[Mapbender-commits] r1876 - trunk/mapbender/resources/db/update
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri Nov 30 10:08:58 EST 2007
Author: astrid_emde
Date: 2007-11-30 10:08:58 -0500 (Fri, 30 Nov 2007)
New Revision: 1876
   trunk/mapbender/resources/db/update/update_guis_utf8.sql
undo - was already in the update sql 'gazetteerWFS', 'maxHighlightedPoints'
Modified: trunk/mapbender/resources/db/update/update_guis_utf8.sql
--- trunk/mapbender/resources/db/update/update_guis_utf8.sql	2007-11-30 15:06:11 UTC (rev 1875)
+++ trunk/mapbender/resources/db/update/update_guis_utf8.sql	2007-11-30 15:08:58 UTC (rev 1876)
@@ -132,8 +132,8 @@
 INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'openfolder', 'false', 'initial open folder', 'var');
 INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'showstatus', 'true', 'show status in folderimages', 'var');
 INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'treeGDE', 'wmsbuttons', 'false', 'wms management buttons', 'var');
- INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui', 'gazetteerWFS', 'maxHighlightedPoints', '500', 'max number of points to highlight', 'var');
 Delete from gui_element where fkey_gui_id ='gui1';
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('gui1','WMS_preferences',2,1,'configure the preferences of each loaded wms','WMS preferences','img','../img/button_blink_red/preferences_off.png','onclick=''window.open("../php/mod_WMSpreferences.php?sessionID","","width=400, height=600, left=300, resizable=yes, scrollbars=yes")''  onmouseover=''this.src = this.src.replace(/_off/,"_over");''  onmouseout=''this.src = this.src.replace(/_over/, "_off");'' ',670,60,24,24,1,'','','','','','mapframe1,treeGDE','','http://www.mapbender.org/index.php/WMS_preferences');
@@ -363,9 +363,9 @@
 INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'treeGDE', 'openfolder', 'false', 'initial open folder', 'var');
 INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'treeGDE', 'showstatus', 'true', 'show status in folderimages', 'var');
 INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'treeGDE', 'wmsbuttons', 'false', 'wms management buttons', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui2', 'gazetteerWFS', 'maxHighlightedPoints', '500', 'max number of points to highlight', 'var');
 Delete from gui_element where fkey_gui_id ='gui_digitize';
@@ -552,9 +552,9 @@
 INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'treeGDE', 'showstatus', 'true', 'show status in folderimages', 'var');
 INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'treeGDE', 'wmsbuttons', 'true', 'wms management buttons', 'var');
 INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'wfs', 'displayWfsResultList', '1', '', 'var');
-INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'gazetteerWFS', 'maxHighlightedPoints', '500', 'max number of points to highlight', 'var');
 Delete from gui_element where fkey_gui_id ='admin1';
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin1','AdminFrame',2,1,'the frame for administration modules','','iframe','','frameborder = "0"',220,20,800,800,NULL ,'','','iframe','','','','','');
More information about the Mapbender_commits mailing list
