[Mapbender-commits] r2756 - branches/spsneo_dev/build
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri Aug 8 16:03:27 EDT 2008
Author: spsneo
Date: 2008-08-08 16:03:27 -0400 (Fri, 08 Aug 2008)
New Revision: 2756
   branches/spsneo_dev/build/checksum-utils.inc
minor refactoring
Modified: branches/spsneo_dev/build/checksum-utils.inc
--- branches/spsneo_dev/build/checksum-utils.inc	2008-08-08 12:34:37 UTC (rev 2755)
+++ branches/spsneo_dev/build/checksum-utils.inc	2008-08-08 20:03:27 UTC (rev 2756)
@@ -17,7 +17,7 @@
 	if(!is_readable($dir_path)) {
-		echo $dir_path." is not readable.\nPlease make sure you have privilege to build.\nAborting...";
+		echo $dir_path." is not readable.\nPlease make sure you have privilege to build.\nAborting...\n";
 		exit();
@@ -28,7 +28,7 @@
 			if(is_readable($file_path)) {
 				$file_arr[$file] = sha1_file($file_path);
 			} else {
-				echo $file_path." is not readable.\nPlease make sure you have privelege to build.\nAborting...";
+				echo $file_path." is not readable.\nPlease make sure you have privelege to build.\nAborting...\n";
 				exit();
 		} else if (is_dir($file_path) && !preg_match("/^\./", $file)) {
@@ -40,7 +40,6 @@
 	$file_json_string = json_encode($file_arr);
 	$file_json_name = $dir_path."/checksum.json";
 	$file_json_handle = fopen($file_json_name, "w");
@@ -49,6 +48,7 @@
 		exit();
 	fwrite($file_json_handle, $file_json_string);
+	fclose($file_json_handle);
 	//echo "Succesfully created checksums of files in directory: ".$dir_path."\n";
 	return TRUE;
More information about the Mapbender_commits mailing list
