[Mapbender-commits] r2406 - trunk/mapbender/http/classes
svn_mapbender at osgeo.org
Wed Apr 23 11:59:32 EDT 2008
Author: christoph
Date: 2008-04-23 11:59:31 -0400 (Wed, 23 Apr 2008)
New Revision: 2406
Added:
trunk/mapbender/http/classes/class_json.php
trunk/mapbender/http/classes/class_user.php
trunk/mapbender/http/classes/class_weldMaps2Image.php
Removed:
trunk/mapbender/http/classes/class_kml_parser_2.2.php
trunk/mapbender/http/classes/class_administration.php
trunk/mapbender/http/classes/class_gml2.php
trunk/mapbender/http/classes/class_gui.php
trunk/mapbender/http/classes/class_kml_ows.php
trunk/mapbender/http/classes/class_kml_parser_ows.php
trunk/mapbender/http/classes/class_kml_polygon.php
trunk/mapbender/http/classes/class_locale.php
trunk/mapbender/http/classes/class_mb_log.php
trunk/mapbender/http/classes/class_metadata.php
trunk/mapbender/http/classes/class_stripRequest.php
trunk/mapbender/http/classes/class_wfs.php
trunk/mapbender/http/classes/class_wfs_conf.php
trunk/mapbender/http/classes/class_wmc.php
trunk/mapbender/http/classes/class_wms.php
merge w/ 2.5 branch (1)
Modified: trunk/mapbender/http/classes/class_administration.php
--- trunk/mapbender/http/classes/class_administration.php 2008-04-23 13:21:04 UTC (rev 2405)
+++ trunk/mapbender/http/classes/class_administration.php 2008-04-23 15:59:31 UTC (rev 2406)
@@ -18,10 +18,11 @@
require_once(dirname(__FILE__)."/../../conf/mapbender.conf");
require_once(dirname(__FILE__)."/class_mb_exception.php");
+require_once(dirname(__FILE__)."/class_user.php");
$con = db_connect(DBSERVER,OWNER,PW);
db_select_db(DB,$con);
-require("phpmailer-1.72/class.phpmailer.php");
+require(dirname(__FILE__) . "/phpmailer-1.72/class.phpmailer.php");
* class to wrap administration methods
@@ -632,51 +633,13 @@
return $arrayWmc;
- function getGuisByPermission($mb_user_id,$ignoreublic){
- $arrayGuis = array();
- $mb_user_groups = array();
- $sql_groups = "SELECT fkey_mb_group_id FROM mb_user_mb_group WHERE fkey_mb_user_id = $1 ";
- $v = array($mb_user_id);
- $t = array("i");
- $res_groups = db_prep_query($sql_groups,$v,$t);
- $cnt_groups = 0;
- while($row = db_fetch_array($res_groups)){
- $mb_user_groups[$cnt_groups] = $row["fkey_mb_group_id"];
- $cnt_groups++;
- if($cnt_groups > 0){
- $v = array();
- $t = array();
- $sql_g = "SELECT gui.gui_id FROM gui JOIN gui_mb_group ";
- $sql_g .= " ON gui.gui_id = gui_mb_group.fkey_gui_id WHERE gui_mb_group.fkey_mb_group_id IN (";
- for($i=0; $i<count($mb_user_groups);$i++){
- if($i > 0){$sql_g .= ",";}
- $sql_g .= "$".strval($i+1);
- array_push($v,$mb_user_groups[$i]);
- array_push($t,"i");
- $sql_g .= ") GROUP BY gui.gui_id";
- $res_g = db_prep_query($sql_g,$v,$t);
- while($row = db_fetch_array($res_g)){
- array_push($arrayGuis,$row["gui_id"]);
- $sql_guis = "SELECT gui.gui_id FROM gui JOIN gui_mb_user ON gui.gui_id = gui_mb_user.fkey_gui_id";
- $sql_guis .= " WHERE (gui_mb_user.fkey_mb_user_id = $1) ";
- if (!isset($ignore_public) OR $ignore_public== false){
- $sql_guis .= " AND gui.gui_public = 1 ";
- $sql_guis .= " GROUP BY gui.gui_id";
- $t = array("i");
- $res_guis = db_prep_query($sql_guis,$v,$t);
- $guis = array();
- while($row = db_fetch_array($res_guis)){
- if(!in_array($row['gui_id'],$arrayGuis)){
- return $arrayGuis;
+ * @deprecated
+ function getGuisByPermission($mb_user_id,$ignorepublic){
+ $e = new mb_notice("administration->getGuisByPermission is deprecated, use user->getApplicationsByPermission instead!");
+ $user = new User($mb_user_id);
+ return $user->getApplicationsByPermission($ignorepublic);
function getWmsByOwnGuis($array_gui_ids){
@@ -793,7 +756,63 @@
- function getWMSOWSstring($wms_id){
+ * Checks if a user is allowed to access a GUI element
+ * @return boolean
+ * @param $arrayGuis Object
+ * @param $modulePath Object
+ * @param $elementTag Object
+ function checkModulePermission_new($userId, $modulePath, $elementTag){
+ if (CHECK) {
+ $arrayGuis = $this->getGuisByPermission($userId, true);
+ switch ($elementTag) {
+ case "a" :
+ $column = "e_attributes";
+ $pattern = "/^.*href\s*=\s*(\'|\")\.\.((\/[a-zA-Z0-9_\/\.]+)+)(\?|\'|\").*$/";
+ $replace = "$2";
+ break;
+ case "iframe" :
+ $column = "e_src";
+ $pattern = "/^\.\.((\/[a-zA-Z0-9_\/\.]+)+)(\?|\'|\").*$/";
+ $replace = "$1";
+ break;
+ if ($column && count($arrayGuis) > 0) {
+ $v = array();
+ $t = array();
+ $sql = "SELECT DISTINCT ".$column." FROM gui_element WHERE fkey_gui_id IN (";
+ for($i=0; $i<count($arrayGuis); $i++){
+ if($i > 0){ $sql .= ","; }
+ $sql .= "$".($i+1);
+ array_push($v,$arrayGuis[$i]);
+ array_push($t,'s');
+ $sql .= ") ORDER BY " . $column;
+ $res = db_prep_query($sql,$v,$t);
+ while($row = db_fetch_array($res)){
+ if ($row[$column]) {
+ if (preg_match($pattern, stripslashes($row[$column]))) {
+ $dbFilename = preg_replace($pattern, $replace, stripslashes($row[$column]));
+ $e = new mb_notice($dbFilename . " - " . $modulePath);
+ if(strpos($modulePath, $dbFilename) !== false){
+ return true;
+ return false;
+ return true;
+ function getWMSOWSstring($wms_id){
$sql = "SELECT wms_owsproxy FROM wms WHERE wms_id = $1 ";
$v = array($wms_id);
$t = array("i");
@@ -1055,44 +1074,14 @@
/** identifies the Conf-FeatureServices where the current user is owner
+ * @deprecated
* @param integer userid the user-ID of the current user
* @return integer[] the IDs of the wfs_conf-table
- function getWfsConfByPermission($userid){
- $guisByPer = array();
-// 1.
- $guisByPer = $this->getGuisByPermission($userid, true);
-// 2.
- if(count($guisByPer)>0){
- $v = array();
- $t = array();
- $sql = "SELECT wfs_conf.wfs_conf_id FROM gui_wfs_conf, wfs_conf " .
- "where wfs_conf.wfs_conf_id = gui_wfs_conf.fkey_wfs_conf_id " .
- "and gui_wfs_conf.fkey_gui_id IN(";
- for($i=0; $i<count($guisByPer); $i++){
- if($i>0){ $sql .= ",";}
- $sql .= "$".strval($i+1);
- array_push($v, $guisByPer[$i]);
- array_push($t, "s");
- $sql .= ") GROUP BY wfs_conf.wfs_conf_id ORDER BY wfs_conf.wfs_conf_id";
- $res = db_prep_query($sql,$v,$t);
- $ownWFSconfs = array();
- $i=0;
- while($row = db_fetch_array($res)){
- $ownWFSconfs[$i] = $row['wfs_conf_id'];
- $i++;
- return $ownWFSconfs;
+ function getWfsConfByPermission($userid){
+ $e = new mb_notice("administration->getWfsConfByPermission is deprecated, use user->getWfsConfByPermission instead!");
+ $user = new User($userid);
+ return $user->getWfsConfByPermission();
\ No newline at end of file
Modified: trunk/mapbender/http/classes/class_gml2.php
--- trunk/mapbender/http/classes/class_gml2.php 2008-04-23 13:21:04 UTC (rev 2405)
+++ trunk/mapbender/http/classes/class_gml2.php 2008-04-23 15:59:31 UTC (rev 2406)
@@ -1,5 +1,5 @@
<?php
-# $Id: class_gml2.php 2058 2008-02-05 14:39:45Z verenadiewald $
+# $Id$
# http://www.mapbender.org/index.php/class_gml2.php
# Copyright (C) 2002 CCGIS
@@ -18,7 +18,7 @@
# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
require_once("class_mb_exception.php");
require_once("class_connector.php");
-require_once("../extensions/JSON.php");
+require_once("../classes/class_json.php");
require_once("../../conf/mapbender.conf");
class gml2 {
var $geomtype_point = 'Point';
@@ -500,7 +500,7 @@
$cnt ++;
- $json = new Services_JSON();
+ $json = new Mapbender_JSON();
$str .= $json->encode($prop);
$str .= "}";
Modified: trunk/mapbender/http/classes/class_gui.php
--- trunk/mapbender/http/classes/class_gui.php 2008-04-23 13:21:04 UTC (rev 2405)
+++ trunk/mapbender/http/classes/class_gui.php 2008-04-23 15:59:31 UTC (rev 2406)
@@ -1,5 +1,4 @@
<?php
# $Id$
# http://www.mapbender.org/index.php/class_gui.php
@@ -19,253 +18,201 @@
$con = db_connect($DBSERVER,$OWNER,$PW);
-class gui{
+ * GUI is a set of GUI elements and services.
+class gui {
- function gui() {
+ public function __construct () {
- // CB - returns true if a gui '$gui_id' exists
- function guiExists($gui_id){
- $sql = "SELECT * FROM gui ";
- $sql .= "WHERE gui_id = $1";
+ * Checks if a GUI with a given ID exists in the database
+ * @param integer $gui_id the ID of the GUI that is being checked
+ * @return boolean true if a gui '$gui_id' exists; else false
+ public function guiExists ($gui_id){
+ $sql = "SELECT * FROM gui WHERE gui_id = $1";
$v = array($gui_id);
$t = array('s');
$row = db_fetch_array($res);
- if ($row) return true;
- else return false;
+ if ($row) {
+ return true;
+ return false;
- // CB - deletes a GUI $guiId and all its links to users, layers etc.
- function deleteGui ($guiId) {
+ * Deletes a GUI $guiId and all its links to users, layers etc.
+ * @param Integer $guiId the GUI that is going to be deleted
+ * @return boolean true if the deletion succeded, else false
+ public function deleteGui ($guiId) {
$guiList = $guiId;
- $sql = "BEGIN";
- $res = db_query($sql);
- if (!$res) {
- $report .= "<br><br>" . $sql . "<br><br>" . db_error() . "<br>";
- $error = true;
+ $sql = array();
+ $v = array();
+ $t = array();
- $sql = "DELETE FROM gui WHERE gui_id = $1";
- $v = array($guiList);
- $t = array('s');
- if (!$res) {
- $error = true;
+ array_push($sql, "BEGIN");
+ array_push($v, array());
+ array_push($t, array());
+ array_push($sql, "DELETE FROM gui WHERE gui_id = $1");
+ array_push($v, array($guiList));
+ array_push($t, array('s'));
- $sql = "DELETE FROM gui_element WHERE fkey_gui_id = $1";
- $t = array('s');
- if (!$res) {
- $error = true;
+ array_push($sql, "DELETE FROM gui_element WHERE fkey_gui_id = $1");
- $sql = "DELETE FROM gui_element_vars WHERE fkey_gui_id = $1";
- $t = array('s');
- if (!$res) {
- $error = true;
+ array_push($sql, "DELETE FROM gui_element_vars WHERE fkey_gui_id = $1");
- $sql = "DELETE FROM gui_layer WHERE fkey_gui_id = $1";
- $t = array('s');
- if (!$res) {
- $error = true;
+ array_push($sql, "DELETE FROM gui_layer WHERE fkey_gui_id = $1");
- $sql = "DELETE FROM gui_mb_group WHERE fkey_gui_id = $1";
- $t = array('s');
- if (!$res) {
- $error = true;
+ array_push($sql, "DELETE FROM gui_mb_group WHERE fkey_gui_id = $1");
- $sql = "DELETE FROM gui_mb_user WHERE fkey_gui_id = $1";
- $t = array('s');
- if (!$res) {
- $error = true;
+ array_push($sql, "DELETE FROM gui_mb_user WHERE fkey_gui_id = $1");
- $sql = "DELETE FROM gui_treegde WHERE fkey_gui_id = $1";
- $t = array('s');
- if (!$res) {
- $error = true;
+ array_push($sql, "DELETE FROM gui_treegde WHERE fkey_gui_id = $1");
- $sql = "DELETE FROM gui_wfs WHERE fkey_gui_id = $1";
- $t = array('s');
- if (!$res) {
- $error = true;
+ array_push($sql, "DELETE FROM gui_wfs WHERE fkey_gui_id = $1");
- $sql = "DELETE FROM gui_wms WHERE fkey_gui_id = $1";
- $t = array('s');
- if (!$res) {
- $error = true;
+ array_push($sql, "DELETE FROM gui_wms WHERE fkey_gui_id = $1");
- // if $error is true, the transaction is aborted -> rollback
- if (!$error) {
- $sql = "COMMIT";
+ array_push($sql, "COMMIT");
+ // execute all SQLs
+ for ($i = 0; $i < count($sql); $i++) {
+ $res = db_prep_query($sql[$i], $v[$i], $t[$i]);
+ // if an SQL fails, send a ROLLBACK and return false
if (!$res) {
- $error = true;
+ db_query("ROLLBACK");
+ return false;
- //if $error is false, the transaction is executed -> commit
- else {
- $sql = "ROLLBACK";
- if (!$res) {
- $error = true;
- return !$error;
+ return true;
- // CB - rename a GUI
- function renameGui ($guiId, $newGuiName) {
- $error = false;
+ /** Renames the GUI $guiID to $newGUIName
+ * @param Integer $guiId ID of the GUI
+ * @param String $newGuiName the new name of the GUI
+ * @return boolean true if the renaming succeded, else false
+ public function renameGui ($guiId, $newGuiName) {
if ($this->copyGui($guiId, $newGuiName, true)) {
$this->deleteGui($guiId);
+ return true;
- else {
- $error = true;
- return !$error;
+ return false;
- // CB - copies a GUI $guiId and all its links to users, layers etc. to GUI $newGuiName
- function copyGui ($guiId, $newGuiName, $withUsers) {
- $error = false;
+ * Copies a GUI $guiId and all its links to users, layers etc. to GUI $newGuiName
+ * @param boolean $withUsers true if the users, that may access the GUI $guiId, shall have access to the new GUI; else false.
+ public function copyGui ($guiId, $newGuiName, $withUsers) {
$guiList = $guiId;
if (!$this->guiExists($newGuiName)) {
- $sql = "BEGIN";
- if (!$res) {
- $error = true;
+ $sql = array();
+ $v = array();
+ $t = array();
- $sql = "INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) SELECT '" . $newGuiName . "', '" . $newGuiName . "',gui_description, gui_public FROM gui WHERE gui_id = '" . $guiList . "';";
- if (!$res) {
- $error = true;
+ array_push($sql, "INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) SELECT $1, $2, gui_description, gui_public FROM gui WHERE gui_id = $3;");
+ array_push($v, array ($newGuiName, $newGuiName, $guiList));
+ array_push($t, array ("s", "s", "s"));;
+ array_push($sql, "INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) SELECT $1, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url FROM gui_element WHERE fkey_gui_id = $2;");
+ array_push($v, array($newGuiName, $guiList));
+ array_push($t, array("s", "s"));
- $sql = "INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) SELECT '" . $newGuiName . "', e_id, e_pos, e_public, e_comment, e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url FROM gui_element WHERE fkey_gui_id = '" . $guiList . "';";
- if (!$res) {
- $error = true;
+ array_push($sql, "INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT $1, fkey_e_id, var_name, var_value, context, var_type FROM gui_element_vars WHERE fkey_gui_id = $2;");
- $sql = "INSERT INTO gui_element_vars (fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) SELECT '" . $newGuiName . "', fkey_e_id, var_name, var_value, context, var_type FROM gui_element_vars WHERE fkey_gui_id = '" . $guiList . "';";
- if (!$res) {
- $error = true;
+ array_push($sql, "INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) SELECT $1, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype FROM gui_layer WHERE fkey_gui_id = $2;");
- $sql = "INSERT INTO gui_layer (fkey_gui_id, fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype) SELECT '" . $newGuiName . "', fkey_layer_id, gui_layer_wms_id, gui_layer_status, gui_layer_selectable, gui_layer_visible, gui_layer_queryable, gui_layer_querylayer, gui_layer_minscale, gui_layer_maxscale, gui_layer_priority, gui_layer_style, gui_layer_wfs_featuretype FROM gui_layer WHERE fkey_gui_id = '" . $guiList . "';";
- if (!$res) {
- $error = true;
if ($withUsers == true) {
/* group of original gui is copied as well */
- $sql = "INSERT INTO gui_mb_group (fkey_gui_id, fkey_mb_group_id, mb_group_type) SELECT '" . $newGuiName . "', fkey_mb_group_id, mb_group_type FROM gui_mb_group WHERE fkey_gui_id = '" . $guiList . "';";
- if (!$res) {
- $error = true;
+ array_push($sql, "INSERT INTO gui_mb_group (fkey_gui_id, fkey_mb_group_id, mb_group_type) SELECT $1, fkey_mb_group_id, mb_group_type FROM gui_mb_group WHERE fkey_gui_id = $2;");
/* users of original gui are copied as well */
- $sql = "INSERT INTO gui_mb_user (fkey_gui_id, fkey_mb_user_id, mb_user_type) SELECT '" . $newGuiName . "', fkey_mb_user_id, mb_user_type FROM gui_mb_user WHERE fkey_gui_id = '" . $guiList . "';";
- if (!$res) {
- $error = true;
+ array_push($sql, "INSERT INTO gui_mb_user (fkey_gui_id, fkey_mb_user_id, mb_user_type) SELECT $1, fkey_mb_user_id, mb_user_type FROM gui_mb_user WHERE fkey_gui_id = $2;");
else {
// users of original gui are not copied, the current user is set as owner
- $sql = "INSERT INTO gui_mb_user (fkey_gui_id, fkey_mb_user_id, mb_user_type) VALUES ($1, $2, 'owner')";
- $v = array($newGuiName, $_SESSION["mb_user_id"]);
- $t = array('s', 'i');
- if (!$res) {
- $error = true;
+ array_push($sql, "INSERT INTO gui_mb_user (fkey_gui_id, fkey_mb_user_id, mb_user_type) VALUES ($1, $2, 'owner')");
+ array_push($v, array($newGuiName, $_SESSION["mb_user_id"]));
+ array_push($t, array('s', 'i'));
- $sql = "INSERT INTO gui_treegde (fkey_gui_id, fkey_layer_id, id, lft, rgt, my_layer_title, layer, wms_id) SELECT '" . $newGuiName . "', fkey_layer_id, id, lft, rgt, my_layer_title, layer, wms_id FROM gui_treegde WHERE fkey_gui_id = '" . $guiList . "';";
- if (!$res) {
- $error = true;
+ array_push($sql, "INSERT INTO gui_treegde (fkey_gui_id, fkey_layer_id, id, lft, rgt, my_layer_title, layer, wms_id) SELECT $1, fkey_layer_id, id, lft, rgt, my_layer_title, layer, wms_id FROM gui_treegde WHERE fkey_gui_id = $2;");
- $sql = "INSERT INTO gui_wfs (fkey_gui_id, fkey_wfs_id) SELECT '" . $newGuiName . "', fkey_wfs_id FROM gui_wfs WHERE fkey_gui_id = '" . $guiList . "';";
- if (!$res) {
- $error = true;
+ array_push($sql, "INSERT INTO gui_wfs (fkey_gui_id, fkey_wfs_id) SELECT $1, fkey_wfs_id FROM gui_wfs WHERE fkey_gui_id = $2;");
- $sql = "INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) SELECT '" . $newGuiName . "', fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible FROM gui_wms WHERE fkey_gui_id = '" . $guiList . "';";
- if (!$res) {
- $error = true;
+ array_push($sql, "INSERT INTO gui_wms (fkey_gui_id, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible) SELECT $1, fkey_wms_id, gui_wms_position, gui_wms_mapformat, gui_wms_featureinfoformat, gui_wms_exceptionformat, gui_wms_epsg, gui_wms_visible FROM gui_wms WHERE fkey_gui_id = $2;");
- // if $error is false, the transaction is executed -> commit
- if (!$error) {
- $sql = "COMMIT";
- else {
+ if (!$res) {
+ return false;
- if (!$res) {
- $error = true;
- return !$error;
+ return true;
else {
echo "<script language='javascript'>";
Copied: trunk/mapbender/http/classes/class_json.php (from rev 2404, branches/2.5/http/classes/class_json.php)
--- trunk/mapbender/http/classes/class_json.php (rev 0)
+++ trunk/mapbender/http/classes/class_json.php 2008-04-23 15:59:31 UTC (rev 2406)
@@ -0,0 +1,81 @@
+<?php
+# $Id$
+# http://www.mapbender.org/index.php/JSON
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+mb_internal_encoding("UTF-8");
+require_once(dirname(__FILE__)."/../../conf/mapbender.conf");
+require_once(dirname(__FILE__)."/../classes/class_mb_exception.php");
+define("JSON_PEAR", "json_pear");
+define("JSON_NATIVE", "json_native");
+if (!function_exists("json_encode")) {
+ require_once(dirname(__FILE__)."/../classes/class_json.php");
+ * A wrapper class for PHP JSON encoding/decoding.
+ * Uses native PHP functions if available.
+ * @class
+class Mapbender_JSON {
+ * Either JSON_PEAR or JSON_NATIVE
+ private $library = JSON_PEAR;
+ * Determines which JSON lib to use.
+ * @constructor
+ public function __construct(){
+ if (function_exists("json_encode")) {
+ $this->library = JSON_NATIVE;
+ * Encodes an object to JSON
+ public function encode($anObject) {
+ if ($this->library == JSON_PEAR) {
+ $pear = new Mapbender_JSON();
+ $e = new mb_notice("using PEAR JSON");
+ return $pear->encode($anObject);
+ $e = new mb_notice("using native JSON");
+ return json_encode($anObject);
+ * Decodes a JSON string
+ public function decode($aString) {
+ return $pear->decode($aString);
+ return json_decode($aString);
Modified: trunk/mapbender/http/classes/class_kml_ows.php
--- trunk/mapbender/http/classes/class_kml_ows.php 2008-04-23 13:21:04 UTC (rev 2405)
+++ trunk/mapbender/http/classes/class_kml_ows.php 2008-04-23 15:59:31 UTC (rev 2406)
@@ -21,7 +21,7 @@
-require_once(dirname(__FILE__)."/../extensions/JSON.php");
+require_once(dirname(__FILE__)."/../classes/class_json.php");
require_once(dirname(__FILE__)."/../classes/class_point.php");
@@ -108,9 +108,9 @@
$coordinates = "";
for ($j = 0; $j < count($coordinatesArray); $j++) {
if ($j > 0) {
- $coordinates .= ",";
+ $coordinates .= " ";
- $coordinates .= $coordinatesArray[$j]["x"] . "," . $coordinatesArray[$j]["y"];
+ $coordinates .= $coordinatesArray[$j]["x"] . "," . $coordinatesArray[$j]["y"] . ",0";
$e_coordinates = $doc->createElement("coordinates", $coordinates);
@@ -134,6 +134,12 @@
return $this->kml;
+ * @return string the ID of this KML.
+ public function getId () {
+ return $this->id;
* parses an incoming KML, creates the object,
@@ -175,7 +181,7 @@
$e = new mb_notice("parsing finished...#placemarks: " . count($this->placemarkArray) . " (" . count($parser->placemarkArray) . ")");
$this->placemarkArray = $parser->placemarkArray;
- print_r($this);
+// print_r($this);
// $this->kml = $this->__toString();
@@ -227,7 +233,7 @@
$kmlDoc_DOM->loadXML($kmlFromDb);
//load the geoJSON
$geoObj = $json->decode($geoJSON);
// construct an array that holds all metadata of the placemark
@@ -378,7 +384,7 @@
private function updateGeometry ($currentNode, $geometry) {
$currentNode_SimpleXML = simplexml_import_dom($currentNode);
$currentTypeXml = mb_strtoupper($currentNode->nodeName);
Deleted: trunk/mapbender/http/classes/class_kml_parser_2.2.php
--- trunk/mapbender/http/classes/class_kml_parser_2.2.php 2008-04-23 13:21:04 UTC (rev 2405)
+++ trunk/mapbender/http/classes/class_kml_parser_2.2.php 2008-04-23 15:59:31 UTC (rev 2406)
@@ -1,186 +0,0 @@
-<?php
-# $Id$
-# http://www.mapbender.org/index.php/class_wmc.php
-# Copyright (C) 2002 CCGIS
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2, or (at your option)
-# any later version.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
-# GNU General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-require_once("../classes/class_mb_exception.php");
-require_once("../classes/class_kml_polygon.php");
-require_once("../classes/class_kml_linearring.php");
-require_once("../classes/class_kml_line.php");
-require_once("../classes/class_kml_point.php");
-require_once("../classes/class_kml_multigeometry.php");
-require_once("../classes/class_kml_placemark.php");
- * not used in OGC KML Mapbender project, may be buggy
-class Kml22Parser {
- public function __construct($kml) {
- $doc = new DOMDocument("1.0");
- $doc->preserveWhiteSpace = false;
- $doc->loadXML($kml);
- * Get geometry information only, store it in placemarkArray
- $placemarkTagArray = $doc->getElementsByTagName("Placemark");
- foreach ($placemarkTagArray as $node) {
- $geometryArray = $this->getGeometryArrayFromPlacemarkOrMultigeometryNode($node);
- * For a placemark, the geometryArray should only contain 1 geometry!
- for ($i=0; $i < count($geometryArray); $i++) {
- $currentPlacemark = new KMLPlacemark($geometryArray[$i]);
- $currentPlacemark->setName($this->getNameFromPlacemarkNode($node));
- array_push($this->placemarkArray, $currentPlacemark);
- * Given a "Point" node, this function returns the geometry (KMLPoint)
- * from within the node.
- private function getGeometryFromPointNode ($node) {
- $coordinatesNode = $this->getCoordinatesNode($node);
- $geomString = $coordinatesNode->nodeValue;
- return new KMLPoint($geomString);
- * Given a "LineString" node, this function returns the geometry (KMLLine)
- private function getGeometryFromLinestringNode ($node) {
- return new KMLLine($geomString);
- * Given a "Polygon" node, this function returns the geometry (KMLPolygon)
- private function getGeometryFromPolygonNode ($node) {
- $polygon = null;
- $children = $node->childNodes;
- // create new KMLPolygon
- foreach ($children as $child) {
- if (mb_strtoupper($child->nodeName) == "OUTERBOUNDARYIS") {
- // create a new Linear Ring
- $outerBoundary = $this->getGeometryFromLinearRingNode($child);
- $polygon = new KMLPolygon($outerBoundary);
- if ($polygon !== null) {
- // append inner boundaries to KMLPolygon
- if (mb_strtoupper($child->nodeName) == "INNERBOUNDARYIS") {
- $innerBoundary = $this->getGeometryFromLinearRingNode($child);
- $polygon->appendInnerBoundary($innerBoundary);
- return $polygon;
- * Given a "OuterBoundaryIs" or "InnerBoundaryIs" node, this function
- * returns the geometry (KMLLinearRing) within the child node named "linearring"
- private function getGeometryFromLinearRingNode ($node) {
- foreach($children as $child) {
- if (mb_strtoupper($child->nodeName) == "LINEARRING") {
- $coordinatesNode = $this->getCoordinatesNode($child);
- return new KMLLinearRing($geomString);
- return null;
- * Checks if the child nodes of a given KML node contains any geometries and
- * returns an array of geometries (KMLPoint, KMLPolygon, KMLLinestring and KMLMultigeometry)
- private function getGeometryArrayFromPlacemarkOrMultigeometryNode ($node) {
- $geometryArray = array();
- if (mb_strtoupper($child->nodeName) == "POINT") {
- array_push($geometryArray, $this->getGeometryFromPointNode($child));
- elseif (mb_strtoupper($child->nodeName) == "POLYGON") {
- array_push($geometryArray, $this->getGeometryFromPolygonNode($child));
- elseif (mb_strtoupper($child->nodeName) == "LINESTRING") {
- array_push($geometryArray, $this->getGeometryFromLinestringNode($child));
- elseif (mb_strtoupper($child->nodeName) == "MULTIGEOMETRY") {
- $geometryArray = $this->getGeometryArrayFromPlacemarkOrMultigeometryNode($child);
- $multigeometry = new KMLMultiGeometry();
- $multigeometry->append($geometryArray[$i]);
- array_push($geometryArray, $multigeometry);
- return $geometryArray;
- * Returns the name of the placemark from the placemark node
- function getNameFromPlacemarkNode($node) {
- $name = "new";
- if (mb_strtoupper($child->nodeName) == "NAME") {
- $name = $child->nodeValue;
- return $name;
- * Returns the child node with node name "coordinates" of a given KML node.
- * If no node is found, null is returned.
- private function getCoordinatesNode ($node) {
- if (mb_strtoupper($child->nodeName) == "COORDINATES") {
- return $child;
- return null;
-// end class
Modified: trunk/mapbender/http/classes/class_kml_parser_ows.php
--- trunk/mapbender/http/classes/class_kml_parser_ows.php 2008-04-23 13:21:04 UTC (rev 2405)
+++ trunk/mapbender/http/classes/class_kml_parser_ows.php 2008-04-23 15:59:31 UTC (rev 2406)
@@ -17,7 +17,7 @@
require_once(dirname(__FILE__)."/../classes/class_kml_polygon.php");
@@ -37,7 +37,9 @@
public function parseGeoJSON ($geoJSON, $kmlId) {
+// $e = new mb_notice("GEOJSON: " . $geoJSON);
$geometryFromGeoJSON = $json->decode($geoJSON);
$id = 0;
@@ -75,17 +77,20 @@
if ($currentGeometry) {
$currentPlacemark = new KMLPlacemark($currentGeometry);
- foreach ($feature->properties as $key => $value) {
- $currentPlacemark->setProperty($key, $value);
+ if (gettype($feature->properties) == "object") {
+ foreach ($feature->properties as $key => $value) {
+ $currentPlacemark->setProperty($key, $value);
+ $currentPlacemark->setProperty("Mapbender:kml", true);
+ $currentPlacemark->setProperty("Mapbender:name", "unknown");
+ $currentPlacemark->setProperty("Mapbender:id", $kmlId);
+ $currentPlacemark->setProperty("Mapbender:placemarkId", $id);
+ $e = new mb_notice("adding to placemarkArray (current length: " . count($this->placemarkArray) . ")");
+ array_push($this->placemarkArray, $currentPlacemark);
+ $e = new mb_notice("added...new length: " . count($this->placemarkArray));
+ $id ++;
- $currentPlacemark->setProperty("Mapbender:kml", true);
- $currentPlacemark->setProperty("Mapbender:name", "unknown");
- $currentPlacemark->setProperty("Mapbender:id", $kmlId);
- $currentPlacemark->setProperty("Mapbender:placemarkId", $id);
- $e = new mb_notice("adding to placemarkArray (current length: " . count($this->placemarkArray) . ")");
- $e = new mb_notice("added...new length: " . count($this->placemarkArray));
- $id ++;
Modified: trunk/mapbender/http/classes/class_kml_polygon.php
--- trunk/mapbender/http/classes/class_kml_polygon.php 2008-04-23 13:21:04 UTC (rev 2405)
+++ trunk/mapbender/http/classes/class_kml_polygon.php 2008-04-23 15:59:31 UTC (rev 2406)
@@ -1,6 +1,6 @@
<?php
- * $Id$
+ * @version $Id$
* @link http://www.mapbender.org/index.php/class_wmc.php
* @copyright 2002 CCGIS
* @license http://opensource.org/licenses/gpl-license.php
Modified: trunk/mapbender/http/classes/class_locale.php
--- trunk/mapbender/http/classes/class_locale.php 2008-04-23 13:21:04 UTC (rev 2405)
+++ trunk/mapbender/http/classes/class_locale.php 2008-04-23 15:59:31 UTC (rev 2406)
@@ -1,5 +1,5 @@
<?php
-# $Id:$
+# $Id$
# http://www.mapbender.org/index.php/class_locale.php
@@ -33,13 +33,22 @@
var $browserLanguages = null;
var $os = null;
var $name = null;
- var $defaultLanguage = "de";
+ var $defaultLanguage = "en";
var $status = "No locale set.";
function Mb_locale($languageId) {
- if (!$this->setCurrentLocale($languageId)) {
- $e = new Mb_exception("Locale could not be set. Language ID: '" . $languageId . "'");
+ if (!$languageId) {
+ $languageId = LANGUAGE;
+ $e = new Mb_notice("class_locale: setting locale to " . $languageId);
+ if (USE_I18N) {
+ if (!$this->setCurrentLocale($languageId)) {
+ $e = new Mb_exception("Locale could not be set. Language ID: '" . $languageId . "'");
+ else {
+ $this->setCurrentLocale($this->defaultLanguage);
@@ -84,7 +93,7 @@
$this->os = $this->guessHostOS();
- if ($this->os != null && isset($languageId)) {
+ if (!USE_I18N || ($this->os != null && isset($languageId))) {
if ($this->isKnownLanguage($languageId)) {
if ($this->systemLocales == null) {
@@ -122,6 +131,8 @@
return 'linux';
else if (strncasecmp(php_uname(), 'OpenBSD', 7) == 0)
return 'bsd';
+ else if (strncasecmp(php_uname(), 'FreeBSD', 7) == 0)
+ return 'bsd';
else {
throw new Mb_exception('unknown platform: could not interpret uname. php_uname() returned '. php_uname().'. Please report to MB developers');
return null;
@@ -174,6 +185,14 @@
'en' => 'en_US',
'de_DE' => 'de_DE',
'de' => 'de_DE',
+ 'bg_BG' => 'bg_BG',
+ 'bg' => 'bg_BG',
+ 'es_ES' => 'es_ES',
+ 'es' => 'es_ES',
+ 'nl_NL' => 'nl_NL',
+ 'nl' => 'nl_NL',
+ 'gr_GR' => 'gr_GR',
+ 'gr' => 'gr_GR',
'it_IT' => 'it_IT',
'it' => 'it_IT');
Modified: trunk/mapbender/http/classes/class_mb_log.php
--- trunk/mapbender/http/classes/class_mb_log.php 2008-04-23 13:21:04 UTC (rev 2405)
+++ trunk/mapbender/http/classes/class_mb_log.php 2008-04-23 15:59:31 UTC (rev 2406)
@@ -133,11 +133,11 @@
* @var bool true if the logging succeeded; else false.
- protected $result = false;
+ public $result = false;
* @var string if the logging did not succeed, this contains an error message.
- protected $message = "";
+ public $message = "";
Modified: trunk/mapbender/http/classes/class_metadata.php
--- trunk/mapbender/http/classes/class_metadata.php 2008-04-23 13:21:04 UTC (rev 2405)
+++ trunk/mapbender/http/classes/class_metadata.php 2008-04-23 15:59:31 UTC (rev 2406)
@@ -178,8 +178,7 @@
/* set categories as array */
function set_categories(){
$sql = "SELECT * FROM md_topic_category ";
- $sql .= " ORDER BY md_topic_category_id";
+ $sql .= "ORDER BY md_topic_category_id";
$this->cat[0] = array();
@@ -212,10 +211,10 @@
- * replace german letters (for example ä => ae)
+ * replace german letters (for example � => ae)
function replaceChars($text){
- $search = array( "ä", "ö", "ü", "Ä", "Ö", "Ü", "ß");
+ $search = array( "�", "�", "�", "�", "�", "�", "�");
$repwith = array("ae", "oe", "ue", "AE", "OE", "UE", "ss");
if(CHARSET=="UTF-8")
@@ -400,7 +399,7 @@
$sql .= " ORDER BY load_count DESC";
- //Beschränkung
+ //Beschr�nkung
$lim = $this->limit;
$overLimit = $lim+1;
$sql .= " LIMIT ".$overLimit;
@@ -599,13 +598,13 @@
$tmp_layer_pos = $member -> getAttribute('layer_pos');
- * Wiederfinden des Members über die Attribute
+ * Wiederfinden des Members �ber die Attribute
if ($this->cat[$i]['member'][$ii]['wms_id'] == $tmp_wms_id){
if ($this->cat[$i]['member'][$ii]['layer_parent'] == $tmp_layer_pos){
$sub = "true";
- $member->appendChild($m); // dem member $member wird ein weiteres member $m hinzugefügt
+ $member->appendChild($m); // dem member $member wird ein weiteres member $m hinzugef�gt
break;
} else {
@@ -665,7 +664,7 @@
$epsg_text = $this->doc->createTextNode($equalEPSG);
$epsg->appendChild($epsg_text);
- // Länderkennung
+ // L�nderkennung
$state = $this->doc->createElement('federalstate');
$m->appendChild($state);
@@ -690,7 +689,7 @@
$last_monitoring_text = $this->doc->createTextNode($lastMonitoring);
$last_monitoring->appendChild($last_monitoring_text);
- // Verfügbarkeit - Prozentzahl
+ // Verf�gbarkeit - Prozentzahl
$availability = $this->doc->createElement('availability');
$m->appendChild($availability);
@@ -930,7 +929,7 @@
- // Länderkennung
+ // L�nderkennung
@@ -1082,7 +1081,7 @@
$last_date = date("d.m.Y - H:i", $last_timestamp);
-// Vorrübergehend auskommentiert da keine aktuellen (auf Timestamp basierten) Daten vorliegen
+// Vorr�bergehend auskommentiert da keine aktuellen (auf Timestamp basierten) Daten vorliegen
// $sql = "SELECT upload_id as time, status FROM mb_monitor WHERE fkey_wms_id=$1 AND upload_id > ".$last_timestamp;
$sql = "SELECT upload_id as time, status FROM mb_monitor WHERE fkey_wms_id=$1";
Modified: trunk/mapbender/http/classes/class_stripRequest.php
--- trunk/mapbender/http/classes/class_stripRequest.php 2008-04-23 13:21:04 UTC (rev 2405)
+++ trunk/mapbender/http/classes/class_stripRequest.php 2008-04-23 15:59:31 UTC (rev 2406)
@@ -39,8 +39,8 @@
$tmp = explode("=", $patterns[$i]);
if(mb_strtoupper($tmp[0]) == mb_strtoupper($key)){
$replacement = mb_strtoupper($key) . "=" . $value;
- $currentPattern = "/" . $patterns[$i] . "/";
- $this->url = preg_replace($currentPattern, $replacement, $this->url);
+ $currentPattern = $patterns[$i];
+ $this->url = str_replace($currentPattern, $replacement, $this->url);
$exists = true;
Copied: trunk/mapbender/http/classes/class_user.php (from rev 2404, branches/2.5/http/classes/class_user.php)
--- trunk/mapbender/http/classes/class_user.php (rev 0)
+++ trunk/mapbender/http/classes/class_user.php 2008-04-23 15:59:31 UTC (rev 2406)
@@ -0,0 +1,133 @@
+<?php
+# $Id: class_kml_geometry.php 1966 2008-01-15 08:25:15Z christoph $
+# http://www.mapbender.org/index.php/class_wmc.php
+ * A Mapbender user as described in the table mb_user.
+class User {
+ * @var Integer The user ID
+ var $id;
+ * Constructor
+ * @param $userId Integer the ID of the user that is represented by
+ * this object.
+ public function __construct ($userId) {
+ $this->id = $userId;
+ * Returns an array of application IDs that the user is allowed to access.
+ * @return Array an array of application IDs
+ * @param $ignorepublic boolean whether or not to ignore
+ * public applications (?)
+ public function getApplicationsByPermission ($ignorepublic) {
+ $mb_user_id = $this->id;
+ $arrayGuis = array();
+ $mb_user_groups = array();
+ $sql_groups = "SELECT fkey_mb_group_id FROM mb_user_mb_group WHERE fkey_mb_user_id = $1 ";
+ $v = array($mb_user_id);
+ $t = array("i");
+ $res_groups = db_prep_query($sql_groups,$v,$t);
+ $cnt_groups = 0;
+ while($row = db_fetch_array($res_groups)){
+ $mb_user_groups[$cnt_groups] = $row["fkey_mb_group_id"];
+ $cnt_groups++;
+ if($cnt_groups > 0){
+ $v = array();
+ $t = array();
+ $sql_g = "SELECT gui.gui_id FROM gui JOIN gui_mb_group ";
+ $sql_g .= " ON gui.gui_id = gui_mb_group.fkey_gui_id WHERE gui_mb_group.fkey_mb_group_id IN (";
+ for($i=0; $i<count($mb_user_groups);$i++){
+ if($i > 0){$sql_g .= ",";}
+ $sql_g .= "$".strval($i+1);
+ array_push($v,$mb_user_groups[$i]);
+ array_push($t,"i");
+ $sql_g .= ") GROUP BY gui.gui_id";
+ $res_g = db_prep_query($sql_g,$v,$t);
+ while($row = db_fetch_array($res_g)){
+ array_push($arrayGuis,$row["gui_id"]);
+ $sql_guis = "SELECT gui.gui_id FROM gui JOIN gui_mb_user ON gui.gui_id = gui_mb_user.fkey_gui_id";
+ $sql_guis .= " WHERE (gui_mb_user.fkey_mb_user_id = $1) ";
+ if (!isset($ignore_public) OR $ignore_public== false){
+ $sql_guis .= " AND gui.gui_public = 1 ";
+ $sql_guis .= " GROUP BY gui.gui_id";
+ $t = array("i");
+ $res_guis = db_prep_query($sql_guis,$v,$t);
+ $guis = array();
+ while($row = db_fetch_array($res_guis)){
+ if(!in_array($row['gui_id'],$arrayGuis)){
+ return $arrayGuis;
+ /** identifies the IDs of WFS confs where the user is owner
+ * @param integer userid the user-ID of the current user
+ * @return integer[] the IDs of the wfs_conf-table
+ public function getWfsConfByPermission(){
+ $userid = $this->id;
+ $guisByPer = array();
+// 1.
+ $adm = new administration();
+ $guisByPer = $adm->getGuisByPermission($userid, true);
+// 2.
+ $ownWFSconfs = array();
+ if(count($guisByPer)>0){
+ $v = array();
+ $t = array();
+ $sql = "SELECT wfs_conf.wfs_conf_id FROM gui_wfs_conf, wfs_conf " .
+ "where wfs_conf.wfs_conf_id = gui_wfs_conf.fkey_wfs_conf_id " .
+ "and gui_wfs_conf.fkey_gui_id IN(";
+ for($i=0; $i<count($guisByPer); $i++){
+ if($i>0){ $sql .= ",";}
+ $sql .= "$".strval($i+1);
+ array_push($v, $guisByPer[$i]);
+ array_push($t, "s");
+ $sql .= ") GROUP BY wfs_conf.wfs_conf_id ORDER BY wfs_conf.wfs_conf_id";
+ $i=0;
+ $ownWFSconfs[$i] = $row['wfs_conf_id'];
+ $i++;
+ return $ownWFSconfs;
Copied: trunk/mapbender/http/classes/class_weldMaps2Image.php (from rev 2404, branches/2.5/http/classes/class_weldMaps2Image.php)
--- trunk/mapbender/http/classes/class_weldMaps2Image.php (rev 0)
+++ trunk/mapbender/http/classes/class_weldMaps2Image.php 2008-04-23 15:59:31 UTC (rev 2406)
@@ -0,0 +1,204 @@
+<?php
+# $Id$
+require_once(dirname(__FILE__)."/class_stripRequest.php");
+require_once(dirname(__FILE__)."/class_mb_exception.php");
+require_once(dirname(__FILE__)."/class_connector.php");
+include_once(dirname(__FILE__)."/../../conf/mapbender.conf");
+ * Class generats Images (jpegs/pngs/geotiff)
+ * of Image-URL-Array
+ * For geotiff export gdal is necessary
+ class weldMaps2Image{
+ var $urls = array();
+ var $filename;
+ function weldMaps2Image($urls, $array_file){
+ $this->urls = $urls;
+ $this->array_file = $array_file;
+ function getImage($imageTyp_imp, $outputKind=''){
+ $imageTyp="";
+ $imageTyp=$imageTyp_imp;
+ if($imageTyp=='jpg'){
+ $imageTyp='jpeg';
+ if(!$this->urls || $this->urls == ""){
+ $e = new mb_exception("weldMaps2Image: no maprequests delivered");
+ $obj1 = new stripRequest($this->urls[0]);
+ $width = $obj1->get("width");
+ $height = $obj1->get("height");
+ $wms_srs = $obj1->get("srs");
+ $wms_bbox = $obj1->get("bbox");
+ $wms_format = $obj1->getFormat();
+ $image = imagecreatetruecolor($width, $height );
+ $white = ImageColorAllocate($image,255,255,255);
+ ImageFilledRectangle($image,0,0,$width,$height,$white);
+ for($i=0; $i<count($this->urls); $i++){
+ $obj = new stripRequest($this->urls[$i]);
+ if($imageTyp=='geotiff'){
+ $this->urls[$i] = $obj->setFormat($wms_format);
+ } else {
+ $this->urls[$i] = $obj->setFormat($imageTyp);
+ $this->urls[$i] = $obj->encodeGET();
+ $img = $this->loadImage($this->urls[$i]);
+ if($img != false){
+ imagecopy($image, $img, 0, 0, 0, 0, $width, $height);
+ else{
+ $e = new mb_exception("weldMaps2Image: unable to load image: " . $this->urls[$i]);
+ $filename = $this->array_file['dir']."/";
+ $timestamp = time();
+ $filenameOnly =$this->array_file['filename'].md5($timestamp);
+ if($imageTyp=='png'){
+ $filenameOnly .= '.png';
+ $filename .= $filenameOnly;
+ imagepng($image, $filename);
+ $this->downloadLink($filenameOnly);
+ } else if($imageTyp=='jpeg'){
+ $filenameOnly .= '.jpeg';
+ imagejpeg($image, $filename);
+ } else if($imageTyp=='geotiff'){
+ $filenameOnly .= '.'.$wms_format;
+ if ($wms_format=='png'){
+ } else if ($wms_format=='jpeg'){
+ } else {
+ $e = new mb_exception("weldMaps2Image: unable to generate temp-Image for getiff: " . $filename);
+ // gdal_translate...
+ $wms_bbox = str_replace(',', ' ', $wms_bbox);
+ $filename_tif = str_replace($wms_format, 'tif', $filenameOnly);
+ $tmp_dir = $this->array_file['dir']."/";
+ $array_bbox = explode(" ", $wms_bbox);
+ $wms_bbox = $array_bbox[0]." ".$array_bbox[3]." ".$array_bbox[2]." ".$array_bbox[1];
+ $cmd = "gdal_translate -a_srs ".$wms_srs." -a_ullr ".$wms_bbox." ".$tmp_dir.$filenameOnly." ".$tmp_dir.$filename_tif;
+ exec($cmd);
+ $this->downloadLink($filename_tif);
+ }else {
+ function loadImage ($imgurl) {
+ $x = new connector($imgurl);
+ $im = @imagecreatefromstring($x->file);
+ if(!$im){
+ $im = false;
+ $e = new mb_exception("weldMaps2Image: unable to load image: ".$imgurl);
+ return $im;
+ function downloadLink($downloadFilename){
+ $dwDir = $this->array_file['dir']."/";
+ $dwFilename = $downloadFilename;
+ if(!(bool)$dwFilename) {
+ die("No filename given.");
+ if((int)strpos($dwFilename,"..") !== 0) {
+ die("Illegal filename given.");
+ $img = $dwDir."/".$dwFilename;
+ if(!file_exists($img) || !is_readable($img)) {
+ die("An error occured.");
+ $now_date = date("Ymd_His");
+ switch(substr($dwFilename,-4)) {
+ case ".png":
+ $filename = "map_export__".$now_date.".png";
+ header('Content-Type: image/png');
+ break;
+ case "jpeg":
+ $filename = "map_export__".$now_date.".jpeg";
+ header('Content-Type: image/jpeg');
+ break;
+ case ".tif";
+ $filename = "map_export__".$now_date.".tif";
+ header('Content-Type: image/tif');
+ break;
+ default:
+ if(file_exists($img) && is_file($img)) {
+ header("Content-Disposition: attachment; filename=\"".$filename."\"");
+ readfile($img);
+ } else {
+ die('Error: The file '.$img.' does not exist!');
Modified: trunk/mapbender/http/classes/class_wfs.php
--- trunk/mapbender/http/classes/class_wfs.php 2008-04-23 13:21:04 UTC (rev 2405)
+++ trunk/mapbender/http/classes/class_wfs.php 2008-04-23 15:59:31 UTC (rev 2406)
@@ -22,9 +22,9 @@
-require_once(dirname(__FILE__)."/class_connector.php");
-require_once(dirname(__FILE__)."/class_administration.php");
+require_once(dirname(__FILE__)."/class_administration.php");
class wfs {
@@ -65,7 +65,7 @@
$values = null;
$tags = null;
$admin = new administration();
- $this->wfs_getcapabilities_doc = $admin->char_encode($data);
+ $this->wfs_getcapabilities_doc = $admin->char_encode($data);
$this->wfs_upload_url = $url;
# for temporary wfs a id has to be created...
@@ -76,7 +76,7 @@
xml_parser_set_option($parser,XML_OPTION_TARGET_ENCODING,CHARSET);
xml_parse_into_struct($parser,$this->wfs_getcapabilities_doc,$values,$tags);
//xml_parse_into_struct($parser,$data,$values,$tags);
xml_parser_free($parser);
$section = false;
@@ -196,7 +196,7 @@
function addFeaturetype($name,$title,$abstract,$srs,$url,$version){
$this->wfs_featuretype[count($this->wfs_featuretype)] = new featuretype($name,$title,$abstract,$srs,$url,$version);
function stripEndlineAndCarriageReturn($string) {
return preg_replace("/\n/", "", preg_replace("/\r/", " ", $string));
@@ -321,8 +321,10 @@
// if it might exist, update it
if ($wfs_exists) {
// but check first if it really exists in the database
- $sql = "SELECT * FROM wfs WHERE wfs_id = ".$this->wfs_id.";";
+ $sql = "SELECT * FROM wfs WHERE wfs_id = $1;";
+ $v = array($this->wfs_id);
+ $t = array("i");
+ $res = db_prep_query($sql, $v, $t);
if($res){
$this->updateWfs();
@@ -337,8 +339,10 @@
# delete featuretypes from DB that does not exist and find the ids
- $sql = "SELECT * FROM wfs_featuretype WHERE fkey_wfs_id = ".$this->wfs_id.";";
- $res_ft = db_query($sql);
+ $sql = "SELECT * FROM wfs_featuretype WHERE fkey_wfs_id = $1;";
+ $t = array("i");
+ $res_ft = db_prep_query($sql, $v, $t);
$cnt = 0;
while(db_fetch_row($res_ft)){
$found = false;
@@ -391,9 +395,10 @@
//delete featuretype elements from db and find the ids
- $sql = "SELECT * FROM wfs_element WHERE fkey_featuretype_id = ".$this->wfs_featuretype[$i]->featuretype_id.";";
- //echo $sql."<br />";
- $res_el = db_query($sql);
+ $sql = "SELECT * FROM wfs_element WHERE fkey_featuretype_id = $1;";
+ $v = array($this->wfs_featuretype[$i]->featuretype_id);
+ $t = array("i");
+ $res_el = db_prep_query($sql, $v, $t);
$cnt = 0;
while(db_fetch_row($res_el)){
$found = false;
@@ -420,57 +425,881 @@
for($j=0; $j<count($this->wfs_featuretype[$i]->featuretype_element);$j++){
if(!$this->wfs_featuretype[$i]->featuretype_element[$j]["id"]){
$sql = "INSERT INTO wfs_element(fkey_featuretype_id, element_name,element_type) ";
- $sql .= "VALUES(";
- $sql .= "'" .$this->wfs_featuretype[$i]->featuretype_id. "', ";
- $sql .= "'" .$this->wfs_featuretype[$i]->featuretype_element[$j]["name"]. "', ";
- $sql .= "'" .$this->wfs_featuretype[$i]->featuretype_element[$j]["type"]. "' ";
- $sql .= ");";
+ $sql .= "VALUES($1, $2, $3);";
+ $v = array($this->wfs_featuretype[$i]->featuretype_id, $this->wfs_featuretype[$i]->featuretype_element[$j]["name"], $this->wfs_featuretype[$i]->featuretype_element[$j]["type"]);
+ $t = array("s", "s", "s");
if(!$res){db_rollback();$e = new mb_exception("Error while saving WFS to DB. Rollback performed.");return;}
else{
- $sql = "UPDATE wfs_element SET element_type = '".$this->wfs_featuretype[$i]->featuretype_element[$j]["type"]."' ";
- $sql .= "WHERE element_id = ".$this->wfs_featuretype[$i]->featuretype_element[$j]["id"]." AND ";
- $sql .= "fkey_featuretype_id = ".$this->wfs_featuretype[$i]->featuretype_id.";";
- if(!$res){db_rollback();$e = new mb_exception("Error while saving WFS to DB. Rollback performed.");return;}
+ $sql = "UPDATE wfs_element SET element_type = $1 ";
+ $sql .= "WHERE element_id = $2 AND ";
+ $sql .= "fkey_featuretype_id = $3;";
+ $v = array($this->wfs_featuretype[$i]->featuretype_element[$j]["type"], $this->wfs_featuretype[$i]->featuretype_element[$j]["id"], $this->wfs_featuretype[$i]->featuretype_id);
+ $t = array("s", "i", "i");
+ if (!$res) {
+ db_rollback();
+ $e = new mb_exception("Error while saving WFS to DB. Rollback performed.");
+ return;
$sql = "DELETE FROM wfs_featuretype_namespace WHERE ";
- $sql .= "fkey_wfs_id = ".$this->wfs_id." AND ";
+ $sql .= "fkey_wfs_id = $1 AND fkey_featuretype_id = $2";
+ $v = array($this->wfs_id, $this->wfs_featuretype[$i]->featuretype_id);
+ $t = array("i", "i");
+ if (!$res) {
+ db_rollback();
+ return;
for($j=0; $j<count($this->wfs_featuretype[$i]->featuretype_namespace);$j++){
- $sql = "INSERT INTO wfs_featuretype_namespace(fkey_wfs_id, fkey_featuretype_id, namespace, namespace_location) ";
- $sql .= "'" .$this->wfs_id. "',";
- $sql .= "'" .$this->wfs_featuretype[$i]->featuretype_namespace[$j]["name"]. "', ";
- $sql .= "'" .$this->wfs_featuretype[$i]->featuretype_namespace[$j]["value"]. "' ";
- $sql .= ");";
+ $sql = "INSERT INTO wfs_featuretype_namespace ";
+ $sql .= "(fkey_wfs_id, fkey_featuretype_id, namespace, namespace_location) ";
+ $sql .= "VALUES ($1, $2, $3, $4);";
+ $v = array($this->wfs_id, $this->wfs_featuretype[$i]->featuretype_id, $this->wfs_featuretype[$i]->featuretype_namespace[$j]["name"], $this->wfs_featuretype[$i]->featuretype_namespace[$j]["value"]);
+ $t = array("s", "s", "s", "s");
+ if (!$res) {
+ db_rollback();
+ return;
+ # TABLE gui_wfs
+ if($gui_id){
+ $sql ="INSERT INTO gui_wfs (fkey_gui_id, fkey_wfs_id)";
+ $sql .= "VALUES($1, $2);";
+ $v = array($gui_id, $this->wfs_id);
+ $t = array("s", "i");
+ if (!$res) {
+ db_rollback();
+ return;
+ //echo "Successfully saved!<br />";
+ db_commit();
+ return true;
+* updateObjFromXML
+* this function regets the information from the xml (update)
+* @return boolean true if successful, false otherwise
+function updateObjFromXML($url){
+ $x = new connector($url);
+ $data = $x->file;
+ #$data = implode("",file($url));
+ if(!$data){
+ $e = new mb_exception("Unable to open document: ".$url);
+ return false;
+ $values = null;
+ $tags = null;
+ $admin = new administration();
+ $this->wfs_featuretype = array();
+ $this->wfs_upload_url = $url;
+ # for temporary wfs a id has to be created...
+ //$this->wfs_id = "id_" . substr(md5(rand()),0,6);
+ $parser = xml_parser_create(CHARSET);
+ xml_parser_set_option($parser,XML_OPTION_CASE_FOLDING,0);
+ xml_parser_set_option($parser,XML_OPTION_SKIP_WHITE,1);
+ xml_parser_set_option($parser,XML_OPTION_TARGET_ENCODING,CHARSET);
+ xml_parse_into_struct($parser,$this->wfs_getcapabilities_doc,$values,$tags);
+ //xml_parse_into_struct($parser,$data,$values,$tags);
+ xml_parser_free($parser);
+ $section = false;
+ $request = false;
+ $featuretype_name = false;
+ $featuretype_title = false;
+ $featuretype_abstract = false;
+ $featuretype_srs = false;
+ foreach ($values as $element) {
+ if(strtoupper($element[tag]) == "WFS_CAPABILITIES" && $element[type] == "open"){
+ $this->wfs_version = $element[attributes][version];
+ if(strtoupper($element[tag]) == "NAME" && $element[level] == '3'){
+ $this->wfs_name = $element[value];
+/* if(strtoupper($element[tag]) == "TITLE" && $element[level] == '3'){
+ $this->wfs_title = $this->stripEndlineAndCarriageReturn($element[value]);
+ if(strtoupper($element[tag]) == "ABSTRACT" && $element[level] == '3'){
+ $this->wfs_abstract = $this->stripEndlineAndCarriageReturn($element[value]);
+ //new WFS 1.0.0 -- SB 2007-08-06
+ if(strtolower($element[tag]) == "fees"){
+ $this->fees = $element[value];
+ if(strtolower($element[tag]) == "accessconstraints"){
+ $this->accessconstraints = $element[value];
+ /*capability section*/
+ if($this->wfs_version == "1.0.0"){
+ # getCapabilities
+ if(strtoupper($element[tag]) == "GETCAPABILITIES" && $element[type] == "open"){
+ $section = "getcapabilities";
+ if($section == "getcapabilities" && strtoupper($element[tag]) == "GET"){
+ $this->wfs_getcapabilities = $element[attributes][onlineResource];
+ # descriptFeatureType
+ if(strtoupper($element[tag]) == "DESCRIBEFEATURETYPE" && $element[type] == "open"){
+ $section = "describefeaturetype";
+ $this->wfs_describefeaturetype = $element[attributes][onlineResource];
+ if($section == "describefeaturetype" && strtoupper($element[tag]) == "GET"){
+ # getFeature
+ if(strtoupper($element[tag]) == "GETFEATURE" && $element[type] == "open"){
+ $section = "getfeature";
+ if($section == "getfeature" && strtoupper($element[tag]) == "GET"){
+ $this->wfs_getfeature = $element[attributes][onlineResource];
+ if(strtoupper($element[tag]) == "GETFEATURE" && $element[type] == "close"){
+ $section = "";
+ # transaction
+ if(strtoupper($element[tag]) == "TRANSACTION" && $element[type] == "open"){
+ $section = "transaction";
+ if($section == "transaction" && strtoupper($element[tag]) == "GET"){
+ $this->wfs_transaction = $element[attributes][onlineResource];
+ if(strtoupper($element[tag]) == "TRANSACTION" && $element[type] == "close"){
+ $section = "";
+ if(strtoupper($element[tag]) == "FEATURETYPE" && $element[type] == "open"){
+ $section = "featuretype";
+ if($section == "featuretype" && strtoupper($element[tag]) == "NAME"){
+ $featuretype_name = $element[value];
+ if($section == "featuretype" && strtoupper($element[tag]) == "TITLE"){
+ $featuretype_title = $this->stripEndlineAndCarriageReturn($element[value]);
+ if($section == "featuretype" && strtoupper($element[tag]) == "ABSTRACT"){
+ $featuretype_abstract = $this->$element[value];
+ if($section == "featuretype" && strtoupper($element[tag]) == "SRS"){
+ $featuretype_srs = $element[value];
+ $this->addFeaturetype($featuretype_name,$featuretype_title,$featuretype_abstract,$featuretype_srs,$this->wfs_describefeaturetype,$this->wfs_version);
+ return true;
+* creatObjfromDB
+* this function fills the object with wfs information from db
+* @param int the id of wfs to get the information from
+function createObjFromDB($wfs_id){
+ global $DBSERVER,$DB,$OWNER,$PW;
+ $con = db_connect($DBSERVER,$OWNER,$PW);
+ db_select_db($DB,$con);
+ $v = array($wfs_id);
+ $t = array("i");
+ $cnt = 0;
+ while(db_fetch_row($res)){
+ $this->wfs_id = db_result($res, $cnt, "wfs_id");
+ $this->wfs_version = db_result($res, $cnt, "wfs_version");
+ $this->wfs_name = db_result($res, $cnt, "wfs_name");
+ $this->wfs_title = db_result($res, $cnt, "wfs_title");
+ $this->wfs_abstract = db_result($res, $cnt, "wfs_abstract");
+ $this->wfs_getcapabilities = db_result($res, $cnt, "wfs_getcapabilities");
+ $this->wfs_getcapabilities_doc = db_result($res, $cnt, "wfs_getcapabilities_doc");
+ $this->wfs_upload_url = db_result($res, $cnt, "wfs_upload_url");
+ $this->wfs_describefeaturetype = db_result($res, $cnt, "wfs_describefeaturetype");
+ $this->wfs_getfeature = db_result($res, $cnt, "wfs_getfeature");
+ $this->wfs_transaction = db_result($res, $cnt, "wfs_transaction");
+ $this->fees = db_result($res, $cnt, "fees");
+ $this->accessconstraints = db_result($res, $cnt, "accessconstraints");
+ $this->wfs_owner = db_result($res, $cnt, "wfs_owner");
+ $this->wfs_timestamp = db_result($res, $cnt, "wfs_timestamp");
+ $sql_fe = "SELECT * FROM wfs_featuretype WHERE fkey_wfs_id = $1 ORDER BY featuretype_id";
+ $t = array("i");
+ $res_fe = db_prep_query($sql_fe, $v, $t);
+ $cnt_fe = 0;
+ while(db_fetch_row($res_fe)){
+ $c = count($this->wfs_featuretype);
+// $this->wfs_featuretype[$c]->featuretype_id = db_result($res_fe, $cnt_fe, "featuretype_id");
+ $this->wfs_featuretype[$c]->featuretype_name = db_result($res_fe, $cnt_fe, "featuretype_name");
+ $this->wfs_featuretype[$c]->featuretype_title = db_result($res_fe, $cnt_fe, "featuretype_title");
+ $this->wfs_featuretype[$c]->featuretype_abstract = db_result($res_fe, $cnt_fe, "featuretype_abstract");
+ $this->wfs_featuretype[$c]->featuretype_srs = db_result($res_fe, $cnt_fe, "featuretype_srs");
+ $sql_el = "SELECT * FROM wfs_element WHERE fkey_featuretype_id = $1 ORDER BY element_id";
+ $v = array(db_result($res_fe, $cnt_fe, "featuretype_id"));
+ $t = array("i");
+ $res_el = db_prep_query($sql_el, $v, $t);
+ $cnt_el = 0;
+ while(db_fetch_row($res_el)){
+ $z = count($this->wfs_featuretype[$c]->featuretype_element);
+ $this->wfs_featuretype[$c]->featuretype_element[$z]["name"] = db_result($res_el, $cnt_el, "element_name");
+ $this->wfs_featuretype[$c]->featuretype_element[$z]["type"] = db_result($res_el, $cnt_el, "element_type");
+ $cnt_el++;
+ $sql_ns = "SELECT * FROM wfs_featuretype_namespace WHERE fkey_featuretype_id = $1 ORDER BY namespace";
+ $t = array("i");
+ $res_ns = db_prep_query($sql_ns, $v, $t);
+ $cnt_ns = 0;
+ while(db_fetch_row($res_ns)){
+ $z = count($this->wfs_featuretype[$c]->featuretype_namespace);
+ $this->wfs_featuretype[$c]->featuretype_namespace[$z]["name"] = db_result($res_ns, $cnt_ns, "namespace");
+ $this->wfs_featuretype[$c]->featuretype_namespace[$z]["value"] = db_result($res_ns, $cnt_ns, "namespace_location");
+ $cnt_ns++;
+ $cnt_fe++;
+ $cnt++;
+/** end createObjfromDB **/
+ public function getallwfs($userid){
+ $this->wfs_id = array();
+ $this->wfs_name = array();
+ $this->wfs_title = array();
+ $this->wfs_abstract = array();
+ if($userid){
+ $sql = "SELECT * FROM wfs WHERE wfs_owner = $1";
+ $v = array($userid);
+ $t = array('i');
+ else{
+ $sql = "SELECT * FROM wfs";
+ $res = db_query($sql);
+ $cnt = 0;
+ while ($row = db_fetch_array($res)){
+ $this->wfs_version[$cnt] = $row["wfs_version"];
+ $this->wfs_id[$cnt] = $row["wfs_id"];
+ $this->wfs_name[$cnt] = $row["wfs_name"];
+ $this->wfs_title[$cnt] = $row["wfs_title"];
+ $this->wfs_abstract[$cnt] = $row["wfs_abstract"];
+ $this->wfs_getcapabilities[$cnt] = $row["wfs_getcapabilities"];
+ $this->wfs_describefeaturetype[$cnt] = $row["wfs_describefeaturetype"];
+ $this->wfs_getfeature[$cnt] = $row["wfs_getfeature"];
+ $cnt++;
+class featuretype extends wfs{
+ var $featuretype_element = array();
+ var $featuretype_namespace = array();
+ function featuretype($name,$title,$abstract,$srs,$url,$version){
+ $url .= "&SERVICE=WFS&VERSION=".$version."&REQUEST=DescribeFeatureType&TYPENAME=".$name;
+ $this->featuretype_name = $name;
+ $this->featuretype_title = $title;
+ $this->featuretype_abstract = $abstract;
+ $this->featuretype_srs = $srs;
+ $y = new connector($url);
+ $data = $y->file;
+ $parser = xml_parser_create();
+ xml_parse_into_struct($parser,$data,$values,$tags);
+ if($this->sepNameSpace($element[tag]) == "schema" && $element[type] == "open"){
+ $section = "namespace";
+// echo "namespace<br>";
+ if($section == "namespace"){
+ while (list($k, $val) = each ($element[attributes])) {
+ if (substr($k, 0, 5) == "xmlns") {
+ $cnt = count($this->featuretype_namespace);
+ $match = false;
+ for ($i = 0 ; $i < $cnt && $match == false ; $i++) {
+ if ($this->sepNameSpace($k) == $this->featuretype_namespace[$i]["name"] && $val == $this->featuretype_namespace[$i]["value"]) {
+ $match = true;
+ if ($match == false) {
+ $this->featuretype_namespace[$cnt]["name"] = $this->sepNameSpace($k);
+ $this->featuretype_namespace[$cnt]["value"] = $val;
+// echo "namespace: " . $this->sepNameSpace($k) . " -> " . $val . "<br>";
+ if($this->sepNameSpace($element[tag]) == "complexType" && $element[type] == "open"){
+ $section = "";
+ if($this->sepNameSpace($element[tag]) == "complexContent" && $element[type] == "open"){
+ $section = "complexcontent";
+// echo "complexcontent<br>";
+ if($section == "complexcontent" && $this->sepNameSpace($element[tag]) == "element" && $element[attributes][name]){
+ $cnt = count($this->featuretype_element);
+ $this->featuretype_element[$cnt]["name"] = $element[attributes]["name"];
+ $this->featuretype_element[$cnt]["type"] = $this->sepNameSpace($element[attributes]["type"]);
+// echo "element: ".$this->featuretype_element[$cnt]["name"]."<br>";
+ if($this->sepNameSpace($element[tag]) == "complexContent" && $element[type] == "close"){
+ $section = "";
+ function sepNameSpace($s){
+ $c = strpos($s,":");
+ if($c>0){
+ return substr($s,$c+1);
+ else{
+ return $s;
+?><?php
+# $Id$
+# http://www.mapbender.org/index.php/class_wfs.php
+* class for wfs-objects
+class wfs {
+ var $wfs_id;
+ var $wfs_version;
+ var $wfs_name;
+ var $wfs_title;
+ var $wfs_abstract;
+ var $wfs_getcapabilities;
+ var $wfs_getcapabilities_doc; //new SB 2007-08-09
+ var $wfs_describefeaturetype;
+ var $wfs_describefeaturetype_namespace = array();
+ var $wfs_getfeature;
+ var $wfs_transaction;
+ var $wfs_upload_url; //new SB 2007-08-09
+ var $fees;
+ var $accessconstraints;
+ var $wfs_featuretype = array();
+function wfs() {
+function createObjFromXML($url){
+ $data = $x->file;
+ if(!$data){
+ echo "Unable to open document: ".$url;
+ die;
+ $values = null;
+ $tags = null;
+ $this->wfs_id = "id_" . substr(md5(rand()),0,6);
+ $section = false;
+ $request = false;
+ if(strtoupper($element[tag]) == "TITLE" && $element[level] == '3'){
+ # getCapabilities
+ # getFeature
+ $section = "";
+ # transaction
+ $section = "";
+function displayWFS(){
+ echo "id: " . $this->wfs_id . " <br>";
+ echo "version: " . $this->wfs_version . " <br>";
+ echo "name: " . $this->wfs_name . " <br>";
+ echo "title: " . $this->wfs_title . " <br>";
+ echo "abstract: " . $this->wfs_abstract . " <br>";
+ echo "capabilitiesrequest: " . $this->wfs_getcapabilities . " <br>";
+ echo "describefeaturetype: " . $this->wfs_describefeaturetype . " <br>";
+ echo "getfeature: " . $this->wfs_getfeature . " <br>";
+ echo "transaction: " . $this->wfs_transaction . " <br>";
+ for($i=0; $i<count($this->wfs_featuretype); $i++){
+ echo "<hr>";
+ echo "name: ". $this->wfs_featuretype[$i]->featuretype_name . "<br>";
+ echo "title: ". $this->wfs_featuretype[$i]->featuretype_title . "<br>";
+ echo "abstract: ". $this->wfs_featuretype[$i]->featuretype_abstract . "<br>";
+ echo "srs: ". $this->wfs_featuretype[$i]->featuretype_srs . "<br>";
+ for($j=0; $j<count($this->wfs_featuretype[$i]->featuretype_element);$j++){
+ echo " element: " . $this->wfs_featuretype[$i]->featuretype_element[$j]["name"] ." - ".$this->wfs_featuretype[$i]->featuretype_element[$j]["type"]."<br>";
+ for($j=0; $j<count($this->wfs_featuretype[$i]->featuretype_namespace);$j++){
+ echo " namespace: " . $this->wfs_featuretype[$i]->featuretype_namespace[$j]["name"] ." - ".$this->wfs_featuretype[$i]->featuretype_namespace[$j]["value"]."<br>";
+function addFeaturetype($name,$title,$abstract,$srs,$url,$version){
+ $this->wfs_featuretype[count($this->wfs_featuretype)] = new featuretype($name,$title,$abstract,$srs,$url,$version);
+ function stripEndlineAndCarriageReturn($string) {
+ return preg_replace("/\n/", "", preg_replace("/\r/", " ", $string));
+function createJsObjFromWFS($parent){
+ if(!$this->wfs_title || $this->wfs_title == ""){
+ echo "alert('Error: no valid capabilities-document !!');";
+ die; exit;
+ if($parent){
+ echo "parent.";
+ print("add_wfs('".
+ $this->wfs_id ."','".
+ $this->wfs_version ."','".
+ $this->wfs_title ."','".
+ $this->wfs_abstract ."','".
+ $this->wfs_getcapabilities ."','" .
+ $this->wfs_describefeaturetype ."');");
+ if($parent){
+ echo "parent.";
+ print ("wfs_add_featuretype('".
+ $this->wfs_featuretype[$i]->featuretype_name ."','".
+ $this->wfs_featuretype[$i]->featuretype_title . "','".
+ $this->wfs_featuretype[$i]->featuretype_abstract . "','".
+ $this->wfs_featuretype[$i]->featuretype_srs ."','".
+ $this->wfs_featuretype[$i]->featuretype_geomtype ."');");
+ if($parent){
+ echo "parent.";
+ print("wfs_add_featuretype_element('".$this->wfs_featuretype[$i]->featuretype_element[$j]["name"]."', '".$this->wfs_featuretype[$i]->featuretype_element[$j]["type"]."', ".$j.", ".$i.");");
+ if($parent){
+ echo "parent.";
+ print("wfs_add_featuretype_namespace('".$this->wfs_featuretype[$i]->featuretype_namespace[$j]["name"]."', '".$this->wfs_featuretype[$i]->featuretype_namespace[$j]["value"]."', ".$j.", ".$i.");");
+ * Inserts this WFS in the database
+function insertWfs() {
+ $sql = "INSERT INTO wfs (wfs_version, wfs_name, wfs_title, wfs_abstract, ";
+ $sql .= "wfs_getcapabilities, wfs_getcapabilities_doc, wfs_upload_url, ";
+ $sql .= "wfs_describefeaturetype, wfs_getfeature, wfs_transaction, fees, ";
+ $sql .= "accessconstraints, wfs_owner, wfs_timestamp) ";
+ $sql .= "VALUES($1,$2,$3,$4,$5,$6,$7,$8,$9,$10,$11,$12,$13,$14)";
+ $v = array($this->wfs_version, $this->wfs_name, $this->wfs_title,
+ $this->wfs_abstract, $this->wfs_getcapabilities, $this->wfs_getcapabilities_doc,
+ $this->wfs_upload_url, $this->wfs_describefeaturetype, $this->wfs_getfeature,
+ $this->wfs_transaction, $this->fees, $this->accessconstraints,
+ $_SESSION["mb_user_id"], strtotime("now"));
+ $t = array('s', 's', 's', 's', 's', 's', 's', 's', 's', 's', 's', 's', 'i', 'i');
+ if(!$res){
+ db_rollback();
+ return false;
+ $this->wfs_id = db_insert_id($con,'wfs','wfs_id');
+ return true;
+function updateWfs() {
+ $sql = "UPDATE wfs SET wfs_version = $1, wfs_name = $2, wfs_title = $3, ";
+ $sql .= "wfs_abstract = $4, wfs_getcapabilities = $5, wfs_getcapabilities_doc = $6, ";
+ $sql .= "wfs_upload_url = $7, wfs_describefeaturetype = $8, wfs_getfeature = $9, ";
+ $sql .= "wfs_transaction = $10, fees = $11, accessconstraints = $12, wfs_owner = $13, ";
+ $sql .= "wfs_timestamp = $14 ";
+ $sql .= "WHERE wfs_id = $15";
+ //echo $sql."<br />";
+ $v = array($this->wfs_version, $this->wfs_name, $this->wfs_title, $this->wfs_abstract,
+ $this->wfs_getcapabilities, $this->wfs_getcapabilities_doc, $this->wfs_upload_url,
+ $this->wfs_describefeaturetype, $this->wfs_getfeature, $this->wfs_transaction,
+ $this->fees, $this->accessconstraints, $_SESSION["mb_user_id"],strtotime("now"),
+ $this->wfs_id);
+ $t = array('s', 's', 's', 's', 's', 's', 's', 's' ,'s' ,'s' ,'s' ,'s' ,'i' ,'i' ,'i');
+ $res = db_prep_query($sql,$v,$t);
+ if(!$res){
+ db_rollback();
+ return false;
+ return true;
+* wfs2db
+* this function saves the class information to the mapbender database
+* @return boolean true if sucessful false otherwise
+function wfs2db($gui_id){
+ db_begin();
+ // check if WFS already might exists (it might exist when wfs_id is numeric)
+ $wfs_exists = is_numeric($this->wfs_id);
+ // if it might exist, update it
+ if ($wfs_exists) {
+ // but check first if it really exists in the database
+ $t = array("i");
+ if($res){
+ $this->updateWfs();
+ // if not, insert as new WFS
+ else {
+ $this->insertWfs();
+ // if it does not exist, insert as new WFS
+ else {
+ # delete featuretypes from DB that does not exist and find the ids
+ $t = array("i");
+ $cnt = 0;
+ while(db_fetch_row($res_ft)){
+ $found = false;
+ if($this->wfs_featuretype[$i]->featuretype_name == db_result($res_ft, $cnt, "featuretype_name")){
+ $this->wfs_featuretype[$i]->featuretype_id = db_result($res_ft, $cnt, "featuretype_id");
+ $found = true;
+ break;
+ if(!$found){
+ $sql = "DELETE FROM wfs_featuretype WHERE featuretype_id = $1 AND fkey_wfs_id = $2";
+ $v = array(db_result($res_ft, $cnt, "featuretype_id"), $this->wfs_id);
+ $t = array('i','i');
+ $cnt++;
+ # TABLE wfs_featuretype
+ if(!$this->wfs_featuretype[$i]->featuretype_id){
+ $sql = "INSERT INTO wfs_featuretype(fkey_wfs_id, featuretype_name, featuretype_title, featuretype_abstract, featuretype_srs) ";
+ $sql .= "VALUES($1,$2,$3,$4,$5)";
+ $v = array($this->wfs_id,$this->wfs_featuretype[$i]->featuretype_name,$this->wfs_featuretype[$i]->featuretype_title,$this->wfs_featuretype[$i]->featuretype_abstract,$this->wfs_featuretype[$i]->featuretype_srs);
+ $t = array('i','s','s','s','s');
+ if(!$res){db_rollback();$e = new mb_exception("Error while saving WFS to DB. Rollback performed.");return;}
+ # save the id of each featuretype:
+ $this->wfs_featuretype[$i]->featuretype_id = db_insert_id($con,'wfs_featuretype','featuretype_id');
+ else{
+ $sql = "UPDATE wfs_featuretype SET ";
+ $sql .= "featuretype_title = $1,";
+ $sql .= "featuretype_abstract = $2,";
+ $sql .= "featuretype_srs = $3 ";
+ $sql .= "WHERE featuretype_id = $4";
+ $v = array($this->wfs_featuretype[$i]->featuretype_title,$this->wfs_featuretype[$i]->featuretype_abstract,$this->wfs_featuretype[$i]->featuretype_srs,$this->wfs_featuretype[$i]->featuretype_id);
+ $t = array('s','s','s','i');
+ //delete featuretype elements from db and find the ids
+ $t = array("i");
+ $cnt = 0;
+ $found = false;
+ for($j=0; $j<count($this->wfs_featuretype[$i]->featuretype_element); $j++){
+ if($this->wfs_featuretype[$i]->featuretype_element[$j]["name"] == db_result($res_el, $cnt, "element_name")){
+ $this->wfs_featuretype[$i]->featuretype_element[$j]["id"] = db_result($res_el, $cnt, "element_id");
+ $found = true;
+ break;
+ if(!$found){
+ $sql = "DELETE FROM wfs_element WHERE element_id = $1 AND fkey_featuretype_id = $2";
+ $v = array(db_result($res_el, $cnt, "element_id"), $this->wfs_featuretype[$i]->featuretype_id);
+ $cnt++;
+ if(!$this->wfs_featuretype[$i]->featuretype_element[$j]["id"]){
+ $sql = "INSERT INTO wfs_element(fkey_featuretype_id, element_name,element_type) ";
+ else{
+ if (!$res) {
+ db_rollback();
+ return;
+ $sql = "DELETE FROM wfs_featuretype_namespace WHERE ";
+ if (!$res) {
+ db_rollback();
+ return;
+ if (!$res) {
+ db_rollback();
+ return;
# TABLE gui_wfs
if($gui_id){
- $sql .= "'" . $gui_id . "', ";
- $sql .= $this->wfs_id;
- $sql .= ");";
+ if (!$res) {
+ db_rollback();
+ return;
@@ -616,8 +1445,10 @@
- $sql = "SELECT * FROM wfs WHERE wfs_id = ".$wfs_id.";";
+ $t = array("i");
$cnt = 0;
@@ -636,8 +1467,10 @@
- $sql_fe = "SELECT * FROM wfs_featuretype WHERE fkey_wfs_id = '" . $this->wfs_id . "' ORDER BY featuretype_id";
- $res_fe = db_query($sql_fe);
+ $t = array("i");
$cnt_fe = 0;
@@ -647,8 +1480,10 @@
- $sql_el = "SELECT * FROM wfs_element WHERE fkey_featuretype_id = ". db_result($res_fe, $cnt_fe, "featuretype_id")." ORDER BY element_id";
- $res_el = db_query($sql_el);
+ $t = array("i");
$cnt_el = 0;
@@ -656,8 +1491,10 @@
$cnt_el++;
- $sql_ns = "SELECT * FROM wfs_featuretype_namespace WHERE fkey_featuretype_id = ". db_result($res_fe, $cnt_fe, "featuretype_id")." ORDER BY namespace";
- $res_ns = db_query($sql_ns);
+ $t = array("i");
$cnt_ns = 0;
@@ -724,7 +1561,7 @@
$data = $y->file;
- //$data = implode("",file($url));
Modified: trunk/mapbender/http/classes/class_wfs_conf.php
--- trunk/mapbender/http/classes/class_wfs_conf.php 2008-04-23 13:21:04 UTC (rev 2405)
+++ trunk/mapbender/http/classes/class_wfs_conf.php 2008-04-23 15:59:31 UTC (rev 2406)
@@ -18,8 +18,9 @@
+require_once(dirname(__FILE__)."/class_user.php");
class WfsConf {
var $confArray = array();
@@ -31,185 +32,204 @@
+ function __toString () {
+ $json = new Mapbender_JSON();
+ return $json->encode($this->confArray);
+ * Loads WFS conf data from the database
+ * @return Object WFS conf data.
+ * @param $idOrIdArray Object May be an integer or an array of integers representing WFS conf IDs.
public function load ($idOrIdArray) {
- * Check parameter and set idArray
+ // Check parameter and set idArray
if (isset($idOrIdArray)){
// parameter is a number
if (!is_array($idOrIdArray) && is_numeric($idOrIdArray)) {
- $this->getWfsConfFromDB(array(intval($idOrIdArray)), $_SESSION["mb_user_id"]);
+ $idArray = array(intval($idOrIdArray));
// parameter is an array of numbers
- else if (is_array($idOrIdArray)) {
+ if (is_array($idOrIdArray)) {
$idArray = array();
for ($i=0; $i < count($idOrIdArray); $i++) {
if (!is_numeric($idOrIdArray[$i])) {
$e = new mb_exception("Wfs_conf: constructor: wrong parameter: ".$idOrIdArray[$i]." is not a number.");
- return null;
+ return array();
array_push($idArray, intval($idOrIdArray[$i]));
- $this->getWfsConfFromDB($idArray, $_SESSION["mb_user_id"]);
+ // If a user ID is given, remove the ones the user has no access to
+ if ($_SESSION["mb_user_id"]) {
+ $user = new User($_SESSION["mb_user_id"]);
+ $idArray = array_intersect($idArray, $user->getWfsConfByPermission());
+ return $this->getWfsConfFromDB($idArray);
// parameter is invalid
else {
$e = new mb_exception("Wfs_conf: constructor: parameter must be number or an array of numbers.");
- return null;
+ return array();
else {
$e = new mb_exception("Wfs_conf: constructor: parameter is not valid");
+ return null;
+ // --------------------------- private -----------------------------------
- * get WFS conf data from database
+ * Gets the database content for a number of WFS configurations given by their IDs.
+ * @return Array
+ * @param $idArray Array an array of integer values representing WFS conf IDs.
- private function getWfsConfFromDB ($idArray, $userId) {
- * If a user ID is given, remove the ones the user has no access to
- if ($userId) {
- $idArray = array_intersect($idArray, WfsConf::getWfsConfByPermission($userId));
+ private static function getWfsConfFromDbByArray ($idArray) {
+ $sql = "SELECT * FROM wfs_conf ";
+ $sql .= "JOIN wfs ON wfs_conf.fkey_wfs_id = wfs.wfs_id ";
+ $sql .= "WHERE wfs_conf.wfs_conf_id IN (";
+ $v = array();
+ $t = array();
+ for ($i = 0; $i < count($idArray); $i++) {
+ if ($i > 0) {$sql .= ", ";}
+ $sql .= "$" . ($i+1);
+ array_push($v, $idArray[$i]);
+ array_push($t, 'i');
+ $sql .= ")";
- if (count($idArray) > 0) {
- * Get WFS configurations
- $sql = "SELECT * FROM wfs_conf ";
- $sql .= "JOIN wfs ON wfs_conf.fkey_wfs_id = wfs.wfs_id ";
- $sql .= "WHERE wfs_conf.wfs_conf_id IN (";
- $v = array();
- $t = array();
- for ($i = 0; $i < count($idArray); $i++) {
- if ($i > 0) {$sql .= ", ";}
- $sql .= "$" . ($i+1);
- array_push($v, $idArray[$i]);
- array_push($t, 'i');
- $sql .= ")";
- $res = db_prep_query($sql, $v, $t);
- while ($row = db_fetch_array($res)) {
+ $rowArray = array();
+ while ($row = db_fetch_array($res)) {
+ array_push($rowArray, $row);
+ return $rowArray;
- * Get WFS conf elements
- $id = $row["wfs_conf_id"];
+ * Gets the database content of a WFS conf element given by a WFS conf ID.
+ * @return Array
+ * @param $id Integer the WFS conf ID.
+ private static function getWfsConfElementFromDb ($id) {
+ $sql = "SELECT * FROM wfs_conf_element ";
+ $sql .= "JOIN wfs_element ON wfs_conf_element.f_id = wfs_element.element_id ";
+ $sql .= "WHERE wfs_conf_element.fkey_wfs_conf_id = $1 ";
+ #filtered on client side
+ #$sql .= "AND wfs_conf_element.f_search = 1 ";
+ $sql .= "ORDER BY wfs_conf_element.f_pos";
+ $v = array($id);
+ $t = array('i');
- $sql_conf_element = "SELECT * FROM wfs_conf_element ";
- $sql_conf_element .= "JOIN wfs_element ON wfs_conf_element.f_id = wfs_element.element_id ";
- $sql_conf_element .= "WHERE wfs_conf_element.fkey_wfs_conf_id = $1 ";
-#filtered on client side
-# $sql_conf_element .= "AND wfs_conf_element.f_search = 1 ";
- $sql_conf_element .= "ORDER BY wfs_conf_element.f_pos";
- $v_conf_element = array($id);
- $t_conf_element = array('i');
- $res_conf_element = db_prep_query($sql_conf_element, $v_conf_element, $t_conf_element);
- $elementArray = array();
- while ($row_conf_element = db_fetch_array($res_conf_element)) {
+ $elementArray = array();
+ $currentElement = array("element_name" => $row["element_name"],
+ "element_type" => $row["element_type"],
+ "f_search" => $row["f_search"],
+ "f_style_id" => $row["f_style_id"],
+ "f_toupper" => $row["f_toupper"],
+ "f_label" => $row["f_label"],
+ "f_label_id" => $row["f_label_id"],
+ "f_geom" => $row["f_geom"],
+ "f_show" => $row["f_show"],
+ "f_respos" => $row["f_respos"],
+ "f_form_element_html" => $row["f_form_element_html"],
+ "f_show_detail" => $row["f_show_detail"]
+ array_push($elementArray, $currentElement);
+ return $elementArray;
+ * Gets the database content of a WFS feature type given by a WFS ID and a featuretype ID.
+ * @return Array
+ * @param $wfsId Integer the WFS ID.
+ * @param $featuretypeId Integer the WFS featuretype ID.
+ private static function getWfsFeatureTypeFromDb($wfsId, $featuretypeId) {
+ $sql = "SELECT * FROM wfs_featuretype WHERE fkey_wfs_id = $1 AND featuretype_id = $2";
+ $v = array($wfsId, $featuretypeId);
+ $currentRow = array();
+ if($row = db_fetch_array($res)){
+ $currentRow["featuretype_name"] = $row["featuretype_name"];
+ $currentRow["featuretype_srs"] = $row["featuretype_srs"];
- $currentElement = array("f_search" => $row_conf_element["f_search"],
- "f_style_id" => $row_conf_element["f_style_id"],
- "f_toupper" => $row_conf_element["f_toupper"],
- "f_label" => $row_conf_element["f_label"],
- "f_label_id" => $row_conf_element["f_label_id"],
- "f_geom" => $row_conf_element["f_geom"],
- "f_show" => $row_conf_element["f_show"],
- "f_respos" => $row_conf_element["f_respos"],
- "f_show_detail" => $row_conf_element["f_show_detail"],
- "element_name" => $row_conf_element["element_name"],
- "element_type" => $row_conf_element["element_type"]
- array_push($elementArray, $currentElement);
- * Get WFS featuretype
- $sql_feature_type = "SELECT * FROM wfs_featuretype WHERE fkey_wfs_id = $1 AND featuretype_id = $2";
- $v_feature_type = array($row["fkey_wfs_id"], $row["fkey_featuretype_id"]);
- $t_feature_type = array("i", "i");
+ return $currentRow;
+ * get WFS conf data from database
+ private function getWfsConfFromDB ($idArray) {
+ // if a user has access to some WFS confs...
+ if (count($idArray) > 0) {
+ // get WFS conf data from DB
+ $rowArray = self::getWfsConfFromDbByArray($idArray);
- $res_feature_type = db_prep_query($sql_feature_type, $v_feature_type, $t_feature_type);
- if($row_feature_type = db_fetch_array($res_feature_type)){
- $featuretype_name = $row_feature_type["featuretype_name"];
- $featuretype_srs = $row_feature_type["featuretype_srs"];
- $currentRow = array("g_label" => $row["g_label"],
- "g_label_id" => $row["g_label_id"],
- "g_style" => $row["g_style"],
- "g_button" => $row["g_button"],
- "g_button_id" => $row["g_button_id"],
- "g_buffer" => $row["g_buffer"],
- "g_res_style" => $row["g_res_style"],
- "g_use_wzgraphics" => $row["g_use_wzgraphics"],
- "wfs_id" => $row["fkey_wfs_id"],
- "featuretype_id" => $row["fkey_featuretype_id"],
- "featuretype_name" => $featuretype_name,
- "featuretype_id" => $featuretype_srs,
- "wfs_getfeature" => $row["wfs_getfeature"],
- "wfs_describefeaturetype" => $row["wfs_describefeaturetype"],
- "element" => $elementArray
+ for ($i=0; $i < count($rowArray); $i++) {
+ // WFS conf data
+ $currentRow = array("g_label" => $rowArray[$i]["g_label"],
+ "g_label_id" => $rowArray[$i]["g_label_id"],
+ "g_style" => $rowArray[$i]["g_style"],
+ "g_button" => $rowArray[$i]["g_button"],
+ "g_button_id" => $rowArray[$i]["g_button_id"],
+ "g_buffer" => $rowArray[$i]["g_buffer"],
+ "g_res_style" => $rowArray[$i]["g_res_style"],
+ "g_use_wzgraphics" => $rowArray[$i]["g_use_wzgraphics"],
+ "wfs_id" => $rowArray[$i]["fkey_wfs_id"],
+ "featuretype_id" => $rowArray[$i]["fkey_featuretype_id"],
+ "wfs_getfeature" => $rowArray[$i]["wfs_getfeature"],
+ "wfs_describefeaturetype" => $rowArray[$i]["wfs_describefeaturetype"],
+ "wfs_transaction" => $rowArray[$i]["wfs_transaction"]
+ // get WFS conf element data of current WFS conf
+ $id = $rowArray[$i]["wfs_conf_id"];
+ $currentRow["element"] = self::getWfsConfElementFromDb($id);
+ // get WFS featuretype data of current WFS conf
+ $wfsId = $rowArray[$i]["fkey_wfs_id"];
+ $featuretypeId = $rowArray[$i]["fkey_featuretype_id"];
+ $currentRow = array_merge($currentRow , self::getWfsFeatureTypeFromDb($wfsId, $featuretypeId));
$this->confArray[$id] = $currentRow;
+ return $this->confArray;
else {
$e = new mb_warning("class_wfs_conf.php: getWfsConfFromDB: You don't have access to any WFS confs. Check EDIT WFS.");
+ return array();
- /** identifies the Conf-FeatureServices where the current user is owner
- * @param integer userid the user-ID of the current user
- * @return integer[] the IDs of the wfs_conf-table
- public static function getWfsConfByPermission($userid){
- $guisByPer = array();
-// 1.
- $adm = new administration();
- $guisByPer = $adm->getGuisByPermission($userid, true);
-// 2.
- if(count($guisByPer)>0){
- $v = array();
- $t = array();
- $sql = "SELECT wfs_conf.wfs_conf_id FROM gui_wfs_conf, wfs_conf " .
- "where wfs_conf.wfs_conf_id = gui_wfs_conf.fkey_wfs_conf_id " .
- "and gui_wfs_conf.fkey_gui_id IN(";
- for($i=0; $i<count($guisByPer); $i++){
- if($i>0){ $sql .= ",";}
- $sql .= "$".strval($i+1);
- array_push($v, $guisByPer[$i]);
- array_push($t, "s");
- $sql .= ") GROUP BY wfs_conf.wfs_conf_id ORDER BY wfs_conf.wfs_conf_id";
- $res = db_prep_query($sql,$v,$t);
- $ownWFSconfs = array();
- $i=0;
- while($row = db_fetch_array($res)){
- $ownWFSconfs[$i] = $row['wfs_conf_id'];
- $i++;
- return $ownWFSconfs;
+ * @deprecated
class wfs_conf{
var $wfs_id;
@@ -285,8 +305,10 @@
- $sql = "SELECT * FROM wfs_featuretype WHERE fkey_wfs_id = ".$id;
- $res = db_query($sql);
+ $sql = "SELECT * FROM wfs_featuretype WHERE fkey_wfs_id = $1";
+ $v = array($id);
+ $t = array("i");
$cnt = 0;
$this->featuretype_id[$cnt] = $row["featuretype_id"];
@@ -312,8 +334,10 @@
- $sql = "SELECT * FROM wfs_element WHERE fkey_featuretype_id = ".$fid;
+ $sql = "SELECT * FROM wfs_element WHERE fkey_featuretype_id = $1";
+ $v = array($fid);
+ $t = array("s");
$cnt = 0;
$this->element_id[$cnt] = $row["element_id"];
@@ -336,8 +360,10 @@
- $sql = "SELECT * FROM wfs_featuretype_namespace WHERE fkey_featuretype_id = ".$fid;
+ $sql = "SELECT * FROM wfs_featuretype_namespace WHERE fkey_featuretype_id = $1";
+ $v = array($fid);
+ $t = array("s");
$cnt = 0;
$this->namespace_name[$cnt] = $row["namespace"];
Modified: trunk/mapbender/http/classes/class_wmc.php
--- trunk/mapbender/http/classes/class_wmc.php 2008-04-23 13:21:04 UTC (rev 2405)
+++ trunk/mapbender/http/classes/class_wmc.php 2008-04-23 15:59:31 UTC (rev 2406)
@@ -16,12 +16,13 @@
-require_once("../../conf/mapbender.conf");
-require_once("../classes/class_wms.php");
-require_once("../classes/class_layer_monitor.php");
-require_once("../classes/class_bbox.php");
-require_once("../extensions/JSON.php");
+require_once(dirname(__FILE__) . "/../../conf/mapbender.conf");
+require_once(dirname(__FILE__) . "/../classes/class_wms.php");
+require_once(dirname(__FILE__) . "/../classes/class_mb_exception.php");
+require_once(dirname(__FILE__) . "/../classes/class_layer_monitor.php");
+require_once(dirname(__FILE__) . "/../classes/class_point.php");
+require_once(dirname(__FILE__) . "/../classes/class_bbox.php");
+require_once(dirname(__FILE__) . "/../classes/class_json.php");
$con = db_connect(DBSERVER,OWNER,PW);
db_select_db(DB,$con);
@@ -39,6 +40,10 @@
if($c>0)return substr($s,$c+1);
return $s;
+ * Implementation of a Web Map Context Document, WMC 1.1.0
class wmc {
var $xml;
@@ -136,6 +141,11 @@
function wmc() {
+ * Saves the current WMC in the log folder.
+ * @return string the filename of the WMC document.
function saveAsFile() {
$filename = "wmc_" . date("Y_m_d_H_i_s") . ".log";
$logfile = "../../log/" . $filename;
@@ -151,14 +161,29 @@
return $filename;
+ * @return string the title of the WMC.
function getTitle() {
return $this->wmc_title;
+ * @return Integer the number of (unique?) WMS contained in this WMC.
function getNumberOfWms () {
return $this->wmc_wms_count;
+ * Creates a WMC object from a JS map object {@see map.js}
+ * @param object $mapObject a map object
+ * @param integer $user_id the ID of the current user
+ * @param string $generalTitle the desired title of the WMC
+ * @param object $extensionData data exclusive to Mapbender, which will be
+ * mapped into the extension part of the WMC
function createWMCFromObj($mapObject, $user_id, $generalTitle, $extensionData) {
$this->wmc_id = $user_id . '_' . time();
@@ -630,19 +655,31 @@
+ * Loads a WMC from the database.
+ * @param integer $wmc_id the ID of the WMC document in the database table "mb_user_wmc"
function createObjFromWMC_id($wmc_id){
db_select_db(DB, $con);
- $sql = "SELECT wmc FROM mb_user_wmc WHERE wmc_id = '" . $wmc_id . "'";
+ $sql = "SELECT wmc FROM mb_user_wmc WHERE wmc_id = $1";
+ $v = array($wmc_id);
+ $t = array("i");
$wmc = db_fetch_row($res);
$this->createObjFromWMC_xml($wmc[0]);
$this->monitoringIsOn = true;
+ * Loads a WMC from an actual WMC XML document.
+ * @param string $data the data from the XML file
function createObjFromWMC_xml($data){
# $data = str_replace("&", "&", $data);
@@ -1022,6 +1059,16 @@
//return $verbose;
+ * Creates JS code manipulating the map and wms objects,
+ * by this displaying the WMC
+ * @param string $target the link to the map object, f.e. "parent." or "window.opener."
+ * @param string $mapObj the name of the map object, f.e. "mapframe1"
+ * @param string $action "load", "merge" or "append"
+ * @return string the JS code
function createJsObjFromWMC($target, $mapObj, $action){
@@ -1043,7 +1090,7 @@
// general extension
if (count($this->wmc_general_extension) > 0) {
- $json = new Services_JSON();
$wmc_string .= $target . "restoredWmcExtensionData = " . $json->encode($this->wmc_general_extension) . ";\n";
@@ -1106,7 +1153,7 @@
$this->wmc_wms_serviceURL[$i] ."','" .
$this->wmc_layer_style_legendurl[$i][0] ."','','".
$wms_data_format ."','text/html','application/vnd.ogc.se_xml','".
- $this->wmc_bBox_SRS ."','1','100');\n";
+ $this->wmc_bBox_SRS ."','1','100','');\n";
$added_wms[count($added_wms)] = $current_wms;
$cnt_wms++;
@@ -1319,7 +1366,6 @@
$wmc_string .= "\t". $target . "setMapRequest(old_mapObj[i].frameName);\n";
$wmc_string .= "}\n";
$wmc_string .= $target . "mb_execloadWmsSubFunctions();\n";
- $wmc_string .= $target . "mb_execloadWmcSubFunctions();\n";
// $e = new mb_exception("js code: " . $wmc_string);
return $wmc_string;
Modified: trunk/mapbender/http/classes/class_wms.php
--- trunk/mapbender/http/classes/class_wms.php 2008-04-23 13:21:04 UTC (rev 2405)
+++ trunk/mapbender/http/classes/class_wms.php 2008-04-23 15:59:31 UTC (rev 2406)
@@ -59,10 +59,16 @@
var $data_format = array();
var $objLayer = array();
+ var $wms_supportsld;
+ var $wms_userlayer;
+ var $wms_userstyle;
+ var $wms_remotewfs;
var $gui_wms_mapformat;
var $gui_wms_featureinfoformat;
var $gui_wms_exceptionformat;
var $gui_wms_epsg;
+ var $gui_wms_sldurl;
var $default_epsg = 0;
var $overwrite = true;
@@ -94,8 +100,7 @@
-// xml_parse_into_struct($parser,$this->wms_getcapabilities_doc,$values,$tags);
- xml_parse_into_struct($parser,$data,$values,$tags);
+ xml_parse_into_struct($parser,$this->wms_getcapabilities_doc,$values,$tags);
$code = xml_get_error_code($parser);
if ($code) {
@@ -341,7 +346,14 @@
$section = "";
+ /* sld section */
+ if(mb_strtoupper($element[tag]) == "USERDEFINEDSYMBOLIZATION" && $element[type] == "complete"){
+ $this->wms_supportsld = $element[attributes]["SupportSLD"];
+ $this->wms_userlayer = $element[attributes]["UserLayer"];
+ $this->wms_userstyle = $element[attributes]["UserStyle"];
+ $this->wms_remotewfs = $element[attributes]["RemoteWFS"];
/*layer section*/
if(mb_strtoupper($element[tag]) == "LAYER"){
$section = "layer";
@@ -600,7 +612,22 @@
for($i=0; $i<count($this->objLayer); $i++){
$this->objLayer[$i]->layer_pos=$i;
+ /* fill sld variables when empty */
+ if($this->wms_supportsld == ""){
+ $this->wms_supportsld = 0;
+ if($this->wms_userlayer == ""){
+ $this->wms_userlayer = 0;
+ if($this->wms_userstyle == ""){
+ $this->wms_userstyle = 0;
+ if($this->wms_remotewfs == ""){
+ $this->wms_remotewfs = 0;
function displayWMS(){
echo "<br>id: " . $this->wms_id . " <br>";
echo "version: " . $this->wms_version . " <br>";
@@ -616,6 +643,7 @@
echo "wms_srs: " . $this->objLayer[0]->wms_srs1 . " <br>";
echo "gui_wms_visible: " . $this->gui_wms_visible . " <br>";
echo "gui_wms_opacity: " . $this->gui_wms_opacity . " <br>";
+ echo "support_sld: " . $this->wms_supportsld . " <br>";
for($i=0; $i<count($this->data_type);$i++){
echo $this->data_type[$i]. " -> ".$this->data_format[$i]. "<br>";
@@ -678,7 +706,8 @@
"'" . $this->gui_wms_exceptionformat . "'," .
"'" . $this->gui_wms_epsg ."'," .
"'" . $this->gui_wms_visible ."'," .
- "'" . $this->gui_wms_opacity ."" .
+ "'" . $this->gui_wms_opacity ."'," .
+ "'" . $this->gui_wms_sldurl ."" .
echo $add_wms_string;
@@ -769,7 +798,8 @@
$this->gui_wms_exceptionformat . "','".
$this->gui_wms_epsg ."','".
$this->gui_wms_visible ."','".
- $this->gui_wms_opacity ."');\n");
+ $this->gui_wms_opacity ."','".
+ $this->gui_wms_sldurl ."');\n");
for($i=0;$i<count($this->data_format);$i++){
if($parent){
@@ -846,25 +876,27 @@
global $con;
$this->checkObj();
- //db_begin();
+ db_begin();
# TABLE wms
$sql = "INSERT INTO wms (wms_version, wms_title, wms_abstract, wms_getcapabilities, wms_getmap, ";
$sql.= "wms_getfeatureinfo, wms_getlegendurl, wms_getcapabilities_doc, wms_upload_url, fees, ";
$sql .= "accessconstraints, contactperson, contactposition, contactorganization, address, city, ";
$sql .= "stateorprovince, postcode, country, contactvoicetelephone, contactfacsimiletelephone, contactelectronicmailaddress, ";
- $sql .= "wms_owner,wms_timestamp) ";
- $sql .= "VALUES($1,$2,$3,$4,$5,$6,$7,$8,$9,$10,$11,$12,$13,$14,$15,$16,$17,$18,$19,$20,$21,$22,$23,$24)";
+ $sql .= "wms_owner,wms_timestamp, ";
+ $sql .= "wms_supportsld, wms_userlayer, wms_userstyle, wms_remotewfs) ";
+ $sql .= "VALUES($1,$2,$3,$4,$5,$6,$7,$8,$9,$10,$11,$12,$13,$14,$15,$16,$17,$18,$19,$20,$21,$22,$23,$24,$25,$26,$27,$28)";
$v = array($this->wms_version,$this->wms_title,$this->wms_abstract,$this->wms_getcapabilities,
- $this->wms_getmap,$this->wms_getfeatureinfo,$this->wms_getlegendurl,"",
+ $this->wms_getmap,$this->wms_getfeatureinfo,$this->wms_getlegendurl,$this->wms_getcapabilities_doc,
$this->wms_upload_url,$this->fees,$this->accessconstraints,$this->contactperson,$this->contactposition,
$this->contactorganization,$this->address,$this->city,$this->stateorprovince,$this->postcode,$this->country,
$this->contactvoicetelephone,$this->contactfacsimiletelephone,$this->contactelectronicmailaddress,
- $_SESSION['mb_user_id'],strtotime("now"));
- $t = array('s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','i','i');
+ $_SESSION['mb_user_id'],strtotime("now"),
+ $this->wms_supportsld,$this->wms_userlayer,$this->wms_userstyle,$this->wms_remotewfs );
+ $t = array('s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','i','i','s','s','s','s');
if(!$res){
- ////db_rollback();
+ db_rollback();
$myWMS = db_insert_id($con,'wms', 'wms_id');
@@ -902,9 +934,9 @@
$t = array('s','i','i','s','s','s','s');
if(!$res){
+ db_rollback();
- //db_commit();
+ db_commit();
#Changes JW
$this->wms_id = $myWMS;
@@ -931,7 +963,7 @@
$t = array('i','i','s','s','s','i','i','i','s','s','s');
if(!$res){
+ db_rollback();
else {
# save the id of each layer: set param2 true
@@ -955,7 +987,7 @@
$l_id = $row['layer_id'];
else{
+ db_rollback();
$e = new mb_exception("Not found: ".$this->objLayer[$i]->layer_name);
return;
@@ -1000,7 +1032,7 @@
if(!$res){
+ db_rollback();
else {
@@ -1034,7 +1066,7 @@
#$e = new mb_exception("name des insert styles und fkey_layer_id: ".$layer_style_name." --- ".$this->objLayer[$i]->db_id);
if(!$res){
+ db_rollback();
function appendGuiLayer($i,$myWMS,$gui_id){
@@ -1055,7 +1087,7 @@
$t = array('s','i','i','i','i','i','i','i','i','i','i','s');
if(!$res){
+ db_rollback();
function insertSRS($myWMS){
@@ -1065,7 +1097,7 @@
$t = array('i','s');
if(!$res){
- //db_rollback();
+ db_rollback();
@@ -1077,7 +1109,7 @@
$t = array('i','s','s');
if(!$res){
+ db_rollback();
@@ -1096,7 +1128,7 @@
$t = array('i','s','d','d','d','d');
if(!$res){
+ db_rollback();
@@ -1115,7 +1147,7 @@
if(!$res){
+ db_rollback();
@@ -1147,10 +1179,9 @@
$sql_insertKeyword .= "VALUES ($1)";
$v1 = array($k[$j]);
$t1 = array('s');
- echo $k[$j];
$res_insertKeyword = db_prep_query($sql_insertKeyword,$v1,$t1);
if(!$res_insertKeyword){
- //db_rollback();
+ db_rollback();
@@ -1169,13 +1200,13 @@
$t1 = array('i','i');
$res1 = db_prep_query($sql1,$v1,$t1);
if(!$res1){
+ db_rollback();
function updateObjInDB($myWMS){
- //db_begin();
+ db_begin();
$sql = "UPDATE wms SET ";
$sql .= "wms_version = $1 ,";
@@ -1186,17 +1217,22 @@
$sql .= "wms_getcapabilities_doc = $6 ,";
$sql .= "wms_upload_url = $7, ";
$sql .= "wms_owner = $8, ";
- $sql .= "wms_timestamp = $9 ";
- $sql .= " WHERE wms_id = $10";
+ $sql .= "wms_timestamp = $9, ";
+ $sql .= "wms_supportsld = $10, ";
+ $sql .= "wms_userlayer = $11, ";
+ $sql .= "wms_userstyle = $12, ";
+ $sql .= "wms_remotewfs = $13 ";
+ $sql .= " WHERE wms_id = $14";
$v = array($this->wms_version,$this->wms_getcapabilities,
- $this->wms_getcapabilities_doc,$this->wms_upload_url,$_SESSION["mb_user_id"],strtotime("now"),$myWMS);
- $t = array('s','s','s','s','s','s','s','i','i','i');
+ $this->wms_getcapabilities_doc,$this->wms_upload_url,$_SESSION["mb_user_id"],strtotime("now"),
+ $this->wms_supportsld,$this->wms_userlayer,$this->wms_userstyle,$this->wms_remotewfs,$myWMS);
+ $t = array('s','s','s','s','s','s','s','i','i','s','s','s','s','i');
if(!$res){
- //db_rollback();
+ db_rollback();
if($this->overwrite == true){
@@ -1225,7 +1261,7 @@
$t = array('s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','i');
if(!$res){
- //db_rollback();
+ db_rollback();
@@ -1235,7 +1271,7 @@
$t = array('i');
if(!$res){
- //db_rollback();
+ db_rollback();
$this->insertSRS($myWMS);
@@ -1244,7 +1280,7 @@
$t = array('i');
if(!$res){
- //db_rollback();
+ db_rollback();
$this->insertFormat($myWMS);
@@ -1268,7 +1304,7 @@
if(!$res){
- //db_rollback();
+ db_rollback();
# update or insert?
@@ -1306,7 +1342,7 @@
- //db_commit();
+ db_commit();
return;
function updateGuiLayer($i,$myWMS,$gui_id){
@@ -1318,7 +1354,7 @@
else{
- //db_rollback();
+ db_rollback();
$e = new mb_exception("Not found: ".$this->objLayer[$i]->layer_name. " in gui: ".$gui_id);
return;
@@ -1336,7 +1372,7 @@
$res1 = db_prep_query($sql1,$v,$t);
if(!$res1){
- //db_rollback();
+ db_rollback();
if($this->objLayer[$i]->layer_queryable == 1){
@@ -1347,7 +1383,7 @@
if(!$res1){
- //db_rollback();
+ db_rollback();
if($row["gui_layer_minscale"] < $this->objLayer[$i]->layer_minscale){
@@ -1356,7 +1392,7 @@
$v = array($this->objLayer[$i]->layer_minscale,$l_id,$gui_id);
$t = array('i','i','s');
- if(!$res1){//db_rollback();
+ if(!$res1){db_rollback();
if($row["gui_layer_maxscale"] > $this->objLayer[$i]->layer_maxscale){
@@ -1365,7 +1401,7 @@
$v = array($this->objLayer[$i]->layer_maxscale,$l_id,$gui_id);
@@ -1380,7 +1416,12 @@
unset($mySubmit);
$myGUI[$cnt] = $row["fkey_gui_id"];
- $sql = "UPDATE gui_wms SET ";
+ $sql = "UPDATE gui_wms SET ";
+ $v = array();
+ $t = array();
+ $paramCount = 0;
for($i=0; $i<count($this->data_type); $i++){
# gui_wms_mapformat
if(mb_strtolower($this->data_type[$i]) == "map" && mb_strtolower($this->data_format[$i]) == mb_strtolower($row["gui_wms_mapformat"])){
@@ -1396,17 +1437,26 @@
if(!$myMapFormat){
- $sql .= "gui_wms_mapformat = '".$this->gui_wms_mapformat."' ";
+ $paramCount++;
+ $sql .= "gui_wms_mapformat = $" . $paramCount . " ";
$mySubmit = true;
+ array_push($v, $this->gui_wms_mapformat);
if(!$myFeatureInfoFormat){
if($mySubmit){ $sql .= ",";}
- $sql .= "gui_wms_featureinfoformat = '".$this->gui_wms_featureinfoformat."' ";
+ $paramCount++;
+ $sql .= "gui_wms_featureinfoformat = $" . $paramCount . " ";
+ array_push($v, $this->gui_wms_featureinfoformat);
$mySubmit = true;
if(!$myExceptionFormat){
- $sql .= "gui_wms_exceptionformat = '".$this->gui_wms_exceptionformat."' ";
+ $paramCount++;
+ $sql .= "gui_wms_exceptionformat = $" . $paramCount ." ";
+ array_push($v, $this->gui_wms_exceptionformat);
$mySubmit = true;
@@ -1418,12 +1468,30 @@
if(!$myGUI_EPSG){
- $sql .= "gui_wms_epsg = '".$this->gui_wms_epsg."' ";
+ $paramCount++;
+ $sql .= "gui_wms_epsg = $" . $paramCount . " ";
+ array_push($v, $this->gui_wms_epsg);
$mySubmit = true;
- $sql .= " WHERE fkey_gui_id = '".$row["fkey_gui_id"]."' AND fkey_wms_id = " . $myWMS;
+ $paramCount++;
+ $sql .= " WHERE fkey_gui_id = $" . $paramCount . " ";
+ array_push($v, $row["fkey_gui_id"]);
+ $paramCount++;
+ $sql .= "AND fkey_wms_id = $" . $paramCount;
+ array_push($v, $myWMS);
+ array_push($t, "i");
if($mySubmit){
- $this->transaction($sql);
+ if(!$res){
+ db_rollback();
+ echo "<pre>".$sql."</pre><br> <br><p>";
+ echo db_error();
+ echo "<br /> UPDATE ERROR -> KILL PROCESS AND ROLLBACK....................no update<br><br>";
+ $e = new mb_exception("class_wms.php: transaction: Transaction aborted, rollback.");
$cnt++;
@@ -1439,26 +1507,7 @@
function getCapabilitiesDoc() {
return $this->wms_getcapabilities_doc;
- function transaction($sql){
- #echo "<hr>". $sql;
- $ok = db_query($sql);
- if(!$ok){
- echo "<pre>".$sql."</pre><br> <br><p>";
- $error = db_error();
- $sql = "ROLLBACK";
- if(SYS_DBTYPE=="pgsql")
- $sql = "SET AUTOCOMMIT=0";
- else
- $sql = "SET AUTOCOMMIT=1";
- echo $error;
- echo "<br /> UPDATE ERROR -> KILL PROCESS AND ROLLBACK....................no update<br><br>";
* creatObjfromDB
@@ -1481,7 +1530,7 @@
$this->gui_wms_epsg=$row["gui_wms_epsg"];
$this->gui_wms_visible = $row["gui_wms_visible"];
$this->gui_wms_opacity = $row["gui_wms_opacity"];
+ $this->gui_wms_sldurl = $row["gui_wms_sldurl"];
$sql = "Select * from wms where wms_id = $1 ";
$v = array($wms_id);
@@ -1510,6 +1559,10 @@
$this->wms_getcapabilities_doc = $row2["wms_getcapabilities_doc"];
$this->wms_filter = $row2["wms_filter"];
+ $this->wms_supportsld = $row2["wms_supportsld"];
+ $this->wms_userlayer = $row2["wms_userlayer"];
+ $this->wms_userstyle = $row2["wms_userstyle"];
+ $this->wms_remotewfs = $row2["wms_remotewfs"];
$count_wms++;
More information about the Mapbender_commits
