[Mapbender-commits] r1860 - trunk/mapbender/http/javascripts
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Tue Nov 27 09:22:37 EST 2007
Author: christoph
Date: 2007-11-27 09:22:36 -0500 (Tue, 27 Nov 2007)
New Revision: 1860
   trunk/mapbender/http/javascripts/mod_digitize_tab.php
kml enhancement
Modified: trunk/mapbender/http/javascripts/mod_digitize_tab.php
--- trunk/mapbender/http/javascripts/mod_digitize_tab.php	2007-11-26 13:41:25 UTC (rev 1859)
+++ trunk/mapbender/http/javascripts/mod_digitize_tab.php	2007-11-27 14:22:36 UTC (rev 1860)
@@ -81,11 +81,34 @@
 var digitizeDivTag;
+var GeometryArray = parent.GeometryArray;
+var MultiGeometry = parent.MultiGeometry;
+var Geometry = parent.Geometry;
+var Point = parent.Point;
+var geomType = parent.geomType;
 var msgObj;
 var featureTypeElementFormId = "featureTypeElementForm";
 try {if(mod_digitize_elName){}}catch(e) {mod_digitize_elName = "digitize";}
+ * Append geometries from KML when KML has been loaded
+function appendGeometryArrayFromKML () {
+	try {
+		parent.kmlHasLoaded.register(function(properties){
+			d = parent.geoJsonToGeometryArray(properties);
+			executeDigitizeSubFunctions();
+	catch (e) {
+		var exc = new parent.Mb_warning(e);
 // --- polygon, line, point insertion (begin) ----------------------------------------------------------------------------------------------
@@ -348,9 +371,11 @@
 function executeDigitizeSubFunctions(){
+//	console.profile();
 	for(var i=0; i<mod_digitizeSubFunctions.length; i++){
 		eval(mod_digitizeSubFunctions[i]);
+//	console.profileEnd();
 function executeDigitizePreFunctions(){
@@ -372,13 +397,14 @@
 	parent.mb_registerInitFunctions("window.frames['"+ mod_digitize_elName + "'].checkDigitizeTag()");
 	parent.mb_registerInitFunctions("window.frames['"+ mod_digitize_elName + "'].initialiseSnapping()");
 	parent.mb_registerL10nFunctions("window.frames['"+ mod_digitize_elName + "'].getMessages()");
+	parent.mb_registerInitFunctions("window.frames['"+ mod_digitize_elName + "'].appendGeometryArrayFromKML()");
 	if (!nonTransactionalEditable) {
 		parent.mb_registerInitFunctions("window.frames['"+ mod_digitize_elName + "'].initialiseHighlight()");
 	parent.mb_registerInitFunctions("window.frames['"+ mod_digitize_elName + "'].initialiseMeasure()");
 	parent.mb_registerSubFunctions("window.frames['" + mod_digitize_elName + "'].updateExtent()");
 	if(spatialRequestResultToDigitize==1){
-		parent.mb_registerWfsReadSubFunctions(function(geom){parent.tab_open(mod_digitize_elName);parent.window.frames[mod_digitize_elName].appendGeometryArray(geom);});
+	parent.mb_registerWfsReadSubFunctions(function(geom){parent.tab_open(mod_digitize_elName);parent.window.frames[mod_digitize_elName].appendGeometryArray(geom);});
 	parent.mb_registerWfsWriteSubFunctions(function(){parent.zoom(mod_digitize_target, true, 0.999);});
@@ -640,75 +666,84 @@
 		nonTransactionalHighlight.clean();
-	var smP = "";
-	smP += "<div class='t_img'>";
-	smP += "<img src='"+parent.mb_trans.src+"' width='"+mod_digitize_width+"' height='0'></div>";
-	smP += "<img src='"+parent.mb_trans.src+"' width='0' height='"+mod_digitize_height+"'></div>";
-	for(var i=0; i<d.count(); i++){
-		if (!nonTransactionalEditable && !isTransactional(d.get(i))) {
-			nonTransactionalHighlight.add(d.get(i), nonTransactionalColor);
+	var smPArray = [];
+	smPArray[smPArray.length] = "<div class='t_img'>"
+			+ "<img src='"+parent.mb_trans.src+"' width='"+mod_digitize_width+"' height='0'></div>"
+			+ "<div class='t_img'>"
+			+ "<img src='"+parent.mb_trans.src+"' width='0' height='"+mod_digitize_height+"'></div>";
+	for(var i=0, lenGeomArray = d.count(); i < lenGeomArray; i++){
+		var currentGeomArray = d.get(i);
+		if (!nonTransactionalEditable && !isTransactional(currentGeomArray)) {
+			nonTransactionalHighlight.add(currentGeomArray, nonTransactionalColor);
 		else {
-			for(var j=0; j<d.get(i).count(); j++){
-				for(var k = 0; k < d.getGeometry(i,j).count(); k++){
-					var pos = parent.makeRealWorld2mapPos(mod_digitize_target,d.getPoint(i,j,k).x,d.getPoint(i,j,k).y);
+			for(var j=0, lenGeom = currentGeomArray.count(); j < lenGeom ; j++){
+				var currentGeometry = d.getGeometry(i,j);
+				for(var k = 0, lenPoint = currentGeometry.count(); k < lenPoint; k++){
+					var currentPoint = d.getPoint(i,j,k);
+					var pos = parent.makeRealWorld2mapPos(mod_digitize_target, currentPoint.x, currentPoint.y);
-					if (!d.getGeometry(i,j).isComplete() &&
-						( (k == 0 && d.get(i).geomType == parent.geomType.polygon) || (k == d.getGeometry(i,j).count()-1 && d.get(i).geomType == parent.geomType.line))) {
-						smP += "<div class='bp' style='top:"+(pos[1]-2)+"px;left:"+(pos[0]-2)+"px;z-index:"+digitizeTransactionalZIndex+";background-color:"+linepointColor+"'";
+					if (!currentGeometry.isComplete() &&
+						( (k == 0 && currentGeomArray.geomType == parent.geomType.polygon) || (k == currentGeometry.count()-1 && currentGeomArray.geomType == parent.geomType.line))) {
+						smPArray[smPArray.length] = "<div class='bp' style='top:"+
+							(pos[1]-2)+"px;left:"+(pos[0]-2)+"px;z-index:"+
+							digitizeTransactionalZIndex+";background-color:"+linepointColor+"'";
 					else {
-						smP += "<div class='bp' style='top:"+(pos[1]-2)+"px;left:"+(pos[0]-2)+"px;z-index:"+digitizeTransactionalZIndex+";'";
+						smPArray[smPArray.length] = "<div class='bp' style='top:"+(pos[1]-2)+"px;left:"+(pos[0]-2)+"px;z-index:"+digitizeTransactionalZIndex+";'";
-					if(j==0 && d.get(i).geomType == parent.geomType.polygon && !d.getGeometry(i,j).isComplete()){
-						smP += " title='"+closePolygon_title+"' ";
+					if(j==0 && currentGeomArray.geomType == parent.geomType.polygon && !currentGeometry.isComplete()){
+						smPArray[smPArray.length] = " title='"+closePolygon_title+"' ";
 					if(mod_digitizeEvent == button_move || mod_digitizeEvent == button_insert || mod_digitizeEvent == button_delete) {
-						smP += " onmouseover='parent.window.frames[\""+mod_digitize_elName+"\"].handleBasepoint(this,"+i+","+j+","+k+")' ;";
+						smPArray[smPArray.length] = " onmouseover='parent.window.frames[\""+mod_digitize_elName+"\"].handleBasepoint(this,"+i+","+j+","+k+")' ;";
-					smP += "></div>";
+					smPArray[smPArray.length] = "></div>";
-				var mapObjInd = parent.getMapObjIndexByName(mod_digitize_target);
-				for(var k = 1; k < d.getGeometry(i,j).count(); k++){
+				var mapObj = parent.mb_mapObj[parent.getMapObjIndexByName(mod_digitize_target)];
+				for(var k = 1; k < currentGeometry.count(); k++){
 					var p0 = parent.realToMap(mod_digitize_target, d.getPoint(i,j,k));
 					var p1 = parent.realToMap(mod_digitize_target, d.getPoint(i,j,k-1));
-					points = parent.calculateVisibleDash(p0, p1, parent.mb_mapObj[mapObjInd].width, parent.mb_mapObj[mapObjInd].height);
+					points = parent.calculateVisibleDash(p0, p1, mapObj.width, mapObj.height);
 					if (points != false) {
-						smP += evaluateDashes(points[0], points[1], i, j, k);
+						smPArray[smPArray.length] = evaluateDashes(points[0], points[1], i, j, k);
-	digitizeDivTag.write(smP);
+	digitizeDivTag.write(smPArray.join(""));
 function evaluateDashes(start, end, memberIndex, geomIndex, pointIndex){
-	var str_dashedLine = "";
+	var strArray = [];
 	var delta = new parent.Point(end.x - start.x, end.y - start.y);
+	var lastGeomIsComplete = d.getGeometry(-1,-1).isComplete();
 	var vecLength = start.dist(end);
 	var n = Math.round(vecLength/dotDistance);
-	var step = new parent.Point(delta.x/n, delta.y/n);
-	for(var i=1; i<n; i++){
+	if (n > 0) {
+		var step = delta.dividedBy(n);
+	for(var i=1; i < n; i++){
 		var x = Math.round(start.x + i * step.x) - 2;
 		var y = Math.round(start.y + i * step.y) - 2;
 		if(x >= 0 && x <= mod_digitize_width && y >= 0 && y <= mod_digitize_height){
-			if (memberIndex == d.count()-1 && !d.getGeometry(-1,-1).isComplete()) {
-				str_dashedLine += "<div class='lp' style='top:"+y+"px;left:"+x+"px;z-index:"+digitizeTransactionalZIndex+";background-color:"+linepointColor+"' ";
+			if (memberIndex == d.count()-1 && !lastGeomIsComplete) {
+				strArray[strArray.length] = "<div class='lp' style='top:"+y+"px;left:"+x+"px;z-index:"+digitizeTransactionalZIndex+";background-color:"+linepointColor+"' ";
 			else {
-				str_dashedLine += "<div class='lp' style='top:"+y+"px;left:"+x+"px;z-index:"+digitizeTransactionalZIndex+";' ";
+				strArray[strArray.length] = "<div class='lp' style='top:"+y+"px;left:"+x+"px;z-index:"+digitizeTransactionalZIndex+";' ";
 			if(mod_digitizeEvent == button_insert) {
-				str_dashedLine += "onmouseover='parent.window.frames[\""+mod_digitize_elName+"\"].convertLinepointToBasepoint(this,"+memberIndex+","+geomIndex+","+pointIndex+")'";
+				strArray[strArray.length] = "onmouseover='parent.window.frames[\""+mod_digitize_elName+"\"].convertLinepointToBasepoint(this,"+memberIndex+","+geomIndex+","+pointIndex+")'";
-			str_dashedLine += "></div>";
+			strArray[strArray.length] = "></div>";
-	return str_dashedLine;
+	return strArray.join("");
 function isTransactional(geom) {
@@ -748,6 +783,9 @@
 		return resultName;
+	else if (geom.e.getElementValueByName("name")) {
+		return geom.e.getElementValueByName("name");
 	else {
 		return msgObj.digitizeDefaultGeometryName;
@@ -758,15 +796,32 @@
 	if (d.count() > 0) {
 		wfsConf = parent.get_complete_wfs_conf();
 		for (var i = 0 ; i < d.count(); i ++) {
 			if (d.get(i).get(-1).isComplete() && (nonTransactionalEditable || isTransactional(d.get(i)))) {
-				listOfGeom += "\t<tr>\n\t\t<td>\n";
-				if (wfsExistsForGeom(d.get(i), wfsConf)) {
-					listOfGeom += "\t\t\t<img src = '"+buttonDig_imgdir+buttonDig_wfs_src+"' title='"+msgObj.buttonDig_wfs_title+"' onclick='showWfs("+i+")'>\n";
+				// for the geometries from a kml, there is another save dialogue
+				if (d.get(i).isFromKml()) {
+					// if the kml is in the db (id = id in database)
+					if (d.get(i).e.getElementValueByName("Mapbender:id")) {
+						// button: geometry information, update kml
+						listOfGeom += "\t<tr>\n\t\t<td>\n";
+						listOfGeom += "\t\t\t<img src = '"+buttonDig_imgdir+buttonDig_wfs_src+"' title='"+msgObj.buttonDig_wfs_title+"' onclick='showWfsKml("+i+")'>\n";
+				else {
+					// button: geometry information, save, update, delete
+					if (wfsExistsForGeom(d.get(i), wfsConf)) {
+						listOfGeom += "\t\t\t<img src = '"+buttonDig_imgdir+buttonDig_wfs_src+"' title='"+msgObj.buttonDig_wfs_title+"' onclick='showWfs("+i+")'>\n";
+					listOfGeom += "\t\t</td>\n\t\t<td>\n";
+					// button: remove this geometry
+					listOfGeom += "\t\t\t<img src = '"+buttonDig_imgdir+buttonDig_remove_src+"' title='"+msgObj.buttonDig_remove_title+"' onclick='parent.mb_disableThisButton(mod_digitizeEvent);d.del("+i+");executeDigitizeSubFunctions();'>\n";
-				listOfGeom += "\t\t\t<img src = '"+buttonDig_imgdir+buttonDig_remove_src+"' title='"+msgObj.buttonDig_remove_title+"' onclick='parent.mb_disableThisButton(mod_digitizeEvent);d.del("+i+");executeDigitizeSubFunctions();'>\n";
-				listOfGeom += "\t\t</td>\n\t\t<td>\n";
+				// button: remove geometry from database
 				if (isValidWfsConfIndex(wfsConf, d.get(i).wfs_conf)) {
 					listOfGeom += "\t\t\t<img src = '"+buttonDig_imgdir+buttonDig_removeDb_src+"' title='"+msgObj.buttonDig_removeDb_title+"' onclick=\"var deltrans = confirm('"+msgObj.messageConfirmDeleteGeomFromDb+"');if (deltrans) dbGeom('delete', "+i+")\">\n";
@@ -958,6 +1013,46 @@
+function showWfsKml (geometryIndex) {
+	wfsKmlWindow = open("", "wfsattributes", "width="+wfsWindowWidth+", height="+wfsWindowHeight+", resizable, dependent=yes, scrollbars=yes");
+	wfsKmlWindow.document.open("text/html");
+	wfsKmlWindow.document.writeln("<html><head></head><body><div id='linkToKml'></div><div id='elementForm'></div></body></html>");
+	wfsKmlWindow.document.close();
+	str = "<form id = 'wmsKmlForm' onsubmit='return false;'><table>";
+	var properties = d.get(geometryIndex).e;
+	var propertyCount = properties.count();
+	for (var i = 0; i < propertyCount; i++) {
+		var key = properties.getName(i);
+		var value = properties.getValue(i);
+		var expr = /Mapbender:/;
+		if (!key.match(expr)) {
+			str += "\t\t<tr>\n";
+			str += "\t\t\t<td>\n\t\t\t\t<div>" + key + "</div>\n\t\t\t</td>\n";
+			str += "\t\t\t<td>\n";
+			str += "\t\t\t\t<input id = 'wmskml_" + i + "' name='" + key + "' type='text' size=20 value = '" + value + "'>\n";
+			str += "\t\t\t</td>\n\t\t</tr>\n";
+	var updateOnClickText = "this.disabled=true;window.opener.updateKmlInDb("+geometryIndex+", 'update');";
+	var deleteOnClickText = "var deltrans = confirm('This geometry will be removed from the KML.');";
+	deleteOnClickText += "if (deltrans){";
+	deleteOnClickText += "this.disabled=true;window.opener.updateKmlInDb("+geometryIndex+", 'delete')}";
+	str += "\t\t\t<td><input type='button' name='updateButton' value='Update' onclick=\""+updateOnClickText+"\"/></td>\n";
+// delete button not yet implemented
+//	str += "\t\t\t<td><input type='button' name='deleteButton' value='Delete' onclick=\""+deleteOnClickText+"\"/></td>\n";
+	str += "\t\t\t<td><input type='button' name='abortButton' value='Abort' onclick=\"window.close();\" /></td>\n";
+	str += "\t\t</tr>\n";
+	str += "\t</table>\n";
+	str += "</form>\n";
+	wfsKmlWindow.document.getElementById("elementForm").innerHTML = str;
 // this method opens a new window and displays the attributes in wfs_conf
@@ -1234,6 +1329,62 @@
 		alert(wfsWriteMessage);
+function getMultiGeometryIdsByPlacemarkId (placemarkId) {
+	var multiGeometryIdArray = [];
+	for (var i = 0; i < d.count(); i++) {
+		var currentPlacemarkId = d.get(i).e.getElementValueByName("Mapbender:placemarkId");
+		if (currentPlacemarkId && currentPlacemarkId == placemarkId) {
+			multiGeometryIdArray.push(i);
+	return multiGeometryIdArray;
+function updateKmlInDb (geometryIndex, command) {
+	var placemarkId = properties.getElementValueByName("Mapbender:placemarkId");
+	var multiGeometryIdArray = getMultiGeometryIdsByPlacemarkId(placemarkId);
+	if (typeof(wfsKmlWindow) != 'undefined' && !wfsKmlWindow.closed) {
+		// update properties from form
+		myform = wfsKmlWindow.document.getElementById("wmsKmlForm");
+		for (var i=0; i < myform.length; i++){
+			if (myform.elements[i].type == 'text' ){
+				if (myform.elements[i].id) {
+					var key = myform.elements[i].name;
+					var value = myform.elements[i].value;
+					// update all geometries with the same placemark id
+					for (var j = 0; j < multiGeometryIdArray.length; j++) {
+						var currentProperties = d.get(j).e;
+						currentProperties.setElement(key, value);
+		var kmlId = properties.getElementValueByName("Mapbender:id");
+		parent.mb_ajax_post("../php/mod_updateKmlInDb.php", {command:command, kmlId:kmlId, placemarkId:placemarkId, geoJSON:d.placemarkToString(placemarkId)}, function(obj, status) {
+			if (obj === "1") {
+				wfsKmlWindow.alert("KML updated.");
+				var link = wfsKmlWindow.document.createElement("a");
+				link.href = "../php/mod_displayKML.php?kmlId=" + kmlId;
+				link.target = "_blank";
+				link.innerHTML = "KML";
+				wfsKmlWindow.document.getElementById('elementForm').innerHTML = "";
+				wfsKmlWindow.document.getElementById('linkToKml').appendChild(link);
+			else {
+				wfsKmlWindow.alert("Error, KML could not be updated. Check your error log.");
 // --- wfs window (begin) -----------------------------------------------------------------------------------------
More information about the Mapbender_commits mailing list
