[Mapbender-commits] r2417 - trunk/mapbender/http/classes
svn_mapbender at osgeo.org
Wed Apr 23 16:31:28 EDT 2008
Author: nimix
Date: 2008-04-23 16:31:28 -0400 (Wed, 23 Apr 2008)
New Revision: 2417
trunk/mapbender/http/classes/class_wfs.php
remove dublicate file content
Modified: trunk/mapbender/http/classes/class_wfs.php
--- trunk/mapbender/http/classes/class_wfs.php 2008-04-23 20:28:37 UTC (rev 2416)
+++ trunk/mapbender/http/classes/class_wfs.php 2008-04-23 20:31:28 UTC (rev 2417)
@@ -809,815 +809,4 @@
-?><?php
-# $Id$
-# http://www.mapbender.org/index.php/class_wfs.php
-# Copyright (C) 2002 CCGIS
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2, or (at your option)
-# any later version.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
-# GNU General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-* class for wfs-objects
-include_once(dirname(__FILE__)."/../../conf/mapbender.conf");
-require_once(dirname(__FILE__)."/class_connector.php");
-require_once(dirname(__FILE__)."/class_mb_exception.php");
-require_once(dirname(__FILE__)."/class_administration.php");
-class wfs {
- var $wfs_id;
- var $wfs_version;
- var $wfs_name;
- var $wfs_title;
- var $wfs_abstract;
- var $wfs_getcapabilities;
- var $wfs_getcapabilities_doc; //new SB 2007-08-09
- var $wfs_describefeaturetype;
- var $wfs_describefeaturetype_namespace = array();
- var $wfs_getfeature;
- var $wfs_transaction;
- var $wfs_upload_url; //new SB 2007-08-09
- //new WFS 1.0.0 -- SB 2007-08-06
- var $fees;
- var $accessconstraints;
- var $wfs_featuretype = array();
-function wfs() {
-function createObjFromXML($url){
- $x = new connector($url);
- $data = $x->file;
- #$data = implode("",file($url));
- if(!$data){
- echo "Unable to open document: ".$url;
- die;
- $values = null;
- $tags = null;
- $admin = new administration();
- $this->wfs_getcapabilities_doc = $admin->char_encode($data);
- $this->wfs_upload_url = $url;
- # for temporary wfs a id has to be created...
- $this->wfs_id = "id_" . substr(md5(rand()),0,6);
- $parser = xml_parser_create(CHARSET);
- xml_parser_set_option($parser,XML_OPTION_CASE_FOLDING,0);
- xml_parser_set_option($parser,XML_OPTION_SKIP_WHITE,1);
- xml_parser_set_option($parser,XML_OPTION_TARGET_ENCODING,CHARSET);
- xml_parse_into_struct($parser,$this->wfs_getcapabilities_doc,$values,$tags);
- //xml_parse_into_struct($parser,$data,$values,$tags);
- xml_parser_free($parser);
- $section = false;
- $request = false;
- $featuretype_name = false;
- $featuretype_title = false;
- $featuretype_abstract = false;
- $featuretype_srs = false;
- foreach ($values as $element) {
- if(strtoupper($element[tag]) == "WFS_CAPABILITIES" && $element[type] == "open"){
- $this->wfs_version = $element[attributes][version];
- if(strtoupper($element[tag]) == "NAME" && $element[level] == '3'){
- $this->wfs_name = $element[value];
- if(strtoupper($element[tag]) == "TITLE" && $element[level] == '3'){
- $this->wfs_title = $this->stripEndlineAndCarriageReturn($element[value]);
- if(strtoupper($element[tag]) == "ABSTRACT" && $element[level] == '3'){
- $this->wfs_abstract = $this->stripEndlineAndCarriageReturn($element[value]);
- if(strtolower($element[tag]) == "fees"){
- $this->fees = $element[value];
- if(strtolower($element[tag]) == "accessconstraints"){
- $this->accessconstraints = $element[value];
- /*capability section*/
- if($this->wfs_version == "1.0.0"){
- # getCapabilities
- if(strtoupper($element[tag]) == "GETCAPABILITIES" && $element[type] == "open"){
- $section = "getcapabilities";
- if($section == "getcapabilities" && strtoupper($element[tag]) == "GET"){
- $this->wfs_getcapabilities = $element[attributes][onlineResource];
- # descriptFeatureType
- if(strtoupper($element[tag]) == "DESCRIBEFEATURETYPE" && $element[type] == "open"){
- $section = "describefeaturetype";
- $this->wfs_describefeaturetype = $element[attributes][onlineResource];
- if($section == "describefeaturetype" && strtoupper($element[tag]) == "GET"){
- # getFeature
- if(strtoupper($element[tag]) == "GETFEATURE" && $element[type] == "open"){
- $section = "getfeature";
- if($section == "getfeature" && strtoupper($element[tag]) == "GET"){
- $this->wfs_getfeature = $element[attributes][onlineResource];
- if(strtoupper($element[tag]) == "GETFEATURE" && $element[type] == "close"){
- $section = "";
- # transaction
- if(strtoupper($element[tag]) == "TRANSACTION" && $element[type] == "open"){
- $section = "transaction";
- if($section == "transaction" && strtoupper($element[tag]) == "GET"){
- $this->wfs_transaction = $element[attributes][onlineResource];
- if(strtoupper($element[tag]) == "TRANSACTION" && $element[type] == "close"){
- $section = "";
- if(strtoupper($element[tag]) == "FEATURETYPE" && $element[type] == "open"){
- $section = "featuretype";
- if($section == "featuretype" && strtoupper($element[tag]) == "NAME"){
- $featuretype_name = $element[value];
- if($section == "featuretype" && strtoupper($element[tag]) == "TITLE"){
- $featuretype_title = $this->stripEndlineAndCarriageReturn($element[value]);
- if($section == "featuretype" && strtoupper($element[tag]) == "ABSTRACT"){
- $featuretype_abstract = $this->$element[value];
- if($section == "featuretype" && strtoupper($element[tag]) == "SRS"){
- $featuretype_srs = $element[value];
- $this->addFeaturetype($featuretype_name,$featuretype_title,$featuretype_abstract,$featuretype_srs,$this->wfs_describefeaturetype,$this->wfs_version);
-function displayWFS(){
- echo "id: " . $this->wfs_id . " <br>";
- echo "version: " . $this->wfs_version . " <br>";
- echo "name: " . $this->wfs_name . " <br>";
- echo "title: " . $this->wfs_title . " <br>";
- echo "abstract: " . $this->wfs_abstract . " <br>";
- echo "capabilitiesrequest: " . $this->wfs_getcapabilities . " <br>";
- echo "describefeaturetype: " . $this->wfs_describefeaturetype . " <br>";
- echo "getfeature: " . $this->wfs_getfeature . " <br>";
- echo "transaction: " . $this->wfs_transaction . " <br>";
- for($i=0; $i<count($this->wfs_featuretype); $i++){
- echo "<hr>";
- echo "name: ". $this->wfs_featuretype[$i]->featuretype_name . "<br>";
- echo "title: ". $this->wfs_featuretype[$i]->featuretype_title . "<br>";
- echo "abstract: ". $this->wfs_featuretype[$i]->featuretype_abstract . "<br>";
- echo "srs: ". $this->wfs_featuretype[$i]->featuretype_srs . "<br>";
- for($j=0; $j<count($this->wfs_featuretype[$i]->featuretype_element);$j++){
- echo " element: " . $this->wfs_featuretype[$i]->featuretype_element[$j]["name"] ." - ".$this->wfs_featuretype[$i]->featuretype_element[$j]["type"]."<br>";
- for($j=0; $j<count($this->wfs_featuretype[$i]->featuretype_namespace);$j++){
- echo " namespace: " . $this->wfs_featuretype[$i]->featuretype_namespace[$j]["name"] ." - ".$this->wfs_featuretype[$i]->featuretype_namespace[$j]["value"]."<br>";
-function addFeaturetype($name,$title,$abstract,$srs,$url,$version){
- $this->wfs_featuretype[count($this->wfs_featuretype)] = new featuretype($name,$title,$abstract,$srs,$url,$version);
- function stripEndlineAndCarriageReturn($string) {
- return preg_replace("/\n/", "", preg_replace("/\r/", " ", $string));
-function createJsObjFromWFS($parent){
- if(!$this->wfs_title || $this->wfs_title == ""){
- echo "alert('Error: no valid capabilities-document !!');";
- die; exit;
- if($parent){
- echo "parent.";
- print("add_wfs('".
- $this->wfs_id ."','".
- $this->wfs_version ."','".
- $this->wfs_title ."','".
- $this->wfs_abstract ."','".
- $this->wfs_getcapabilities ."','" .
- $this->wfs_describefeaturetype ."');");
- if($parent){
- echo "parent.";
- print ("wfs_add_featuretype('".
- $this->wfs_featuretype[$i]->featuretype_name ."','".
- $this->wfs_featuretype[$i]->featuretype_title . "','".
- $this->wfs_featuretype[$i]->featuretype_abstract . "','".
- $this->wfs_featuretype[$i]->featuretype_srs ."','".
- $this->wfs_featuretype[$i]->featuretype_geomtype ."');");
- if($parent){
- echo "parent.";
- print("wfs_add_featuretype_element('".$this->wfs_featuretype[$i]->featuretype_element[$j]["name"]."', '".$this->wfs_featuretype[$i]->featuretype_element[$j]["type"]."', ".$j.", ".$i.");");
- if($parent){
- echo "parent.";
- print("wfs_add_featuretype_namespace('".$this->wfs_featuretype[$i]->featuretype_namespace[$j]["name"]."', '".$this->wfs_featuretype[$i]->featuretype_namespace[$j]["value"]."', ".$j.", ".$i.");");
- * Inserts this WFS in the database
-function insertWfs() {
- global $DBSERVER,$DB,$OWNER,$PW;
- $con = db_connect($DBSERVER,$OWNER,$PW);
- db_select_db($DB,$con);
- $sql = "INSERT INTO wfs (wfs_version, wfs_name, wfs_title, wfs_abstract, ";
- $sql .= "wfs_getcapabilities, wfs_getcapabilities_doc, wfs_upload_url, ";
- $sql .= "wfs_describefeaturetype, wfs_getfeature, wfs_transaction, fees, ";
- $sql .= "accessconstraints, wfs_owner, wfs_timestamp) ";
- $sql .= "VALUES($1,$2,$3,$4,$5,$6,$7,$8,$9,$10,$11,$12,$13,$14)";
- $v = array($this->wfs_version, $this->wfs_name, $this->wfs_title,
- $this->wfs_abstract, $this->wfs_getcapabilities, $this->wfs_getcapabilities_doc,
- $this->wfs_upload_url, $this->wfs_describefeaturetype, $this->wfs_getfeature,
- $this->wfs_transaction, $this->fees, $this->accessconstraints,
- $_SESSION["mb_user_id"], strtotime("now"));
- $t = array('s', 's', 's', 's', 's', 's', 's', 's', 's', 's', 's', 's', 'i', 'i');
- $res = db_prep_query($sql,$v,$t);
- if(!$res){
- db_rollback();
- $e = new mb_exception("Error while saving WFS to DB. Rollback performed.");
- return false;
- $this->wfs_id = db_insert_id($con,'wfs','wfs_id');
- return true;
-function updateWfs() {
- $sql = "UPDATE wfs SET wfs_version = $1, wfs_name = $2, wfs_title = $3, ";
- $sql .= "wfs_abstract = $4, wfs_getcapabilities = $5, wfs_getcapabilities_doc = $6, ";
- $sql .= "wfs_upload_url = $7, wfs_describefeaturetype = $8, wfs_getfeature = $9, ";
- $sql .= "wfs_transaction = $10, fees = $11, accessconstraints = $12, wfs_owner = $13, ";
- $sql .= "wfs_timestamp = $14 ";
- $sql .= "WHERE wfs_id = $15";
- //echo $sql."<br />";
- $v = array($this->wfs_version, $this->wfs_name, $this->wfs_title, $this->wfs_abstract,
- $this->wfs_getcapabilities, $this->wfs_getcapabilities_doc, $this->wfs_upload_url,
- $this->wfs_describefeaturetype, $this->wfs_getfeature, $this->wfs_transaction,
- $this->fees, $this->accessconstraints, $_SESSION["mb_user_id"],strtotime("now"),
- $this->wfs_id);
- $t = array('s', 's', 's', 's', 's', 's', 's', 's' ,'s' ,'s' ,'s' ,'s' ,'i' ,'i' ,'i');
- if(!$res){
- db_rollback();
- return false;
- return true;
-* wfs2db
-* this function saves the class information to the mapbender database
-* @return boolean true if sucessful false otherwise
-function wfs2db($gui_id){
- db_begin();
- // check if WFS already might exists (it might exist when wfs_id is numeric)
- $wfs_exists = is_numeric($this->wfs_id);
- // if it might exist, update it
- if ($wfs_exists) {
- // but check first if it really exists in the database
- $sql = "SELECT * FROM wfs WHERE wfs_id = $1;";
- $v = array($this->wfs_id);
- $t = array("i");
- $res = db_prep_query($sql, $v, $t);
- if($res){
- $this->updateWfs();
- // if not, insert as new WFS
- else {
- $this->insertWfs();
- // if it does not exist, insert as new WFS
- else {
- # delete featuretypes from DB that does not exist and find the ids
- $sql = "SELECT * FROM wfs_featuretype WHERE fkey_wfs_id = $1;";
- $t = array("i");
- $res_ft = db_prep_query($sql, $v, $t);
- $cnt = 0;
- while(db_fetch_row($res_ft)){
- $found = false;
- if($this->wfs_featuretype[$i]->featuretype_name == db_result($res_ft, $cnt, "featuretype_name")){
- $this->wfs_featuretype[$i]->featuretype_id = db_result($res_ft, $cnt, "featuretype_id");
- $found = true;
- break;
- if(!$found){
- $sql = "DELETE FROM wfs_featuretype WHERE featuretype_id = $1 AND fkey_wfs_id = $2";
- $v = array(db_result($res_ft, $cnt, "featuretype_id"), $this->wfs_id);
- $t = array('i','i');
- if(!$res){db_rollback();$e = new mb_exception("Error while saving WFS to DB. Rollback performed.");return;}
- $cnt++;
- # TABLE wfs_featuretype
- if(!$this->wfs_featuretype[$i]->featuretype_id){
- $sql = "INSERT INTO wfs_featuretype(fkey_wfs_id, featuretype_name, featuretype_title, featuretype_abstract, featuretype_srs) ";
- $sql .= "VALUES($1,$2,$3,$4,$5)";
- $v = array($this->wfs_id,$this->wfs_featuretype[$i]->featuretype_name,$this->wfs_featuretype[$i]->featuretype_title,$this->wfs_featuretype[$i]->featuretype_abstract,$this->wfs_featuretype[$i]->featuretype_srs);
- $t = array('i','s','s','s','s');
- # save the id of each featuretype:
- $this->wfs_featuretype[$i]->featuretype_id = db_insert_id($con,'wfs_featuretype','featuretype_id');
- else{
- $sql = "UPDATE wfs_featuretype SET ";
- $sql .= "featuretype_title = $1,";
- $sql .= "featuretype_abstract = $2,";
- $sql .= "featuretype_srs = $3 ";
- $sql .= "WHERE featuretype_id = $4";
- $v = array($this->wfs_featuretype[$i]->featuretype_title,$this->wfs_featuretype[$i]->featuretype_abstract,$this->wfs_featuretype[$i]->featuretype_srs,$this->wfs_featuretype[$i]->featuretype_id);
- $t = array('s','s','s','i');
- //delete featuretype elements from db and find the ids
- $sql = "SELECT * FROM wfs_element WHERE fkey_featuretype_id = $1;";
- $v = array($this->wfs_featuretype[$i]->featuretype_id);
- $t = array("i");
- $res_el = db_prep_query($sql, $v, $t);
- $cnt = 0;
- while(db_fetch_row($res_el)){
- $found = false;
- for($j=0; $j<count($this->wfs_featuretype[$i]->featuretype_element); $j++){
- if($this->wfs_featuretype[$i]->featuretype_element[$j]["name"] == db_result($res_el, $cnt, "element_name")){
- $this->wfs_featuretype[$i]->featuretype_element[$j]["id"] = db_result($res_el, $cnt, "element_id");
- $found = true;
- break;
- if(!$found){
- $sql = "DELETE FROM wfs_element WHERE element_id = $1 AND fkey_featuretype_id = $2";
- $v = array(db_result($res_el, $cnt, "element_id"), $this->wfs_featuretype[$i]->featuretype_id);
- $cnt++;
- if(!$this->wfs_featuretype[$i]->featuretype_element[$j]["id"]){
- $sql = "INSERT INTO wfs_element(fkey_featuretype_id, element_name,element_type) ";
- $sql .= "VALUES($1, $2, $3);";
- $v = array($this->wfs_featuretype[$i]->featuretype_id, $this->wfs_featuretype[$i]->featuretype_element[$j]["name"], $this->wfs_featuretype[$i]->featuretype_element[$j]["type"]);
- $t = array("s", "s", "s");
- else{
- $sql = "UPDATE wfs_element SET element_type = $1 ";
- $sql .= "WHERE element_id = $2 AND ";
- $sql .= "fkey_featuretype_id = $3;";
- $v = array($this->wfs_featuretype[$i]->featuretype_element[$j]["type"], $this->wfs_featuretype[$i]->featuretype_element[$j]["id"], $this->wfs_featuretype[$i]->featuretype_id);
- $t = array("s", "i", "i");
- if (!$res) {
- db_rollback();
- return;
- $sql = "DELETE FROM wfs_featuretype_namespace WHERE ";
- $sql .= "fkey_wfs_id = $1 AND fkey_featuretype_id = $2";
- $v = array($this->wfs_id, $this->wfs_featuretype[$i]->featuretype_id);
- $t = array("i", "i");
- if (!$res) {
- db_rollback();
- return;
- $sql = "INSERT INTO wfs_featuretype_namespace ";
- $sql .= "(fkey_wfs_id, fkey_featuretype_id, namespace, namespace_location) ";
- $sql .= "VALUES ($1, $2, $3, $4);";
- $v = array($this->wfs_id, $this->wfs_featuretype[$i]->featuretype_id, $this->wfs_featuretype[$i]->featuretype_namespace[$j]["name"], $this->wfs_featuretype[$i]->featuretype_namespace[$j]["value"]);
- $t = array("s", "s", "s", "s");
- if (!$res) {
- db_rollback();
- return;
- # TABLE gui_wfs
- if($gui_id){
- $sql ="INSERT INTO gui_wfs (fkey_gui_id, fkey_wfs_id)";
- $sql .= "VALUES($1, $2);";
- $v = array($gui_id, $this->wfs_id);
- $t = array("s", "i");
- if (!$res) {
- db_rollback();
- return;
- //echo "Successfully saved!<br />";
- db_commit();
- return true;
-* updateObjFromXML
-* this function regets the information from the xml (update)
-* @return boolean true if successful, false otherwise
-function updateObjFromXML($url){
- $data = $x->file;
- if(!$data){
- $e = new mb_exception("Unable to open document: ".$url);
- return false;
- $values = null;
- $tags = null;
- $this->wfs_featuretype = array();
- //$this->wfs_id = "id_" . substr(md5(rand()),0,6);
- $section = false;
- $request = false;
-/* if(strtoupper($element[tag]) == "TITLE" && $element[level] == '3'){
- # getCapabilities
- # getFeature
- $section = "";
- # transaction
- $section = "";
- return true;
-* creatObjfromDB
-* this function fills the object with wfs information from db
-* @param int the id of wfs to get the information from
-function createObjFromDB($wfs_id){
- $v = array($wfs_id);
- $t = array("i");
- $cnt = 0;
- while(db_fetch_row($res)){
- $this->wfs_id = db_result($res, $cnt, "wfs_id");
- $this->wfs_version = db_result($res, $cnt, "wfs_version");
- $this->wfs_name = db_result($res, $cnt, "wfs_name");
- $this->wfs_title = db_result($res, $cnt, "wfs_title");
- $this->wfs_abstract = db_result($res, $cnt, "wfs_abstract");
- $this->wfs_getcapabilities = db_result($res, $cnt, "wfs_getcapabilities");
- $this->wfs_getcapabilities_doc = db_result($res, $cnt, "wfs_getcapabilities_doc");
- $this->wfs_upload_url = db_result($res, $cnt, "wfs_upload_url");
- $this->wfs_describefeaturetype = db_result($res, $cnt, "wfs_describefeaturetype");
- $this->wfs_getfeature = db_result($res, $cnt, "wfs_getfeature");
- $this->wfs_transaction = db_result($res, $cnt, "wfs_transaction");
- $this->fees = db_result($res, $cnt, "fees");
- $this->accessconstraints = db_result($res, $cnt, "accessconstraints");
- $this->wfs_owner = db_result($res, $cnt, "wfs_owner");
- $this->wfs_timestamp = db_result($res, $cnt, "wfs_timestamp");
- $sql_fe = "SELECT * FROM wfs_featuretype WHERE fkey_wfs_id = $1 ORDER BY featuretype_id";
- $t = array("i");
- $res_fe = db_prep_query($sql_fe, $v, $t);
- $cnt_fe = 0;
- while(db_fetch_row($res_fe)){
- $c = count($this->wfs_featuretype);
-// $this->wfs_featuretype[$c]->featuretype_id = db_result($res_fe, $cnt_fe, "featuretype_id");
- $this->wfs_featuretype[$c]->featuretype_name = db_result($res_fe, $cnt_fe, "featuretype_name");
- $this->wfs_featuretype[$c]->featuretype_title = db_result($res_fe, $cnt_fe, "featuretype_title");
- $this->wfs_featuretype[$c]->featuretype_abstract = db_result($res_fe, $cnt_fe, "featuretype_abstract");
- $this->wfs_featuretype[$c]->featuretype_srs = db_result($res_fe, $cnt_fe, "featuretype_srs");
- $sql_el = "SELECT * FROM wfs_element WHERE fkey_featuretype_id = $1 ORDER BY element_id";
- $v = array(db_result($res_fe, $cnt_fe, "featuretype_id"));
- $t = array("i");
- $res_el = db_prep_query($sql_el, $v, $t);
- $cnt_el = 0;
- $z = count($this->wfs_featuretype[$c]->featuretype_element);
- $this->wfs_featuretype[$c]->featuretype_element[$z]["name"] = db_result($res_el, $cnt_el, "element_name");
- $this->wfs_featuretype[$c]->featuretype_element[$z]["type"] = db_result($res_el, $cnt_el, "element_type");
- $cnt_el++;
- $sql_ns = "SELECT * FROM wfs_featuretype_namespace WHERE fkey_featuretype_id = $1 ORDER BY namespace";
- $t = array("i");
- $res_ns = db_prep_query($sql_ns, $v, $t);
- $cnt_ns = 0;
- while(db_fetch_row($res_ns)){
- $z = count($this->wfs_featuretype[$c]->featuretype_namespace);
- $this->wfs_featuretype[$c]->featuretype_namespace[$z]["name"] = db_result($res_ns, $cnt_ns, "namespace");
- $this->wfs_featuretype[$c]->featuretype_namespace[$z]["value"] = db_result($res_ns, $cnt_ns, "namespace_location");
- $cnt_ns++;
- $cnt_fe++;
- $cnt++;
-/** end createObjfromDB **/
- public function getallwfs($userid){
- $this->wfs_id = array();
- $this->wfs_name = array();
- $this->wfs_title = array();
- $this->wfs_abstract = array();
- if($userid){
- $sql = "SELECT * FROM wfs WHERE wfs_owner = $1";
- $v = array($userid);
- $t = array('i');
- else{
- $sql = "SELECT * FROM wfs";
- $res = db_query($sql);
- $cnt = 0;
- while ($row = db_fetch_array($res)){
- $this->wfs_version[$cnt] = $row["wfs_version"];
- $this->wfs_id[$cnt] = $row["wfs_id"];
- $this->wfs_name[$cnt] = $row["wfs_name"];
- $this->wfs_title[$cnt] = $row["wfs_title"];
- $this->wfs_abstract[$cnt] = $row["wfs_abstract"];
- $this->wfs_getcapabilities[$cnt] = $row["wfs_getcapabilities"];
- $this->wfs_describefeaturetype[$cnt] = $row["wfs_describefeaturetype"];
- $this->wfs_getfeature[$cnt] = $row["wfs_getfeature"];
- $cnt++;
-class featuretype extends wfs{
- var $featuretype_element = array();
- var $featuretype_namespace = array();
- function featuretype($name,$title,$abstract,$srs,$url,$version){
- $url .= "&SERVICE=WFS&VERSION=".$version."&REQUEST=DescribeFeatureType&TYPENAME=".$name;
- $this->featuretype_name = $name;
- $this->featuretype_title = $title;
- $this->featuretype_abstract = $abstract;
- $this->featuretype_srs = $srs;
- $y = new connector($url);
- $data = $y->file;
- $parser = xml_parser_create();
- xml_parse_into_struct($parser,$data,$values,$tags);
- if($this->sepNameSpace($element[tag]) == "schema" && $element[type] == "open"){
- $section = "namespace";
-// echo "namespace<br>";
- if($section == "namespace"){
- while (list($k, $val) = each ($element[attributes])) {
- if (substr($k, 0, 5) == "xmlns") {
- $cnt = count($this->featuretype_namespace);
- $match = false;
- for ($i = 0 ; $i < $cnt && $match == false ; $i++) {
- if ($this->sepNameSpace($k) == $this->featuretype_namespace[$i]["name"] && $val == $this->featuretype_namespace[$i]["value"]) {
- $match = true;
- if ($match == false) {
- $this->featuretype_namespace[$cnt]["name"] = $this->sepNameSpace($k);
- $this->featuretype_namespace[$cnt]["value"] = $val;
-// echo "namespace: " . $this->sepNameSpace($k) . " -> " . $val . "<br>";
- if($this->sepNameSpace($element[tag]) == "complexType" && $element[type] == "open"){
- $section = "";
- if($this->sepNameSpace($element[tag]) == "complexContent" && $element[type] == "open"){
- $section = "complexcontent";
-// echo "complexcontent<br>";
- if($section == "complexcontent" && $this->sepNameSpace($element[tag]) == "element" && $element[attributes][name]){
- $cnt = count($this->featuretype_element);
- $this->featuretype_element[$cnt]["name"] = $element[attributes]["name"];
- $this->featuretype_element[$cnt]["type"] = $this->sepNameSpace($element[attributes]["type"]);
-// echo "element: ".$this->featuretype_element[$cnt]["name"]."<br>";
- if($this->sepNameSpace($element[tag]) == "complexContent" && $element[type] == "close"){
- $section = "";
- function sepNameSpace($s){
- $c = strpos($s,":");
- if($c>0){
- return substr($s,$c+1);
- else{
- return $s;
\ No newline at end of file
More information about the Mapbender_commits
