[Mapbender-commits] r1714 - trunk/mapbender/http/print
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri Oct 5 10:27:42 EDT 2007
Author: verenadiewald
Date: 2007-10-05 10:27:41 -0400 (Fri, 05 Oct 2007)
New Revision: 1714
   trunk/mapbender/http/print/mod_printPDF.php
new handling for legendurl
Modified: trunk/mapbender/http/print/mod_printPDF.php
--- trunk/mapbender/http/print/mod_printPDF.php	2007-10-05 13:42:47 UTC (rev 1713)
+++ trunk/mapbender/http/print/mod_printPDF.php	2007-10-05 14:27:41 UTC (rev 1714)
@@ -89,103 +89,63 @@
 	document.forms[0].wms_title.value = "";
 	document.forms[0].legendurl.value = "";
 	for(var i=0; i<pt.mb_mapObj[ind].wms.length; i++){
-		if(pt.mb_mapObj[ind].wms[i].gui_wms_visible != 0){
-			layers = pt.mb_checkScale(mod_legend_target,ind,i);
-			var layer = layers[0].split(",");
-			var title = layers[2].split(",");
-			var temp_legendurl = layers[3].split(",");
-			var layerparent= layers[4].split(",");
-			if( pt.mb_mapObj[ind].layers[i] != "" && pt.mb_mapObj[ind].layers[i]){
-			   if(i>0 && document.forms[0].wms_id.value!=''){
+		layers = pt.mb_mapObj[ind].wms[i].getLayers(pt.mb_mapObj[ind]);
+		if(layers != "" && layers){
+			if(i>0 && document.forms[0].wms_id.value!=''){
 			    document.forms[0].layers.value += "___";
 			    document.forms[0].wms_id.value += "___";
 			    document.forms[0].wms_title.value += "___";
 			    document.forms[0].legendurl.value += "___";
+			document.forms[0].wms_id.value += pt.mb_mapObj[ind].wms[i].wms_id;
+			document.forms[0].wms_title.value += pt.mb_mapObj[ind].wms[i].wms_title;
+			for(var j=0; j<layers.length; j++){
+				var layer = layers[j];
+				var title = pt.mb_mapObj[ind].wms[i].getTitleByLayerName(layers[j]);
+				var layerStyle = pt.mb_mapObj[ind].wms[i].getCurrentStyleByLayerName(layers[j]);
+				if(layerStyle==false){
+					var temp_legendurl = pt.mb_mapObj[ind].wms[i].getLegendUrlByGuiLayerStyle(layers[j],"default");
+				else{
+					var temp_legendurl = pt.mb_mapObj[ind].wms[i].getLegendUrlByGuiLayerStyle(layers[j],layerStyle);
-				//document.forms[0].layers.value += pt.mb_mapObj[ind].wms[i].objLayer[ii].layer_title; //pt.mb_mapObj[ind].layers[i]	;
-				document.forms[0].wms_id.value += pt.mb_mapObj[ind].wms[i].wms_id;
-				document.forms[0].wms_title.value += pt.mb_mapObj[ind].wms[i].wms_title;
 				//---------- legendurl ----------
-				tmp_name = "";
-				for(var j=0; j<layer.length; j++){
-				 if(layerparent[j] == 0){
-					if(j>0){
-						document.forms[0].layers.value += ",";
-					var l = pt.mb_getchildsbyname(ind,i,layer[j]);
-				 	if (l) {
-				 		document.forms[0].layers.value += title[j];
-				 		if(j>0){
-							document.forms[0].legendurl.value += ",";
-						for (var k=0; k<l["name"].length; k++){
-					 		if (tmp_name != l["title"][k]) {
-					 		    document.forms[0].layers.value += "*"
-					 			if(k>0){
-					 				 document.forms[0].legendurl.value += "*";
-					 			}else{
-					 				 document.forms[0].legendurl.value += '1*';
-								if (l["legendurl"][k] != '' || !l["legendurl"][k]==true){
-									document.forms[0].layers.value += l["name"][k];
-					  				document.forms[0].legendurl.value += l["legendurl"][k];
-								}else{
-									document.forms[0].layers.value += '0';
-									document.forms[0].legendurl.value += '0';
-								tmp_name = l["title"][k];
-					 		}	// if
-						 } // for var k=0
-					} // if (l)
-					else{
-						//prompt (!temp_legendurl[j] ,temp_legendurl[j] + !temp_legendurl[j]);
-							if(j>0){
-							if (temp_legendurl[j]!= '' || !temp_legendurl[j] == 'true'){
-								document.forms[0].legendurl.value += temp_legendurl[j];
-							}else{
-								document.forms[0].legendurl.value +='0';
-					}// else (l)
-				   }//check parent==0
-				}//for var j=0
-				//document.forms[0].legendurl.value += layers[3];
-			} else{
+				tmp_name = "";
+				if(j>0){
+					document.forms[0].layers.value += ",";
+					document.forms[0].layers.value += title;
+				if(j>0){
+					document.forms[0].legendurl.value += ",";
+				if (temp_legendurl!= '' || !temp_legendurl == 'true'){
+					document.forms[0].legendurl.value += temp_legendurl;
+				}else{
+					document.forms[0].legendurl.value +='0';
+		else{
-				document.forms[0].layers.value += "0";
-			    document.forms[0].wms_id.value += "0";
-			    document.forms[0].wms_title.value += "0";
-			    document.forms[0].legendurl.value += "0";
-		}//if
+			document.forms[0].layers.value += "0";
+		    document.forms[0].wms_id.value += "0";
+		    document.forms[0].wms_title.value += "0";
+		    document.forms[0].legendurl.value += "0";
 	}//for
+	//alert(document.forms[0].layers.value+"---"+document.forms[0].wms_id.value+"---"+document.forms[0].wms_title.value+"---"+document.forms[0].legendurl.value);
 function validate(){
More information about the Mapbender_commits mailing list
