[Mapbender-commits] r1873 - trunk/mapbender/resources/db/update
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri Nov 30 09:42:29 EST 2007
Author: verenadiewald
Date: 2007-11-30 09:42:29 -0500 (Fri, 30 Nov 2007)
New Revision: 1873
   trunk/mapbender/resources/db/update/update_mysql_db.sql
   trunk/mapbender/resources/db/update/update_postgresql_db.sql
transfered element_var sqls to update_guis.sql files
Modified: trunk/mapbender/resources/db/update/update_mysql_db.sql
--- trunk/mapbender/resources/db/update/update_mysql_db.sql	2007-11-30 12:58:15 UTC (rev 1872)
+++ trunk/mapbender/resources/db/update/update_mysql_db.sql	2007-11-30 14:42:29 UTC (rev 1873)
@@ -74,11 +74,6 @@
 INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Search', 'Suche');
 INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Meetingpoint', 'Treffpunkt');
 INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Metadatasearch', 'Metadatensuche');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'gazetteerWFS', 'maxHighlightedPoints', '500', 'max number of points to highlight', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'gazetteerWFS', 'maxHighlightedPoints', '500', 'max number of points to highlight', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'gazetteerWFS', 'maxHighlightedPoints', '500', 'max number of points to highlight', 'var');
Modified: trunk/mapbender/resources/db/update/update_postgresql_db.sql
--- trunk/mapbender/resources/db/update/update_postgresql_db.sql	2007-11-30 12:58:15 UTC (rev 1872)
+++ trunk/mapbender/resources/db/update/update_postgresql_db.sql	2007-11-30 14:42:29 UTC (rev 1873)
@@ -203,11 +203,4 @@
 INSERT INTO translations (locale, msgid, msgstr) VALUES ('de ', 'Logo', 'Logo');
 INSERT INTO translations (locale, msgid, msgstr) VALUES ('de', 'Measure distance', 'Streckenabschnittsmessung');
- -- table gui_element_vars: new element var for max number of highlighted points in WFSGazetteer (guis 'gui', 'gui_digitize', 'gui2')
- INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'gazetteerWFS', 'maxHighlightedPoints', '500', 'max number of points to highlight', 'var');
More information about the Mapbender_commits mailing list
