[Mapbender-commits] r1681 - in trunk/mapbender/http: extensions frames javascripts
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Wed Sep 26 04:11:53 EDT 2007
Author: nimix
Date: 2007-09-26 04:11:53 -0400 (Wed, 26 Sep 2007)
New Revision: 1681
   trunk/mapbender/http/extensions/json.js
   trunk/mapbender/http/frames/index.php
   trunk/mapbender/http/javascripts/mod_savewmc.php
put jQuery in main window
Modified: trunk/mapbender/http/extensions/json.js
--- trunk/mapbender/http/extensions/json.js	2007-09-25 14:46:17 UTC (rev 1680)
+++ trunk/mapbender/http/extensions/json.js	2007-09-26 08:11:53 UTC (rev 1681)
@@ -4,12 +4,13 @@
     This file adds these methods to JavaScript:
-        array.toJSONString()
-        boolean.toJSONString()
-        date.toJSONString()
-        number.toJSONString()
-        object.toJSONString()
-        string.toJSONString()
+		toJSONString(obj)
+        arrayToJSONString(obj)
+        booleanToJSONString(obj)
+        dateToJSONString(obj)
+        numberToJSONString(obj)
+        objectToJSONString(obj)
+        stringToJSONString(obj)
             These methods produce a JSON text from a JavaScript value.
             It must not contain any cyclical references. Illegal values
             will be excluded.
@@ -18,7 +19,7 @@
             add a toJSONString method to any date object to get a different
             representation.
-        string.parseJSON(filter)
+        parseJSON(string, filter)
             This method parses a JSON text to produce an object or
             array. It can throw a SyntaxError exception.
@@ -41,153 +42,173 @@
     JavaScript Programming Language in the Fourth Edition of the
     ECMAScript standard in 2007.
-if (!Object.prototype.toJSONString) {
-    Array.prototype.toJSONString = function () {
-        var a = ['['], b, i, l = this.length, v;
+function arrayToJSONString(ao){
+	var a = ['['], b, i, l = ao.length, v;
+	function p(s) {
+		if (b) {
+			a.push(',');
+		a.push(s);
+		b = true;
-        function p(s) {
-            if (b) {
-                a.push(',');
-            a.push(s);
-            b = true;
+	for (i = 0; i < l; i += 1) {
+		v = ao[i];
+		switch (typeof v) {
+		case 'undefined':
+		case 'function':
+		case 'unknown':
+			break;
+		case 'object':
+			if (v) {
+				p(toJSONString(v));
+			} else {
+				p("null");
+			break;
+		default:
+	a.push(']');
+	return a.join('');
+function boolToJSONString(bo) {
+	return String(bo);
-        for (i = 0; i < l; i += 1) {
-            v = this[i];
-            switch (typeof v) {
-            case 'undefined':
-            case 'function':
-            case 'unknown':
-                break;
-            case 'object':
-                if (v) {
-                    if (typeof v.toJSONString === 'function') {
-                        p(v.toJSONString());
-                } else {
-                    p("null");
-                break;
-            default:
-        a.push(']');
-        return a.join('');
+function dateToJSONString(dao) {
+	function f(n) {
+		return n < 10 ? '0' + n : n;
-    Boolean.prototype.toJSONString = function () {
-        return String(this);
+	return '"' + dao.getFullYear() + '-' +
+		f(dao.getMonth() + 1) + '-' +
+		f(dao.getDate()) + 'T' +
+		f(dao.getHours()) + ':' +
+		f(dao.getMinutes()) + ':' +
+		f(dao.getSeconds()) + '"';
+function numberToJSONString(no) {
+	return isFinite(no) ? String(no) : "null";
-    Date.prototype.toJSONString = function () {
-        function f(n) {
-            return n < 10 ? '0' + n : n;
-        return '"' + this.getFullYear() + '-' +
-                f(this.getMonth() + 1) + '-' +
-                f(this.getDate()) + 'T' +
-                f(this.getHours()) + ':' +
-                f(this.getMinutes()) + ':' +
-                f(this.getSeconds()) + '"';
-    Number.prototype.toJSONString = function () {
-        return isFinite(this) ? String(this) : "null";
-    Object.prototype.toJSONString = function () {
+function objectToJSONString(ob) {
-        var a = ['{'], b, i, v;
+	var a = ['{'], b, i, v;
-        function p(s) {
-            if (b) {
-                a.push(',');
-            a.push(i.toJSONString(), ':', s);
-            b = true;
+	function p(s) {
+		if (b) {
+			a.push(',');
+		a.push(toJSONString(i), ':', s);
+		b = true;
-        for (i in this) {
-            if (this.hasOwnProperty(i)) {
-                v = this[i];
-                case 'undefined':
-                case 'function':
-                case 'unknown':
-                    break;
-                case 'object':
-                    if (v) {
-                    } else {
-                        p("null");
-                    break;
-                default:
-        a.push('}');
+	for (i in ob) {
+		if (ob.hasOwnProperty(i)) {
+			v = ob[i];
+			case 'undefined':
+			case 'function':
+			case 'unknown':
+				break;
+			case 'object':
+				if (v) {
+				} else {
+					p("null");
+				break;
+			default:
+	a.push('}');
+function stringToJSONString(so){
+	var m = {
+		'\b': '\\b',
+		'\t': '\\t',
+		'\n': '\\n',
+		'\f': '\\f',
+		'\r': '\\r',
+	if (/["\\\x00-\x1f]/.test(so)) {
+		return '"' + so.replace(/([\x00-\x1f\\"])/g, function(a, b) {
+			var c = m[b];
+			if (c) {
+				return c;
+			c = b.charCodeAt();
+			return '\\u00' +
+				Math.floor(c / 16).toString(16) +
+				(c % 16).toString(16);
+	return '"' + so + '"';
-    (function (s) {
-        var m = {
-            '\b': '\\b',
-            '\t': '\\t',
-            '\n': '\\n',
-            '\f': '\\f',
-            '\r': '\\r',
+function toJSONString(o){
+	switch(typeof o){
+	case 'undefined':
+	case 'function':
+	case 'unknown':
+		break;
+	case 'object':
+		if (o.constructor == Array){
+			return arrayToJSONString(o);
+		}else if(o.constructor == Date){
+			return dateToJSONString(o);
+		}else{
+			return objectToJSONString(o);
+	case 'number':
+		return numberToJSONString(o);
+	case 'string':
+		return stringToJSONString(o);
+	case 'boolean':
+		return boolToJSONString(o);
-        s.parseJSON = function (filter) {
-            try {
-                if (/^("(\\.|[^"\\\n\r])*?"|[,:{}\[\]0-9.\-+Eaeflnr-u \n\r\t])+?$/.
-                        test(this)) {
-                    var j = eval('(' + this + ')');
-                    if (typeof filter === 'function') {
-                        function walk(k, v) {
-                            if (v && typeof v === 'object') {
-                                for (var i in v) {
-                                    if (v.hasOwnProperty(i)) {
-                                        v[i] = walk(i, v[i]);
-                            return filter(k, v);
-                        return walk('', j);
-                    return j;
-            } catch (e) {
-            throw new SyntaxError("parseJSON");
-        s.toJSONString = function () {
-            if (/["\\\x00-\x1f]/.test(this)) {
-                return '"' + this.replace(/([\x00-\x1f\\"])/g, function(a, b) {
-                    var c = m[b];
-                    if (c) {
-                        return c;
-                    c = b.charCodeAt();
-                    return '\\u00' +
-                        Math.floor(c / 16).toString(16) +
-                        (c % 16).toString(16);
-            return '"' + this + '"';
-    })(String.prototype);
+function parseJSON(so, filter){
+	var m = {
+		'\b': '\\b',
+		'\t': '\\t',
+		'\n': '\\n',
+		'\f': '\\f',
+		'\r': '\\r',
+	try {
+		if (/^("(\\.|[^"\\\n\r])*?"|[,:{}\[\]0-9.\-+Eaeflnr-u \n\r\t])+?$/.
+				test(so)) {
+			var j = eval('(' + so + ')');
+			if (typeof filter === 'function') {
+				function walk(k, v) {
+					if (v && typeof v === 'object') {
+						for (var i in v) {
+							if (v.hasOwnProperty(i)) {
+								v[i] = walk(i, v[i]);
+					return filter(k, v);
+				return walk('', j);
+			return j;
+	} catch (e) {
+	throw new SyntaxError("parseJSON");
\ No newline at end of file
Modified: trunk/mapbender/http/frames/index.php
--- trunk/mapbender/http/frames/index.php	2007-09-25 14:46:17 UTC (rev 1680)
+++ trunk/mapbender/http/frames/index.php	2007-09-26 08:11:53 UTC (rev 1681)
@@ -77,7 +77,7 @@
 </style>
+<script type='text/javascript' src="../extensions/jquery.js"></script>
 <script type='text/javascript' src="../extensions/json.js"></script>
 <script type='text/javascript' src="../javascripts/point.js"></script>
 <script type='text/javascript' src="../javascripts/map_obj.js"></script>
Modified: trunk/mapbender/http/javascripts/mod_savewmc.php
--- trunk/mapbender/http/javascripts/mod_savewmc.php	2007-09-25 14:46:17 UTC (rev 1680)
+++ trunk/mapbender/http/javascripts/mod_savewmc.php	2007-09-26 08:11:53 UTC (rev 1681)
@@ -63,7 +63,7 @@
 	var ind = getMapObjIndexByName(mod_savewmc_target);
 	var generalTitle = "session";
 	window.frames['ajax'].$.ajaxSetup({async:false}); //TODO: find out why async doesn't work sometimes
-	window.frames['ajax'].$.post("../php/mod_insertWmcIntoDb.php", {"saveInSession":1, "generalTitle":generalTitle, "mapObject":mb_mapObj[ind].toJSONString()}, function (result, status) {
+	window.frames['ajax'].$.post("../php/mod_insertWmcIntoDb.php", {"saveInSession":1, "generalTitle":generalTitle, "mapObject":toJSONString(mb_mapObj[ind])}, function (result, status) {
@@ -78,7 +78,7 @@
 		generalTitle = prompt("Save WMC as...");
 	window.frames['ajax'].$.ajaxSetup({async:false}); //TODO: find out why async doesn't work onunload
-	window.frames['ajax'].$.post("../php/mod_insertWmcIntoDb.php", {"saveInSession":0, "generalTitle":generalTitle, "mapObject":mb_mapObj[ind].toJSONString()}, function (result, status) {
+	window.frames['ajax'].$.post("../php/mod_insertWmcIntoDb.php", {"saveInSession":0, "generalTitle":generalTitle, "mapObject":toJSONString(mb_mapObj[ind])}, function (result, status) {
 		alert(status + ": " + result);
More information about the Mapbender_commits mailing list
