERT INTO gui_mb_user (fkey_gui_id, fkey_mb_user_id, mb_user_type) SELECT '" . $newGuiName . "', fkey_mb_user_id, mb_user_type FROM gui_mb_user WHERE fkey_gui_id = '" . $guiList . "';";
Added: branches/mapbender_sld/http/classes/class_keyword.php
--- branches/mapbender_sld/http/classes/class_keyword.php	                        (rev 0)
+++ branches/mapbender_sld/http/classes/class_keyword.php	2007-11-23 13:22:46 UTC (rev 1831)
@@ -0,0 +1,371 @@
+<?php
+# $Id$
+# http://www.mapbender.org/index.php/class_administration
+include_once(dirname(__FILE__)."/../../conf/mapbender.conf");
+ * class to handle keywords for services
+class Mapbender_keyword{
+	private $service;
+	private $serviceId;
+	 * Constructor of the keyword-class
+	 * set the service to: wms, layer, wfs, featuretype
+	 * @param string service
+	 * @param integer id the id of the service
+	function __construct($service,$serviceId){
+		$this->service = $service;
+		$this->serviceId = $serviceId;
+		if ($this->service == "layer"){
+			$this->table = 'layer_keyword';
+			$this->serviceIdColumn = 'fkey_layer_id';
+		//example for wms
+		else if ($this->service == "wms"){
+			$this->table = 'wms_keyword';
+			$this->serviceIdColumn = 'fkey_wms_id';
+		//example for featuretype
+		else if ($this->service == "featuretype"){
+			$this->table = 'wfs_featuretype_keyword';
+			$this->serviceIdColumn = 'fkey_featuretype_id';
+	 * selects a keyword
+	 * @param integer the keyword_id
+	 * @return string the name of the selected keyword
+	function get($keywordId){
+		global $con;
+		$sql = "SELECT keyword FROM keyword WHERE keyword_id = $1";
+		$v = array($keywordId);
+		$t = array('i');
+			return $row['keyword'];
+		else{
+			return false;
+	/* selects keywords of layer
+	 * @param integer the layer_id
+	 * @return array keywords
+	function getLayerKeywords(){
+		global $con;
+		$sql = "SELECT keyword FROM keyword, layer_keyword, layer " .
+               "WHERE keyword.keyword_id = layer_keyword.fkey_keyword_id " .
+               "AND layer_keyword.fkey_layer_id = layer.layer_id " .
+               "AND layer.layer_id = $1";
+       	$v = array($this->serviceId);
+		$t = array('i');
+		$keywordList = "";
+        $separator = "";
+	        if($keywordList != ""){
+	                $separator = ",";
+            $keywordList .= $separator.$row["keyword"];
+        return $keywordList;
+    /* selects keywords of featuretype
+	 * @param integer the featuretype_id
+	function getFeaturetypeKeywords(){
+		global $con;
+		$sql = "SELECT keyword FROM keyword, wfs_featuretype_keyword, wfs_featuretype " .
+               "WHERE keyword.keyword_id = wfs_featuretype_keyword.fkey_keyword_id " .
+               "AND wfs_featuretype_keyword.fkey_featuretype_id = wfs_featuretype.featuretype_id " .
+               "AND wfs_featuretype.featuretype_id = $1";
+		$t = array('i');
+        $separator = "";
+	                $separator = ",";
+	 * Checks whether the keyword exist in the table keywords
+	 * @param string the keyword
+	 * @return integer the ID of the keyword
+	function exists($keyword){
+		global $con;
+		$sql = "SELECT keyword_id FROM keyword WHERE keyword = $1";
+		$v = array($keyword);
+		$t = array('s');
+			return $row['keyword_id'];
+		else{
+			return false;
+	 * Inserts a new keyword in the parent table keyword
+	 * Check first, if the keyword exists
+	 * @return integer the id of the new keyword
+	function insert($keyword){
+		global $con;
+		if ($this->exists($keyword)){
+			return false;
+		else{
+			$sql = "INSERT INTO keyword (keyword) VALUES ($1)";
+			$t = array('s');
+			$id_sql = "SELECT keyword_id FROM keyword WHERE keyword = $1";
+			$id_v = array($keyword);
+			$id_t = array('s');
+			$id_res = db_prep_query($id_sql,$id_v,$id_t);
+				if($row = db_fetch_array($id_res)){
+				else{
+					return false;
+	 * Deletes the entry in the parent table keyword
+	function delete($keywordId){
+		global $con;
+		$sql = "DELETE FROM keyword WHERE keyword_id = $1";
+		$t = array('i');
+		else{
+			return false;
+	 * Inserts a new keyword-constraint in the crosstabulation
+	 * @return integer the id of the new keyword-constraint
+	function allocate($keywordId){
+		global $con;
+		$sql = "INSERT INTO ".$this->table." (".$this->serviceIdColumn.", fkey_keyword_id) VALUES ($1,$2)";
+		$v = array($this->serviceId, $keywordId);
+		$t = array('i','i');
+			return $row['fkey_keyword_id'];
+		else{
+			return false;
+	 * Checks whether the keyword exist in the crosstabulation layer_keywords
+	 * @return true or false
+	function isAllocated($keywordId){
+		global $con;
+		$sql = "SELECT ".$this->serviceIdColumn." FROM ".$this->table." WHERE fkey_keyword_id = $1";
+		$t = array('i');
+			return true;
+		else{
+			return false;
+	 * Deletes the entry in the crosstabulation (relation)
+	 * @return integer the id of the keyword
+	function remove($keywordId){
+		global $con;
+		$sql = "DELETE FROM ".$this->table." WHERE ".$this->serviceIdColumn." = $1 AND fkey_keyword_id = $2";
+		if($res!=FALSE){
+			return true;
+		else{
+			return false;
+	 * Deletes all entries of service in the crosstabulation (relation)
+	 * @param
+	 * @return
+	function removeAll(){
+		global $con;
+		$sql = "DELETE FROM ".$this->table." WHERE ".$this->serviceIdColumn." = $1";
+		$t = array('i');
+		if($res!=FALSE){
+			return true;
+		else{
+			return false;
+	 * Deletes the keyword if it has no entry in one of the crosstabs
+	 * @TODO check if the keyword exists in every crosstab (wms, layer, wfs, feturetype) !!!
+	function orphaned(){
+		global $con;
+		$sql = "DELETE FROM keyword WHERE NOT EXISTS (SELECT fkey_keyword_id FROM layer_keyword WHERE keyword.keyword_id = layer_keyword.fkey_keyword_id);";
+		//$sql .= " AND NOT EXISTS  (SELECT fkey_keyword_id FROM wms_keyword WHERE keyword.keyword_id = wms_keyword.fkey_keyword_id);";
+		$res = db_prep_query($sql);
+		if($res!=FALSE){
+			return true;
+		else{
+			return false;
+	 * add a new keyword.
+	 * @param string the new keyword
+	function add($keyword){
+		// if the keyword exists add a new entry in the crosstab
+		if ($keywordId = $this->exists($keyword)){
+			$this->allocate($keywordId);
+		// if it doesn´t exist create a new entry in the keyword table and add a new entry in the crosstab
+		else{
+			$keywordId = $this->insert($keyword);
+	 * add list of keywords to a service
+	 * @param string[] keywords an array of keywords
+	function addList($keywords){
+		foreach ($keywords as $keyword){
+			else{
+	 * replaces the keywords of a service
+	 * @param string keywords an array of keywords
+	function replaceList($keywords){
+		// remove all entries in the crosstable for the current service
+		$this->removeAll();
+		// check for each keyword of the array if it exists
+				// check if the keyword is allocated
+			else{
+				$keywordIdNew = $this->insert($keyword);
+				$this->allocate($keywordIdNew);
+			// if a keyword exists, that has no constraint delete it
+			$this->orphaned();
+//$x = new Mapbender_keyword("layer",20840);
+//echo $x->replaceList(array(test1,test2));
Modified: branches/mapbender_sld/http/classes/class_kml.php
--- branches/mapbender_sld/http/classes/class_kml.php	2007-11-23 13:20:10 UTC (rev 1830)
+++ branches/mapbender_sld/http/classes/class_kml.php	2007-11-23 13:22:46 UTC (rev 1831)
@@ -46,6 +46,10 @@
 	function createObjFromKML($kml_doc) {
+		$section = null;
+		$values = null;
+		$tags = null;
 		$data = $kml_doc;
 		if(!$data){
@@ -53,7 +57,7 @@
 			return false;
-		$this->kml = $this->char_encode($data);
+		$this->kml = $data;
@@ -62,7 +66,6 @@
-		$section;
 		$cnt_format = 0;
 		$parent = array();
 		$myParent = array();
@@ -71,49 +74,49 @@
 		$cnt_styles = -1;
-			if(strtoupper($element[tag]) == "KML" && $element[type] == "open"){
+			if(mb_strtoupper($element[tag]) == "KML" && $element[type] == "open"){
 				$section = "kml";
-			if ($section == "kml" && strtoupper($element[tag]) == "PLACEMARK" && $element[type] == "open") {
+			if ($section == "kml" && mb_strtoupper($element[tag]) == "PLACEMARK" && $element[type] == "open") {
 				$section = "placemark";
-			if ($section == "placemark" && strtoupper($element[tag]) == "DESCRIPTION" && $element[type] == "complete") {
+			if ($section == "placemark" && mb_strtoupper($element[tag]) == "DESCRIPTION" && $element[type] == "complete") {
 				$this->description = $element[value];
-			if ($section == "placemark" && strtoupper($element[tag]) == "NAME" && $element[type] == "complete") {
+			if ($section == "placemark" && mb_strtoupper($element[tag]) == "NAME" && $element[type] == "complete") {
 				$this->title = $element[value];
-			if ($section == "placemark" && strtoupper($element[tag]) == "LOOKAT" && $element[type] == "open") {
+			if ($section == "placemark" && mb_strtoupper($element[tag]) == "LOOKAT" && $element[type] == "open") {
 				$section = "lookat";
 			if ($section == "lookat") {
-				if (strtoupper($element[tag]) == "RANGE" && $element[type] == "complete") {
+				if (mb_strtoupper($element[tag]) == "RANGE" && $element[type] == "complete") {
 					$this->lookAt_range = $element[value];
-				if (strtoupper($element[tag]) == "HEADING" && $element[type] == "complete") {
+				if (mb_strtoupper($element[tag]) == "HEADING" && $element[type] == "complete") {
 					$this->lookAt_heading = $element[value];
-				if (strtoupper($element[tag]) == "TILT" && $element[type] == "complete") {
+				if (mb_strtoupper($element[tag]) == "TILT" && $element[type] == "complete") {
 					$this->lookAt_tilt = $element[value];
-			if (strtoupper($element[tag]) == "STYLE" && $element[type] == "open") {
+			if (mb_strtoupper($element[tag]) == "STYLE" && $element[type] == "open") {
 				$section = "style";
-			if ($section == "style" && strtoupper($element[tag]) == "ICONSTYLE" && $element[type] == "open") {
+			if ($section == "style" && mb_strtoupper($element[tag]) == "ICONSTYLE" && $element[type] == "open") {
 				$section = "iconstyle";
-			if ($section == "iconstyle" && strtoupper($element[tag]) == "ICON" && $element[type] == "open") {
+			if ($section == "iconstyle" && mb_strtoupper($element[tag]) == "ICON" && $element[type] == "open") {
 				$section = "icon";
-			if ($section == "icon" && strtoupper($element[tag]) == "HREF" && $element[type] == "complete") {
+			if ($section == "icon" && mb_strtoupper($element[tag]) == "HREF" && $element[type] == "complete") {
 				$this->icon = $element[value];
-			if (strtoupper($element[tag]) == "POINT" && $element[type] == "open") {
+			if (mb_strtoupper($element[tag]) == "POINT" && $element[type] == "open") {
 				$section = "point";
-			if ($section == "point" && strtoupper($element[tag]) == "COORDINATES" && $element[type] == "complete") {
+			if ($section == "point" && mb_strtoupper($element[tag]) == "COORDINATES" && $element[type] == "complete") {
 				$array = explode(",", $element[value]);
 				$this->x = $array[0];
 				$this->y = $array[1];
@@ -167,12 +170,6 @@
 		return $kml;
-		return $s;
 // end class
Added: branches/mapbender_sld/http/classes/class_layer_monitor.php
--- branches/mapbender_sld/http/classes/class_layer_monitor.php	                        (rev 0)
+++ branches/mapbender_sld/http/classes/class_layer_monitor.php	2007-11-23 13:22:46 UTC (rev 1831)
@@ -0,0 +1,55 @@
+<?php
+# $Id: class_layer_monitor.php 791 2007-08-10 10:36:04Z baudson $
+class Layer_load_count {
+	function __construct () {
+	 * increments the load count in table "layer_load_count" for
+	 * each layer in the WMC document by one.
+	function increment($layer_id) {
+		//check if an entry exists for the current layer id
+		$sql = "SELECT load_count FROM layer_load_count WHERE fkey_layer_id = $1";
+		$v = array($layer_id);
+		$t = array('i');
+		$res = db_prep_query($sql, $v, $t);
+		$row = db_fetch_array($res);
+		//if yes, increment the load counter
+		if ($row) {
+			$currentCount = $row["load_count"];
+			$sql = "UPDATE layer_load_count SET load_count = $1 WHERE fkey_layer_id = $2";
+			$v = array(intval($currentCount + 1), $layer_id);
+			$t = array('i', 'i');
+		//if no, insert a new row with current layer id and load_count = 1
+		else {
+			$sql = "INSERT INTO layer_load_count (fkey_layer_id, load_count) VALUES ($1, 1)";
+			$t = array('i');
Added: branches/mapbender_sld/http/classes/class_locale.php
--- branches/mapbender_sld/http/classes/class_locale.php	                        (rev 0)
+++ branches/mapbender_sld/http/classes/class_locale.php	2007-11-23 13:22:46 UTC (rev 1831)
@@ -0,0 +1,196 @@
+<?php
+# $Id:$
+# http://www.mapbender.org/index.php/class_locale.php
+ * sets the locale, depending on various settings:
+ * 1) a language ID passed to the constructor
+ * 2) the browser settings $_SERVER["HTTP_ACCEPT_LANGUAGE"]
+ * 3) a default language ID
+class Mb_locale {
+	var $knownLanguages = null;
+	var $systemLocales = null;
+	var $browserLanguages = null;
+	var $os = null;
+	var $name = null;
+	var $defaultLanguage = "de";
+	var $status = "No locale set.";
+	function Mb_locale($languageId) {
+		if (!$this->setCurrentLocale($languageId)) {
+			$e = new Mb_exception("Locale could not be set. Language ID: '" . $languageId . "'");
+	 * Get the current locale, evaluating GET/POST variables, browser languages
+	 * and a default locale (in that preference)
+	 * @returns current locale
+	function setCurrentLocale($languageId) {
+	  	// try to set the locale to $languageId
+		if ($this->checkAndSetLocale($languageId)) {
+			return true;
+	  	else {
+	  		$e = new Mb_notice("class_locale: no input parameter specified.");
+		// determine the browser setting and try to set locale according to that
+		if ($this->browserLanguage == null) {
+			$this->setBrowserLanguages();
+		foreach ($this->browserLanguages as $lang) {
+			$e = new Mb_notice("trying browser setting " . $lang);
+			if ($this->checkAndSetLocale($lang)) {
+				return true;
+		// set to default language
+		$e = new Mb_notice("trying default language " . $this->defaultLanguage);
+		return $this->checkAndSetLocale($this->defaultLanguage);
+	 * checks if a locale is available; if yes, it is set via setlocale
+	 * @returns true if the the locale is set successfully; otherwise false
+	function checkAndSetLocale($languageId) {
+		if ($this->os == null) {
+			$this->os = $this->guessHostOS();
+		if ($this->os != null && isset($languageId)) {
+			if ($this->isKnownLanguage($languageId)) {
+				if ($this->systemLocales == null) {
+					$this->setSystemLocales();
+				$locale = $this->systemLocales[$this->knownLanguages[$languageId]][$this->os];
+				bindtextdomain(LOCALE_DOMAIN, LOCALE_DIR);
+				textdomain(LOCALE_DOMAIN);
+				if (setlocale(LC_ALL, $locale)) {
+					$this->name = $locale;
+					$_SESSION["mb_lang"] = $languageId;
+					$_SESSION["mb_locale"] = $this->name;
+					$e = new Mb_notice("locale " . $this->name . " ok on " . $this->os);
+					return true;
+				$e = new Mb_notice("locale " . $locale . " not found.");
+		return false;
+	 * Guess the operating system which on which this code is running
+	 * multiple methods are tested for reliably guessing the os
+	 * @private
+	 * @returns string with os name
+	function guessHostOS(){
+	  if (strncasecmp(php_uname(), 'Windows', 7) == 0)
+	    return 'windows';
+	  else if (strncasecmp(php_uname(), 'Linux', 5) == 0)
+	    return 'linux';
+	  else if (strncasecmp(php_uname(), 'OpenBSD', 7) == 0)
+	    return 'bsd';
+	  else {
+	    throw new Mb_exception('unknown platform: could not interpret uname. php_uname() returned '. php_uname().'. Please report to MB developers');
+	    return null;
+	 * checks if a language is supported
+	 * @returns true if the language is supported; otherwise false
+	function isKnownLanguage($languageId) {
+		if ($this->knownLocales == null) {
+			$this->setKnownLanguages();
+		if (array_key_exists($languageId, $this->knownLanguages)) {
+			return true;
+		else {
+			$e = new Mb_notice("language " . $languageId . " not supported.");
+		return false;
+	 * determines the available Locales on this system
+	function setSystemLocales() {
+		$this->systemLocales['it_IT'] = array('linux' => 'it_IT.utf8',
+	                                'windows' => 'Italian_Italy.1252',
+	                                'bsd' => 'it_IT',
+	                                'posix' => 'it_IT');
+		$this->systemLocales['de_DE'] = array('linux' => 'de_DE.utf8',
+	                                'windows' => 'German_Germany.1252',
+	                                'bsd' => 'de_DE',
+		$this->systemLocales['en_US'] = array('linux' => 'en_US.utf8',
+	                                'windows' => 'English_United States.1252',
+	                                'bsd' => 'en_US',
+	 * set the known languages
+	function setKnownLanguages() {
+		$this->knownLanguages = array('en_US' => 'en_US',
+                      'en' => 'en_US',
+                      'de_DE' => 'de_DE',
+                      'de' => 'de_DE',
+                      'it_IT' => 'it_IT',
+                      'it' => 'it_IT');
+	 * sets the languages accepted by the client browser
+	function setBrowserLanguages () {
+		$this->browserLanguages = array();
+	    $bLangs = split(',', $_SERVER["HTTP_ACCEPT_LANGUAGE"]);
+	    foreach ($bLangs as $lang) {
+			if (strpos($lang, ';') === false)
+				array_push($this->browserLanguages, $lang);
+			else
+				array_push($this->browserLanguages, substr($lang, 0, strpos($lang, ';')));
Modified: branches/mapbender_sld/http/classes/class_mb_exception.php
--- branches/mapbender_sld/http/classes/class_mb_exception.php	2007-11-23 13:20:10 UTC (rev 1830)
+++ branches/mapbender_sld/http/classes/class_mb_exception.php	2007-11-23 13:22:46 UTC (rev 1831)
@@ -29,6 +29,8 @@
 	var $mb_log_level = LOG_LEVEL;
 	var $dir = "../../log/";
 	var $filename_prefix = "mb_error_";
+	var $result = false;
+	var $message = "";
 	function indexOf($level, $levelArray) {
 		$index = false;
@@ -57,20 +59,48 @@
 				if($h = fopen($logfile,"a")){
 					$content = date("Y.m.d, H:i:s") . "," . $n .chr(13).chr(10);
 					if(!fwrite($h,$content)){
-						#exit;
+						$this->result = false;
+						$this->message = "Unable to write " . $logfile;
+						return false;
 					fclose($h);
+					$this->result = true;
+					$this->message = "Successful.";
+					return true;
+				else {
+					$this->message = "Unable to open or generate " . $logfile;
+					return false;
+			else {
+				$this->message = "Directory " . $this->dir . " is not valid.";
+				return false;
+		else {
+			$this->message = "Log level '" . $level . "' is not valid or logging is disabled in mapbender.conf.";
+			return false;
+class mb_notice extends mb_log {
+	var $level = "notice";
+	function mb_notice($message) {
+		return $this->mb_log("Notice: " . $message, $this->level);
 class mb_warning extends mb_log {
 	var $level = "warning";
 	function mb_warning($message) {
-		$this->mb_log($message, $this->level);
+		return $this->mb_log("Warning: " . $message, $this->level);
@@ -78,7 +108,7 @@
 	var $level = "error";
 	function mb_exception($message) {
+		return $this->mb_log("ERROR: " . $message, $this->level);
Added: branches/mapbender_sld/http/classes/class_metadata.php
--- branches/mapbender_sld/http/classes/class_metadata.php	                        (rev 0)
+++ branches/mapbender_sld/http/classes/class_metadata.php	2007-11-23 13:22:46 UTC (rev 1831)
@@ -0,0 +1,1465 @@
+<?php
+# $Id$
+#require_once(dirname(__FILE__)."/../../conf/mapbender.conf");
+require_once(dirname(__FILE__)."/class_administration.php");
+class class_metadata{
+	private $user_id;
+	private $departments = array();
+	private $categories = array();
+	private $searchtext;
+	private $timestamp_beg;
+	private $timestamp_end;
+	private $limit;
+	private $search_bbox = array();
+	private $search_epsg;
+	private $obj_members = array();
+	private $availabilityTime;
+	private $doc;
+	 * Constructor of the class_metadata-class
+	 * @$user_id 		integer 	users ID
+	 * @$departments 	array 		departments
+	 * @$categories 	array 		categories
+	 * @$searchtext 	string 		searchtext (with blanks => more searchwords)
+	 * @$timestamp_beg 	integer		Timebegin of the Search in TIMESTAMP-Format
+	 * @$timestamp_end 	integer		Timeend of the Search in TIMESTAMP-Format
+	 * @$limit			integer		Limit of the whole Result of the Metadata Search
+	 * @$search_bbox	array		BoundingBox
+	 * @$search_epsg	string		EPSG like: "EPSG:4326"
+	 function logit($text){
+	 	if($h = fopen("/data/mapbender/http/tmp/gregor.txt","a")){
+					$content = $text .chr(13).chr(10);
+					if(!fwrite($h,$content)){
+						#exit;
+					fclose($h);
+	function __construct($user_id, $departments, $categories, $searchtext, $timestamp_beg, $timestamp_end, $limit, $search_bbox, $search_epsg){
+		$this->user_id = $user_id;
+		$this->departments = $departments;
+		$this->categories = $categories;
+		$this->searchtext = $searchtext;
+		$this->timestamp_beg = $timestamp_beg;
+		$this->timestamp_end = $timestamp_end;
+		$this->limit = $limit;
+		$this->search_bbox = $search_bbox;
+		$this->search_epsg = $search_epsg;
+		$this->availabilityTime = 60*60*24*90;	// sec*min*hour*days
+//		$e = new mb_notice("Search extended => user_id: ".$this->user_id."");
+//		$e = new mb_notice("Search extended => searchtext: ".$this->searchtext."");
+//		$e = new mb_notice("Search extended => timestamp_beg: ".$this->timestamp_beg."");
+//		$e = new mb_notice("Search extended => timestamp_end: ".$this->timestamp_end."");
+//		$e = new mb_notice("Search extended => limit: ".$this->limit."");
+//		$e = new mb_notice("Search extended => search_epsg: ".$this->search_epsg."");
+//		$e = new mb_notice("Search extended => count departments: ".count($this->departments)."");
+//		$e = new mb_notice("Search extended => count categories: ".count($this->categories)."");
+//		$e = new mb_notice("Search extended => count search_bbox: ".count($this->search_bbox)."");
+//		echo "Search extended => user_id: ".$this->user_id."<br>";
+//		echo "Search extended => searchtext: ".$this->searchtext."<br>";
+//		echo "Search extended => timestamp_beg: ".$this->timestamp_beg."<br>";
+//		echo "Search extended => timestamp_end: ".$this->timestamp_end."<br>";
+//		echo "Search extended => limit: ".$this->limit."<br>";
+//		echo "Search extended => search_epsg: ".$this->search_epsg."<br>";
+//		echo "Search extended => count search_bbox: ".count($this->search_bbox)."<br>";
+//		echo "Search extended => count departments: ".count($this->departments)."<br>";
+//		echo "Search extended => count categories: ".count($this->categories)."<br>";
+//		echo "Search extended => count departments: ".$this->departments[0]."<br>";
+//		echo "Search extended => count categories: ".$this->categories[0]."<br>";
+//		echo "Search extended => count search_bbox: ".$this->search_bbox[0]."<br>";
+		$this->logit("searchtext: ".$this->searchtext);
+		$this->logit("count categories: ".count($this->categories));
+		$this->logit("count departments: ".count($this->departments));
+		$this->logit("count search_bbox: ".count($this->search_bbox));
+		$cat_id="";
+		for ($index = 0; $index < sizeof($this->categories); $index++) {
+			$array_element = $this->categories[$index];
+			$cat_id .= $array_element.", ";
+		$this->isOverLimit;
+		$this->anz_wms=0;
+		$this->anz_wfs=0;
+		$cat = array();
+		$this->cat = $cat;
+		$this->user_authorization();
+		$this->set_categories();
+		$this->doc = new DOMDocument('1.0');
+		$this->generate_xml_output();
+	 * user authorization
+	function user_authorization(){
+		$n = new administration();
+		$this->n = $n;
+		$myguis = $this->n->getGuisByPermission($this->user_id,true);
+		$mywms = $this->n->getWmsByOwnGuis($myguis);
+		$myWFSconfs = $this->n->getWfsConfByPermission($this->user_id);
+		$this->myWFSConfs = $myWFSconfs;
+		for ($index = 0; $index < sizeof($this->myWFSConfs); $index++) {
+			$array_element = $this->myWFSConfs[$index];
+//			 echo $index."wfs_conf_id: ".$array_element."<br>";
+		$mylayer = array();
+		$this->mylayer = $mylayer;
+		if($mywms == false){
+			$mywms = array();
+	/* set categories as array */
+		function set_categories(){
+			$sql = "SELECT * FROM md_topic_category ";
+			$sql .= " ORDER BY md_topic_category_id";
+			$this->cat[0] = array();
+			$this->cat[0]['md_topic_category_code_de'] = '';
+			$this->cat[0]['member'] = array();
+			$cnt = 1;
+				$this->cat[$cnt] = array();
+				$this->cat[$cnt]['md_topic_category_code_de'] = $row['md_topic_category_code_de'];
+				$this->cat[$cnt]['member'] = array();
+				$cnt++;
+//				echo " => ".$row['md_topic_category_code_de'];
+//				echo " => ".$row['md_topic_category_id']."<br>";
+			$cat_de="";
+			for ($index = 0; $index < sizeof($this->cat); $index++) {
+				$array_element = $this->cat[$index];
+				$cat_de .= "'".$this->cat[$index]['md_topic_category_code_de']."', ";
+//			$this->logit("set cat => count categories in [][]: ".count($this->cat));
+//			$this->logit("set cat => categories: ".$cat_de);
+	 * replace german letters (for example ä => ae)
+	function replaceChars($text){
+	$search = array( "ä",  "ö",  "ü",  "Ä",  "Ö",  "Ü",  "ß");
+	$repwith = array("ae", "oe", "ue", "AE", "OE", "UE", "ss");
+	if(CHARSET=="UTF-8")
+		$text = utf8_decode($text);
+	$ret = str_replace($search, $repwith, $text);
+		$ret = utf8_encode($ret);
+	return $ret;
+	function replaceString($string , $replaceString, $newString){
+		$newstr = str_replace($string, $replaceString, $newString);
+		return $newstr;
+	function generate_xml_output(){
+		$this->writeXmlhead();
+		$this->writeXmlWMSPart();
+		$this->writeXmlWFSPart();
+		$this->writeXmlEnd();
+	function writeXmlhead(){
+		$this->doc->encoding = CHARSET;
+		$result = $this->doc->createElement("result");
+		$this->doc->appendChild($result);
+		//Trefferanzahl
+		$overLimit = $this->doc->createElement('overLimit');
+		$result->appendChild($overLimit);
+		$tr_text = $this->doc->createTextNode($this->isOverLimit);
+		$overLimit->appendChild($tr_text);
+		$rd = $this->doc->createElement("redirect");
+		$result->appendChild($rd);
+		$trd = $this->doc->createTextNode("muss noch...");
+		$rd->appendChild($trd);
+	function writeXmlEnd(){
+		$overLimitText = $this->doc->createTextNode($this->isOverLimit);
+		$overLimits = $this->doc->getElementsByTagName("overLimit");
+		foreach ($overLimits as $overLimit) {
+			$overLimit->appendChild($overLimitText);
+		$ready = $this->doc->createElement('ready');
+		$tready = $this->doc->createTextNode("true");
+		$ready->appendChild($tready);
+		$results = $this->doc->getElementsByTagName("result");
+				foreach ($results as $result) {
+				$result->appendChild($ready);
+		echo $this->doc->saveXML();	// Ausgabe
+		$e = new mb_notice("Wrote the XML-File");
+	 * generats categories with members in the xml-File
+	function writeXmlWMSPart(){
+		$asstr = array();
+		if ($this->searchtext!="false"){
+			$asstr = split(" ",$this->searchtext);
+		$isTextSearch = "false";
+		for ($index = 0; $index < count($asstr); $index++) {
+			$array_element = $asstr[$index];
+			$e = new mb_notice("Search-Text: ".$index.".  ".$array_element."");
+		$v = array();
+		$t = array();
+		$sql = "SELECT DISTINCT * from service_metadata where ";
+		for($i=0; $i<count($asstr); $i++){
+			$isTextSearch = "true";
+			if($i>0){$sql .= " AND ";}
+			$sql .= "searchtext LIKE $".($i+1);
+			$va = "%".trim(strtoupper($this->replaceChars($asstr[$i])))."%";
+			array_push($v,$va);
+			array_push($t,"s");
+		$whereBedArray = array();
+		//layer_searchable condition
+		array_push($whereBedArray, "(layer_searchable = 1)");
+		//date condition
+		if ($this->timestamp_beg!="false" && $this->timestamp_end!="false"){
+			$time ="(wms_timestamp BETWEEN ".$this->timestamp_beg." AND ".$this->timestamp_end.")";
+			array_push($whereBedArray, $time);
+		} else if ($this->timestamp_beg!="false" && $this->timestamp_end=="false"){
+			$time ="(wms_timestamp > ".$this->timestamp_beg.")";
+		} else if ($this->timestamp_beg=="false" && $this->timestamp_end!="false"){
+			$time ="(wms_timestamp < ".$this->timestamp_end.")";
+		//department condition
+		if(count($this->departments)>0){
+			$txt = $this->getDepartmentBed("wms_owner", "mb_user_department", $this->departments, "OR");
+			$dep = " (". $txt . ") ";
+			array_push($whereBedArray, $dep);
+//		//Testausgabe
+//		for ($index = 0; $index < sizeof($this->whereBedArray); $index++) {
+//			$array_element = $this->whereBedArray[$index];
+//			echo $index." el: ".$array_element."<br>";
+		//Creating the Where Clausel, based on a Array
+		if(count($whereBedArray)>0){
+			$txt_whereBed="";
+			for ($index = 0; $index < sizeof($whereBedArray); $index++) {
+			$array_element = $whereBedArray[$index];
+				if($isTextSearch=="true") {
+					$txt_whereBed .=" AND ".$array_element;
+				} else {
+					if($index>0){
+					} else {
+						$txt_whereBed .=" ".$array_element;
+			$sql .= $txt_whereBed;
+		//order by
+		$sql .= " ORDER BY load_count DESC";
+		//Beschränkung
+		$lim = $this->limit;
+		$overLimit = $lim+1;
+		$sql .= " LIMIT ".$overLimit;
+		for ($index = 0; $index < sizeof($asstr); $index++) {
+			$this->logit($index.".Suchwort : ".$array_element);
+		$this->logit("SQL_WMS: ".$sql);
+		$e = new mb_notice("Search extended => SQL-Request of view service_metadata: ".$sql."");
+		//	spatial search
+//		for ($index = 0; $index < sizeof($this->cat); $index++) {
+//		$array_element = $this->cat[$index];
+//		$this->logit("0. vor Kategorieeinordnung => Kategorie: ".$this->cat[$index]['md_topic_category_code_de'].", Anzahl Member: ".count($this->cat[$index]['member']));
+		if(count($this->search_bbox)>0){
+		$anz = 0;
+			$resultColumns = array();
+			$resultColumns = $this->generateNewReaArray($res);
+			$e = new mb_notice("count service_metadata: ".count($resultColumns)."");
+			for ($index = 0; $index < count($resultColumns); $index++) {
+				$row = $resultColumns[$index];
+				if ($this->n->getLayerPermission($row['wms_id'], $row['layer_name'], $this->user_id)) {
+					array_push($this->mylayer,$row['layer_id']);
+				//accessconstraints -> email subadmin
+//				$sql_ac = "SELECT mb_user_email FROM mb_user WHERE mb_user_id = $1";
+//				$v = array($row["wms_owner"]);
+//				$t = array('i');
+//				$res_ac = db_prep_query($sql_ac, $v, $t);
+//				if($row_ac = db_fetch_array($res_ac)){
+//					$row["accessconstraints"] = $row_ac["mb_user_email"];
+				$ns = $this->make_members($row);
+				$anz++;
+			$e = new mb_notice("count service_metadata(spatial-search): ".$anz."");
+			$this->logit("ANZ_WMS mit bbox: ".$anz);
+		} else {
+		$anz = 0;
+//				if ($row_ac = db_fetch_array($res_ac)){
+				$anz++;
+		$e = new mb_notice("count service_metadata(no spatial-search): ".$anz."");
+		$this->logit("ANZ_WMS ohne bbox: ".$anz);
+//		$this->logit("1.nach Kategorieeinordnung => Kategorie: ".$this->cat[$index]['md_topic_category_code_de'].", Anzahl Member: ".count($this->cat[$index]['member']));
+		if ($this->limit < $anz ){
+			$this->isOverLimit="true";
+		} else {
+			$this->isOverLimit="false";
+		$ns = $this->make_xml();
+	 *  fills an array[][] with members based on categories
+	function make_members($r){
+//		$sql = "SELECT fkey_md_topic_category_id FROM layer_md_topic_category WHERE fkey_layer_id = $1";
+		$sql = "SELECT fkey_md_topic_category_id, md_topic_category_code_de, fkey_layer_id " .
+		"FROM layer_md_topic_category, md_topic_category " .
+		"WHERE layer_md_topic_category.fkey_md_topic_category_id = md_topic_category.md_topic_category_id " .
+		"AND fkey_layer_id = $1";
+		$sql .= " ORDER BY fkey_md_topic_category_id";
+		$v = array($r['layer_id']);
+		$t = array('i');
+		$c = 0;
+		//layer with category
+			if (count($this->categories)>0){
+				if (in_array($row['fkey_md_topic_category_id'], $this->categories) ){
+					$this->cat[$row['fkey_md_topic_category_id']]['member'][count($this->cat[$row['fkey_md_topic_category_id']]['member'])] = $r;
+			} else {
+//			$this->cat[$row['fkey_md_topic_category_id']]['member'][count($this->cat[$row['fkey_md_topic_category_id']]['member'])] = $r;
+//			$catID = $row['fkey_md_topic_category_id'];
+//			array_push($this->cat[$catID]['member'],$r);
+			$c++;
+		// no category for this layer
+		if($c == 0){
+			array_push($this->cat[0]['member'],$r);
+		return true;
+	 * generats the xml-document
+	function make_xml(){
+//		echo "Kategorie: ".$this->cat[$index]['md_topic_category_code_de'].", Anzahl Member: ".count($this->cat[$index]['member'])."<br>";
+	$i=0;
+	if (count($this->categories) == 0){		// Wenn eine Kategorieauswahl werde WMSe/Layer die keiner Kategorie zugeordnet sind nicht angezeigt
+		$i=0;
+	} else {
+		$i=1;
+	for($i; $i<count($this->cat); $i++){
+		if(count($this->cat[$i]['member'])>0){
+			$c = $this->doc->createElement("category");
+			$result->appendChild($c);
+			$c->setAttribute('name',$this->cat[$i]['md_topic_category_code_de']);
+			$c->setAttribute('count',count($this->cat[$i]['member']));
+			$this->logit("IM XML-Aufbau: category: ".$this->cat[$i]['md_topic_category_code_de'].", Anzahl: ".count($this->cat[$i]['member']));
+			for($ii=0; $ii<count($this->cat[$i]['member']); $ii++){
+// 					Schachtelung Start
+					$m = $this->doc->createElement('member');
+					$m->setAttribute('wms_id',$this->cat[$i]['member'][$ii]['wms_id']);			// Attribut muss gesetzt werden um es wieder zu finden
+					$m->setAttribute('layer_pos',$this->cat[$i]['member'][$ii]['layer_pos']);	// Attribut muss gesetzt werden um es wieder zu finden
+//					$m->setAttribute('layer_parent',$this->cat[$i]['member'][$ii]['layer_parent']);
+					if ($ii != 0){
+						$members = $c->getElementsByTagName('member');
+						$sub = "false";
+						$mem = null;
+						foreach ($members as $member) {
+							$tmp_wms_id = $member -> getAttribute('wms_id');
+							$tmp_layer_pos = $member -> getAttribute('layer_pos');
+						     * Wiederfinden des Members über die Attribute
+							if ($this->cat[$i]['member'][$ii]['wms_id'] == $tmp_wms_id){
+								if ($this->cat[$i]['member'][$ii]['layer_parent'] == $tmp_layer_pos){
+									$sub = "true";
+									$member->appendChild($m);	// dem member $member wird ein weiteres member $m hinzugefügt
+									break;
+								} else {
+									$sub = "false";
+						if ($sub == "true"){
+										     // member konnte schon in der foreach-schleife eingefuegt werden
+						} else {
+						$c->appendChild($m); // member kategorie 1	(anderer WMS)
+					} else {
+						$c->appendChild($m);	 // member kategorie 1 (erstes member)
+// 				Schachtelung Ende
+				// LayerName
+				$state = $this->doc->createElement('layername');
+				$m->appendChild($state);
+				$name = "";
+				$layname = $this->cat[$i]['member'][$ii]['layer_name'];
+				if ($layname == "NULL" || $layname == "") {
+					$name = "";
+				} else {
+					$name = $layname;
+				$lay_name_text = $this->doc->createTextNode($name);
+				$state->appendChild($lay_name_text);
+				//Abfragbarkeit
+				$queryable = $this->doc->createElement('queryable');
+				$m->appendChild($queryable);
+				if ($this->cat[$i]['member'][$ii]['layer_queryable']==1){
+					$lay_queryable = "true";
+				} else {
+					$lay_queryable = "false";
+				$abf_text = $this->doc->createTextNode($lay_queryable);
+				$queryable->appendChild($abf_text);
+				// Epsg
+				$epsg = $this->doc->createElement('epsg');
+				$m->appendChild($epsg);
+				$equalEPSG = $this->checkEPSG($this->cat[$i]['member'][$ii]['wms_id']);
+				$epsg_text = $this->doc->createTextNode($equalEPSG);
+				$epsg->appendChild($epsg_text);
+				// Länderkennung
+				$state = $this->doc->createElement('federalstate');
+				$spatialSource = "";
+				$stateorprovince = $this->cat[$i]['member'][$ii]['stateorprovince'];
+				if ($stateorprovince == "NULL" || $stateorprovince == "") {
+					$spatialSource = $this->cat[$i]['member'][$ii]['country'];
+				} else {
+					$spatialSource = $this->cat[$i]['member'][$ii]['stateorprovince'];
+				$countr_code_text = $this->doc->createTextNode($spatialSource);
+				$state->appendChild($countr_code_text);
+				// Satus des letzten Monitorings
+				$last_monitoring = $this->doc->createElement('last_monitoring');
+				$m->appendChild($last_monitoring);
+				$lastMonitoring = $this->getLastMonitoringDate($this->cat[$i]['member'][$ii]['wms_id']);
+				$last_monitoring_text = $this->doc->createTextNode($lastMonitoring);
+				$last_monitoring->appendChild($last_monitoring_text);
+				// Verfügbarkeit - Prozentzahl
+				$availability = $this->doc->createElement('availability');
+				$m->appendChild($availability);
+				$availabilityPercent = $this->getWMSavailability($this->cat[$i]['member'][$ii]['wms_id'], $this->availabilityTime);
+				$availability_text = $this->doc->createTextNode($availabilityPercent);
+				$availability->appendChild($availability_text);
+				// Relevanz / Count
+				$relevance = $this->doc->createElement('relevance');
+				$m->appendChild($relevance);
+				$lay_count=0;
+				if($this->cat[$i]['member'][$ii]['load_count'] != null){
+				$lay_count=$this->cat[$i]['member'][$ii]['load_count'];
+				$relevance_text = $this->doc->createTextNode($lay_count);
+				$relevance->appendChild($relevance_text);
+				//type
+				$type = $this->doc->createElement('type');
+				$m->appendChild($type);
+				if($this->cat[$i]['member'][$ii]['layer_pos'] > 0){
+					$ttype = $this->doc->createTextNode("layer");
+				else{
+					$ttype = $this->doc->createTextNode("wms");
+				$type->appendChild($ttype);
+				//wms_id
+				$wms__id = $this->doc->createElement('wms_id');
+				$m->appendChild($wms__id);
+				$id_text = $this->doc->createTextNode($this->cat[$i]['member'][$ii]['wms_id']);
+				$wms__id->appendChild($id_text);
+				//layer_id
+				$id = $this->doc->createElement('id');
+				$m->appendChild($id);
+				$tid = $this->doc->createTextNode($this->cat[$i]['member'][$ii]['layer_id']);
+				$id->appendChild($tid);
+				//title
+				$title = $this->doc->createElement('title');
+				$m->appendChild($title);
+				$ttitle = $this->doc->createTextNode($this->cat[$i]['member'][$ii]['layer_title']);
+				$title->appendChild($ttitle);
+				//abstract
+				$abst = $this->doc->createElement('abstract');
+				$m->appendChild($abst);
+				$tabst = $this->doc->createTextNode($this->cat[$i]['member'][$ii]['layer_abstract']);
+				$abst->appendChild($tabst);
+				// accesscontraints
+				$ac = $this->doc->createElement('accessconstraints');
+				$m->appendChild($ac);
+				$myac = $this->doc->createTextNode($this->cat[$i]['member'][$ii]['accessconstraints']);
+				$ac->appendChild($myac);
+				//data
+				$date = $this->doc->createElement('date');
+				$m->appendChild($date);
+				$tdate = $this->doc->createTextNode(date("d.m.Y",$this->cat[$i]['member'][$ii]['wms_timestamp']));
+				$date->appendChild($tdate);
+				//department
+				$dm = $this->doc->createElement('department');
+				$m->appendChild($dm);
+				$tdm = $this->doc->createTextNode($this->cat[$i]['member'][$ii]['mb_group_name']);
+				$dm->appendChild($tdm);
+				//permission // Leseberechtigung des Benutzers(true), sonst Email zur Beantragung(email)
+				$per = $this->doc->createElement('permission');
+				$m->appendChild($per);
+				$per_text = $this->getPermissionValue( $this->cat[$i]['member'][$ii]['wms_id'], $this->cat[$i]['member'][$ii]['layer_id']);
+				$pe =  $this->doc->createTextNode($per_text);
+				$per->appendChild($pe);
+				// termsofuse
+				$ter = $this->doc->createElement('termsofuse');
+				$m->appendChild($ter);
+				$myter_text = $this->getTermOfUse($this->cat[$i]['member'][$ii]['wms_id']);
+				$myter =  $this->doc->createTextNode($myter_text);
+				$ter->appendChild($myter);
+//				$this->logit("Ende member: ".$ii);
+//				echo "ende member: ".$ii."<br>";
+	function writeXmlWFSPart(){
+//		$asstr = split(" ",$this->searchtext);
+		$asstr = array();
+		$v = array();
+		$t = array();
+		$sql = "SELECT DISTINCT * from wfs_service_metadata where ";
+		$isTextSearch="false";
+		//textsearch
+			$isTextSearch="true";
+		//date condition
+			$time ="(wfs_timestamp BETWEEN ".$this->timestamp_beg." AND ".$this->timestamp_end.")";
+			$time ="(wfs_timestamp > ".$this->timestamp_beg.")";
+			$time ="(wfs_timestamp < ".$this->timestamp_end.")";
+				$txt = $this->getDepartmentBed("wfs_owner", "mb_user_department", $this->departments, "OR");
+		//featuretype_searchable condition
+			array_push($whereBedArray, "(featuretype_searchable = 1)");
+		// Creating the Where Clausel, based on a Array
+				$txt_whereBed="";
+					} else {
+						if($index>0){
+						} else {
+//				$txt_whereBed .=" AND ".$array_element;
+			//order by
+			$sql .= " ORDER BY featuretype_id ";
+//			echo "WFS-SQL:<br>".$sql."<br>";
+			$this->logit("WFS_SQL: ".$sql);
+				$c->setAttribute('name', "Geometriedienste");
+				$c->setAttribute('count', "0");
+			$i = 0;
+			while($row = db_fetch_array($res)){
+			$m->setAttribute('wfs_id', $row['wfs_id']);
+			$m->setAttribute('layer_pos', "");
+			//Abfragbarkeit
+			if ($row['featuretype_searchable'] == "1"){
+			} else {
+			$search_text = $this->doc->createTextNode($lay_queryable);
+			$queryable->appendChild($search_text);
+			// Epsg
+			$equalEPSG = $row['featuretype_srs'];
+			// Länderkennung
+			$stateorprovince = $row['administrativearea'];
+				$spatialSource = $row['country'];
+			} else {
+				$spatialSource = $row['administrativearea'];
+			//type
+			$ttype = $this->doc->createTextNode("wfs");
+//			// FeaturetypeName
+//			$state = $this->doc->createElement('name');
+//			$m->appendChild($state);
+//			$name = "";
+//			$stateorprovince = $row['featuretype_name'];
+//			if ($stateorprovince == "NULL" || $stateorprovince == "") {
+////				$name = $row[''];
+//			} else {
+//				$name = $row['featuretype_name'];
+//			$countr_code_text = $this->doc->createTextNode($name);
+//			$state->appendChild($countr_code_text);
+			//id
+			$id = $this->doc->createElement('featuretype_id');
+			$tid = $this->doc->createTextNode($row['featuretype_id']);
+			//wfs_conf_id
+			$conf_id = $this->doc->createElement('wfs_conf_id');
+			$m->appendChild($conf_id);
+			$c_id = $this->doc->createTextNode($row['wfs_conf_id']);
+			$conf_id->appendChild($c_id);
+			//title
+			$ttitle = $this->doc->createTextNode($row['wfs_conf_abstract']);
+			//title
+			//abstract
+			$tabst = $this->doc->createTextNode($row['wfs_conf_description']);
+			// Geomtype
+			$geo = $this->doc->createElement('geomtype');
+			$m->appendChild($geo);
+			$geo_text = $this->getGeoType($row['wfs_id'], $row['featuretype_id']);
+			$ge =  $this->doc->createTextNode($geo_text);
+			$geo->appendChild($ge);
+//				$myac = $this->getAccessConstraints($this->cat[$i]['member'][$ii]['wms_id'], $this->cat[$i]['member'][$ii]['accessconstraints'], $this->cat[$i]['member'][$ii]['layer_id']);
+			$myac = $this->doc->createTextNode($row['accessconstraints']);
+			//data
+			$tdate = $this->doc->createTextNode(date("d.m.Y",$row['wfs_timestamp']));
+			//department
+			$tdm = $this->doc->createTextNode($row['mb_group_name']);
+			//permission  		 Leseberechtigung des Benutzers(true), sonst Email zur Beantragung(email)
+			$per_text = $this->getPermissionValueForWFS($row['wfs_id'], $row['wfs_conf_id']);
+//			// termsofuse
+//			$ter = $this->doc->createElement('termsofuse');
+//			$m->appendChild($ter);
+////			$myter = $this->getAccessConstraints($this->cat[$i]['member'][$ii]['wms_id'], $this->cat[$i]['member'][$ii]['accessconstraints'], $this->cat[$i]['member'][$ii]['layer_id']);
+//			$myter_text = "";
+//			$myter =  $this->doc->createTextNode($myter_text);
+//			$ter->appendChild($myter);
+			$i++;
+		$c->setAttribute('count', $i);
+		$this->anz_wfs = $i;
+	function getLastMonitoringDate($wms_id){
+	$sql = "SELECT max(upload_id) as last_time, status FROM mb_monitor WHERE fkey_wms_id=$1 GROUP BY (status)";
+	$v = array($wms_id);
+	$t = array('i');
+	$c = 0;
+	$status = "";
+		$status = $row['status'];
+		$c++;
+		return $status;
+	 * Returns the availability of a WMS/Layer during a period of time
+	 * in percent
+	function getWMSavailability ($wms_id, $time_period){
+		$timestamp = time();
+		$datum = date("d.m.Y - H:i", $timestamp);
+		$last_timestamp = $timestamp - $time_period;
+		$last_date = date("d.m.Y - H:i", $last_timestamp);
+//		Vorrübergehend auskommentiert da keine aktuellen (auf Timestamp basierten) Daten vorliegen
+//		$sql = "SELECT upload_id as time, status FROM mb_monitor WHERE fkey_wms_id=$1 AND upload_id > ".$last_timestamp;
+		$sql = "SELECT upload_id as time, status FROM mb_monitor WHERE fkey_wms_id=$1";
+		$t = array('i');
+		$c = 0;
+		$positivStatus=0;
+			if ($row['status'] == "1" || $row['status'] == "0"){
+				$positivStatus++;
+			$c++;
+		$percent=0;
+		if ($c!=0){
+			$percent = ($positivStatus*100) / $c;
+		} else {
+			$percent = 0;
+		return number_format($percent,0, ",", ".") ;
+	function checkEPSG ($wms_id){
+	$sql = "SELECT wms.wms_id, wms_srs.wms_srs FROM wms, wms_srs where wms.wms_id=fkey_wms_id and wms.wms_id=$1";
+	$t = array('i');
+	$c = 0;
+	$isequal = "false";
+		$wms_epsg = $row['wms_srs.wms_srs'];
+		$c++;
+		if ($wms_epsg==$this->epsg){
+			$isequal="true";
+		return $isequal;
+	function isPermissioned() {
+	function getPermissionValue($wms_id, $lay_id){
+		$return_permission="";
+		// get permission
+		if (in_array($lay_id, $this->mylayer)){
+			$return_permission = "true";
+		} else {
+			$sql = "SELECT wms.wms_id, mb_user.mb_user_email as email FROM wms, mb_user where wms.wms_owner=mb_user.mb_user_id " .
+						"and wms.wms_id=$1";
+			$t = array('i');
+			// get email
+			$mail="";
+			$mail = $row['email'];
+			$return_permission = $mail;
+		return $return_permission;
+	function getPermissionValueForWFS($wfs_id, $wfs_conf_id){
+	// get permission
+	if (in_array($wfs_conf_id, $this->myWFSConfs)){
+	} else {
+		$sql = "SELECT wfs.wfs_id, mb_user.mb_user_email as email FROM wfs, mb_user where wfs.wfs_owner=mb_user.mb_user_id " .
+					"and wfs.wfs_id=$1";
+		$v = array($wfs_id);
+		$t = array('i');
+		// get email
+		$mail="";
+	function getTermOfUse($wms_id){
+		$return_tou_id="";
+		$sql = "SELECT wms.wms_id, wms_termsofuse.fkey_wms_id, wms_termsofuse.fkey_termsofuse_id, termsofuse.termsofuse_id as tid " .
+				"FROM wms, wms_termsofuse, termsofuse " .
+				"where wms.wms_id=wms_termsofuse.fkey_wms_id " .
+				"and wms_termsofuse.fkey_termsofuse_id=termsofuse.termsofuse_id " .
+		$t = array('i');
+		// get termsofuse_id
+		$termsofuse_id="";
+		$termsofuse_id = $row['tid'];
+//		$return_tou_id = "mapbender/php/mod_termsofuse_service.php?id=".$termsofuse_id;
+		$return_tou_id = $termsofuse_id;
+		return $return_tou_id;
+	function generateNewReaArray($result){
+		global $con;
+//		echo "func generateNewReaArray<br>";
+//		$this->search_bbox;
+//		$this->search_epsg;
+		$delColumns = array();
+		$columnsResult = array();
+		$db_epsg="";
+		$db_minx="";
+		$db_miny="";
+		$db_maxx="";
+		$db_maxy="";
+		$isIntersecting = "";
+		$anz = 0;
+		while($row = db_fetch_array($result)){
+			$status="";
+//			echo $anz.". layer_id: ".$row['layer_id'];
+			//EPSG Vergleich
+			$sql_ac = "SELECT * FROM layer_epsg WHERE fkey_layer_id = $1";
+			$v = array($row["layer_id"]);
+			$t = array('i');
+			$res_ac = db_prep_query($sql_ac, $v, $t);
+			$tra_epsg="";
+			$tra_minx="";
+			$tra_miny="";
+			$tra_maxx="";
+			$tra_maxy="";
+			$i=0;
+			while($row_ac = db_fetch_array($res_ac)){
+				if ($row_ac["epsg"]=="EPSG:4326"){ // maybe for transformation needed
+					$db_epsg=$row_ac["epsg"];
+					$db_minx=$row_ac["minx"];
+					$db_miny=$row_ac["miny"];
+					$db_maxx=$row_ac["maxx"];
+					$db_maxy=$row_ac["maxy"];
+				if ($row_ac["epsg"]==$this->search_epsg){
+//				if ($row_ac["epsg"]=="EPSG:31467"){
+					$status="match";
+					break;
+				} else {
+				$i++;
+			if ($status=="match"){
+//					echo "match<br>";
+					$temp = $this->search_bbox;
+					$isIntersecting = $this->intersect($temp[0], $temp[1], $temp[2], $temp[3], $db_minx, $db_miny, $db_maxx, $db_maxy, $this->search_epsg);
+			} else if ($status != "match" && $i>0){
+//					echo "Transformation<br>";
+//					Transformation
+					$sqlMinx = "SELECT X(transform(GeometryFromText('POINT(".$temp[0]." ".$temp[1].")',".str_replace("EPSG:","",$this->search_epsg)."), 4326)) as minx";
+					$resMinx = @pg_query($con,$sqlMinx);
+					$s_minx = pg_result($resMinx,0,"minx");
+					$sqlMiny = "SELECT Y(transform(GeometryFromText('POINT(".$temp[0]." ".$temp[1].")',".str_replace("EPSG:","",$this->search_epsg)."), 4326)) as miny";
+					$resMiny = @pg_query($con,$sqlMiny);
+					$s_miny = pg_result($resMiny,0,"miny");
+					$sqlMaxx = "SELECT X(transform(GeometryFromText('POINT(".$temp[2]." ".$temp[3].")',".str_replace("EPSG:","",$this->search_epsg)."), 4326)) as maxx";
+					$resMaxx = @pg_query($con,$sqlMaxx);
+					$s_maxx = pg_result($resMaxx,0,"maxx");
+					$sqlMaxy = "SELECT Y(transform(GeometryFromText('POINT(".$temp[2]." ".$temp[3].")',".str_replace("EPSG:","",$this->search_epsg)."), 4326)) as maxy";
+					$resMaxy = @pg_query($con,$sqlMaxy);
+					$s_maxy = pg_result($resMaxy,0,"maxy");
+					$isIntersecting = $this->intersect($s_minx, $s_miny, $s_maxx, $s_maxy, $db_minx, $db_miny, $db_maxx, $db_maxy, "EPSG:4326");
+			} else {
+//					"no intersection possible()<br>";
+					$isIntersecting="f";
+			if ($isIntersecting=="t"){
+//				Datensatz loeschen
+				array_push($columnsResult, $row);
+			$anz++;
+		return $columnsResult;
+	function intersect($s_minx, $s_miny, $s_maxx, $s_maxy, $db_minx, $db_miny, $db_maxx, $db_maxy, $epsg){
+		global $con;
+		$result="";
+		$sqlint = "SELECT intersects(envelope(geometryFROMtext('LINESTRING(".$s_minx." ".$s_miny.", ".$s_maxx." ".$s_maxy.")',".str_replace("EPSG:","",$epsg).")) " .
+								   ",envelope(geometryFROMtext('LINESTRING(".$db_minx." ".$db_miny.", ".$db_maxx." ".$db_maxy.")',".str_replace("EPSG:","",$epsg).")))";
+		$resInt = @pg_query($con,$sqlint);
+		$result = pg_result($resInt,0,"intersects");
+		return $result;
+	 * @todo is UPPER() working with mysql
+		global $con;
+		$sql = "SELECT keyword_id FROM keyword WHERE UPPER(keyword) = UPPER($1)";
+		$t = array('s');
+		$res = db_prep_query($sql,$v,$t);
+		if($row = db_fetch_array($res)){
+		else{
+			return false;
+	function getSQLBedfromArray($culumnName, $columnValues, $additionalChar){
+		$a = array();
+		$a = $columnValues;
+		$a_char = $additionalChar;
+		$colName=$culumnName;
+		$resultSql="";
+		for ($index = 0; $index < sizeof($a); $index++) {
+			$array_element = $a[$index];
+			if ($index<1){
+				$resultSql .= $colName."='".$a[$index]."'";
+			}else{
+				$resultSql .= " ".$a_char." " .$colName."='".$a[$index]."'";
+		return $resultSql;
+	function getDepartmentBed ($columnFkey, $culumnName, $columnValues, $additionalChar){
+		$a = array();
+		$resultSql = $columnFkey." in (SELECT mb_user_id FROM mb_user WHERE ";
+		for ($index = 0; $index < count($a); $index++) {
+			if ($index<1){
+			}else{
+		$resultSql .=")";
+	function getGeoType($wfs_id, $featureType_id){
+		$return_geoType="";
+		$sql = "SELECT element_type FROM wfs_element, wfs_featuretype " .
+				"where wfs_featuretype.featuretype_id=wfs_element.fkey_featuretype_id " .
+				"and element_name='the_geom'" .
+				"and wfs_featuretype.fkey_wfs_id = $1" .
+				"and wfs_element.fkey_featuretype_id=$2";
+		$v = array($wfs_id, $featureType_id);
+		// get element_type
+		$return_geoType = $row['element_type'];;
+		return $return_geoType;
Added: branches/mapbender_sld/http/classes/class_monitor.php
--- branches/mapbender_sld/http/classes/class_monitor.php	                        (rev 0)
+++ branches/mapbender_sld/http/classes/class_monitor.php	2007-11-23 13:22:46 UTC (rev 1831)
@@ -0,0 +1,478 @@
+<?php
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+require_once(dirname(__FILE__)."/../classes/class_wms.php");
+require_once(dirname(__FILE__)."/../classes/class_bbox.php");
+require_once(dirname(__FILE__)."/../../conf/mapbender.conf");
+define("MONITOR_DEFAULT_SCALE", 500000);
+define("MONITOR_IMG_WIDTH", 20);
+define("MONITOR_IMG_HEIGHT", 20);
+define("MB_RESOLUTION", 28.35);
+class Monitor {
+	 *  1 = reachable and in sync with db
+	 *  0 = reachable and out of sync with db
+	 * -1 = unreachable
+	 * -2 = monitoring in progress
+	var $result = -1;
+	 * 1  = the get map request DEFINITELY returns a valid map image
+	 * 0  = the WMS doesn't support XML error format. Who knows if the image is really a map?
+	 * -1 = the get map request doesn't return an image
+	var $returnsImage;
+	var $comment = "";
+	var $updated = "0";
+	var $supportsXMLException = false;
+	var $timestamp;
+	var $capabilitiesURL;
+	var $mapURL;
+	var $remoteXML;
+	var $localXML;
+	function __construct($wmsId, $uploadId, $autoUpdate) {
+		$this->wmsId = $wmsId;
+		$this->uploadId = $uploadId;
+		$this->autoUpdate = $autoUpdate;
+		$this->capabilitiesURL = $this->getUploadURL($this->wmsId, $this->uploadId);
+		set_time_limit(TIME_LIMIT);
+		$this->timestamp = time();
+		if ($this->capabilitiesURL) {
+			$remoteWms = new wms();
+			$remoteWms->createObjFromXML($this->capabilitiesURL);
+			$this->remoteXML = $remoteWms->wms_getcapabilities_doc;
+			$this->localXML = $this->getCapabilitiesDocByWMS($this->wmsId);
+			// service unreachable
+			if (!$this->remoteXML) {
+				$this->result = -1;
+				$this->comment = "Connection failed.";
+			 * service available;
+			 * no local copy of capabilities file,
+			 * so it has to be updated anyway
+			elseif (!$this->localXML) {
+				$this->result = 0;
+			 * check if local copy is different
+			 * to remote capabilties document
+			else {
+				 * compare to local capabilities document
+				// capabilities files match
+				if ($this->localXML == $this->remoteXML) {
+					$this->result = 1;
+					$this->comment = "WMS is stable.";
+				// capabilities files don't match
+				else {
+			 * if the WMS is available,
+			 * 1) get a map image
+			 * 2) update the local backup of the capabilities doc if necessary
+			if ($this->result != -1) {
+				$this->mapURL = $this->getMapRequest($this->wmsId);
+				if ($this->isImage($this->mapURL)) {
+					$this->returnsImage = 1;
+				else {
+					$this->returnsImage = -1;
+				 * if the local backup of the capabilities document
+				 * is deprecated, update the local backup
+				if ($this->result == 0) {
+					$mywms = new wms();
+					 * if the capabilities document is valid,
+					 * update it OR mark it as "not up to date"
+					if ($mywms->createObjFromXML($this->capabilitiesURL)) {
+						if ($this->autoUpdate) {
+							$mywms->updateObjInDB($this->wmsId);
+							$this->updated = "1";
+							$this->comment = "WMS has been updated.";
+						else {
+							$this->comment = "WMS is not up to date.";
+					// capabilities document is invalid
+					else {
+						$this->comment = "Invalid getCapabilities request/document or service exception.";
+		else {
+			$this->comment = "Invalid upload URL.";
+		$e = new mb_notice("class_monitor: constructor: result = " . $this->result);
+		$e = new mb_notice("class_monitor: constructor: comment = " . $this->comment);
+		$e = new mb_notice("class_monitor: constructor: returnsImage = " . $this->returnsImage);
+	public function __toString() {
+		$str = "";
+		$str .= "wmsid: " . $this->wmsId . "\nupload_id: " . $this->uploadId . "\n";
+		$str .= "autoupdate: " . $this->autoUpdate . "\n";
+		$str .= "result: " . $this->result . "\ncomment: " . $this->comment . "\n";
+		$str .= "timestamp: " . $this->timestamp . " (".date("F j, Y, G:i:s", $this->timestamp).")\n";
+		$str .= "getCapabilities URL: " . $this->capabilitiesURL . "\nupdated: " . $this->updated . "\n\n";
+		$str .= "getMap URL: " . $this->mapURL . "\nis image: " . $this->returnsImage . "\n\n";
+		$str .= "-------------------------------------------------------------------\n";
+		$str .= "remote XML:\n\n" . $this->remoteXML . "\n\n";
+		$str .= "local XML:\n\n" . $this->localXML . "\n\n";
+		return (string) $str;
+	 * Update database
+	function updateInDB() {
+		$sql = "UPDATE mb_monitor SET updated = $1, status = $2, image = $3, status_comment = $4, upload_url = $5, timestamp_end = $6, map_url = $7 WHERE upload_id = $8 AND fkey_wms_id = $9";
+		$v = array($this->updated, $this->result, $this->returnsImage, $this->comment, $this->capabilitiesURL, $this->timestamp, $this->mapURL, $this->uploadId, $this->wmsId);
+		$t = array('s', 'i', 'i', 's', 's', 's', 's', 's', 'i');
+	 * Checks if the mapUrl returns an image or an exception
+	private function isImage($url) {
+		$headers = get_headers($url, 1);
+		$e = new mb_notice("class_monitor: isImage: map URL is " . $url);
+		$e = new mb_notice("class_monitor: isImage: Content-Type is " . $headers["Content-Type"]);
+		if (preg_match("/xml/", $headers["Content-Type"])) {
+			return false;
+		return true;
+	 * Returns the upload url of some WMS
+	private function getUploadURL($wmsId, $upload_id) {
+		$e = new mb_notice("class_monitor: getUploadURL: wms = " . $wmsId);
+		$e = new mb_notice("class_monitor: getUploadURL: upload_id = " . $upload_id);
+		$sql = "SELECT upload_url FROM mb_monitor WHERE fkey_wms_id = $1 AND upload_id = $2";
+		$v = array($wmsId, $upload_id);
+		$someArray = db_fetch_array($res);
+		$e = new mb_notice("class_monitor: getUploadURL: url = " . $someArray["upload_url"]);
+		return $someArray["upload_url"];
+	 * Returns the character that needs to be appended to
+	 * a given online resource, in order to append other GET
+	 * parameters.
+	 * Possible characters: "?", "&", ""
+	private function mb_getConjunctionCharacter($onlineresource){
+		// index of character ? in online resource
+		$indexOfChar = mb_strpos($onlineresource,"?");
+		if($indexOfChar) {
+			// no conjunction character needed
+			if($indexOfChar == mb_strlen($onlineresource)-1){
+				return "";
+			else if (mb_substr($onlineresource, mb_strlen($onlineresource)-1) == "&") {
+				return "";
+			else{
+				return "&";
+		return "?";
+	 * retrieves all information necessary to build a map request,
+	 * concatenates them and returns a valid get map request
+	private function getMapRequest($wmsId) {
+		// get map (wms_getmap)
+		// version (wms_version)
+		$sql = "SELECT wms_getmap, wms_version FROM wms WHERE wms_id = $1";
+		$res = db_prep_query($sql, array($wmsId), array('i'));
+		$getmap = $row["wms_getmap"];
+		$version = $row["wms_version"];
+		//map format
+		$sql = "SELECT * FROM wms_format WHERE data_type = 'map' AND fkey_wms_id = $1";
+		$mapFormat = "";
+		while ($row = db_fetch_array($res)) {
+			$mapFormat = urlencode($row["data_format"]);
+			if (preg_match("/png/", $mapFormat) || preg_match("/gif/", $mapFormat) || preg_match("/jp.{1}g/", $mapFormat)) {
+				break;
+		// layers (all layers)
+		$sql = "SELECT layer_name FROM layer WHERE fkey_wms_id = $1 AND layer_parent <> '' AND layer_pos > 0";
+		$layerArray = array();
+			array_push($layerArray, urlencode($row["layer_name"]));
+		$layerList = implode(",", $layerArray);
+		// srs (layer_epsg: epsg)
+		// bbox (layer_epsg: minx, miny, maxx, maxy)
+		$sql = "SELECT epsg, minx, miny, maxx, maxy ";
+		$sql .= "FROM layer_epsg, (SELECT fkey_wms_id, layer_id FROM layer WHERE fkey_wms_id = $1 AND layer_parent = '' AND layer_pos = 0) AS l ";
+		$sql .= "WHERE l.layer_id = layer_epsg.fkey_layer_id AND l.fkey_wms_id = $1";
+		$bboxArray = array();
+			array_push($bboxArray, new Mapbender_bbox($row["minx"], $row["miny"], $row["maxx"], $row["maxy"], $row["epsg"]));
+		// get a bbox in a preferably non WGS84 epsg to use the scalehints
+		for ($i=0; $i < count($bboxArray); $i++) {
+			$bbox = $bboxArray[$i];
+			if ($bboxArray[$i]->epsg != "EPSG:4326") {
+				break;
+		 * transform to 31466 if is 4326
+		 * TODO: extend to other EPSG apart from 31466
+		if ($bbox->epsg == "EPSG:4326") {
+			$bbox->transform("EPSG:31466");
+		 * get map and check if result is image
+		// check if this WMS supports exception type XML
+		$sql = "SELECT data_format FROM wms_format WHERE fkey_wms_id = $1 AND data_type = 'exception'";
+		$v = array($wmsId);
+		$t = array('i');
+			$exceptionFormat = $row["data_format"];
+			// set the exception type to xml (if possible)
+			if (preg_match('/xml/', $exceptionFormat)) {
+				$this->supportsXMLException = true;
+				break;
+		// correct bbox according to scale
+		$scale = $this->getScaleForWMS($wmsId);
+		$bbox = $this->getBBoxInScale($bbox, $scale);
+		return $this->concatenateMapRequest($getmap, $version, $mapFormat, $layerList, $bbox, MONITOR_IMG_WIDTH, MONITOR_IMG_HEIGHT, $exceptionFormat);
+	 * updates a given BBox according to a given scale
+	 * @param bbox
+	 * @param scale
+	private function getBBoxInScale($bbox, $scale) {
+		$e = new mb_notice("class_monitor: getMapRequest: old bbox = " . $bbox);
+		$e = new mb_notice("class_monitor: getMapRequest: old bbox = " . $bbox->min->x . "," . $bbox->min->y . "," . $bbox->max->x . "," . $bbox->max->y);
+		$e = new mb_notice("class_monitor: getMapRequest: scale = " . $scale);
+		if ($scale) {
+			$center = $bbox->min->plus($bbox->max)->times(0.5);
+			$e = new mb_notice("class_monitor: getMapRequest: center = " . $center);
+			 * TODO: this formula should have documentation
+			$offset =  MONITOR_IMG_WIDTH / (MB_RESOLUTION * 100 * 2) * $scale;
+			$offsetPoint = new Mapbender_point($offset, $offset, $bbox->epsg);
+			$min = $center->minus($offsetPoint);
+			$max = $center->plus($offsetPoint);
+			$bbox->min = $min;
+			$bbox->max = $max;
+			$e = new mb_notice("class_monitor: getMapRequest: new bbox = " . $bbox);
+			$e = new mb_notice("class_monitor: getMapRequest: new bbox = " . $bbox->min->x . "," . $bbox->min->y . "," . $bbox->max->x . "," . $bbox->max->y);
+		return $bbox;
+	 * Returns an online resource representing a get map request
+	private function concatenateMapRequest(	$getmap, $wmsVersion, $mapFormat, $layerList,
+							$bbox, $width, $height, $exceptionFormat) {
+		 * getMap URL
+		$mapRequest = $getmap;
+		$mapRequest .= $this->mb_getConjunctionCharacter($getmap);
+		 * WMS version
+		if ($wmsVersion == "1.0.0") {
+			$mapRequest .= "WMTVER=" . $wmsVersion . "&REQUEST=map&";
+		else {
+			$mapRequest .= "VERSION=" . $wmsVersion . "&REQUEST=GetMap&SERVICE=WMS&";
+		 * Layer list
+		$mapRequest .= "LAYERS=" . $layerList . "&";
+		 * Format
+		 $mapRequest .= "FORMAT=" . $mapFormat . "&";
+		 * SRS and BBox
+		$mapRequest .= "SRS=" . $bbox->epsg . "&";
+		$mapRequest .= "BBOX=" . $bbox->min->x . "," . $bbox->min->y . "," . $bbox->max->x . "," . $bbox->max->y . "&";
+		 * Width and height
+		$mapRequest .= "WIDTH=" . $width . "&";
+		$mapRequest .= "HEIGHT=" . $height . "&";
+		 * BGColor
+		$mapRequest .= "BGCOLOR=0xffffff&";
+		 * Transparency
+		if (preg_match("/png/", $mapFormat) || preg_match("/gif/", $mapFormat)) {
+			$mapRequest .= "TRANSPARENT=TRUE&";
+		 * Exception format
+		$mapRequest .= "EXCEPTIONS=" . $exceptionFormat . "&";
+//		return urlencode($mapRequest);
+		return $mapRequest;
+	 * Checks if the given WMS has ScaleHints. If yes, a scale is selected and returned.
+	private function getScaleForWMS($wmsId) {
+		// get the scalehints
+		$sql = "SELECT layer_minscale, layer_maxscale FROM layer WHERE fkey_wms_id = $1 AND layer_pos = 0 AND layer_parent = '' AND layer_minscale <> layer_maxscale LIMIT 1";
+		$t = array('i');
+		$scaleHintArray = db_fetch_array($res);
+		 *  determine the scalehint
+		// if a scalehint exists
+		if ($scaleHintArray) {
+			// if upper boundary
+			if ($scaleHintArray["layer_minscale"] < $scaleHintArray["layer_maxscale"]) {
+				// TODO: find a better algorithm with a less obscure scale
+				$scaleHint = round($scaleHintArray["layer_maxscale"] - $scaleHintArray["layer_minscale"]) / 2;
+			// if lower boundary
+			else {
+				if ($scaleHintArray["layer_minscale"] < MONITOR_DEFAULT_SCALE) {
+					$scaleHint = MONITOR_DEFAULT_SCALE;
+				else {
+					$scaleHint = $scaleHintArray["layer_minscale"] + 1000;
+		// otherwise, use a default value
+		else {
+		return $scaleHint;
+	 * Returns the local backup of the given WMS' capabilities document
+	private function getCapabilitiesDocByWMS($wmsId) {
+		$sql = "SELECT wms_getcapabilities_doc FROM wms WHERE wms_id = $1";
+		$t = array('i');
+		return $someArray["wms_getcapabilities_doc"];
\ No newline at end of file
Modified: branches/mapbender_sld/http/classes/class_stripRequest.php
--- branches/mapbender_sld/http/classes/class_stripRequest.php	2007-11-23 13:20:10 UTC (rev 1830)
+++ branches/mapbender_sld/http/classes/class_stripRequest.php	2007-11-23 13:22:46 UTC (rev 1831)
@@ -37,9 +37,10 @@
 		$patterns = explode("&", $a[1]);
 		for($i=0; $i<count($patterns); $i++){
 			$tmp = explode("=", $patterns[$i]);
-			if(strtoupper($tmp[0]) == strtoupper($key)){
-				$replacement = strtoupper($key) . "=" . $value;
-				$this->url = str_replace($patterns[$i],$replacement, $this->url);
+			if(mb_strtoupper($tmp[0]) == mb_strtoupper($key)){
+				$replacement = mb_strtoupper($key) . "=" . $value;
+				$currentPattern = "/" . $patterns[$i] . "/";
+				$this->url = preg_replace($currentPattern, $replacement, $this->url);
 				$exists = true;
@@ -58,7 +59,7 @@
 				$exists = true;
 				return $tmp[1];
@@ -90,9 +91,10 @@
 				$replacement = "";
 		$this->encodeGET();
@@ -104,7 +106,7 @@
 		$a[0].= "?";
-			if(in_array(strtoupper($tmp[0]),$this->encodeParams)){
+			if(in_array(mb_strtoupper($tmp[0]),$this->encodeParams)){
 				$val = explode(",", $tmp[1]);
 				$a[0] .= $tmp[0]."=";
 				for($ii=0; $ii<count($val); $ii++){
@@ -127,7 +129,7 @@
 	function encodeLegGET(){
-		$this->url = str_replace("&amp;", "\&", $this->url);
+		$this->url = preg_replace("/&amp;/", "\&", $this->url);
 		return $this->url;
Modified: branches/mapbender_sld/http/classes/class_weldLegend2PNG.php
--- branches/mapbender_sld/http/classes/class_weldLegend2PNG.php	2007-11-23 13:20:10 UTC (rev 1830)
+++ branches/mapbender_sld/http/classes/class_weldLegend2PNG.php	2007-11-23 13:22:46 UTC (rev 1831)
@@ -95,13 +95,13 @@
 		 * @todo handle as reg-exp?
 		 * @todo instanciate $im as false or null?
-		if(strtolower($f) == 'image/png' || strtolower($f) == 'png'){
+		if(mb_strtolower($f) == 'image/png' || mb_strtolower($f) == 'png'){
 			$im = @ImageCreateFromPNG($imgurl);
-		if(strtolower($f) == 'image/jpeg' || strtolower($f) == 'jpeg'){
+		if(mb_strtolower($f) == 'image/jpeg' || mb_strtolower($f) == 'jpeg'){
 			$im = @ImageCreateFromJPEG($imgurl);
-		if(strtolower($f) == 'image/gif' || strtolower($f) == 'gif'){
+		if(mb_strtolower($f) == 'image/gif' || mb_strtolower($f) == 'gif'){
 			$im = @ImageCreateFromGIF($imgurl);
 		if(!$im){
Modified: branches/mapbender_sld/http/classes/class_weldOverview2PNG.php
--- branches/mapbender_sld/http/classes/class_weldOverview2PNG.php	2007-11-23 13:20:10 UTC (rev 1830)
+++ branches/mapbender_sld/http/classes/class_weldOverview2PNG.php	2007-11-23 13:22:46 UTC (rev 1831)
@@ -107,8 +107,6 @@
 	function loadpng ($imgurl) {
-		#ereg_replace(' ', "\%90", $imgurl);
 		$obj = new stripRequest($imgurl);
 		$x = new connector($imgurl);
Modified: branches/mapbender_sld/http/classes/class_wfs.php
--- branches/mapbender_sld/http/classes/class_wfs.php	2007-11-23 13:20:10 UTC (rev 1830)
+++ branches/mapbender_sld/http/classes/class_wfs.php	2007-11-23 13:22:46 UTC (rev 1831)
@@ -22,7 +22,10 @@
 include_once(dirname(__FILE__)."/../../conf/mapbender.conf");
-require_once(dirname(__FILE__)."/class_connector.php");
+require_once(dirname(__FILE__)."/class_connector.php");
+require_once(dirname(__FILE__)."/class_mb_exception.php");
 class wfs {
   var $wfs_id;
@@ -31,17 +34,21 @@
   var $wfs_title;
   var $wfs_abstract;
   var $wfs_getcapabilities;
+  var $wfs_getcapabilities_doc; //new SB 2007-08-09
   var $wfs_describefeaturetype;
   var $wfs_describefeaturetype_namespace = array();
   var $wfs_getfeature;
-  //neu
   var $wfs_transaction;
+  var $wfs_upload_url; //new SB 2007-08-09
+  //new WFS 1.0.0 -- SB 2007-08-06
+  var $fees;
+  var $accessconstraints;
   var $wfs_featuretype = array();
 function wfs() {
@@ -55,19 +62,28 @@
 		die;
-	# for temporary wms a id has to be created...
+	$values = null;
+	$tags = null;
+	$admin = new administration();
+	$this->wfs_getcapabilities_doc = $admin->char_encode($data);
+	$this->wfs_upload_url = $url;
+	# for temporary wfs a id has to be created...
 	$this->wfs_id = "id_" . substr(md5(rand()),0,6);
 	$parser = xml_parser_create(CHARSET);
 	xml_parser_set_option($parser,XML_OPTION_CASE_FOLDING,0);
 	xml_parser_set_option($parser,XML_OPTION_SKIP_WHITE,1);
 	xml_parser_set_option($parser,XML_OPTION_TARGET_ENCODING,CHARSET);
-	xml_parse_into_struct($parser,$data,$values,$tags);
+	xml_parse_into_struct($parser,$this->wfs_getcapabilities_doc,$values,$tags);
+	//xml_parse_into_struct($parser,$data,$values,$tags);
 	xml_parser_free($parser);
 	$section = false;
 	$request = false;
 	$featuretype_name = false;
  	$featuretype_title = false;
+ 	$featuretype_abstract = false;
  	$featuretype_srs = false;
 	foreach ($values as $element) {
@@ -79,13 +95,19 @@
 			$this->wfs_name = $element[value];
 		if(strtoupper($element[tag]) == "TITLE"  && $element[level] == '3'){
-			$this->wfs_title = $element[value];
+			$this->wfs_title = $this->stripEndlineAndCarriageReturn($element[value]);
 		if(strtoupper($element[tag]) == "ABSTRACT" && $element[level] == '3'){
-			$this->wfs_abstract = $element[value];
+			$this->wfs_abstract = $this->stripEndlineAndCarriageReturn($element[value]);
+		if(strtolower($element[tag]) == "fees"){
+			$this->fees = $element[value];
+		if(strtolower($element[tag]) == "accessconstraints"){
+			$this->accessconstraints = $element[value];
 		/*capability section*/
 		if($this->wfs_version == "1.0.0"){
@@ -137,11 +159,14 @@
 			$featuretype_name = $element[value];
 		if($section == "featuretype" && strtoupper($element[tag]) == "TITLE"){
-			$featuretype_title = $element[value];
+			$featuretype_title = $this->stripEndlineAndCarriageReturn($element[value]);
+		if($section == "featuretype" && strtoupper($element[tag]) == "ABSTRACT"){
+			$featuretype_abstract = $this->$element[value];
 		if($section == "featuretype" && strtoupper($element[tag]) == "SRS"){
 			$featuretype_srs = $element[value];
-			$this->addFeaturetype($featuretype_name,$featuretype_title,$featuretype_srs,$this->wfs_describefeaturetype,$this->wfs_version);
+			$this->addFeaturetype($featuretype_name,$featuretype_title,$featuretype_abstract,$featuretype_srs,$this->wfs_describefeaturetype,$this->wfs_version);
@@ -159,6 +184,7 @@
 		echo "<hr>";
 		echo "name: ". $this->wfs_featuretype[$i]->featuretype_name . "<br>";
 		echo "title: ". $this->wfs_featuretype[$i]->featuretype_title . "<br>";
+		echo "abstract: ". $this->wfs_featuretype[$i]->featuretype_abstract . "<br>";
 		echo "srs: ". $this->wfs_featuretype[$i]->featuretype_srs . "<br>";
 		for($j=0; $j<count($this->wfs_featuretype[$i]->featuretype_element);$j++){
 			echo " element: " . $this->wfs_featuretype[$i]->featuretype_element[$j]["name"] ." - ".$this->wfs_featuretype[$i]->featuretype_element[$j]["type"]."<br>";
@@ -168,9 +194,12 @@
-function addFeaturetype($name,$title,$srs,$url,$version){
-	$this->wfs_featuretype[count($this->wfs_featuretype)] = new featuretype($name,$title,$srs,$url,$version);
+function addFeaturetype($name,$title,$abstract,$srs,$url,$version){
+	$this->wfs_featuretype[count($this->wfs_featuretype)] = new featuretype($name,$title,$abstract,$srs,$url,$version);
+ function stripEndlineAndCarriageReturn($string) {
+	  	return preg_replace("/\n/", "", preg_replace("/\r/", " ", $string));
 function createJsObjFromWFS($parent){
 	if(!$this->wfs_title || $this->wfs_title == ""){
 		echo "alert('Error: no valid capabilities-document !!');";
@@ -194,7 +223,8 @@
 		print ("wfs_add_featuretype('".
 			$this->wfs_featuretype[$i]->featuretype_name ."','".
-			$this->wfs_featuretype[$i]->featuretype_title . "','".
+			$this->wfs_featuretype[$i]->featuretype_title . "','".
+			$this->wfs_featuretype[$i]->featuretype_abstract . "','".
 			$this->wfs_featuretype[$i]->featuretype_srs ."','".
 			$this->wfs_featuretype[$i]->featuretype_geomtype ."');");
@@ -210,169 +240,485 @@
 			print("wfs_add_featuretype_namespace('".$this->wfs_featuretype[$i]->featuretype_namespace[$j]["name"]."', '".$this->wfs_featuretype[$i]->featuretype_namespace[$j]["value"]."', ".$j.", ".$i.");");
+ * Inserts this WFS in the database
+function insertWfs() {
+	global $DBSERVER,$DB,$OWNER,$PW;
+	$con = db_connect($DBSERVER,$OWNER,$PW);
+	db_select_db($DB,$con);
+	$sql = "INSERT INTO wfs (wfs_version, wfs_name, wfs_title, wfs_abstract, ";
+	$sql .= "wfs_getcapabilities, wfs_getcapabilities_doc, wfs_upload_url, ";
+	$sql .= "wfs_describefeaturetype, wfs_getfeature, wfs_transaction, fees, ";
+	$sql .= "accessconstraints, wfs_owner, wfs_timestamp) ";
+	$sql .= "VALUES($1,$2,$3,$4,$5,$6,$7,$8,$9,$10,$11,$12,$13,$14)";
+	$v = array($this->wfs_version, $this->wfs_name, $this->wfs_title,
+		$this->wfs_abstract, $this->wfs_getcapabilities, $this->wfs_getcapabilities_doc,
+		$this->wfs_upload_url, $this->wfs_describefeaturetype, $this->wfs_getfeature,
+		$this->wfs_transaction, $this->fees, $this->accessconstraints,
+		$_SESSION["mb_user_id"], strtotime("now"));
+	$t = array('s', 's', 's', 's', 's', 's', 's', 's', 's', 's', 's', 's', 'i', 'i');
+	if(!$res){
+		db_rollback();
+		$e = new mb_exception("Error while saving WFS to DB. Rollback performed.");
+		return false;
+	$this->wfs_id = db_insert_id($con,'wfs','wfs_id');
+	return true;
+function updateWfs() {
+	$sql = "UPDATE wfs SET wfs_version = $1, wfs_name = $2, wfs_title = $3, ";
+	$sql .= "wfs_abstract = $4, wfs_getcapabilities = $5, wfs_getcapabilities_doc = $6, ";
+	$sql .= "wfs_upload_url = $7, wfs_describefeaturetype = $8, wfs_getfeature = $9, ";
+	$sql .= "wfs_transaction = $10, fees = $11, accessconstraints = $12, wfs_owner = $13, ";
+	$sql .= "wfs_timestamp = $14 ";
+	$sql .= "WHERE wfs_id = $15";
+	//echo $sql."<br />";
+	$v = array($this->wfs_version, $this->wfs_name, $this->wfs_title, $this->wfs_abstract,
+		$this->wfs_getcapabilities, $this->wfs_getcapabilities_doc, $this->wfs_upload_url,
+		$this->wfs_describefeaturetype, $this->wfs_getfeature, $this->wfs_transaction,
+		$this->fees, $this->accessconstraints, $_SESSION["mb_user_id"],strtotime("now"),
+		$this->wfs_id);
+	$t = array('s', 's', 's', 's', 's', 's', 's', 's' ,'s' ,'s' ,'s' ,'s' ,'i' ,'i' ,'i');
+	if(!$res){
+		db_rollback();
+		return false;
+	return true;
 * wfs2db
-* this function exports the information from the xml to the mapbender database
+* this function saves the class information to the mapbender database
+* @return boolean true if sucessful false otherwise
 function wfs2db($gui_id){
-	# TABLE wfs
-	$sql = "INSERT INTO wfs (wfs_version, wfs_name, wfs_title, wfs_abstract, wfs_getcapabilities, wfs_describefeaturetype, wfs_getfeature, wfs_transaction) ";
-	$sql .= "VALUES(";
-		$sql .= "'" . $this->wfs_version ."', ";
-		$sql .= "'" . db_escape_string(str_replace("'","",$this->wfs_name)) ."', ";
-		$sql .= "'" . db_escape_string(str_replace("'","",$this->wfs_title)) ."', ";
-		$sql .= "'" . db_escape_string(str_replace("'","",$this->wfs_abstract)) .  "', ";
-		$sql .= "'" . $this->wfs_getcapabilities ."', ";
-		$sql .= "'" . $this->wfs_describefeaturetype . "', ";
-		$sql .= "'". $this->wfs_getfeature . "', ";
-		$sql .= "'". $this->wfs_transaction . "'";
-	$sql .= ");";
-	#echo "sql wfs: <br>".$sql;
+	db_begin();
-	$res = db_query($sql)or die(db_error());
+	// check if WFS already might exists (it might exist when wfs_id is numeric)
+	$wfs_exists = is_numeric($this->wfs_id);
+	// if it might exist, update it
+	if ($wfs_exists) {
+		// but check first if it really exists in the database
+		$sql = "SELECT * FROM wfs WHERE wfs_id = ".$this->wfs_id.";";
+		$res = db_query($sql);
+		if($res){
+			$this->updateWfs();
+		// if not, insert as new WFS
+		else {
+			$this->insertWfs();
+	// if it does not exist, insert as new WFS
+	else {
+	# delete featuretypes from DB that does not exist and find the ids
+	$sql = "SELECT * FROM wfs_featuretype WHERE fkey_wfs_id = ".$this->wfs_id.";";
+	$res_ft = db_query($sql);
+	$cnt = 0;
+	while(db_fetch_row($res_ft)){
+		$found = false;
+		for($i=0; $i<count($this->wfs_featuretype); $i++){
+			if($this->wfs_featuretype[$i]->featuretype_name == db_result($res_ft, $cnt, "featuretype_name")){
+				$this->wfs_featuretype[$i]->featuretype_id = db_result($res_ft, $cnt, "featuretype_id");
+				$found = true;
+				break;
+		if(!$found){
+			$sql = "DELETE FROM wfs_featuretype WHERE featuretype_id = $1 AND fkey_wfs_id = $2";
+			$v = array(db_result($res_ft, $cnt, "featuretype_id"), $this->wfs_id);
+			$t = array('i','i');
+			if(!$res){db_rollback();$e = new mb_exception("Error while saving WFS to DB. Rollback performed.");return;}
+		$cnt++;
-	$myWFS = db_insert_id($con,'wfs','wfs_id');
-	#echo "<br> myWFS: ".$myWFS;
 	# TABLE wfs_featuretype
-		$sql = "INSERT INTO wfs_featuretype(fkey_wfs_id, featuretype_name, featuretype_title, featuretype_srs) ";
-			$sql .= $myWFS . ",";
-			$sql .= "'".$this->wfs_featuretype[$i]->featuretype_name . "',";
-			$sql .= "'".$this->wfs_featuretype[$i]->featuretype_title."',";
-			$sql .= "'".$this->wfs_featuretype[$i]->featuretype_srs."'";
-		$sql .= ")";
+		if(!$this->wfs_featuretype[$i]->featuretype_id){
+			$sql = "INSERT INTO wfs_featuretype(fkey_wfs_id, featuretype_name, featuretype_title, featuretype_abstract, featuretype_srs) ";
+			$sql .= "VALUES($1,$2,$3,$4,$5)";
+			$v = array($this->wfs_id,$this->wfs_featuretype[$i]->featuretype_name,$this->wfs_featuretype[$i]->featuretype_title,$this->wfs_featuretype[$i]->featuretype_abstract,$this->wfs_featuretype[$i]->featuretype_srs);
+			$t = array('i','s','s','s','s');
+			# save the id of each featuretype:
+			$this->wfs_featuretype[$i]->featuretype_id = db_insert_id($con,'wfs_featuretype','featuretype_id');
+		else{
+			$sql = "UPDATE wfs_featuretype SET ";
+			$sql .= "featuretype_title = $1,";
+			$sql .= "featuretype_abstract = $2,";
+			$sql .= "featuretype_srs = $3 ";
+			$sql .= "WHERE featuretype_id = $4";
+			$v = array($this->wfs_featuretype[$i]->featuretype_title,$this->wfs_featuretype[$i]->featuretype_abstract,$this->wfs_featuretype[$i]->featuretype_srs,$this->wfs_featuretype[$i]->featuretype_id);
+			$t = array('s','s','s','i');
-		#$res = mysql_query($sql) or $this->cleanDB($myWFS,$sql);
-		$res = db_query($sql) or $this->cleanDB($myWFS,$sql);
+		//delete featuretype elements from db and find the ids
+		$sql = "SELECT * FROM wfs_element WHERE fkey_featuretype_id = ".$this->wfs_featuretype[$i]->featuretype_id.";";
+		$res_el = db_query($sql);
+		$cnt = 0;
+		while(db_fetch_row($res_el)){
+			$found = false;
+			for($j=0; $j<count($this->wfs_featuretype[$i]->featuretype_element); $j++){
+				if($this->wfs_featuretype[$i]->featuretype_element[$j]["name"] == db_result($res_el, $cnt, "element_name")){
+					$this->wfs_featuretype[$i]->featuretype_element[$j]["id"] = db_result($res_el, $cnt, "element_id");
+					$found = true;
+					break;
+			if(!$found){
+				$sql = "DELETE FROM wfs_element WHERE element_id = $1 AND fkey_featuretype_id = $2";
+				$v = array(mysql_result($res_el, $cnt, "element_id"), $this->wfs_featuretype[$i]->featuretype_id);
+			$cnt++;
-		# save the id of each featuretype:
-		$this->wfs_featuretype[$i]->mysql_id = db_insert_id($con,'wfs_featuretype','featuretype_id');
-			$sql = "INSERT INTO wfs_element(fkey_featuretype_id, element_name,element_type) ";
-			$sql .= "'" .$this->wfs_featuretype[$i]->mysql_id. "', ";
-			$sql .= "'" .$this->wfs_featuretype[$i]->featuretype_element[$j]["name"]. "', ";
-			$sql .= "'" .$this->wfs_featuretype[$i]->featuretype_element[$j]["type"]. "' ";
-			$sql .= ")";
+			if(!$this->wfs_featuretype[$i]->featuretype_element[$j]["id"]){
+				$sql = "INSERT INTO wfs_element(fkey_featuretype_id, element_name,element_type) ";
+				$sql .= "VALUES(";
+				$sql .= "'" .$this->wfs_featuretype[$i]->featuretype_id. "', ";
+				$sql .= "'" .$this->wfs_featuretype[$i]->featuretype_element[$j]["name"]. "', ";
+				$sql .= "'" .$this->wfs_featuretype[$i]->featuretype_element[$j]["type"]. "' ";
+				$sql .= ");";
+			else{
+				$sql = "UPDATE wfs_element SET element_type = '".$this->wfs_featuretype[$i]->featuretype_element[$j]["type"]."' ";
+				$sql .= "WHERE element_id = ".$this->wfs_featuretype[$i]->featuretype_element[$j]["id"]." AND ";
+				$sql .= "fkey_featuretype_id = ".$this->wfs_featuretype[$i]->featuretype_id.";";
+		$sql = "DELETE FROM wfs_featuretype_namespace WHERE ";
+		$sql .= "fkey_wfs_id = ".$this->wfs_id." AND ";
 		for($j=0; $j<count($this->wfs_featuretype[$i]->featuretype_namespace);$j++){
 			$sql = "INSERT INTO wfs_featuretype_namespace(fkey_wfs_id, fkey_featuretype_id, namespace, namespace_location) ";
 			$sql .= "VALUES(";
-			$sql .= "'" .$myWFS. "',";
+			$sql .= "'" .$this->wfs_id. "',";
 			$sql .= "'" .$this->wfs_featuretype[$i]->featuretype_namespace[$j]["name"]. "', ";
 			$sql .= "'" .$this->wfs_featuretype[$i]->featuretype_namespace[$j]["value"]. "' ";
-			$sql .= ")";
+			$sql .= ");";
 	# TABLE gui_wfs
-	$sql ="INSERT INTO gui_wfs (fkey_gui_id, fkey_wfs_id)";
-		$sql .= "'" . $gui_id . "', ";
-		$sql .= $myWFS;
-	$sql .= ");";
+	if($gui_id){
+		$sql ="INSERT INTO gui_wfs (fkey_gui_id, fkey_wfs_id)";
+			$sql .= "'" . $gui_id . "', ";
+			$sql .= $this->wfs_id;
+		$sql .= ");";
+	//echo "Successfully saved!<br />";
+	db_commit();
+	return true;
-function cleanDB($wfsid,$sql){
-	global $DBSERVER,$DB,$OWNER,$PW;
-	$con = db_connect($DBSERVER,$OWNER,$PW);
-	db_select_db($DB,$con);
-	$s = "DELETE FROM wfs WHERE wfs_id = ".$wfsid;
-	$res = db_query($s);
-	echo "<br>Error in :".$sql."<br>";
-	echo "<br>Db cleaned.<br>";
-	die;
+* updateObjFromXML
+* this function regets the information from the xml (update)
+* @return boolean true if successful, false otherwise
+function updateObjFromXML($url){
+	$x = new connector($url);
+	$data = $x->file;
+	#$data = implode("",file($url));
+	if(!$data){
+		$e = new mb_exception("Unable to open document: ".$url);
+		return false;
+	$values = null;
+	$tags = null;
+	$this->wfs_featuretype = array();
+	//$this->wfs_id = "id_" . substr(md5(rand()),0,6);
+	$parser = xml_parser_create(CHARSET);
+	xml_parser_set_option($parser,XML_OPTION_CASE_FOLDING,0);
+	xml_parser_set_option($parser,XML_OPTION_SKIP_WHITE,1);
+	xml_parser_set_option($parser,XML_OPTION_TARGET_ENCODING,CHARSET);
+	xml_parser_free($parser);
+	$section = false;
+	$request = false;
+	$featuretype_name = false;
+ 	$featuretype_title = false;
+ 	$featuretype_srs = false;
+	foreach ($values as $element) {
+		if(strtoupper($element[tag]) == "WFS_CAPABILITIES" && $element[type] == "open"){
+			$this->wfs_version = $element[attributes][version];
+		if(strtoupper($element[tag]) == "NAME"  && $element[level] == '3'){
+			$this->wfs_name = $element[value];
+/*		if(strtoupper($element[tag]) == "TITLE"  && $element[level] == '3'){
+		if(strtoupper($element[tag]) == "ABSTRACT" && $element[level] == '3'){
+		/*capability section*/
+		if($this->wfs_version == "1.0.0"){
+			# getCapabilities
+			if(strtoupper($element[tag]) == "GETCAPABILITIES" && $element[type] == "open"){
+				$section = "getcapabilities";
+			if($section == "getcapabilities" && strtoupper($element[tag]) == "GET"){
+				$this->wfs_getcapabilities = $element[attributes][onlineResource];
+			# descriptFeatureType
+			if(strtoupper($element[tag]) == "DESCRIBEFEATURETYPE" && $element[type] == "open"){
+				$section = "describefeaturetype";
+				$this->wfs_describefeaturetype = $element[attributes][onlineResource];
+			if($section == "describefeaturetype" && strtoupper($element[tag]) == "GET"){
+			# getFeature
+			if(strtoupper($element[tag]) == "GETFEATURE" && $element[type] == "open"){
+				$section = "getfeature";
+			if($section == "getfeature" && strtoupper($element[tag]) == "GET"){
+				$this->wfs_getfeature = $element[attributes][onlineResource];
+			if(strtoupper($element[tag]) == "GETFEATURE" && $element[type] == "close"){
+				$section = "";
+			# transaction
+			if(strtoupper($element[tag]) == "TRANSACTION" && $element[type] == "open"){
+				$section = "transaction";
+			if($section == "transaction" && strtoupper($element[tag]) == "GET"){
+				$this->wfs_transaction = $element[attributes][onlineResource];
+			if(strtoupper($element[tag]) == "TRANSACTION" && $element[type] == "close"){
+				$section = "";
+		if(strtoupper($element[tag]) == "FEATURETYPE" && $element[type] == "open"){
+			$section = "featuretype";
+		if($section == "featuretype" && strtoupper($element[tag]) == "NAME"){
+			$featuretype_name = $element[value];
+		if($section == "featuretype" && strtoupper($element[tag]) == "TITLE"){
+		if($section == "featuretype" && strtoupper($element[tag]) == "SRS"){
+			$featuretype_srs = $element[value];
+	return true;
 * creatObjfromDB
+* this function fills the object with wfs information from db
+* @param int the id of wfs to get the information from
-function createObjFromDB________($wfs_id){
-	global $server,$db,$owner,$pw;
-	$con = mysql_connect($server,$owner,$pw);
-	mysql_select_db($db, $con);
+function createObjFromDB($wfs_id){
 	$sql = "SELECT * FROM wfs WHERE wfs_id = ".$wfs_id.";";
-	$res = mysql_query($sql);
 	$cnt = 0;
-	while(mysql_fetch_row($res)){
-		$this->wfs_id = mysql_result($res, $cnt, "wfs_id");
-		$this->wfs_version = mysql_result($res, $cnt, "wfs_version");
-		$this->wfs_title = mysql_result($res, $cnt, "wfs_title");
-		$this->wfs_abstract = mysql_result($res, $cnt, "wfs_abstract");
-		$this->wfs_getcapabilities = mysql_result($res, $cnt, "wfs_getcapabilities");
-		$this->wfs_describefeaturetype = mysql_result($res, $cnt, "wfs_describefeaturetype");
+	while(db_fetch_row($res)){
+		$this->wfs_id = db_result($res, $cnt, "wfs_id");
+		$this->wfs_version = db_result($res, $cnt, "wfs_version");
+		$this->wfs_name = db_result($res, $cnt, "wfs_name");
+		$this->wfs_title = db_result($res, $cnt, "wfs_title");
+		$this->wfs_abstract = db_result($res, $cnt, "wfs_abstract");
+		$this->wfs_getcapabilities = db_result($res, $cnt, "wfs_getcapabilities");
+		$this->wfs_getcapabilities_doc = db_result($res, $cnt, "wfs_getcapabilities_doc");
+		$this->wfs_upload_url = db_result($res, $cnt, "wfs_upload_url");
+		$this->wfs_describefeaturetype = db_result($res, $cnt, "wfs_describefeaturetype");
+		$this->wfs_getfeature = db_result($res, $cnt, "wfs_getfeature");
+		$this->wfs_transaction = db_result($res, $cnt, "wfs_transaction");
+		$this->fees = db_result($res, $cnt, "fees");
+		$this->accessconstraints = db_result($res, $cnt, "accessconstraints");
+		$this->wfs_owner = db_result($res, $cnt, "wfs_owner");
+		$this->wfs_timestamp = db_result($res, $cnt, "wfs_timestamp");
-		$sql_fe = "SELECT * FROM wfs_featuretype WHERE fkey_wfs_id = " . $this->wfs_id . " ORDER BY featuretype_id";
-		$res_fe = mysql_query($sql_fe);
+		$sql_fe = "SELECT * FROM wfs_featuretype WHERE fkey_wfs_id = '" . $this->wfs_id . "' ORDER BY featuretype_id";
+		$res_fe = db_query($sql_fe);
 		$cnt_fe = 0;
-		while(mysql_fetch_row($res_fe)){
+		while(db_fetch_row($res_fe)){
 			$c = count($this->wfs_featuretype);
-			$this->wfs_featuretype[$c]->featuretype_name = mysql_result($res_fe, $cnt_fe, "featuretype_name");
-			$this->wfs_featuretype[$c]->featuretype_title = mysql_result($res_fe, $cnt_fe, "featuretype_title");
-			$this->wfs_featuretype[$c]->featuretype_srs = mysql_result($res_fe, $cnt_fe, "featuretype_srs");
-			$this->wfs_featuretype[$c]->featuretype_geomtype = mysql_result($res_fe, $cnt_fe, "featuretype_geomtype");
+//			$this->wfs_featuretype[$c]->featuretype_id = db_result($res_fe, $cnt_fe, "featuretype_id");
+			$this->wfs_featuretype[$c]->featuretype_name = db_result($res_fe, $cnt_fe, "featuretype_name");
+			$this->wfs_featuretype[$c]->featuretype_title = db_result($res_fe, $cnt_fe, "featuretype_title");
+			$this->wfs_featuretype[$c]->featuretype_abstract = db_result($res_fe, $cnt_fe, "featuretype_abstract");
+			$this->wfs_featuretype[$c]->featuretype_srs = db_result($res_fe, $cnt_fe, "featuretype_srs");
-			$sql_el = "SELECT * FROM wfs_element WHERE fkey_featuretype_id = ". mysql_result($res_fe, $cnt_fe, "featuretype_id")." ORDER BY element_id";
-			$res_el = mysql_query($sql_el);
+			$sql_el = "SELECT * FROM wfs_element WHERE fkey_featuretype_id = ". db_result($res_fe, $cnt_fe, "featuretype_id")." ORDER BY element_id";
+			$res_el = db_query($sql_el);
 			$cnt_el = 0;
-			while(mysql_fetch_row($res_el)){
 				$z = count($this->wfs_featuretype[$c]->featuretype_element);
-				$this->wfs_featuretype[$c]->featuretype_element[$z]["name"] = mysql_result($res_el, $cnt_el, "element_name");
-				$this->wfs_featuretype[$c]->featuretype_element[$z]["type"] = mysql_result($res_el, $cnt_el, "element_type");
+				$this->wfs_featuretype[$c]->featuretype_element[$z]["name"] = db_result($res_el, $cnt_el, "element_name");
+				$this->wfs_featuretype[$c]->featuretype_element[$z]["type"] = db_result($res_el, $cnt_el, "element_type");
 				$cnt_el++;
-			$sql_el = "SELECT * FROM wfs_featuretype_namespace WHERE fkey_featuretype_id = ". mysql_result($res_fe, $cnt_fe, "featuretype_id")." ORDER BY namespace";
-			$cnt_el = 0;
+			$sql_ns = "SELECT * FROM wfs_featuretype_namespace WHERE fkey_featuretype_id = ". db_result($res_fe, $cnt_fe, "featuretype_id")." ORDER BY namespace";
+			$res_ns = db_query($sql_ns);
+			$cnt_ns = 0;
+			while(db_fetch_row($res_ns)){
 				$z = count($this->wfs_featuretype[$c]->featuretype_namespace);
-				$this->wfs_featuretype[$c]->featuretype_namespace[$z]["name"] = mysql_result($res_el, $cnt_el, "namespace");
-				$this->wfs_featuretype[$c]->featuretype_namespace[$z]["value"] = mysql_result($res_el, $cnt_el, "namespace_location");
-				$cnt_el++;
+				$this->wfs_featuretype[$c]->featuretype_namespace[$z]["name"] = db_result($res_ns, $cnt_ns, "namespace");
+				$this->wfs_featuretype[$c]->featuretype_namespace[$z]["value"] = db_result($res_ns, $cnt_ns, "namespace_location");
+				$cnt_ns++;
 			$cnt_fe++;
 		$cnt++;
 /** end createObjfromDB **/
+	public function getallwfs($userid){
+		$this->wfs_id = array();
+		$this->wfs_name = array();
+		$this->wfs_title = array();
+		$this->wfs_abstract = array();
+		if($userid){
+		 	$sql = "SELECT * FROM wfs WHERE wfs_owner = $1";
+			$v = array($userid);
+			$t = array('i');
+		else{
+		 	$sql = "SELECT * FROM wfs";
+		$cnt = 0;
+		while ($row = db_fetch_array($res)){
+			$this->wfs_version[$cnt] = $row["wfs_version"];
+			$this->wfs_id[$cnt] = $row["wfs_id"];
+			$this->wfs_name[$cnt] = $row["wfs_name"];
+			$this->wfs_title[$cnt] = $row["wfs_title"];
+			$this->wfs_abstract[$cnt] = $row["wfs_abstract"];
+			$this->wfs_getcapabilities[$cnt] = $row["wfs_getcapabilities"];
+			$this->wfs_describefeaturetype[$cnt] = $row["wfs_describefeaturetype"];
+			$this->wfs_getfeature[$cnt] = $row["wfs_getfeature"];
+			$cnt++;
 class featuretype extends wfs{
 	var $featuretype_element = array();
 	var $featuretype_namespace = array();
-	function featuretype($name,$title,$srs,$url,$version){
+	function featuretype($name,$title,$abstract,$srs,$url,$version){
 		$url .= "&SERVICE=WFS&VERSION=".$version."&REQUEST=DescribeFeatureType&TYPENAME=".$name;
 		$this->featuretype_name = $name;
 		$this->featuretype_title = $title;
+		$this->featuretype_abstract = $abstract;
 		$this->featuretype_srs = $srs;
@@ -385,7 +731,7 @@
 			if($this->sepNameSpace($element[tag]) == "schema" && $element[type] == "open"){
 				$section = "namespace";
-				echo "namespace<br>";
+//				echo "namespace<br>";
 			if($section == "namespace"){
@@ -401,7 +747,7 @@
 						if ($match == false) {
 							$this->featuretype_namespace[$cnt]["name"] = $this->sepNameSpace($k);
 							$this->featuretype_namespace[$cnt]["value"] = $val;
-							echo "namespace: " . $this->sepNameSpace($k) . " -> " . $val . "<br>";
+//							echo "namespace: " . $this->sepNameSpace($k) . " -> " . $val . "<br>";
@@ -411,20 +757,14 @@
 			if($this->sepNameSpace($element[tag]) == "complexContent" && $element[type] == "open"){
 				$section = "complexcontent";
-				echo "complexcontent<br>";
+//				echo "complexcontent<br>";
 			if($section == "complexcontent" && $this->sepNameSpace($element[tag]) == "element" && $element[attributes][name]){
 				$cnt = count($this->featuretype_element);
 				$this->featuretype_element[$cnt]["name"] = $element[attributes]["name"];
-				if (array_key_exists("type", $element[attributes])) {
-					$this->featuretype_element[$cnt]["type"] = $this->sepNameSpace($element[attributes]["type"]);
-				echo "element: ".$this->featuretype_element[$cnt]["name"]."<br>";
+				$this->featuretype_element[$cnt]["type"] = $this->sepNameSpace($element[attributes]["type"]);
+//				echo "element: ".$this->featuretype_element[$cnt]["name"]."<br>";
-			if($section == "complexcontent" && $this->sepNameSpace($element[tag]) == "restriction" && $element[attributes][base]){
-				$this->featuretype_element[$cnt]["type"] = $this->sepNameSpace($element[attributes]["base"]);
 			if($this->sepNameSpace($element[tag]) == "complexContent" && $element[type] == "close"){
 				$section = "";
Modified: branches/mapbender_sld/http/classes/class_wfs_conf.php
--- branches/mapbender_sld/http/classes/class_wfs_conf.php	2007-11-23 13:20:10 UTC (rev 1830)
+++ branches/mapbender_sld/http/classes/class_wfs_conf.php	2007-11-23 13:22:46 UTC (rev 1831)
@@ -17,6 +17,195 @@
+require_once(dirname(__FILE__)."/class_administration.php");
+require_once(dirname(__FILE__)."/../extensions/JSON.php");
+class WfsConf {
+	var $confArray = array();
+	 * Gets the configuration from the database
+	function __construct () {
+	public function load ($idOrIdArray) {
+		 * Check parameter and set idArray
+		if (isset($idOrIdArray)){
+			// parameter is a number
+			if (!is_array($idOrIdArray) && is_numeric($idOrIdArray)) {
+				$this->getWfsConfFromDB(array(intval($idOrIdArray)), $_SESSION["mb_user_id"]);
+			// parameter is an array of numbers
+			else if (is_array($idOrIdArray)) {
+				$idArray = array();
+				for ($i=0; $i < count($idOrIdArray); $i++) {
+					if (!is_numeric($idOrIdArray[$i])) {
+						$e = new mb_exception("Wfs_conf: constructor: wrong parameter: ".$idOrIdArray[$i]." is not a number.");
+						return null;
+					array_push($idArray, intval($idOrIdArray[$i]));
+				$this->getWfsConfFromDB($idArray, $_SESSION["mb_user_id"]);
+			// parameter is invalid
+			else {
+				$e = new mb_exception("Wfs_conf: constructor: parameter must be number or an array of numbers.");
+				return null;
+		else {
+			$e = new mb_exception("Wfs_conf: constructor: parameter is not valid");
+	 * get WFS conf data from database
+	private function getWfsConfFromDB ($idArray, $userId) {
+		 * If a user ID is given, remove the ones the user has no access to
+		if ($userId) {
+			$idArray = array_intersect($idArray, WfsConf::getWfsConfByPermission($userId));
+		if (count($idArray) > 0) {
+			 * Get WFS configurations
+			$sql = "SELECT * FROM wfs_conf ";
+			$sql .= "JOIN wfs ON wfs_conf.fkey_wfs_id = wfs.wfs_id ";
+			$sql .= "WHERE wfs_conf.wfs_conf_id IN (";
+			$v = array();
+			$t = array();
+			for ($i = 0; $i < count($idArray); $i++) {
+				if ($i > 0) {$sql .= ", ";}
+				$sql .= "$" . ($i+1);
+				array_push($v, $idArray[$i]);
+				array_push($t, 'i');
+			$sql .= ")";
+			$res = db_prep_query($sql, $v, $t);
+				 * Get WFS conf elements
+				$id = $row["wfs_conf_id"];
+				$sql_conf_element = "SELECT * FROM wfs_conf_element ";
+				$sql_conf_element .= "JOIN wfs_element ON wfs_conf_element.f_id = wfs_element.element_id ";
+				$sql_conf_element .= "WHERE wfs_conf_element.fkey_wfs_conf_id = $1 ";
+#filtered on client side
+#				$sql_conf_element .= "AND wfs_conf_element.f_search = 1 ";
+				$sql_conf_element .= "ORDER BY wfs_conf_element.f_pos";
+				$v_conf_element = array($id);
+				$t_conf_element = array('i');
+				$res_conf_element = db_prep_query($sql_conf_element, $v_conf_element, $t_conf_element);
+				$elementArray = array();
+				while ($row_conf_element = db_fetch_array($res_conf_element)) {
+					$currentElement = array("f_search" => $row_conf_element["f_search"],
+											"f_style_id" => $row_conf_element["f_style_id"],
+											"f_toupper" => $row_conf_element["f_toupper"],
+											"f_label" => $row_conf_element["f_label"],
+											"f_label_id" => $row_conf_element["f_label_id"],
+											"f_geom" => $row_conf_element["f_geom"],
+											"element_name" => $row_conf_element["element_name"],
+											"element_type" => $row_conf_element["element_type"]
+					array_push($elementArray, $currentElement);
+				 * Get WFS featuretype
+				$sql_feature_type = "SELECT * FROM wfs_featuretype WHERE fkey_wfs_id = $1 AND featuretype_id = $2";
+				$v_feature_type = array($row["fkey_wfs_id"], $row["fkey_featuretype_id"]);
+				$t_feature_type = array("i", "i");
+				$res_feature_type = db_prep_query($sql_feature_type, $v_feature_type, $t_feature_type);
+				if($row_feature_type = db_fetch_array($res_feature_type)){
+					$featuretype_name  = $row_feature_type["featuretype_name"];
+					$featuretype_srs  = $row_feature_type["featuretype_srs"];
+				$currentRow = array("g_label" => $row["g_label"],
+			                        "g_label_id" => $row["g_label_id"],
+									"g_style" => $row["g_style"],
+									"g_button" => $row["g_button"],
+									"g_button_id" => $row["g_button_id"],
+									"g_buffer" => $row["g_buffer"],
+									"g_res_style" => $row["g_res_style"],
+									"g_use_wzgraphics" => $row["g_use_wzgraphics"],
+									"wfs_id" => $row["fkey_wfs_id"],
+									"featuretype_id" => $row["fkey_featuretype_id"],
+									"featuretype_name" => $featuretype_name,
+									"featuretype_id" => $featuretype_srs,
+									"wfs_getfeature" => $row["wfs_getfeature"],
+									"element" => $elementArray
+				$this->confArray[$id] = $currentRow;
+		else {
+			$e = new mb_warning("class_wfs_conf.php: getWfsConfFromDB: You don't have access to any WFS confs. Check EDIT WFS.");
+	/** identifies the Conf-FeatureServices where the current user is owner
+	 * @param integer userid the user-ID of the current user
+	 * @return integer[] the IDs of the wfs_conf-table
+	public static function getWfsConfByPermission($userid){
+	 	$guisByPer = array();
+//	 	1.
+		$adm = new administration();
+	 	$guisByPer = $adm->getGuisByPermission($userid, true);
+//	 	2.
+		if(count($guisByPer)>0){
+			$v = array();
+			$t = array();
+			$sql = "SELECT wfs_conf.wfs_conf_id  FROM gui_wfs_conf, wfs_conf " .
+					"where wfs_conf.wfs_conf_id = gui_wfs_conf.fkey_wfs_conf_id " .
+					"and gui_wfs_conf.fkey_gui_id IN(";
+			for($i=0; $i<count($guisByPer); $i++){
+				if($i>0){ $sql .= ",";}
+				$sql .= "$".strval($i+1);
+				array_push($v, $guisByPer[$i]);
+				array_push($t, "s");
+			$sql .= ") GROUP BY wfs_conf.wfs_conf_id ORDER BY wfs_conf.wfs_conf_id";
+			$ownWFSconfs = array();
+			$i=0;
+				$ownWFSconfs[$i] = $row['wfs_conf_id'];
+				$i++;
+		return $ownWFSconfs;
 class wfs_conf{
 	var $wfs_id;
@@ -31,30 +220,7 @@
 	var $elements;
 	var $namespaces;
-	function getallwfs(){
-		$this->wfs_id = array();
-		$this->wfs_name = array();
-		$this->wfs_title = array();
-		$this->wfs_abstract = array();
-		$sql = "SELECT * FROM wfs"; // include permission handling
-		$res = db_query($sql);
-		$cnt = 0;
-		while ($row = db_fetch_array($res)){
-			$this->wfs_version[$cnt] = $row["wfs_version"];
-			$this->wfs_id[$cnt] = $row["wfs_id"];
-			$this->wfs_name[$cnt] = $row["wfs_name"];
-			$this->wfs_title[$cnt] = $row["wfs_title"];
-			$this->wfs_abstract[$cnt] = $row["wfs_abstract"];
-			$this->wfs_getcapabilities[$cnt] = $row["wfs_getcapabilities"];
-			$this->wfs_describefeaturetype[$cnt] = $row["wfs_describefeaturetype"];
-			$this->wfs_getfeature[$cnt] = $row["wfs_getfeature"];
-			$cnt++;
 	function getfeatures($wfsid){
 		$this->features = new features($wfsid);
Modified: branches/mapbender_sld/http/classes/class_wmc.php
--- branches/mapbender_sld/http/classes/class_wmc.php	2007-11-23 13:20:10 UTC (rev 1830)
+++ branches/mapbender_sld/http/classes/class_wmc.php	2007-11-23 13:22:46 UTC (rev 1831)
@@ -1,5 +1,5 @@
 <?php
-# $Id: class_wmc.php 645 2006-12-08 12:58:39Z christoph $
+# $Id: class_wmc.php 1233 2007-10-19 14:28:21Z baudson $
 # http://www.mapbender.org/index.php/class_wmc.php
@@ -16,11 +16,16 @@
 require_once("../../conf/mapbender.conf");
 require_once("../classes/class_wms.php");
 require_once("../classes/class_mb_exception.php");
+require_once("../classes/class_layer_monitor.php");
+require_once("../classes/class_bbox.php");
+require_once("../extensions/JSON.php");
+$con = db_connect(DBSERVER,OWNER,PW);
+db_select_db(DB,$con);
 function mb_utf8_encode ($str) {
 	if(CHARSET=="UTF-8") return utf8_encode($str);
 	return $str;
@@ -36,231 +41,756 @@
 class wmc {
-		var $wmc_id;
-		var $wmc_version;
-		var $wmc_windowWidth;
-		var $wmc_windowHeight;
-		var $wmc_bBox_SRS;
-		var $wmc_bBox_minx;
-		var $wmc_bBox_maxx;
-		var $wmc_bBox_miny;
-		var $wmc_bBox_maxy;
-		var $wmc_name;
-		var $wmc_title;
-		var $wmc_abstract;
-		var $wmc_logourl;
-		var $wmc_logourl_format;
-		var $wmc_logourl_type;
-		var $wmc_logourl_width;
-		var $wmc_logourl_height;
-		var $wmc_descriptionurl;
-		var $wmc_descriptionurl_format;
-		var $wmc_descriptionurl_type;
-		var $wmc_keyword = array();
-		var $wmc_contactposition;
-		var $wmc_contactvoicetelephone;
-		var $wmc_contactemail;
-		var $wmc_contactfacsimiletelephone;
-		var $wmc_contactperson;
-		var $wmc_contactorganization;
-		var $wmc_contactaddresstype;
-		var $wmc_contactaddress;
-		var $wmc_contactcity;
-		var $wmc_contactstateorprovince;
-		var $wmc_contactpostcode;
-		var $wmc_contactcountry;
-		var $wmc_wms_title = array();
-		var $wmc_layer_queryable = array();
-		var $wmc_layer_querylayer = array();
-		var $wmc_layer_hidden = array();
-		var $wmc_wms_id = array();
-		var $wmc_wms_service = array();
-		var $wmc_wms_version = array();
-		var $wmc_layer_id = array();
-		var $wmc_layer_title = array();
-		var $wmc_layer_name = array();
-		var $wmc_layer_abstract = array();
-		var $wmc_layer_srs = array();
-		var $wmc_wms_serviceURL = array();
-		var $wmc_layer_format_current = array();
-		var $wmc_layer_dataurl = array();
-		var $wmc_layer_metadataurl = array();
-		var $wmc_layer_minscale = array();
-		var $wmc_layer_maxscale = array();
-		var $wmc_layer_format = array();
-		var $wmc_layer_style_current = array();
-		var $wmc_layer_style_name = array();
-		var $wmc_layer_style_title = array();
-		var $wmc_layer_style_legendurl = array();
-		var $wmc_layer_style_legendurl_width = array();
-		var $wmc_layer_style_legendurl_height = array();
-		var $wmc_layer_style_legendurl_format = array();
-		var $wmc_layer_style_legendurl_type = array();
-		var $wmc_layer_style_sld_url = array();
-		var $wmc_layer_style_sld_type = array();
-		var $wmc_layer_style_sld_title = array();
-		var $wmc_wms_count = 0;
+	var $xml;
+	var $wmc_id;
+	var $wmc_version;
+	var $wmc_windowWidth;
+	var $wmc_windowHeight;
+	var $wmc_bBox_SRS;
+	var $wmc_bBox_minx;
+	var $wmc_bBox_maxx;
+	var $wmc_bBox_miny;
+	var $wmc_bBox_maxy;
+	var $wmc_name;
+	var $wmc_title;
+	var $wmc_abstract;
+	var $wmc_general_extension = array();
+	var $wmc_logourl;
+	var $wmc_logourl_format;
+	var $wmc_logourl_type;
+	var $wmc_logourl_width;
+	var $wmc_logourl_height;
+	var $wmc_descriptionurl;
+	var $wmc_descriptionurl_format;
+	var $wmc_descriptionurl_type;
+	var $wmc_keyword = array();
+	var $wmc_contactposition;
+	var $wmc_contactvoicetelephone;
+	var $wmc_contactemail;
+	var $wmc_contactfacsimiletelephone;
+	var $wmc_contactperson;
+	var $wmc_contactorganization;
+	var $wmc_contactaddresstype;
+	var $wmc_contactaddress;
+	var $wmc_contactcity;
+	var $wmc_contactstateorprovince;
+	var $wmc_contactpostcode;
+	var $wmc_contactcountry;
+	var $wmc_wms_title = array();
+	var $wmc_layer_queryable = array();
+	var $wmc_layer_hidden = array();
+	var $wmc_wms_id = array();
+	var $wmc_wms_service = array();
+	var $wmc_wms_version = array();
+	var $wmc_wms_layer_id = array();
+	var $wmc_layer_wfs_featuretype = array();
+	var $wmc_layer_id = array();
+	var $wmc_layer_pos = array();
+	var $wmc_layer_parent = array();
+	var $wmc_layer_querylayer = array();
+	var $wmc_layer_title = array();
+	var $wmc_layer_name = array();
+	var $wmc_layer_abstract = array();
+	var $wmc_layer_srs = array();
+	var $wmc_wms_serviceURL = array();
+	var $wmc_layer_format_current = array();
+	var $wmc_layer_dataurl = array();
+	var $wmc_layer_metadataurl = array();
+	var $wmc_layer_minscale = array();
+	var $wmc_layer_maxscale = array();
+	var $wmc_gui_layer_minscale = array();
+	var $wmc_gui_layer_maxscale = array();
+	var $wmc_layer_format = array();
+	var $wmc_layer_style_current = array();
+	var $wmc_layer_style_name = array();
+	var $wmc_layer_style_title = array();
+	var $wmc_layer_style_legendurl = array();
+	var $wmc_layer_style_legendurl_width = array();
+	var $wmc_layer_style_legendurl_height = array();
+	var $wmc_layer_style_legendurl_format = array();
+	var $wmc_layer_style_legendurl_type = array();
+	var $wmc_layer_style_sld_url = array();
+	var $wmc_layer_style_sld_type = array();
+	var $wmc_layer_style_sld_title = array();
+	var $wmc_wms_count = 0;
-	function wmc() {
+	 	var $data_type = array();
+		var $data_format = array();
+		var $objLayer = array();
+		var $gui_wms_mapformat;
+		var $gui_wms_featureinfoformat;
+		var $gui_wms_exceptionformat;
+		var $gui_wms_epsg;
+		var $default_epsg = 0;
+	var $monitoringIsOn = false;
+function wmc() {
+function saveAsFile() {
+	$filename = "wmc_" . date("Y_m_d_H_i_s") . ".log";
+	$logfile = "../../log/" . $filename;
-	function getTitle() {
-		return $this->wmc_title;
+	if($h = fopen($logfile,"a")){
+		$content = $this->xml;
+		if(!fwrite($h,$content)){
+			$e = new mb_exception("class_wmc.php: failed to write wmc.");
+			return false;
+		fclose($h);
+	return $filename;
+function getTitle() {
+	return $this->wmc_title;
+function getNumberOfWms () {
+	return $this->wmc_wms_count;
+function createWMCFromObj($mapObject, $user_id, $generalTitle, $extensionData) {
+	$this->wmc_id = $user_id . '_' . time();
-	function getNumberOfWms () {
-		return $this->wmc_wms_count;
+	$generalWidth = $mapObject->width;
+	$generalHeight = $mapObject->height;
+	$generalBboxSrs = $mapObject->epsg;
+	$arrayBBox = explode(",", $mapObject->extent);
+	$generalBboxMinx = floatval($arrayBBox[0]);
+	$generalBboxMiny = floatval($arrayBBox[1]);
+	$generalBboxMaxx = floatval($arrayBBox[2]);
+	$generalBboxMaxy = floatval($arrayBBox[3]);
+	$generalName = "Mapbender WMC"; // TO do : insert proper data
+	$generalKeywords = array("Mapbender", "WMC"); // TO do : insert proper data
+	$generalAbstract = ""; // TO do : insert proper data
+	$generalLogoUrl = ""; // TO do : insert proper data
+	$generalLogoUrlWidth = ""; // TO do : insert proper data
+	$generalLogoUrlHeight = ""; // TO do : insert proper data
+	$generalLogoUrlFormat = ""; // TO do : insert proper data
+	$generalDescriptionUrl = ""; // TO do : insert proper data
+	$generalContactPerson = "";
+	$generalContactOrganization = "";
+	$generalContactPosition = "";
+	$generalContactAddressType = "";
+	$generalContactAddress = "";
+	$generalContactCity = "";
+	$generalContactStateOrProvince = "";
+	$generalContactPostCode = "";
+	$generalContactCountry = "";
+	$generalContactVoiceTelephone = "";
+	$generalContactFacsimileTelephone = "";
+	$generalContactElectronicMailAddress = "";
+	$extension_namespace = "mapbender";
+	// LayerList variables
+	$layerHidden = "";
+	$layerQueryable = "";
+	$layerAbstract = "";
+	$layerName = "";
+	$layerSrs = "";
+	$layerDataUrl = "";
+	$layerMetadataUrl = "";
+	$layerFormat = "";
+	$layerFormat_current = "";
+	$layerStyle_current = "";
+	$layerStyle_name = "";
+	$layerStyle_title = "";
+	$layerStyle_legendURL = "";
+	$layerStyle_legendURL_width = "";
+	$layerStyle_legendURL_height = "";
+	$layerStyle_legendURL_format = "";
+	// generate XML
+	$doc = new DOMDocument("1.0", CHARSET);
+	$doc->preserveWhiteSpace = false;
+	// ViewContext
+	$e_view_context = $doc->createElementNS("http://www.opengis.net/context", "ViewContext");
+	$e_view_context->setAttribute("version", "1.0.0");
+	$e_view_context->setAttribute("id", $this->wmc_id);
+	$e_view_context->setAttribute("xmlns:xlink", "http://www.w3.org/1999/xlink");
+	$e_view_context->setAttribute("xmlns:mapbender", "http://www.mapbender.org");
+	$e_view_context->setAttribute("xmlns:xsi", "http://www.w3.org/2001/XMLSchema-instance");
+	$e_view_context->setAttribute("xsi:SchemaLocation", "http://schemas.opengis.net/context/1.0.0/context.xsd");
+		// General
+		$e_general = $doc->createElement("General");
+			$e_window = $doc->createElement("Window");
+			if (!empty($generalWidth) && !empty($generalHeight)) {
+				$e_window->setAttribute("width", $generalWidth);
+				$e_window->setAttribute("height", $generalHeight);
+			$e_general->appendChild($e_window);
+			$e_bbox = $doc->createElement("BoundingBox");
+			$e_bbox->setAttribute("SRS", $generalBboxSrs);
+			$e_bbox->setAttribute("minx", $generalBboxMinx);
+			$e_bbox->setAttribute("miny", $generalBboxMiny);
+			$e_bbox->setAttribute("maxx", $generalBboxMaxx);
+			$e_bbox->setAttribute("maxy", $generalBboxMaxy);
+			$e_general->appendChild($e_bbox);
+			$e_name = $doc->createElement("Name", $generalName);
+			$e_general->appendChild($e_name);
+			$e_title = $doc->createElement("Title", $generalTitle);
+			$e_general->appendChild($e_title);
+			$e_keyword_list = $doc->createElement("KeywordList");
+			for ($i=0; $i < count($generalKeywords); $i++) {
+				$e_keyword = $doc->createElement("Keyword", $generalKeywords[$i]);
+				$e_keyword_list->appendChild($e_keyword);
+			$e_general->appendChild($e_keyword_list);
+			if ($generalAbstract){
+				$e_abstract = $doc->createElement("Abstract", $generalAbstract);
+				$e_general->appendChild($e_abstract);
+			if ($generalLogoUrlWidth && $generalLogoUrlHeight && $generalLogoUrlFormat && $generalLogoUrl){
+				$e_logo_url = $doc->createElement("LogoURL");
+				$e_logo_url->setAttribute("width", $generalLogoUrlWidth);
+				$e_logo_url->setAttribute("height", $generalLogoUrlHeight);
+				$e_logo_url->setAttribute("format", $generalLogoUrlFormat);
+				$e_logo_url_or = $doc->createElement("OnlineResource");
+				$e_logo_url_or->setAttributeNS("http://www.opengis.net/context", "xmlns:xlink", "http://www.w3.org/1999/xlink");
+				$e_logo_url_or->setAttribute("xlink:type", "simple");
+				$e_logo_url_or->setAttribute("xlink:href", $generalLogoUrl);
+				$e_logo_url->appendChild($e_logo_url_or);
+				$e_general->appendChild($e_logo_url);
+			if ($generalDescriptionUrl){
+				$e_description_url = $doc->createElement("DescriptionURL");
+				$e_description_url_or = $doc->createElement("OnlineResource");
+				$e_description_url_or->setAttributeNS("http://www.opengis.net/context", "xmlns:xlink", "http://www.w3.org/1999/xlink");
+				$e_description_url_or->setAttribute("xlink:type", "simple");
+				$e_description_url_or->setAttribute("xlink:href", $generalDescriptionUrl);
+				$e_description_url->appendChild($e_description_url_or);
+				$e_general->appendChild($e_description_url);
+			if ($generalContactElectronicMailAddress || $generalContactOrganization ||
+				$generalContactPerson || $generalContactPosition || $generalContactAddressType ||
+				$generalContactAddress || $generalContactCity || $generalContactStateOrProvince ||
+				$generalContactPostCode || $generalContactCountry || $generalContactVoiceTelephone ||
+				$generalContactFacsimileTelephone || $generalContactElectronicMailAddress) {
+				$e_contact = $doc->createElement("ContactInformation");
+				if ($generalContactPerson || $generalContactOrganization){
+					$e_contact_person_primary = $doc->createElement("ContactPersonPrimary");
+					if ($generalContactPerson){
+						$e_contact_person = $doc->createElement("ContactPerson", $generalContactPerson);
+						$e_contact_person_primary->appendChild($e_contact_person);
+					if ($generalContactOrganization){
+						$e_contact_organization = $doc->createElement("ContactOrganization", $generalContactOrganization);
+						$e_contact_person_primary->appendChild($e_contact_organization);
+					$e_contact->appendChild($e_contact_person_primary);
+				if ($generalContactPosition){
+					$e_contact_position = $doc->createElement("ContactPosition", $generalContactPosition);
+					$e_contact->appendChild($e_contact_position);
+				if ($generalContactAddressType || $generalContactAddress ||
+					$generalContactCity || $generalContactStateOrProvince ||
+					$generalContactPostCode || $generalContactCountry) {
+					$e_contact_address = $doc->createElement("ContactAddress");
+					if ($generalContactAddressType){
+						$e_address_type = $doc->createElement("AddressType", $generalContactAddressType);
+						$e_contact_address->appendChild($e_address_type);
+					if ($generalContactAddress){
+						$e_address = $doc->createElement("Address", $generalContactAddress);
+						$e_contact_address->appendChild($e_address);
+					if ($generalContactCity){
+						$e_city = $doc->createElement("City", $generalContactCity);
+						$e_contact_address->appendChild($e_city);
+					if ($generalContactStateOrProvince){
+						$e_state = $doc->createElement("StateOrProvince", $generalContactStateOrProvince);
+						$e_contact_address->appendChild($e_state);
+					if ($generalContactPostCode){
+						$e_postcode = $doc->createElement("PostCode", $generalContactPostCode);
+						$e_contact_address->appendChild($e_postcode);
+					if ($generalContactCountry){
+						$e_country = $doc->createElement("Country", $generalContactCountry);
+						$e_contact_address->appendChild($e_country);
+					$e_contact->appendChild($e_contact_address);
+				if ($generalContactVoiceTelephone){
+					$e_voice_telephone = $doc->createElement("ContactVoiceTelephone", $generalContactVoiceTelephone);
+					$e_contact->appendChild($e_voice_telephone);
+				if ($generalContactFacsimileTelephone){
+					$e_facsimile_telephone = $doc->createElement("ContactFacsimileTelephone", $generalContactFacsimileTelephone);
+					$e_contact->appendChild($e_facsimile_telephone);
+				if ($generalContactElectronicMailAddress){
+					$e_email = $doc->createElement("ContactElectronicMailAddress", $generalContactElectronicMailAddress);
+					$e_contact->appendChild($e_email);
+				$e_general->appendChild($e_contact);
+			if (count($extensionData) > 0) {
+				//$e = new mb_exception("writing wmc...");
+				$e_extensionGeneral = $doc->createElement("Extension");
+				foreach ($extensionData as $keyExtensionData => $valueExtensionData) {
+					$e_currentExtensionTag = $doc->createElement($extension_namespace.":".$keyExtensionData, $valueExtensionData);
+					$e_extensionGeneral->appendChild($e_currentExtensionTag);
+				$e_general->appendChild($e_extensionGeneral);
+		$e_view_context->appendChild($e_general);
+		// LayerList
+		$e_layer_list = $doc->createElement("LayerList");
+		for ($i=0; $i < count($mapObject->wms); $i++){
+			$wmsId = $mapObject->wms[$i]->wms_id;
+			$wms_epsg = array();
+			$wms_epsg[0] = $mapObject->epsg;
+			if ($mapObject->wms[$i]->gui_wms_epsg != $mapObject->epsg){
+				$wms_epsg[1] = $mapObject->wms[$i]->gui_wms_epsg;
+			for ($q = 0; $q < count($mapObject->wms[$i]->gui_epsg); $q++){
+				$isInArray = false;
+				for ($r=0 ; $r < count($wms_epsg); $r++){
+					if ($wms_epsg[$r] == $mapObject->wms[$i]->gui_epsg[$q]){
+						$isInArray = true;
+				if ($isInArray == false){
+					array_push($wms_epsg, $mapObject->wms[$i]->gui_epsg[$q]);
+			for ($j = 0; $j < count($mapObject->wms[$i]->objLayer); $j++){
+				if ($mapObject->wms[$i]->objLayer[$j]->layer_parent != ''){
+					if ($mapObject->wms[$i]->objLayer[$j]->gui_layer_visible == "1"){
+						$layerHidden = 0;
+					else{
+						$layerHidden = 1;
+					$layerQueryable = $mapObject->wms[$i]->objLayer[$j]->layer_queryable;
+					$layerQuerylayer = $mapObject->wms[$i]->objLayer[$j]->gui_layer_querylayer;
+					$layerId = $mapObject->wms[$i]->objLayer[$j]->layer_uid;
+					$layerName = $mapObject->wms[$i]->objLayer[$j]->layer_name;
+					$layerTitle = $mapObject->wms[$i]->objLayer[$j]->layer_title;
+					$layerAbstract = $mapObject->wms[$i]->wms_abstract; //To Do: insert actual abstract
+					$layerDataUrl = $mapObject->wms[$i]->objLayer[$j]->layer_dataurl_href;
+					$layerMetadataUrl = $mapObject->wms[$i]->objLayer[$j]->layer_metadataurl;
+					$layerMinscale = $mapObject->wms[$i]->objLayer[$j]->layer_minscale;
+					$layerMaxscale = $mapObject->wms[$i]->objLayer[$j]->layer_maxscale;
+					$guiLayerMinscale = $mapObject->wms[$i]->objLayer[$j]->gui_layer_minscale;
+					$guiLayerMaxscale = $mapObject->wms[$i]->objLayer[$j]->gui_layer_maxscale;
+					$wmsVersion = $mapObject->wms[$i]->wms_version;
+					$wmsTitle = $mapObject->wms[$i]->wms_title;
+					$wmsLayerId = $mapObject->wms[$i]->objLayer[0]->layer_uid;
+					$wmsOnlineResource = $mapObject->wms[$i]->wms_getmap;
+					$layerPos = $mapObject->wms[$i]->objLayer[$j]->layer_pos;
+					$layerParent = $mapObject->wms[$i]->objLayer[$j]->layer_parent;
+					$queryLayer = $mapObject->wms[$i]->objLayer[$j]->gui_layer_querylayer;
+					$wfsFeatureType = $mapObject->wms[$i]->objLayer[$j]->gui_layer_wfs_featuretype;
+					$e_layer = $doc->createElement("Layer");
+					$e_layer->setAttribute("queryable", $layerQueryable);
+					$e_layer->setAttribute("hidden", $layerHidden);
+						$e_service = $doc->createElement("Server");
+						$e_service->setAttribute("service", "OGC:WMS");
+						$e_service->setAttribute("version", $wmsVersion);
+						$e_service->setAttribute("title", $wmsTitle);
+						$e_service_or = $doc->createElement("OnlineResource");
+						$e_service_or->setAttribute("xmlns:xlink", "http://www.w3.org/1999/xlink");
+						$e_service_or->setAttribute("xlink:type", "simple");
+						$e_service_or->setAttribute("xlink:href", $wmsOnlineResource);
+						$e_service->appendChild($e_service_or);
+						$e_layer->appendChild($e_service);
+						$e_layer_name = $doc->createElement("Name", $layerName);
+						$e_layer->appendChild($e_layer_name);
+						$e_layer_title = $doc->createElement("Title", $layerTitle);
+						$e_layer->appendChild($e_layer_title);
+						if ($layerAbstract){
+							$e_layer_abstract = $doc->createElement("Abstract", $layerAbstract);
+							$e_layer->appendChild($e_layer_abstract);
+						$e_layer_srs = $doc->createElement("SRS", implode(" ", $wms_epsg));
+						if ($layerDataUrl){
+							$e_layer_data_url = $doc->createElement("DataURL");
+							$e_layer_data_url_or = $doc->createElement("OnlineResource");
+							$e_layer_data_url_or->setAttribute("xmlns:xlink", "http://www.w3.org/1999/xlink");
+							$e_layer_data_url_or->setAttribute("xlink:type", "simple");
+							$e_layer_data_url_or->setAttribute("xlink:href", $layerDataUrl);
+							$e_layer_data_url->appendChild($e_layer_data_url_or);
+							$e_layer->appendChild($e_layer_data_url);
+						if ($layerMetadataUrl){
+							$e_layer_metadata_url = $doc->createElement("MetadataURL");
+							$e_layer_metadata_url_or = $doc->createElement("OnlineResource");
+							$e_layer_metadata_url_or->setAttribute("xmlns:xlink", "http://www.w3.org/1999/xlink");
+							$e_layer_metadata_url_or->setAttribute("xlink:type", "simple");
+							$e_layer_metadata_url_or->setAttribute("xlink:href", $layerMetadataUrl);
+							$e_layer_metadata_url->appendChild($e_layer_metadata_url_or);
+							$e_layer->appendChild($e_layer_metadata_url);
+						$e_extension = $doc->createElement("Extension");
+						$e_scalehint = $doc->createElement($extension_namespace.":ScaleHint");
+						$e_scalehint->setAttribute("min", $layerMinscale);
+						$e_scalehint->setAttribute("max", $layerMaxscale);
+						$e_extension->appendChild($e_scalehint);
+						$e_gui_scalehint = $doc->createElement($extension_namespace.":guiScaleHint");
+						$e_gui_scalehint->setAttribute("min", $guiLayerMinscale);
+						$e_gui_scalehint->setAttribute("max", $guiLayerMaxscale);
+						$e_extension->appendChild($e_gui_scalehint);
+						$e_layer_id = $doc->createElement($extension_namespace.":layer_id", $layerId);
+						$e_extension->appendChild($e_layer_id);
+						$e_wms_layer_id = $doc->createElement($extension_namespace.":wms_layer_id", $wmsLayerId);
+						$e_extension->appendChild($e_wms_layer_id);
+						$e_layer_pos = $doc->createElement($extension_namespace.":layer_pos", $layerPos);
+						$e_extension->appendChild($e_layer_pos);
+						$e_layer_parent = $doc->createElement($extension_namespace.":layer_parent", $layerParent);
+						$e_extension->appendChild($e_layer_parent);
+						$e_wms_id = $doc->createElement($extension_namespace.":wms_id", $wmsId);
+						$e_extension->appendChild($e_wms_id);
+						$e_querylayer = $doc->createElement($extension_namespace.":querylayer", $layerQuerylayer);
+						$e_extension->appendChild($e_querylayer);
+						if ($wfsFeatureType) {
+							$e_wfsFeatureType = $doc->createElement($extension_namespace.":wfsFeatureType", $wfsFeatureType);
+							$e_extension->appendChild($e_wfsFeatureType);
-	function createObjFromWMC_id($wmc_id){
+						$e_layer->appendChild($e_extension);
-		$con = db_connect(DBSERVER,OWNER,PW);
-		db_select_db(DB, $con);
+						//layerFormat
+						$e_layer_format = $doc->createElement("FormatList");
-		$sql = "SELECT wmc FROM mb_user_wmc WHERE wmc_id = $1";
-		$v = array($wmc_id);
-		$t = array("s");
-		$res = db_prep_query($sql, $v, $t);
-		$wmc = db_fetch_array($res);
-		$this->createObjFromWMC_xml($wmc[0]);
+						$data_format_current = false;
+						for ($k = 0; $k < count($mapObject->wms[$i]->data_format); $k++){
+							if ($mapObject->wms[$i]->data_type[$k] == "map") {
+								$layerFormat = $mapObject->wms[$i]->data_format[$k];
+								$e_format = $doc->createElement("Format", $layerFormat);
+								if ($data_format_current == false && (
+										($mapObject->wms[$i]->data_format[$k] == $mapObject->wms[$i]->gui_wms_mapformat) ||
+										($k == (count($mapObject->wms[$i]->data_format)-1))
+									$e_format->setAttribute("current", "1");
+									$data_format_current = true;
+								$e_layer_format->appendChild($e_format);
+						$e_layer->appendChild($e_layer_format);
+						// LayerStyle
+						$e_layer_stylelist = $doc->createElement("StyleList");
+						for ($k = 0; $k < count($mapObject->wms[$i]->objLayer[$j]->layer_style); $k++){
+							if ($k == 0){
+								$layerStyle_current = 1; // To do: insert proper data
+							else{
+								$layerStyle_current = 0; // To do: insert proper data
+							$e_layer_style = $doc->createElement("Style");
+							$layerStyleSLD = "";
+							if ($layerStyleSLD){
+								$layerStyleSLDUrl = ""; // To Do: Insert Proper Data
+								$e_layer_style_or = $doc->createElement("OnlineResource");
+								$e_layer_style_or->setAttribute("xmlns:xlink", "http://www.w3.org/1999/xlink");
+								$e_layer_style_or->setAttribute("xlink:type", "simple");
+								$e_layer_style_or->setAttribute("xlink:href", $layerStyleSLDUrl);
+								$e_layer_style->appendChild($e_layer_style_or);
+							else{
+								//TODO: determine correct layer style entries
+								$layerStyle_name = $mapObject->wms[$i]->objLayer[$j]->layer_style[$k]->name;
+								$layerStyle_title = $mapObject->wms[$i]->objLayer[$j]->layer_style[$k]->title;
+								$layerStyle_legendUrl = $mapObject->wms[$i]->objLayer[$j]->layer_style[$k]->legendurl;
+								$layerStyle_legendUrl_width = ""; // To Do: add proper data
+								$layerStyle_legendUrl_height = ""; // To Do: add proper data
+								$layerStyle_legendUrl_format = ""; // To Do: add proper data
+								if ($layerStyle_current == 1){
+									$e_layer_style->setAttribute("current", "1");
+								$e_layer_style_name = $doc->createElement("Name", $layerStyle_name);
+								$e_layer_style->appendChild($e_layer_style_name);
+								$e_layer_style_title = $doc->createElement("Title", $layerStyle_title);
+								$e_layer_style->appendChild($e_layer_style_title);
+								$e_layer_style_legendurl = $doc->createElement("LegendUrl");
+								$e_layer_style_legendurl->setAttribute("width", $layerStyle_legendUrl_width);
+								$e_layer_style_legendurl->setAttribute("height", $layerStyle_legendUrl_height);
+								$e_layer_style_legendurl->setAttribute("format", $layerStyle_legendUrl_format);
+								$e_layer_style_legendurl_or = $doc->createElement("OnlineResource");
+								$e_layer_style_legendurl_or->setAttribute("xmlns:xlink", "http://www.w3.org/1999/xlink");
+								$e_layer_style_legendurl_or->setAttribute("xlink:type", "simple");
+								$e_layer_style_legendurl_or->setAttribute("xlink:href", $layerStyle_legendUrl);
+								$e_layer_style_legendurl->appendChild($e_layer_style_legendurl_or);
+								$e_layer_style->appendChild($e_layer_style_legendurl);
+							$e_layer_stylelist->appendChild($e_layer_style);
+						$e_layer->appendChild($e_layer_stylelist);
+					$e_layer_list->appendChild($e_layer);
+		$e_view_context->appendChild($e_layer_list);
+	$doc->appendChild($e_view_context);
+	$this->xml = $doc->saveXML();
+	// for debugging: saving WMC as file
+	// (comment when no longer needed)
+	$filename = $this->saveAsFile();
+	if ($filename) {
+		$e = new mb_notice("class_wmc: saving WMC as file " . $filename);
-	function createObjFromWMC_xml($data){
-		$data = str_replace("&#38;", "&amp;", $data);
-		$values = NULL;
-		$tags = NULL;
-		$parser = xml_parser_create(CHARSET);
-		xml_parser_set_option($parser,XML_OPTION_CASE_FOLDING,0);
-		xml_parser_set_option($parser,XML_OPTION_SKIP_WHITE,1);
-		xml_parser_set_option($parser,XML_OPTION_TARGET_ENCODING,CHARSET);
-		$code = xml_get_error_code ($parser);
-		if ($code) {
-			$line = xml_get_current_line_number($parser);
-			$mb_exception = new mb_exception(xml_error_string($code) .  " in line " . $line);
-			return false;
+function createObjFromWMC_id($wmc_id){
+	db_select_db(DB, $con);
+	$sql = "SELECT wmc FROM mb_user_wmc WHERE wmc_id = '" . $wmc_id . "'";
+	$wmc = db_fetch_row($res);
+	$this->createObjFromWMC_xml($wmc[0]);
+	$this->monitoringIsOn = true;
+function createObjFromWMC_xml($data){
+#	$data = str_replace("&#38;", "&amp;", $data);
+	// store xml
+	$this->xml = $data;
+	if ($filename) {
+	$values = NULL;
+	$tags = NULL;
+	xml_parse_into_struct($parser,$data,$values,$tags);
+	$code = xml_get_error_code ($parser);
+	if ($code) {
+		$line = xml_get_current_line_number($parser);
+		$mb_exception = new mb_exception(xml_error_string($code) .  " in line " . $line);
+		return false;
+	$section = NULL;
+	$format = NULL;
+	$cnt_format = 0;
+	$parent = array();
+	$myParent = array();
+	$cnt_layer = -1;
+	$request = NULL;
+	$layer_style = array();
+	$extension = false;
+	$general = false;
+	$layerlist = false;
+	$layer = false;
+	$formatlist = false;
+	$dataurl = false;
+	$metadataurl = false;
+	$stylelist = false;
+	$cnt_style = -1;
+					$verbose .= ".";
+		if(strtoupper($element[tag]) == "VIEWCONTEXT" && $element[type] == "open"){
+				$this->wmc_id = $element[attributes]["id"];
+				$this->wmc_version = $element[attributes]["version"];
-		xml_parser_free($parser);
-		$section = NULL;
-		$format = NULL;
-		$cnt_format = 0;
-		$parent = array();
-		$myParent = array();
-		$cnt_layer = -1;
-		$request = NULL;
-		$layer_style = array();
-		$cnt_style = -1;
-		$extension = false;
-		$general = false;
-		$layerlist = false;
-		$layer = false;
-		$formatlist = false;
-		$metadataurl = false;
-		$dataurl = false;
-		$stylelist = false;
-		foreach ($values as $element) {
-			if(strtoupper($element[tag]) == "VIEWCONTEXT" && $element[type] == "open"){
-					$this->wmc_id = $element[attributes]["id"];
-					$this->wmc_version = $element[attributes]["version"];
-			if(strtoupper($element[tag]) == "GENERAL" && $element[type] == "open"){
-			   $general = true;
-			if(strtoupper($element[tag]) == "LAYERLIST" && $element[type] == "open"){
-			   $layerlist = true;
-			if ($general) {
+		if(strtoupper($element[tag]) == "GENERAL" && $element[type] == "open"){
+		   $general = true;
+		if(strtoupper($element[tag]) == "LAYERLIST" && $element[type] == "open"){
+		   $layerlist = true;
+		if ($general) {
 				if(strtoupper($element[tag]) == "WINDOW"){
-					$this->wmc_windowWidth = $element[attributes]["width"];
-					$this->wmc_windowHeight = $element[attributes]["height"];
+						$this->wmc_windowWidth = $element[attributes]["width"];
+						$this->wmc_windowHeight = $element[attributes]["height"];
 				if(strtoupper($element[tag]) == "BOUNDINGBOX"){
-					$this->wmc_bBox_SRS = $element[attributes]["SRS"];
-					$this->wmc_bBox_minx = $element[attributes]["minx"];
-					$this->wmc_bBox_miny = $element[attributes]["miny"];
-					$this->wmc_bBox_maxx = $element[attributes]["maxx"];
-					$this->wmc_bBox_maxy = $element[attributes]["maxy"];
+						$this->wmc_bBox_SRS = $element[attributes]["SRS"];
+						$this->wmc_bBox_minx = $element[attributes]["minx"];
+						$this->wmc_bBox_miny = $element[attributes]["miny"];
+						$this->wmc_bBox_maxx = $element[attributes]["maxx"];
+						$this->wmc_bBox_maxy = $element[attributes]["maxy"];
 				if(strtoupper($element[tag]) == "NAME"){
-					$this->wmc_name = mb_utf8_decode(html_entity_decode($element[value]));
+						$this->wmc_name = mb_utf8_decode(html_entity_decode($element[value]));
 				if(strtoupper($element[tag]) == "TITLE"){
-					$this->wmc_title = mb_utf8_decode(html_entity_decode($element[value]));
+						$this->wmc_title = mb_utf8_decode(html_entity_decode($element[value]));
 				if(strtoupper($element[tag]) == "ABSTRACT"){
-					$this->wmc_abstract = mb_utf8_decode(html_entity_decode($element[value]));
+						$this->wmc_abstract = mb_utf8_decode(html_entity_decode($element[value]));
 				if(strtoupper($element[tag]) == "CONTACTINFORMATION" && $element['type'] == "open"){
-					$contactinformation = true;
+						$contactinformation = true;
 				if ($contactinformation) {
 					if(strtoupper($element[tag]) == "CONTACTPOSITION"){
-						$this->wmc_contactposition = mb_utf8_decode(html_entity_decode($element[value]));
+							$this->wmc_contactposition = mb_utf8_decode(html_entity_decode($element[value]));
 					if(strtoupper($element[tag]) == "CONTACTVOICETELEPHONE"){
-						$this->wmc_contactvoicetelephone = $element[value];
+							$this->wmc_contactvoicetelephone = $element[value];
 					if(strtoupper($element[tag]) == "CONTACTFACSIMILETELEPHONE"){
-						$this->wmc_contactfacsimiletelephone = $element[value];
+							$this->wmc_contactfacsimiletelephone = $element[value];
 					if(strtoupper($element[tag]) == "CONTACTELECTRONICMAILADDRESS"){
-						$this->wmc_contactemail = mb_utf8_decode(html_entity_decode($element[value]));
+							$this->wmc_contactemail = mb_utf8_decode(html_entity_decode($element[value]));
 					if(strtoupper($element[tag]) == "CONTACTPERSONPRIMARY" && $element['type'] == "open"){
-						$contactpersonprimary = true;
+							$contactpersonprimary = true;
 					if ($contactpersonprimary) {
 						if(strtoupper($element[tag]) == "CONTACTPERSON"){
-							$this->wmc_contactperson = mb_utf8_decode(html_entity_decode($element[value]));
+								$this->wmc_contactperson = mb_utf8_decode(html_entity_decode($element[value]));
 						if(strtoupper($element[tag]) == "CONTACTORGANIZATION"){
-							$this->wmc_contactorganization = mb_utf8_decode(html_entity_decode($element[value]));
+								$this->wmc_contactorganization = mb_utf8_decode(html_entity_decode($element[value]));
 						if(strtoupper($element[tag]) == "CONTACTPERSONPRIMARY" && $element['type'] == "close"){
-							$contactpersonprimary = false;
+								$contactpersonprimary = false;
 					if(strtoupper($element[tag]) == "CONTACTADDRESS" && $element['type'] == "open"){
-						$contactaddress = true;
+							$contactaddress = true;
 					if ($contactaddress) {
 						if(strtoupper($element[tag]) == "ADDRESSTYPE"){
-							$this->wmc_contactaddresstype = mb_utf8_decode(html_entity_decode($element[value]));
+								$this->wmc_contactaddresstype = mb_utf8_decode(html_entity_decode($element[value]));
 						if(strtoupper($element[tag]) == "ADDRESS"){
-							$this->wmc_contactaddress = mb_utf8_decode(html_entity_decode($element[value]));
+								$this->wmc_contactaddress = mb_utf8_decode(html_entity_decode($element[value]));
 						if(strtoupper($element[tag]) == "CITY"){
-							$this->wmc_contactcity = mb_utf8_decode(html_entity_decode($element[value]));
+								$this->wmc_contactcity = mb_utf8_decode(html_entity_decode($element[value]));
 						if(strtoupper($element[tag]) == "STATEORPROVINCE"){
-							$this->wmc_contactstateorprovince = mb_utf8_decode(html_entity_decode($element[value]));
+								$this->wmc_contactstateorprovince = mb_utf8_decode(html_entity_decode($element[value]));
 						if(strtoupper($element[tag]) == "POSTCODE"){
-							$this->wmc_contactpostcode = $element[value];
+								$this->wmc_contactpostcode = $element[value];
 						if(strtoupper($element[tag]) == "COUNTRY"){
-							$this->wmc_contactcountry = mb_utf8_decode(html_entity_decode($element[value]));
+								$this->wmc_contactcountry = mb_utf8_decode(html_entity_decode($element[value]));
 						if(strtoupper($element[tag]) == "CONTACTADDRESS" && $element['type'] == "close"){
-							$contactaddress = false;
+								$contactaddress = false;
 				if(strtoupper($element[tag]) == "LOGOURL" && $element['type'] == "open"){
-					$logourl = true;
-					$this->wmc_logourl_width = $element[attributes]["width"];
-					$this->wmc_logourl_height = $element[attributes]["height"];
-					$this->wmc_logourl_format = $element[attributes]["format"];
+						$logourl = true;
+						$this->wmc_logourl_width = $element[attributes]["width"];
+						$this->wmc_logourl_height = $element[attributes]["height"];
+						$this->wmc_logourl_format = $element[attributes]["format"];
 				if ($logourl) {
 					if(strtoupper($element[tag]) == "LOGOURL" && $element['type'] == "close"){
-						$logourl = false;
+							$logourl = false;
 					if(strtoupper($element[tag]) == "ONLINERESOURCE"){
 						$this->wmc_logourl_type = $element[attributes]["xlink:type"];
@@ -268,12 +798,12 @@
 				if(strtoupper($element[tag]) == "DESCRIPTIONURL" && $element['type'] == "open"){
-					$descriptionurl = true;
-					$this->wmc_descriptionurl_format = $element[attributes]["format"];
+						$descriptionurl = true;
+						$this->wmc_descriptionurl_format = $element[attributes]["format"];
 				if ($descriptionurl) {
 					if(strtoupper($element[tag]) == "DESCRIPTIONURL" && $element['type'] == "close"){
-						$descriptionurl = false;
+							$descriptionurl = false;
 						$this->wmc_descriptionurl_type = $element[attributes]["xlink:type"];
@@ -281,12 +811,12 @@
 				if(strtoupper($element[tag]) == "KEYWORDLIST" && $element['type'] == "open"){
-					$keywordlist = true;
+						$keywordlist = true;
 				if ($keywordlist) {
 					if(strtoupper($element[tag]) == "KEYWORDLIST" && $element['type'] == "close"){
-						$keywordlist = false;
-						$cnt_keyword = -1;
+							$keywordlist = false;
+							$cnt_keyword = -1;
 					if(strtoupper($element[tag]) == "KEYWORD"){
 						$cnt_keyword++;
@@ -294,11 +824,22 @@
+				if(strtoupper($element[tag]) == "EXTENSION" && $element['type'] == "close"){
+					$generalExtension = false;
+				if ($generalExtension) {
+					$this->wmc_general_extension[sepNameSpace($element[tag])] = $element[value];
+//					$e = new mb_exception("WMC: " . $element[tag] . ": " . $element[value]);
+				if(strtoupper($element[tag]) == "EXTENSION" && $element['type'] == "open"){
+					$generalExtension = true;
 				if(strtoupper($element[tag]) == "GENERAL" && $element['type'] == "close"){
 		   			$general = false;
-			if ($layerlist) {
+		if ($layerlist) {
 				if(strtoupper($element[tag]) == "LAYERLIST" && $element['type'] == "close"){
 				   $layerlist = false;
@@ -310,9 +851,9 @@
       		 		 $cnt_epsg = 0;
 				if ($layer) {
-					if(strtoupper($element[tag]) == "LAYER" && $element[type] == "close"){
-						$layer = false;
+					 if(strtoupper($element[tag]) == "LAYER" && $element[type] == "close"){
+					 		$layer = false;
 					 if ($formatlist) {
 						 if(strtoupper($element[tag]) == "FORMAT"){
 						 	$cnt_format++;
@@ -325,10 +866,10 @@
 					 elseif ($metadataurl) {
-							$this->wmc_layer_metadataurl[$cnt_layer] = $element[attributes]["xlink:href"];
+						 	$this->wmc_layer_metadataurl[$cnt_layer] = $element[attributes]["xlink:href"];
 						 if(strtoupper($element[tag]) == "METADATAURL" && $element[type] == "close"){
 					 elseif ($dataurl) {
@@ -434,15 +975,31 @@
 					 		 $this->wmc_layer_minscale[$cnt_layer] = $element[attributes]["min"];
 					 		 $this->wmc_layer_maxscale[$cnt_layer] = $element[attributes]["max"];
+						 if($extension == true && strtoupper(sepNameSpace($element[tag])) == "GUISCALEHINT"){
+					 		 $this->wmc_gui_layer_minscale[$cnt_layer] = $element[attributes]["min"];
+					 		 $this->wmc_gui_layer_maxscale[$cnt_layer] = $element[attributes]["max"];
 						 if($extension == true && strtoupper(sepNameSpace($element[tag])) == "LAYER_ID"){
 					 		 $this->wmc_layer_id[$cnt_layer] = $element[value];
-						 if($extension == true && strtoupper(sepNameSpace($element[tag])) == "WMS_ID"){
-					 		 $this->wmc_wms_id[$cnt_layer] = $element[value];
+						 if($extension == true && strtoupper(sepNameSpace($element[tag])) == "WMS_LAYER_ID"){
+					 		 $this->wmc_wms_layer_id[$cnt_layer] = $element[value];
+						 if($extension == true && strtoupper(sepNameSpace($element[tag])) == "LAYER_POS"){
+					 		 $this->wmc_layer_pos[$cnt_layer] = $element[value];
+						 if($extension == true && strtoupper(sepNameSpace($element[tag])) == "LAYER_PARENT"){
+					 		 $this->wmc_layer_parent[$cnt_layer] = $element[value];
 						 if($extension == true && strtoupper(sepNameSpace($element[tag])) == "QUERYLAYER"){
 					 		 $this->wmc_layer_querylayer[$cnt_layer] = $element[value];
+						 if($extension == true && strtoupper(sepNameSpace($element[tag])) == "WMS_ID"){
+					 		 $this->wmc_wms_id[$cnt_layer] = $element[value];
+						 if($extension == true && strtoupper(sepNameSpace($element[tag])) == "WFSFEATURETYPE"){
+					 		 $this->wmc_layer_wfs_featuretype[$cnt_layer] = $element[value];
 						 if(strtoupper($element[tag]) == "METADATAURL" && $element[type] == "open"){
 							 $metadataurl = true;
@@ -462,15 +1019,34 @@
 		return true;
+	  //return $verbose;
 	function createJsObjFromWMC($target, $mapObj, $action){
+		 * counts how often a layer has been loaded
+		if ($this->monitoringIsOn) {
+			$monitor = new Layer_load_count();
+			for ($i = 0; $i < count($this->wmc_layer_id); $i++) {
+				$monitor->increment($this->wmc_layer_id[$i]);
 		$wmc_string = "";
 		$validActions = array("load", "merge", "append");
 		if (!in_array($action, $validActions)) {
 			$wmc_string .= "alert('invalid action: ".$action."');";
 		else {
+			// general extension
+			if (count($this->wmc_general_extension) > 0) {
+				$json = new Services_JSON();
+				$wmc_string .= $target . "restoredWmcExtensionData = " . $json->encode($this->wmc_general_extension) . ";\n";
 			$wmc_string .= "var index = " . $target . "getMapObjIndexByName('" . $mapObj . "');\n";
 			if ($action == "load") {
 				// delete all previous wms
@@ -521,7 +1097,8 @@
 					// add wms
-					$wmc_string .= "\t" . $target . "add_wms('','".
+					$wmc_string .= "\t" . $target . "add_wms('".
+						$this->wmc_wms_id[$i]."','".
 						$this->wmc_wms_version[$i] ."','".
 						$this->wmc_wms_title[$i] ."','".
 						$this->wmc_layer_abstract[$i] ."','".
@@ -565,7 +1142,10 @@
 									$wmc_string .= "if (!wms_exists) {\n\t";
 								// add parent layer
-								$wmc_string .= $target . "wms_add_layer('','".$this->wmc_layer_id[$i]."','','". $this->wmc_wms_title[$i] ."','','0','0','0','0','','".$this->wmc_wms_id[$i]."','1','1','1','0','0','0','0');\n";
+								$wmc_string .= $target . "wms_add_layer('','".
+									$this->wmc_wms_layer_id[$i]."','','".
+									$this->wmc_wms_title[$i] ."','','0','0','0','0','','".
+									$this->wmc_wms_id[$i]."','1','', '1','1','0','0','0','0','');\n";
 								if ($action == "merge") {
 									$wmc_string .= "}\n";
@@ -585,15 +1165,21 @@
 								$wmc_string .= "\t\t\tcurrent_layer_index = m;\n";
 								$wmc_string .= "\t\t}\n";
 								$wmc_string .= "\t}\n";
+								if ($this->wmc_layer_querylayer[$ii]!="") {
+									$querylayer_yn = $this->wmc_layer_querylayer[$ii];
+								else {
+									$querylayer_yn = $this->wmc_layer_queryable[$ii];
 								$wmc_string .= "\tif (layer_exists) {\n";
 								// check if the visibility or the queryability are different to the existing layer
 								$wmc_string .= "\t\tif (" . $target . "mb_mapObj[index].wms[current_wms_index].objLayer[current_layer_index].gui_layer_visible != '" . intval(!$this->wmc_layer_hidden[$ii]) . "'";
-								$wmc_string .= " || " . $target . "mb_mapObj[index].wms[current_wms_index].objLayer[current_layer_index].gui_layer_querylayer != '" . $this->wmc_layer_queryable[$ii] . "') {\n";
+								$wmc_string .= " || " . $target . "mb_mapObj[index].wms[current_wms_index].objLayer[current_layer_index].gui_layer_querylayer != '" . $querylayer_yn . "') {\n";
 								// if yes, update the visibility and queryability
 								$wmc_string .= "\t\t\t" . $target . "mb_mapObj[index].wms[current_wms_index].objLayer[current_layer_index].gui_layer_visible = " . intval(!$this->wmc_layer_hidden[$ii]) . ";\n";
-								$wmc_string .= "\t\t\t" . $target . "mb_mapObj[index].wms[current_wms_index].objLayer[current_layer_index].gui_layer_querylayer = " . $this->wmc_layer_queryable[$ii] . ";\n";
+								$wmc_string .= "\t\t\t" . $target . "mb_mapObj[index].wms[current_wms_index].objLayer[current_layer_index].gui_layer_querylayer = " . $querylayer_yn . ";\n";
@@ -601,29 +1187,31 @@
 							// add layer
-							$wmc_string .= "\t" . $target . "wms_add_layer('0','".
+							$wmc_string .= "\t" . $target . "wms_add_layer('".
+								($this->wmc_layer_parent[$ii]!=""?$this->wmc_layer_parent[$ii]:"0") . "','".
 								$this->wmc_layer_id[$ii] . "','".
 								$this->wmc_layer_name[$ii] . "','".
 								$this->wmc_layer_title[$ii] ."','".
 								$this->wmc_layer_dataurl[$ii] . "','".
-								intval($cnt_layers) ."','".
+								($this->wmc_layer_pos[$ii]!=""?$this->wmc_layer_pos[$ii]:intval($cnt_layers)) ."','".
 								$this->wmc_layer_queryable[$ii] ."','".
 								$this->wmc_layer_minscale[$ii]  ."','".
 								$this->wmc_layer_maxscale[$ii]  ."','".
 								$this->wmc_layer_metadataurl[$ii] ."','".
-								$this->wmc_wms_id[$ii] ."','1','1','".
+								$this->wmc_wms_id[$i] ."','1','', '1','".
 								intval(!$this->wmc_layer_hidden[$ii]) ."','".
-								$this->wmc_layer_querylayer[$ii] ."','".
-								$this->wmc_layer_minscale[$ii]  ."','".
-								$this->wmc_layer_maxscale[$ii]  ."');\n";
+								($this->wmc_layer_querylayer[$ii]!=""?$this->wmc_layer_querylayer[$ii]:$this->wmc_layer_queryable[$ii]) ."','".
+								($this->wmc_gui_layer_minscale[$ii]!=""?$this->wmc_gui_layer_minscale[$ii]:$this->wmc_layer_minscale[$ii]) ."','".
+								($this->wmc_gui_layer_maxscale[$ii]!=""?$this->wmc_gui_layer_maxscale[$ii]:$this->wmc_layer_maxscale[$ii]) ."','".
+								$this->wmc_layer_wfs_featuretype[$ii] . "');\n";
 							// if layer is queryable, add it to querylayerlist
-							if ($this->wmc_layer_queryable[$ii]) {
+							if (($this->wmc_layer_querylayer[$ii]!=""?$this->wmc_layer_querylayer[$ii]:$this->wmc_layer_queryable[$ii])) {
 								$cnt_query_layers++;
 								if (!in_array($this->wmc_layer_name[$ii], explode(",",$querylayerlist))) {
 									if ($querylayerlist == "") {$querylayerlist = $this->wmc_layer_name[$ii];} else {$querylayerlist .= "," . $this->wmc_layer_name[$ii];}
@@ -666,30 +1254,57 @@
 			$wmc_string .= "\t\tvar found = false;\n";
 			$wmc_string .= "\t\tfor (var j=0; j < " . $target . "wms.length && found == false; j++) {\n";
 			$wmc_string .= "\t\t\tif (" . $target . "wms[j].wms_getmap == old_mapObj[i].wms[0].wms_getmap) {\n";
-			$wmc_string .= "\t\t\t\t" . $target . "mb_registerMapObj('overview', old_mapObj[i].elementName, j, old_mapObj[i].width,  old_mapObj[i].height);\n";
+			$wmc_string .= "\t\t\t\t" . $target . "mb_registerMapObj('overview', old_mapObj[i].elementName, j, old_mapObj[i].width,  old_mapObj[i].width);\n";
 			$wmc_string .= "\t\t\t\tfound = true;\n";
 			$wmc_string .= "\t\t\t}\n";
 			$wmc_string .= "\t\tif (!found) {\n";
-			$wmc_string .= "\t\t\t" . $target . "mb_registerMapObj('overview', old_mapObj[i].elementName, 0, old_mapObj[i].width,  old_mapObj[i].height);\n";
+			$wmc_string .= "\t\t\t" . $target . "mb_registerMapObj('overview', old_mapObj[i].elementName, 0, old_mapObj[i].width,  old_mapObj[i].width);\n";
-			$sql = "SELECT minx, miny, maxx, maxy FROM layer_epsg WHERE fkey_layer_id = $1 AND epsg = $2 LIMIT 1";
-			$v = array($this->wmc_layer_id[0], $this->wmc_bBox_SRS);
-			$t = array('i', 's');
-			$row = db_fetch_array($res);
-			if ($row["minx"] && $row["miny"] && $row["maxx"] && $row["maxy"]) {
-				$ov_bbox = array($row["minx"],$row["miny"],$row["maxx"],$row["maxy"]);
+			$ov_bbox = array();
+			// compute the union of the overview and the mapframe bbox for the new overview bbox
+			if ($this->wmc_general_extension["ov_minx"] && $this->wmc_general_extension["ov_miny"] &&
+				$this->wmc_general_extension["ov_maxx"] && $this->wmc_general_extension["ov_maxy"]) {
+				// box for overview
+				$ov_min = new Mapbender_point($this->wmc_general_extension["ov_minx"], $this->wmc_general_extension["ov_miny"], $this->wmc_bBox_SRS);
+				$ov_max = new Mapbender_point($this->wmc_general_extension["ov_maxx"], $this->wmc_general_extension["ov_maxy"], $this->wmc_bBox_SRS);
+				$ov_box = new Mapbender_bbox($ov_min, $ov_max, $this->wmc_bBox_SRS);
+				// box for mapframe
+				$mf_min = new Mapbender_point($this->wmc_bBox_minx, $this->wmc_bBox_miny, $this->wmc_bBox_SRS);
+				$mf_max = new Mapbender_point($this->wmc_bBox_maxx, $this->wmc_bBox_maxy, $this->wmc_bBox_SRS);
+				$mf_box = new Mapbender_bbox($mf_min, $mf_max, $this->wmc_bBox_SRS);
+				$unionBox = Mapbender_bbox::union(array($ov_box, $mf_box));
+				array_push($ov_bbox, $unionBox->min->x);
+				array_push($ov_bbox, $unionBox->min->y);
+				array_push($ov_bbox, $unionBox->max->x);
+				array_push($ov_bbox, $unionBox->max->y);
-			else if ($this->wmc_layer_id[0] && $this->wmc_bBox_SRS){
-				$ov_bbox = array($this->wmc_bBox_minx, $this->wmc_bBox_miny, $this->wmc_bBox_maxx, $this->wmc_bBox_maxy);
 			else {
-				$ov_bbox = array();
+				$sql = "SELECT minx, miny, maxx, maxy FROM layer_epsg WHERE fkey_layer_id = $1 AND epsg = $2 LIMIT 1";
+				$v = array($this->wmc_layer_id[0], $this->wmc_bBox_SRS);
+				$t = array('i', 's');
+				$row = db_fetch_array($res);
+				if ($row["minx"] && $row["miny"] && $row["maxx"] && $row["maxy"]) {
+					$ov_bbox = array($row["minx"],$row["miny"],$row["maxx"],$row["maxy"]);
+				else if ($this->wmc_layer_id[0] && $this->wmc_bBox_SRS){
+					$ov_bbox = array($this->wmc_bBox_minx, $this->wmc_bBox_miny, $this->wmc_bBox_maxx, $this->wmc_bBox_maxy);
+				else {
+					$ov_bbox = array(2412139.175257732, 5365000, 2767860.824742268, 5700000);
 			$wmc_string .= "for (var i=0; i<old_mapObj.length; i++) {\n";
 			$wmc_string .= "\tif (old_mapObj[i].frameName != 'overview') {\n";
 			$wmc_string .= "\t\t".$target."mb_calculateExtent(old_mapObj[i].frameName, ";
@@ -697,25 +1312,16 @@
 			$wmc_string .= $this->wmc_bBox_maxx .",".$this->wmc_bBox_maxy.");\n";
 			$wmc_string .= "\telse {\n";
-			if (count($ov_bbox)>0) {
-//				$wmc_string .= "alert('found bbox for ov: ".implode(',',$ov_bbox)."');";
-				$wmc_string .= "\t\t".$target."mb_calculateExtent(old_mapObj[i].frameName, ";
-				$wmc_string .= $ov_bbox[0] .",".$ov_bbox[1] .",";
-				$wmc_string .= $ov_bbox[2] .",".$ov_bbox[3] .");\n";
-			else {
-//				$wmc_string .= "alert('no bbox found for ov: old bbox ".$this->wmc_bBox_minx." etc');";
-				$wmc_string .= $this->wmc_bBox_minx .",".$this->wmc_bBox_miny .",";
-				$wmc_string .= $this->wmc_bBox_maxx .",".$this->wmc_bBox_maxy.");\n";
-//				$wmc_string .= "\t\tvar ov_index = " . $target . "getMapObjIndexByName('overview');\n";
-//				$wmc_string .= "\t\t" . $target . "mb_mapObj[ov_index].extent = old_mapObj[i].extent;\n";
+			$wmc_string .= "\t\t".$target."mb_calculateExtent(old_mapObj[i].frameName, ";
+			$wmc_string .= $ov_bbox[0] .",".$ov_bbox[1] .",";
+			$wmc_string .= $ov_bbox[2] .",".$ov_bbox[3] .");\n";
 			$wmc_string .= "\t". $target . "setMapRequest(old_mapObj[i].frameName);\n";
 			$wmc_string .= $target . "mb_execloadWmsSubFunctions();\n";
+			$wmc_string .= $target . "mb_execloadWmcSubFunctions();\n";
+//		$e = new mb_exception("js code: " . $wmc_string);
 		return $wmc_string;
More information about the Mapbender_commits mailing list
